RTEMS
6.3
Toggle main menu visibility
bsps
m68k
gen68340
include
m340uart.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Header file for console driver
13
* defines for accessing M68340/68349 UART registers
14
15
* Author:
16
* Geoffroy Montel
17
* France Telecom - CNET/DSM/TAM/CAT
18
* 4, rue du Clos Courtel
19
* 35512 CESSON-SEVIGNE
20
* FRANCE
21
22
* e-mail: g_montel@yahoo.com
23
24
25
* COPYRIGHT (c) 1989-2008.
26
* On-Line Applications Research Corporation (OAR).
27
28
29
* modification, are permitted provided that the following conditions
30
* are met:
31
* 1. Redistributions of source code must retain the above copyright
32
* notice, this list of conditions and the following disclaimer.
33
* 2. Redistributions in binary form must reproduce the above copyright
34
* notice, this list of conditions and the following disclaimer in the
35
* documentation and/or other materials provided with the distribution.
36
37
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
38
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
39
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
40
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
41
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
42
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
43
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
44
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
45
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
46
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
47
* POSSIBILITY OF SUCH DAMAGE.
48
49
50
#ifndef __m340uart_H__
51
#define __m340uart_H__
52
53
#include <sys/types.h>
54
55
/* UART initialisation */
56
#define UART_CHANNEL_A 0
57
#define UART_CHANNEL_B 1
58
#define UART_NUMBER_OF_CHANNELS 2
59
#define UART_CONSOLE_NAME "/dev/console"
60
#define UART_RAW_IO_NAME "/dev/tty1"
61
#define UART_FIFO_FULL 0
62
#define UART_CRR 1
63
#define UART_INTERRUPTS 0
64
#define UART_POLLING 1
65
#define UART_TERMIOS_CONSOLE 0
66
#define UART_TERMIOS_RAW 1
67
#define UART_TERMIOS_MIN_DEFAULT 1
68
#define UART_TERMIOS_TIME_DEFAULT 0
69
70
void
Init_UART_Table(
void
71
72
typedef
struct
73
uint8_t enable;
74
uint16_t rx_buffer_size;
/* NOT IMPLEMENTED */
75
uint16_t tx_buffer_size;
76
uart_termios_config
77
78
typedef
struct
/* for one channel */
79
uint8_t enable;
/* use this channel */
80
char
name[64];
/* use UART_CONSOLE_NAME for console purpose */
81
uint8_t parity_mode;
/* parity mode, see MR1 section for defines */
82
uint8_t bits_per_char;
/* bits per character, see MR1 section for defines */
83
float
rx_baudrate;
/* Rx baudrate */
84
float
tx_baudrate;
/* Tx baudrate */
85
uint8_t rx_mode;
/* FIFO Full (UART_FIFO_FULL) or ChannelReceiverReady (UART_CRR) */
86
uint8_t mode;
/* use interrupts (UART_INTERRUPTS) or polling (UART_POLLING) */
87
uart_termios_config
termios;
88
uart_channel_config
89
90
extern
uart_channel_config
m340_uart_config[UART_NUMBER_OF_CHANNELS];
91
92
typedef
struct
93
int
set;
/* number of the m340 baud speed set */
94
int
rcs;
/* RCS for the needed baud set */
95
int
tcs;
/* TCS for the needed baud set */
96
t_baud_speed
97
98
typedef
struct
99
t_baud_speed
baud_speed_table[2];
100
short
nb;
101
t_baud_speed_table
102
103
extern
t_baud_speed_table
104
Find_Right_m340_UART_Config(
float
ChannelA_ReceiverBaudRate,
float
ChannelA_TransmitterBaudRate, uint8_t enableA,
105
float
ChannelB_ReceiverBaudRate,
float
ChannelB_TransmitterBaudRate, uint8_t enableB);
106
107
extern
rtems_isr
InterruptHandler (
rtems_vector_number
v);
108
109
extern
int
dbugRead (
int
minor);
110
extern
ssize_t dbugWrite (
int
minor,
const
char
*buf,
size_t
len);
111
112
extern
float
m340_Baud_Rates_Table[16][2];
113
114
/* SR */
115
#define m340_Rx_RDY 1
116
#define m340_FFULL (1<<1)
117
#define m340_Tx_RDY (1<<2)
118
#define m340_TxEMP (1<<3)
119
#define m340_OE (1<<4)
120
#define m340_PE (1<<5)
121
#define m340_FE (1<<6)
122
#define m340_RB (1<<7)
123
124
/* IER */
125
#define m340_TxRDYA 1
126
#define m340_RxRDYA (1<<1)
127
#define m340_TxRxRDYA 0x3
128
#define m340_TxRDYB (1<<4)
129
#define m340_RxRDYB (1<<5)
130
#define m340_TxRxRDYB 0x30
131
132
/* CR */
133
#define m340_Reset_Error_Status 0x40
134
#define m340_Reset_Receiver 0x20
135
#define m340_Reset_Transmitter 0x30
136
#define m340_Transmitter_Enable (1<<2)
137
#define m340_Receiver_Enable 1
138
#define m340_Transmitter_Disable (2<<2)
139
#define m340_Receiver_Disable 2
140
141
/* ACR */
142
#define m340_BRG_Set1 0
143
#define m340_BRG_Set2 (1<<7)
144
145
/* OPCR */
146
#define m340_OPCR_Gal 0x0
147
#define m340_OPCR_Aux 0xFF
148
149
/* ISR */
150
#define m340_COS (1<<7)
151
#define m340_DBB (1<<6)
152
#define m340_XTAL_RDY (1<<3)
153
#define m340_DBA (1<<2)
154
155
/* MR1 */
156
#define m340_RxRTS (1<<7)
157
#define m340_R_F (1<<6)
/* character or block mode */
158
#define m340_ERR (1<<5)
159
#define m340_RxRTX (1<<7)
160
#define m340_Even_Parity 0
161
#define m340_Odd_Parity (1<<2)
162
#define m340_Low_Parity (2<<2)
163
#define m340_High_Parity (3<<2)
164
#define m340_No_Parity (4<<2)
165
#define m340_Data_Character (6<<2)
166
#define m340_Address_Character (7<<2)
167
#define m340_5bpc 0x0
168
#define m340_6bpc 0x1
169
#define m340_7bpc 0x2
170
#define m340_8bpc 0x3
171
172
/* MR2 */
173
#define m340_normal (0<<6)
174
#define m340_automatic_echo (1<<6)
175
#define m340_local_loopback (2<<6)
176
#define m340_remote_loopback (3<<6)
177
#define m340_TxRTS (1<<5)
178
#define m340_TxCTS (1<<4)
179
180
/* Baud rates for Transmitter/Receiver */
181
#define SCLK 1
/* put your own SCLK value here */
182
183
#endif
rtems_isr
ISR_Handler rtems_isr
This type defines the return type of interrupt service routines.
Definition
intr.h:123
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition
intr.h:102
t_baud_speed_table
Definition
m340uart.h:98
t_baud_speed
Definition
m340uart.h:92
uart_channel_config
Definition
m340uart.h:78
uart_termios_config
Definition
m340uart.h:72
