RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
motload-gev-set.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2026 Chris Johns <chrisj@rtems.org>. All rights reserved.
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25
* SUCH DAMAGE.
26
27
28
29
* MOTLoad GEV in NVRAM.
30
31
32
#ifndef _POWERPC_MOTLOAD_GEV_NVRAM_h
33
#define _POWERPC_MOTLOAD_GEV_NVRAM_h
34
35
#include <stddef.h>
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
/* __cplusplus */
40
41
42
* Set the NVRAM base. Setting the base will result in the GEV
43
* variables being scanned and the environment table being set with
44
* any value settings.
45
46
* @param nvram_base Base address if the byte addressable NVRAM
47
48
void
motload_gev_set_nvbase(uintptr_t nvram_base);
49
50
51
* Set the RTEMS network unit for environment vairables. You can set
52
* up to 4 interfaces, 0 to 3. This call can be made in BSP start or
53
* BSP early start.
54
55
* For example if the GEV variable "mot-/dev/enet1-cipa" is set and
56
* this call is made with the unit set 1 the environment variable
57
* "RTEMS_NET_IF_1_IP_ADDR" will be set to the IP address of the GEV
58
* variable.
59
60
* @param unit Network interface unit number, ie `0` for `enet0`
61
62
void
motload_gev_set_net_unit(
const
size_t
unit);
63
64
65
* Set the RTEMS network unit label. You can set up to 4 interfaces, 0
66
* to 3. This call can be made in BSP start or BSP early start.
67
68
69
* @param label Network interface unit label, ie `0` for `em0`
70
71
void
motload_gev_set_net_label(
const
size_t
unit,
const
char
* label);
72
73
#ifdef __cplusplus
74
75
#endif
/* __cplusplus */
76
77
#endif
