RTEMS 6.3
tm27.h
1/*
2 * @file
3 * @ingroup m68k_uC5282
4 * @brief Implementations for interrupt mechanisms for Time Test 27
5 */
6
7/*
8 * Copyright (c) 2005 Eric Norum <eric@norum.ca>
9 *
10 * COPYRIGHT (c) 2005-2014.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_TMTEST27
19#error "This is an RTEMS internal file you must not include directly."
20#endif
21
22#ifndef __tm27_h
23#define __tm27_h
24
25/*
26 * Stuff for Time Test 27
27 * Don't bother with hardware -- just use a software-interrupt
28 */
29
30#define MUST_WAIT_FOR_INTERRUPT 0
31
32#define TM27_USE_VECTOR_HANDLER
33
34#define Install_tm27_vector( handler ) set_vector( (handler), 35, 1 )
35
36#define Cause_tm27_intr() asm volatile ("trap #3");
37
38#define Clear_tm27_intr() /* empty */
39
40#define Lower_tm27_intr() /* empty */
41
42#endif
