RTEMS
6.3
Toggle main menu visibility
bsps
sparc64
niagara
start
m5op.h
1
2
* Copyright (c) 2003-2006 The Regents of The University of Michigan
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions are
7
* met: redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer;
9
* redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution;
12
* neither the name of the copyright holders nor the names of its
13
* contributors may be used to endorse or promote products derived from
14
* this software without specific prior written permission.
15
16
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
17
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
18
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
19
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
20
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
21
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
22
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
26
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27
28
* Authors: Nathan Binkert
29
* Ali Saidi
30
31
32
#ifndef __M5OP_H__
33
#define __M5OP_H__
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
#include <stdint.h>
40
41
void
arm(uint64_t address);
42
void
quiesce(
void
43
void
quiesceNs(uint64_t ns);
44
void
quiesceCycle(uint64_t cycles);
45
uint64_t quiesceTime(
void
46
uint64_t rpns(
void
47
void
wakeCPU(uint64_t cpuid);
48
49
void
m5_exit(uint64_t ns_delay);
50
void
m5_fail(uint64_t ns_delay, uint64_t
code
51
uint64_t m5_initparam(
void
52
void
m5_checkpoint(uint64_t ns_delay, uint64_t ns_period);
53
void
m5_reset_stats(uint64_t ns_delay, uint64_t ns_period);
54
void
m5_dump_stats(uint64_t ns_delay, uint64_t ns_period);
55
void
m5_dumpreset_stats(uint64_t ns_delay, uint64_t ns_period);
56
uint64_t m5_readfile(
void
*buffer, uint64_t len, uint64_t offset);
57
uint64_t m5_writefile(
void
*buffer, uint64_t len, uint64_t offset,
const
char
*filename);
58
void
m5_debugbreak(
void
59
void
m5_switchcpu(
void
60
void
m5_addsymbol(uint64_t addr,
char
*symbol);
61
void
m5_panic(
void
62
void
m5_work_begin(uint64_t workid, uint64_t threadid);
63
void
m5_work_end(uint64_t workid, uint64_t threadid);
64
65
// These operations are for critical path annotation
66
void
m5a_bsm(
char
*sm,
const
void
id
int
flags);
67
void
m5a_esm(
char
*sm);
68
void
m5a_begin(
int
flags,
char
*st);
69
void
m5a_end(
void
70
void
m5a_q(
const
void
id
char
*q,
int
count);
71
void
m5a_dq(
const
void
id
char
*q,
int
count);
72
void
m5a_wf(
const
void
id
char
*q,
char
*sm,
int
count);
73
void
m5a_we(
const
void
id
char
*q,
char
*sm,
int
count);
74
void
m5a_ws(
const
void
id
char
*q,
char
*sm);
75
void
m5a_sq(
const
void
id
char
*q,
int
count,
int
flags);
76
void
m5a_aq(
const
void
id
char
*q,
int
count);
77
void
m5a_pq(
const
void
id
char
*q,
int
count);
78
void
m5a_l(
char
*lsm,
const
void
id
char
*sm);
79
void
m5a_identify(uint64_t
id
80
uint64_t m5a_getid(
void
81
82
#define M5_AN_FL_NONE 0x0
83
#define M5_AN_FL_BAD 0x2
84
#define M5_AN_FL_LINK 0x10
85
#define M5_AN_FL_RESET 0x20
86
87
#ifdef __cplusplus
88
89
#endif
90
#endif
// __M5OP_H__
code
Definition
inftrees.h:24
