RTEMS 6.3
m48t08_reg.c
2
3/*
4 * This file contains a typical set of register access routines which may be
5 * used with the m48t08 chip if accesses to the chip are as follows:
6 *
7 * + registers are accessed as bytes
8 * + registers are only byte-aligned (no address gaps)
9 *
10 * COPYRIGHT (c) 1989-1997.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#include <rtems.h>
36#include <libchip/rtc.h>
37#include <libchip/m48t08.h>
38
39#ifndef _M48T08_MULTIPLIER
40#define _M48T08_MULTIPLIER 1
41#define _M48T08_NAME(_X) _X
42#define _M48T08_TYPE uint8_t
43#endif
44
45#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
46 (_M48T08_TYPE *)((_base) + ((_reg) * _M48T08_MULTIPLIER ))
47
48/*
49 * M48T08 Get Register Routine
50 */
51
52uint32_t _M48T08_NAME(m48t08_get_register)(
53 uintptr_t ulCtrlPort,
54 uint8_t ucRegNum
55)
56{
57 _M48T08_TYPE *port;
58
59 port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
60
61 return *port;
62}
63
64/*
65 * M48T08 Set Register Routine
66 */
67
68void _M48T08_NAME(m48t08_set_register)(
69 uintptr_t ulCtrlPort,
70 uint8_t ucRegNum,
71 uint32_t ucData
72)
73{
74 _M48T08_TYPE *port;
75
76 port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
77
78 *port = ucData;
79}
