RTEMS 6.3
mc68681_reg.c
2
3/*
4 * This file contains a typical set of register access routines which may be
5 * used with the mc68681 chip if accesses to the chip are as follows:
6 *
7 * + registers are accessed as bytes
8 * + registers are only byte-aligned (no address gaps)
9 *
10 * COPYRIGHT (c) 1989-1997.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#include <rtems.h>
36
37#include <libchip/serial.h>
38#include <libchip/mc68681.h>
39
40#ifndef _MC68681_MULTIPLIER
41#define _MC68681_MULTIPLIER 1
42#define _MC68681_NAME(_X) _X
43#define _MC68681_TYPE uint8_t
44#endif
45
46#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
47 (_MC68681_TYPE *)((_base) + ((_reg) * _MC68681_MULTIPLIER ))
48
49/*
50 * MC68681 Get Register Routine
51 */
52
53uint8_t _MC68681_NAME(mc68681_get_register)(
54 uintptr_t ulCtrlPort,
55 uint8_t ucRegNum
56)
57{
58 _MC68681_TYPE *port;
59
60 port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
61
62 return *port;
63}
64
65/*
66 * MC68681 Set Register Routine
67 */
68
69void _MC68681_NAME(mc68681_set_register)(
70 uintptr_t ulCtrlPort,
71 uint8_t ucRegNum,
72 uint8_t ucData
73)
74{
75 _MC68681_TYPE *port;
76
77 port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
78
79 *port = ucData;
80}
The generic libchip serial driver interface.
