#define | UART_BAUD_RATE (115200) |
#define | MM_FREQUENCY (0xe0001074) |
#define | FMLBRG_FLUSH_BASE (0xc8000000) |
#define | FMLBRG_LINE_LENGTH (32) |
#define | FMLBRG_LINE_COUNT (512) |
#define | MM_UART_RXTX (0xe0000000) |
#define | MM_UART_DIV (0xe0000004) |
#define | MM_UART_STAT (0xe0000008) |
#define | MM_UART_CTRL (0xe000000c) |
#define | UART_STAT_THRE (0x1) |
#define | UART_STAT_RX_EVT (0x2) |
#define | UART_STAT_TX_EVT (0x4) |
#define | UART_CTRL_RX_INT (0x1) |
#define | UART_CTRL_TX_INT (0x2) |
#define | UART_CTRL_THRU (0x4) |
#define | MM_TIMER1_COMPARE (0xe0001024) |
#define | MM_TIMER1_COUNTER (0xe0001028) |
#define | MM_TIMER1_CONTROL (0xe0001020) |
#define | MM_TIMER0_COMPARE (0xe0001014) |
#define | MM_TIMER0_COUNTER (0xe0001018) |
#define | MM_TIMER0_CONTROL (0xe0001010) |
#define | TIMER_ENABLE (0x01) |
#define | TIMER_AUTORESTART (0x02) |
#define | MM_GPIO_IN (0xe0001000) |
#define | MM_GPIO_OUT (0xe0001004) |
#define | MM_GPIO_INTEN (0xe0001008) |
#define | GPIO_BTN1 (0x00000001) |
#define | GPIO_BTN2 (0x00000002) |
#define | GPIO_BTN3 (0x00000004) |
#define | GPIO_PCBREV0 (0x00000008) |
#define | GPIO_PCBREV1 (0x00000010) |
#define | GPIO_PCBREV2 (0x00000020) |
#define | GPIO_PCBREV3 (0x00000040) |
#define | GPIO_LED1 (0x00000001) |
#define | GPIO_LED2 (0x00000002) |
#define | MM_SYSTEM_ID (0xe000107c) |
#define | MM_ICAP (0xe0001040) |
#define | ICAP_READY (0x01) |
#define | ICAP_CE (0x10000) |
#define | ICAP_WRITE (0x20000) |
#define | MM_VGA_RESET (0xe0003000) |
#define | MM_VGA_HRES (0xe0003004) |
#define | MM_VGA_HSYNC_START (0xe0003008) |
#define | MM_VGA_HSYNC_END (0xe000300C) |
#define | MM_VGA_HSCAN (0xe0003010) |
#define | MM_VGA_VRES (0xe0003014) |
#define | MM_VGA_VSYNC_START (0xe0003018) |
#define | MM_VGA_VSYNC_END (0xe000301C) |
#define | MM_VGA_VSCAN (0xe0003020) |
#define | MM_VGA_BASEADDRESS (0xe0003024) |
#define | MM_VGA_BASEADDRESS_ACT (0xe0003028) |
#define | MM_VGA_BURST_COUNT (0xe000302C) |
#define | MM_VGA_DDC (0xe0003030) |
#define | MM_VGA_CLKSEL (0xe0003034) |
#define | VGA_RESET (0x01) |
#define | VGA_DDC_SDAIN (0x1) |
#define | VGA_DDC_SDAOUT (0x2) |
#define | VGA_DDC_SDAOE (0x4) |
#define | VGA_DDC_SDC (0x8) |
#define | MM_MINIMAC_SETUP (0xe0008000) |
#define | MM_MINIMAC_MDIO (0xe0008004) |
#define | MM_MINIMAC_STATE0 (0xe0008008) |
#define | MM_MINIMAC_COUNT0 (0xe000800C) |
#define | MM_MINIMAC_STATE1 (0xe0008010) |
#define | MM_MINIMAC_COUNT1 (0xe0008014) |
#define | MM_MINIMAC_TXCOUNT (0xe0008018) |
#define | MINIMAC_RX0_BASE (0xb0000000) |
#define | MINIMAC_RX1_BASE (0xb0000800) |
#define | MINIMAC_TX_BASE (0xb0001000) |
#define | MINIMAC_SETUP_PHYRST (0x1) |
#define | MINIMAC_STATE_EMPTY (0x0) |
#define | MINIMAC_STATE_LOADED (0x1) |
#define | MINIMAC_STATE_PENDING (0x2) |
#define | MM_AC97_CRCTL (0xe0005000) |
#define | AC97_CRCTL_RQEN (0x01) |
#define | AC97_CRCTL_WRITE (0x02) |
#define | MM_AC97_CRADDR (0xe0005004) |
#define | MM_AC97_CRDATAOUT (0xe0005008) |
#define | MM_AC97_CRDATAIN (0xe000500C) |
#define | MM_AC97_DCTL (0xe0005010) |
#define | MM_AC97_DADDRESS (0xe0005014) |
#define | MM_AC97_DREMAINING (0xe0005018) |
#define | MM_AC97_UCTL (0xe0005020) |
#define | MM_AC97_UADDRESS (0xe0005024) |
#define | MM_AC97_UREMAINING (0xe0005028) |
#define | AC97_SCTL_EN (0x01) |
#define | AC97_MAX_DMASIZE (0x3fffc) |
#define | MM_SOFTUSB_CONTROL (0xe000f000) |
#define | SOFTUSB_CONTROL_RESET (0x1) |
#define | MM_SOFTUSB_PMEM_BASE (0xa0000000) |
#define | MM_SOFTUSB_DMEM_BASE (0xa0020000) |
#define | SOFTUSB_PMEM_SIZE (1 << 13) |
#define | SOFTUSB_DMEM_SIZE (1 << 13) |
#define | MM_PFPU_CTL (0xe0006000) |
#define | PFPU_CTL_START (0x01) |
#define | PFPU_CTL_BUSY (0x01) |
#define | MM_PFPU_MESHBASE (0xe0006004) |
#define | MM_PFPU_HMESHLAST (0xe0006008) |
#define | MM_PFPU_VMESHLAST (0xe000600C) |
#define | MM_PFPU_CODEPAGE (0xe0006010) |
#define | MM_PFPU_DREGBASE (0xe0006400) |
#define | MM_PFPU_CODEBASE (0xe0006800) |
#define | PFPU_PAGESIZE (512) |
#define | PFPU_SPREG_COUNT (2) |
#define | PFPU_REG_X (0) |
#define | PFPU_REG_Y (1) |
#define | MM_TMU_CTL (0xe0007000) |
#define | TMU_CTL_START (0x01) |
#define | TMU_CTL_BUSY (0x01) |
#define | TMU_CTL_CHROMAKEY (0x02) |
#define | MM_TMU_HMESHLAST (0xe0007004) |
#define | MM_TMU_VMESHLAST (0xe0007008) |
#define | MM_TMU_BRIGHTNESS (0xe000700C) |
#define | MM_TMU_CHROMAKEY (0xe0007010) |
#define | MM_TMU_VERTICESADR (0xe0007014) |
#define | MM_TMU_TEXFBUF (0xe0007018) |
#define | MM_TMU_TEXHRES (0xe000701C) |
#define | MM_TMU_TEXVRES (0xe0007020) |
#define | MM_TMU_TEXHMASK (0xe0007024) |
#define | MM_TMU_TEXVMASK (0xe0007028) |
#define | MM_TMU_DSTFBUF (0xe000702C) |
#define | MM_TMU_DSTHRES (0xe0007030) |
#define | MM_TMU_DSTVRES (0xe0007034) |
#define | MM_TMU_DSTHOFFSET (0xe0007038) |
#define | MM_TMU_DSTVOFFSET (0xe000703C) |
#define | MM_TMU_DSTSQUAREW (0xe0007040) |
#define | MM_TMU_DSTSQUAREH (0xe0007044) |
#define | MM_TMU_ALPHA (0xe0007048) |
#define | MM_MEMCARD_CLK2XDIV (0xe0004000) |
#define | MM_MEMCARD_ENABLE (0xe0004004) |
#define | MEMCARD_ENABLE_CMD_TX (0x1) |
#define | MEMCARD_ENABLE_CMD_RX (0x2) |
#define | MEMCARD_ENABLE_DAT_TX (0x4) |
#define | MEMCARD_ENABLE_DAT_RX (0x8) |
#define | MM_MEMCARD_PENDING (0xe0004008) |
#define | MEMCARD_PENDING_CMD_TX (0x1) |
#define | MEMCARD_PENDING_CMD_RX (0x2) |
#define | MEMCARD_PENDING_DAT_TX (0x4) |
#define | MEMCARD_PENDING_DAT_RX (0x8) |
#define | MM_MEMCARD_START (0xe000400c) |
#define | MEMCARD_START_CMD_RX (0x1) |
#define | MEMCARD_START_DAT_RX (0x2) |
#define | MM_MEMCARD_CMD (0xe0004010) |
#define | MM_MEMCARD_DAT (0xe0004014) |
| #define | MM_DMX_TX(x) |
#define | MM_DMX_THRU (0xe000c800) |
| #define | MM_DMX_RX(x) |
#define | MM_MIDI_RXTX (0xe000b000) |
#define | MM_MIDI_DIV (0xe000b004) |
#define | MM_MIDI_STAT (0xe000b008) |
#define | MM_MIDI_CTRL (0xe000b00c) |
#define | MIDI_STAT_THRE (0x1) |
#define | MIDI_STAT_RX_EVT (0x2) |
#define | MIDI_STAT_TX_EVT (0x4) |
#define | MIDI_CTRL_RX_INT (0x1) |
#define | MIDI_CTRL_TX_INT (0x2) |
#define | MIDI_CTRL_THRU (0x4) |
#define | MM_IR_RX (0xe000e000) |
#define | MM_BT656_I2C (0xe000a000) |
#define | MM_BT656_FILTERSTATUS (0xe000a004) |
#define | MM_BT656_BASE (0xe000a008) |
#define | MM_BT656_MAXBURSTS (0xe000a00c) |
#define | MM_BT656_DONEBURSTS (0xe000a010) |
#define | BT656_I2C_SDAIN (0x1) |
#define | BT656_I2C_SDAOUT (0x2) |
#define | BT656_I2C_SDAOE (0x4) |
#define | BT656_I2C_SDC (0x8) |
#define | BT656_FILTER_FIELD1 (0x1) |
#define | BT656_FILTER_FIELD2 (0x2) |
#define | BT656_FILTER_INFRAME (0x4) |
#define | MM_IRQ_UART (0) |
#define | MM_IRQ_GPIO (1) |
#define | MM_IRQ_TIMER0 (2) |
#define | MM_IRQ_TIMER1 (3) |
#define | MM_IRQ_AC97CRREQUEST (4) |
#define | MM_IRQ_AC97CRREPLY (5) |
#define | MM_IRQ_AC97DMAR (6) |
#define | MM_IRQ_AC97DMAW (7) |
#define | MM_IRQ_PFPU (8) |
#define | MM_IRQ_TMU (9) |
#define | MM_IRQ_ETHRX (10) |
#define | MM_IRQ_ETHTX (11) |
#define | MM_IRQ_VIDEOIN (12) |
#define | MM_IRQ_MIDI (13) |
#define | MM_IRQ_IR (14) |
#define | MM_IRQ_USB (15) |
#define | FLASH_BASE (0x80000000) |
#define | FLASH_OFFSET_STANDBY_BITSTREAM (0x80000000) |
#define | FLASH_OFFSET_RESCUE_BITSTREAM (0x800A0000) |
#define | FLASH_OFFSET_RESCUE_BIOS (0x80220000) |
#define | FLASH_OFFSET_MAC_ADDRESS (0x802200E0) |
#define | FLASH_OFFSET_RESCUE_SPLASH (0x80240000) |
#define | FLASH_OFFSET_RESCUE_APP (0x802E0000) |
#define | FLASH_OFFSET_REGULAR_BITSTREAM (0x806E0000) |
#define | FLASH_OFFSET_REGULAR_BIOS (0x80860000) |
#define | FLASH_OFFSET_REGULAR_SPLASH (0x80880000) |
#define | FLASH_OFFSET_REGULAR_APP (0x80920000) |
| #define | MM_READ(reg) |
| #define | MM_WRITE(reg, val) |
#define | FLASH_SECTOR_SIZE (128*1024) |
#define | FLASH_PARTITION_COUNT (5) |
| #define | FLASH_PARTITIONS |
