RTEMS
6.3
Toggle main menu visibility
bsps
m68k
include
mcf548x
mcdma_glue.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS generic mcf548x BSP
5
6
* This file declares glue functions to the Freescale Mcdma API.
7
8
9
10
* Copyright (C) 2004, 2009 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef _MCDMA_GLUE_H
35
#define _MCDMA_GLUE_H
36
37
rtems.h
38
rtems/irq.h
39
#include <mcf548x/mcf548x.h>
40
41
#define MCDMA_CLR_PENDING(chan) (MCF548X_DMA_DIPR = (1 << (chan)))
42
#define MCDMA_GET_PENDING(chan) (MCF548X_DMA_DIPR & (1 << (chan)))
43
44
45
| Function: |
46
47
void
mcdma_glue_irq_enable
48
49
50
| Purpose: |
51
| enable interrupt for given task number |
52
53
| Input Parameters: |
54
55
int
mcdma_taskno
/* task number to enable */
56
57
58
| Return Value: |
59
| none |
60
61
62
63
| Function: |
64
65
void
mcdma_glue_irq_disable
66
67
68
| Purpose: |
69
| disable interrupt for given task number |
70
71
| Input Parameters: |
72
73
int
mcdma_taskno
/* task number to disable */
74
75
76
| Return Value: |
77
| none |
78
79
80
81
| Function: |
82
83
void
mcdma_glue_irq_install
84
85
86
| Purpose: |
87
| install given function as mcdma interrupt handler |
88
89
| Input Parameters: |
90
91
int
mcdma_taskno,
/* task number for handler */
92
void
(*the_handler)(rtems_irq_hdl_param),
/* function to call */
93
void
*the_param
94
95
96
| Return Value: |
97
| none |
98
99
100
101
| Function: |
102
103
void
mcdma_glue_init
104
105
106
| Purpose: |
107
| initialize the mcdma module (if not yet done): |
108
| - load code |
109
| - initialize registers |
110
| - initialize bus arbiter |
111
| - initialize interrupt control |
112
113
| Input Parameters: |
114
115
void
*sram_base
/* base address for SRAM, to be used for DMA task */
116
117
118
| Return Value: |
119
| none |
120
121
122
#endif
/* _MCDMA_GLUE_H */
irq.h
rtems.h
