RTEMS 6.3
tm27.h
1
4
5/*
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef _RTEMS_TMTEST27
12#error "This is an RTEMS internal file you must not include directly."
13#endif
14
15#ifndef __tm27_h
16#define __tm27_h
17
18/*
19 * Define the interrupt mechanism for Time Test 27
20 */
21
22#include <bsp/irq.h>
23
24#define MUST_WAIT_FOR_INTERRUPT 1
25
26#define Install_tm27_vector( handler ) \
27 rtems_interrupt_handler_install( \
28 TX3904_IRQ_TMR0, "benchmark", 0, \
29 handler, NULL );
30
31#define Cause_tm27_intr() \
32 do { \
33 uint32_t _clicks = 20; \
34 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \
35 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CPRA, _clicks ); \
36 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR, 0x00 ); \
37 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x8001 ); \
38 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TCR, 0xC0 ); \
39 *((volatile uint32_t*) 0xFFFFC01C) = 0x00000700; \
40 } while(0)
41
42#define Clear_tm27_intr() \
43 do { \
44 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x0001 ); \
45 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \
46 TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR, 0x00 ); \
47 } while(0)
48
49#define Lower_tm27_intr() \
50 mips_enable_in_interrupt_mask( 0xff01 );
51
52#endif
jmr3904 interrupt definitions.
