RTEMS
6.3
Toggle main menu visibility
bsps
m68k
include
mcf5223x
mcf5223x.h
1
2
* File: mcf5223x.h
3
* Purpose: Register and bit definitions
4
5
6
#ifndef __MCF5223x_H__
7
#define __MCF5223x_H__
8
9
typedef
volatile
unsigned
char
vuint8
10
typedef
volatile
unsigned
short
vuint16;
11
typedef
volatile
unsigned
long
vuint32;
12
13
14
15
* System Control Module (SCM)
16
17
18
19
/* Register read/write macros */
20
#define MCF_SCM_IPSBAR (*(vuint32*)(&__IPSBAR[0x000000]))
21
#define MCF_SCM_RAMBAR (*(vuint32*)(&__IPSBAR[0x000008]))
22
#define MCF_SCM_PPMRH (*(vuint32*)(&__IPSBAR[0x00000C]))
23
#define MCF_SCM_CRSR (*(vuint8 *)(&__IPSBAR[0x000010]))
24
#define MCF_SCM_CWCR (*(vuint8 *)(&__IPSBAR[0x000011]))
25
#define MCF_SCM_LPICR (*(vuint8 *)(&__IPSBAR[0x000012]))
26
#define MCF_SCM_CWSR (*(vuint8 *)(&__IPSBAR[0x000013]))
27
#define MCF_SCM_PPMRL (*(vuint32*)(&__IPSBAR[0x000018]))
28
#define MCF_SCM_MPARK (*(vuint32*)(&__IPSBAR[0x00001C]))
29
#define MCF_SCM_MPR (*(vuint32*)(&__IPSBAR[0x000020]))
30
#define MCF_SCM_PPMRS (*(vuint8 *)(&__IPSBAR[0x000021]))
31
#define MCF_SCM_PPMRC (*(vuint8 *)(&__IPSBAR[0x000022]))
32
#define MCF_SCM_IPSBMT (*(vuint8 *)(&__IPSBAR[0x000023]))
33
#define MCF_SCM_PACR0 (*(vuint8 *)(&__IPSBAR[0x000024]))
34
#define MCF_SCM_PACR1 (*(vuint8 *)(&__IPSBAR[0x000025]))
35
#define MCF_SCM_PACR2 (*(vuint8 *)(&__IPSBAR[0x000026]))
36
#define MCF_SCM_PACR3 (*(vuint8 *)(&__IPSBAR[0x000027]))
37
#define MCF_SCM_PACR4 (*(vuint8 *)(&__IPSBAR[0x000028]))
38
#define MCF_SCM_PACR5 (*(vuint8 *)(&__IPSBAR[0x000029]))
39
#define MCF_SCM_PACR6 (*(vuint8 *)(&__IPSBAR[0x00002A]))
40
#define MCF_SCM_PACR7 (*(vuint8 *)(&__IPSBAR[0x00002B]))
41
#define MCF_SCM_PACR8 (*(vuint8 *)(&__IPSBAR[0x00002C]))
42
#define MCF_SCM_GPACR0 (*(vuint8 *)(&__IPSBAR[0x000030]))
43
#define MCF_SCM_GPACR1 (*(vuint8 *)(&__IPSBAR[0x000031]))
44
45
/* Bit definitions and macros for MCF_SCM_IPSBAR */
46
#define MCF_SCM_IPSBAR_V (0x00000001)
47
#define MCF_SCM_IPSBAR_BA(x) ((x)&0xC0000000)
48
49
/* Bit definitions and macros for MCF_SCM_RAMBAR */
50
#define MCF_SCM_RAMBAR_BDE (0x00000200)
51
#define MCF_SCM_RAMBAR_BA(x) ((x)&0xFFFF0000)
52
53
/* Bit definitions and macros for MCF_SCM_CRSR */
54
#define MCF_SCM_CRSR_CWDR (0x20)
55
#define MCF_SCM_CRSR_EXT (0x80)
56
57
/* Bit definitions and macros for MCF_SCM_CWCR */
58
#define MCF_SCM_CWCR_CWTIC (0x01)
59
#define MCF_SCM_CWCR_CWTAVAL (0x02)
60
#define MCF_SCM_CWCR_CWTA (0x04)
61
#define MCF_SCM_CWCR_CWT(x) (((x)&0x07)<<3)
62
#define MCF_SCM_CWCR_CWRI (0x40)
63
#define MCF_SCM_CWCR_CWE (0x80)
64
65
/* Bit definitions and macros for MCF_SCM_LPICR */
66
#define MCF_SCM_LPICR_XIPL(x) (((x)&0x07)<<4)
67
#define MCF_SCM_LPICR_ENBSTOP (0x80)
68
69
/* Bit definitions and macros for MCF_SCM_CWSR */
70
#define MCF_SCM_CWSR_CWSR(x) (((x)&0xFF)<<0)
71
72
/* Bit definitions and macros for MCF_SCM_PPMRH */
73
#define MCF_SCM_PPMRH_CDPORTS (0x00000001)
74
#define MCF_SCM_PPMRH_CDEPORT (0x00000002)
75
#define MCF_SCM_PPMRH_CDPIT0 (0x00000008)
76
#define MCF_SCM_PPMRH_CDPIT1 (0x00000010)
77
#define MCF_SCM_PPMRH_CDADC (0x00000080)
78
#define MCF_SCM_PPMRH_CDGPT (0x00000100)
79
#define MCF_SCM_PPMRH_CDPWN (0x00000200)
80
#define MCF_SCM_PPMRH_CDFCAN (0x00000400)
81
#define MCF_SCM_PPMRH_CDCFM (0x00000800)
82
83
/* Bit definitions and macros for MCF_SCM_PPMRL */
84
#define MCF_SCM_PPMRL_CDG (0x00000002)
85
#define MCF_SCM_PPMRL_CDEIM (0x00000008)
86
#define MCF_SCM_PPMRL_CDDMA (0x00000010)
87
#define MCF_SCM_PPMRL_CDUART0 (0x00000020)
88
#define MCF_SCM_PPMRL_CDUART1 (0x00000040)
89
#define MCF_SCM_PPMRL_CDUART2 (0x00000080)
90
#define MCF_SCM_PPMRL_CDI2C (0x00000200)
91
#define MCF_SCM_PPMRL_CDQSPI (0x00000400)
92
#define MCF_SCM_PPMRL_CDDTIM0 (0x00002000)
93
#define MCF_SCM_PPMRL_CDDTIM1 (0x00004000)
94
#define MCF_SCM_PPMRL_CDDTIM2 (0x00008000)
95
#define MCF_SCM_PPMRL_CDDTIM3 (0x00010000)
96
#define MCF_SCM_PPMRL_CDINTC0 (0x00020000)
97
98
/* Bit definitions and macros for MCF_SCM_MPARK */
99
#define MCF_SCM_MPARK_LCKOUT_TIME(x) (((x)&0x0000000F)<<8)
100
#define MCF_SCM_MPARK_PRKLAST (0x00001000)
101
#define MCF_SCM_MPARK_TIMEOUT (0x00002000)
102
#define MCF_SCM_MPARK_FIXED (0x00004000)
103
#define MCF_SCM_MPARK_M0PRTY(x) (((x)&0x00000003)<<18)
104
#define MCF_SCM_MPARK_M2PRTY(x) (((x)&0x00000003)<<20)
105
#define MCF_SCM_MPARK_M3PRTY(x) (((x)&0x00000003)<<22)
106
#define MCF_SCM_MPARK_BCR24BIT (0x01000000)
107
#define MCF_SCM_MPARK_M2_P_EN (0x02000000)
108
109
/* Bit definitions and macros for MCF_SCM_PPMRS */
110
#define MCF_SCM_PPMRS_DISABLE_ALL (64)
111
#define MCF_SCM_PPMRS_DISABLE_CFM (43)
112
#define MCF_SCM_PPMRS_DISABLE_CAN (42)
113
#define MCF_SCM_PPMRS_DISABLE_PWM (41)
114
#define MCF_SCM_PPMRS_DISABLE_GPT (40)
115
#define MCF_SCM_PPMRS_DISABLE_ADC (39)
116
#define MCF_SCM_PPMRS_DISABLE_PIT1 (36)
117
#define MCF_SCM_PPMRS_DISABLE_PIT0 (35)
118
#define MCF_SCM_PPMRS_DISABLE_EPORT (33)
119
#define MCF_SCM_PPMRS_DISABLE_PORTS (32)
120
#define MCF_SCM_PPMRS_DISABLE_INTC (17)
121
#define MCF_SCM_PPMRS_DISABLE_DTIM3 (16)
122
#define MCF_SCM_PPMRS_DISABLE_DTIM2 (15)
123
#define MCF_SCM_PPMRS_DISABLE_DTIM1 (14)
124
#define MCF_SCM_PPMRS_DISABLE_DTIM0 (13)
125
#define MCF_SCM_PPMRS_DISABLE_QSPI (10)
126
#define MCF_SCM_PPMRS_DISABLE_I2C (9)
127
#define MCF_SCM_PPMRS_DISABLE_UART2 (7)
128
#define MCF_SCM_PPMRS_DISABLE_UART1 (6)
129
#define MCF_SCM_PPMRS_DISABLE_UART0 (5)
130
#define MCF_SCM_PPMRS_DISABLE_DMA (4)
131
#define MCF_SCM_PPMRS_SET_CDG (1)
132
133
/* Bit definitions and macros for MCF_SCM_PPMRC */
134
#define MCF_SCM_PPMRC_ENABLE_ALL (64)
135
#define MCF_SCM_PPMRC_ENABLE_CFM (43)
136
#define MCF_SCM_PPMRC_ENABLE_CAN (42)
137
#define MCF_SCM_PPMRC_ENABLE_PWM (41)
138
#define MCF_SCM_PPMRC_ENABLE_GPT (40)
139
#define MCF_SCM_PPMRC_ENABLE_ADC (39)
140
#define MCF_SCM_PPMRC_ENABLE_PIT1 (36)
141
#define MCF_SCM_PPMRC_ENABLE_PIT0 (35)
142
#define MCF_SCM_PPMRC_ENABLE_EPORT (33)
143
#define MCF_SCM_PPMRC_ENABLE_PORTS (32)
144
#define MCF_SCM_PPMRC_ENABLE_INTC (17)
145
#define MCF_SCM_PPMRC_ENABLE_DTIM3 (16)
146
#define MCF_SCM_PPMRC_ENABLE_DTIM2 (15)
147
#define MCF_SCM_PPMRC_ENABLE_DTIM1 (14)
148
#define MCF_SCM_PPMRC_ENABLE_DTIM0 (13)
149
#define MCF_SCM_PPMRC_ENABLE_QSPI (10)
150
#define MCF_SCM_PPMRC_ENABLE_I2C (9)
151
#define MCF_SCM_PPMRC_ENABLE_UART2 (7)
152
#define MCF_SCM_PPMRC_ENABLE_UART1 (6)
153
#define MCF_SCM_PPMRC_ENABLE_UART0 (5)
154
#define MCF_SCM_PPMRC_ENABLE_DMA (4)
155
#define MCF_SCM_PPMRC_CLEAR_CDG (1)
156
157
158
159
160
* Power Management Module (PMM)
161
162
163
164
165
#define MCF_PMM_PPMRH (*(vuint32*)(&__IPSBAR[0x00000C]))
166
#define MCF_PMM_PPMRL (*(vuint32*)(&__IPSBAR[0x000018]))
167
#define MCF_PMM_LPICR (*(vuint8 *)(&__IPSBAR[0x000012]))
168
#define MCF_PMM_LPCR (*(vuint8 *)(&__IPSBAR[0x110007]))
169
170
/* Bit definitions and macros for MCF_PMM_PPMRH */
171
#define MCF_PMM_PPMRH_CDPORTS (0x00000001)
172
#define MCF_PMM_PPMRH_CDEPORT (0x00000002)
173
#define MCF_PMM_PPMRH_CDPIT0 (0x00000008)
174
#define MCF_PMM_PPMRH_CDPIT1 (0x00000010)
175
#define MCF_PMM_PPMRH_CDADC (0x00000080)
176
#define MCF_PMM_PPMRH_CDGPT (0x00000100)
177
#define MCF_PMM_PPMRH_CDPWM (0x00000200)
178
#define MCF_PMM_PPMRH_CDFCAN (0x00000400)
179
#define MCF_PMM_PPMRH_CDCFM (0x00000800)
180
181
/* Bit definitions and macros for MCF_PMM_PPMRL */
182
#define MCF_PMM_PPMRL_CDG (0x00000002)
183
#define MCF_PMM_PPMRL_CDEIM (0x00000008)
184
#define MCF_PMM_PPMRL_CDDMA (0x00000010)
185
#define MCF_PMM_PPMRL_CDUART0 (0x00000020)
186
#define MCF_PMM_PPMRL_CDUART1 (0x00000040)
187
#define MCF_PMM_PPMRL_CDUART2 (0x00000080)
188
#define MCF_PMM_PPMRL_CDI2C (0x00000200)
189
#define MCF_PMM_PPMRL_CDQSPI (0x00000400)
190
#define MCF_PMM_PPMRL_CDDTIM0 (0x00002000)
191
#define MCF_PMM_PPMRL_CDDTIM1 (0x00004000)
192
#define MCF_PMM_PPMRL_CDDTIM2 (0x00008000)
193
#define MCF_PMM_PPMRL_CDDTIM3 (0x00010000)
194
#define MCF_PMM_PPMRL_CDINTC0 (0x00020000)
195
196
/* Bit definitions and macros for MCF_PMM_LPICR */
197
#define MCF_PMM_LPICR_XIPL(x) (((x)&0x07)<<4)
198
#define MCF_PMM_LPICR_ENBSTOP (0x80)
199
200
/* Bit definitions and macros for MCF_PMM_LPCR */
201
#define MCF_PMM_LPCR_LVDSE (0x02)
202
#define MCF_PMM_LPCR_STPMD(x) (((x)&0x03)<<3)
203
#define MCF_PMM_LPCR_LPMD(x) (((x)&0x03)<<6)
204
#define MCF_PMM_LPCR_LPMD_STOP (0xC0)
205
#define MCF_PMM_LPCR_LPMD_WAIT (0x80)
206
#define MCF_PMM_LPCR_LPMD_DOZE (0x40)
207
#define MCF_PMM_LPCR_LPMD_RUN (0x00)
208
209
210
211
212
* DMA Controller Module (DMA)
213
214
215
216
217
#define MCF_DMA_DMAREQC (*(vuint32*)(&__IPSBAR[0x000014]))
218
#define MCF_DMA_SAR0 (*(vuint32*)(&__IPSBAR[0x000100]))
219
#define MCF_DMA_SAR1 (*(vuint32*)(&__IPSBAR[0x000110]))
220
#define MCF_DMA_SAR2 (*(vuint32*)(&__IPSBAR[0x000120]))
221
#define MCF_DMA_SAR3 (*(vuint32*)(&__IPSBAR[0x000130]))
222
#define MCF_DMA_SAR(x) (*(vuint32*)(&__IPSBAR[0x000100+((x)*0x010)]))
223
#define MCF_DMA_DAR0 (*(vuint32*)(&__IPSBAR[0x000104]))
224
#define MCF_DMA_DAR1 (*(vuint32*)(&__IPSBAR[0x000114]))
225
#define MCF_DMA_DAR2 (*(vuint32*)(&__IPSBAR[0x000124]))
226
#define MCF_DMA_DAR3 (*(vuint32*)(&__IPSBAR[0x000134]))
227
#define MCF_DMA_DAR(x) (*(vuint32*)(&__IPSBAR[0x000104+((x)*0x010)]))
228
#define MCF_DMA_DSR0 (*(vuint8 *)(&__IPSBAR[0x000108]))
229
#define MCF_DMA_DSR1 (*(vuint8 *)(&__IPSBAR[0x000118]))
230
#define MCF_DMA_DSR2 (*(vuint8 *)(&__IPSBAR[0x000128]))
231
#define MCF_DMA_DSR3 (*(vuint8 *)(&__IPSBAR[0x000138]))
232
#define MCF_DMA_DSR(x) (*(vuint8 *)(&__IPSBAR[0x000108+((x)*0x010)]))
233
#define MCF_DMA_BCR0 (*(vuint32*)(&__IPSBAR[0x000108]))
234
#define MCF_DMA_BCR1 (*(vuint32*)(&__IPSBAR[0x000118]))
235
#define MCF_DMA_BCR2 (*(vuint32*)(&__IPSBAR[0x000128]))
236
#define MCF_DMA_BCR3 (*(vuint32*)(&__IPSBAR[0x000138]))
237
#define MCF_DMA_BCR(x) (*(vuint32*)(&__IPSBAR[0x000108+((x)*0x010)]))
238
#define MCF_DMA_DCR0 (*(vuint32*)(&__IPSBAR[0x00010C]))
239
#define MCF_DMA_DCR1 (*(vuint32*)(&__IPSBAR[0x00011C]))
240
#define MCF_DMA_DCR2 (*(vuint32*)(&__IPSBAR[0x00012C]))
241
#define MCF_DMA_DCR3 (*(vuint32*)(&__IPSBAR[0x00013C]))
242
#define MCF_DMA_DCR(x) (*(vuint32*)(&__IPSBAR[0x00010C+((x)*0x010)]))
243
244
/* Bit definitions and macros for MCF_DMA_DMAREQC */
245
#define MCF_DMA_DMAREQC_DMAC0(x) (((x)&0x0000000F)<<0)
246
#define MCF_DMA_DMAREQC_DMAC1(x) (((x)&0x0000000F)<<4)
247
#define MCF_DMA_DMAREQC_DMAC2(x) (((x)&0x0000000F)<<8)
248
#define MCF_DMA_DMAREQC_DMAC3(x) (((x)&0x0000000F)<<12)
249
#define MCF_DMA_DMAREQC_DMAREQC_EXT(x) (((x)&0x0000000F)<<16)
250
251
/* Bit definitions and macros for MCF_DMA_SAR */
252
#define MCF_DMA_SAR_SAR(x) (((x)&0xFFFFFFFF)<<0)
253
254
/* Bit definitions and macros for MCF_DMA_DAR */
255
#define MCF_DMA_DAR_DAR(x) (((x)&0xFFFFFFFF)<<0)
256
257
/* Bit definitions and macros for MCF_DMA_DSR */
258
#define MCF_DMA_DSR_DONE (0x01)
259
#define MCF_DMA_DSR_BSY (0x02)
260
#define MCF_DMA_DSR_REQ (0x04)
261
#define MCF_DMA_DSR_BED (0x10)
262
#define MCF_DMA_DSR_BES (0x20)
263
#define MCF_DMA_DSR_CE (0x40)
264
265
/* Bit definitions and macros for MCF_DMA_BCR */
266
#define MCF_DMA_BCR_BCR(x) (((x)&0x00FFFFFF)<<0)
267
#define MCF_DMA_BCR_DSR(x) (((x)&0x000000FF)<<24)
268
269
/* Bit definitions and macros for MCF_DMA_DCR */
270
#define MCF_DMA_DCR_LCH2(x) (((x)&0x00000003)<<0)
271
#define MCF_DMA_DCR_LCH1(x) (((x)&0x00000003)<<2)
272
#define MCF_DMA_DCR_LINKCC(x) (((x)&0x00000003)<<4)
273
#define MCF_DMA_DCR_D_REQ (0x00000080)
274
#define MCF_DMA_DCR_DMOD(x) (((x)&0x0000000F)<<8)
275
#define MCF_DMA_DCR_SMOD(x) (((x)&0x0000000F)<<12)
276
#define MCF_DMA_DCR_START (0x00010000)
277
#define MCF_DMA_DCR_DSIZE(x) (((x)&0x00000003)<<17)
278
#define MCF_DMA_DCR_DINC (0x00080000)
279
#define MCF_DMA_DCR_SSIZE(x) (((x)&0x00000003)<<20)
280
#define MCF_DMA_DCR_SINC (0x00400000)
281
#define MCF_DMA_DCR_BWC(x) (((x)&0x00000007)<<25)
282
#define MCF_DMA_DCR_AA (0x10000000)
283
#define MCF_DMA_DCR_CS (0x20000000)
284
#define MCF_DMA_DCR_EEXT (0x40000000)
285
#define MCF_DMA_DCR_INT (0x80000000)
286
#define MCF_DMA_DCR_BWC_16K (0x1)
287
#define MCF_DMA_DCR_BWC_32K (0x2)
288
#define MCF_DMA_DCR_BWC_64K (0x3)
289
#define MCF_DMA_DCR_BWC_128K (0x4)
290
#define MCF_DMA_DCR_BWC_256K (0x5)
291
#define MCF_DMA_DCR_BWC_512K (0x6)
292
#define MCF_DMA_DCR_BWC_1024K (0x7)
293
#define MCF_DMA_DCR_DMOD_DIS (0x0)
294
#define MCF_DMA_DCR_DMOD_16 (0x1)
295
#define MCF_DMA_DCR_DMOD_32 (0x2)
296
#define MCF_DMA_DCR_DMOD_64 (0x3)
297
#define MCF_DMA_DCR_DMOD_128 (0x4)
298
#define MCF_DMA_DCR_DMOD_256 (0x5)
299
#define MCF_DMA_DCR_DMOD_512 (0x6)
300
#define MCF_DMA_DCR_DMOD_1K (0x7)
301
#define MCF_DMA_DCR_DMOD_2K (0x8)
302
#define MCF_DMA_DCR_DMOD_4K (0x9)
303
#define MCF_DMA_DCR_DMOD_8K (0xA)
304
#define MCF_DMA_DCR_DMOD_16K (0xB)
305
#define MCF_DMA_DCR_DMOD_32K (0xC)
306
#define MCF_DMA_DCR_DMOD_64K (0xD)
307
#define MCF_DMA_DCR_DMOD_128K (0xE)
308
#define MCF_DMA_DCR_DMOD_256K (0xF)
309
#define MCF_DMA_DCR_SMOD_DIS (0x0)
310
#define MCF_DMA_DCR_SMOD_16 (0x1)
311
#define MCF_DMA_DCR_SMOD_32 (0x2)
312
#define MCF_DMA_DCR_SMOD_64 (0x3)
313
#define MCF_DMA_DCR_SMOD_128 (0x4)
314
#define MCF_DMA_DCR_SMOD_256 (0x5)
315
#define MCF_DMA_DCR_SMOD_512 (0x6)
316
#define MCF_DMA_DCR_SMOD_1K (0x7)
317
#define MCF_DMA_DCR_SMOD_2K (0x8)
318
#define MCF_DMA_DCR_SMOD_4K (0x9)
319
#define MCF_DMA_DCR_SMOD_8K (0xA)
320
#define MCF_DMA_DCR_SMOD_16K (0xB)
321
#define MCF_DMA_DCR_SMOD_32K (0xC)
322
#define MCF_DMA_DCR_SMOD_64K (0xD)
323
#define MCF_DMA_DCR_SMOD_128K (0xE)
324
#define MCF_DMA_DCR_SMOD_256K (0xF)
325
#define MCF_DMA_DCR_SSIZE_LONG (0x0)
326
#define MCF_DMA_DCR_SSIZE_BYTE (0x1)
327
#define MCF_DMA_DCR_SSIZE_WORD (0x2)
328
#define MCF_DMA_DCR_SSIZE_LINE (0x3)
329
#define MCF_DMA_DCR_DSIZE_LONG (0x0)
330
#define MCF_DMA_DCR_DSIZE_BYTE (0x1)
331
#define MCF_DMA_DCR_DSIZE_WORD (0x2)
332
#define MCF_DMA_DCR_DSIZE_LINE (0x3)
333
#define MCF_DMA_DCR_LCH1_CH0 (0x0)
334
#define MCF_DMA_DCR_LCH1_CH1 (0x1)
335
#define MCF_DMA_DCR_LCH1_CH2 (0x2)
336
#define MCF_DMA_DCR_LCH1_CH3 (0x3)
337
#define MCF_DMA_DCR_LCH2_CH0 (0x0)
338
#define MCF_DMA_DCR_LCH2_CH1 (0x1)
339
#define MCF_DMA_DCR_LCH2_CH2 (0x2)
340
#define MCF_DMA_DCR_LCH2_CH3 (0x3)
341
342
343
344
345
* Universal Asynchronous Receiver Transmitter (UART)
346
347
348
349
350
#define MCF_UART0_UMR (*(vuint8 *)(&__IPSBAR[0x000200]))
351
#define MCF_UART0_USR (*(vuint8 *)(&__IPSBAR[0x000204]))
352
#define MCF_UART0_UCSR (*(vuint8 *)(&__IPSBAR[0x000204]))
353
#define MCF_UART0_UCR (*(vuint8 *)(&__IPSBAR[0x000208]))
354
#define MCF_UART0_URB (*(vuint8 *)(&__IPSBAR[0x00020C]))
355
#define MCF_UART0_UTB (*(vuint8 *)(&__IPSBAR[0x00020C]))
356
#define MCF_UART0_UIPCR (*(vuint8 *)(&__IPSBAR[0x000210]))
357
#define MCF_UART0_UACR (*(vuint8 *)(&__IPSBAR[0x000210]))
358
#define MCF_UART0_UISR (*(vuint8 *)(&__IPSBAR[0x000214]))
359
#define MCF_UART0_UIMR (*(vuint8 *)(&__IPSBAR[0x000214]))
360
#define MCF_UART0_UBG1 (*(vuint8 *)(&__IPSBAR[0x000218]))
361
#define MCF_UART0_UBG2 (*(vuint8 *)(&__IPSBAR[0x00021C]))
362
#define MCF_UART0_UIP (*(vuint8 *)(&__IPSBAR[0x000234]))
363
#define MCF_UART0_UOP1 (*(vuint8 *)(&__IPSBAR[0x000238]))
364
#define MCF_UART0_UOP0 (*(vuint8 *)(&__IPSBAR[0x00023C]))
365
#define MCF_UART1_UMR (*(vuint8 *)(&__IPSBAR[0x000240]))
366
#define MCF_UART1_USR (*(vuint8 *)(&__IPSBAR[0x000244]))
367
#define MCF_UART1_UCSR (*(vuint8 *)(&__IPSBAR[0x000244]))
368
#define MCF_UART1_UCR (*(vuint8 *)(&__IPSBAR[0x000248]))
369
#define MCF_UART1_URB (*(vuint8 *)(&__IPSBAR[0x00024C]))
370
#define MCF_UART1_UTB (*(vuint8 *)(&__IPSBAR[0x00024C]))
371
#define MCF_UART1_UIPCR (*(vuint8 *)(&__IPSBAR[0x000250]))
372
#define MCF_UART1_UACR (*(vuint8 *)(&__IPSBAR[0x000250]))
373
#define MCF_UART1_UISR (*(vuint8 *)(&__IPSBAR[0x000254]))
374
#define MCF_UART1_UIMR (*(vuint8 *)(&__IPSBAR[0x000254]))
375
#define MCF_UART1_UBG1 (*(vuint8 *)(&__IPSBAR[0x000258]))
376
#define MCF_UART1_UBG2 (*(vuint8 *)(&__IPSBAR[0x00025C]))
377
#define MCF_UART1_UIP (*(vuint8 *)(&__IPSBAR[0x000274]))
378
#define MCF_UART1_UOP1 (*(vuint8 *)(&__IPSBAR[0x000278]))
379
#define MCF_UART1_UOP0 (*(vuint8 *)(&__IPSBAR[0x00027C]))
380
#define MCF_UART2_UMR (*(vuint8 *)(&__IPSBAR[0x000280]))
381
#define MCF_UART2_USR (*(vuint8 *)(&__IPSBAR[0x000284]))
382
#define MCF_UART2_UCSR (*(vuint8 *)(&__IPSBAR[0x000284]))
383
#define MCF_UART2_UCR (*(vuint8 *)(&__IPSBAR[0x000288]))
384
#define MCF_UART2_URB (*(vuint8 *)(&__IPSBAR[0x00028C]))
385
#define MCF_UART2_UTB (*(vuint8 *)(&__IPSBAR[0x00028C]))
386
#define MCF_UART2_UIPCR (*(vuint8 *)(&__IPSBAR[0x000290]))
387
#define MCF_UART2_UACR (*(vuint8 *)(&__IPSBAR[0x000290]))
388
#define MCF_UART2_UISR (*(vuint8 *)(&__IPSBAR[0x000294]))
389
#define MCF_UART2_UIMR (*(vuint8 *)(&__IPSBAR[0x000294]))
390
#define MCF_UART2_UBG1 (*(vuint8 *)(&__IPSBAR[0x000298]))
391
#define MCF_UART2_UBG2 (*(vuint8 *)(&__IPSBAR[0x00029C]))
392
#define MCF_UART2_UIP (*(vuint8 *)(&__IPSBAR[0x0002B4]))
393
#define MCF_UART2_UOP1 (*(vuint8 *)(&__IPSBAR[0x0002B8]))
394
#define MCF_UART2_UOP0 (*(vuint8 *)(&__IPSBAR[0x0002BC]))
395
#define MCF_UART_UMR(x) (*(vuint8 *)(&__IPSBAR[0x000200+((x)*0x040)]))
396
#define MCF_UART_USR(x) (*(vuint8 *)(&__IPSBAR[0x000204+((x)*0x040)]))
397
#define MCF_UART_UCSR(x) (*(vuint8 *)(&__IPSBAR[0x000204+((x)*0x040)]))
398
#define MCF_UART_UCR(x) (*(vuint8 *)(&__IPSBAR[0x000208+((x)*0x040)]))
399
#define MCF_UART_URB(x) (*(vuint8 *)(&__IPSBAR[0x00020C+((x)*0x040)]))
400
#define MCF_UART_UTB(x) (*(vuint8 *)(&__IPSBAR[0x00020C+((x)*0x040)]))
401
#define MCF_UART_UIPCR(x) (*(vuint8 *)(&__IPSBAR[0x000210+((x)*0x040)]))
402
#define MCF_UART_UACR(x) (*(vuint8 *)(&__IPSBAR[0x000210+((x)*0x040)]))
403
#define MCF_UART_UISR(x) (*(vuint8 *)(&__IPSBAR[0x000214+((x)*0x040)]))
404
#define MCF_UART_UIMR(x) (*(vuint8 *)(&__IPSBAR[0x000214+((x)*0x040)]))
405
#define MCF_UART_UBG1(x) (*(vuint8 *)(&__IPSBAR[0x000218+((x)*0x040)]))
406
#define MCF_UART_UBG2(x) (*(vuint8 *)(&__IPSBAR[0x00021C+((x)*0x040)]))
407
#define MCF_UART_UIP(x) (*(vuint8 *)(&__IPSBAR[0x000234+((x)*0x040)]))
408
#define MCF_UART_UOP1(x) (*(vuint8 *)(&__IPSBAR[0x000238+((x)*0x040)]))
409
#define MCF_UART_UOP0(x) (*(vuint8 *)(&__IPSBAR[0x00023C+((x)*0x040)]))
410
411
/* Bit definitions and macros for MCF_UART_UMR */
412
#define MCF_UART_UMR_BC(x) (((x)&0x03)<<0)
413
#define MCF_UART_UMR_PT (0x04)
414
#define MCF_UART_UMR_PM(x) (((x)&0x03)<<3)
415
#define MCF_UART_UMR_ERR (0x20)
416
#define MCF_UART_UMR_RXIRQ (0x40)
417
#define MCF_UART_UMR_RXRTS (0x80)
418
#define MCF_UART_UMR_SB(x) (((x)&0x0F)<<0)
419
#define MCF_UART_UMR_TXCTS (0x10)
420
#define MCF_UART_UMR_TXRTS (0x20)
421
#define MCF_UART_UMR_CM(x) (((x)&0x03)<<6)
422
#define MCF_UART_UMR_PM_MULTI_ADDR (0x1C)
423
#define MCF_UART_UMR_PM_MULTI_DATA (0x18)
424
#define MCF_UART_UMR_PM_NONE (0x10)
425
#define MCF_UART_UMR_PM_FORCE_HI (0x0C)
426
#define MCF_UART_UMR_PM_FORCE_LO (0x08)
427
#define MCF_UART_UMR_PM_ODD (0x04)
428
#define MCF_UART_UMR_PM_EVEN (0x00)
429
#define MCF_UART_UMR_BC_5 (0x00)
430
#define MCF_UART_UMR_BC_6 (0x01)
431
#define MCF_UART_UMR_BC_7 (0x02)
432
#define MCF_UART_UMR_BC_8 (0x03)
433
#define MCF_UART_UMR_CM_NORMAL (0x00)
434
#define MCF_UART_UMR_CM_ECHO (0x40)
435
#define MCF_UART_UMR_CM_LOCAL_LOOP (0x80)
436
#define MCF_UART_UMR_CM_REMOTE_LOOP (0xC0)
437
#define MCF_UART_UMR_SB_STOP_BITS_1 (0x07)
438
#define MCF_UART_UMR_SB_STOP_BITS_15 (0x08)
439
#define MCF_UART_UMR_SB_STOP_BITS_2 (0x0F)
440
441
/* Bit definitions and macros for MCF_UART_USR */
442
#define MCF_UART_USR_RXRDY (0x01)
443
#define MCF_UART_USR_FFULL (0x02)
444
#define MCF_UART_USR_TXRDY (0x04)
445
#define MCF_UART_USR_TXEMP (0x08)
446
#define MCF_UART_USR_OE (0x10)
447
#define MCF_UART_USR_PE (0x20)
448
#define MCF_UART_USR_FE (0x40)
449
#define MCF_UART_USR_RB (0x80)
450
451
/* Bit definitions and macros for MCF_UART_UCSR */
452
#define MCF_UART_UCSR_TCS(x) (((x)&0x0F)<<0)
453
#define MCF_UART_UCSR_RCS(x) (((x)&0x0F)<<4)
454
#define MCF_UART_UCSR_RCS_SYS_CLK (0xD0)
455
#define MCF_UART_UCSR_RCS_CTM16 (0xE0)
456
#define MCF_UART_UCSR_RCS_CTM (0xF0)
457
#define MCF_UART_UCSR_TCS_SYS_CLK (0x0D)
458
#define MCF_UART_UCSR_TCS_CTM16 (0x0E)
459
#define MCF_UART_UCSR_TCS_CTM (0x0F)
460
461
/* Bit definitions and macros for MCF_UART_UCR */
462
#define MCF_UART_UCR_RXC(x) (((x)&0x03)<<0)
463
#define MCF_UART_UCR_TXC(x) (((x)&0x03)<<2)
464
#define MCF_UART_UCR_MISC(x) (((x)&0x07)<<4)
465
#define MCF_UART_UCR_NONE (0x00)
466
#define MCF_UART_UCR_STOP_BREAK (0x70)
467
#define MCF_UART_UCR_START_BREAK (0x60)
468
#define MCF_UART_UCR_BKCHGINT (0x50)
469
#define MCF_UART_UCR_RESET_ERROR (0x40)
470
#define MCF_UART_UCR_RESET_TX (0x30)
471
#define MCF_UART_UCR_RESET_RX (0x20)
472
#define MCF_UART_UCR_RESET_MR (0x10)
473
#define MCF_UART_UCR_TX_DISABLED (0x08)
474
#define MCF_UART_UCR_TX_ENABLED (0x04)
475
#define MCF_UART_UCR_RX_DISABLED (0x02)
476
#define MCF_UART_UCR_RX_ENABLED (0x01)
477
478
/* Bit definitions and macros for MCF_UART_UIPCR */
479
#define MCF_UART_UIPCR_CTS (0x01)
480
#define MCF_UART_UIPCR_COS (0x10)
481
482
/* Bit definitions and macros for MCF_UART_UACR */
483
#define MCF_UART_UACR_IEC (0x01)
484
485
/* Bit definitions and macros for MCF_UART_UISR */
486
#define MCF_UART_UISR_TXRDY (0x01)
487
#define MCF_UART_UISR_RXRDY_FU (0x02)
488
#define MCF_UART_UISR_DB (0x04)
489
#define MCF_UART_UISR_RXFTO (0x08)
490
#define MCF_UART_UISR_TXFIFO (0x10)
491
#define MCF_UART_UISR_RXFIFO (0x20)
492
#define MCF_UART_UISR_COS (0x80)
493
494
/* Bit definitions and macros for MCF_UART_UIMR */
495
#define MCF_UART_UIMR_TXRDY (0x01)
496
#define MCF_UART_UIMR_RXRDY_FU (0x02)
497
#define MCF_UART_UIMR_DB (0x04)
498
#define MCF_UART_UIMR_COS (0x80)
499
500
/* Bit definitions and macros for MCF_UART_UIP */
501
#define MCF_UART_UIP_CTS (0x01)
502
503
/* Bit definitions and macros for MCF_UART_UOP1 */
504
#define MCF_UART_UOP1_RTS (0x01)
505
506
/* Bit definitions and macros for MCF_UART_UOP0 */
507
#define MCF_UART_UOP0_RTS (0x01)
508
509
510
511
* I2C Module (I2C)
512
513
514
515
516
#define MCF_I2C_I2AR (*(vuint8 *)(&__IPSBAR[0x000300]))
517
#define MCF_I2C_I2FDR (*(vuint8 *)(&__IPSBAR[0x000304]))
518
#define MCF_I2C_I2CR (*(vuint8 *)(&__IPSBAR[0x000308]))
519
#define MCF_I2C_I2SR (*(vuint8 *)(&__IPSBAR[0x00030C]))
520
#define MCF_I2C_I2DR (*(vuint8 *)(&__IPSBAR[0x000310]))
521
522
/* Bit definitions and macros for MCF_I2C_I2AR */
523
#define MCF_I2C_I2AR_ADR(x) (((x)&0x7F)<<1)
524
525
/* Bit definitions and macros for MCF_I2C_I2FDR */
526
#define MCF_I2C_I2FDR_IC(x) (((x)&0x3F)<<0)
527
528
/* Bit definitions and macros for MCF_I2C_I2CR */
529
#define MCF_I2C_I2CR_RSTA (0x04)
530
#define MCF_I2C_I2CR_TXAK (0x08)
531
#define MCF_I2C_I2CR_MTX (0x10)
532
#define MCF_I2C_I2CR_MSTA (0x20)
533
#define MCF_I2C_I2CR_IIEN (0x40)
534
#define MCF_I2C_I2CR_IEN (0x80)
535
536
/* Bit definitions and macros for MCF_I2C_I2SR */
537
#define MCF_I2C_I2SR_RXAK (0x01)
538
#define MCF_I2C_I2SR_IIF (0x02)
539
#define MCF_I2C_I2SR_SRW (0x04)
540
#define MCF_I2C_I2SR_IAL (0x10)
541
#define MCF_I2C_I2SR_IBB (0x20)
542
#define MCF_I2C_I2SR_IAAS (0x40)
543
#define MCF_I2C_I2SR_ICF (0x80)
544
545
/* Bit definitions and macros for MCF_I2C_I2DR */
546
#define MCF_I2C_I2DR_DATA(x) (((x)&0xFF)<<0)
547
548
/* Bit definitions and macros for MCF_I2C_I2ICR */
549
#define MCF_I2C_I2ICR_IE (0x01)
550
#define MCF_I2C_I2ICR_RE (0x02)
551
#define MCF_I2C_I2ICR_TE (0x04)
552
#define MCF_I2C_I2ICR_BNBE (0x08)
553
554
555
556
* Queued Serial Peripheral Interface (QSPI)
557
558
559
560
561
#define MCF_QSPI_QMR (*(vuint16*)(&__IPSBAR[0x000340]))
562
#define MCF_QSPI_QDLYR (*(vuint16*)(&__IPSBAR[0x000344]))
563
#define MCF_QSPI_QWR (*(vuint16*)(&__IPSBAR[0x000348]))
564
#define MCF_QSPI_QIR (*(vuint16*)(&__IPSBAR[0x00034C]))
565
#define MCF_QSPI_QAR (*(vuint16*)(&__IPSBAR[0x000350]))
566
#define MCF_QSPI_QDR (*(vuint16*)(&__IPSBAR[0x000354]))
567
568
/* Bit definitions and macros for MCF_QSPI_QMR */
569
#define MCF_QSPI_QMR_BAUD(x) (((x)&0x00FF)<<0)
570
#define MCF_QSPI_QMR_CPHA (0x0100)
571
#define MCF_QSPI_QMR_CPOL (0x0200)
572
#define MCF_QSPI_QMR_BITS(x) (((x)&0x000F)<<10)
573
#define MCF_QSPI_QMR_DOHIE (0x4000)
574
#define MCF_QSPI_QMR_MSTR (0x8000)
575
576
/* Bit definitions and macros for MCF_QSPI_QDLYR */
577
#define MCF_QSPI_QDLYR_DTL(x) (((x)&0x00FF)<<0)
578
#define MCF_QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8)
579
#define MCF_QSPI_QDLYR_SPE (0x8000)
580
581
/* Bit definitions and macros for MCF_QSPI_QWR */
582
#define MCF_QSPI_QWR_NEWQP(x) (((x)&0x000F)<<0)
583
#define MCF_QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8)
584
#define MCF_QSPI_QWR_CSIV (0x1000)
585
#define MCF_QSPI_QWR_WRTO (0x2000)
586
#define MCF_QSPI_QWR_WREN (0x4000)
587
#define MCF_QSPI_QWR_HALT (0x8000)
588
589
/* Bit definitions and macros for MCF_QSPI_QIR */
590
#define MCF_QSPI_QIR_SPIF (0x0001)
591
#define MCF_QSPI_QIR_ABRT (0x0004)
592
#define MCF_QSPI_QIR_WCEF (0x0008)
593
#define MCF_QSPI_QIR_SPIFE (0x0100)
594
#define MCF_QSPI_QIR_ABRTE (0x0400)
595
#define MCF_QSPI_QIR_WCEFE (0x0800)
596
#define MCF_QSPI_QIR_ABRTL (0x1000)
597
#define MCF_QSPI_QIR_ABRTB (0x4000)
598
#define MCF_QSPI_QIR_WCEFB (0x8000)
599
600
/* Bit definitions and macros for MCF_QSPI_QAR */
601
#define MCF_QSPI_QAR_ADDR(x) (((x)&0x003F)<<0)
602
603
/* Bit definitions and macros for MCF_QSPI_QDR */
604
#define MCF_QSPI_QDR_DATA(x) (((x)&0xFFFF)<<0)
605
606
607
608
* DMA Timers (DTIM)
609
610
611
612
613
#define MCF_DTIM0_DTMR (*(vuint16*)(&__IPSBAR[0x000400]))
614
#define MCF_DTIM0_DTXMR (*(vuint8 *)(&__IPSBAR[0x000402]))
615
#define MCF_DTIM0_DTER (*(vuint8 *)(&__IPSBAR[0x000403]))
616
#define MCF_DTIM0_DTRR (*(vuint32*)(&__IPSBAR[0x000404]))
617
#define MCF_DTIM0_DTCR (*(vuint32*)(&__IPSBAR[0x000408]))
618
#define MCF_DTIM0_DTCN (*(vuint32*)(&__IPSBAR[0x00040C]))
619
#define MCF_DTIM1_DTMR (*(vuint16*)(&__IPSBAR[0x000440]))
620
#define MCF_DTIM1_DTXMR (*(vuint8 *)(&__IPSBAR[0x000442]))
621
#define MCF_DTIM1_DTER (*(vuint8 *)(&__IPSBAR[0x000443]))
622
#define MCF_DTIM1_DTRR (*(vuint32*)(&__IPSBAR[0x000444]))
623
#define MCF_DTIM1_DTCR (*(vuint32*)(&__IPSBAR[0x000448]))
624
#define MCF_DTIM1_DTCN (*(vuint32*)(&__IPSBAR[0x00044C]))
625
#define MCF_DTIM2_DTMR (*(vuint16*)(&__IPSBAR[0x000480]))
626
#define MCF_DTIM2_DTXMR (*(vuint8 *)(&__IPSBAR[0x000482]))
627
#define MCF_DTIM2_DTER (*(vuint8 *)(&__IPSBAR[0x000483]))
628
#define MCF_DTIM2_DTRR (*(vuint32*)(&__IPSBAR[0x000484]))
629
#define MCF_DTIM2_DTCR (*(vuint32*)(&__IPSBAR[0x000488]))
630
#define MCF_DTIM2_DTCN (*(vuint32*)(&__IPSBAR[0x00048C]))
631
#define MCF_DTIM3_DTMR (*(vuint16*)(&__IPSBAR[0x0004C0]))
632
#define MCF_DTIM3_DTXMR (*(vuint8 *)(&__IPSBAR[0x0004C2]))
633
#define MCF_DTIM3_DTER (*(vuint8 *)(&__IPSBAR[0x0004C3]))
634
#define MCF_DTIM3_DTRR (*(vuint32*)(&__IPSBAR[0x0004C4]))
635
#define MCF_DTIM3_DTCR (*(vuint32*)(&__IPSBAR[0x0004C8]))
636
#define MCF_DTIM3_DTCN (*(vuint32*)(&__IPSBAR[0x0004CC]))
637
#define MCF_DTIM_DTMR(x) (*(vuint16*)(&__IPSBAR[0x000400+((x)*0x040)]))
638
#define MCF_DTIM_DTXMR(x) (*(vuint8 *)(&__IPSBAR[0x000402+((x)*0x040)]))
639
#define MCF_DTIM_DTER(x) (*(vuint8 *)(&__IPSBAR[0x000403+((x)*0x040)]))
640
#define MCF_DTIM_DTRR(x) (*(vuint32*)(&__IPSBAR[0x000404+((x)*0x040)]))
641
#define MCF_DTIM_DTCR(x) (*(vuint32*)(&__IPSBAR[0x000408+((x)*0x040)]))
642
#define MCF_DTIM_DTCN(x) (*(vuint32*)(&__IPSBAR[0x00040C+((x)*0x040)]))
643
644
/* Bit definitions and macros for MCF_DTIM_DTMR */
645
#define MCF_DTIM_DTMR_RST (0x0001)
646
#define MCF_DTIM_DTMR_CLK(x) (((x)&0x0003)<<1)
647
#define MCF_DTIM_DTMR_FRR (0x0008)
648
#define MCF_DTIM_DTMR_ORRI (0x0010)
649
#define MCF_DTIM_DTMR_OM (0x0020)
650
#define MCF_DTIM_DTMR_CE(x) (((x)&0x0003)<<6)
651
#define MCF_DTIM_DTMR_PS(x) (((x)&0x00FF)<<8)
652
#define MCF_DTIM_DTMR_CE_ANY (0x00C0)
653
#define MCF_DTIM_DTMR_CE_FALL (0x0080)
654
#define MCF_DTIM_DTMR_CE_RISE (0x0040)
655
#define MCF_DTIM_DTMR_CE_NONE (0x0000)
656
#define MCF_DTIM_DTMR_CLK_DTIN (0x0006)
657
#define MCF_DTIM_DTMR_CLK_DIV16 (0x0004)
658
#define MCF_DTIM_DTMR_CLK_DIV1 (0x0002)
659
#define MCF_DTIM_DTMR_CLK_STOP (0x0000)
660
661
/* Bit definitions and macros for MCF_DTIM_DTXMR */
662
#define MCF_DTIM_DTXMR_MODE16 (0x01)
663
#define MCF_DTIM_DTXMR_DMAEN (0x80)
664
665
/* Bit definitions and macros for MCF_DTIM_DTER */
666
#define MCF_DTIM_DTER_CAP (0x01)
667
#define MCF_DTIM_DTER_REF (0x02)
668
669
/* Bit definitions and macros for MCF_DTIM_DTRR */
670
#define MCF_DTIM_DTRR_REF(x) (((x)&0xFFFFFFFF)<<0)
671
672
/* Bit definitions and macros for MCF_DTIM_DTCR */
673
#define MCF_DTIM_DTCR_CAP(x) (((x)&0xFFFFFFFF)<<0)
674
675
/* Bit definitions and macros for MCF_DTIM_DTCN */
676
#define MCF_DTIM_DTCN_CNT(x) (((x)&0xFFFFFFFF)<<0)
677
678
679
680
* Interrupt Controller (INTC)
681
682
683
684
685
#define MCF_INTC0_IPRH (*(vuint32*)(&__IPSBAR[0x000C00]))
686
#define MCF_INTC0_IPRL (*(vuint32*)(&__IPSBAR[0x000C04]))
687
#define MCF_INTC0_IMRH (*(vuint32*)(&__IPSBAR[0x000C08]))
688
#define MCF_INTC0_IMRL (*(vuint32*)(&__IPSBAR[0x000C0C]))
689
#define MCF_INTC0_INTFRCH (*(vuint32*)(&__IPSBAR[0x000C10]))
690
#define MCF_INTC0_INTFRCL (*(vuint32*)(&__IPSBAR[0x000C14]))
691
#define MCF_INTC0_IRLR (*(vuint8 *)(&__IPSBAR[0x000C18]))
692
#define MCF_INTC0_IACKLPR (*(vuint8 *)(&__IPSBAR[0x000C19]))
693
#define MCF_INTC0_ICR1 (*(vuint8 *)(&__IPSBAR[0x000C41]))
694
#define MCF_INTC0_ICR2 (*(vuint8 *)(&__IPSBAR[0x000C42]))
695
#define MCF_INTC0_ICR3 (*(vuint8 *)(&__IPSBAR[0x000C43]))
696
#define MCF_INTC0_ICR4 (*(vuint8 *)(&__IPSBAR[0x000C44]))
697
#define MCF_INTC0_ICR5 (*(vuint8 *)(&__IPSBAR[0x000C45]))
698
#define MCF_INTC0_ICR6 (*(vuint8 *)(&__IPSBAR[0x000C46]))
699
#define MCF_INTC0_ICR7 (*(vuint8 *)(&__IPSBAR[0x000C47]))
700
#define MCF_INTC0_ICR8 (*(vuint8 *)(&__IPSBAR[0x000C48]))
701
#define MCF_INTC0_ICR9 (*(vuint8 *)(&__IPSBAR[0x000C49]))
702
#define MCF_INTC0_ICR10 (*(vuint8 *)(&__IPSBAR[0x000C4A]))
703
#define MCF_INTC0_ICR11 (*(vuint8 *)(&__IPSBAR[0x000C4B]))
704
#define MCF_INTC0_ICR12 (*(vuint8 *)(&__IPSBAR[0x000C4C]))
705
#define MCF_INTC0_ICR13 (*(vuint8 *)(&__IPSBAR[0x000C4D]))
706
#define MCF_INTC0_ICR14 (*(vuint8 *)(&__IPSBAR[0x000C4E]))
707
#define MCF_INTC0_ICR15 (*(vuint8 *)(&__IPSBAR[0x000C4F]))
708
#define MCF_INTC0_ICR16 (*(vuint8 *)(&__IPSBAR[0x000C50]))
709
#define MCF_INTC0_ICR17 (*(vuint8 *)(&__IPSBAR[0x000C51]))
710
#define MCF_INTC0_ICR18 (*(vuint8 *)(&__IPSBAR[0x000C52]))
711
#define MCF_INTC0_ICR19 (*(vuint8 *)(&__IPSBAR[0x000C53]))
712
#define MCF_INTC0_ICR20 (*(vuint8 *)(&__IPSBAR[0x000C54]))
713
#define MCF_INTC0_ICR21 (*(vuint8 *)(&__IPSBAR[0x000C55]))
714
#define MCF_INTC0_ICR22 (*(vuint8 *)(&__IPSBAR[0x000C56]))
715
#define MCF_INTC0_ICR23 (*(vuint8 *)(&__IPSBAR[0x000C57]))
716
#define MCF_INTC0_ICR24 (*(vuint8 *)(&__IPSBAR[0x000C58]))
717
#define MCF_INTC0_ICR25 (*(vuint8 *)(&__IPSBAR[0x000C59]))
718
#define MCF_INTC0_ICR26 (*(vuint8 *)(&__IPSBAR[0x000C5A]))
719
#define MCF_INTC0_ICR27 (*(vuint8 *)(&__IPSBAR[0x000C5B]))
720
#define MCF_INTC0_ICR28 (*(vuint8 *)(&__IPSBAR[0x000C5C]))
721
#define MCF_INTC0_ICR29 (*(vuint8 *)(&__IPSBAR[0x000C5D]))
722
#define MCF_INTC0_ICR30 (*(vuint8 *)(&__IPSBAR[0x000C5E]))
723
#define MCF_INTC0_ICR31 (*(vuint8 *)(&__IPSBAR[0x000C5F]))
724
#define MCF_INTC0_ICR32 (*(vuint8 *)(&__IPSBAR[0x000C60]))
725
#define MCF_INTC0_ICR33 (*(vuint8 *)(&__IPSBAR[0x000C61]))
726
#define MCF_INTC0_ICR34 (*(vuint8 *)(&__IPSBAR[0x000C62]))
727
#define MCF_INTC0_ICR35 (*(vuint8 *)(&__IPSBAR[0x000C63]))
728
#define MCF_INTC0_ICR36 (*(vuint8 *)(&__IPSBAR[0x000C64]))
729
#define MCF_INTC0_ICR37 (*(vuint8 *)(&__IPSBAR[0x000C65]))
730
#define MCF_INTC0_ICR38 (*(vuint8 *)(&__IPSBAR[0x000C66]))
731
#define MCF_INTC0_ICR39 (*(vuint8 *)(&__IPSBAR[0x000C67]))
732
#define MCF_INTC0_ICR40 (*(vuint8 *)(&__IPSBAR[0x000C68]))
733
#define MCF_INTC0_ICR41 (*(vuint8 *)(&__IPSBAR[0x000C69]))
734
#define MCF_INTC0_ICR42 (*(vuint8 *)(&__IPSBAR[0x000C6A]))
735
#define MCF_INTC0_ICR43 (*(vuint8 *)(&__IPSBAR[0x000C6B]))
736
#define MCF_INTC0_ICR44 (*(vuint8 *)(&__IPSBAR[0x000C6C]))
737
#define MCF_INTC0_ICR45 (*(vuint8 *)(&__IPSBAR[0x000C6D]))
738
#define MCF_INTC0_ICR46 (*(vuint8 *)(&__IPSBAR[0x000C6E]))
739
#define MCF_INTC0_ICR47 (*(vuint8 *)(&__IPSBAR[0x000C6F]))
740
#define MCF_INTC0_ICR48 (*(vuint8 *)(&__IPSBAR[0x000C70]))
741
#define MCF_INTC0_ICR49 (*(vuint8 *)(&__IPSBAR[0x000C71]))
742
#define MCF_INTC0_ICR50 (*(vuint8 *)(&__IPSBAR[0x000C72]))
743
#define MCF_INTC0_ICR51 (*(vuint8 *)(&__IPSBAR[0x000C73]))
744
#define MCF_INTC0_ICR52 (*(vuint8 *)(&__IPSBAR[0x000C74]))
745
#define MCF_INTC0_ICR53 (*(vuint8 *)(&__IPSBAR[0x000C75]))
746
#define MCF_INTC0_ICR54 (*(vuint8 *)(&__IPSBAR[0x000C76]))
747
#define MCF_INTC0_ICR55 (*(vuint8 *)(&__IPSBAR[0x000C77]))
748
#define MCF_INTC0_ICR56 (*(vuint8 *)(&__IPSBAR[0x000C78]))
749
#define MCF_INTC0_ICR57 (*(vuint8 *)(&__IPSBAR[0x000C79]))
750
#define MCF_INTC0_ICR58 (*(vuint8 *)(&__IPSBAR[0x000C7A]))
751
#define MCF_INTC0_ICR59 (*(vuint8 *)(&__IPSBAR[0x000C7B]))
752
#define MCF_INTC0_ICR60 (*(vuint8 *)(&__IPSBAR[0x000C7C]))
753
#define MCF_INTC0_ICR61 (*(vuint8 *)(&__IPSBAR[0x000C7D]))
754
#define MCF_INTC0_ICR62 (*(vuint8 *)(&__IPSBAR[0x000C7E]))
755
#define MCF_INTC0_ICR63 (*(vuint8 *)(&__IPSBAR[0x000C7F]))
756
#define MCF_INTC0_ICR(x) (*(vuint8 *)(&__IPSBAR[0x000C41+((x-1)*0x001)]))
757
#define MCF_INTC0_SWIACK (*(vuint8 *)(&__IPSBAR[0x000CE0]))
758
#define MCF_INTC0_L1IACK (*(vuint8 *)(&__IPSBAR[0x000CE4]))
759
#define MCF_INTC0_L2IACK (*(vuint8 *)(&__IPSBAR[0x000CE8]))
760
#define MCF_INTC0_L3IACK (*(vuint8 *)(&__IPSBAR[0x000CEC]))
761
#define MCF_INTC0_L4IACK (*(vuint8 *)(&__IPSBAR[0x000CF0]))
762
#define MCF_INTC0_L5IACK (*(vuint8 *)(&__IPSBAR[0x000CF4]))
763
#define MCF_INTC0_L6IACK (*(vuint8 *)(&__IPSBAR[0x000CF8]))
764
#define MCF_INTC0_L7IACK (*(vuint8 *)(&__IPSBAR[0x000CFC]))
765
#define MCF_INTC0_LIACK(x) (*(vuint8 *)(&__IPSBAR[0x000CE4+((x-1)*0x004)]))
766
#define MCF_INTC1_IPRH (*(vuint32*)(&__IPSBAR[0x000D00]))
767
#define MCF_INTC1_IPRL (*(vuint32*)(&__IPSBAR[0x000D04]))
768
#define MCF_INTC1_IMRH (*(vuint32*)(&__IPSBAR[0x000D08]))
769
#define MCF_INTC1_IMRL (*(vuint32*)(&__IPSBAR[0x000D0C]))
770
#define MCF_INTC1_INTFRCH (*(vuint32*)(&__IPSBAR[0x000D10]))
771
#define MCF_INTC1_INTFRCL (*(vuint32*)(&__IPSBAR[0x000D14]))
772
#define MCF_INTC1_IRLR (*(vuint8 *)(&__IPSBAR[0x000D18]))
773
#define MCF_INTC1_IACKLPR (*(vuint8 *)(&__IPSBAR[0x000D19]))
774
#define MCF_INTC1_ICR1 (*(vuint8 *)(&__IPSBAR[0x000D41]))
775
#define MCF_INTC1_ICR2 (*(vuint8 *)(&__IPSBAR[0x000D42]))
776
#define MCF_INTC1_ICR3 (*(vuint8 *)(&__IPSBAR[0x000D43]))
777
#define MCF_INTC1_ICR4 (*(vuint8 *)(&__IPSBAR[0x000D44]))
778
#define MCF_INTC1_ICR5 (*(vuint8 *)(&__IPSBAR[0x000D45]))
779
#define MCF_INTC1_ICR6 (*(vuint8 *)(&__IPSBAR[0x000D46]))
780
#define MCF_INTC1_ICR7 (*(vuint8 *)(&__IPSBAR[0x000D47]))
781
#define MCF_INTC1_ICR8 (*(vuint8 *)(&__IPSBAR[0x000D48]))
782
#define MCF_INTC1_ICR9 (*(vuint8 *)(&__IPSBAR[0x000D49]))
783
#define MCF_INTC1_ICR10 (*(vuint8 *)(&__IPSBAR[0x000D4A]))
784
#define MCF_INTC1_ICR11 (*(vuint8 *)(&__IPSBAR[0x000D4B]))
785
#define MCF_INTC1_ICR12 (*(vuint8 *)(&__IPSBAR[0x000D4C]))
786
#define MCF_INTC1_ICR13 (*(vuint8 *)(&__IPSBAR[0x000D4D]))
787
#define MCF_INTC1_ICR14 (*(vuint8 *)(&__IPSBAR[0x000D4E]))
788
#define MCF_INTC1_ICR15 (*(vuint8 *)(&__IPSBAR[0x000D4F]))
789
#define MCF_INTC1_ICR16 (*(vuint8 *)(&__IPSBAR[0x000D50]))
790
#define MCF_INTC1_ICR17 (*(vuint8 *)(&__IPSBAR[0x000D51]))
791
#define MCF_INTC1_ICR18 (*(vuint8 *)(&__IPSBAR[0x000D52]))
792
#define MCF_INTC1_ICR19 (*(vuint8 *)(&__IPSBAR[0x000D53]))
793
#define MCF_INTC1_ICR20 (*(vuint8 *)(&__IPSBAR[0x000D54]))
794
#define MCF_INTC1_ICR21 (*(vuint8 *)(&__IPSBAR[0x000D55]))
795
#define MCF_INTC1_ICR22 (*(vuint8 *)(&__IPSBAR[0x000D56]))
796
#define MCF_INTC1_ICR23 (*(vuint8 *)(&__IPSBAR[0x000D57]))
797
#define MCF_INTC1_ICR24 (*(vuint8 *)(&__IPSBAR[0x000D58]))
798
#define MCF_INTC1_ICR25 (*(vuint8 *)(&__IPSBAR[0x000D59]))
799
#define MCF_INTC1_ICR26 (*(vuint8 *)(&__IPSBAR[0x000D5A]))
800
#define MCF_INTC1_ICR27 (*(vuint8 *)(&__IPSBAR[0x000D5B]))
801
#define MCF_INTC1_ICR28 (*(vuint8 *)(&__IPSBAR[0x000D5C]))
802
#define MCF_INTC1_ICR29 (*(vuint8 *)(&__IPSBAR[0x000D5D]))
803
#define MCF_INTC1_ICR30 (*(vuint8 *)(&__IPSBAR[0x000D5E]))
804
#define MCF_INTC1_ICR31 (*(vuint8 *)(&__IPSBAR[0x000D5F]))
805
#define MCF_INTC1_ICR32 (*(vuint8 *)(&__IPSBAR[0x000D60]))
806
#define MCF_INTC1_ICR33 (*(vuint8 *)(&__IPSBAR[0x000D61]))
807
#define MCF_INTC1_ICR34 (*(vuint8 *)(&__IPSBAR[0x000D62]))
808
#define MCF_INTC1_ICR35 (*(vuint8 *)(&__IPSBAR[0x000D63]))
809
#define MCF_INTC1_ICR36 (*(vuint8 *)(&__IPSBAR[0x000D64]))
810
#define MCF_INTC1_ICR37 (*(vuint8 *)(&__IPSBAR[0x000D65]))
811
#define MCF_INTC1_ICR38 (*(vuint8 *)(&__IPSBAR[0x000D66]))
812
#define MCF_INTC1_ICR39 (*(vuint8 *)(&__IPSBAR[0x000D67]))
813
#define MCF_INTC1_ICR40 (*(vuint8 *)(&__IPSBAR[0x000D68]))
814
#define MCF_INTC1_ICR41 (*(vuint8 *)(&__IPSBAR[0x000D69]))
815
#define MCF_INTC1_ICR42 (*(vuint8 *)(&__IPSBAR[0x000D6A]))
816
#define MCF_INTC1_ICR43 (*(vuint8 *)(&__IPSBAR[0x000D6B]))
817
#define MCF_INTC1_ICR44 (*(vuint8 *)(&__IPSBAR[0x000D6C]))
818
#define MCF_INTC1_ICR45 (*(vuint8 *)(&__IPSBAR[0x000D6D]))
819
#define MCF_INTC1_ICR46 (*(vuint8 *)(&__IPSBAR[0x000D6E]))
820
#define MCF_INTC1_ICR47 (*(vuint8 *)(&__IPSBAR[0x000D6F]))
821
#define MCF_INTC1_ICR48 (*(vuint8 *)(&__IPSBAR[0x000D70]))
822
#define MCF_INTC1_ICR49 (*(vuint8 *)(&__IPSBAR[0x000D71]))
823
#define MCF_INTC1_ICR50 (*(vuint8 *)(&__IPSBAR[0x000D72]))
824
#define MCF_INTC1_ICR51 (*(vuint8 *)(&__IPSBAR[0x000D73]))
825
#define MCF_INTC1_ICR52 (*(vuint8 *)(&__IPSBAR[0x000D74]))
826
#define MCF_INTC1_ICR53 (*(vuint8 *)(&__IPSBAR[0x000D75]))
827
#define MCF_INTC1_ICR54 (*(vuint8 *)(&__IPSBAR[0x000D76]))
828
#define MCF_INTC1_ICR55 (*(vuint8 *)(&__IPSBAR[0x000D77]))
829
#define MCF_INTC1_ICR56 (*(vuint8 *)(&__IPSBAR[0x000D78]))
830
#define MCF_INTC1_ICR57 (*(vuint8 *)(&__IPSBAR[0x000D79]))
831
#define MCF_INTC1_ICR58 (*(vuint8 *)(&__IPSBAR[0x000D7A]))
832
#define MCF_INTC1_ICR59 (*(vuint8 *)(&__IPSBAR[0x000D7B]))
833
#define MCF_INTC1_ICR60 (*(vuint8 *)(&__IPSBAR[0x000D7C]))
834
#define MCF_INTC1_ICR61 (*(vuint8 *)(&__IPSBAR[0x000D7D]))
835
#define MCF_INTC1_ICR62 (*(vuint8 *)(&__IPSBAR[0x000D7E]))
836
#define MCF_INTC1_ICR63 (*(vuint8 *)(&__IPSBAR[0x000D7F]))
837
#define MCF_INTC1_ICR(x) (*(vuint8 *)(&__IPSBAR[0x000D41+((x-1)*0x001)]))
838
#define MCF_INTC1_SWIACK (*(vuint8 *)(&__IPSBAR[0x000DE0]))
839
#define MCF_INTC1_L1IACK (*(vuint8 *)(&__IPSBAR[0x000DE4]))
840
#define MCF_INTC1_L2IACK (*(vuint8 *)(&__IPSBAR[0x000DE8]))
841
#define MCF_INTC1_L3IACK (*(vuint8 *)(&__IPSBAR[0x000DEC]))
842
#define MCF_INTC1_L4IACK (*(vuint8 *)(&__IPSBAR[0x000DF0]))
843
#define MCF_INTC1_L5IACK (*(vuint8 *)(&__IPSBAR[0x000DF4]))
844
#define MCF_INTC1_L6IACK (*(vuint8 *)(&__IPSBAR[0x000DF8]))
845
#define MCF_INTC1_L7IACK (*(vuint8 *)(&__IPSBAR[0x000DFC]))
846
#define MCF_INTC1_LIACK(x) (*(vuint8 *)(&__IPSBAR[0x000DE4+((x-1)*0x004)]))
847
#define MCF_INTC_IPRH(x) (*(vuint32*)(&__IPSBAR[0x000C00+((x)*0x100)]))
848
#define MCF_INTC_IPRL(x) (*(vuint32*)(&__IPSBAR[0x000C04+((x)*0x100)]))
849
#define MCF_INTC_IMRH(x) (*(vuint32*)(&__IPSBAR[0x000C08+((x)*0x100)]))
850
#define MCF_INTC_IMRL(x) (*(vuint32*)(&__IPSBAR[0x000C0C+((x)*0x100)]))
851
#define MCF_INTC_INTFRCH(x) (*(vuint32*)(&__IPSBAR[0x000C10+((x)*0x100)]))
852
#define MCF_INTC_INTFRCL(x) (*(vuint32*)(&__IPSBAR[0x000C14+((x)*0x100)]))
853
#define MCF_INTC_IRLR(x) (*(vuint8 *)(&__IPSBAR[0x000C18+((x)*0x100)]))
854
#define MCF_INTC_IACKLPR(x) (*(vuint8 *)(&__IPSBAR[0x000C19+((x)*0x100)]))
855
#define MCF_INTC_ICR1(x) (*(vuint8 *)(&__IPSBAR[0x000C41+((x)*0x100)]))
856
#define MCF_INTC_ICR2(x) (*(vuint8 *)(&__IPSBAR[0x000C42+((x)*0x100)]))
857
#define MCF_INTC_ICR3(x) (*(vuint8 *)(&__IPSBAR[0x000C43+((x)*0x100)]))
858
#define MCF_INTC_ICR4(x) (*(vuint8 *)(&__IPSBAR[0x000C44+((x)*0x100)]))
859
#define MCF_INTC_ICR5(x) (*(vuint8 *)(&__IPSBAR[0x000C45+((x)*0x100)]))
860
#define MCF_INTC_ICR6(x) (*(vuint8 *)(&__IPSBAR[0x000C46+((x)*0x100)]))
861
#define MCF_INTC_ICR7(x) (*(vuint8 *)(&__IPSBAR[0x000C47+((x)*0x100)]))
862
#define MCF_INTC_ICR8(x) (*(vuint8 *)(&__IPSBAR[0x000C48+((x)*0x100)]))
863
#define MCF_INTC_ICR9(x) (*(vuint8 *)(&__IPSBAR[0x000C49+((x)*0x100)]))
864
#define MCF_INTC_ICR10(x) (*(vuint8 *)(&__IPSBAR[0x000C4A+((x)*0x100)]))
865
#define MCF_INTC_ICR11(x) (*(vuint8 *)(&__IPSBAR[0x000C4B+((x)*0x100)]))
866
#define MCF_INTC_ICR12(x) (*(vuint8 *)(&__IPSBAR[0x000C4C+((x)*0x100)]))
867
#define MCF_INTC_ICR13(x) (*(vuint8 *)(&__IPSBAR[0x000C4D+((x)*0x100)]))
868
#define MCF_INTC_ICR14(x) (*(vuint8 *)(&__IPSBAR[0x000C4E+((x)*0x100)]))
869
#define MCF_INTC_ICR15(x) (*(vuint8 *)(&__IPSBAR[0x000C4F+((x)*0x100)]))
870
#define MCF_INTC_ICR16(x) (*(vuint8 *)(&__IPSBAR[0x000C50+((x)*0x100)]))
871
#define MCF_INTC_ICR17(x) (*(vuint8 *)(&__IPSBAR[0x000C51+((x)*0x100)]))
872
#define MCF_INTC_ICR18(x) (*(vuint8 *)(&__IPSBAR[0x000C52+((x)*0x100)]))
873
#define MCF_INTC_ICR19(x) (*(vuint8 *)(&__IPSBAR[0x000C53+((x)*0x100)]))
874
#define MCF_INTC_ICR20(x) (*(vuint8 *)(&__IPSBAR[0x000C54+((x)*0x100)]))
875
#define MCF_INTC_ICR21(x) (*(vuint8 *)(&__IPSBAR[0x000C55+((x)*0x100)]))
876
#define MCF_INTC_ICR22(x) (*(vuint8 *)(&__IPSBAR[0x000C56+((x)*0x100)]))
877
#define MCF_INTC_ICR23(x) (*(vuint8 *)(&__IPSBAR[0x000C57+((x)*0x100)]))
878
#define MCF_INTC_ICR24(x) (*(vuint8 *)(&__IPSBAR[0x000C58+((x)*0x100)]))
879
#define MCF_INTC_ICR25(x) (*(vuint8 *)(&__IPSBAR[0x000C59+((x)*0x100)]))
880
#define MCF_INTC_ICR26(x) (*(vuint8 *)(&__IPSBAR[0x000C5A+((x)*0x100)]))
881
#define MCF_INTC_ICR27(x) (*(vuint8 *)(&__IPSBAR[0x000C5B+((x)*0x100)]))
882
#define MCF_INTC_ICR28(x) (*(vuint8 *)(&__IPSBAR[0x000C5C+((x)*0x100)]))
883
#define MCF_INTC_ICR29(x) (*(vuint8 *)(&__IPSBAR[0x000C5D+((x)*0x100)]))
884
#define MCF_INTC_ICR30(x) (*(vuint8 *)(&__IPSBAR[0x000C5E+((x)*0x100)]))
885
#define MCF_INTC_ICR31(x) (*(vuint8 *)(&__IPSBAR[0x000C5F+((x)*0x100)]))
886
#define MCF_INTC_ICR32(x) (*(vuint8 *)(&__IPSBAR[0x000C60+((x)*0x100)]))
887
#define MCF_INTC_ICR33(x) (*(vuint8 *)(&__IPSBAR[0x000C61+((x)*0x100)]))
888
#define MCF_INTC_ICR34(x) (*(vuint8 *)(&__IPSBAR[0x000C62+((x)*0x100)]))
889
#define MCF_INTC_ICR35(x) (*(vuint8 *)(&__IPSBAR[0x000C63+((x)*0x100)]))
890
#define MCF_INTC_ICR36(x) (*(vuint8 *)(&__IPSBAR[0x000C64+((x)*0x100)]))
891
#define MCF_INTC_ICR37(x) (*(vuint8 *)(&__IPSBAR[0x000C65+((x)*0x100)]))
892
#define MCF_INTC_ICR38(x) (*(vuint8 *)(&__IPSBAR[0x000C66+((x)*0x100)]))
893
#define MCF_INTC_ICR39(x) (*(vuint8 *)(&__IPSBAR[0x000C67+((x)*0x100)]))
894
#define MCF_INTC_ICR40(x) (*(vuint8 *)(&__IPSBAR[0x000C68+((x)*0x100)]))
895
#define MCF_INTC_ICR41(x) (*(vuint8 *)(&__IPSBAR[0x000C69+((x)*0x100)]))
896
#define MCF_INTC_ICR42(x) (*(vuint8 *)(&__IPSBAR[0x000C6A+((x)*0x100)]))
897
#define MCF_INTC_ICR43(x) (*(vuint8 *)(&__IPSBAR[0x000C6B+((x)*0x100)]))
898
#define MCF_INTC_ICR44(x) (*(vuint8 *)(&__IPSBAR[0x000C6C+((x)*0x100)]))
899
#define MCF_INTC_ICR45(x) (*(vuint8 *)(&__IPSBAR[0x000C6D+((x)*0x100)]))
900
#define MCF_INTC_ICR46(x) (*(vuint8 *)(&__IPSBAR[0x000C6E+((x)*0x100)]))
901
#define MCF_INTC_ICR47(x) (*(vuint8 *)(&__IPSBAR[0x000C6F+((x)*0x100)]))
902
#define MCF_INTC_ICR48(x) (*(vuint8 *)(&__IPSBAR[0x000C70+((x)*0x100)]))
903
#define MCF_INTC_ICR49(x) (*(vuint8 *)(&__IPSBAR[0x000C71+((x)*0x100)]))
904
#define MCF_INTC_ICR50(x) (*(vuint8 *)(&__IPSBAR[0x000C72+((x)*0x100)]))
905
#define MCF_INTC_ICR51(x) (*(vuint8 *)(&__IPSBAR[0x000C73+((x)*0x100)]))
906
#define MCF_INTC_ICR52(x) (*(vuint8 *)(&__IPSBAR[0x000C74+((x)*0x100)]))
907
#define MCF_INTC_ICR53(x) (*(vuint8 *)(&__IPSBAR[0x000C75+((x)*0x100)]))
908
#define MCF_INTC_ICR54(x) (*(vuint8 *)(&__IPSBAR[0x000C76+((x)*0x100)]))
909
#define MCF_INTC_ICR55(x) (*(vuint8 *)(&__IPSBAR[0x000C77+((x)*0x100)]))
910
#define MCF_INTC_ICR56(x) (*(vuint8 *)(&__IPSBAR[0x000C78+((x)*0x100)]))
911
#define MCF_INTC_ICR57(x) (*(vuint8 *)(&__IPSBAR[0x000C79+((x)*0x100)]))
912
#define MCF_INTC_ICR58(x) (*(vuint8 *)(&__IPSBAR[0x000C7A+((x)*0x100)]))
913
#define MCF_INTC_ICR59(x) (*(vuint8 *)(&__IPSBAR[0x000C7B+((x)*0x100)]))
914
#define MCF_INTC_ICR60(x) (*(vuint8 *)(&__IPSBAR[0x000C7C+((x)*0x100)]))
915
#define MCF_INTC_ICR61(x) (*(vuint8 *)(&__IPSBAR[0x000C7D+((x)*0x100)]))
916
#define MCF_INTC_ICR62(x) (*(vuint8 *)(&__IPSBAR[0x000C7E+((x)*0x100)]))
917
#define MCF_INTC_ICR63(x) (*(vuint8 *)(&__IPSBAR[0x000C7F+((x)*0x100)]))
918
#define MCF_INTC_SWIACK(x) (*(vuint8 *)(&__IPSBAR[0x000CE0+((x)*0x100)]))
919
#define MCF_INTC_L1IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CE4+((x)*0x100)]))
920
#define MCF_INTC_L2IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CE8+((x)*0x100)]))
921
#define MCF_INTC_L3IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CEC+((x)*0x100)]))
922
#define MCF_INTC_L4IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CF0+((x)*0x100)]))
923
#define MCF_INTC_L5IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CF4+((x)*0x100)]))
924
#define MCF_INTC_L6IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CF8+((x)*0x100)]))
925
#define MCF_INTC_L7IACK(x) (*(vuint8 *)(&__IPSBAR[0x000CFC+((x)*0x100)]))
926
927
/* Bit definitions and macros for MCF_INTC_IPRH */
928
#define MCF_INTC_IPRH_INT32 (0x00000001)
929
#define MCF_INTC_IPRH_INT33 (0x00000002)
930
#define MCF_INTC_IPRH_INT34 (0x00000004)
931
#define MCF_INTC_IPRH_INT35 (0x00000008)
932
#define MCF_INTC_IPRH_INT36 (0x00000010)
933
#define MCF_INTC_IPRH_INT37 (0x00000020)
934
#define MCF_INTC_IPRH_INT38 (0x00000040)
935
#define MCF_INTC_IPRH_INT39 (0x00000080)
936
#define MCF_INTC_IPRH_INT40 (0x00000100)
937
#define MCF_INTC_IPRH_INT41 (0x00000200)
938
#define MCF_INTC_IPRH_INT42 (0x00000400)
939
#define MCF_INTC_IPRH_INT43 (0x00000800)
940
#define MCF_INTC_IPRH_INT44 (0x00001000)
941
#define MCF_INTC_IPRH_INT45 (0x00002000)
942
#define MCF_INTC_IPRH_INT46 (0x00004000)
943
#define MCF_INTC_IPRH_INT47 (0x00008000)
944
#define MCF_INTC_IPRH_INT48 (0x00010000)
945
#define MCF_INTC_IPRH_INT49 (0x00020000)
946
#define MCF_INTC_IPRH_INT50 (0x00040000)
947
#define MCF_INTC_IPRH_INT51 (0x00080000)
948
#define MCF_INTC_IPRH_INT52 (0x00100000)
949
#define MCF_INTC_IPRH_INT53 (0x00200000)
950
#define MCF_INTC_IPRH_INT54 (0x00400000)
951
#define MCF_INTC_IPRH_INT55 (0x00800000)
952
#define MCF_INTC_IPRH_INT56 (0x01000000)
953
#define MCF_INTC_IPRH_INT57 (0x02000000)
954
#define MCF_INTC_IPRH_INT58 (0x04000000)
955
#define MCF_INTC_IPRH_INT59 (0x08000000)
956
#define MCF_INTC_IPRH_INT60 (0x10000000)
957
#define MCF_INTC_IPRH_INT61 (0x20000000)
958
#define MCF_INTC_IPRH_INT62 (0x40000000)
959
#define MCF_INTC_IPRH_INT63 (0x80000000)
960
961
/* Bit definitions and macros for MCF_INTC_IPRL */
962
#define MCF_INTC_IPRL_INT1 (0x00000002)
963
#define MCF_INTC_IPRL_INT2 (0x00000004)
964
#define MCF_INTC_IPRL_INT3 (0x00000008)
965
#define MCF_INTC_IPRL_INT4 (0x00000010)
966
#define MCF_INTC_IPRL_INT5 (0x00000020)
967
#define MCF_INTC_IPRL_INT6 (0x00000040)
968
#define MCF_INTC_IPRL_INT7 (0x00000080)
969
#define MCF_INTC_IPRL_INT8 (0x00000100)
970
#define MCF_INTC_IPRL_INT9 (0x00000200)
971
#define MCF_INTC_IPRL_INT10 (0x00000400)
972
#define MCF_INTC_IPRL_INT11 (0x00000800)
973
#define MCF_INTC_IPRL_INT12 (0x00001000)
974
#define MCF_INTC_IPRL_INT13 (0x00002000)
975
#define MCF_INTC_IPRL_INT14 (0x00004000)
976
#define MCF_INTC_IPRL_INT15 (0x00008000)
977
#define MCF_INTC_IPRL_INT16 (0x00010000)
978
#define MCF_INTC_IPRL_INT17 (0x00020000)
979
#define MCF_INTC_IPRL_INT18 (0x00040000)
980
#define MCF_INTC_IPRL_INT19 (0x00080000)
981
#define MCF_INTC_IPRL_INT20 (0x00100000)
982
#define MCF_INTC_IPRL_INT21 (0x00200000)
983
#define MCF_INTC_IPRL_INT22 (0x00400000)
984
#define MCF_INTC_IPRL_INT23 (0x00800000)
985
#define MCF_INTC_IPRL_INT24 (0x01000000)
986
#define MCF_INTC_IPRL_INT25 (0x02000000)
987
#define MCF_INTC_IPRL_INT26 (0x04000000)
988
#define MCF_INTC_IPRL_INT27 (0x08000000)
989
#define MCF_INTC_IPRL_INT28 (0x10000000)
990
#define MCF_INTC_IPRL_INT29 (0x20000000)
991
#define MCF_INTC_IPRL_INT30 (0x40000000)
992
#define MCF_INTC_IPRL_INT31 (0x80000000)
993
994
/* Bit definitions and macros for MCF_INTC_IMRH */
995
#define MCF_INTC_IMRH_MASK32 (0x00000001)
996
#define MCF_INTC_IMRH_MASK33 (0x00000002)
997
#define MCF_INTC_IMRH_MASK34 (0x00000004)
998
#define MCF_INTC_IMRH_MASK35 (0x00000008)
999
#define MCF_INTC_IMRH_MASK36 (0x00000010)
1000
#define MCF_INTC_IMRH_MASK37 (0x00000020)
1001
#define MCF_INTC_IMRH_MASK38 (0x00000040)
1002
#define MCF_INTC_IMRH_MASK39 (0x00000080)
1003
#define MCF_INTC_IMRH_MASK40 (0x00000100)
1004
#define MCF_INTC_IMRH_MASK41 (0x00000200)
1005
#define MCF_INTC_IMRH_MASK42 (0x00000400)
1006
#define MCF_INTC_IMRH_MASK43 (0x00000800)
1007
#define MCF_INTC_IMRH_MASK44 (0x00001000)
1008
#define MCF_INTC_IMRH_MASK45 (0x00002000)
1009
#define MCF_INTC_IMRH_MASK46 (0x00004000)
1010
#define MCF_INTC_IMRH_MASK47 (0x00008000)
1011
#define MCF_INTC_IMRH_MASK48 (0x00010000)
1012
#define MCF_INTC_IMRH_MASK49 (0x00020000)
1013
#define MCF_INTC_IMRH_MASK50 (0x00040000)
1014
#define MCF_INTC_IMRH_MASK51 (0x00080000)
1015
#define MCF_INTC_IMRH_MASK52 (0x00100000)
1016
#define MCF_INTC_IMRH_MASK53 (0x00200000)
1017
#define MCF_INTC_IMRH_MASK54 (0x00400000)
1018
#define MCF_INTC_IMRH_MASK55 (0x00800000)
1019
#define MCF_INTC_IMRH_MASK56 (0x01000000)
1020
#define MCF_INTC_IMRH_MASK57 (0x02000000)
1021
#define MCF_INTC_IMRH_MASK58 (0x04000000)
1022
#define MCF_INTC_IMRH_MASK59 (0x08000000)
1023
#define MCF_INTC_IMRH_MASK60 (0x10000000)
1024
#define MCF_INTC_IMRH_MASK61 (0x20000000)
1025
#define MCF_INTC_IMRH_MASK62 (0x40000000)
1026
#define MCF_INTC_IMRH_MASK63 (0x80000000)
1027
1028
/* Bit definitions and macros for MCF_INTC_IMRL */
1029
#define MCF_INTC_IMRL_MASKALL (0x00000001)
1030
#define MCF_INTC_IMRL_MASK1 (0x00000002)
1031
#define MCF_INTC_IMRL_MASK2 (0x00000004)
1032
#define MCF_INTC_IMRL_MASK3 (0x00000008)
1033
#define MCF_INTC_IMRL_MASK4 (0x00000010)
1034
#define MCF_INTC_IMRL_MASK5 (0x00000020)
1035
#define MCF_INTC_IMRL_MASK6 (0x00000040)
1036
#define MCF_INTC_IMRL_MASK7 (0x00000080)
1037
#define MCF_INTC_IMRL_MASK8 (0x00000100)
1038
#define MCF_INTC_IMRL_MASK9 (0x00000200)
1039
#define MCF_INTC_IMRL_MASK10 (0x00000400)
1040
#define MCF_INTC_IMRL_MASK11 (0x00000800)
1041
#define MCF_INTC_IMRL_MASK12 (0x00001000)
1042
#define MCF_INTC_IMRL_MASK13 (0x00002000)
1043
#define MCF_INTC_IMRL_MASK14 (0x00004000)
1044
#define MCF_INTC_IMRL_MASK15 (0x00008000)
1045
#define MCF_INTC_IMRL_MASK16 (0x00010000)
1046
#define MCF_INTC_IMRL_MASK17 (0x00020000)
1047
#define MCF_INTC_IMRL_MASK18 (0x00040000)
1048
#define MCF_INTC_IMRL_MASK19 (0x00080000)
1049
#define MCF_INTC_IMRL_MASK20 (0x00100000)
1050
#define MCF_INTC_IMRL_MASK21 (0x00200000)
1051
#define MCF_INTC_IMRL_MASK22 (0x00400000)
1052
#define MCF_INTC_IMRL_MASK23 (0x00800000)
1053
#define MCF_INTC_IMRL_MASK24 (0x01000000)
1054
#define MCF_INTC_IMRL_MASK25 (0x02000000)
1055
#define MCF_INTC_IMRL_MASK26 (0x04000000)
1056
#define MCF_INTC_IMRL_MASK27 (0x08000000)
1057
#define MCF_INTC_IMRL_MASK28 (0x10000000)
1058
#define MCF_INTC_IMRL_MASK29 (0x20000000)
1059
#define MCF_INTC_IMRL_MASK30 (0x40000000)
1060
#define MCF_INTC_IMRL_MASK31 (0x80000000)
1061
1062
/* Bit definitions and macros for MCF_INTC_INTFRCH */
1063
#define MCF_INTC_INTFRCH_INTFRC32 (0x00000001)
1064
#define MCF_INTC_INTFRCH_INTFRC33 (0x00000002)
1065
#define MCF_INTC_INTFRCH_INTFRC34 (0x00000004)
1066
#define MCF_INTC_INTFRCH_INTFRC35 (0x00000008)
1067
#define MCF_INTC_INTFRCH_INTFRC36 (0x00000010)
1068
#define MCF_INTC_INTFRCH_INTFRC37 (0x00000020)
1069
#define MCF_INTC_INTFRCH_INTFRC38 (0x00000040)
1070
#define MCF_INTC_INTFRCH_INTFRC39 (0x00000080)
1071
#define MCF_INTC_INTFRCH_INTFRC40 (0x00000100)
1072
#define MCF_INTC_INTFRCH_INTFRC41 (0x00000200)
1073
#define MCF_INTC_INTFRCH_INTFRC42 (0x00000400)
1074
#define MCF_INTC_INTFRCH_INTFRC43 (0x00000800)
1075
#define MCF_INTC_INTFRCH_INTFRC44 (0x00001000)
1076
#define MCF_INTC_INTFRCH_INTFRC45 (0x00002000)
1077
#define MCF_INTC_INTFRCH_INTFRC46 (0x00004000)
1078
#define MCF_INTC_INTFRCH_INTFRC47 (0x00008000)
1079
#define MCF_INTC_INTFRCH_INTFRC48 (0x00010000)
1080
#define MCF_INTC_INTFRCH_INTFRC49 (0x00020000)
1081
#define MCF_INTC_INTFRCH_INTFRC50 (0x00040000)
1082
#define MCF_INTC_INTFRCH_INTFRC51 (0x00080000)
1083
#define MCF_INTC_INTFRCH_INTFRC52 (0x00100000)
1084
#define MCF_INTC_INTFRCH_INTFRC53 (0x00200000)
1085
#define MCF_INTC_INTFRCH_INTFRC54 (0x00400000)
1086
#define MCF_INTC_INTFRCH_INTFRC55 (0x00800000)
1087
#define MCF_INTC_INTFRCH_INTFRC56 (0x01000000)
1088
#define MCF_INTC_INTFRCH_INTFRC57 (0x02000000)
1089
#define MCF_INTC_INTFRCH_INTFRC58 (0x04000000)
1090
#define MCF_INTC_INTFRCH_INTFRC59 (0x08000000)
1091
#define MCF_INTC_INTFRCH_INTFRC60 (0x10000000)
1092
#define MCF_INTC_INTFRCH_INTFRC61 (0x20000000)
1093
#define MCF_INTC_INTFRCH_INTFRC62 (0x40000000)
1094
#define MCF_INTC_INTFRCH_INTFRC63 (0x80000000)
1095
1096
/* Bit definitions and macros for MCF_INTC_INTFRCL */
1097
#define MCF_INTC_INTFRCL_INTFRC1 (0x00000002)
1098
#define MCF_INTC_INTFRCL_INTFRC2 (0x00000004)
1099
#define MCF_INTC_INTFRCL_INTFRC3 (0x00000008)
1100
#define MCF_INTC_INTFRCL_INTFRC4 (0x00000010)
1101
#define MCF_INTC_INTFRCL_INTFRC5 (0x00000020)
1102
#define MCF_INTC_INTFRCL_INTFRC6 (0x00000040)
1103
#define MCF_INTC_INTFRCL_INTFRC7 (0x00000080)
1104
#define MCF_INTC_INTFRCL_INTFRC8 (0x00000100)
1105
#define MCF_INTC_INTFRCL_INTFRC9 (0x00000200)
1106
#define MCF_INTC_INTFRCL_INTFRC10 (0x00000400)
1107
#define MCF_INTC_INTFRCL_INTFRC11 (0x00000800)
1108
#define MCF_INTC_INTFRCL_INTFRC12 (0x00001000)
1109
#define MCF_INTC_INTFRCL_INTFRC13 (0x00002000)
1110
#define MCF_INTC_INTFRCL_INTFRC14 (0x00004000)
1111
#define MCF_INTC_INTFRCL_INTFRC15 (0x00008000)
1112
#define MCF_INTC_INTFRCL_INTFRC16 (0x00010000)
1113
#define MCF_INTC_INTFRCL_INTFRC17 (0x00020000)
1114
#define MCF_INTC_INTFRCL_INTFRC18 (0x00040000)
1115
#define MCF_INTC_INTFRCL_INTFRC19 (0x00080000)
1116
#define MCF_INTC_INTFRCL_INTFRC20 (0x00100000)
1117
#define MCF_INTC_INTFRCL_INTFRC21 (0x00200000)
1118
#define MCF_INTC_INTFRCL_INTFRC22 (0x00400000)
1119
#define MCF_INTC_INTFRCL_INTFRC23 (0x00800000)
1120
#define MCF_INTC_INTFRCL_INTFRC24 (0x01000000)
1121
#define MCF_INTC_INTFRCL_INTFRC25 (0x02000000)
1122
#define MCF_INTC_INTFRCL_INTFRC26 (0x04000000)
1123
#define MCF_INTC_INTFRCL_INTFRC27 (0x08000000)
1124
#define MCF_INTC_INTFRCL_INTFRC28 (0x10000000)
1125
#define MCF_INTC_INTFRCL_INTFRC29 (0x20000000)
1126
#define MCF_INTC_INTFRCL_INTFRC30 (0x40000000)
1127
#define MCF_INTC_INTFRCL_INTFRC31 (0x80000000)
1128
1129
/* Bit definitions and macros for MCF_INTC_IRLR */
1130
#define MCF_INTC_IRLR_IRQ(x) (((x)&0x7F)<<1)
1131
1132
/* Bit definitions and macros for MCF_INTC_IACKLPR */
1133
#define MCF_INTC_IACKLPR_PRI(x) (((x)&0x0F)<<0)
1134
#define MCF_INTC_IACKLPR_LEVEL(x) (((x)&0x07)<<4)
1135
1136
/* Bit definitions and macros for MCF_INTC_ICR */
1137
#define MCF_INTC_ICR_IP(x) (((x)&0x07)<<0)
1138
#define MCF_INTC_ICR_IL(x) (((x)&0x07)<<3)
1139
1140
/* Bit definitions and macros for MCF_INTC_SWIACK */
1141
#define MCF_INTC_SWIACK_VECTOR(x) (((x)&0xFF)<<0)
1142
1143
/* Bit definitions and macros for MCF_INTC_LIACK */
1144
#define MCF_INTC_LIACK_VECTOR(x) (((x)&0xFF)<<0)
1145
1146
1147
1148
* General Purpose I/O (GPIO)
1149
1150
1151
1152
1153
#define MCF_GPIO_PORTNQ (*(vuint8 *)(&__IPSBAR[0x100008]))
1154
#define MCF_GPIO_PORTAN (*(vuint8 *)(&__IPSBAR[0x10000A]))
1155
#define MCF_GPIO_PORTAS (*(vuint8 *)(&__IPSBAR[0x10000B]))
1156
#define MCF_GPIO_PORTQS (*(vuint8 *)(&__IPSBAR[0x10000C]))
1157
#define MCF_GPIO_PORTTA (*(vuint8 *)(&__IPSBAR[0x10000E]))
1158
#define MCF_GPIO_PORTTC (*(vuint8 *)(&__IPSBAR[0x10000F]))
1159
#define MCF_GPIO_PORTTD (*(vuint8 *)(&__IPSBAR[0x100010]))
1160
#define MCF_GPIO_PORTUA (*(vuint8 *)(&__IPSBAR[0x100011]))
1161
#define MCF_GPIO_PORTUB (*(vuint8 *)(&__IPSBAR[0x100012]))
1162
#define MCF_GPIO_PORTUC (*(vuint8 *)(&__IPSBAR[0x100013]))
1163
#define MCF_GPIO_PORTDD (*(vuint8 *)(&__IPSBAR[0x100014]))
1164
#define MCF_GPIO_PORTLD (*(vuint8 *)(&__IPSBAR[0x100015]))
1165
#define MCF_GPIO_PORTGP (*(vuint8 *)(&__IPSBAR[0x100016]))
1166
#define MCF_GPIO_DDRNQ (*(vuint8 *)(&__IPSBAR[0x100020]))
1167
#define MCF_GPIO_DDRAN (*(vuint8 *)(&__IPSBAR[0x100022]))
1168
#define MCF_GPIO_DDRAS (*(vuint8 *)(&__IPSBAR[0x100023]))
1169
#define MCF_GPIO_DDRQS (*(vuint8 *)(&__IPSBAR[0x100024]))
1170
#define MCF_GPIO_DDRTA (*(vuint8 *)(&__IPSBAR[0x100026]))
1171
#define MCF_GPIO_DDRTC (*(vuint8 *)(&__IPSBAR[0x100027]))
1172
#define MCF_GPIO_DDRTD (*(vuint8 *)(&__IPSBAR[0x100028]))
1173
#define MCF_GPIO_DDRUA (*(vuint8 *)(&__IPSBAR[0x100029]))
1174
#define MCF_GPIO_DDRUB (*(vuint8 *)(&__IPSBAR[0x10002A]))
1175
#define MCF_GPIO_DDRUC (*(vuint8 *)(&__IPSBAR[0x10002B]))
1176
#define MCF_GPIO_DDRDD (*(vuint8 *)(&__IPSBAR[0x10002C]))
1177
#define MCF_GPIO_DDRLD (*(vuint8 *)(&__IPSBAR[0x10002D]))
1178
#define MCF_GPIO_DDRGP (*(vuint8 *)(&__IPSBAR[0x10002E]))
1179
#define MCF_GPIO_SETNQ (*(vuint8 *)(&__IPSBAR[0x100038]))
1180
#define MCF_GPIO_SETAN (*(vuint8 *)(&__IPSBAR[0x10003A]))
1181
#define MCF_GPIO_SETAS (*(vuint8 *)(&__IPSBAR[0x10003B]))
1182
#define MCF_GPIO_SETQS (*(vuint8 *)(&__IPSBAR[0x10003C]))
1183
#define MCF_GPIO_SETTA (*(vuint8 *)(&__IPSBAR[0x10003E]))
1184
#define MCF_GPIO_SETTC (*(vuint8 *)(&__IPSBAR[0x10003F]))
1185
#define MCF_GPIO_SETTD (*(vuint8 *)(&__IPSBAR[0x100040]))
1186
#define MCF_GPIO_SETUA (*(vuint8 *)(&__IPSBAR[0x100041]))
1187
#define MCF_GPIO_SETUB (*(vuint8 *)(&__IPSBAR[0x100042]))
1188
#define MCF_GPIO_SETUC (*(vuint8 *)(&__IPSBAR[0x100043]))
1189
#define MCF_GPIO_SETDD (*(vuint8 *)(&__IPSBAR[0x100044]))
1190
#define MCF_GPIO_SETLD (*(vuint8 *)(&__IPSBAR[0x100045]))
1191
#define MCF_GPIO_SETGP (*(vuint8 *)(&__IPSBAR[0x100046]))
1192
#define MCF_GPIO_CLRNQ (*(vuint8 *)(&__IPSBAR[0x100050]))
1193
#define MCF_GPIO_CLRAN (*(vuint8 *)(&__IPSBAR[0x100052]))
1194
#define MCF_GPIO_CLRAS (*(vuint8 *)(&__IPSBAR[0x100053]))
1195
#define MCF_GPIO_CLRQS (*(vuint8 *)(&__IPSBAR[0x100054]))
1196
#define MCF_GPIO_CLRTA (*(vuint8 *)(&__IPSBAR[0x100056]))
1197
#define MCF_GPIO_CLRTC (*(vuint8 *)(&__IPSBAR[0x100057]))
1198
#define MCF_GPIO_CLRTD (*(vuint8 *)(&__IPSBAR[0x100058]))
1199
#define MCF_GPIO_CLRUA (*(vuint8 *)(&__IPSBAR[0x100059]))
1200
#define MCF_GPIO_CLRUB (*(vuint8 *)(&__IPSBAR[0x10005A]))
1201
#define MCF_GPIO_CLRUC (*(vuint8 *)(&__IPSBAR[0x10005B]))
1202
#define MCF_GPIO_CLRDD (*(vuint8 *)(&__IPSBAR[0x10005C]))
1203
#define MCF_GPIO_CLRLD (*(vuint8 *)(&__IPSBAR[0x10005D]))
1204
#define MCF_GPIO_CLRGP (*(vuint8 *)(&__IPSBAR[0x10005E]))
1205
#define MCF_GPIO_PNQPAR (*(vuint16*)(&__IPSBAR[0x100068]))
1206
#define MCF_GPIO_PANPAR (*(vuint8 *)(&__IPSBAR[0x10006A]))
1207
#define MCF_GPIO_PASPAR (*(vuint8 *)(&__IPSBAR[0x10006B]))
1208
#define MCF_GPIO_PQSPAR (*(vuint16*)(&__IPSBAR[0x10006C]))
1209
#define MCF_GPIO_PTAPAR (*(vuint8 *)(&__IPSBAR[0x10006E]))
1210
#define MCF_GPIO_PTCPAR (*(vuint8 *)(&__IPSBAR[0x10006F]))
1211
#define MCF_GPIO_PTDPAR (*(vuint8 *)(&__IPSBAR[0x100070]))
1212
#define MCF_GPIO_PUAPAR (*(vuint8 *)(&__IPSBAR[0x100071]))
1213
#define MCF_GPIO_PUBPAR (*(vuint8 *)(&__IPSBAR[0x100072]))
1214
#define MCF_GPIO_PUCPAR (*(vuint8 *)(&__IPSBAR[0x100073]))
1215
#define MCF_GPIO_PDDPAR (*(vuint8 *)(&__IPSBAR[0x100074]))
1216
#define MCF_GPIO_PLDPAR (*(vuint8 *)(&__IPSBAR[0x100075]))
1217
#define MCF_GPIO_PGPPAR (*(vuint8 *)(&__IPSBAR[0x100076]))
1218
#define MCF_GPIO_PWOR (*(vuint16*)(&__IPSBAR[0x100078]))
1219
#define MCF_GPIO_PDSRH (*(vuint16*)(&__IPSBAR[0x10007A]))
1220
#define MCF_GPIO_PDSRL (*(vuint32*)(&__IPSBAR[0x10007C]))
1221
1222
/* Bit definitions and macros for MCF_GPIO_PORTNQ */
1223
#define MCF_GPIO_PORTNQ_PORTNQ0 (0x01)
1224
#define MCF_GPIO_PORTNQ_PORTNQ1 (0x02)
1225
#define MCF_GPIO_PORTNQ_PORTNQ2 (0x04)
1226
#define MCF_GPIO_PORTNQ_PORTNQ3 (0x08)
1227
#define MCF_GPIO_PORTNQ_PORTNQ4 (0x10)
1228
#define MCF_GPIO_PORTNQ_PORTNQ5 (0x20)
1229
#define MCF_GPIO_PORTNQ_PORTNQ6 (0x40)
1230
#define MCF_GPIO_PORTNQ_PORTNQ7 (0x80)
1231
1232
/* Bit definitions and macros for MCF_GPIO_PORTAN */
1233
#define MCF_GPIO_PORTAN_PORTAN0 (0x01)
1234
#define MCF_GPIO_PORTAN_PORTAN1 (0x02)
1235
#define MCF_GPIO_PORTAN_PORTAN2 (0x04)
1236
#define MCF_GPIO_PORTAN_PORTAN3 (0x08)
1237
#define MCF_GPIO_PORTAN_PORTAN4 (0x10)
1238
#define MCF_GPIO_PORTAN_PORTAN5 (0x20)
1239
#define MCF_GPIO_PORTAN_PORTAN6 (0x40)
1240
#define MCF_GPIO_PORTAN_PORTAN7 (0x80)
1241
1242
/* Bit definitions and macros for MCF_GPIO_PORTAS */
1243
#define MCF_GPIO_PORTAS_PORTAS0 (0x01)
1244
#define MCF_GPIO_PORTAS_PORTAS1 (0x02)
1245
#define MCF_GPIO_PORTAS_PORTAS2 (0x04)
1246
#define MCF_GPIO_PORTAS_PORTAS3 (0x08)
1247
#define MCF_GPIO_PORTAS_PORTAS4 (0x10)
1248
#define MCF_GPIO_PORTAS_PORTAS5 (0x20)
1249
#define MCF_GPIO_PORTAS_PORTAS6 (0x40)
1250
#define MCF_GPIO_PORTAS_PORTAS7 (0x80)
1251
1252
/* Bit definitions and macros for MCF_GPIO_PORTQS */
1253
#define MCF_GPIO_PORTQS_PORTQS0 (0x01)
1254
#define MCF_GPIO_PORTQS_PORTQS1 (0x02)
1255
#define MCF_GPIO_PORTQS_PORTQS2 (0x04)
1256
#define MCF_GPIO_PORTQS_PORTQS3 (0x08)
1257
#define MCF_GPIO_PORTQS_PORTQS4 (0x10)
1258
#define MCF_GPIO_PORTQS_PORTQS5 (0x20)
1259
#define MCF_GPIO_PORTQS_PORTQS6 (0x40)
1260
#define MCF_GPIO_PORTQS_PORTQS7 (0x80)
1261
1262
/* Bit definitions and macros for MCF_GPIO_PORTTA */
1263
#define MCF_GPIO_PORTTA_PORTTA0 (0x01)
1264
#define MCF_GPIO_PORTTA_PORTTA1 (0x02)
1265
#define MCF_GPIO_PORTTA_PORTTA2 (0x04)
1266
#define MCF_GPIO_PORTTA_PORTTA3 (0x08)
1267
#define MCF_GPIO_PORTTA_PORTTA4 (0x10)
1268
#define MCF_GPIO_PORTTA_PORTTA5 (0x20)
1269
#define MCF_GPIO_PORTTA_PORTTA6 (0x40)
1270
#define MCF_GPIO_PORTTA_PORTTA7 (0x80)
1271
1272
/* Bit definitions and macros for MCF_GPIO_PORTTC */
1273
#define MCF_GPIO_PORTTC_PORTTC0 (0x01)
1274
#define MCF_GPIO_PORTTC_PORTTC1 (0x02)
1275
#define MCF_GPIO_PORTTC_PORTTC2 (0x04)
1276
#define MCF_GPIO_PORTTC_PORTTC3 (0x08)
1277
#define MCF_GPIO_PORTTC_PORTTC4 (0x10)
1278
#define MCF_GPIO_PORTTC_PORTTC5 (0x20)
1279
#define MCF_GPIO_PORTTC_PORTTC6 (0x40)
1280
#define MCF_GPIO_PORTTC_PORTTC7 (0x80)
1281
1282
/* Bit definitions and macros for MCF_GPIO_PORTTD */
1283
#define MCF_GPIO_PORTTD_PORTTD0 (0x01)
1284
#define MCF_GPIO_PORTTD_PORTTD1 (0x02)
1285
#define MCF_GPIO_PORTTD_PORTTD2 (0x04)
1286
#define MCF_GPIO_PORTTD_PORTTD3 (0x08)
1287
#define MCF_GPIO_PORTTD_PORTTD4 (0x10)
1288
#define MCF_GPIO_PORTTD_PORTTD5 (0x20)
1289
#define MCF_GPIO_PORTTD_PORTTD6 (0x40)
1290
#define MCF_GPIO_PORTTD_PORTTD7 (0x80)
1291
1292
/* Bit definitions and macros for MCF_GPIO_PORTUA */
1293
#define MCF_GPIO_PORTUA_PORTUA0 (0x01)
1294
#define MCF_GPIO_PORTUA_PORTUA1 (0x02)
1295
#define MCF_GPIO_PORTUA_PORTUA2 (0x04)
1296
#define MCF_GPIO_PORTUA_PORTUA3 (0x08)
1297
#define MCF_GPIO_PORTUA_PORTUA4 (0x10)
1298
#define MCF_GPIO_PORTUA_PORTUA5 (0x20)
1299
#define MCF_GPIO_PORTUA_PORTUA6 (0x40)
1300
#define MCF_GPIO_PORTUA_PORTUA7 (0x80)
1301
1302
/* Bit definitions and macros for MCF_GPIO_PORTUB */
1303
#define MCF_GPIO_PORTUB_PORTUB0 (0x01)
1304
#define MCF_GPIO_PORTUB_PORTUB1 (0x02)
1305
#define MCF_GPIO_PORTUB_PORTUB2 (0x04)
1306
#define MCF_GPIO_PORTUB_PORTUB3 (0x08)
1307
#define MCF_GPIO_PORTUB_PORTUB4 (0x10)
1308
#define MCF_GPIO_PORTUB_PORTUB5 (0x20)
1309
#define MCF_GPIO_PORTUB_PORTUB6 (0x40)
1310
#define MCF_GPIO_PORTUB_PORTUB7 (0x80)
1311
1312
/* Bit definitions and macros for MCF_GPIO_PORTUC */
1313
#define MCF_GPIO_PORTUC_PORTUC0 (0x01)
1314
#define MCF_GPIO_PORTUC_PORTUC1 (0x02)
1315
#define MCF_GPIO_PORTUC_PORTUC2 (0x04)
1316
#define MCF_GPIO_PORTUC_PORTUC3 (0x08)
1317
#define MCF_GPIO_PORTUC_PORTUC4 (0x10)
1318
#define MCF_GPIO_PORTUC_PORTUC5 (0x20)
1319
#define MCF_GPIO_PORTUC_PORTUC6 (0x40)
1320
#define MCF_GPIO_PORTUC_PORTUC7 (0x80)
1321
1322
/* Bit definitions and macros for MCF_GPIO_PORTDD */
1323
#define MCF_GPIO_PORTDD_PORTDD0 (0x01)
1324
#define MCF_GPIO_PORTDD_PORTDD1 (0x02)
1325
#define MCF_GPIO_PORTDD_PORTDD2 (0x04)
1326
#define MCF_GPIO_PORTDD_PORTDD3 (0x08)
1327
#define MCF_GPIO_PORTDD_PORTDD4 (0x10)
1328
#define MCF_GPIO_PORTDD_PORTDD5 (0x20)
1329
#define MCF_GPIO_PORTDD_PORTDD6 (0x40)
1330
#define MCF_GPIO_PORTDD_PORTDD7 (0x80)
1331
1332
/* Bit definitions and macros for MCF_GPIO_PORTLD */
1333
#define MCF_GPIO_PORTLD_PORTLD0 (0x01)
1334
#define MCF_GPIO_PORTLD_PORTLD1 (0x02)
1335
#define MCF_GPIO_PORTLD_PORTLD2 (0x04)
1336
#define MCF_GPIO_PORTLD_PORTLD3 (0x08)
1337
#define MCF_GPIO_PORTLD_PORTLD4 (0x10)
1338
#define MCF_GPIO_PORTLD_PORTLD5 (0x20)
1339
#define MCF_GPIO_PORTLD_PORTLD6 (0x40)
1340
#define MCF_GPIO_PORTLD_PORTLD7 (0x80)
1341
1342
/* Bit definitions and macros for MCF_GPIO_PORTGP */
1343
#define MCF_GPIO_PORTGP_PORTGP0 (0x01)
1344
#define MCF_GPIO_PORTGP_PORTGP1 (0x02)
1345
#define MCF_GPIO_PORTGP_PORTGP2 (0x04)
1346
#define MCF_GPIO_PORTGP_PORTGP3 (0x08)
1347
#define MCF_GPIO_PORTGP_PORTGP4 (0x10)
1348
#define MCF_GPIO_PORTGP_PORTGP5 (0x20)
1349
#define MCF_GPIO_PORTGP_PORTGP6 (0x40)
1350
#define MCF_GPIO_PORTGP_PORTGP7 (0x80)
1351
1352
/* Bit definitions and macros for MCF_GPIO_DDRNQ */
1353
#define MCF_GPIO_DDRNQ_DDRNQ0 (0x01)
1354
#define MCF_GPIO_DDRNQ_DDRNQ1 (0x02)
1355
#define MCF_GPIO_DDRNQ_DDRNQ2 (0x04)
1356
#define MCF_GPIO_DDRNQ_DDRNQ3 (0x08)
1357
#define MCF_GPIO_DDRNQ_DDRNQ4 (0x10)
1358
#define MCF_GPIO_DDRNQ_DDRNQ5 (0x20)
1359
#define MCF_GPIO_DDRNQ_DDRNQ6 (0x40)
1360
#define MCF_GPIO_DDRNQ_DDRNQ7 (0x80)
1361
1362
/* Bit definitions and macros for MCF_GPIO_DDRAN */
1363
#define MCF_GPIO_DDRAN_DDRAN0 (0x01)
1364
#define MCF_GPIO_DDRAN_DDRAN1 (0x02)
1365
#define MCF_GPIO_DDRAN_DDRAN2 (0x04)
1366
#define MCF_GPIO_DDRAN_DDRAN3 (0x08)
1367
#define MCF_GPIO_DDRAN_DDRAN4 (0x10)
1368
#define MCF_GPIO_DDRAN_DDRAN5 (0x20)
1369
#define MCF_GPIO_DDRAN_DDRAN6 (0x40)
1370
#define MCF_GPIO_DDRAN_DDRAN7 (0x80)
1371
1372
/* Bit definitions and macros for MCF_GPIO_DDRAS */
1373
#define MCF_GPIO_DDRAS_DDRAS0 (0x01)
1374
#define MCF_GPIO_DDRAS_DDRAS1 (0x02)
1375
#define MCF_GPIO_DDRAS_DDRAS2 (0x04)
1376
#define MCF_GPIO_DDRAS_DDRAS3 (0x08)
1377
#define MCF_GPIO_DDRAS_DDRAS4 (0x10)
1378
#define MCF_GPIO_DDRAS_DDRAS5 (0x20)
1379
#define MCF_GPIO_DDRAS_DDRAS6 (0x40)
1380
#define MCF_GPIO_DDRAS_DDRAS7 (0x80)
1381
1382
/* Bit definitions and macros for MCF_GPIO_DDRQS */
1383
#define MCF_GPIO_DDRQS_DDRQS0 (0x01)
1384
#define MCF_GPIO_DDRQS_DDRQS1 (0x02)
1385
#define MCF_GPIO_DDRQS_DDRQS2 (0x04)
1386
#define MCF_GPIO_DDRQS_DDRQS3 (0x08)
1387
#define MCF_GPIO_DDRQS_DDRQS4 (0x10)
1388
#define MCF_GPIO_DDRQS_DDRQS5 (0x20)
1389
#define MCF_GPIO_DDRQS_DDRQS6 (0x40)
1390
#define MCF_GPIO_DDRQS_DDRQS7 (0x80)
1391
1392
/* Bit definitions and macros for MCF_GPIO_DDRTA */
1393
#define MCF_GPIO_DDRTA_DDRTA0 (0x01)
1394
#define MCF_GPIO_DDRTA_DDRTA1 (0x02)
1395
#define MCF_GPIO_DDRTA_DDRTA2 (0x04)
1396
#define MCF_GPIO_DDRTA_DDRTA3 (0x08)
1397
#define MCF_GPIO_DDRTA_DDRTA4 (0x10)
1398
#define MCF_GPIO_DDRTA_DDRTA5 (0x20)
1399
#define MCF_GPIO_DDRTA_DDRTA6 (0x40)
1400
#define MCF_GPIO_DDRTA_DDRTA7 (0x80)
1401
1402
/* Bit definitions and macros for MCF_GPIO_DDRTC */
1403
#define MCF_GPIO_DDRTC_DDRTC0 (0x01)
1404
#define MCF_GPIO_DDRTC_DDRTC1 (0x02)
1405
#define MCF_GPIO_DDRTC_DDRTC2 (0x04)
1406
#define MCF_GPIO_DDRTC_DDRTC3 (0x08)
1407
#define MCF_GPIO_DDRTC_DDRTC4 (0x10)
1408
#define MCF_GPIO_DDRTC_DDRTC5 (0x20)
1409
#define MCF_GPIO_DDRTC_DDRTC6 (0x40)
1410
#define MCF_GPIO_DDRTC_DDRTC7 (0x80)
1411
1412
/* Bit definitions and macros for MCF_GPIO_DDRTD */
1413
#define MCF_GPIO_DDRTD_DDRTD0 (0x01)
1414
#define MCF_GPIO_DDRTD_DDRTD1 (0x02)
1415
#define MCF_GPIO_DDRTD_DDRTD2 (0x04)
1416
#define MCF_GPIO_DDRTD_DDRTD3 (0x08)
1417
#define MCF_GPIO_DDRTD_DDRTD4 (0x10)
1418
#define MCF_GPIO_DDRTD_DDRTD5 (0x20)
1419
#define MCF_GPIO_DDRTD_DDRTD6 (0x40)
1420
#define MCF_GPIO_DDRTD_DDRTD7 (0x80)
1421
1422
/* Bit definitions and macros for MCF_GPIO_DDRUA */
1423
#define MCF_GPIO_DDRUA_DDRUA0 (0x01)
1424
#define MCF_GPIO_DDRUA_DDRUA1 (0x02)
1425
#define MCF_GPIO_DDRUA_DDRUA2 (0x04)
1426
#define MCF_GPIO_DDRUA_DDRUA3 (0x08)
1427
#define MCF_GPIO_DDRUA_DDRUA4 (0x10)
1428
#define MCF_GPIO_DDRUA_DDRUA5 (0x20)
1429
#define MCF_GPIO_DDRUA_DDRUA6 (0x40)
1430
#define MCF_GPIO_DDRUA_DDRUA7 (0x80)
1431
1432
/* Bit definitions and macros for MCF_GPIO_DDRUB */
1433
#define MCF_GPIO_DDRUB_DDRUB0 (0x01)
1434
#define MCF_GPIO_DDRUB_DDRUB1 (0x02)
1435
#define MCF_GPIO_DDRUB_DDRUB2 (0x04)
1436
#define MCF_GPIO_DDRUB_DDRUB3 (0x08)
1437
#define MCF_GPIO_DDRUB_DDRUB4 (0x10)
1438
#define MCF_GPIO_DDRUB_DDRUB5 (0x20)
1439
#define MCF_GPIO_DDRUB_DDRUB6 (0x40)
1440
#define MCF_GPIO_DDRUB_DDRUB7 (0x80)
1441
1442
/* Bit definitions and macros for MCF_GPIO_DDRUC */
1443
#define MCF_GPIO_DDRUC_DDRUC0 (0x01)
1444
#define MCF_GPIO_DDRUC_DDRUC1 (0x02)
1445
#define MCF_GPIO_DDRUC_DDRUC2 (0x04)
1446
#define MCF_GPIO_DDRUC_DDRUC3 (0x08)
1447
#define MCF_GPIO_DDRUC_DDRUC4 (0x10)
1448
#define MCF_GPIO_DDRUC_DDRUC5 (0x20)
1449
#define MCF_GPIO_DDRUC_DDRUC6 (0x40)
1450
#define MCF_GPIO_DDRUC_DDRUC7 (0x80)
1451
1452
/* Bit definitions and macros for MCF_GPIO_DDRDD */
1453
#define MCF_GPIO_DDRDD_DDRDD0 (0x01)
1454
#define MCF_GPIO_DDRDD_DDRDD1 (0x02)
1455
#define MCF_GPIO_DDRDD_DDRDD2 (0x04)
1456
#define MCF_GPIO_DDRDD_DDRDD3 (0x08)
1457
#define MCF_GPIO_DDRDD_DDRDD4 (0x10)
1458
#define MCF_GPIO_DDRDD_DDRDD5 (0x20)
1459
#define MCF_GPIO_DDRDD_DDRDD6 (0x40)
1460
#define MCF_GPIO_DDRDD_DDRDD7 (0x80)
1461
1462
/* Bit definitions and macros for MCF_GPIO_DDRLD */
1463
#define MCF_GPIO_DDRLD_DDRLD0 (0x01)
1464
#define MCF_GPIO_DDRLD_DDRLD1 (0x02)
1465
#define MCF_GPIO_DDRLD_DDRLD2 (0x04)
1466
#define MCF_GPIO_DDRLD_DDRLD3 (0x08)
1467
#define MCF_GPIO_DDRLD_DDRLD4 (0x10)
1468
#define MCF_GPIO_DDRLD_DDRLD5 (0x20)
1469
#define MCF_GPIO_DDRLD_DDRLD6 (0x40)
1470
#define MCF_GPIO_DDRLD_DDRLD7 (0x80)
1471
1472
/* Bit definitions and macros for MCF_GPIO_DDRGP */
1473
#define MCF_GPIO_DDRGP_DDRGP0 (0x01)
1474
#define MCF_GPIO_DDRGP_DDRGP1 (0x02)
1475
#define MCF_GPIO_DDRGP_DDRGP2 (0x04)
1476
#define MCF_GPIO_DDRGP_DDRGP3 (0x08)
1477
#define MCF_GPIO_DDRGP_DDRGP4 (0x10)
1478
#define MCF_GPIO_DDRGP_DDRGP5 (0x20)
1479
#define MCF_GPIO_DDRGP_DDRGP6 (0x40)
1480
#define MCF_GPIO_DDRGP_DDRGP7 (0x80)
1481
1482
/* Bit definitions and macros for MCF_GPIO_SETNQ */
1483
#define MCF_GPIO_SETNQ_SETNQ0 (0x01)
1484
#define MCF_GPIO_SETNQ_SETNQ1 (0x02)
1485
#define MCF_GPIO_SETNQ_SETNQ2 (0x04)
1486
#define MCF_GPIO_SETNQ_SETNQ3 (0x08)
1487
#define MCF_GPIO_SETNQ_SETNQ4 (0x10)
1488
#define MCF_GPIO_SETNQ_SETNQ5 (0x20)
1489
#define MCF_GPIO_SETNQ_SETNQ6 (0x40)
1490
#define MCF_GPIO_SETNQ_SETNQ7 (0x80)
1491
1492
/* Bit definitions and macros for MCF_GPIO_SETAN */
1493
#define MCF_GPIO_SETAN_SETAN0 (0x01)
1494
#define MCF_GPIO_SETAN_SETAN1 (0x02)
1495
#define MCF_GPIO_SETAN_SETAN2 (0x04)
1496
#define MCF_GPIO_SETAN_SETAN3 (0x08)
1497
#define MCF_GPIO_SETAN_SETAN4 (0x10)
1498
#define MCF_GPIO_SETAN_SETAN5 (0x20)
1499
#define MCF_GPIO_SETAN_SETAN6 (0x40)
1500
#define MCF_GPIO_SETAN_SETAN7 (0x80)
1501
1502
/* Bit definitions and macros for MCF_GPIO_SETAS */
1503
#define MCF_GPIO_SETAS_SETAS0 (0x01)
1504
#define MCF_GPIO_SETAS_SETAS1 (0x02)
1505
#define MCF_GPIO_SETAS_SETAS2 (0x04)
1506
#define MCF_GPIO_SETAS_SETAS3 (0x08)
1507
#define MCF_GPIO_SETAS_SETAS4 (0x10)
1508
#define MCF_GPIO_SETAS_SETAS5 (0x20)
1509
#define MCF_GPIO_SETAS_SETAS6 (0x40)
1510
#define MCF_GPIO_SETAS_SETAS7 (0x80)
1511
1512
/* Bit definitions and macros for MCF_GPIO_SETQS */
1513
#define MCF_GPIO_SETQS_SETQS0 (0x01)
1514
#define MCF_GPIO_SETQS_SETQS1 (0x02)
1515
#define MCF_GPIO_SETQS_SETQS2 (0x04)
1516
#define MCF_GPIO_SETQS_SETQS3 (0x08)
1517
#define MCF_GPIO_SETQS_SETQS4 (0x10)
1518
#define MCF_GPIO_SETQS_SETQS5 (0x20)
1519
#define MCF_GPIO_SETQS_SETQS6 (0x40)
1520
#define MCF_GPIO_SETQS_SETQS7 (0x80)
1521
1522
/* Bit definitions and macros for MCF_GPIO_SETTA */
1523
#define MCF_GPIO_SETTA_SETTA0 (0x01)
1524
#define MCF_GPIO_SETTA_SETTA1 (0x02)
1525
#define MCF_GPIO_SETTA_SETTA2 (0x04)
1526
#define MCF_GPIO_SETTA_SETTA3 (0x08)
1527
#define MCF_GPIO_SETTA_SETTA4 (0x10)
1528
#define MCF_GPIO_SETTA_SETTA5 (0x20)
1529
#define MCF_GPIO_SETTA_SETTA6 (0x40)
1530
#define MCF_GPIO_SETTA_SETTA7 (0x80)
1531
1532
/* Bit definitions and macros for MCF_GPIO_SETTC */
1533
#define MCF_GPIO_SETTC_SETTC0 (0x01)
1534
#define MCF_GPIO_SETTC_SETTC1 (0x02)
1535
#define MCF_GPIO_SETTC_SETTC2 (0x04)
1536
#define MCF_GPIO_SETTC_SETTC3 (0x08)
1537
#define MCF_GPIO_SETTC_SETTC4 (0x10)
1538
#define MCF_GPIO_SETTC_SETTC5 (0x20)
1539
#define MCF_GPIO_SETTC_SETTC6 (0x40)
1540
#define MCF_GPIO_SETTC_SETTC7 (0x80)
1541
1542
/* Bit definitions and macros for MCF_GPIO_SETTD */
1543
#define MCF_GPIO_SETTD_SETTD0 (0x01)
1544
#define MCF_GPIO_SETTD_SETTD1 (0x02)
1545
#define MCF_GPIO_SETTD_SETTD2 (0x04)
1546
#define MCF_GPIO_SETTD_SETTD3 (0x08)
1547
#define MCF_GPIO_SETTD_SETTD4 (0x10)
1548
#define MCF_GPIO_SETTD_SETTD5 (0x20)
1549
#define MCF_GPIO_SETTD_SETTD6 (0x40)
1550
#define MCF_GPIO_SETTD_SETTD7 (0x80)
1551
1552
/* Bit definitions and macros for MCF_GPIO_SETUA */
1553
#define MCF_GPIO_SETUA_SETUA0 (0x01)
1554
#define MCF_GPIO_SETUA_SETUA1 (0x02)
1555
#define MCF_GPIO_SETUA_SETUA2 (0x04)
1556
#define MCF_GPIO_SETUA_SETUA3 (0x08)
1557
#define MCF_GPIO_SETUA_SETUA4 (0x10)
1558
#define MCF_GPIO_SETUA_SETUA5 (0x20)
1559
#define MCF_GPIO_SETUA_SETUA6 (0x40)
1560
#define MCF_GPIO_SETUA_SETUA7 (0x80)
1561
1562
/* Bit definitions and macros for MCF_GPIO_SETUB */
1563
#define MCF_GPIO_SETUB_SETUB0 (0x01)
1564
#define MCF_GPIO_SETUB_SETUB1 (0x02)
1565
#define MCF_GPIO_SETUB_SETUB2 (0x04)
1566
#define MCF_GPIO_SETUB_SETUB3 (0x08)
1567
#define MCF_GPIO_SETUB_SETUB4 (0x10)
1568
#define MCF_GPIO_SETUB_SETUB5 (0x20)
1569
#define MCF_GPIO_SETUB_SETUB6 (0x40)
1570
#define MCF_GPIO_SETUB_SETUB7 (0x80)
1571
1572
/* Bit definitions and macros for MCF_GPIO_SETUC */
1573
#define MCF_GPIO_SETUC_SETUC0 (0x01)
1574
#define MCF_GPIO_SETUC_SETUC1 (0x02)
1575
#define MCF_GPIO_SETUC_SETUC2 (0x04)
1576
#define MCF_GPIO_SETUC_SETUC3 (0x08)
1577
#define MCF_GPIO_SETUC_SETUC4 (0x10)
1578
#define MCF_GPIO_SETUC_SETUC5 (0x20)
1579
#define MCF_GPIO_SETUC_SETUC6 (0x40)
1580
#define MCF_GPIO_SETUC_SETUC7 (0x80)
1581
1582
/* Bit definitions and macros for MCF_GPIO_SETDD */
1583
#define MCF_GPIO_SETDD_SETDD0 (0x01)
1584
#define MCF_GPIO_SETDD_SETDD1 (0x02)
1585
#define MCF_GPIO_SETDD_SETDD2 (0x04)
1586
#define MCF_GPIO_SETDD_SETDD3 (0x08)
1587
#define MCF_GPIO_SETDD_SETDD4 (0x10)
1588
#define MCF_GPIO_SETDD_SETDD5 (0x20)
1589
#define MCF_GPIO_SETDD_SETDD6 (0x40)
1590
#define MCF_GPIO_SETDD_SETDD7 (0x80)
1591
1592
/* Bit definitions and macros for MCF_GPIO_SETLD */
1593
#define MCF_GPIO_SETLD_SETLD0 (0x01)
1594
#define MCF_GPIO_SETLD_SETLD1 (0x02)
1595
#define MCF_GPIO_SETLD_SETLD2 (0x04)
1596
#define MCF_GPIO_SETLD_SETLD3 (0x08)
1597
#define MCF_GPIO_SETLD_SETLD4 (0x10)
1598
#define MCF_GPIO_SETLD_SETLD5 (0x20)
1599
#define MCF_GPIO_SETLD_SETLD6 (0x40)
1600
#define MCF_GPIO_SETLD_SETLD7 (0x80)
1601
1602
/* Bit definitions and macros for MCF_GPIO_SETGP */
1603
#define MCF_GPIO_SETGP_SETGP0 (0x01)
1604
#define MCF_GPIO_SETGP_SETGP1 (0x02)
1605
#define MCF_GPIO_SETGP_SETGP2 (0x04)
1606
#define MCF_GPIO_SETGP_SETGP3 (0x08)
1607
#define MCF_GPIO_SETGP_SETGP4 (0x10)
1608
#define MCF_GPIO_SETGP_SETGP5 (0x20)
1609
#define MCF_GPIO_SETGP_SETGP6 (0x40)
1610
#define MCF_GPIO_SETGP_SETGP7 (0x80)
1611
1612
/* Bit definitions and macros for MCF_GPIO_CLRNQ */
1613
#define MCF_GPIO_CLRNQ_CLRNQ0 (0x01)
1614
#define MCF_GPIO_CLRNQ_CLRNQ1 (0x02)
1615
#define MCF_GPIO_CLRNQ_CLRNQ2 (0x04)
1616
#define MCF_GPIO_CLRNQ_CLRNQ3 (0x08)
1617
#define MCF_GPIO_CLRNQ_CLRNQ4 (0x10)
1618
#define MCF_GPIO_CLRNQ_CLRNQ5 (0x20)
1619
#define MCF_GPIO_CLRNQ_CLRNQ6 (0x40)
1620
#define MCF_GPIO_CLRNQ_CLRNQ7 (0x80)
1621
1622
/* Bit definitions and macros for MCF_GPIO_CLRAN */
1623
#define MCF_GPIO_CLRAN_CLRAN0 (0x01)
1624
#define MCF_GPIO_CLRAN_CLRAN1 (0x02)
1625
#define MCF_GPIO_CLRAN_CLRAN2 (0x04)
1626
#define MCF_GPIO_CLRAN_CLRAN3 (0x08)
1627
#define MCF_GPIO_CLRAN_CLRAN4 (0x10)
1628
#define MCF_GPIO_CLRAN_CLRAN5 (0x20)
1629
#define MCF_GPIO_CLRAN_CLRAN6 (0x40)
1630
#define MCF_GPIO_CLRAN_CLRAN7 (0x80)
1631
1632
/* Bit definitions and macros for MCF_GPIO_CLRAS */
1633
#define MCF_GPIO_CLRAS_CLRAS0 (0x01)
1634
#define MCF_GPIO_CLRAS_CLRAS1 (0x02)
1635
#define MCF_GPIO_CLRAS_CLRAS2 (0x04)
1636
#define MCF_GPIO_CLRAS_CLRAS3 (0x08)
1637
#define MCF_GPIO_CLRAS_CLRAS4 (0x10)
1638
#define MCF_GPIO_CLRAS_CLRAS5 (0x20)
1639
#define MCF_GPIO_CLRAS_CLRAS6 (0x40)
1640
#define MCF_GPIO_CLRAS_CLRAS7 (0x80)
1641
1642
/* Bit definitions and macros for MCF_GPIO_CLRQS */
1643
#define MCF_GPIO_CLRQS_CLRQS0 (0x01)
1644
#define MCF_GPIO_CLRQS_CLRQS1 (0x02)
1645
#define MCF_GPIO_CLRQS_CLRQS2 (0x04)
1646
#define MCF_GPIO_CLRQS_CLRQS3 (0x08)
1647
#define MCF_GPIO_CLRQS_CLRQS4 (0x10)
1648
#define MCF_GPIO_CLRQS_CLRQS5 (0x20)
1649
#define MCF_GPIO_CLRQS_CLRQS6 (0x40)
1650
#define MCF_GPIO_CLRQS_CLRQS7 (0x80)
1651
1652
/* Bit definitions and macros for MCF_GPIO_CLRTA */
1653
#define MCF_GPIO_CLRTA_CLRTA0 (0x01)
1654
#define MCF_GPIO_CLRTA_CLRTA1 (0x02)
1655
#define MCF_GPIO_CLRTA_CLRTA2 (0x04)
1656
#define MCF_GPIO_CLRTA_CLRTA3 (0x08)
1657
#define MCF_GPIO_CLRTA_CLRTA4 (0x10)
1658
#define MCF_GPIO_CLRTA_CLRTA5 (0x20)
1659
#define MCF_GPIO_CLRTA_CLRTA6 (0x40)
1660
#define MCF_GPIO_CLRTA_CLRTA7 (0x80)
1661
1662
/* Bit definitions and macros for MCF_GPIO_CLRTC */
1663
#define MCF_GPIO_CLRTC_CLRTC0 (0x01)
1664
#define MCF_GPIO_CLRTC_CLRTC1 (0x02)
1665
#define MCF_GPIO_CLRTC_CLRTC2 (0x04)
1666
#define MCF_GPIO_CLRTC_CLRTC3 (0x08)
1667
#define MCF_GPIO_CLRTC_CLRTC4 (0x10)
1668
#define MCF_GPIO_CLRTC_CLRTC5 (0x20)
1669
#define MCF_GPIO_CLRTC_CLRTC6 (0x40)
1670
#define MCF_GPIO_CLRTC_CLRTC7 (0x80)
1671
1672
/* Bit definitions and macros for MCF_GPIO_CLRTD */
1673
#define MCF_GPIO_CLRTD_CLRTD0 (0x01)
1674
#define MCF_GPIO_CLRTD_CLRTD1 (0x02)
1675
#define MCF_GPIO_CLRTD_CLRTD2 (0x04)
1676
#define MCF_GPIO_CLRTD_CLRTD3 (0x08)
1677
#define MCF_GPIO_CLRTD_CLRTD4 (0x10)
1678
#define MCF_GPIO_CLRTD_CLRTD5 (0x20)
1679
#define MCF_GPIO_CLRTD_CLRTD6 (0x40)
1680
#define MCF_GPIO_CLRTD_CLRTD7 (0x80)
1681
1682
/* Bit definitions and macros for MCF_GPIO_CLRUA */
1683
#define MCF_GPIO_CLRUA_CLRUA0 (0x01)
1684
#define MCF_GPIO_CLRUA_CLRUA1 (0x02)
1685
#define MCF_GPIO_CLRUA_CLRUA2 (0x04)
1686
#define MCF_GPIO_CLRUA_CLRUA3 (0x08)
1687
#define MCF_GPIO_CLRUA_CLRUA4 (0x10)
1688
#define MCF_GPIO_CLRUA_CLRUA5 (0x20)
1689
#define MCF_GPIO_CLRUA_CLRUA6 (0x40)
1690
#define MCF_GPIO_CLRUA_CLRUA7 (0x80)
1691
1692
/* Bit definitions and macros for MCF_GPIO_CLRUB */
1693
#define MCF_GPIO_CLRUB_CLRUB0 (0x01)
1694
#define MCF_GPIO_CLRUB_CLRUB1 (0x02)
1695
#define MCF_GPIO_CLRUB_CLRUB2 (0x04)
1696
#define MCF_GPIO_CLRUB_CLRUB3 (0x08)
1697
#define MCF_GPIO_CLRUB_CLRUB4 (0x10)
1698
#define MCF_GPIO_CLRUB_CLRUB5 (0x20)
1699
#define MCF_GPIO_CLRUB_CLRUB6 (0x40)
1700
#define MCF_GPIO_CLRUB_CLRUB7 (0x80)
1701
1702
/* Bit definitions and macros for MCF_GPIO_CLRUC */
1703
#define MCF_GPIO_CLRUC_CLRUC0 (0x01)
1704
#define MCF_GPIO_CLRUC_CLRUC1 (0x02)
1705
#define MCF_GPIO_CLRUC_CLRUC2 (0x04)
1706
#define MCF_GPIO_CLRUC_CLRUC3 (0x08)
1707
#define MCF_GPIO_CLRUC_CLRUC4 (0x10)
1708
#define MCF_GPIO_CLRUC_CLRUC5 (0x20)
1709
#define MCF_GPIO_CLRUC_CLRUC6 (0x40)
1710
#define MCF_GPIO_CLRUC_CLRUC7 (0x80)
1711
1712
/* Bit definitions and macros for MCF_GPIO_CLRDD */
1713
#define MCF_GPIO_CLRDD_CLRDD0 (0x01)
1714
#define MCF_GPIO_CLRDD_CLRDD1 (0x02)
1715
#define MCF_GPIO_CLRDD_CLRDD2 (0x04)
1716
#define MCF_GPIO_CLRDD_CLRDD3 (0x08)
1717
#define MCF_GPIO_CLRDD_CLRDD4 (0x10)
1718
#define MCF_GPIO_CLRDD_CLRDD5 (0x20)
1719
#define MCF_GPIO_CLRDD_CLRDD6 (0x40)
1720
#define MCF_GPIO_CLRDD_CLRDD7 (0x80)
1721
1722
/* Bit definitions and macros for MCF_GPIO_CLRLD */
1723
#define MCF_GPIO_CLRLD_CLRLD0 (0x01)
1724
#define MCF_GPIO_CLRLD_CLRLD1 (0x02)
1725
#define MCF_GPIO_CLRLD_CLRLD2 (0x04)
1726
#define MCF_GPIO_CLRLD_CLRLD3 (0x08)
1727
#define MCF_GPIO_CLRLD_CLRLD4 (0x10)
1728
#define MCF_GPIO_CLRLD_CLRLD5 (0x20)
1729
#define MCF_GPIO_CLRLD_CLRLD6 (0x40)
1730
#define MCF_GPIO_CLRLD_CLRLD7 (0x80)
1731
1732
/* Bit definitions and macros for MCF_GPIO_CLRGP */
1733
#define MCF_GPIO_CLRGP_CLRGP0 (0x01)
1734
#define MCF_GPIO_CLRGP_CLRGP1 (0x02)
1735
#define MCF_GPIO_CLRGP_CLRGP2 (0x04)
1736
#define MCF_GPIO_CLRGP_CLRGP3 (0x08)
1737
#define MCF_GPIO_CLRGP_CLRGP4 (0x10)
1738
#define MCF_GPIO_CLRGP_CLRGP5 (0x20)
1739
#define MCF_GPIO_CLRGP_CLRGP6 (0x40)
1740
#define MCF_GPIO_CLRGP_CLRGP7 (0x80)
1741
1742
/* Bit definitions and macros for MCF_GPIO_PNQPAR */
1743
#define MCF_GPIO_PNQPAR_PNQPAR1(x) (((x)&0x0003)<<2)
1744
#define MCF_GPIO_PNQPAR_PNQPAR2(x) (((x)&0x0003)<<4)
1745
#define MCF_GPIO_PNQPAR_PNQPAR3(x) (((x)&0x0003)<<6)
1746
#define MCF_GPIO_PNQPAR_PNQPAR4(x) (((x)&0x0003)<<8)
1747
#define MCF_GPIO_PNQPAR_PNQPAR5(x) (((x)&0x0003)<<10)
1748
#define MCF_GPIO_PNQPAR_PNQPAR6(x) (((x)&0x0003)<<12)
1749
#define MCF_GPIO_PNQPAR_PNQPAR7(x) (((x)&0x0003)<<14)
1750
#define MCF_GPIO_PNQPAR_IRQ1_GPIO (0x0000)
1751
#define MCF_GPIO_PNQPAR_IRQ2_GPIO (0x0000)
1752
#define MCF_GPIO_PNQPAR_IRQ3_GPIO (0x0000)
1753
#define MCF_GPIO_PNQPAR_IRQ4_GPIO (0x0000)
1754
#define MCF_GPIO_PNQPAR_IRQ5_GPIO (0x0000)
1755
#define MCF_GPIO_PNQPAR_IRQ6_GPIO (0x0000)
1756
#define MCF_GPIO_PNQPAR_IRQ7_GPIO (0x0000)
1757
#define MCF_GPIO_PNQPAR_IRQ1_IRQ1 (0x0004)
1758
#define MCF_GPIO_PNQPAR_IRQ2_IRQ2 (0x0010)
1759
#define MCF_GPIO_PNQPAR_IRQ3_IRQ3 (0x0040)
1760
#define MCF_GPIO_PNQPAR_IRQ4_IRQ4 (0x0100)
1761
#define MCF_GPIO_PNQPAR_IRQ5_IRQ5 (0x0400)
1762
#define MCF_GPIO_PNQPAR_IRQ6_IRQ6 (0x1000)
1763
#define MCF_GPIO_PNQPAR_IRQ7_IRQ7 (0x4000)
1764
#define MCF_GPIO_PNQPAR_IRQ1_SYNCA (0x0008)
1765
#define MCF_GPIO_PNQPAR_IRQ1_PWM1 (0x000C)
1766
1767
/* Bit definitions and macros for MCF_GPIO_PANPAR */
1768
#define MCF_GPIO_PANPAR_PANPAR0 (0x01)
1769
#define MCF_GPIO_PANPAR_PANPAR1 (0x02)
1770
#define MCF_GPIO_PANPAR_PANPAR2 (0x04)
1771
#define MCF_GPIO_PANPAR_PANPAR3 (0x08)
1772
#define MCF_GPIO_PANPAR_PANPAR4 (0x10)
1773
#define MCF_GPIO_PANPAR_PANPAR5 (0x20)
1774
#define MCF_GPIO_PANPAR_PANPAR6 (0x40)
1775
#define MCF_GPIO_PANPAR_PANPAR7 (0x80)
1776
#define MCF_GPIO_PANPAR_AN0_GPIO (0x00)
1777
#define MCF_GPIO_PANPAR_AN1_GPIO (0x00)
1778
#define MCF_GPIO_PANPAR_AN2_GPIO (0x00)
1779
#define MCF_GPIO_PANPAR_AN3_GPIO (0x00)
1780
#define MCF_GPIO_PANPAR_AN4_GPIO (0x00)
1781
#define MCF_GPIO_PANPAR_AN5_GPIO (0x00)
1782
#define MCF_GPIO_PANPAR_AN6_GPIO (0x00)
1783
#define MCF_GPIO_PANPAR_AN7_GPIO (0x00)
1784
#define MCF_GPIO_PANPAR_AN0_AN0 (0x01)
1785
#define MCF_GPIO_PANPAR_AN1_AN1 (0x02)
1786
#define MCF_GPIO_PANPAR_AN2_AN2 (0x04)
1787
#define MCF_GPIO_PANPAR_AN3_AN3 (0x08)
1788
#define MCF_GPIO_PANPAR_AN4_AN4 (0x10)
1789
#define MCF_GPIO_PANPAR_AN5_AN5 (0x20)
1790
#define MCF_GPIO_PANPAR_AN6_AN6 (0x40)
1791
#define MCF_GPIO_PANPAR_AN7_AN7 (0x80)
1792
1793
/* Bit definitions and macros for MCF_GPIO_PASPAR */
1794
#define MCF_GPIO_PASPAR_PASPAR0(x) (((x)&0x03)<<0)
1795
#define MCF_GPIO_PASPAR_PASPAR1(x) (((x)&0x03)<<2)
1796
#define MCF_GPIO_PASPAR_PASPAR2(x) (((x)&0x03)<<4)
1797
#define MCF_GPIO_PASPAR_PASPAR3(x) (((x)&0x03)<<6)
1798
#define MCF_GPIO_PASPAR_SCL_GPIO (0x00)
1799
#define MCF_GPIO_PASPAR_SDA_GPIO (0x00)
1800
#define MCF_GPIO_PASPAR_SYNCA_GPIO (0x00)
1801
#define MCF_GPIO_PASPAR_SYNCB_GPIO (0x00)
1802
#define MCF_GPIO_PASPAR_SCL_SCL (0x01)
1803
#define MCF_GPIO_PASPAR_SDA_SDA (0x04)
1804
#define MCF_GPIO_PASPAR_SYNCA_SYNCA (0x10)
1805
#define MCF_GPIO_PASPAR_SYNCB_SYNCB (0x40)
1806
#define MCF_GPIO_PASPAR_SCL_CANTX (0x02)
1807
#define MCF_GPIO_PASPAR_SDA_CANRX (0x08)
1808
#define MCF_GPIO_PASPAR_SYNCA_CANRX (0x20)
1809
#define MCF_GPIO_PASPAR_SYNCB_CANTX (0x80)
1810
#define MCF_GPIO_PASPAR_SCL_TXD2 (0x30)
1811
#define MCF_GPIO_PASPAR_SDA_RXD2 (0xC0)
1812
1813
/* Bit definitions and macros for MCF_GPIO_PQSPAR */
1814
#define MCF_GPIO_PQSPAR_PQSPAR0(x) (((x)&0x0003)<<0)
1815
#define MCF_GPIO_PQSPAR_PQSPAR1(x) (((x)&0x0003)<<2)
1816
#define MCF_GPIO_PQSPAR_PQSPAR2(x) (((x)&0x0003)<<4)
1817
#define MCF_GPIO_PQSPAR_PQSPAR3(x) (((x)&0x0003)<<6)
1818
#define MCF_GPIO_PQSPAR_PQSPAR4(x) (((x)&0x0003)<<8)
1819
#define MCF_GPIO_PQSPAR_PQSPAR5(x) (((x)&0x0003)<<10)
1820
#define MCF_GPIO_PQSPAR_PQSPAR6(x) (((x)&0x0003)<<12)
1821
#define MCF_GPIO_PQSPAR_DOUT_GPIO (0x0000)
1822
#define MCF_GPIO_PQSPAR_DIN_GPIO (0x0000)
1823
#define MCF_GPIO_PQSPAR_SCK_GPIO (0x0000)
1824
#define MCF_GPIO_PQSPAR_CS0_GPIO (0x0000)
1825
#define MCF_GPIO_PQSPAR_CS1_GPIO (0x0000)
1826
#define MCF_GPIO_PQSPAR_CS2_GPIO (0x0000)
1827
#define MCF_GPIO_PQSPAR_CS3_GPIO (0x0000)
1828
#define MCF_GPIO_PQSPAR_DOUT_DOUT (0x0001)
1829
#define MCF_GPIO_PQSPAR_DIN_DIN (0x0004)
1830
#define MCF_GPIO_PQSPAR_SCK_SCK (0x0010)
1831
#define MCF_GPIO_PQSPAR_CS0_CS0 (0x0040)
1832
#define MCF_GPIO_PQSPAR_CS1_CS1 (0x0100)
1833
#define MCF_GPIO_PQSPAR_CS2_CS2 (0x0400)
1834
#define MCF_GPIO_PQSPAR_CS3_CS3 (0x1000)
1835
#define MCF_GPIO_PQSPAR_DOUT_CANTX (0x0002)
1836
#define MCF_GPIO_PQSPAR_DIN_CANRX (0x0008)
1837
#define MCF_GPIO_PQSPAR_SCK_SCL (0x0020)
1838
#define MCF_GPIO_PQSPAR_CS0_SDA (0x0080)
1839
#define MCF_GPIO_PQSPAR_CS3_SYNCA (0x2000)
1840
#define MCF_GPIO_PQSPAR_DOUT_TXD1 (0x0003)
1841
#define MCF_GPIO_PQSPAR_DIN_RXD1 (0x000C)
1842
#define MCF_GPIO_PQSPAR_SCK_RTS1 (0x0030)
1843
#define MCF_GPIO_PQSPAR_CS0_CTS1 (0x00C0)
1844
#define MCF_GPIO_PQSPAR_CS3_SYNCB (0x3000)
1845
1846
/* Bit definitions and macros for MCF_GPIO_PTAPAR */
1847
#define MCF_GPIO_PTAPAR_PTAPAR0(x) (((x)&0x03)<<0)
1848
#define MCF_GPIO_PTAPAR_PTAPAR1(x) (((x)&0x03)<<2)
1849
#define MCF_GPIO_PTAPAR_PTAPAR2(x) (((x)&0x03)<<4)
1850
#define MCF_GPIO_PTAPAR_PTAPAR3(x) (((x)&0x03)<<6)
1851
#define MCF_GPIO_PTAPAR_ICOC0_GPIO (0x00)
1852
#define MCF_GPIO_PTAPAR_ICOC1_GPIO (0x00)
1853
#define MCF_GPIO_PTAPAR_ICOC2_GPIO (0x00)
1854
#define MCF_GPIO_PTAPAR_ICOC3_GPIO (0x00)
1855
#define MCF_GPIO_PTAPAR_ICOC0_ICOC0 (0x01)
1856
#define MCF_GPIO_PTAPAR_ICOC1_ICOC1 (0x04)
1857
#define MCF_GPIO_PTAPAR_ICOC2_ICOC2 (0x10)
1858
#define MCF_GPIO_PTAPAR_ICOC3_ICOC3 (0x40)
1859
#define MCF_GPIO_PTAPAR_ICOC0_PWM1 (0x02)
1860
#define MCF_GPIO_PTAPAR_ICOC1_PWM3 (0x08)
1861
#define MCF_GPIO_PTAPAR_ICOC2_PWM5 (0x20)
1862
#define MCF_GPIO_PTAPAR_ICOC3_PWM7 (0x80)
1863
1864
/* Bit definitions and macros for MCF_GPIO_PTCPAR */
1865
#define MCF_GPIO_PTCPAR_PTCPAR0(x) (((x)&0x03)<<0)
1866
#define MCF_GPIO_PTCPAR_PTCPAR1(x) (((x)&0x03)<<2)
1867
#define MCF_GPIO_PTCPAR_PTCPAR2(x) (((x)&0x03)<<4)
1868
#define MCF_GPIO_PTCPAR_PTCPAR3(x) (((x)&0x03)<<6)
1869
#define MCF_GPIO_PTCPAR_TIN0_GPIO (0x00)
1870
#define MCF_GPIO_PTCPAR_TIN1_GPIO (0x00)
1871
#define MCF_GPIO_PTCPAR_TIN2_GPIO (0x00)
1872
#define MCF_GPIO_PTCPAR_TIN3_GPIO (0x00)
1873
#define MCF_GPIO_PTCPAR_TIN0_TIN0 (0x01)
1874
#define MCF_GPIO_PTCPAR_TIN1_TIN1 (0x04)
1875
#define MCF_GPIO_PTCPAR_TIN2_TIN2 (0x10)
1876
#define MCF_GPIO_PTCPAR_TIN3_TIN3 (0x40)
1877
#define MCF_GPIO_PTCPAR_TIN0_TOUT0 (0x02)
1878
#define MCF_GPIO_PTCPAR_TIN1_TOUT1 (0x08)
1879
#define MCF_GPIO_PTCPAR_TIN2_TOUT2 (0x20)
1880
#define MCF_GPIO_PTCPAR_TIN3_TOUT3 (0x80)
1881
#define MCF_GPIO_PTCPAR_TIN0_PWM0 (0x03)
1882
#define MCF_GPIO_PTCPAR_TIN1_PWM2 (0x0C)
1883
#define MCF_GPIO_PTCPAR_TIN2_PWM4 (0x30)
1884
#define MCF_GPIO_PTCPAR_TIN3_PWM6 (0xC0)
1885
1886
/* Bit definitions and macros for MCF_GPIO_PTDPAR */
1887
#define MCF_GPIO_PTDPAR_PTDPAR0 (0x01)
1888
#define MCF_GPIO_PTDPAR_PTDPAR1 (0x02)
1889
#define MCF_GPIO_PTDPAR_PTDPAR2 (0x04)
1890
#define MCF_GPIO_PTDPAR_PTDPAR3 (0x08)
1891
#define MCF_GPIO_PTDPAR_PWM1_GPIO (0x00)
1892
#define MCF_GPIO_PTDPAR_PWM3_GPIO (0x00)
1893
#define MCF_GPIO_PTDPAR_PWM5_GPIO (0x00)
1894
#define MCF_GPIO_PTDPAR_PWM7_GPIO (0x00)
1895
#define MCF_GPIO_PTDPAR_PWM1_PWM1 (0x01)
1896
#define MCF_GPIO_PTDPAR_PWM3_PWM3 (0x02)
1897
#define MCF_GPIO_PTDPAR_PWM5_PWM5 (0x04)
1898
#define MCF_GPIO_PTDPAR_PWM7_PWM7 (0x08)
1899
1900
/* Bit definitions and macros for MCF_GPIO_PUAPAR */
1901
#define MCF_GPIO_PUAPAR_PUAPAR0(x) (((x)&0x03)<<0)
1902
#define MCF_GPIO_PUAPAR_PUAPAR1(x) (((x)&0x03)<<2)
1903
#define MCF_GPIO_PUAPAR_PUAPAR2(x) (((x)&0x03)<<4)
1904
#define MCF_GPIO_PUAPAR_PUAPAR3(x) (((x)&0x03)<<6)
1905
#define MCF_GPIO_PUAPAR_TXD0_GPIO (0x00)
1906
#define MCF_GPIO_PUAPAR_RXD0_GPIO (0x00)
1907
#define MCF_GPIO_PUAPAR_RTS0_GPIO (0x00)
1908
#define MCF_GPIO_PUAPAR_CTS0_GPIO (0x00)
1909
#define MCF_GPIO_PUAPAR_TXD0_TXD0 (0x01)
1910
#define MCF_GPIO_PUAPAR_RXD0_RXD0 (0x04)
1911
#define MCF_GPIO_PUAPAR_RTS0_RTS0 (0x10)
1912
#define MCF_GPIO_PUAPAR_CTS0_CTS0 (0x40)
1913
#define MCF_GPIO_PUAPAR_RTS0_CANTX (0x20)
1914
#define MCF_GPIO_PUAPAR_CTS0_CANRX (0x80)
1915
1916
/* Bit definitions and macros for MCF_GPIO_PUBPAR */
1917
#define MCF_GPIO_PUBPAR_PUBPAR0(x) (((x)&0x03)<<0)
1918
#define MCF_GPIO_PUBPAR_PUBPAR1(x) (((x)&0x03)<<2)
1919
#define MCF_GPIO_PUBPAR_PUBPAR2(x) (((x)&0x03)<<4)
1920
#define MCF_GPIO_PUBPAR_PUBPAR3(x) (((x)&0x03)<<6)
1921
#define MCF_GPIO_PUBPAR_TXD1_GPIO (0x00)
1922
#define MCF_GPIO_PUBPAR_RXD1_GPIO (0x00)
1923
#define MCF_GPIO_PUBPAR_RTS1_GPIO (0x00)
1924
#define MCF_GPIO_PUBPAR_CTS1_GPIO (0x00)
1925
#define MCF_GPIO_PUBPAR_TXD1_TXD1 (0x01)
1926
#define MCF_GPIO_PUBPAR_RXD1_RXD1 (0x04)
1927
#define MCF_GPIO_PUBPAR_RTS1_RTS1 (0x10)
1928
#define MCF_GPIO_PUBPAR_CTS1_CTS1 (0x40)
1929
#define MCF_GPIO_PUBPAR_RTS1_SYNCB (0x20)
1930
#define MCF_GPIO_PUBPAR_CTS1_SYNCA (0x80)
1931
#define MCF_GPIO_PUBPAR_RTS1_TXD2 (0x30)
1932
#define MCF_GPIO_PUBPAR_CTS1_RXD2 (0xC0)
1933
1934
/* Bit definitions and macros for MCF_GPIO_PUCPAR */
1935
#define MCF_GPIO_PUCPAR_PUCPAR0 (0x01)
1936
#define MCF_GPIO_PUCPAR_PUCPAR1 (0x02)
1937
#define MCF_GPIO_PUCPAR_PUCPAR2 (0x04)
1938
#define MCF_GPIO_PUCPAR_PUCPAR3 (0x08)
1939
#define MCF_GPIO_PUCPAR_TXD2_GPIO (0x00)
1940
#define MCF_GPIO_PUCPAR_RXD2_GPIO (0x00)
1941
#define MCF_GPIO_PUCPAR_RTS2_GPIO (0x00)
1942
#define MCF_GPIO_PUCPAR_CTS2_GPIO (0x00)
1943
#define MCF_GPIO_PUCPAR_TXD2_TXD2 (0x01)
1944
#define MCF_GPIO_PUCPAR_RXD2_RXD2 (0x02)
1945
#define MCF_GPIO_PUCPAR_RTS2_RTS2 (0x04)
1946
#define MCF_GPIO_PUCPAR_CTS2_CTS2 (0x08)
1947
1948
/* Bit definitions and macros for MCF_GPIO_PDDPAR */
1949
#define MCF_GPIO_PDDPAR_PDDPAR0 (0x01)
1950
#define MCF_GPIO_PDDPAR_PDDPAR1 (0x02)
1951
#define MCF_GPIO_PDDPAR_PDDPAR2 (0x04)
1952
#define MCF_GPIO_PDDPAR_PDDPAR3 (0x08)
1953
#define MCF_GPIO_PDDPAR_PDDPAR4 (0x10)
1954
#define MCF_GPIO_PDDPAR_PDDPAR5 (0x20)
1955
#define MCF_GPIO_PDDPAR_PDDPAR6 (0x40)
1956
#define MCF_GPIO_PDDPAR_PDDPAR7 (0x80)
1957
#define MCF_GPIO_PDDPAR_PDD0_GPIO (0x00)
1958
#define MCF_GPIO_PDDPAR_PDD1_GPIO (0x00)
1959
#define MCF_GPIO_PDDPAR_PDD2_GPIO (0x00)
1960
#define MCF_GPIO_PDDPAR_PDD3_GPIO (0x00)
1961
#define MCF_GPIO_PDDPAR_PDD4_GPIO (0x00)
1962
#define MCF_GPIO_PDDPAR_PDD5_GPIO (0x00)
1963
#define MCF_GPIO_PDDPAR_PDD6_GPIO (0x00)
1964
#define MCF_GPIO_PDDPAR_PDD7_GPIO (0x00)
1965
#define MCF_GPIO_PDDPAR_PDD0_PST0 (0x01)
1966
#define MCF_GPIO_PDDPAR_PDD1_PST1 (0x02)
1967
#define MCF_GPIO_PDDPAR_PDD2_PST2 (0x04)
1968
#define MCF_GPIO_PDDPAR_PDD3_PST3 (0x08)
1969
#define MCF_GPIO_PDDPAR_PDD4_DDATA0 (0x10)
1970
#define MCF_GPIO_PDDPAR_PDD5_DDATA1 (0x20)
1971
#define MCF_GPIO_PDDPAR_PDD6_DDATA2 (0x40)
1972
#define MCF_GPIO_PDDPAR_PDD7_DDATA3 (0x80)
1973
1974
/* Bit definitions and macros for MCF_GPIO_PLDPAR */
1975
#define MCF_GPIO_PLDPAR_PLDPAR0 (0x01)
1976
#define MCF_GPIO_PLDPAR_PLDPAR1 (0x02)
1977
#define MCF_GPIO_PLDPAR_PLDPAR2 (0x04)
1978
#define MCF_GPIO_PLDPAR_PLDPAR3 (0x08)
1979
#define MCF_GPIO_PLDPAR_PLDPAR4 (0x10)
1980
#define MCF_GPIO_PLDPAR_PLDPAR5 (0x20)
1981
#define MCF_GPIO_PLDPAR_PLDPAR6 (0x40)
1982
#define MCF_GPIO_PLDPAR_ACTLED_GPIO (0x00)
1983
#define MCF_GPIO_PLDPAR_LNKLED_GPIO (0x00)
1984
#define MCF_GPIO_PLDPAR_SPDLED_GPIO (0x00)
1985
#define MCF_GPIO_PLDPAR_DUPLED_GPIO (0x00)
1986
#define MCF_GPIO_PLDPAR_COLLED_GPIO (0x00)
1987
#define MCF_GPIO_PLDPAR_RXLED_GPIO (0x00)
1988
#define MCF_GPIO_PLDPAR_TXLED_GPIO (0x00)
1989
#define MCF_GPIO_PLDPAR_ACTLED_ACTLED (0x01)
1990
#define MCF_GPIO_PLDPAR_LNKLED_LNKLED (0x02)
1991
#define MCF_GPIO_PLDPAR_SPDLED_SPDLED (0x04)
1992
#define MCF_GPIO_PLDPAR_DUPLED_DUPLED (0x08)
1993
#define MCF_GPIO_PLDPAR_COLLED_COLLED (0x10)
1994
#define MCF_GPIO_PLDPAR_RXLED_RXLED (0x20)
1995
#define MCF_GPIO_PLDPAR_TXLED_TXLED (0x40)
1996
1997
/* Bit definitions and macros for MCF_GPIO_PGPPAR */
1998
#define MCF_GPIO_PGPPAR_PGPPAR0 (0x01)
1999
#define MCF_GPIO_PGPPAR_PGPPAR1 (0x02)
2000
#define MCF_GPIO_PGPPAR_PGPPAR2 (0x04)
2001
#define MCF_GPIO_PGPPAR_PGPPAR3 (0x08)
2002
#define MCF_GPIO_PGPPAR_PGPPAR4 (0x10)
2003
#define MCF_GPIO_PGPPAR_PGPPAR5 (0x20)
2004
#define MCF_GPIO_PGPPAR_PGPPAR6 (0x40)
2005
#define MCF_GPIO_PGPPAR_PGPPAR7 (0x80)
2006
#define MCF_GPIO_PGPPAR_IRQ8_GPIO (0x00)
2007
#define MCF_GPIO_PGPPAR_IRQ9_GPIO (0x00)
2008
#define MCF_GPIO_PGPPAR_IRQ10_GPIO (0x00)
2009
#define MCF_GPIO_PGPPAR_IRQ11_GPIO (0x00)
2010
#define MCF_GPIO_PGPPAR_IRQ12_GPIO (0x00)
2011
#define MCF_GPIO_PGPPAR_IRQ13_GPIO (0x00)
2012
#define MCF_GPIO_PGPPAR_IRQ14_GPIO (0x00)
2013
#define MCF_GPIO_PGPPAR_IRQ15_GPIO (0x00)
2014
#define MCF_GPIO_PGPPAR_IRQ8_IRQ8 (0x01)
2015
#define MCF_GPIO_PGPPAR_IRQ9_IRQ9 (0x02)
2016
#define MCF_GPIO_PGPPAR_IRQ10_IRQ10 (0x04)
2017
#define MCF_GPIO_PGPPAR_IRQ11_IRQ11 (0x08)
2018
#define MCF_GPIO_PGPPAR_IRQ12_IRQ12 (0x10)
2019
#define MCF_GPIO_PGPPAR_IRQ13_IRQ13 (0x30)
2020
#define MCF_GPIO_PGPPAR_IRQ14_IRQ14 (0x40)
2021
#define MCF_GPIO_PGPPAR_IRQ15_IRQ15 (0x80)
2022
2023
/* Bit definitions and macros for MCF_GPIO_PWOR */
2024
#define MCF_GPIO_PWOR_PWOR0 (0x0001)
2025
#define MCF_GPIO_PWOR_PWOR1 (0x0002)
2026
#define MCF_GPIO_PWOR_PWOR2 (0x0004)
2027
#define MCF_GPIO_PWOR_PWOR3 (0x0008)
2028
#define MCF_GPIO_PWOR_PWOR4 (0x0010)
2029
#define MCF_GPIO_PWOR_PWOR5 (0x0020)
2030
#define MCF_GPIO_PWOR_PWOR6 (0x0040)
2031
#define MCF_GPIO_PWOR_PWOR7 (0x0080)
2032
#define MCF_GPIO_PWOR_PWOR8 (0x0100)
2033
#define MCF_GPIO_PWOR_PWOR9 (0x0200)
2034
#define MCF_GPIO_PWOR_PWOR10 (0x0400)
2035
#define MCF_GPIO_PWOR_PWOR11 (0x0800)
2036
#define MCF_GPIO_PWOR_PWOR12 (0x1000)
2037
#define MCF_GPIO_PWOR_PWOR13 (0x2000)
2038
#define MCF_GPIO_PWOR_PWOR14 (0x4000)
2039
#define MCF_GPIO_PWOR_PWOR15 (0x8000)
2040
2041
/* Bit definitions and macros for MCF_GPIO_PDSRH */
2042
#define MCF_GPIO_PDSRH_PDSR32 (0x0001)
2043
#define MCF_GPIO_PDSRH_PDSR33 (0x0002)
2044
#define MCF_GPIO_PDSRH_PDSR34 (0x0004)
2045
#define MCF_GPIO_PDSRH_PDSR35 (0x0008)
2046
#define MCF_GPIO_PDSRH_PDSR36 (0x0010)
2047
#define MCF_GPIO_PDSRH_PDSR37 (0x0020)
2048
#define MCF_GPIO_PDSRH_PDSR38 (0x0040)
2049
#define MCF_GPIO_PDSRH_PDSR39 (0x0080)
2050
#define MCF_GPIO_PDSRH_PDSR40 (0x0100)
2051
#define MCF_GPIO_PDSRH_PDSR41 (0x0200)
2052
#define MCF_GPIO_PDSRH_PDSR42 (0x0400)
2053
#define MCF_GPIO_PDSRH_PDSR43 (0x0800)
2054
#define MCF_GPIO_PDSRH_PDSR44 (0x1000)
2055
#define MCF_GPIO_PDSRH_PDSR45 (0x2000)
2056
#define MCF_GPIO_PDSRH_PDSR46 (0x4000)
2057
#define MCF_GPIO_PDSRH_PDSR47 (0x8000)
2058
2059
/* Bit definitions and macros for MCF_GPIO_PDSRL */
2060
#define MCF_GPIO_PDSRL_PDSR0 (0x00000001)
2061
#define MCF_GPIO_PDSRL_PDSR1 (0x00000002)
2062
#define MCF_GPIO_PDSRL_PDSR2 (0x00000004)
2063
#define MCF_GPIO_PDSRL_PDSR3 (0x00000008)
2064
#define MCF_GPIO_PDSRL_PDSR4 (0x00000010)
2065
#define MCF_GPIO_PDSRL_PDSR5 (0x00000020)
2066
#define MCF_GPIO_PDSRL_PDSR6 (0x00000040)
2067
#define MCF_GPIO_PDSRL_PDSR7 (0x00000080)
2068
#define MCF_GPIO_PDSRL_PDSR8 (0x00000100)
2069
#define MCF_GPIO_PDSRL_PDSR9 (0x00000200)
2070
#define MCF_GPIO_PDSRL_PDSR10 (0x00000400)
2071
#define MCF_GPIO_PDSRL_PDSR11 (0x00000800)
2072
#define MCF_GPIO_PDSRL_PDSR12 (0x00001000)
2073
#define MCF_GPIO_PDSRL_PDSR13 (0x00002000)
2074
#define MCF_GPIO_PDSRL_PDSR14 (0x00004000)
2075
#define MCF_GPIO_PDSRL_PDSR15 (0x00008000)
2076
#define MCF_GPIO_PDSRL_PDSR16 (0x00010000)
2077
#define MCF_GPIO_PDSRL_PDSR17 (0x00020000)
2078
#define MCF_GPIO_PDSRL_PDSR18 (0x00040000)
2079
#define MCF_GPIO_PDSRL_PDSR19 (0x00080000)
2080
#define MCF_GPIO_PDSRL_PDSR20 (0x00100000)
2081
#define MCF_GPIO_PDSRL_PDSR21 (0x00200000)
2082
#define MCF_GPIO_PDSRL_PDSR22 (0x00400000)
2083
#define MCF_GPIO_PDSRL_PDSR23 (0x00800000)
2084
#define MCF_GPIO_PDSRL_PDSR24 (0x01000000)
2085
#define MCF_GPIO_PDSRL_PDSR25 (0x02000000)
2086
#define MCF_GPIO_PDSRL_PDSR26 (0x04000000)
2087
#define MCF_GPIO_PDSRL_PDSR27 (0x08000000)
2088
#define MCF_GPIO_PDSRL_PDSR28 (0x10000000)
2089
#define MCF_GPIO_PDSRL_PDSR29 (0x20000000)
2090
#define MCF_GPIO_PDSRL_PDSR30 (0x40000000)
2091
#define MCF_GPIO_PDSRL_PDSR31 (0x80000000)
2092
2093
2094
2095
* ColdFire Integration Module (CIM)
2096
2097
2098
2099
/* Register read/write macros */
2100
#define MCF_CIM_RCR (*(vuint8 *)(&__IPSBAR[0x110000]))
2101
#define MCF_CIM_RSR (*(vuint8 *)(&__IPSBAR[0x110001]))
2102
#define MCF_CIM_CCR (*(vuint16*)(&__IPSBAR[0x110004]))
2103
#define MCF_CIM_LPCR (*(vuint8 *)(&__IPSBAR[0x110007]))
2104
#define MCF_CIM_RCON (*(vuint16*)(&__IPSBAR[0x110008]))
2105
#define MCF_CIM_CIR (*(vuint16*)(&__IPSBAR[0x11000A]))
2106
2107
/* Bit definitions and macros for MCF_CIM_RCR */
2108
#define MCF_CIM_RCR_LVDE (0x01)
2109
#define MCF_CIM_RCR_LVDRE (0x04)
2110
#define MCF_CIM_RCR_LVDIE (0x08)
2111
#define MCF_CIM_RCR_LVDF (0x10)
2112
#define MCF_CIM_RCR_FRCRSTOUT (0x40)
2113
#define MCF_CIM_RCR_SOFTRST (0x80)
2114
2115
/* Bit definitions and macros for MCF_CIM_RSR */
2116
#define MCF_CIM_RSR_LOL (0x01)
2117
#define MCF_CIM_RSR_LOC (0x02)
2118
#define MCF_CIM_RSR_EXT (0x04)
2119
#define MCF_CIM_RSR_POR (0x08)
2120
#define MCF_CIM_RSR_WDR (0x10)
2121
#define MCF_CIM_RSR_SOFT (0x20)
2122
#define MCF_CIM_RSR_LVD (0x40)
2123
2124
/* Bit definitions and macros for MCF_CIM_CCR */
2125
#define MCF_CIM_CCR_LOAD (0x8000)
2126
2127
/* Bit definitions and macros for MCF_CIM_LPCR */
2128
#define MCF_CIM_LPCR_LVDSE (0x02)
2129
#define MCF_CIM_LPCR_STPMD(x) (((x)&0x03)<<3)
2130
#define MCF_CIM_LPCR_LPMD(x) (((x)&0x03)<<6)
2131
#define MCF_CIM_LPCR_LPMD_STOP (0xC0)
2132
#define MCF_CIM_LPCR_LPMD_WAIT (0x80)
2133
#define MCF_CIM_LPCR_LPMD_DOZE (0x40)
2134
#define MCF_CIM_LPCR_LPMD_RUN (0x00)
2135
2136
/* Bit definitions and macros for MCF_CIM_RCON */
2137
#define MCF_CIM_RCON_RLOAD (0x0020)
2138
2139
2140
2141
* Clock Module (CLOCK)
2142
2143
2144
2145
2146
#define MCF_CLOCK_SYNCR (*(vuint16*)(&__IPSBAR[0x120000]))
2147
#define MCF_CLOCK_SYNSR (*(vuint8 *)(&__IPSBAR[0x120002]))
2148
#define MCF_CLOCK_LPCR (*(vuint8 *)(&__IPSBAR[0x120007]))
2149
#define MCF_CLOCK_CCHR (*(vuint8 *)(&__IPSBAR[0x120008]))
2150
#define MCF_CLOCK_RTCDR (*(vuint32*)(&__IPSBAR[0x12000C]))
2151
2152
/* Bit definitions and macros for MCF_CLOCK_SYNCR */
2153
#define MCF_CLOCK_SYNCR_PLLEN (0x0001)
2154
#define MCF_CLOCK_SYNCR_PLLMODE (0x0002)
2155
#define MCF_CLOCK_SYNCR_CLKSRC (0x0004)
2156
#define MCF_CLOCK_SYNCR_FWKUP (0x0020)
2157
#define MCF_CLOCK_SYNCR_DISCLK (0x0040)
2158
#define MCF_CLOCK_SYNCR_LOCEN (0x0080)
2159
#define MCF_CLOCK_SYNCR_RFD(x) (((x)&0x0007)<<8)
2160
#define MCF_CLOCK_SYNCR_LOCRE (0x0800)
2161
#define MCF_CLOCK_SYNCR_MFD(x) (((x)&0x0007)<<12)
2162
#define MCF_CLOCK_SYNCR_LOLRE (0x8000)
2163
2164
/* Bit definitions and macros for MCF_CLOCK_SYNSR */
2165
#define MCF_CLOCK_SYNSR_LOCS (0x04)
2166
#define MCF_CLOCK_SYNSR_LOCK (0x08)
2167
#define MCF_CLOCK_SYNSR_LOCKS (0x10)
2168
#define MCF_CLOCK_SYNSR_CRYOSC (0x20)
2169
#define MCF_CLOCK_SYNSR_OCOSC (0x40)
2170
#define MCF_CLOCK_SYNSR_EXTOSC (0x80)
2171
2172
/* Bit definitions and macros for MCF_CLOCK_LPCR */
2173
#define MCF_CLOCK_LPCR_LPD(x) (((x)&0x0F)<<0)
2174
2175
/* Bit definitions and macros for MCF_CLOCK_CCHR */
2176
#define MCF_CLOCK_CCHR_PFD(x) (((x)&0x07)<<0)
2177
2178
/* Bit definitions and macros for MCF_CLOCK_RTCDR */
2179
#define MCF_CLOCK_RTCDR_RTCDF(x) (((x)&0xFFFFFFFF)<<0)
2180
2181
2182
2183
* Edge Port Module (EPORT)
2184
2185
2186
2187
2188
#define MCF_EPORT_EPPAR0 (*(vuint16*)(&__IPSBAR[0x130000]))
2189
#define MCF_EPORT_EPPAR1 (*(vuint16*)(&__IPSBAR[0x140000]))
2190
#define MCF_EPORT_EPDDR0 (*(vuint8 *)(&__IPSBAR[0x130002]))
2191
#define MCF_EPORT_EPDDR1 (*(vuint8 *)(&__IPSBAR[0x140002]))
2192
#define MCF_EPORT_EPIER0 (*(vuint8 *)(&__IPSBAR[0x130003]))
2193
#define MCF_EPORT_EPIER1 (*(vuint8 *)(&__IPSBAR[0x140003]))
2194
#define MCF_EPORT_EPDR0 (*(vuint8 *)(&__IPSBAR[0x130004]))
2195
#define MCF_EPORT_EPDR1 (*(vuint8 *)(&__IPSBAR[0x140004]))
2196
#define MCF_EPORT_EPPDR0 (*(vuint8 *)(&__IPSBAR[0x130005]))
2197
#define MCF_EPORT_EPPDR1 (*(vuint8 *)(&__IPSBAR[0x140005]))
2198
#define MCF_EPORT_EPFR0 (*(vuint8 *)(&__IPSBAR[0x130006]))
2199
#define MCF_EPORT_EPFR1 (*(vuint8 *)(&__IPSBAR[0x140006]))
2200
2201
/* Bit definitions and macros for MCF_EPORT_EPPAR */
2202
#define MCF_EPORT_EPPAR_EPPA1(x) (((x)&0x0003)<<2)
2203
#define MCF_EPORT_EPPAR_EPPA2(x) (((x)&0x0003)<<4)
2204
#define MCF_EPORT_EPPAR_EPPA3(x) (((x)&0x0003)<<6)
2205
#define MCF_EPORT_EPPAR_EPPA4(x) (((x)&0x0003)<<8)
2206
#define MCF_EPORT_EPPAR_EPPA5(x) (((x)&0x0003)<<10)
2207
#define MCF_EPORT_EPPAR_EPPA6(x) (((x)&0x0003)<<12)
2208
#define MCF_EPORT_EPPAR_EPPA7(x) (((x)&0x0003)<<14)
2209
#define MCF_EPORT_EPPAR_EPPA8(x) (((x)&0x0003)<<0)
2210
#define MCF_EPORT_EPPAR_EPPA9(x) (((x)&0x0003)<<2)
2211
#define MCF_EPORT_EPPAR_EPPA10(x) (((x)&0x0003)<<4)
2212
#define MCF_EPORT_EPPAR_EPPA11(x) (((x)&0x0003)<<6)
2213
#define MCF_EPORT_EPPAR_EPPA12(x) (((x)&0x0003)<<8)
2214
#define MCF_EPORT_EPPAR_EPPA13(x) (((x)&0x0003)<<10)
2215
#define MCF_EPORT_EPPAR_EPPA14(x) (((x)&0x0003)<<12)
2216
#define MCF_EPORT_EPPAR_EPPA15(x) (((x)&0x0003)<<14)
2217
#define MCF_EPORT_EPPAR_LEVEL (0)
2218
#define MCF_EPORT_EPPAR_RISING (1)
2219
#define MCF_EPORT_EPPAR_FALLING (2)
2220
#define MCF_EPORT_EPPAR_BOTH (3)
2221
#define MCF_EPORT_EPPAR_EPPA15_LEVEL (0x0000)
2222
#define MCF_EPORT_EPPAR_EPPA15_RISING (0x4000)
2223
#define MCF_EPORT_EPPAR_EPPA15_FALLING (0x8000)
2224
#define MCF_EPORT_EPPAR_EPPA15_BOTH (0xC000)
2225
#define MCF_EPORT_EPPAR_EPPA14_LEVEL (0x0000)
2226
#define MCF_EPORT_EPPAR_EPPA14_RISING (0x1000)
2227
#define MCF_EPORT_EPPAR_EPPA14_FALLING (0x2000)
2228
#define MCF_EPORT_EPPAR_EPPA14_BOTH (0x3000)
2229
#define MCF_EPORT_EPPAR_EPPA13_LEVEL (0x0000)
2230
#define MCF_EPORT_EPPAR_EPPA13_RISING (0x0400)
2231
#define MCF_EPORT_EPPAR_EPPA13_FALLING (0x0800)
2232
#define MCF_EPORT_EPPAR_EPPA13_BOTH (0x0C00)
2233
#define MCF_EPORT_EPPAR_EPPA12_LEVEL (0x0000)
2234
#define MCF_EPORT_EPPAR_EPPA12_RISING (0x0100)
2235
#define MCF_EPORT_EPPAR_EPPA12_FALLING (0x0200)
2236
#define MCF_EPORT_EPPAR_EPPA12_BOTH (0x0300)
2237
#define MCF_EPORT_EPPAR_EPPA11_LEVEL (0x0000)
2238
#define MCF_EPORT_EPPAR_EPPA11_RISING (0x0040)
2239
#define MCF_EPORT_EPPAR_EPPA11_FALLING (0x0080)
2240
#define MCF_EPORT_EPPAR_EPPA11_BOTH (0x00C0)
2241
#define MCF_EPORT_EPPAR_EPPA10_LEVEL (0x0000)
2242
#define MCF_EPORT_EPPAR_EPPA10_RISING (0x0010)
2243
#define MCF_EPORT_EPPAR_EPPA10_FALLING (0x0020)
2244
#define MCF_EPORT_EPPAR_EPPA10_BOTH (0x0030)
2245
#define MCF_EPORT_EPPAR_EPPA9_LEVEL (0x0000)
2246
#define MCF_EPORT_EPPAR_EPPA9_RISING (0x0004)
2247
#define MCF_EPORT_EPPAR_EPPA9_FALLING (0x0008)
2248
#define MCF_EPORT_EPPAR_EPPA9_BOTH (0x000C)
2249
#define MCF_EPORT_EPPAR_EPPA8_LEVEL (0x0000)
2250
#define MCF_EPORT_EPPAR_EPPA8_RISING (0x0001)
2251
#define MCF_EPORT_EPPAR_EPPA8_FALLING (0x0002)
2252
#define MCF_EPORT_EPPAR_EPPA8_BOTH (0x0003)
2253
#define MCF_EPORT_EPPAR_EPPA7_LEVEL (0x0000)
2254
#define MCF_EPORT_EPPAR_EPPA7_RISING (0x4000)
2255
#define MCF_EPORT_EPPAR_EPPA7_FALLING (0x8000)
2256
#define MCF_EPORT_EPPAR_EPPA7_BOTH (0xC000)
2257
#define MCF_EPORT_EPPAR_EPPA6_LEVEL (0x0000)
2258
#define MCF_EPORT_EPPAR_EPPA6_RISING (0x1000)
2259
#define MCF_EPORT_EPPAR_EPPA6_FALLING (0x2000)
2260
#define MCF_EPORT_EPPAR_EPPA6_BOTH (0x3000)
2261
#define MCF_EPORT_EPPAR_EPPA5_LEVEL (0x0000)
2262
#define MCF_EPORT_EPPAR_EPPA5_RISING (0x0400)
2263
#define MCF_EPORT_EPPAR_EPPA5_FALLING (0x0800)
2264
#define MCF_EPORT_EPPAR_EPPA5_BOTH (0x0C00)
2265
#define MCF_EPORT_EPPAR_EPPA4_LEVEL (0x0000)
2266
#define MCF_EPORT_EPPAR_EPPA4_RISING (0x0100)
2267
#define MCF_EPORT_EPPAR_EPPA4_FALLING (0x0200)
2268
#define MCF_EPORT_EPPAR_EPPA4_BOTH (0x0300)
2269
#define MCF_EPORT_EPPAR_EPPA3_LEVEL (0x0000)
2270
#define MCF_EPORT_EPPAR_EPPA3_RISING (0x0040)
2271
#define MCF_EPORT_EPPAR_EPPA3_FALLING (0x0080)
2272
#define MCF_EPORT_EPPAR_EPPA3_BOTH (0x00C0)
2273
#define MCF_EPORT_EPPAR_EPPA2_LEVEL (0x0000)
2274
#define MCF_EPORT_EPPAR_EPPA2_RISING (0x0010)
2275
#define MCF_EPORT_EPPAR_EPPA2_FALLING (0x0020)
2276
#define MCF_EPORT_EPPAR_EPPA2_BOTH (0x0030)
2277
#define MCF_EPORT_EPPAR_EPPA1_LEVEL (0x0000)
2278
#define MCF_EPORT_EPPAR_EPPA1_RISING (0x0004)
2279
#define MCF_EPORT_EPPAR_EPPA1_FALLING (0x0008)
2280
#define MCF_EPORT_EPPAR_EPPA1_BOTH (0x000C)
2281
2282
/* Bit definitions and macros for MCF_EPORT_EPDDR */
2283
#define MCF_EPORT_EPDDR_EPDD1 (0x02)
2284
#define MCF_EPORT_EPDDR_EPDD2 (0x04)
2285
#define MCF_EPORT_EPDDR_EPDD3 (0x08)
2286
#define MCF_EPORT_EPDDR_EPDD4 (0x10)
2287
#define MCF_EPORT_EPDDR_EPDD5 (0x20)
2288
#define MCF_EPORT_EPDDR_EPDD6 (0x40)
2289
#define MCF_EPORT_EPDDR_EPDD7 (0x80)
2290
#define MCF_EPORT_EPDDR_EPDD8 (0x01)
2291
#define MCF_EPORT_EPDDR_EPDD9 (0x02)
2292
#define MCF_EPORT_EPDDR_EPDD10 (0x04)
2293
#define MCF_EPORT_EPDDR_EPDD11 (0x08)
2294
#define MCF_EPORT_EPDDR_EPDD12 (0x10)
2295
#define MCF_EPORT_EPDDR_EPDD13 (0x20)
2296
#define MCF_EPORT_EPDDR_EPDD14 (0x40)
2297
#define MCF_EPORT_EPDDR_EPDD15 (0x80)
2298
2299
/* Bit definitions and macros for MCF_EPORT_EPIER */
2300
#define MCF_EPORT_EPIER_EPIE1 (0x02)
2301
#define MCF_EPORT_EPIER_EPIE2 (0x04)
2302
#define MCF_EPORT_EPIER_EPIE3 (0x08)
2303
#define MCF_EPORT_EPIER_EPIE4 (0x10)
2304
#define MCF_EPORT_EPIER_EPIE5 (0x20)
2305
#define MCF_EPORT_EPIER_EPIE6 (0x40)
2306
#define MCF_EPORT_EPIER_EPIE7 (0x80)
2307
#define MCF_EPORT_EPIER_EPIE8 (0x01)
2308
#define MCF_EPORT_EPIER_EPIE9 (0x02)
2309
#define MCF_EPORT_EPIER_EPIE10 (0x04)
2310
#define MCF_EPORT_EPIER_EPIE11 (0x08)
2311
#define MCF_EPORT_EPIER_EPIE12 (0x10)
2312
#define MCF_EPORT_EPIER_EPIE13 (0x20)
2313
#define MCF_EPORT_EPIER_EPIE14 (0x40)
2314
#define MCF_EPORT_EPIER_EPIE15 (0x80)
2315
2316
/* Bit definitions and macros for MCF_EPORT_EPDR */
2317
#define MCF_EPORT_EPDR_EPD1 (0x02)
2318
#define MCF_EPORT_EPDR_EPD2 (0x04)
2319
#define MCF_EPORT_EPDR_EPD3 (0x08)
2320
#define MCF_EPORT_EPDR_EPD4 (0x10)
2321
#define MCF_EPORT_EPDR_EPD5 (0x20)
2322
#define MCF_EPORT_EPDR_EPD6 (0x40)
2323
#define MCF_EPORT_EPDR_EPD7 (0x80)
2324
#define MCF_EPORT_EPDR_EPD8 (0x01)
2325
#define MCF_EPORT_EPDR_EPD9 (0x02)
2326
#define MCF_EPORT_EPDR_EPD10 (0x04)
2327
#define MCF_EPORT_EPDR_EPD11 (0x08)
2328
#define MCF_EPORT_EPDR_EPD12 (0x10)
2329
#define MCF_EPORT_EPDR_EPD13 (0x20)
2330
#define MCF_EPORT_EPDR_EPD14 (0x40)
2331
#define MCF_EPORT_EPDR_EPD15 (0x80)
2332
2333
/* Bit definitions and macros for MCF_EPORT_EPPDR */
2334
#define MCF_EPORT_EPPDR_EPPD1 (0x02)
2335
#define MCF_EPORT_EPPDR_EPPD2 (0x04)
2336
#define MCF_EPORT_EPPDR_EPPD3 (0x08)
2337
#define MCF_EPORT_EPPDR_EPPD4 (0x10)
2338
#define MCF_EPORT_EPPDR_EPPD5 (0x20)
2339
#define MCF_EPORT_EPPDR_EPPD6 (0x40)
2340
#define MCF_EPORT_EPPDR_EPPD7 (0x80)
2341
#define MCF_EPORT_EPPDR_EPPD8 (0x01)
2342
#define MCF_EPORT_EPPDR_EPPD9 (0x02)
2343
#define MCF_EPORT_EPPDR_EPPD10 (0x04)
2344
#define MCF_EPORT_EPPDR_EPPD11 (0x08)
2345
#define MCF_EPORT_EPPDR_EPPD12 (0x10)
2346
#define MCF_EPORT_EPPDR_EPPD13 (0x20)
2347
#define MCF_EPORT_EPPDR_EPPD14 (0x40)
2348
#define MCF_EPORT_EPPDR_EPPD15 (0x80)
2349
2350
/* Bit definitions and macros for MCF_EPORT_EPFR */
2351
#define MCF_EPORT_EPFR_EPF1 (0x02)
2352
#define MCF_EPORT_EPFR_EPF2 (0x04)
2353
#define MCF_EPORT_EPFR_EPF3 (0x08)
2354
#define MCF_EPORT_EPFR_EPF4 (0x10)
2355
#define MCF_EPORT_EPFR_EPF5 (0x20)
2356
#define MCF_EPORT_EPFR_EPF6 (0x40)
2357
#define MCF_EPORT_EPFR_EPF7 (0x80)
2358
#define MCF_EPORT_EPFR_EPF8 (0x01)
2359
#define MCF_EPORT_EPFR_EPF9 (0x02)
2360
#define MCF_EPORT_EPFR_EPF10 (0x04)
2361
#define MCF_EPORT_EPFR_EPF11 (0x08)
2362
#define MCF_EPORT_EPFR_EPF12 (0x10)
2363
#define MCF_EPORT_EPFR_EPF13 (0x20)
2364
#define MCF_EPORT_EPFR_EPF14 (0x40)
2365
#define MCF_EPORT_EPFR_EPF15 (0x80)
2366
2367
2368
2369
* Programmable Interrupt Timer Modules (PIT)
2370
2371
2372
2373
2374
#define MCF_PIT0_PCSR (*(vuint16*)(&__IPSBAR[0x150000]))
2375
#define MCF_PIT0_PMR (*(vuint16*)(&__IPSBAR[0x150002]))
2376
#define MCF_PIT0_PCNTR (*(vuint16*)(&__IPSBAR[0x150004]))
2377
#define MCF_PIT1_PCSR (*(vuint16*)(&__IPSBAR[0x160000]))
2378
#define MCF_PIT1_PMR (*(vuint16*)(&__IPSBAR[0x160002]))
2379
#define MCF_PIT1_PCNTR (*(vuint16*)(&__IPSBAR[0x160004]))
2380
#define MCF_PIT_PCSR(x) (*(vuint16*)(&__IPSBAR[0x150000+((x)*0x10000)]))
2381
#define MCF_PIT_PMR(x) (*(vuint16*)(&__IPSBAR[0x150002+((x)*0x10000)]))
2382
#define MCF_PIT_PCNTR(x) (*(vuint16*)(&__IPSBAR[0x150004+((x)*0x10000)]))
2383
2384
/* Bit definitions and macros for MCF_PIT_PCSR */
2385
#define MCF_PIT_PCSR_EN (0x0001)
2386
#define MCF_PIT_PCSR_RLD (0x0002)
2387
#define MCF_PIT_PCSR_PIF (0x0004)
2388
#define MCF_PIT_PCSR_PIE (0x0008)
2389
#define MCF_PIT_PCSR_OVW (0x0010)
2390
#define MCF_PIT_PCSR_HALTED (0x0020)
2391
#define MCF_PIT_PCSR_DOZE (0x0040)
2392
#define MCF_PIT_PCSR_PRE(x) (((x)&0x000F)<<8)
2393
2394
/* Bit definitions and macros for MCF_PIT_PMR */
2395
#define MCF_PIT_PMR_PM(x) (((x)&0xFFFF)<<0)
2396
2397
/* Bit definitions and macros for MCF_PIT_PCNTR */
2398
#define MCF_PIT_PCNTR_PC(x) (((x)&0xFFFF)<<0)
2399
2400
2401
2402
* Analog-to-Digital Converter (ADC)
2403
2404
2405
2406
2407
#define MCF_ADC_CTRL1 (*(vuint16*)(&__IPSBAR[0x190000]))
2408
#define MCF_ADC_CTRL2 (*(vuint16*)(&__IPSBAR[0x190002]))
2409
#define MCF_ADC_ADZCC (*(vuint16*)(&__IPSBAR[0x190004]))
2410
#define MCF_ADC_ADLST1 (*(vuint16*)(&__IPSBAR[0x190006]))
2411
#define MCF_ADC_ADLST2 (*(vuint16*)(&__IPSBAR[0x190008]))
2412
#define MCF_ADC_ADSDIS (*(vuint16*)(&__IPSBAR[0x19000A]))
2413
#define MCF_ADC_ADSTAT (*(vuint16*)(&__IPSBAR[0x19000C]))
2414
#define MCF_ADC_ADLSTAT (*(vuint16*)(&__IPSBAR[0x19000E]))
2415
#define MCF_ADC_ADZCSTAT (*(vuint16*)(&__IPSBAR[0x190010]))
2416
#define MCF_ADC_ADRSLT0 (*(vuint16*)(&__IPSBAR[0x190012]))
2417
#define MCF_ADC_ADRSLT1 (*(vuint16*)(&__IPSBAR[0x190014]))
2418
#define MCF_ADC_ADRSLT2 (*(vuint16*)(&__IPSBAR[0x190016]))
2419
#define MCF_ADC_ADRSLT3 (*(vuint16*)(&__IPSBAR[0x190018]))
2420
#define MCF_ADC_ADRSLT4 (*(vuint16*)(&__IPSBAR[0x19001A]))
2421
#define MCF_ADC_ADRSLT5 (*(vuint16*)(&__IPSBAR[0x19001C]))
2422
#define MCF_ADC_ADRSLT6 (*(vuint16*)(&__IPSBAR[0x19001E]))
2423
#define MCF_ADC_ADRSLT7 (*(vuint16*)(&__IPSBAR[0x190020]))
2424
#define MCF_ADC_ADRSLT(x) (*(vuint16*)(&__IPSBAR[0x190012+((x)*0x002)]))
2425
#define MCF_ADC_ADLLMT0 (*(vuint16*)(&__IPSBAR[0x190022]))
2426
#define MCF_ADC_ADLLMT1 (*(vuint16*)(&__IPSBAR[0x190024]))
2427
#define MCF_ADC_ADLLMT2 (*(vuint16*)(&__IPSBAR[0x190026]))
2428
#define MCF_ADC_ADLLMT3 (*(vuint16*)(&__IPSBAR[0x190028]))
2429
#define MCF_ADC_ADLLMT4 (*(vuint16*)(&__IPSBAR[0x19002A]))
2430
#define MCF_ADC_ADLLMT5 (*(vuint16*)(&__IPSBAR[0x19002C]))
2431
#define MCF_ADC_ADLLMT6 (*(vuint16*)(&__IPSBAR[0x19002E]))
2432
#define MCF_ADC_ADLLMT7 (*(vuint16*)(&__IPSBAR[0x190030]))
2433
#define MCF_ADC_ADLLMT(x) (*(vuint16*)(&__IPSBAR[0x190022+((x)*0x002)]))
2434
#define MCF_ADC_ADHLMT0 (*(vuint16*)(&__IPSBAR[0x190032]))
2435
#define MCF_ADC_ADHLMT1 (*(vuint16*)(&__IPSBAR[0x190034]))
2436
#define MCF_ADC_ADHLMT2 (*(vuint16*)(&__IPSBAR[0x190036]))
2437
#define MCF_ADC_ADHLMT3 (*(vuint16*)(&__IPSBAR[0x190038]))
2438
#define MCF_ADC_ADHLMT4 (*(vuint16*)(&__IPSBAR[0x19003A]))
2439
#define MCF_ADC_ADHLMT5 (*(vuint16*)(&__IPSBAR[0x19003C]))
2440
#define MCF_ADC_ADHLMT6 (*(vuint16*)(&__IPSBAR[0x19003E]))
2441
#define MCF_ADC_ADHLMT7 (*(vuint16*)(&__IPSBAR[0x190040]))
2442
#define MCF_ADC_ADHLMT(x) (*(vuint16*)(&__IPSBAR[0x190032+((x)*0x002)]))
2443
#define MCF_ADC_ADOFS0 (*(vuint16*)(&__IPSBAR[0x190042]))
2444
#define MCF_ADC_ADOFS1 (*(vuint16*)(&__IPSBAR[0x190044]))
2445
#define MCF_ADC_ADOFS2 (*(vuint16*)(&__IPSBAR[0x190046]))
2446
#define MCF_ADC_ADOFS3 (*(vuint16*)(&__IPSBAR[0x190048]))
2447
#define MCF_ADC_ADOFS4 (*(vuint16*)(&__IPSBAR[0x19004A]))
2448
#define MCF_ADC_ADOFS5 (*(vuint16*)(&__IPSBAR[0x19004C]))
2449
#define MCF_ADC_ADOFS6 (*(vuint16*)(&__IPSBAR[0x19004E]))
2450
#define MCF_ADC_ADOFS7 (*(vuint16*)(&__IPSBAR[0x190050]))
2451
#define MCF_ADC_ADOFS(x) (*(vuint16*)(&__IPSBAR[0x190042+((x)*0x002)]))
2452
#define MCF_ADC_POWER (*(vuint16*)(&__IPSBAR[0x190052]))
2453
#define MCF_ADC_CAL (*(vuint16*)(&__IPSBAR[0x190054]))
2454
2455
/* Bit definitions and macros for MCF_ADC_CTRL1 */
2456
#define MCF_ADC_CTRL1_SMODE(x) (((x)&0x0007)<<0)
2457
#define MCF_ADC_CTRL1_CHNCFG(x) (((x)&0x000F)<<4)
2458
#define MCF_ADC_CTRL1_HLMTIE (0x0100)
2459
#define MCF_ADC_CTRL1_LLMTIE (0x0200)
2460
#define MCF_ADC_CTRL1_ZCIE (0x0400)
2461
#define MCF_ADC_CTRL1_EOSIE0 (0x0800)
2462
#define MCF_ADC_CTRL1_SYNC0 (0x1000)
2463
#define MCF_ADC_CTRL1_START0 (0x2000)
2464
#define MCF_ADC_CTRL1_STOP0 (0x4000)
2465
2466
/* Bit definitions and macros for MCF_ADC_CTRL2 */
2467
#define MCF_ADC_CTRL2_DIV(x) (((x)&0x001F)<<0)
2468
#define MCF_ADC_CTRL2_SIMULT (0x0020)
2469
#define MCF_ADC_CTRL2_EOSIE1 (0x0800)
2470
#define MCF_ADC_CTRL2_SYNC1 (0x1000)
2471
#define MCF_ADC_CTRL2_START1 (0x2000)
2472
#define MCF_ADC_CTRL2_STOP1 (0x4000)
2473
2474
/* Bit definitions and macros for MCF_ADC_ADZCC */
2475
#define MCF_ADC_ADZCC_ZCE0(x) (((x)&0x0003)<<0)
2476
#define MCF_ADC_ADZCC_ZCE1(x) (((x)&0x0003)<<2)
2477
#define MCF_ADC_ADZCC_ZCE2(x) (((x)&0x0003)<<4)
2478
#define MCF_ADC_ADZCC_ZCE3(x) (((x)&0x0003)<<6)
2479
#define MCF_ADC_ADZCC_ZCE4(x) (((x)&0x0003)<<8)
2480
#define MCF_ADC_ADZCC_ZCE5(x) (((x)&0x0003)<<10)
2481
#define MCF_ADC_ADZCC_ZCE6(x) (((x)&0x0003)<<12)
2482
#define MCF_ADC_ADZCC_ZCE7(x) (((x)&0x0003)<<14)
2483
2484
/* Bit definitions and macros for MCF_ADC_ADLST1 */
2485
#define MCF_ADC_ADLST1_SAMPLE0(x) (((x)&0x0007)<<0)
2486
#define MCF_ADC_ADLST1_SAMPLE1(x) (((x)&0x0007)<<4)
2487
#define MCF_ADC_ADLST1_SAMPLE2(x) (((x)&0x0007)<<8)
2488
#define MCF_ADC_ADLST1_SAMPLE3(x) (((x)&0x0007)<<12)
2489
2490
/* Bit definitions and macros for MCF_ADC_ADLST2 */
2491
#define MCF_ADC_ADLST2_SAMPLE4(x) (((x)&0x0007)<<0)
2492
#define MCF_ADC_ADLST2_SAMPLE5(x) (((x)&0x0007)<<4)
2493
#define MCF_ADC_ADLST2_SAMPLE6(x) (((x)&0x0007)<<8)
2494
#define MCF_ADC_ADLST2_SAMPLE7(x) (((x)&0x0007)<<12)
2495
2496
/* Bit definitions and macros for MCF_ADC_ADSDIS */
2497
#define MCF_ADC_ADSDIS_DS0 (0x0001)
2498
#define MCF_ADC_ADSDIS_DS1 (0x0002)
2499
#define MCF_ADC_ADSDIS_DS2 (0x0004)
2500
#define MCF_ADC_ADSDIS_DS3 (0x0008)
2501
#define MCF_ADC_ADSDIS_DS4 (0x0010)
2502
#define MCF_ADC_ADSDIS_DS5 (0x0020)
2503
#define MCF_ADC_ADSDIS_DS6 (0x0040)
2504
#define MCF_ADC_ADSDIS_DS7 (0x0080)
2505
2506
/* Bit definitions and macros for MCF_ADC_ADSTAT */
2507
#define MCF_ADC_ADSTAT_RDY0 (0x0001)
2508
#define MCF_ADC_ADSTAT_RDY1 (0x0002)
2509
#define MCF_ADC_ADSTAT_RDY2 (0x0004)
2510
#define MCF_ADC_ADSTAT_RDY3 (0x0008)
2511
#define MCF_ADC_ADSTAT_RDY4 (0x0010)
2512
#define MCF_ADC_ADSTAT_RDY5 (0x0020)
2513
#define MCF_ADC_ADSTAT_RDY6 (0x0040)
2514
#define MCF_ADC_ADSTAT_RDY7 (0x0080)
2515
#define MCF_ADC_ADSTAT_HLMT (0x0100)
2516
#define MCF_ADC_ADSTAT_LLMTI (0x0200)
2517
#define MCF_ADC_ADSTAT_ZCI (0x0400)
2518
#define MCF_ADC_ADSTAT_EOSI (0x0800)
2519
#define MCF_ADC_ADSTAT_CIP (0x8000)
2520
2521
/* Bit definitions and macros for MCF_ADC_ADLSTAT */
2522
#define MCF_ADC_ADLSTAT_LLS0 (0x0001)
2523
#define MCF_ADC_ADLSTAT_LLS1 (0x0002)
2524
#define MCF_ADC_ADLSTAT_LLS2 (0x0004)
2525
#define MCF_ADC_ADLSTAT_LLS3 (0x0008)
2526
#define MCF_ADC_ADLSTAT_LLS4 (0x0010)
2527
#define MCF_ADC_ADLSTAT_LLS5 (0x0020)
2528
#define MCF_ADC_ADLSTAT_LLS6 (0x0040)
2529
#define MCF_ADC_ADLSTAT_LLS7 (0x0080)
2530
#define MCF_ADC_ADLSTAT_HLS0 (0x0100)
2531
#define MCF_ADC_ADLSTAT_HLS1 (0x0200)
2532
#define MCF_ADC_ADLSTAT_HLS2 (0x0400)
2533
#define MCF_ADC_ADLSTAT_HLS3 (0x0800)
2534
#define MCF_ADC_ADLSTAT_HLS4 (0x1000)
2535
#define MCF_ADC_ADLSTAT_HLS5 (0x2000)
2536
#define MCF_ADC_ADLSTAT_HLS6 (0x4000)
2537
#define MCF_ADC_ADLSTAT_HLS7 (0x8000)
2538
2539
/* Bit definitions and macros for MCF_ADC_ADZCSTAT */
2540
#define MCF_ADC_ADZCSTAT_ZCS0 (0x0001)
2541
#define MCF_ADC_ADZCSTAT_ZCS1 (0x0002)
2542
#define MCF_ADC_ADZCSTAT_ZCS2 (0x0004)
2543
#define MCF_ADC_ADZCSTAT_ZCS3 (0x0008)
2544
#define MCF_ADC_ADZCSTAT_ZCS4 (0x0010)
2545
#define MCF_ADC_ADZCSTAT_ZCS5 (0x0020)
2546
#define MCF_ADC_ADZCSTAT_ZCS6 (0x0040)
2547
#define MCF_ADC_ADZCSTAT_ZCS7 (0x0080)
2548
2549
/* Bit definitions and macros for MCF_ADC_ADRSLT */
2550
#define MCF_ADC_ADRSLT_RSLT(x) (((x)&0x0FFF)<<3)
2551
#define MCF_ADC_ADRSLT_SEXT (0x8000)
2552
2553
/* Bit definitions and macros for MCF_ADC_ADLLMT */
2554
#define MCF_ADC_ADLLMT_LLMT(x) (((x)&0x0FFF)<<3)
2555
2556
/* Bit definitions and macros for MCF_ADC_ADHLMT */
2557
#define MCF_ADC_ADHLMT_HLMT(x) (((x)&0x0FFF)<<3)
2558
2559
/* Bit definitions and macros for MCF_ADC_ADOFS */
2560
#define MCF_ADC_ADOFS_OFFSET(x) (((x)&0x0FFF)<<3)
2561
2562
/* Bit definitions and macros for MCF_ADC_POWER */
2563
#define MCF_ADC_POWER_PD0 (0x0001)
2564
#define MCF_ADC_POWER_PD1 (0x0002)
2565
#define MCF_ADC_POWER_PD2 (0x0004)
2566
#define MCF_ADC_POWER_APD (0x0008)
2567
#define MCF_ADC_POWER_PUDELAY(x) (((x)&0x003F)<<4)
2568
#define MCF_ADC_POWER_PSTS0 (0x0400)
2569
#define MCF_ADC_POWER_PSTS1 (0x0800)
2570
#define MCF_ADC_POWER_PSTS2 (0x1000)
2571
#define MCF_ADC_POWER_ASTBY (0x8000)
2572
2573
/* Bit definitions and macros for MCF_ADC_CAL */
2574
#define MCF_ADC_CAL_CAL0 (0x0001)
2575
#define MCF_ADC_CAL_CRS0 (0x0002)
2576
#define MCF_ADC_CAL_CAL1 (0x0004)
2577
#define MCF_ADC_CAL_CRS1 (0x0008)
2578
2579
2580
2581
* General Purpose Timer (GPT)
2582
2583
2584
2585
2586
#define MCF_GPT_GPTIOS (*(vuint8 *)(&__IPSBAR[0x1A0000]))
2587
#define MCF_GPT_GPTCFORC (*(vuint8 *)(&__IPSBAR[0x1A0001]))
2588
#define MCF_GPT_GPTOC3M (*(vuint8 *)(&__IPSBAR[0x1A0002]))
2589
#define MCF_GPT_GPTOC3D (*(vuint8 *)(&__IPSBAR[0x1A0003]))
2590
#define MCF_GPT_GPTCNT (*(vuint16*)(&__IPSBAR[0x1A0004]))
2591
#define MCF_GPT_GPTSCR1 (*(vuint8 *)(&__IPSBAR[0x1A0006]))
2592
#define MCF_GPT_GPTTOV (*(vuint8 *)(&__IPSBAR[0x1A0008]))
2593
#define MCF_GPT_GPTCTL1 (*(vuint8 *)(&__IPSBAR[0x1A0009]))
2594
#define MCF_GPT_GPTCTL2 (*(vuint8 *)(&__IPSBAR[0x1A000B]))
2595
#define MCF_GPT_GPTIE (*(vuint8 *)(&__IPSBAR[0x1A000C]))
2596
#define MCF_GPT_GPTSCR2 (*(vuint8 *)(&__IPSBAR[0x1A000D]))
2597
#define MCF_GPT_GPTFLG1 (*(vuint8 *)(&__IPSBAR[0x1A000E]))
2598
#define MCF_GPT_GPTFLG2 (*(vuint8 *)(&__IPSBAR[0x1A000F]))
2599
#define MCF_GPT_GPTC0 (*(vuint16*)(&__IPSBAR[0x1A0010]))
2600
#define MCF_GPT_GPTC1 (*(vuint16*)(&__IPSBAR[0x1A0012]))
2601
#define MCF_GPT_GPTC2 (*(vuint16*)(&__IPSBAR[0x1A0014]))
2602
#define MCF_GPT_GPTC3 (*(vuint16*)(&__IPSBAR[0x1A0016]))
2603
#define MCF_GPT_GPTC(x) (*(vuint16*)(&__IPSBAR[0x1A0010+((x)*0x002)]))
2604
#define MCF_GPT_GPTPACTL (*(vuint8 *)(&__IPSBAR[0x1A0018]))
2605
#define MCF_GPT_GPTPAFLG (*(vuint8 *)(&__IPSBAR[0x1A0019]))
2606
#define MCF_GPT_GPTPACNT (*(vuint16*)(&__IPSBAR[0x1A001A]))
2607
#define MCF_GPT_GPTPORT (*(vuint8 *)(&__IPSBAR[0x1A001D]))
2608
#define MCF_GPT_GPTDDR (*(vuint8 *)(&__IPSBAR[0x1A001E]))
2609
2610
/* Bit definitions and macros for MCF_GPT_GPTIOS */
2611
#define MCF_GPT_GPTIOS_IOS0 (0x01)
2612
#define MCF_GPT_GPTIOS_IOS1 (0x02)
2613
#define MCF_GPT_GPTIOS_IOS2 (0x04)
2614
#define MCF_GPT_GPTIOS_IOS3 (0x08)
2615
2616
/* Bit definitions and macros for MCF_GPT_GPTCFORC */
2617
#define MCF_GPT_GPTCFORC_FOC0 (0x01)
2618
#define MCF_GPT_GPTCFORC_FOC1 (0x02)
2619
#define MCF_GPT_GPTCFORC_FOC2 (0x04)
2620
#define MCF_GPT_GPTCFORC_FOC3 (0x08)
2621
2622
/* Bit definitions and macros for MCF_GPT_GPTOC3D */
2623
#define MCF_GPT_GPTOC3D_OC3D0 (0x01)
2624
#define MCF_GPT_GPTOC3D_OC3D1 (0x02)
2625
#define MCF_GPT_GPTOC3D_OC3D2 (0x04)
2626
#define MCF_GPT_GPTOC3D_OC3D3 (0x08)
2627
2628
/* Bit definitions and macros for MCF_GPT_GPTSCR1 */
2629
#define MCF_GPT_GPTSCR1_TFFCA (0x10)
2630
#define MCF_GPT_GPTSCR1_GPTEN (0x80)
2631
2632
/* Bit definitions and macros for MCF_GPT_GPTTOV */
2633
#define MCF_GPT_GPTTOV_TOV0 (0x01)
2634
#define MCF_GPT_GPTTOV_TOV1 (0x02)
2635
#define MCF_GPT_GPTTOV_TOV2 (0x04)
2636
#define MCF_GPT_GPTTOV_TOV3 (0x08)
2637
2638
/* Bit definitions and macros for MCF_GPT_GPTCTL1 */
2639
#define MCF_GPT_GPTCTL1_OL0 (0x01)
2640
#define MCF_GPT_GPTCTL1_OM0 (0x02)
2641
#define MCF_GPT_GPTCTL1_OL1 (0x04)
2642
#define MCF_GPT_GPTCTL1_OM1 (0x08)
2643
#define MCF_GPT_GPTCTL1_OL2 (0x10)
2644
#define MCF_GPT_GPTCTL1_OM2 (0x20)
2645
#define MCF_GPT_GPTCTL1_OL3 (0x40)
2646
#define MCF_GPT_GPTCTL1_OM3 (0x80)
2647
#define MCF_GPT_GPTCTL1_OUTPUT3_NOTHING ((0x00))
2648
#define MCF_GPT_GPTCTL1_OUTPUT3_TOGGLE ((0x40))
2649
#define MCF_GPT_GPTCTL1_OUTPUT3_CLEAR ((0x80))
2650
#define MCF_GPT_GPTCTL1_OUTPUT3_SET ((0xC0))
2651
#define MCF_GPT_GPTCTL1_OUTPUT2_NOTHING ((0x00))
2652
#define MCF_GPT_GPTCTL1_OUTPUT2_TOGGLE ((0x10))
2653
#define MCF_GPT_GPTCTL1_OUTPUT2_CLEAR ((0x20))
2654
#define MCF_GPT_GPTCTL1_OUTPUT2_SET ((0x30))
2655
#define MCF_GPT_GPTCTL1_OUTPUT1_NOTHING ((0x00))
2656
#define MCF_GPT_GPTCTL1_OUTPUT1_TOGGLE ((0x04))
2657
#define MCF_GPT_GPTCTL1_OUTPUT1_CLEAR ((0x08))
2658
#define MCF_GPT_GPTCTL1_OUTPUT1_SET ((0x0C))
2659
#define MCF_GPT_GPTCTL1_OUTPUT0_NOTHING ((0x00))
2660
#define MCF_GPT_GPTCTL1_OUTPUT0_TOGGLE ((0x01))
2661
#define MCF_GPT_GPTCTL1_OUTPUT0_CLEAR ((0x02))
2662
#define MCF_GPT_GPTCTL1_OUTPUT0_SET ((0x03))
2663
2664
/* Bit definitions and macros for MCF_GPT_GPTCTL2 */
2665
#define MCF_GPT_GPTCTL2_EDG0A (0x01)
2666
#define MCF_GPT_GPTCTL2_EDG0B (0x02)
2667
#define MCF_GPT_GPTCTL2_EDG1A (0x04)
2668
#define MCF_GPT_GPTCTL2_EDG1B (0x08)
2669
#define MCF_GPT_GPTCTL2_EDG2A (0x10)
2670
#define MCF_GPT_GPTCTL2_EDG2B (0x20)
2671
#define MCF_GPT_GPTCTL2_EDG3A (0x40)
2672
#define MCF_GPT_GPTCTL2_EDG3B (0x80)
2673
#define MCF_GPT_GPTCTL2_INPUT3_DISABLED ((0x00))
2674
#define MCF_GPT_GPTCTL2_INPUT3_RISING ((0x40))
2675
#define MCF_GPT_GPTCTL2_INPUT3_FALLING ((0x80))
2676
#define MCF_GPT_GPTCTL2_INPUT3_ANY ((0xC0))
2677
#define MCF_GPT_GPTCTL2_INPUT2_DISABLED ((0x00))
2678
#define MCF_GPT_GPTCTL2_INPUT2_RISING ((0x10))
2679
#define MCF_GPT_GPTCTL2_INPUT2_FALLING ((0x20))
2680
#define MCF_GPT_GPTCTL2_INPUT2_ANY ((0x30))
2681
#define MCF_GPT_GPTCTL2_INPUT1_DISABLED ((0x00))
2682
#define MCF_GPT_GPTCTL2_INPUT1_RISING ((0x04))
2683
#define MCF_GPT_GPTCTL2_INPUT1_FALLING ((0x08))
2684
#define MCF_GPT_GPTCTL2_INPUT1_ANY ((0x0C))
2685
#define MCF_GPT_GPTCTL2_INPUT0_DISABLED ((0x00))
2686
#define MCF_GPT_GPTCTL2_INPUT0_RISING ((0x01))
2687
#define MCF_GPT_GPTCTL2_INPUT0_FALLING ((0x02))
2688
#define MCF_GPT_GPTCTL2_INPUT0_ANY ((0x03))
2689
2690
/* Bit definitions and macros for MCF_GPT_GPTIE */
2691
#define MCF_GPT_GPTIE_CI0 (0x01)
2692
#define MCF_GPT_GPTIE_CI1 (0x02)
2693
#define MCF_GPT_GPTIE_CI2 (0x04)
2694
#define MCF_GPT_GPTIE_CI3 (0x08)
2695
2696
/* Bit definitions and macros for MCF_GPT_GPTSCR2 */
2697
#define MCF_GPT_GPTSCR2_PR(x) (((x)&0x07)<<0)
2698
#define MCF_GPT_GPTSCR2_TCRE (0x08)
2699
#define MCF_GPT_GPTSCR2_RDPT (0x10)
2700
#define MCF_GPT_GPTSCR2_PUPT (0x20)
2701
#define MCF_GPT_GPTSCR2_TOI (0x80)
2702
#define MCF_GPT_GPTSCR2_PR_1 ((0x00))
2703
#define MCF_GPT_GPTSCR2_PR_2 ((0x01))
2704
#define MCF_GPT_GPTSCR2_PR_4 ((0x02))
2705
#define MCF_GPT_GPTSCR2_PR_8 ((0x03))
2706
#define MCF_GPT_GPTSCR2_PR_16 ((0x04))
2707
#define MCF_GPT_GPTSCR2_PR_32 ((0x05))
2708
#define MCF_GPT_GPTSCR2_PR_64 ((0x06))
2709
#define MCF_GPT_GPTSCR2_PR_128 ((0x07))
2710
2711
/* Bit definitions and macros for MCF_GPT_GPTFLG1 */
2712
#define MCF_GPT_GPTFLG1_CF0 (0x01)
2713
#define MCF_GPT_GPTFLG1_CF1 (0x02)
2714
#define MCF_GPT_GPTFLG1_CF2 (0x04)
2715
#define MCF_GPT_GPTFLG1_CF3 (0x08)
2716
2717
/* Bit definitions and macros for MCF_GPT_GPTFLG2 */
2718
#define MCF_GPT_GPTFLG2_CF0 (0x01)
2719
#define MCF_GPT_GPTFLG2_CF1 (0x02)
2720
#define MCF_GPT_GPTFLG2_CF2 (0x04)
2721
#define MCF_GPT_GPTFLG2_CF3 (0x08)
2722
#define MCF_GPT_GPTFLG2_TOF (0x80)
2723
2724
/* Bit definitions and macros for MCF_GPT_GPTC */
2725
#define MCF_GPT_GPTC_CCNT(x) (((x)&0xFFFF)<<0)
2726
2727
/* Bit definitions and macros for MCF_GPT_GPTPACTL */
2728
#define MCF_GPT_GPTPACTL_PAI (0x01)
2729
#define MCF_GPT_GPTPACTL_PAOVI (0x02)
2730
#define MCF_GPT_GPTPACTL_CLK(x) (((x)&0x03)<<2)
2731
#define MCF_GPT_GPTPACTL_PEDGE (0x10)
2732
#define MCF_GPT_GPTPACTL_PAMOD (0x20)
2733
#define MCF_GPT_GPTPACTL_PAE (0x40)
2734
#define MCF_GPT_GPTPACTL_CLK_GPTPR ((0x00))
2735
#define MCF_GPT_GPTPACTL_CLK_PACLK ((0x01))
2736
#define MCF_GPT_GPTPACTL_CLK_PACLK_256 ((0x02))
2737
#define MCF_GPT_GPTPACTL_CLK_PACLK_65536 ((0x03))
2738
2739
/* Bit definitions and macros for MCF_GPT_GPTPAFLG */
2740
#define MCF_GPT_GPTPAFLG_PAIF (0x01)
2741
#define MCF_GPT_GPTPAFLG_PAOVF (0x02)
2742
2743
/* Bit definitions and macros for MCF_GPT_GPTPACNT */
2744
#define MCF_GPT_GPTPACNT_PACNT(x) (((x)&0xFFFF)<<0)
2745
2746
/* Bit definitions and macros for MCF_GPT_GPTPORT */
2747
#define MCF_GPT_GPTPORT_PORTT(x) (((x)&0x0F)<<0)
2748
2749
/* Bit definitions and macros for MCF_GPT_GPTDDR */
2750
#define MCF_GPT_GPTDDR_DDRT0 (0x01)
2751
#define MCF_GPT_GPTDDR_DDRT1 (0x02)
2752
#define MCF_GPT_GPTDDR_DDRT2 (0x04)
2753
#define MCF_GPT_GPTDDR_DDRT3 (0x08)
2754
2755
2756
2757
* Pulse Width Modulation (PWM)
2758
2759
2760
2761
2762
#define MCF_PWM_PWME (*(vuint8 *)(&__IPSBAR[0x1B0000]))
2763
#define MCF_PWM_PWMPOL (*(vuint8 *)(&__IPSBAR[0x1B0001]))
2764
#define MCF_PWM_PWMCLK (*(vuint8 *)(&__IPSBAR[0x1B0002]))
2765
#define MCF_PWM_PWMPRCLK (*(vuint8 *)(&__IPSBAR[0x1B0003]))
2766
#define MCF_PWM_PWMCAE (*(vuint8 *)(&__IPSBAR[0x1B0004]))
2767
#define MCF_PWM_PWMCTL (*(vuint8 *)(&__IPSBAR[0x1B0005]))
2768
#define MCF_PWM_PWMSCLA (*(vuint8 *)(&__IPSBAR[0x1B0008]))
2769
#define MCF_PWM_PWMSCLB (*(vuint8 *)(&__IPSBAR[0x1B0009]))
2770
#define MCF_PWM_PWMCNT0 (*(vuint8 *)(&__IPSBAR[0x1B000C]))
2771
#define MCF_PWM_PWMCNT1 (*(vuint8 *)(&__IPSBAR[0x1B000D]))
2772
#define MCF_PWM_PWMCNT2 (*(vuint8 *)(&__IPSBAR[0x1B000E]))
2773
#define MCF_PWM_PWMCNT3 (*(vuint8 *)(&__IPSBAR[0x1B000F]))
2774
#define MCF_PWM_PWMCNT4 (*(vuint8 *)(&__IPSBAR[0x1B0010]))
2775
#define MCF_PWM_PWMCNT5 (*(vuint8 *)(&__IPSBAR[0x1B0011]))
2776
#define MCF_PWM_PWMCNT6 (*(vuint8 *)(&__IPSBAR[0x1B0012]))
2777
#define MCF_PWM_PWMCNT7 (*(vuint8 *)(&__IPSBAR[0x1B0013]))
2778
#define MCF_PWM_PWMCNT(x) (*(vuint8 *)(&__IPSBAR[0x1B000C+((x)*0x001)]))
2779
#define MCF_PWM_PWMPER0 (*(vuint8 *)(&__IPSBAR[0x1B0014]))
2780
#define MCF_PWM_PWMPER1 (*(vuint8 *)(&__IPSBAR[0x1B0015]))
2781
#define MCF_PWM_PWMPER2 (*(vuint8 *)(&__IPSBAR[0x1B0016]))
2782
#define MCF_PWM_PWMPER3 (*(vuint8 *)(&__IPSBAR[0x1B0017]))
2783
#define MCF_PWM_PWMPER4 (*(vuint8 *)(&__IPSBAR[0x1B0018]))
2784
#define MCF_PWM_PWMPER5 (*(vuint8 *)(&__IPSBAR[0x1B0019]))
2785
#define MCF_PWM_PWMPER6 (*(vuint8 *)(&__IPSBAR[0x1B001A]))
2786
#define MCF_PWM_PWMPER7 (*(vuint8 *)(&__IPSBAR[0x1B001B]))
2787
#define MCF_PWM_PWMPER(x) (*(vuint8 *)(&__IPSBAR[0x1B0014+((x)*0x001)]))
2788
#define MCF_PWM_PWMDTY0 (*(vuint8 *)(&__IPSBAR[0x1B001C]))
2789
#define MCF_PWM_PWMDTY1 (*(vuint8 *)(&__IPSBAR[0x1B001D]))
2790
#define MCF_PWM_PWMDTY2 (*(vuint8 *)(&__IPSBAR[0x1B001E]))
2791
#define MCF_PWM_PWMDTY3 (*(vuint8 *)(&__IPSBAR[0x1B001F]))
2792
#define MCF_PWM_PWMDTY4 (*(vuint8 *)(&__IPSBAR[0x1B0020]))
2793
#define MCF_PWM_PWMDTY5 (*(vuint8 *)(&__IPSBAR[0x1B0021]))
2794
#define MCF_PWM_PWMDTY6 (*(vuint8 *)(&__IPSBAR[0x1B0022]))
2795
#define MCF_PWM_PWMDTY7 (*(vuint8 *)(&__IPSBAR[0x1B0023]))
2796
#define MCF_PWM_PWMDTY(x) (*(vuint8 *)(&__IPSBAR[0x1B001C+((x)*0x001)]))
2797
#define MCF_PWM_PWMSDN (*(vuint8 *)(&__IPSBAR[0x1B0024]))
2798
2799
/* Bit definitions and macros for MCF_PWM_PWME */
2800
#define MCF_PWM_PWME_PWME0 (0x01)
2801
#define MCF_PWM_PWME_PWME1 (0x02)
2802
#define MCF_PWM_PWME_PWME2 (0x04)
2803
#define MCF_PWM_PWME_PWME3 (0x08)
2804
2805
/* Bit definitions and macros for MCF_PWM_PWMPOL */
2806
#define MCF_PWM_PWMPOL_PPOL0 (0x01)
2807
#define MCF_PWM_PWMPOL_PPOL1 (0x02)
2808
#define MCF_PWM_PWMPOL_PPOL2 (0x04)
2809
#define MCF_PWM_PWMPOL_PPOL3 (0x08)
2810
2811
/* Bit definitions and macros for MCF_PWM_PWMCLK */
2812
#define MCF_PWM_PWMCLK_PCLK0 (0x01)
2813
#define MCF_PWM_PWMCLK_PCLK1 (0x02)
2814
#define MCF_PWM_PWMCLK_PCLK2 (0x04)
2815
#define MCF_PWM_PWMCLK_PCLK3 (0x08)
2816
2817
/* Bit definitions and macros for MCF_PWM_PWMPRCLK */
2818
#define MCF_PWM_PWMPRCLK_PCKA(x) (((x)&0x07)<<0)
2819
#define MCF_PWM_PWMPRCLK_PCKB(x) (((x)&0x07)<<4)
2820
2821
/* Bit definitions and macros for MCF_PWM_PWMCAE */
2822
#define MCF_PWM_PWMCAE_CAE0 (0x01)
2823
#define MCF_PWM_PWMCAE_CAE1 (0x02)
2824
#define MCF_PWM_PWMCAE_CAE2 (0x04)
2825
#define MCF_PWM_PWMCAE_CAE3 (0x08)
2826
2827
/* Bit definitions and macros for MCF_PWM_PWMCTL */
2828
#define MCF_PWM_PWMCTL_PFRZ (0x04)
2829
#define MCF_PWM_PWMCTL_PSWAI (0x08)
2830
#define MCF_PWM_PWMCTL_CON01 (0x10)
2831
#define MCF_PWM_PWMCTL_CON23 (0x20)
2832
2833
/* Bit definitions and macros for MCF_PWM_PWMSCLA */
2834
#define MCF_PWM_PWMSCLA_SCALEA(x) (((x)&0xFF)<<0)
2835
2836
/* Bit definitions and macros for MCF_PWM_PWMSCLB */
2837
#define MCF_PWM_PWMSCLB_SCALEB(x) (((x)&0xFF)<<0)
2838
2839
/* Bit definitions and macros for MCF_PWM_PWMCNT */
2840
#define MCF_PWM_PWMCNT_COUNT(x) (((x)&0xFF)<<0)
2841
2842
/* Bit definitions and macros for MCF_PWM_PWMPER */
2843
#define MCF_PWM_PWMPER_PERIOD(x) (((x)&0xFF)<<0)
2844
2845
/* Bit definitions and macros for MCF_PWM_PWMDTY */
2846
#define MCF_PWM_PWMDTY_DUTY(x) (((x)&0xFF)<<0)
2847
2848
/* Bit definitions and macros for MCF_PWM_PWMSDN */
2849
#define MCF_PWM_PWMSDN_SDNEN (0x01)
2850
#define MCF_PWM_PWMSDN_PWM7IL (0x02)
2851
#define MCF_PWM_PWMSDN_PWM7IN (0x04)
2852
#define MCF_PWM_PWMSDN_LVL (0x10)
2853
#define MCF_PWM_PWMSDN_RESTART (0x20)
2854
#define MCF_PWM_PWMSDN_IE (0x40)
2855
#define MCF_PWM_PWMSDN_IF (0x80)
2856
2857
2858
2859
* FlexCAN Module (CAN)
2860
2861
2862
2863
2864
#define MCF_CAN_CANMCR (*(vuint32*)(&__IPSBAR[0x1C0000]))
2865
#define MCF_CAN_CANCTRL (*(vuint32*)(&__IPSBAR[0x1C0004]))
2866
#define MCF_CAN_TIMER (*(vuint32*)(&__IPSBAR[0x1C0008]))
2867
#define MCF_CAN_RXGMASK (*(vuint32*)(&__IPSBAR[0x1C0010]))
2868
#define MCF_CAN_RX14MASK (*(vuint32*)(&__IPSBAR[0x1C0014]))
2869
#define MCF_CAN_RX15MASK (*(vuint32*)(&__IPSBAR[0x1C0018]))
2870
#define MCF_CAN_ERRCNT (*(vuint32*)(&__IPSBAR[0x1C001C]))
2871
#define MCF_CAN_ERRSTAT (*(vuint32*)(&__IPSBAR[0x1C0020]))
2872
#define MCF_CAN_IMASK (*(vuint32*)(&__IPSBAR[0x1C0028]))
2873
#define MCF_CAN_IFLAG (*(vuint32*)(&__IPSBAR[0x1C0030]))
2874
2875
/* Bit definitions and macros for MCF_CAN_CANMCR */
2876
#define MCF_CAN_CANMCR_MAXMB(x) (((x)&0x0000000F)<<0)
2877
#define MCF_CAN_CANMCR_SUPV (0x00800000)
2878
#define MCF_CAN_CANMCR_FRZACK (0x01000000)
2879
#define MCF_CAN_CANMCR_SOFTRST (0x02000000)
2880
#define MCF_CAN_CANMCR_HALT (0x10000000)
2881
#define MCF_CAN_CANMCR_FRZ (0x40000000)
2882
#define MCF_CAN_CANMCR_MDIS (0x80000000)
2883
2884
/* Bit definitions and macros for MCF_CAN_CANCTRL */
2885
#define MCF_CAN_CANCTRL_PROPSEG(x) (((x)&0x00000007)<<0)
2886
#define MCF_CAN_CANCTRL_LOM (0x00000008)
2887
#define MCF_CAN_CANCTRL_LBUF (0x00000010)
2888
#define MCF_CAN_CANCTRL_TSYNC (0x00000020)
2889
#define MCF_CAN_CANCTRL_BOFFREC (0x00000040)
2890
#define MCF_CAN_CANCTRL_SAMP (0x00000080)
2891
#define MCF_CAN_CANCTRL_LPB (0x00001000)
2892
#define MCF_CAN_CANCTRL_CLKSRC (0x00002000)
2893
#define MCF_CAN_CANCTRL_ERRMSK (0x00004000)
2894
#define MCF_CAN_CANCTRL_BOFFMSK (0x00008000)
2895
#define MCF_CAN_CANCTRL_PSEG2(x) (((x)&0x00000007)<<16)
2896
#define MCF_CAN_CANCTRL_PSEG1(x) (((x)&0x00000007)<<19)
2897
#define MCF_CAN_CANCTRL_RJW(x) (((x)&0x00000003)<<22)
2898
#define MCF_CAN_CANCTRL_PRESDIV(x) (((x)&0x000000FF)<<24)
2899
2900
/* Bit definitions and macros for MCF_CAN_TIMER */
2901
#define MCF_CAN_TIMER_TIMER(x) (((x)&0x0000FFFF)<<0)
2902
2903
/* Bit definitions and macros for MCF_CAN_RXGMASK */
2904
#define MCF_CAN_RXGMASK_MI(x) (((x)&0x1FFFFFFF)<<0)
2905
2906
/* Bit definitions and macros for MCF_CAN_RX14MASK */
2907
#define MCF_CAN_RX14MASK_MI(x) (((x)&0x1FFFFFFF)<<0)
2908
2909
/* Bit definitions and macros for MCF_CAN_RX15MASK */
2910
#define MCF_CAN_RX15MASK_MI(x) (((x)&0x1FFFFFFF)<<0)
2911
2912
/* Bit definitions and macros for MCF_CAN_ERRCNT */
2913
#define MCF_CAN_ERRCNT_TXECTR(x) (((x)&0x000000FF)<<0)
2914
#define MCF_CAN_ERRCNT_RXECTR(x) (((x)&0x000000FF)<<8)
2915
2916
/* Bit definitions and macros for MCF_CAN_ERRSTAT */
2917
#define MCF_CAN_ERRSTAT_WAKINT (0x00000001)
2918
#define MCF_CAN_ERRSTAT_ERRINT (0x00000002)
2919
#define MCF_CAN_ERRSTAT_BOFFINT (0x00000004)
2920
#define MCF_CAN_ERRSTAT_FLTCONF(x) (((x)&0x00000003)<<4)
2921
#define MCF_CAN_ERRSTAT_TXRX (0x00000040)
2922
#define MCF_CAN_ERRSTAT_IDLE (0x00000080)
2923
#define MCF_CAN_ERRSTAT_RXWRN (0x00000100)
2924
#define MCF_CAN_ERRSTAT_TXWRN (0x00000200)
2925
#define MCF_CAN_ERRSTAT_STFERR (0x00000400)
2926
#define MCF_CAN_ERRSTAT_FRMERR (0x00000800)
2927
#define MCF_CAN_ERRSTAT_CRCERR (0x00001000)
2928
#define MCF_CAN_ERRSTAT_ACKERR (0x00002000)
2929
#define MCF_CAN_ERRSTAT_BITERR(x) (((x)&0x00000003)<<14)
2930
#define MCF_CAN_ERRSTAT_FLTCONF_ACTIVE (0x00000000)
2931
#define MCF_CAN_ERRSTAT_FLTCONF_PASSIVE (0x00000010)
2932
#define MCF_CAN_ERRSTAT_FLTCONF_BUSOFF (0x00000020)
2933
2934
/* Bit definitions and macros for MCF_CAN_IMASK */
2935
#define MCF_CAN_IMASK_BUF(x) (1<<x)
2936
2937
/* Bit definitions and macros for MCF_CAN_IFLAG */
2938
#define MCF_CAN_IFLAG_BUF(x) (1<<x)
2939
2940
2941
2942
* ColdFire Flash Module (CFM)
2943
2944
2945
2946
2947
#define MCF_CFM_CFMMCR (*(vuint16*)(&__IPSBAR[0x1D0000]))
2948
#define MCF_CFM_CFMCLKD (*(vuint8 *)(&__IPSBAR[0x1D0002]))
2949
#define MCF_CFM_CFMSEC (*(vuint32*)(&__IPSBAR[0x1D0008]))
2950
#define MCF_CFM_CFMPROT (*(vuint32*)(&__IPSBAR[0x1D0010]))
2951
#define MCF_CFM_CFMSACC (*(vuint32*)(&__IPSBAR[0x1D0014]))
2952
#define MCF_CFM_CFMDACC (*(vuint32*)(&__IPSBAR[0x1D0018]))
2953
#define MCF_CFM_CFMUSTAT (*(vuint8 *)(&__IPSBAR[0x1D0020]))
2954
#define MCF_CFM_CFMCMD (*(vuint8 *)(&__IPSBAR[0x1D0024]))
2955
2956
/* Bit definitions and macros for MCF_CFM_CFMMCR */
2957
#define MCF_CFM_CFMMCR_KEYACC (0x0020)
2958
#define MCF_CFM_CFMMCR_CCIE (0x0040)
2959
#define MCF_CFM_CFMMCR_CBEIE (0x0080)
2960
#define MCF_CFM_CFMMCR_AEIE (0x0100)
2961
#define MCF_CFM_CFMMCR_PVIE (0x0200)
2962
#define MCF_CFM_CFMMCR_LOCK (0x0400)
2963
2964
/* Bit definitions and macros for MCF_CFM_CFMCLKD */
2965
#define MCF_CFM_CFMCLKD_DIV(x) (((x)&0x3F)<<0)
2966
#define MCF_CFM_CFMCLKD_PRDIV8 (0x40)
2967
#define MCF_CFM_CFMCLKD_DIVLD (0x80)
2968
2969
/* Bit definitions and macros for MCF_CFM_CFMSEC */
2970
#define MCF_CFM_CFMSEC_SEC(x) (((x)&0x0000FFFF)<<0)
2971
#define MCF_CFM_CFMSEC_SECSTAT (0x40000000)
2972
#define MCF_CFM_CFMSEC_KEYEN (0x80000000)
2973
2974
/* Bit definitions and macros for MCF_CFM_CFMUSTAT */
2975
#define MCF_CFM_CFMUSTAT_BLANK (0x04)
2976
#define MCF_CFM_CFMUSTAT_ACCERR (0x10)
2977
#define MCF_CFM_CFMUSTAT_PVIOL (0x20)
2978
#define MCF_CFM_CFMUSTAT_CCIF (0x40)
2979
#define MCF_CFM_CFMUSTAT_CBEIF (0x80)
2980
2981
/* Bit definitions and macros for MCF_CFM_CFMCMD */
2982
#define MCF_CFM_CFMCMD_CMD(x) (((x)&0x7F)<<0)
2983
#define MCF_CFM_CFMCMD_RDARY1 (0x05)
2984
#define MCF_CFM_CFMCMD_PGM (0x20)
2985
#define MCF_CFM_CFMCMD_PGERS (0x40)
2986
#define MCF_CFM_CFMCMD_MASERS (0x41)
2987
#define MCF_CFM_CFMCMD_PGERSVER (0x06)
2988
2989
2990
2991
* Interrupt Controller (INTC_IACK)
2992
2993
2994
2995
2996
#define MCF_INTC_IACK_GSWIACK (*(vuint8 *)(&__IPSBAR[0x000FE0]))
2997
#define MCF_INTC_IACK_GL1IACK (*(vuint8 *)(&__IPSBAR[0x000FE4]))
2998
#define MCF_INTC_IACK_GL2IACK (*(vuint8 *)(&__IPSBAR[0x000FE8]))
2999
#define MCF_INTC_IACK_GL3IACK (*(vuint8 *)(&__IPSBAR[0x000FEC]))
3000
#define MCF_INTC_IACK_GL4IACK (*(vuint8 *)(&__IPSBAR[0x000FF0]))
3001
#define MCF_INTC_IACK_GL5IACK (*(vuint8 *)(&__IPSBAR[0x000FF4]))
3002
#define MCF_INTC_IACK_GL6IACK (*(vuint8 *)(&__IPSBAR[0x000FF8]))
3003
#define MCF_INTC_IACK_GL7IACK (*(vuint8 *)(&__IPSBAR[0x000FFC]))
3004
#define MCF_INTC_IACK_GLIACK(x) (*(vuint8 *)(&__IPSBAR[0x000FE4+((x-1)*0x004)]))
3005
3006
/* Bit definitions and macros for MCF_INTC_IACK_GSWIACK */
3007
#define MCF_INTC_IACK_GSWIACK_VECTOR(x) (((x)&0xFF)<<0)
3008
3009
/* Bit definitions and macros for MCF_INTC_IACK_GLIACK */
3010
#define MCF_INTC_IACK_GLIACK_VECTOR(x) (((x)&0xFF)<<0)
3011
3012
3013
3014
* Fast Ethernet Controller (FEC)
3015
3016
3017
3018
3019
#define MCF_FEC_EIR (*(vuint32*)(&__IPSBAR[0x001004]))
3020
#define MCF_FEC_EIMR (*(vuint32*)(&__IPSBAR[0x001008]))
3021
#define MCF_FEC_RDAR (*(vuint32*)(&__IPSBAR[0x001010]))
3022
#define MCF_FEC_TDAR (*(vuint32*)(&__IPSBAR[0x001014]))
3023
#define MCF_FEC_ECR (*(vuint32*)(&__IPSBAR[0x001024]))
3024
#define MCF_FEC_MMFR (*(vuint32*)(&__IPSBAR[0x001040]))
3025
#define MCF_FEC_MSCR (*(vuint32*)(&__IPSBAR[0x001044]))
3026
#define MCF_FEC_MIBC (*(vuint32*)(&__IPSBAR[0x001064]))
3027
#define MCF_FEC_RCR (*(vuint32*)(&__IPSBAR[0x001084]))
3028
#define MCF_FEC_TCR (*(vuint32*)(&__IPSBAR[0x0010C4]))
3029
#define MCF_FEC_PALR (*(vuint32*)(&__IPSBAR[0x0010E4]))
3030
#define MCF_FEC_PAUR (*(vuint32*)(&__IPSBAR[0x0010E8]))
3031
#define MCF_FEC_OPD (*(vuint32*)(&__IPSBAR[0x0010EC]))
3032
#define MCF_FEC_IAUR (*(vuint32*)(&__IPSBAR[0x001118]))
3033
#define MCF_FEC_IALR (*(vuint32*)(&__IPSBAR[0x00111C]))
3034
#define MCF_FEC_GAUR (*(vuint32*)(&__IPSBAR[0x001120]))
3035
#define MCF_FEC_GALR (*(vuint32*)(&__IPSBAR[0x001124]))
3036
#define MCF_FEC_TFWR (*(vuint32*)(&__IPSBAR[0x001144]))
3037
#define MCF_FEC_FRBR (*(vuint32*)(&__IPSBAR[0x00114C]))
3038
#define MCF_FEC_FRSR (*(vuint32*)(&__IPSBAR[0x001150]))
3039
#define MCF_FEC_ERDSR (*(vuint32*)(&__IPSBAR[0x001180]))
3040
#define MCF_FEC_ETDSR (*(vuint32*)(&__IPSBAR[0x001184]))
3041
#define MCF_FEC_EMRBR (*(vuint32*)(&__IPSBAR[0x001188]))
3042
#define MCF_FEC_RMON_T_DROP (*(vuint32*)(&__IPSBAR[0x001200]))
3043
#define MCF_FEC_RMON_T_PACKETS (*(vuint32*)(&__IPSBAR[0x001204]))
3044
#define MCF_FEC_RMON_T_BC_PKT (*(vuint32*)(&__IPSBAR[0x001208]))
3045
#define MCF_FEC_RMON_T_MC_PKT (*(vuint32*)(&__IPSBAR[0x00120C]))
3046
#define MCF_FEC_RMON_T_CRC_ALIGN (*(vuint32*)(&__IPSBAR[0x001210]))
3047
#define MCF_FEC_RMON_T_UNDERSIZE (*(vuint32*)(&__IPSBAR[0x001214]))
3048
#define MCF_FEC_RMON_T_OVERSIZE (*(vuint32*)(&__IPSBAR[0x001218]))
3049
#define MCF_FEC_RMON_T_FRAG (*(vuint32*)(&__IPSBAR[0x00121C]))
3050
#define MCF_FEC_RMON_T_JAB (*(vuint32*)(&__IPSBAR[0x001220]))
3051
#define MCF_FEC_RMON_T_COL (*(vuint32*)(&__IPSBAR[0x001224]))
3052
#define MCF_FEC_RMON_T_P64 (*(vuint32*)(&__IPSBAR[0x001228]))
3053
#define MCF_FEC_RMON_T_P65TO127 (*(vuint32*)(&__IPSBAR[0x00122C]))
3054
#define MCF_FEC_RMON_T_P128TO255 (*(vuint32*)(&__IPSBAR[0x001230]))
3055
#define MCF_FEC_RMON_T_P256TO511 (*(vuint32*)(&__IPSBAR[0x001234]))
3056
#define MCF_FEC_RMON_T_P512TO1023 (*(vuint32*)(&__IPSBAR[0x001238]))
3057
#define MCF_FEC_RMON_T_P1024TO2047 (*(vuint32*)(&__IPSBAR[0x00123C]))
3058
#define MCF_FEC_RMON_T_P_GTE2048 (*(vuint32*)(&__IPSBAR[0x001240]))
3059
#define MCF_FEC_RMON_T_OCTETS (*(vuint32*)(&__IPSBAR[0x001244]))
3060
#define MCF_FEC_IEEE_T_DROP (*(vuint32*)(&__IPSBAR[0x001248]))
3061
#define MCF_FEC_IEEE_T_FRAME_OK (*(vuint32*)(&__IPSBAR[0x00124C]))
3062
#define MCF_FEC_IEEE_T_1COL (*(vuint32*)(&__IPSBAR[0x001250]))
3063
#define MCF_FEC_IEEE_T_MCOL (*(vuint32*)(&__IPSBAR[0x001254]))
3064
#define MCF_FEC_IEEE_T_DEF (*(vuint32*)(&__IPSBAR[0x001258]))
3065
#define MCF_FEC_IEEE_T_LCOL (*(vuint32*)(&__IPSBAR[0x00125C]))
3066
#define MCF_FEC_IEEE_T_EXCOL (*(vuint32*)(&__IPSBAR[0x001260]))
3067
#define MCF_FEC_IEEE_T_MACERR (*(vuint32*)(&__IPSBAR[0x001264]))
3068
#define MCF_FEC_IEEE_T_CSERR (*(vuint32*)(&__IPSBAR[0x001268]))
3069
#define MCF_FEC_IEEE_T_SQE (*(vuint32*)(&__IPSBAR[0x00126C]))
3070
#define MCF_FEC_IEEE_T_FDXFC (*(vuint32*)(&__IPSBAR[0x001270]))
3071
#define MCF_FEC_IEEE_T_OCTETS_OK (*(vuint32*)(&__IPSBAR[0x001274]))
3072
#define MCF_FEC_RMON_R_PACKETS (*(vuint32*)(&__IPSBAR[0x001284]))
3073
#define MCF_FEC_RMON_R_BC_PKT (*(vuint32*)(&__IPSBAR[0x001288]))
3074
#define MCF_FEC_RMON_R_MC_PKT (*(vuint32*)(&__IPSBAR[0x00128C]))
3075
#define MCF_FEC_RMON_R_CRC_ALIGN (*(vuint32*)(&__IPSBAR[0x001290]))
3076
#define MCF_FEC_RMON_R_UNDERSIZE (*(vuint32*)(&__IPSBAR[0x001294]))
3077
#define MCF_FEC_RMON_R_OVERSIZE (*(vuint32*)(&__IPSBAR[0x001298]))
3078
#define MCF_FEC_RMON_R_FRAG (*(vuint32*)(&__IPSBAR[0x00129C]))
3079
#define MCF_FEC_RMON_R_JAB (*(vuint32*)(&__IPSBAR[0x0012A0]))
3080
#define MCF_FEC_RMON_R_RESVD_0 (*(vuint32*)(&__IPSBAR[0x0012A4]))
3081
#define MCF_FEC_RMON_R_P64 (*(vuint32*)(&__IPSBAR[0x0012A8]))
3082
#define MCF_FEC_RMON_R_P65TO127 (*(vuint32*)(&__IPSBAR[0x0012AC]))
3083
#define MCF_FEC_RMON_R_P128TO255 (*(vuint32*)(&__IPSBAR[0x0012B0]))
3084
#define MCF_FEC_RMON_R_P256TO511 (*(vuint32*)(&__IPSBAR[0x0012B4]))
3085
#define MCF_FEC_RMON_R_512TO1023 (*(vuint32*)(&__IPSBAR[0x0012B8]))
3086
#define MCF_FEC_RMON_R_P_GTE2048 (*(vuint32*)(&__IPSBAR[0x0012C0]))
3087
#define MCF_FEC_RMON_R_1024TO2047 (*(vuint32*)(&__IPSBAR[0x0012BC]))
3088
#define MCF_FEC_RMON_R_OCTETS (*(vuint32*)(&__IPSBAR[0x0012C4]))
3089
#define MCF_FEC_IEEE_R_DROP (*(vuint32*)(&__IPSBAR[0x0012C8]))
3090
#define MCF_FEC_IEEE_R_FRAME_OK (*(vuint32*)(&__IPSBAR[0x0012CC]))
3091
#define MCF_FEC_IEEE_R_CRC (*(vuint32*)(&__IPSBAR[0x0012D0]))
3092
#define MCF_FEC_IEEE_R_ALIGN (*(vuint32*)(&__IPSBAR[0x0012D4]))
3093
#define MCF_FEC_IEEE_R_MACERR (*(vuint32*)(&__IPSBAR[0x0012D8]))
3094
#define MCF_FEC_IEEE_R_FDXFC (*(vuint32*)(&__IPSBAR[0x0012DC]))
3095
#define MCF_FEC_IEEE_R_OCTETS_OK (*(vuint32*)(&__IPSBAR[0x0012E0]))
3096
3097
/* Bit definitions and macros for MCF_FEC_EIR */
3098
#define MCF_FEC_EIR_UN (0x00080000)
3099
#define MCF_FEC_EIR_RL (0x00100000)
3100
#define MCF_FEC_EIR_LC (0x00200000)
3101
#define MCF_FEC_EIR_EBERR (0x00400000)
3102
#define MCF_FEC_EIR_MII (0x00800000)
3103
#define MCF_FEC_EIR_RXB (0x01000000)
3104
#define MCF_FEC_EIR_RXF (0x02000000)
3105
#define MCF_FEC_EIR_TXB (0x04000000)
3106
#define MCF_FEC_EIR_TXF (0x08000000)
3107
#define MCF_FEC_EIR_GRA (0x10000000)
3108
#define MCF_FEC_EIR_BABT (0x20000000)
3109
#define MCF_FEC_EIR_BABR (0x40000000)
3110
#define MCF_FEC_EIR_HBERR (0x80000000)
3111
#define MCF_FEC_EIR_CLEAR_ALL (0xFFFFFFFF)
3112
3113
/* Bit definitions and macros for MCF_FEC_EIMR */
3114
#define MCF_FEC_EIMR_UN (0x00080000)
3115
#define MCF_FEC_EIMR_RL (0x00100000)
3116
#define MCF_FEC_EIMR_LC (0x00200000)
3117
#define MCF_FEC_EIMR_EBERR (0x00400000)
3118
#define MCF_FEC_EIMR_MII (0x00800000)
3119
#define MCF_FEC_EIMR_RXB (0x01000000)
3120
#define MCF_FEC_EIMR_RXF (0x02000000)
3121
#define MCF_FEC_EIMR_TXB (0x04000000)
3122
#define MCF_FEC_EIMR_TXF (0x08000000)
3123
#define MCF_FEC_EIMR_GRA (0x10000000)
3124
#define MCF_FEC_EIMR_BABT (0x20000000)
3125
#define MCF_FEC_EIMR_BABR (0x40000000)
3126
#define MCF_FEC_EIMR_HBERR (0x80000000)
3127
#define MCF_FEC_EIMR_MASK_ALL (0x00000000)
3128
#define MCF_FEC_EIMR_UNMASK_ALL (0xFFFFFFFF)
3129
3130
/* Bit definitions and macros for MCF_FEC_RDAR */
3131
#define MCF_FEC_RDAR_R_DES_ACTIVE (0x01000000)
3132
3133
/* Bit definitions and macros for MCF_FEC_TDAR */
3134
#define MCF_FEC_TDAR_X_DES_ACTIVE (0x01000000)
3135
3136
/* Bit definitions and macros for MCF_FEC_ECR */
3137
#define MCF_FEC_ECR_RESET (0x00000001)
3138
#define MCF_FEC_ECR_ETHER_EN (0x00000002)
3139
3140
/* Bit definitions and macros for MCF_FEC_MMFR */
3141
#define MCF_FEC_MMFR_DATA(x) (((x)&0x0000FFFF)<<0)
3142
#define MCF_FEC_MMFR_TA(x) (((x)&0x00000003)<<16)
3143
#define MCF_FEC_MMFR_RA(x) (((x)&0x0000001F)<<18)
3144
#define MCF_FEC_MMFR_PA(x) (((x)&0x0000001F)<<23)
3145
#define MCF_FEC_MMFR_OP(x) (((x)&0x00000003)<<28)
3146
#define MCF_FEC_MMFR_ST(x) (((x)&0x00000003)<<30)
3147
#define MCF_FEC_MMFR_ST_01 (0x40000000)
3148
#define MCF_FEC_MMFR_OP_READ (0x20000000)
3149
#define MCF_FEC_MMFR_OP_WRITE (0x10000000)
3150
#define MCF_FEC_MMFR_TA_10 (0x00020000)
3151
3152
/* Bit definitions and macros for MCF_FEC_MSCR */
3153
#define MCF_FEC_MSCR_MII_SPEED(x) (((x)&0x0000003F)<<1)
3154
#define MCF_FEC_MSCR_DIS_PREAMBLE (0x00000080)
3155
3156
/* Bit definitions and macros for MCF_FEC_MIBC */
3157
#define MCF_FEC_MIBC_MIB_IDLE (0x40000000)
3158
#define MCF_FEC_MIBC_MIB_DISABLE (0x80000000)
3159
3160
/* Bit definitions and macros for MCF_FEC_RCR */
3161
#define MCF_FEC_RCR_LOOP (0x00000001)
3162
#define MCF_FEC_RCR_DRT (0x00000002)
3163
#define MCF_FEC_RCR_MII_MODE (0x00000004)
3164
#define MCF_FEC_RCR_PROM (0x00000008)
3165
#define MCF_FEC_RCR_BC_REJ (0x00000010)
3166
#define MCF_FEC_RCR_FCE (0x00000020)
3167
#define MCF_FEC_RCR_MAX_FL(x) (((x)&0x000007FF)<<16)
3168
3169
/* Bit definitions and macros for MCF_FEC_TCR */
3170
#define MCF_FEC_TCR_GTS (0x00000001)
3171
#define MCF_FEC_TCR_HBC (0x00000002)
3172
#define MCF_FEC_TCR_FDEN (0x00000004)
3173
#define MCF_FEC_TCR_TFC_PAUSE (0x00000008)
3174
#define MCF_FEC_TCR_RFC_PAUSE (0x00000010)
3175
3176
/* Bit definitions and macros for MCF_FEC_PALR */
3177
#define MCF_FEC_PALR_PADDR1(x) (((x)&0xFFFFFFFF)<<0)
3178
3179
/* Bit definitions and macros for MCF_FEC_PAUR */
3180
#define MCF_FEC_PAUR_TYPE(x) (((x)&0x0000FFFF)<<0)
3181
#define MCF_FEC_PAUR_PADDR2(x) (((x)&0x0000FFFF)<<16)
3182
3183
/* Bit definitions and macros for MCF_FEC_OPD */
3184
#define MCF_FEC_OPD_PAUSE_DUR(x) (((x)&0x0000FFFF)<<0)
3185
#define MCF_FEC_OPD_OPCODE(x) (((x)&0x0000FFFF)<<16)
3186
3187
/* Bit definitions and macros for MCF_FEC_IAUR */
3188
#define MCF_FEC_IAUR_IADDR1(x) (((x)&0xFFFFFFFF)<<0)
3189
3190
/* Bit definitions and macros for MCF_FEC_IALR */
3191
#define MCF_FEC_IALR_IADDR2(x) (((x)&0xFFFFFFFF)<<0)
3192
3193
/* Bit definitions and macros for MCF_FEC_GAUR */
3194
#define MCF_FEC_GAUR_GADDR1(x) (((x)&0xFFFFFFFF)<<0)
3195
3196
/* Bit definitions and macros for MCF_FEC_GALR */
3197
#define MCF_FEC_GALR_GADDR2(x) (((x)&0xFFFFFFFF)<<0)
3198
3199
/* Bit definitions and macros for MCF_FEC_TFWR */
3200
#define MCF_FEC_TFWR_X_WMRK(x) (((x)&0x00000003)<<0)
3201
3202
/* Bit definitions and macros for MCF_FEC_FRBR */
3203
#define MCF_FEC_FRBR_R_BOUND(x) (((x)&0x000000FF)<<2)
3204
3205
/* Bit definitions and macros for MCF_FEC_FRSR */
3206
#define MCF_FEC_FRSR_R_FSTART(x) (((x)&0x000000FF)<<2)
3207
3208
/* Bit definitions and macros for MCF_FEC_ERDSR */
3209
#define MCF_FEC_ERDSR_R_DES_START(x) (((x)&0x3FFFFFFF)<<2)
3210
3211
/* Bit definitions and macros for MCF_FEC_ETDSR */
3212
#define MCF_FEC_ETDSR_X_DES_START(x) (((x)&0x3FFFFFFF)<<2)
3213
3214
/* Bit definitions and macros for MCF_FEC_EMRBR */
3215
#define MCF_FEC_EMRBR_R_BUF_SIZE(x) (((x)&0x0000007F)<<4)
3216
3217
3218
3219
* Ethernet PHY (PHY)
3220
3221
3222
3223
3224
#define MCF_PHY_EPHYCTL0 (*(vuint8 *)(&__IPSBAR[0x1E0000]))
3225
#define MCF_PHY_EPHYCTL1 (*(vuint8 *)(&__IPSBAR[0x1E0001]))
3226
#define MCF_PHY_EPHYSR (*(vuint8 *)(&__IPSBAR[0x1E0002]))
3227
3228
/* Bit definitions and macros for MCF_PHY_EPHYCTL0 */
3229
#define MCF_PHY_EPHYCTL0_EPHYIEN (0x01)
3230
#define MCF_PHY_EPHYCTL0_EPHYWAI (0x04)
3231
#define MCF_PHY_EPHYCTL0_LEDEN (0x08)
3232
#define MCF_PHY_EPHYCTL0_DIS10 (0x10)
3233
#define MCF_PHY_EPHYCTL0_DIS100 (0x20)
3234
#define MCF_PHY_EPHYCTL0_ANDIS (0x40)
3235
#define MCF_PHY_EPHYCTL0_EPHYEN (0x80)
3236
3237
/* Bit definitions and macros for MCF_PHY_EPHYCTL1 */
3238
#define MCF_PHY_EPHYCTL1_PHYADDR(x) (((x)&0x1F)<<0)
3239
3240
/* Bit definitions and macros for MCF_PHY_EPHYSR */
3241
#define MCF_PHY_EPHYSR_EPHYIF (0x01)
3242
#define MCF_PHY_EPHYSR_10DIS (0x10)
3243
#define MCF_PHY_EPHYSR_100DIS (0x20)
3244
3245
3246
3247
* Random Number Generator (RNG)
3248
3249
3250
3251
3252
#define MCF_RNG_RNGCR (*(vuint32*)(&__IPSBAR[0x1F0000]))
3253
#define MCF_RNG_RNGSR (*(vuint32*)(&__IPSBAR[0x1F0004]))
3254
#define MCF_RNG_RNGER (*(vuint32*)(&__IPSBAR[0x1F0008]))
3255
#define MCF_RNG_RNGOUT (*(vuint32*)(&__IPSBAR[0x1F000C]))
3256
3257
/* Bit definitions and macros for MCF_RNG_RNGCR */
3258
#define MCF_RNG_RNGCR_GO (0x00000001)
3259
#define MCF_RNG_RNGCR_HA (0x00000002)
3260
#define MCF_RNG_RNGCR_IM (0x00000004)
3261
#define MCF_RNG_RNGCR_CI (0x00000008)
3262
3263
/* Bit definitions and macros for MCF_RNG_RNGSR */
3264
#define MCF_RNG_RNGSR_SV (0x00000001)
3265
#define MCF_RNG_RNGSR_LRS (0x00000002)
3266
#define MCF_RNG_RNGSR_FUF (0x00000004)
3267
#define MCF_RNG_RNGSR_EI (0x00000008)
3268
#define MCF_RNG_RNGSR_OFL(x) (((x)&0x000000FF)<<8)
3269
#define MCF_RNG_RNGSR_OFS(x) (((x)&0x000000FF)<<16)
3270
3271
/* Bit definitions and macros for MCF_RNG_RNGER */
3272
#define MCF_RNG_RNGER_ENTROPY(x) (((x)&0xFFFFFFFF)<<0)
3273
3274
/* Bit definitions and macros for MCF_RNG_RNGOUT */
3275
#define MCF_RNG_RNGOUT_OUTPUT(x) (((x)&0xFFFFFFFF)<<0)
3276
3277
3278
3279
* Real-time Clock (RTC)
3280
3281
3282
3283
3284
#define MCF_RTC_HOURMIN (*(vuint32*)(&__IPSBAR[0x0003C0]))
3285
#define MCF_RTC_SECONDS (*(vuint32*)(&__IPSBAR[0x0003C4]))
3286
#define MCF_RTC_ALRM_HM (*(vuint32*)(&__IPSBAR[0x0003C8]))
3287
#define MCF_RTC_ALRM_SEC (*(vuint32*)(&__IPSBAR[0x0003CC]))
3288
#define MCF_RTC_CR (*(vuint32*)(&__IPSBAR[0x0003D0]))
3289
#define MCF_RTC_ISR (*(vuint32*)(&__IPSBAR[0x0003D4]))
3290
#define MCF_RTC_IER (*(vuint32*)(&__IPSBAR[0x0003D8]))
3291
#define MCF_RTC_STPWCH (*(vuint32*)(&__IPSBAR[0x0003DC]))
3292
#define MCF_RTC_DAYS (*(vuint32*)(&__IPSBAR[0x0003E0]))
3293
#define MCF_RTC_ALRM_DAY (*(vuint32*)(&__IPSBAR[0x0003E4]))
3294
3295
/* Bit definitions and macros for MCF_RTC_HOURMIN */
3296
#define MCF_RTC_HOURMIN_MINUTES(x) (((x)&0x0000003F)<<0)
3297
#define MCF_RTC_HOURMIN_HOURS(x) (((x)&0x0000001F)<<8)
3298
3299
/* Bit definitions and macros for MCF_RTC_SECONDS */
3300
#define MCF_RTC_SECONDS_SECONDS(x) (((x)&0x0000003F)<<0)
3301
3302
/* Bit definitions and macros for MCF_RTC_ALRM_HM */
3303
#define MCF_RTC_ALRM_HM_MINUTES(x) (((x)&0x0000003F)<<0)
3304
#define MCF_RTC_ALRM_HM_HOURS(x) (((x)&0x0000001F)<<8)
3305
3306
/* Bit definitions and macros for MCF_RTC_ALRM_SEC */
3307
#define MCF_RTC_ALRM_SEC_SECONDS(x) (((x)&0x0000003F)<<0)
3308
3309
/* Bit definitions and macros for MCF_RTC_CR */
3310
#define MCF_RTC_CR_SWR (0x00000001)
3311
#define MCF_RTC_CR_XTL(x) (((x)&0x00000003)<<5)
3312
#define MCF_RTC_CR_EN (0x00000080)
3313
#define MCF_RTC_CR_32768 (0x0)
3314
#define MCF_RTC_CR_32000 (0x1)
3315
#define MCF_RTC_CR_38400 (0x2)
3316
3317
/* Bit definitions and macros for MCF_RTC_ISR */
3318
#define MCF_RTC_ISR_SW (0x00000001)
3319
#define MCF_RTC_ISR_MIN (0x00000002)
3320
#define MCF_RTC_ISR_ALM (0x00000004)
3321
#define MCF_RTC_ISR_DAY (0x00000008)
3322
#define MCF_RTC_ISR_1HZ (0x00000010)
3323
#define MCF_RTC_ISR_HR (0x00000020)
3324
#define MCF_RTC_ISR_2HZ (0x00000080)
3325
#define MCF_RTC_ISR_SAM0 (0x00000100)
3326
#define MCF_RTC_ISR_SAM1 (0x00000200)
3327
#define MCF_RTC_ISR_SAM2 (0x00000400)
3328
#define MCF_RTC_ISR_SAM3 (0x00000800)
3329
#define MCF_RTC_ISR_SAM4 (0x00001000)
3330
#define MCF_RTC_ISR_SAM5 (0x00002000)
3331
#define MCF_RTC_ISR_SAM6 (0x00004000)
3332
#define MCF_RTC_ISR_SAM7 (0x00008000)
3333
3334
/* Bit definitions and macros for MCF_RTC_IER */
3335
#define MCF_RTC_IER_SW (0x00000001)
3336
#define MCF_RTC_IER_MIN (0x00000002)
3337
#define MCF_RTC_IER_ALM (0x00000004)
3338
#define MCF_RTC_IER_DAY (0x00000008)
3339
#define MCF_RTC_IER_1HZ (0x00000010)
3340
#define MCF_RTC_IER_HR (0x00000020)
3341
#define MCF_RTC_IER_2HZ (0x00000080)
3342
#define MCF_RTC_IER_SAM0 (0x00000100)
3343
#define MCF_RTC_IER_SAM1 (0x00000200)
3344
#define MCF_RTC_IER_SAM2 (0x00000400)
3345
#define MCF_RTC_IER_SAM3 (0x00000800)
3346
#define MCF_RTC_IER_SAM4 (0x00001000)
3347
#define MCF_RTC_IER_SAM5 (0x00002000)
3348
#define MCF_RTC_IER_SAM6 (0x00004000)
3349
#define MCF_RTC_IER_SAM7 (0x00008000)
3350
3351
/* Bit definitions and macros for MCF_RTC_STPWCH */
3352
#define MCF_RTC_STPWCH_CNT(x) (((x)&0x0000003F)<<0)
3353
3354
/* Bit definitions and macros for MCF_RTC_DAYS */
3355
#define MCF_RTC_DAYS_DAYS(x) (((x)&0x0000FFFF)<<0)
3356
3357
/* Bit definitions and macros for MCF_RTC_ALRM_DAY */
3358
#define MCF_RTC_ALRM_DAY_DAYS(x) (((x)&0x0000FFFF)<<0)
3359
3360
3361
3362
#endif
/* __MCF5223x_H__ */
vuint8
volatile unsigned char vuint8
Definition
mcf5223x.h:9
