RTEMS 6.3
tm27.h
1/*
2 * @file
3 * @ingroup m68k_mvme167
4 * @brief Implementations for interrupt mechanisms for Time Test 27
5 */
6
7/*
8 * The license and distribution terms for this file may be
9 * found in the file LICENSE in this distribution or at
10 * http://www.rtems.org/license/LICENSE.
11 */
12
13#ifndef _RTEMS_TMTEST27
14#error "This is an RTEMS internal file you must not include directly."
15#endif
16
17#ifndef __tm27_h
18#define __tm27_h
19
20/*
21 * Define the interrupt mechanism for Time Test 27
22 *
23 * NOTE: We use software interrupt 0
24 */
25#define MUST_WAIT_FOR_INTERRUPT 0
26
27#define TM27_USE_VECTOR_HANDLER
28
29#define Install_tm27_vector( handler ) \
30 set_vector( (handler), VBR1 * 0x10 + 0x8, 1 ); \
31 lcsr->intr_level[2] |= 3; \
32 lcsr->intr_ena |= 0x100
33
34#define Cause_tm27_intr() lcsr->intr_soft_set |= 0x100
35
36#define Clear_tm27_intr() lcsr->intr_clear |= 0x100
37
38#define Lower_tm27_intr() /* empty */
39
40#endif
