RTEMS
6.3
Toggle main menu visibility
bsps
mips
csb350
include
tm27.h
1
4
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef _RTEMS_TMTEST27
12
#error "This is an RTEMS internal file you must not include directly."
13
#endif
14
15
#ifndef __tm27_h
16
#define __tm27_h
17
18
bsp/irq.h
19
20
21
* Define the interrupt mechanism for Time Test 27
22
23
24
int
assert_sw_irw(uint32_t irqnum);
25
int
negate_sw_irw(uint32_t irqnum);
26
27
#define MUST_WAIT_FOR_INTERRUPT 0
28
29
#define Install_tm27_vector( handler ) \
30
rtems_interrupt_handler_install( \
31
AU1X00_IRQ_SW0, "benchmark", 0, handler, NULL );
32
33
#define Cause_tm27_intr() \
34
do { \
35
assert_sw_irq(0); \
36
} while(0)
37
38
#define Clear_tm27_intr() \
39
do { \
40
negate_sw_irq(0); \
41
} while(0)
42
43
#define Lower_tm27_intr() \
44
do { \
45
continue;\
46
} while(0)
47
48
#endif
irq.h
interrupt definitions.
