RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
mmctrl-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/mmctrl-header */
54
55
#ifndef _GRLIB_MMCTRL_REGS_H
56
#define _GRLIB_MMCTRL_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/mmctrl */
65
75
84
85
#define MMCTRL_SDCFG1_RF 0x80000000U
86
87
#define MMCTRL_SDCFG1_TRP 0x40000000U
88
89
#define MMCTRL_SDCFG1_TRFC_SHIFT 27
90
#define MMCTRL_SDCFG1_TRFC_MASK 0x38000000U
91
#define MMCTRL_SDCFG1_TRFC_GET( _reg ) \
92
( ( ( _reg ) & MMCTRL_SDCFG1_TRFC_MASK ) >> \
93
MMCTRL_SDCFG1_TRFC_SHIFT )
94
#define MMCTRL_SDCFG1_TRFC_SET( _reg, _val ) \
95
( ( ( _reg ) & ~MMCTRL_SDCFG1_TRFC_MASK ) | \
96
( ( ( _val ) << MMCTRL_SDCFG1_TRFC_SHIFT ) & \
97
MMCTRL_SDCFG1_TRFC_MASK ) )
98
#define MMCTRL_SDCFG1_TRFC( _val ) \
99
100
101
102
#define MMCTRL_SDCFG1_TC 0x4000000U
103
104
#define MMCTRL_SDCFG1_BANKSZ_SHIFT 23
105
#define MMCTRL_SDCFG1_BANKSZ_MASK 0x3800000U
106
#define MMCTRL_SDCFG1_BANKSZ_GET( _reg ) \
107
( ( ( _reg ) & MMCTRL_SDCFG1_BANKSZ_MASK ) >> \
108
MMCTRL_SDCFG1_BANKSZ_SHIFT )
109
#define MMCTRL_SDCFG1_BANKSZ_SET( _reg, _val ) \
110
( ( ( _reg ) & ~MMCTRL_SDCFG1_BANKSZ_MASK ) | \
111
( ( ( _val ) << MMCTRL_SDCFG1_BANKSZ_SHIFT ) & \
112
MMCTRL_SDCFG1_BANKSZ_MASK ) )
113
#define MMCTRL_SDCFG1_BANKSZ( _val ) \
114
115
116
117
#define MMCTRL_SDCFG1_COLSZ_SHIFT 21
118
#define MMCTRL_SDCFG1_COLSZ_MASK 0x600000U
119
#define MMCTRL_SDCFG1_COLSZ_GET( _reg ) \
120
( ( ( _reg ) & MMCTRL_SDCFG1_COLSZ_MASK ) >> \
121
MMCTRL_SDCFG1_COLSZ_SHIFT )
122
#define MMCTRL_SDCFG1_COLSZ_SET( _reg, _val ) \
123
( ( ( _reg ) & ~MMCTRL_SDCFG1_COLSZ_MASK ) | \
124
( ( ( _val ) << MMCTRL_SDCFG1_COLSZ_SHIFT ) & \
125
MMCTRL_SDCFG1_COLSZ_MASK ) )
126
#define MMCTRL_SDCFG1_COLSZ( _val ) \
127
128
129
130
#define MMCTRL_SDCFG1_COMMAND_SHIFT 18
131
#define MMCTRL_SDCFG1_COMMAND_MASK 0x1c0000U
132
#define MMCTRL_SDCFG1_COMMAND_GET( _reg ) \
133
( ( ( _reg ) & MMCTRL_SDCFG1_COMMAND_MASK ) >> \
134
MMCTRL_SDCFG1_COMMAND_SHIFT )
135
#define MMCTRL_SDCFG1_COMMAND_SET( _reg, _val ) \
136
( ( ( _reg ) & ~MMCTRL_SDCFG1_COMMAND_MASK ) | \
137
( ( ( _val ) << MMCTRL_SDCFG1_COMMAND_SHIFT ) & \
138
MMCTRL_SDCFG1_COMMAND_MASK ) )
139
#define MMCTRL_SDCFG1_COMMAND( _val ) \
140
141
142
143
#define MMCTRL_SDCFG1_MS 0x10000U
144
145
#define MMCTRL_SDCFG1_64 0x8000U
146
147
#define MMCTRL_SDCFG1_RFLOAD_SHIFT 0
148
#define MMCTRL_SDCFG1_RFLOAD_MASK 0x7fffU
149
#define MMCTRL_SDCFG1_RFLOAD_GET( _reg ) \
150
( ( ( _reg ) & MMCTRL_SDCFG1_RFLOAD_MASK ) >> \
151
MMCTRL_SDCFG1_RFLOAD_SHIFT )
152
#define MMCTRL_SDCFG1_RFLOAD_SET( _reg, _val ) \
153
( ( ( _reg ) & ~MMCTRL_SDCFG1_RFLOAD_MASK ) | \
154
( ( ( _val ) << MMCTRL_SDCFG1_RFLOAD_SHIFT ) & \
155
MMCTRL_SDCFG1_RFLOAD_MASK ) )
156
#define MMCTRL_SDCFG1_RFLOAD( _val ) \
157
158
159
161
170
171
#define MMCTRL_SDCFG2_CE 0x40000000U
172
173
#define MMCTRL_SDCFG2_EN2T 0x8000U
174
175
#define MMCTRL_SDCFG2_DCS 0x4000U
176
177
#define MMCTRL_SDCFG2_BPARK 0x2000U
178
180
188
189
#define MMCTRL_MUXCFG_ERRLOC_SHIFT 20
190
#define MMCTRL_MUXCFG_ERRLOC_MASK 0xfff00000U
191
#define MMCTRL_MUXCFG_ERRLOC_GET( _reg ) \
192
( ( ( _reg ) & MMCTRL_MUXCFG_ERRLOC_MASK ) >> \
193
MMCTRL_MUXCFG_ERRLOC_SHIFT )
194
#define MMCTRL_MUXCFG_ERRLOC_SET( _reg, _val ) \
195
( ( ( _reg ) & ~MMCTRL_MUXCFG_ERRLOC_MASK ) | \
196
( ( ( _val ) << MMCTRL_MUXCFG_ERRLOC_SHIFT ) & \
197
MMCTRL_MUXCFG_ERRLOC_MASK ) )
198
#define MMCTRL_MUXCFG_ERRLOC( _val ) \
199
200
201
202
#define MMCTRL_MUXCFG_DDERR 0x80000U
203
204
#define MMCTRL_MUXCFG_DWIDTH_SHIFT 16
205
#define MMCTRL_MUXCFG_DWIDTH_MASK 0x70000U
206
#define MMCTRL_MUXCFG_DWIDTH_GET( _reg ) \
207
( ( ( _reg ) & MMCTRL_MUXCFG_DWIDTH_MASK ) >> \
208
MMCTRL_MUXCFG_DWIDTH_SHIFT )
209
#define MMCTRL_MUXCFG_DWIDTH_SET( _reg, _val ) \
210
( ( ( _reg ) & ~MMCTRL_MUXCFG_DWIDTH_MASK ) | \
211
( ( ( _val ) << MMCTRL_MUXCFG_DWIDTH_SHIFT ) & \
212
MMCTRL_MUXCFG_DWIDTH_MASK ) )
213
#define MMCTRL_MUXCFG_DWIDTH( _val ) \
214
215
216
217
#define MMCTRL_MUXCFG_BEID_SHIFT 12
218
#define MMCTRL_MUXCFG_BEID_MASK 0xf000U
219
#define MMCTRL_MUXCFG_BEID_GET( _reg ) \
220
( ( ( _reg ) & MMCTRL_MUXCFG_BEID_MASK ) >> \
221
MMCTRL_MUXCFG_BEID_SHIFT )
222
#define MMCTRL_MUXCFG_BEID_SET( _reg, _val ) \
223
( ( ( _reg ) & ~MMCTRL_MUXCFG_BEID_MASK ) | \
224
( ( ( _val ) << MMCTRL_MUXCFG_BEID_SHIFT ) & \
225
MMCTRL_MUXCFG_BEID_MASK ) )
226
#define MMCTRL_MUXCFG_BEID( _val ) \
227
228
229
230
#define MMCTRL_MUXCFG_DATAMUX_SHIFT 5
231
#define MMCTRL_MUXCFG_DATAMUX_MASK 0xe0U
232
#define MMCTRL_MUXCFG_DATAMUX_GET( _reg ) \
233
( ( ( _reg ) & MMCTRL_MUXCFG_DATAMUX_MASK ) >> \
234
MMCTRL_MUXCFG_DATAMUX_SHIFT )
235
#define MMCTRL_MUXCFG_DATAMUX_SET( _reg, _val ) \
236
( ( ( _reg ) & ~MMCTRL_MUXCFG_DATAMUX_MASK ) | \
237
( ( ( _val ) << MMCTRL_MUXCFG_DATAMUX_SHIFT ) & \
238
MMCTRL_MUXCFG_DATAMUX_MASK ) )
239
#define MMCTRL_MUXCFG_DATAMUX( _val ) \
240
241
242
243
#define MMCTRL_MUXCFG_CEN 0x10U
244
245
#define MMCTRL_MUXCFG_BAUPD 0x8U
246
247
#define MMCTRL_MUXCFG_BAEN 0x4U
248
249
#define MMCTRL_MUXCFG_CODE 0x2U
250
251
#define MMCTRL_MUXCFG_EDEN 0x1U
252
254
262
263
#define MMCTRL_FTDA_FTDA_SHIFT 2
264
#define MMCTRL_FTDA_FTDA_MASK 0xfffffffcU
265
#define MMCTRL_FTDA_FTDA_GET( _reg ) \
266
( ( ( _reg ) & MMCTRL_FTDA_FTDA_MASK ) >> \
267
MMCTRL_FTDA_FTDA_SHIFT )
268
#define MMCTRL_FTDA_FTDA_SET( _reg, _val ) \
269
( ( ( _reg ) & ~MMCTRL_FTDA_FTDA_MASK ) | \
270
( ( ( _val ) << MMCTRL_FTDA_FTDA_SHIFT ) & \
271
MMCTRL_FTDA_FTDA_MASK ) )
272
#define MMCTRL_FTDA_FTDA( _val ) \
273
274
275
277
285
286
#define MMCTRL_FTDC_CBD_SHIFT 24
287
#define MMCTRL_FTDC_CBD_MASK 0xff000000U
288
#define MMCTRL_FTDC_CBD_GET( _reg ) \
289
( ( ( _reg ) & MMCTRL_FTDC_CBD_MASK ) >> \
290
MMCTRL_FTDC_CBD_SHIFT )
291
#define MMCTRL_FTDC_CBD_SET( _reg, _val ) \
292
( ( ( _reg ) & ~MMCTRL_FTDC_CBD_MASK ) | \
293
( ( ( _val ) << MMCTRL_FTDC_CBD_SHIFT ) & \
294
MMCTRL_FTDC_CBD_MASK ) )
295
#define MMCTRL_FTDC_CBD( _val ) \
296
297
298
299
#define MMCTRL_FTDC_CBC_SHIFT 16
300
#define MMCTRL_FTDC_CBC_MASK 0xff0000U
301
#define MMCTRL_FTDC_CBC_GET( _reg ) \
302
( ( ( _reg ) & MMCTRL_FTDC_CBC_MASK ) >> \
303
MMCTRL_FTDC_CBC_SHIFT )
304
#define MMCTRL_FTDC_CBC_SET( _reg, _val ) \
305
( ( ( _reg ) & ~MMCTRL_FTDC_CBC_MASK ) | \
306
( ( ( _val ) << MMCTRL_FTDC_CBC_SHIFT ) & \
307
MMCTRL_FTDC_CBC_MASK ) )
308
#define MMCTRL_FTDC_CBC( _val ) \
309
310
311
312
#define MMCTRL_FTDC_CBB_SHIFT 8
313
#define MMCTRL_FTDC_CBB_MASK 0xff00U
314
#define MMCTRL_FTDC_CBB_GET( _reg ) \
315
( ( ( _reg ) & MMCTRL_FTDC_CBB_MASK ) >> \
316
MMCTRL_FTDC_CBB_SHIFT )
317
#define MMCTRL_FTDC_CBB_SET( _reg, _val ) \
318
( ( ( _reg ) & ~MMCTRL_FTDC_CBB_MASK ) | \
319
( ( ( _val ) << MMCTRL_FTDC_CBB_SHIFT ) & \
320
MMCTRL_FTDC_CBB_MASK ) )
321
#define MMCTRL_FTDC_CBB( _val ) \
322
323
324
325
#define MMCTRL_FTDC_CBA_SHIFT 0
326
#define MMCTRL_FTDC_CBA_MASK 0xffU
327
#define MMCTRL_FTDC_CBA_GET( _reg ) \
328
( ( ( _reg ) & MMCTRL_FTDC_CBA_MASK ) >> \
329
MMCTRL_FTDC_CBA_SHIFT )
330
#define MMCTRL_FTDC_CBA_SET( _reg, _val ) \
331
( ( ( _reg ) & ~MMCTRL_FTDC_CBA_MASK ) | \
332
( ( ( _val ) << MMCTRL_FTDC_CBA_SHIFT ) & \
333
MMCTRL_FTDC_CBA_MASK ) )
334
#define MMCTRL_FTDC_CBA( _val ) \
335
336
337
339
347
348
#define MMCTRL_FTDD_DATA_SHIFT 0
349
#define MMCTRL_FTDD_DATA_MASK 0xffffffffU
350
#define MMCTRL_FTDD_DATA_GET( _reg ) \
351
( ( ( _reg ) & MMCTRL_FTDD_DATA_MASK ) >> \
352
MMCTRL_FTDD_DATA_SHIFT )
353
#define MMCTRL_FTDD_DATA_SET( _reg, _val ) \
354
( ( ( _reg ) & ~MMCTRL_FTDD_DATA_MASK ) | \
355
( ( ( _val ) << MMCTRL_FTDD_DATA_SHIFT ) & \
356
MMCTRL_FTDD_DATA_MASK ) )
357
#define MMCTRL_FTDD_DATA( _val ) \
358
359
360
362
370
371
#define MMCTRL_FTBND_FTBND_31_3_SHIFT 3
372
#define MMCTRL_FTBND_FTBND_31_3_MASK 0xfffffff8U
373
#define MMCTRL_FTBND_FTBND_31_3_GET( _reg ) \
374
( ( ( _reg ) & MMCTRL_FTBND_FTBND_31_3_MASK ) >> \
375
MMCTRL_FTBND_FTBND_31_3_SHIFT )
376
#define MMCTRL_FTBND_FTBND_31_3_SET( _reg, _val ) \
377
( ( ( _reg ) & ~MMCTRL_FTBND_FTBND_31_3_MASK ) | \
378
( ( ( _val ) << MMCTRL_FTBND_FTBND_31_3_SHIFT ) & \
379
MMCTRL_FTBND_FTBND_31_3_MASK ) )
380
#define MMCTRL_FTBND_FTBND_31_3( _val ) \
381
382
383
385
389
typedef
struct
mmctrl
393
uint32_t
sdcfg1
394
398
uint32_t
sdcfg2
399
400
uint32_t reserved_8_20[ 6 ];
401
405
uint32_t
muxcfg
406
410
uint32_t
ftda
411
415
uint32_t
ftdc
416
420
uint32_t
ftdd
421
425
uint32_t
ftbnd
426
mmctrl
427
429
430
#ifdef __cplusplus
431
432
#endif
433
434
#endif
/* _GRLIB_MMCTRL_REGS_H */
mmctrl
This structure defines the MMCTRL register block memory map.
Definition
mmctrl-regs.h:389
mmctrl::ftdc
uint32_t ftdc
See FT diagnostic checkbits register (FTDC).
Definition
mmctrl-regs.h:415
mmctrl::sdcfg1
uint32_t sdcfg1
See SDRAM configuration register 1 (SDCFG1).
Definition
mmctrl-regs.h:393
mmctrl::sdcfg2
uint32_t sdcfg2
See SDRAM configuration register 2 (SDCFG2).
Definition
mmctrl-regs.h:398
mmctrl::muxcfg
uint32_t muxcfg
See Mux configuration register (MUXCFG).
Definition
mmctrl-regs.h:405
mmctrl::ftbnd
uint32_t ftbnd
See FT boundary address register (FTBND).
Definition
mmctrl-regs.h:425
mmctrl::ftda
uint32_t ftda
See FT diagnostic address register (FTDA).
Definition
mmctrl-regs.h:410
mmctrl::ftdd
uint32_t ftdd
See FT diagnostic data register (FTDD).
Definition
mmctrl-regs.h:420
