RTEMS 6.3
motload-gev-net-env.h
2
3/*
4 * Copyright (c) 2026 Chris Johns <chrisj@rtems.org>. All rights reserved.
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25 * SUCH DAMAGE.
26 */
27
28/*
29 * MOTLoad RTEMS Network Environment Variables
30 *
31 * Set the environment variables based on the GEV settings. The
32 * pattern for scanning follows the parsing that was in EPICS Base's
33 * `setBootConfigFromNVRAM.c`. The code was moved to RTEMS as part of
34 * a clean up of EPICS code.
35 */
36
37#ifndef _POWERPC_MOTLOAD_GEV_NET_ENV_h
38#define _POWERPC_MOTLOAD_GEV_NET_ENV_h
39
40#include <stdbool.h>
41#include <stdint.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47/*
48 * Set the RTEMS network environment vairables from GEV variables for
49 * the specified network interface
50 *
51 * @param nvram_base Base address if the byte addressable NVRAM
52 * @param unit Network interface unit number, ie `0` for `enet0`
53 * @param label Network interface unit label, ie `0` for `em0`
54 */
55void motload_gev_set_net_envs(uintptr_t nvram_base, const size_t unit,
56 const char* label);
57
58#ifdef __cplusplus
59}
60#endif /* __cplusplus */
61
62#endif
