RTEMS
6.3
Toggle main menu visibility
bsps
m68k
include
mcf5272
mcf5272.h
1
2
* Coldfire MCF5272 definitions.
3
* Contents of this file based on information provided in
4
* Motorola MCF5272 User's Manual.
5
6
* Copyright (C) 2004 Jay Monkman <jtm@lopingdog.com>
7
8
* The license and distribution terms for this file may be
9
* found in the file LICENSE in this distribution or at
10
* http://www.rtems.org/license/LICENSE.
11
12
13
#ifndef __MCF5272_H__
14
#define __MCF5272_H__
15
16
#ifndef ASM
17
rtems.h
18
#endif
19
20
#define bit(x) (1 << (x))
21
22
#define MCF5272_SIM_BASE(mbar) ((mbar) + 0x0000)
23
#define MCF5272_INT_BASE(mbar) ((mbar) + 0x0020)
24
#define MCF5272_CS_BASE(mbar) ((mbar) + 0x0040)
25
#define MCF5272_GPIO_BASE(mbar) ((mbar) + 0x0080)
26
#define MCF5272_QSPI_BASE(mbar) ((mbar) + 0x00A0)
27
#define MCF5272_PWM_BASE(mbar) ((mbar) + 0x00C0)
28
#define MCF5272_DMAC_BASE(mbar) ((mbar) + 0x00E0)
29
#define MCF5272_UART0_BASE(mbar) ((mbar) + 0x0100)
30
#define MCF5272_UART1_BASE(mbar) ((mbar) + 0x0140)
31
#define MCF5272_SDRAMC_BASE(mbar) ((mbar) + 0x0180)
32
#define MCF5272_TIMER_BASE(mbar) ((mbar) + 0x0200)
33
#define MCF5272_PLIC_BASE(mbar) ((mbar) + 0x0300)
34
#define MCF5272_ENET_BASE(mbar) ((mbar) + 0x0840)
35
#define MCF5272_USB_BASE(mbar) ((mbar) + 0x1000)
36
37
38
/* RAMBAR - SRAM Base Address Register */
39
#define MCF5272_RAMBAR_BA (0xfffff000)
/* SRAM Base Address */
40
#define MCF5272_RAMBAR_WP (0x00000100)
/* Write Protect */
41
#define MCF5272_RAMBAR_CI (0x00000020)
/* CPU Space mask */
42
#define MCF5272_RAMBAR_SC (0x00000010)
/* Supervisor Code Space Mask */
43
#define MCF5272_RAMBAR_SD (0x00000008)
/* Supervisor Data Space Mask */
44
#define MCF5272_RAMBAR_UC (0x00000004)
/* User Code Space Mask */
45
#define MCF5272_RAMBAR_UD (0x00000002)
/* User Data Space Mask */
46
#define MCF5272_RAMBAR_V (0x00000001)
/* Contents of RAMBAR are valid */
47
48
/* MBAR - Module Base Address Register */
49
#define MCF5272_MBAR_BA (0xffff0000)
/* Base Address */
50
#define MCF5272_MBAR_SC (0x00000010)
51
#define MCF5272_MBAR_SD (0x00000008)
52
#define MCF5272_MBAR_UC (0x00000004)
53
#define MCF5272_MBAR_UD (0x00000002)
54
#define MCF5272_MBAR_V (0x00000001)
/* Contents of MBAR are valid */
55
56
/* CACR - Cache Control Register */
57
#define MCF5272_CACR_CENB (0x80000000)
/* Cache Enable */
58
#define MCF5272_CACR_CPDI (0x10000000)
/* Disable CPUSHL Invalidation */
59
#define MCF5272_CACR_CFRZ (0x08000000)
/* Cache Freeze */
60
#define MCF5272_CACR_CINV (0x01000000)
/* Cache Invalidate */
61
#define MCF5272_CACR_CEIB (0x00000400)
/* Cache Enable Noncacheable
62
instruction bursting */
63
#define MCF5272_CACR_DCM (0x00000200)
/* Default cache mode - noncacheable*/
64
#define MCF5272_CACR_DBWE (0x00000100)
/* Default Buffered Write Enable */
65
#define MCF5272_CACR_DWP (0x00000020)
/* Default Write Protection */
66
#define MCF5272_CACR_CLNF (0x00000003)
/* Cache Line Fill */
67
68
/* ACRx - Cache Access Control Registers */
69
#define MCF5272_ACR_BA (0xff000000)
/* Address Base */
70
#define MCF5272_ACR_BAM (0x00ff0000)
/* Address Mask */
71
#define MCF5272_ACR_EN (0x00008000)
/* Enable */
72
#define MCF5272_ACR_SM_USR (0x00000000)
/* Match if user mode */
73
#define MCF5272_ACR_SM_SVR (0x00002000)
/* Match if supervisor mode */
74
#define MCF5272_ACR_SM_ANY (0x00004000)
/* Match Always */
75
#define MCF527_ACR_CM (0x00000040)
/* Cache Mode (1 - noncacheable) */
76
#define MCF5272_ACR_BWE (0x00000020)
/* Buffered Write Enable */
77
#define MCF5272_ACR_WP (0x00000004)
/* Write Protect */
78
#define MCF5272_ACR_BASE(base) ((base) & MCF5272_ACR_BA)
79
#define MCF5272_ACR_MASK(mask) (((mask) >> 8) & MCF5272_ACR_BAM)
80
81
82
#define MCF5272_ICR1_INT1_PI (bit(31))
83
#define MCF5272_ICR1_INT1_IPL(x) ((x) << 28)
84
#define MCF5272_ICR1_INT1_MASK ((7) << 28)
85
#define MCF5272_ICR1_INT2_PI (bit(27))
86
#define MCF5272_ICR1_INT2_IPL(x) ((x) << 24)
87
#define MCF5272_ICR1_INT2_MASK ((7) << 24)
88
#define MCF5272_ICR1_INT3_PI (bit(23))
89
#define MCF5272_ICR1_INT3_IPL(x) ((x) << 20)
90
#define MCF5272_ICR1_INT3_MASK ((7) << 20)
91
#define MCF5272_ICR1_INT4_PI (bit(19))
92
#define MCF5272_ICR1_INT4_IPL(x) ((x) << 16)
93
#define MCF5272_ICR1_INT4_MASK ((7) << 16)
94
#define MCF5272_ICR1_TMR0_PI (bit(15))
95
#define MCF5272_ICR1_TMR0_IPL(x) ((x) << 12)
96
#define MCF5272_ICR1_TMR0_MASK ((7) << 12)
97
#define MCF5272_ICR1_TMR1_PI (bit(11))
98
#define MCF5272_ICR1_TMR1_IPL(x) ((x) << 8)
99
#define MCF5272_ICR1_TMR1_MASK ((7) << 8)
100
#define MCF5272_ICR1_TMR2_PI (bit(7))
101
#define MCF5272_ICR1_TMR2_IPL(x) ((x) << 4)
102
#define MCF5272_ICR1_TMR2_MASK ((7) << 4)
103
#define MCF5272_ICR1_TMR3_PI (bit(3))
104
#define MCF5272_ICR1_TMR3_IPL(x) ((x) << 0)
105
#define MCF5272_ICR1_TMR3_MASK ((7) << 0)
106
107
#define MCF5272_ICR3_USB4_PI (bit(31))
108
#define MCF5272_ICR3_USB4_IPL(x) ((x) << 28)
109
#define MCF5272_ICR3_USB4_MASK ((7) << 28)
110
#define MCF5272_ICR3_USB5_PI (bit(27))
111
#define MCF5272_ICR3_USB5_IPL(x) ((x) << 24)
112
#define MCF5272_ICR3_USB5_MASK ((7) << 24)
113
#define MCF5272_ICR3_USB6_PI (bit(23))
114
#define MCF5272_ICR3_USB6_IPL(x) ((x) << 20)
115
#define MCF5272_ICR3_USB6_MASK ((7) << 20)
116
#define MCF5272_ICR3_USB7_PI (bit(19))
117
#define MCF5272_ICR3_USB7_IPL(x) ((x) << 16)
118
#define MCF5272_ICR3_USB7_MASK ((7) << 16)
119
#define MCF5272_ICR3_DMA_PI (bit(15))
120
#define MCF5272_ICR3_DMA_IPL(x) ((x) << 12)
121
#define MCF5272_ICR3_DMA_MASK ((7) << 12)
122
#define MCF5272_ICR3_ERX_PI (bit(11))
123
#define MCF5272_ICR3_ERX_IPL(x) ((x) << 8)
124
#define MCF5272_ICR3_ERX_MASK ((7) << 8)
125
#define MCF5272_ICR3_ETX_PI (bit(7))
126
#define MCF5272_ICR3_ETX_IPL(x) ((x) << 4)
127
#define MCF5272_ICR3_ETX_MASK ((7) << 4)
128
#define MCF5272_ICR3_ENTC_PI (bit(3))
129
#define MCF5272_ICR3_ENTC_IPL(x) ((x) << 0)
130
#define MCF5272_ICR3_ENTC_MASK ((7) << 0)
131
132
133
#define MCF5272_USR_RB (bit(7))
134
#define MCF5272_USR_FE (bit(6))
135
#define MCF5272_USR_PE (bit(5))
136
#define MCF5272_USR_OE (bit(4))
137
#define MCF5272_USR_TXEMP (bit(3))
138
#define MCF5272_USR_TXRDY (bit(2))
139
#define MCF5272_USR_FFULL (bit(1))
140
#define MCF5272_USR_RXRDY (bit(0))
141
142
#define MCF5272_TMR_PS_MASK 0xff00
143
#define MCF5272_TMR_PS_SHIFT 8
144
#define MCF5272_TMR_CE_DISABLE (0 << 6)
145
#define MCF5272_TMR_CE_RISING (1 << 6)
146
#define MCF5272_TMR_CE_FALLING (2 << 6)
147
#define MCF5272_TMR_CE_ANY (3 << 6)
148
#define MCF5272_TMR_OM (bit(5))
149
#define MCF5272_TMR_ORI (bit(4))
150
#define MCF5272_TMR_FRR (bit(3))
151
#define MCF5272_TMR_CLK_STOP (0 << 1)
152
#define MCF5272_TMR_CLK_MSTR (1 << 1)
153
#define MCF5272_TMR_CLK_MSTR16 (2 << 1)
154
#define MCF5272_TMR_CLK_TIN (3 << 1)
155
#define MCF5272_TMR_RST (bit(0))
156
#define MCF5272_TER_REF (bit(1))
157
#define MCF5272_TER_CAP (bit(0))
158
159
#define MCF5272_SCR_PRI (bit(8))
160
#define MCF5272_SCR_AR (bit(7))
161
#define MCF5272_SCR_SRST (bit(6))
162
#define MCF5272_SCR_BUSLOCK (bit(3))
163
#define MCF5272_SCR_HWR_128 (0)
164
#define MCF5272_SCR_HWR_256 (1)
165
#define MCF5272_SCR_HWR_512 (2)
166
#define MCF5272_SCR_HWR_1024 (3)
167
#define MCF5272_SCR_HWR_2048 (4)
168
#define MCF5272_SCR_HWR_4096 (5)
169
#define MCF5272_SCR_HWR_8192 (6)
170
#define MCF5272_SCR_HWR_16384 (7)
171
172
#define MCF5272_SPR_ADC (bit(15))
173
#define MCF5272_SPR_WPV (bit(15))
174
#define MCF5272_SPR_SMV (bit(15))
175
#define MCF5272_SPR_PE (bit(15))
176
#define MCF5272_SPR_HWT (bit(15))
177
#define MCF5272_SPR_RPV (bit(15))
178
#define MCF5272_SPR_EXT (bit(15))
179
#define MCF5272_SPR_SUV (bit(15))
180
#define MCF5272_SPR_ADCEN (bit(15))
181
#define MCF5272_SPR_WPVEN (bit(15))
182
#define MCF5272_SPR_SMVEN (bit(15))
183
#define MCF5272_SPR_PEEN (bit(15))
184
#define MCF5272_SPR_HWTEN (bit(15))
185
#define MCF5272_SPR_RPVEN (bit(15))
186
#define MCF5272_SPR_EXTEN (bit(15))
187
#define MCF5272_SPR_SUVEN (bit(15))
188
189
#define MCF5272_ENET_TX_RT (bit(25))
190
#define MCF5272_ENET_ETHERN_EN (bit(1))
191
#define MCF5272_ENET_RESET (bit(0))
192
193
#define MCF5272_ENET_EIR_HBERR (bit(31))
194
#define MCF5272_ENET_EIR_BABR (bit(30))
195
#define MCF5272_ENET_EIR_BABT (bit(29))
196
#define MCF5272_ENET_EIR_GRA (bit(28))
197
#define MCF5272_ENET_EIR_TXF (bit(27))
198
#define MCF5272_ENET_EIR_TXB (bit(26))
199
#define MCF5272_ENET_EIR_RXF (bit(25))
200
#define MCF5272_ENET_EIR_RXB (bit(24))
201
#define MCF5272_ENET_EIR_MII (bit(23))
202
#define MCF5272_ENET_EIR_EBERR (bit(22))
203
#define MCF5272_ENET_EIR_UMINT (bit(21))
204
205
#define MCF5272_ENET_RCR_PROM (bit(3))
206
#define MCF5272_ENET_RCR_MII (bit(2))
207
#define MCF5272_ENET_RCR_DRT (bit(1))
208
#define MCF5272_ENET_RCR_LOOP (bit(0))
209
210
#define MCF5272_ENET_TCR_FDEN (bit(2))
211
#define MCF5272_ENET_TCR_HBC (bit(1))
212
#define MCF5272_ENET_TCR_GTS (bit(0))
213
214
215
#ifndef ASM
216
typedef
struct
217
volatile
uint32_t mbar;
/* READ ONLY!! */
218
219
volatile
uint16_t scr;
220
volatile
uint16_t _res0;
221
222
volatile
uint16_t _res1;
223
volatile
uint16_t spr;
224
225
volatile
uint32_t pmr;
226
227
volatile
uint16_t _res2;
228
volatile
uint16_t alpr;
229
230
volatile
uint32_t dir;
231
sim_regs_t
232
233
typedef
struct
234
volatile
uint32_t icr1;
235
volatile
uint32_t icr2;
236
volatile
uint32_t icr3;
237
volatile
uint32_t icr4;
238
volatile
uint32_t isr;
239
volatile
uint32_t pitr;
240
volatile
uint32_t piwr;
241
volatile
uint8_t _res0[3];
242
volatile
uint8_t pivr;
243
intctrl_regs_t
244
245
typedef
struct
246
volatile
uint32_t csbr0;
247
volatile
uint32_t csor0;
248
volatile
uint32_t csbr1;
249
volatile
uint32_t csor1;
250
volatile
uint32_t csbr2;
251
volatile
uint32_t csor2;
252
volatile
uint32_t csbr3;
253
volatile
uint32_t csor3;
254
volatile
uint32_t csbr4;
255
volatile
uint32_t csor4;
256
volatile
uint32_t csbr5;
257
volatile
uint32_t csor5;
258
volatile
uint32_t csbr6;
259
volatile
uint32_t csor6;
260
volatile
uint32_t csbr7;
261
volatile
uint32_t csor7;
262
chipsel_regs_t
263
264
typedef
struct
265
volatile
uint32_t pacnt;
266
267
volatile
uint16_t paddr;
268
volatile
uint16_t _res0;
269
270
volatile
uint16_t _res1;
271
volatile
uint16_t padat;
272
273
volatile
uint32_t pbcnt;
274
275
volatile
uint16_t pbddr;
276
volatile
uint16_t _res2;
277
278
volatile
uint16_t _res3;
279
volatile
uint16_t pbdat;
280
281
volatile
uint16_t pcddr;
282
volatile
uint16_t _res4;
283
284
volatile
uint16_t _res5;
285
volatile
uint16_t pcdat;
286
287
volatile
uint32_t pdcnt;
288
gpio_regs_t
289
290
typedef
struct
291
volatile
uint32_t qmr;
292
volatile
uint32_t qdlyr;
293
volatile
uint32_t qwr;
294
volatile
uint32_t qir;
295
volatile
uint32_t qar;
296
volatile
uint32_t qdr;
297
qspi_regs_t
298
299
typedef
struct
300
volatile
uint8_t pwcr1;
301
volatile
uint8_t _res0[3];
302
303
volatile
uint8_t pwcr2;
304
volatile
uint8_t _res1[3];
305
306
volatile
uint8_t pwcr3;
307
volatile
uint8_t _res2[3];
308
309
volatile
uint8_t pwwd1;
310
volatile
uint8_t _res3[3];
311
312
volatile
uint8_t pwwd2;
313
volatile
uint8_t _res4[3];
314
315
volatile
uint8_t pwwd3;
316
volatile
uint8_t _res5[3];
317
pwm_regs_t
318
319
typedef
struct
320
volatile
uint32_t dcmr;
321
322
volatile
uint16_t _res0;
323
volatile
uint16_t dcir;
324
325
volatile
uint32_t dbcr;
326
327
volatile
uint32_t dsar;
328
329
volatile
uint32_t ddar;
330
dma_regs_t
331
332
typedef
struct
333
volatile
uint8_t umr;
/* 0x000 */
334
volatile
uint8_t _res0[3];
335
336
volatile
uint8_t ucsr;
/* 0x004 */
337
volatile
uint8_t _res2[3];
338
339
volatile
uint8_t ucr;
/* 0x008 */
340
volatile
uint8_t _res3[3];
341
342
volatile
uint8_t udata;
/* 0x00c */
343
volatile
uint8_t _res4[3];
344
345
volatile
uint8_t uccr;
/* 0x010 */
346
volatile
uint8_t _res6[3];
347
348
volatile
uint8_t uisr;
/* 0x014 */
349
volatile
uint8_t _res8[3];
350
351
volatile
uint8_t ubg1;
/* 0x018 */
352
volatile
uint8_t _res10[3];
353
354
volatile
uint8_t ubg2;
/* 0x01c */
355
volatile
uint8_t _res11[3];
356
357
volatile
uint8_t uabr1;
/* 0x020 */
358
volatile
uint8_t _res12[3];
359
360
volatile
uint8_t uabr2;
/* 0x024 */
361
volatile
uint8_t _res13[3];
362
363
volatile
uint8_t utxfcsr;
/* 0x028 */
364
volatile
uint8_t _res14[3];
365
366
volatile
uint8_t urxfcsr;
/* 0x02c */
367
volatile
uint8_t _res15[3];
368
369
volatile
uint8_t ufpdn;
/* 0x030 */
370
volatile
uint8_t _res16[3];
371
372
volatile
uint8_t uip;
/* 0x034 */
373
volatile
uint8_t _res17[3];
374
375
volatile
uint8_t uop1;
/* 0x038 */
376
volatile
uint8_t _res18[3];
377
378
volatile
uint8_t uop0;
/* 0x03c */
379
volatile
uint8_t _res19[3];
380
uart_regs_t
381
382
typedef
struct
383
volatile
uint16_t tmr0;
384
volatile
uint16_t _res0;
385
386
volatile
uint16_t trr0;
387
volatile
uint16_t _res1;
388
389
volatile
uint16_t tcap0;
390
volatile
uint16_t _res2;
391
392
volatile
uint16_t tcn0;
393
volatile
uint16_t _res3;
394
395
volatile
uint16_t ter0;
396
volatile
uint16_t _res4;
397
398
volatile
uint8_t _res40[12];
399
400
volatile
uint16_t tmr1;
401
volatile
uint16_t _res5;
402
403
volatile
uint16_t trr1;
404
volatile
uint16_t _res6;
405
406
volatile
uint16_t tcap1;
407
volatile
uint16_t _res7;
408
409
volatile
uint16_t tcn1;
410
volatile
uint16_t _res8;
411
412
volatile
uint16_t ter1;
413
volatile
uint16_t _res9;
414
415
volatile
uint8_t _res91[12];
416
417
volatile
uint16_t tmr2;
418
volatile
uint16_t _res10;
419
420
volatile
uint16_t trr2;
421
volatile
uint16_t _res11;
422
423
volatile
uint16_t tcap2;
424
volatile
uint16_t _res12;
425
426
volatile
uint16_t tcn2;
427
volatile
uint16_t _res13;
428
429
volatile
uint16_t ter2;
430
volatile
uint16_t _res14;
431
432
volatile
uint8_t _res140[12];
433
434
volatile
uint16_t tmr3;
435
volatile
uint16_t _res15;
436
437
volatile
uint16_t trr3;
438
volatile
uint16_t _res16;
439
440
volatile
uint16_t tcap3;
441
volatile
uint16_t _res17;
442
443
volatile
uint16_t tcn3;
444
volatile
uint16_t _res18;
445
446
volatile
uint16_t ter3;
447
volatile
uint16_t _res19;
448
449
volatile
uint8_t _res190[12];
450
451
volatile
uint16_t wrrr;
452
volatile
uint16_t _res20;
453
454
volatile
uint16_t wirr;
455
volatile
uint16_t _res21;
456
457
volatile
uint16_t wcr;
458
volatile
uint16_t _res22;
459
460
volatile
uint16_t wer;
461
volatile
uint16_t _res23;
462
timer_regs_t
463
464
typedef
struct
465
volatile
uint32_t p0b1rr;
466
volatile
uint32_t p1b1rr;
467
volatile
uint32_t p2b1rr;
468
volatile
uint32_t p3b1rr;
469
volatile
uint32_t p0b2rr;
470
volatile
uint32_t p1b2rr;
471
volatile
uint32_t p2b2rr;
472
volatile
uint32_t p3b2rr;
473
474
volatile
uint8_t p0drr;
475
volatile
uint8_t p1drr;
476
volatile
uint8_t p2drr;
477
volatile
uint8_t p3drr;
478
479
volatile
uint32_t p0b1tr;
480
volatile
uint32_t p1b1tr;
481
volatile
uint32_t p2b1tr;
482
volatile
uint32_t p3b1tr;
483
volatile
uint32_t p0b2tr;
484
volatile
uint32_t p1b2tr;
485
volatile
uint32_t p2b2tr;
486
volatile
uint32_t p3b2tr;
487
488
volatile
uint8_t p0dtr;
489
volatile
uint8_t p1dtr;
490
volatile
uint8_t p2dtr;
491
volatile
uint8_t p3dtr;
492
493
volatile
uint16_t p0cr;
494
volatile
uint16_t p1cr;
495
volatile
uint16_t p2cr;
496
volatile
uint16_t p3cr;
497
volatile
uint16_t p0icr;
498
volatile
uint16_t p1icr;
499
volatile
uint16_t p2icr;
500
volatile
uint16_t p3icr;
501
volatile
uint16_t p0gmr;
502
volatile
uint16_t p1gmr;
503
volatile
uint16_t p2gmr;
504
volatile
uint16_t p3gmr;
505
volatile
uint16_t p0gmt;
506
volatile
uint16_t p1gmt;
507
volatile
uint16_t p2gmt;
508
volatile
uint16_t p3gmt;
509
510
volatile
uint8_t _res0;
511
volatile
uint8_t pgmts;
512
volatile
uint8_t pgmta;
513
volatile
uint8_t _res1;
514
volatile
uint8_t p0gcir;
515
volatile
uint8_t p1gcir;
516
volatile
uint8_t p2gcir;
517
volatile
uint8_t p3gcir;
518
volatile
uint8_t p0gcit;
519
volatile
uint8_t p1gcit;
520
volatile
uint8_t p2gcit;
521
volatile
uint8_t p3gcit;
522
volatile
uint8_t _res3[3];
523
volatile
uint8_t pgcitsr;
524
volatile
uint8_t _res4[3];
525
volatile
uint8_t pdcsr;
526
527
volatile
uint16_t p0psr;
528
volatile
uint16_t p1psr;
529
volatile
uint16_t p2psr;
530
volatile
uint16_t p3psr;
531
volatile
uint16_t pasr;
532
volatile
uint8_t _res5;
533
volatile
uint8_t plcr;
534
volatile
uint16_t _res6;
535
volatile
uint16_t pdrqr;
536
volatile
uint16_t p0sdr;
537
volatile
uint16_t p1sdr;
538
volatile
uint16_t p2sdr;
539
volatile
uint16_t p3sdr;
540
volatile
uint16_t _res7;
541
volatile
uint16_t pcsr;
542
plic_regs_t
543
544
typedef
struct
545
volatile
uint32_t ecr;
546
volatile
uint32_t eir;
547
volatile
uint32_t eimr;
548
volatile
uint32_t ivsr;
549
volatile
uint32_t rdar;
550
volatile
uint32_t tdar;
551
volatile
uint32_t _res0[10];
552
volatile
uint32_t mmfr;
553
volatile
uint32_t mscr;
554
volatile
uint32_t _res1[17];
555
volatile
uint32_t frbr;
556
volatile
uint32_t frsr;
557
volatile
uint32_t _res2[4];
558
volatile
uint32_t tfwr;
559
volatile
uint32_t _res3[1];
560
volatile
uint32_t tfsr;
561
volatile
uint32_t _res4[21];
562
volatile
uint32_t rcr;
563
volatile
uint32_t mflr;
564
volatile
uint32_t _res5[14];
565
volatile
uint32_t tcr;
566
volatile
uint32_t _res6[158];
567
volatile
uint32_t malr;
568
volatile
uint32_t maur;
569
volatile
uint32_t htur;
570
volatile
uint32_t htlr;
571
volatile
uint32_t erdsr;
572
volatile
uint32_t etdsr;
573
volatile
uint32_t emrbr;
574
/* volatile uint8_t fifo[448]; */
575
enet_regs_t
576
577
typedef
struct
578
volatile
uint16_t _res0;
579
volatile
uint16_t fnr;
580
volatile
uint16_t _res1;
581
volatile
uint16_t fnmr;
582
volatile
uint16_t _res2;
583
volatile
uint16_t rfmr;
584
volatile
uint16_t _res3;
585
volatile
uint16_t rfmmr;
586
volatile
uint8_t _res4[3];
587
volatile
uint8_t far;
588
volatile
uint32_t asr;
589
volatile
uint32_t drr1;
590
volatile
uint32_t drr2;
591
volatile
uint16_t _res5;
592
volatile
uint16_t specr;
593
volatile
uint16_t _res6;
594
volatile
uint16_t ep0sr;
595
596
volatile
uint32_t iep0cfg;
597
volatile
uint32_t oep0cfg;
598
volatile
uint32_t ep1cfg;
599
volatile
uint32_t ep2cfg;
600
volatile
uint32_t ep3cfg;
601
volatile
uint32_t ep4cfg;
602
volatile
uint32_t ep5cfg;
603
volatile
uint32_t ep6cfg;
604
volatile
uint32_t ep7cfg;
605
volatile
uint32_t ep0ctl;
606
607
volatile
uint16_t _res7;
608
volatile
uint16_t ep1ctl;
609
volatile
uint16_t _res8;
610
volatile
uint16_t ep2ctl;
611
volatile
uint16_t _res9;
612
volatile
uint16_t ep3ctl;
613
volatile
uint16_t _res10;
614
volatile
uint16_t ep4ctl;
615
volatile
uint16_t _res11;
616
volatile
uint16_t ep5ctl;
617
volatile
uint16_t _res12;
618
volatile
uint16_t ep6ctl;
619
volatile
uint16_t _res13;
620
volatile
uint16_t ep7ctl;
621
622
volatile
uint32_t ep0isr;
623
624
volatile
uint16_t _res14;
625
volatile
uint16_t ep1isr;
626
volatile
uint16_t _res15;
627
volatile
uint16_t ep2isr;
628
volatile
uint16_t _res16;
629
volatile
uint16_t ep3isr;
630
volatile
uint16_t _res17;
631
volatile
uint16_t ep4isr;
632
volatile
uint16_t _res18;
633
volatile
uint16_t ep5isr;
634
volatile
uint16_t _res19;
635
volatile
uint16_t ep6isr;
636
volatile
uint16_t _res20;
637
volatile
uint16_t ep7isr;
638
639
volatile
uint32_t ep0imr;
640
641
volatile
uint16_t _res21;
642
volatile
uint16_t ep1imr;
643
volatile
uint16_t _res22;
644
volatile
uint16_t ep2imr;
645
volatile
uint16_t _res23;
646
volatile
uint16_t ep3imr;
647
volatile
uint16_t _res24;
648
volatile
uint16_t ep4imr;
649
volatile
uint16_t _res25;
650
volatile
uint16_t ep5imr;
651
volatile
uint16_t _res26;
652
volatile
uint16_t ep6imr;
653
volatile
uint16_t _res27;
654
volatile
uint16_t ep7imr;
655
656
volatile
uint32_t ep0dr;
657
volatile
uint32_t ep1dr;
658
volatile
uint32_t ep2dr;
659
volatile
uint32_t ep3dr;
660
volatile
uint32_t ep4dr;
661
volatile
uint32_t ep5dr;
662
volatile
uint32_t ep6dr;
663
volatile
uint32_t ep7dr;
664
665
volatile
uint16_t _res28;
666
volatile
uint16_t ep0dpr;
667
volatile
uint16_t _res29;
668
volatile
uint16_t ep1dpr;
669
volatile
uint16_t _res30;
670
volatile
uint16_t ep2dpr;
671
volatile
uint16_t _res31;
672
volatile
uint16_t ep3dpr;
673
volatile
uint16_t _res32;
674
volatile
uint16_t ep4dpr;
675
volatile
uint16_t _res33;
676
volatile
uint16_t ep5dpr;
677
volatile
uint16_t _res34;
678
volatile
uint16_t ep6dpr;
679
volatile
uint16_t _res35;
680
volatile
uint16_t ep7dpr;
681
/* uint8_t ram[1024]; */
682
usb_regs_t
683
684
extern
intctrl_regs_t
*g_intctrl_regs;
685
extern
chipsel_regs_t
*g_chipsel_regs;
686
extern
gpio_regs_t
*g_gpio_regs;
687
extern
qspi_regs_t
*g_qspi_regs;
688
extern
pwm_regs_t
*g_pwm_regs;
689
extern
dma_regs_t
*g_dma_regs;
690
extern
uart_regs_t
*g_uart0_regs;
691
extern
uart_regs_t
*g_uart1_regs;
692
extern
timer_regs_t
*g_timer_regs;
693
extern
plic_regs_t
*g_plic_regs;
694
extern
enet_regs_t
*g_enet_regs;
695
extern
usb_regs_t
*g_usb_regs;
696
697
#endif
/* ASM */
698
699
#endif
/* __MCF5272_H__ */
rtems.h
chipsel_regs_t
Definition
mcf5272.h:245
dma_regs_t
Definition
mcf5272.h:319
enet_regs_t
Definition
mcf5272.h:544
gpio_regs_t
Definition
mcf5272.h:264
intctrl_regs_t
Definition
mcf5272.h:233
plic_regs_t
Definition
mcf5272.h:464
pwm_regs_t
Definition
mcf5272.h:299
qspi_regs_t
Definition
mcf5272.h:290
sim_regs_t
Definition
mcf5272.h:216
timer_regs_t
Definition
mcf5272.h:382
uart_regs_t
Definition
mcf5272.h:332
usb_regs_t
Definition
mcf5272.h:577
