RTEMS 6.3
lpc-clock-config.h
2
10
11/*
12 * Copyright (c) 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC32XX_LPC_CLOCK_CONFIG_H
37#define LIBBSP_ARM_LPC32XX_LPC_CLOCK_CONFIG_H
38
39#include <bsp.h>
40#include <bsp/irq.h>
41#include <bsp/lpc32xx.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
56
57#define LPC_CLOCK_INTERRUPT LPC32XX_IRQ_TIMER_0
58
59#define LPC_CLOCK_TIMER_BASE LPC32XX_BASE_TIMER_0
60
61#define LPC_CLOCK_TIMECOUNTER_BASE LPC32XX_BASE_TIMER_1
62
63#define LPC_CLOCK_REFERENCE LPC32XX_PERIPH_CLK
64
65#define LPC_CLOCK_MODULE_ENABLE()
66
68
69#ifdef __cplusplus
70}
71#endif /* __cplusplus */
72
73#endif /* LIBBSP_ARM_LPC32XX_LPC_CLOCK_CONFIG_H */
Register base addresses.
