RTEMS
6.3
Toggle main menu visibility
bsps
arm
lpc176x
include
bsp
lpc176x.h
1
8
9
10
* Copyright (c) 2014 Taller Technologies.
11
12
* @author Boretto Martin (martin.boretto@tallertechnologies.com)
13
* @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
14
* @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
15
* @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
16
17
* The license and distribution terms for this file may be
18
* found in the file LICENSE in this distribution or at
19
* http://www.rtems.org/license/LICENSE.
20
21
22
#ifndef LIBBSP_ARM_LPC176X_H
23
#define LIBBSP_ARM_LPC176X_H
24
25
bsp/lpc-i2s.h
26
27
#define LPC176X_PLL_CON_PLLE BSP_BIT32( 0 )
28
#define LPC176X_PLL_CON_PLLC BSP_BIT32( 1 )
29
#define LPC176X_PLL_SEL_MSEL( val ) BSP_FLD32( val, 0, 14 )
30
#define LPC176X_PLL_SEL_MSEL_GET( reg ) BSP_FLD32GET( reg, 0, 14 )
31
#define LPC176X_PLL_SEL_MSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 14 )
32
#define LPC176X_PLL_SEL_PSEL( val ) BSP_FLD32( val, 16, 23 )
33
#define LPC176X_PLL_SEL_PSEL_GET( reg ) BSP_FLD32GET( reg, 16, 23 )
34
#define LPC176X_PLL_SEL_PSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 16, 23 )
35
#define LPC176X_PLL_STAT_PLLE BSP_BIT32( 24 )
36
#define LPC176X_PLL_STAT_PLLC BSP_BIT32( 25 )
37
#define LPC176X_PLL_STAT_PLOCK BSP_BIT32( 26 )
38
42
typedef
struct
46
uint32_t
con
50
uint32_t
cfg
54
uint32_t
stat
58
uint32_t
feed
59
lpc176x_pll
60
61
#define LPC176X_SCB_BASE_ADDR 0x400FC000U
62
#define LPC176X_SCB_FLASHCFG_FLASHTIM( val ) BSP_FLD32( val, 12, 15 )
63
#define LPC176X_SCB_FLASHCFG_FLASHTIM_GET( reg ) BSP_FLD32GET( reg, 12, 15 )
64
#define LPC176X_SCB_FLASHCFG_FLASHTIM_SET( reg, val ) BSP_FLD32SET( reg, val, \
65
12, 15 )
66
#define LPC176X_SCB_MEMMAP_MAP BSP_BIT32( 0 )
67
/* POWER MODE CONTROL REGISTER (PCON) */
68
/* Power mode control bit 0 */
69
#define LPC176X_SCB_PCON_PM0 BSP_BIT32( 0 )
70
/* Power mode control bit 1 */
71
#define LPC176X_SCB_PCON_PM1 BSP_BIT32( 1 )
72
/* Brown-Out Reduced ower Down */
73
#define LPC176X_SCB_PCON_BODRPM BSP_BIT32( 2 )
74
/* Brown-Out Global Disable */
75
#define LPC176X_SCB_PCON_BOGD BSP_BIT32( 3 )
76
/* Brown-Out Reset Disable */
77
#define LPC176X_SCB_PCON_BORD BSP_BIT32( 4 )
78
/* Sleep Mode entry flag */
79
#define LPC176X_SCB_PCON_SMFLAG BSP_BIT32( 8 )
80
/* Deep Sleep entry flag */
81
#define LPC176X_SCB_PCON_DSFLAG BSP_BIT32( 9 )
82
/* Power-Down entry flag */
83
#define LPC176X_SCB_PCON_PDFLAG BSP_BIT32( 10 )
84
/* Deep Power-Down entry flag */
85
#define LPC176X_SCB_PCON_DPDFLAG BSP_BIT32( 11 )
86
/* POWER CONTROL for PERIPHERALS REGISTER (PCONP) */
87
/* 0 - Reserved */
88
/* Timer/Counter 0 power/clock control bit */
89
#define LPC176X_SCB_PCONP_TIMER_0 BSP_BIT32( 1 )
90
/* Timer/Counter 1 power/clock control bit */
91
#define LPC176X_SCB_PCONP_TIMER_1 BSP_BIT32( 2 )
92
/* UART 0 power/clock control bit */
93
#define LPC176X_SCB_PCONP_UART_0 BSP_BIT32( 3 )
94
/* UART 1 power/clock control bit */
95
#define LPC176X_SCB_PCONP_UART_1 BSP_BIT32( 4 )
96
/* 5 - Reserved */
97
/* PWM 1 power/clock control bit */
98
#define LPC176X_SCB_PCONP_PWM_0 BSP_BIT32( 6 )
99
/* The I2C0 interface power/clock control bit */
100
#define LPC176X_SCB_PCONP_I2C_0 BSP_BIT32( 7 )
101
/* The SPI interface power/clock control bit */
102
#define LPC176X_SCB_PCONP_SPI BSP_BIT32( 8 )
103
/* The RTC power/clock control bit */
104
#define LPC176X_SCB_PCONP_RTC BSP_BIT32( 9 )
105
/* The SSP1 interface power/clock control bit */
106
#define LPC176X_SCB_PCONP_SSP_1 BSP_BIT32( 10 )
107
/* 11 - Reserved */
108
/* A/D converter (ADC) power/clock control bit */
109
#define LPC176X_SCB_PCONP_ADC BSP_BIT32( 12 )
110
/* CAN Controller 1 power/clock control bit */
111
#define LPC176X_SCB_PCONP_CAN_1 BSP_BIT32( 13 )
112
/* CAN Controller 2 power/clock control bit */
113
#define LPC176X_SCB_PCONP_CAN_2 BSP_BIT32( 14 )
114
/* Power/clock control bit for IOCON, GPIO, and GPIO interrupts*/
115
#define LPC176X_SCB_PCONP_GPIO BSP_BIT32( 15 )
116
/* Repetitive Interrupt Timer power/clock control bit */
117
#define LPC176X_SCB_PCONP_RIT BSP_BIT32( 16 )
118
/* Motor Control PWM */
119
#define LPC176X_SCB_PCONP_MCPWM BSP_BIT32( 17 )
120
/* Quadrate Encoder Interface power/clock control bit */
121
#define LPC176X_SCB_PCONP_QEI BSP_BIT32( 18 )
122
/* The IC21 interface power/clock control bit */
123
#define LPC176X_SCB_PCONP_I2C_1 BSP_BIT32( 19 )
124
/* 20 - Reserved */
125
/* The SSP0 interface power/clock control bit */
126
#define LPC176X_SCB_PCONP_SSP_0 BSP_BIT32( 21 )
127
/* Timer 2 power/clock control bit */
128
#define LPC176X_SCB_PCONP_TIMER_2 BSP_BIT32( 22 )
129
/* Timer 3 power/clock control bit */
130
#define LPC176X_SCB_PCONP_TIMER_3 BSP_BIT32( 23 )
131
/* UART 2 power/clock control bit */
132
#define LPC176X_SCB_PCONP_UART_2 BSP_BIT32( 24 )
133
/* UART 3 power/clock control bit */
134
#define LPC176X_SCB_PCONP_UART_3 BSP_BIT32( 25 )
135
/* I2C interface 2 power/clock control bit */
136
#define LPC176X_SCB_PCONP_I2C_2 BSP_BIT32( 26 )
137
/* I2S interface power/clock control bit */
138
#define LPC176X_SCB_PCONP_I2S BSP_BIT32( 27 )
139
/* 28 - Reserved */
140
/* GPDMA function power/clock control bit */
141
#define LPC176X_SCB_PCONP_GPDMA BSP_BIT32( 29 )
142
/* Ethernet block power/clock control bit */
143
#define LPC176X_SCB_PCONP_ENET BSP_BIT32( 30 )
144
/* USB interface power/clock control bit */
145
#define LPC176X_SCB_PCONP_USB BSP_BIT32( 31 )
146
#define LPC176X_SCB_CCLKSEL_CCLKDIV( val ) BSP_FLD32( val, 0, 7 )
147
#define LPC176X_SCB_CCLKSEL_CCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 7 )
148
#define LPC176X_SCB_CCLKSEL_CCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \
149
val, \
150
0, \
151
7 )
152
#define LPC176X_SCB_CCLKSEL_CCLKSEL BSP_BIT32( 8 )
153
#define LPC176X_SCB_USBCLKSEL_USBDIV( val ) BSP_FLD32( val, 0, 4 )
154
#define LPC176X_SCB_USBCLKSEL_USBDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )
155
#define LPC176X_SCB_USBCLKSEL_USBDIV_SET( reg, val ) BSP_FLD32SET( reg, \
156
val, \
157
0, \
158
4 )
159
#define LPC176X_SCB_USBCLKSEL_USBSEL( val ) BSP_FLD32( val, 8, 9 )
160
#define LPC176X_SCB_USBCLKSEL_USBSEL_GET( reg ) BSP_FLD32GET( reg, 8, 9 )
161
#define LPC176X_SCB_USBCLKSEL_USBSEL_SET( reg, val ) BSP_FLD32SET( reg, \
162
val, \
163
8, \
164
9 )
165
#define LPC176X_SCB_CLKSRCSEL_CLKSRC BSP_BIT32( 0 )
166
#define LPC176X_SCB_SCS_MCIPWR BSP_BIT32( 3 )
167
#define LPC176X_SCB_SCS_OSC_RANGE_SEL BSP_BIT32( 4 )
168
#define LPC176X_SCB_SCS_OSC_ENABLE BSP_BIT32( 5 )
169
#define LPC176X_SCB_SCS_OSC_STATUS BSP_BIT32( 6 )
170
#define LPC176X_SCB_PCLKSEL_PCLKDIV( val ) BSP_FLD32( val, 0, 4 )
171
#define LPC176X_SCB_PCLKSEL_PCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )
172
#define LPC176X_SCB_PCLKSEL_PCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \
173
val, \
174
0, \
175
4 )
176
#define LPC176X_SCB_PBOOST_BOOST BSP_BIT32( 0 )
177
#define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL( val ) BSP_FLD32( val, 3, 0 )
178
#define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_GET( reg ) BSP_FLD32GET( reg, 3, 0 )
179
#define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_SET( reg, val ) BSP_FLD32SET( reg, \
180
val, 3, 0 )
181
#define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV( val ) BSP_FLD32( val, 7, 4 )
182
#define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_GET( reg ) BSP_FLD32GET( reg, 7, 4 )
183
#define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_SET( reg, val ) BSP_FLD32SET( reg, \
184
val, 7, 4 )
185
#define LPC176X_SCB_CLKOUTCFG_CLKOUT_EN BSP_BIT32( 8 )
186
#define LPC176X_SCB_CLKOUTCFG_CLKOUT_ACT BSP_BIT32( 9 )
187
191
typedef
struct
195
uint32_t
flashcfg
196
uint32_t reserved_04[ 15 ];
200
uint32_t
memmap
201
uint32_t reserved_44[ 15 ];
205
lpc176x_pll
pll_0
206
uint32_t reserved_90[ 4 ];
210
lpc176x_pll
pll_1
211
uint32_t reserved_b0[ 4 ];
215
uint32_t
pcon
219
uint32_t
pconp
220
uint32_t reserved_c8[ 15 ];
225
uint32_t
cclksel
230
uint32_t
usbclksel
234
uint32_t
clksrcsel
235
uint32_t reserved_110[ 12 ];
239
uint32_t
extint
240
uint32_t reserved_144;
244
uint32_t
extmode
248
uint32_t
extpolar
249
uint32_t reserved_150[ 12 ];
253
uint32_t
rsid
254
uint32_t reserved_184[ 7 ];
258
uint32_t
scs
259
uint32_t reserved_1a4;
263
uint32_t
pclksel
[ 2 ];
267
uint32_t
pboost
268
uint32_t reserved_1b4[ 5 ];
272
uint32_t
clkoutcfg
276
uint32_t
rstcon
[ 2 ];
277
uint32_t reserved_1d4[ 4 ];
278
lpc176x_scb
279
280
#define LPC176X_BASE 0x00u
281
#define LPC176X_SCB ( *(volatile lpc176x_scb *) ( LPC176X_SCB_BASE_ADDR ) )
282
283
/* Fast I/O setup */
284
#define LPC176X_FIO_BASE_ADDR 0x2009C000U
285
#define LPC176X_FIO ( (volatile lpc176x_fio *) LPC176X_FIO_BASE_ADDR )
286
287
#define FIO0DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
288
#define FIO0MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
289
#define FIO0PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
290
#define FIO0SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
291
#define FIO0CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
292
293
#define FIO1DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
294
#define FIO1MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
295
#define FIO1PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
296
#define FIO1SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
297
#define FIO1CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
298
299
#define FIO2DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
300
#define FIO2MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
301
#define FIO2PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
302
#define FIO2SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
303
#define FIO2CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
304
305
#define FIO3DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
306
#define FIO3MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
307
#define FIO3PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
308
#define FIO3SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
309
#define FIO3CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
310
311
#define FIO4DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
312
#define FIO4MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
313
#define FIO4PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
314
#define FIO4SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
315
#define FIO4CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
316
317
/* FIOs can be accessed through WORD, HALF-WORD or BYTE. */
318
#define FIO0DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
319
#define FIO1DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
320
#define FIO2DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
321
#define FIO3DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
322
#define FIO4DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
323
324
#define FIO0DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x01U ) )
325
#define FIO1DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )
326
#define FIO2DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x41U ) )
327
#define FIO3DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x61U ) )
328
#define FIO4DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x81U ) )
329
330
#define FIO0DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )
331
#define FIO1DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )
332
#define FIO2DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )
333
#define FIO3DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )
334
#define FIO4DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )
335
336
#define FIO0DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x03U ) )
337
#define FIO1DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x23U ) )
338
#define FIO2DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x43U ) )
339
#define FIO3DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x63U ) )
340
#define FIO4DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x83U ) )
341
342
#define FIO0DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
343
#define FIO1DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
344
#define FIO2DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
345
#define FIO3DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
346
#define FIO4DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
347
348
#define FIO0DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )
349
#define FIO1DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )
350
#define FIO2DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )
351
#define FIO3DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )
352
#define FIO4DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )
353
354
#define FIO0MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
355
#define FIO1MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
356
#define FIO2MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
357
#define FIO3MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
358
#define FIO4MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
359
360
#define FIO0MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x11U ) )
361
#define FIO1MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )
362
#define FIO2MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x51U ) )
363
#define FIO3MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x71U ) )
364
#define FIO4MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x91U ) )
365
366
#define FIO0MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )
367
#define FIO1MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )
368
#define FIO2MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )
369
#define FIO3MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )
370
#define FIO4MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )
371
372
#define FIO0MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x13U ) )
373
#define FIO1MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x33U ) )
374
#define FIO2MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x53U ) )
375
#define FIO3MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x73U ) )
376
#define FIO4MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x93U ) )
377
378
#define FIO0MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
379
#define FIO1MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
380
#define FIO2MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
381
#define FIO3MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
382
#define FIO4MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
383
384
#define FIO0MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )
385
#define FIO1MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )
386
#define FIO2MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )
387
#define FIO3MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )
388
#define FIO4MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )
389
390
#define FIO0PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
391
#define FIO1PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
392
#define FIO2PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
393
#define FIO3PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
394
#define FIO4PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
395
396
#define FIO0PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x15U ) )
397
#define FIO1PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x25U ) )
398
#define FIO2PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x55U ) )
399
#define FIO3PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x75U ) )
400
#define FIO4PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x95U ) )
401
402
#define FIO0PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )
403
#define FIO1PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )
404
#define FIO2PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )
405
#define FIO3PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )
406
#define FIO4PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )
407
408
#define FIO0PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x17U ) )
409
#define FIO1PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x37U ) )
410
#define FIO2PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x57U ) )
411
#define FIO3PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x77U ) )
412
#define FIO4PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x97U ) )
413
414
#define FIO0PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
415
#define FIO1PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
416
#define FIO2PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
417
#define FIO3PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
418
#define FIO4PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
419
420
#define FIO0PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )
421
#define FIO1PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )
422
#define FIO2PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )
423
#define FIO3PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )
424
#define FIO4PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )
425
426
#define FIO0SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
427
#define FIO1SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
428
#define FIO2SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
429
#define FIO3SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
430
#define FIO4SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
431
432
#define FIO0SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x19U ) )
433
#define FIO1SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x29U ) )
434
#define FIO2SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x59U ) )
435
#define FIO3SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x79U ) )
436
#define FIO4SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x99U ) )
437
438
#define FIO0SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )
439
#define FIO1SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )
440
#define FIO2SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )
441
#define FIO3SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )
442
#define FIO4SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )
443
444
#define FIO0SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1BU ) )
445
#define FIO1SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3BU ) )
446
#define FIO2SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5BU ) )
447
#define FIO3SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7BU ) )
448
#define FIO4SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9BU ) )
449
450
#define FIO0SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
451
#define FIO1SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
452
#define FIO2SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
453
#define FIO3SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
454
#define FIO4SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
455
456
#define FIO0SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )
457
#define FIO1SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )
458
#define FIO2SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )
459
#define FIO3SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )
460
#define FIO4SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )
461
462
#define FIO0CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
463
#define FIO1CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
464
#define FIO2CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
465
#define FIO3CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
466
#define FIO4CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
467
468
#define FIO0CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1DU ) )
469
#define FIO1CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x2DU ) )
470
#define FIO2CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5DU ) )
471
#define FIO3CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7DU ) )
472
#define FIO4CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9DU ) )
473
474
#define FIO0CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )
475
#define FIO1CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )
476
#define FIO2CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )
477
#define FIO3CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )
478
#define FIO4CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9EU ) )
479
480
#define FIO0CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1FU ) )
481
#define FIO1CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3FU ) )
482
#define FIO2CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5FU ) )
483
#define FIO3CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7FU ) )
484
#define FIO4CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9FU ) )
485
486
#define FIO0CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
487
#define FIO1CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
488
#define FIO2CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
489
#define FIO3CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
490
#define FIO4CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
491
492
#define FIO0CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )
493
#define FIO1CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )
494
#define FIO2CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )
495
#define FIO3CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )
496
#define FIO4CLRU ( *(volatile uint16_t *) ( FIO_BASE_ADDR + 0x9EU ) )
497
498
#define LPC176X_USB_CLOCK 48000000U
499
#define LPC176X_MODULE_CLOCK_MASK 0x3U
500
501
/* Pin Connect Block */
502
#define PINSEL_BASE_ADDR 0x4002C000U
503
504
#define PINSEL0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x00U ) )
505
#define PINSEL1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x04U ) )
506
#define PINSEL2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x08U ) )
507
#define PINSEL3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x0CU ) )
508
#define PINSEL4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x10U ) )
509
#define PINSEL5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x14U ) )
510
#define PINSEL6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x18U ) )
511
#define PINSEL7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x1CU ) )
512
#define PINSEL8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x20U ) )
513
#define PINSEL9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x24U ) )
514
#define PINSEL10 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x28U ) )
515
#define PINSEL11 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x2CU ) )
516
517
#define PINMODE0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x40U ) )
518
#define PINMODE1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x44U ) )
519
#define PINMODE2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x48U ) )
520
#define PINMODE3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x4CU ) )
521
#define PINMODE4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x50U ) )
522
#define PINMODE5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x54U ) )
523
#define PINMODE6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x58U ) )
524
#define PINMODE7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x5CU ) )
525
#define PINMODE8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x60U ) )
526
#define PINMODE9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x64U ) )
527
528
/* Pulse Width Modulator (PWM) */
529
#define PWM0_BASE_ADDR 0x40014000
530
531
#define PWM0IR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x00 ) )
532
#define PWM0TCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x04 ) )
533
#define PWM0TC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x08 ) )
534
#define PWM0PR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x0C ) )
535
#define PWM0PC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x10 ) )
536
#define PWM0MCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x14 ) )
537
#define PWM0MR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x18 ) )
538
#define PWM0MR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x1C ) )
539
#define PWM0MR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x20 ) )
540
#define PWM0MR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x24 ) )
541
#define PWM0CCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x28 ) )
542
#define PWM0CR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x2C ) )
543
#define PWM0CR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x30 ) )
544
#define PWM0CR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x34 ) )
545
#define PWM0CR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x38 ) )
546
#define PWM0EMR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x3C ) )
547
#define PWM0MR4 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x40 ) )
548
#define PWM0MR5 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x44 ) )
549
#define PWM0MR6 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x48 ) )
550
#define PWM0PCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x4C ) )
551
#define PWM0LER ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x50 ) )
552
#define PWM0CTCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x70 ) )
553
554
#define PWM1_BASE_ADDR 0x40018000
555
556
#define PWM1IR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x00 ) )
557
#define PWM1TCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x04 ) )
558
#define PWM1TC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x08 ) )
559
#define PWM1PR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x0C ) )
560
#define PWM1PC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x10 ) )
561
#define PWM1MCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x14 ) )
562
#define PWM1MR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x18 ) )
563
#define PWM1MR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x1C ) )
564
#define PWM1MR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x20 ) )
565
#define PWM1MR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x24 ) )
566
#define PWM1CCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x28 ) )
567
#define PWM1CR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x2C ) )
568
#define PWM1CR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x30 ) )
569
#define PWM1CR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x34 ) )
570
#define PWM1CR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x38 ) )
571
#define PWM1EMR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x3C ) )
572
#define PWM1MR4 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x40 ) )
573
#define PWM1MR5 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x44 ) )
574
#define PWM1MR6 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x48 ) )
575
#define PWM1PCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x4C ) )
576
#define PWM1LER ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x50 ) )
577
#define PWM1CTCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x70 ) )
578
579
/* Universal Asynchronous Receiver Transmitter 0 (UART0) */
580
#define UART0_BASE_ADDR 0x4000C000
581
582
#define U0RBR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
583
#define U0THR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
584
#define U0DLL ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
585
#define U0DLM ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )
586
#define U0IER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )
587
#define U0IIR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )
588
#define U0FCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )
589
#define U0LCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x0C ) )
590
#define U0LSR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x14 ) )
591
#define U0SCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x1C ) )
592
#define U0ACR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x20 ) )
593
#define U0ICR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x24 ) )
594
#define U0FDR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x28 ) )
595
#define U0TER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x30 ) )
596
597
/* Universal Asynchronous Receiver Transmitter 1 (UART1) */
598
#define UART1_BASE_ADDR 0x40010000
599
600
#define U1RBR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
601
#define U1THR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
602
#define U1DLL ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
603
#define U1DLM ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )
604
#define U1IER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )
605
#define U1IIR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )
606
#define U1FCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )
607
#define U1LCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x0C ) )
608
#define U1MCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x10 ) )
609
#define U1LSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x14 ) )
610
#define U1MSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x18 ) )
611
#define U1SCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x1C ) )
612
#define U1ACR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x20 ) )
613
#define U1FDR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x28 ) )
614
#define U1TER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x30 ) )
615
616
/* Universal Asynchronous Receiver Transmitter 2 (UART2) */
617
#define UART2_BASE_ADDR 0x40098000
618
619
#define U2RBR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
620
#define U2THR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
621
#define U2DLL ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
622
#define U2DLM ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )
623
#define U2IER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )
624
#define U2IIR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )
625
#define U2FCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )
626
#define U2LCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x0C ) )
627
#define U2LSR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x14 ) )
628
#define U2SCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x1C ) )
629
#define U2ACR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x20 ) )
630
#define U2ICR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x24 ) )
631
#define U2FDR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x28 ) )
632
#define U2TER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x30 ) )
633
634
/* Universal Asynchronous Receiver Transmitter 3 (UART3) */
635
#define UART3_BASE_ADDR 0x4009C000
636
637
#define U3RBR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
638
#define U3THR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
639
#define U3DLL ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
640
#define U3DLM ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )
641
#define U3IER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )
642
#define U3IIR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )
643
#define U3FCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )
644
#define U3LCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x0C ) )
645
#define U3LSR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x14 ) )
646
#define U3SCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x1C ) )
647
#define U3ACR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x20 ) )
648
#define U3ICR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x24 ) )
649
#define U3FDR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x28 ) )
650
#define U3TER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x30 ) )
651
652
/* SPI0 (Serial Peripheral Interface 0) */
653
#define SPI0_BASE_ADDR 0xE0020000
654
#define S0SPCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x00 ) )
655
#define S0SPSR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x04 ) )
656
#define S0SPDR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x08 ) )
657
#define S0SPCCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x0C ) )
658
#define S0SPINT ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x1C ) )
659
660
/* Real Time Clock */
661
#define RTC_BASE_ADDR 0x40024000
662
663
#define RTC_ILR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x00 ) )
664
#define RTC_CTC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x04 ) )
665
#define RTC_CCR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x08 ) )
666
#define RTC_CIIR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x0C ) )
667
#define RTC_AMR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x10 ) )
668
#define RTC_CTIME0 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x14 ) )
669
#define RTC_CTIME1 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x18 ) )
670
#define RTC_CTIME2 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x1C ) )
671
#define RTC_SEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x20 ) )
672
#define RTC_MIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x24 ) )
673
#define RTC_HOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x28 ) )
674
#define RTC_DOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x2C ) )
675
#define RTC_DOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x30 ) )
676
#define RTC_DOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x34 ) )
677
#define RTC_MONTH ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x38 ) )
678
#define RTC_YEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x3C ) )
679
#define RTC_CISS ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x40 ) )
680
#define RTC_ALSEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x60 ) )
681
#define RTC_ALMIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x64 ) )
682
#define RTC_ALHOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x68 ) )
683
#define RTC_ALDOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x6C ) )
684
#define RTC_ALDOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x70 ) )
685
#define RTC_ALDOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x74 ) )
686
#define RTC_ALMON ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x78 ) )
687
#define RTC_ALYEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x7C ) )
688
#define RTC_PREINT ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x80 ) )
689
#define RTC_PREFRAC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x84 ) )
690
691
/* A/D Converter 0 (AD0) */
692
#define AD0_BASE_ADDR 0x40034000
693
694
#define AD0CR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x00 ) )
695
#define AD0GDR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x04 ) )
696
#define AD0INTEN ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x0C ) )
697
#define AD0_DATA_START ( (volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )
698
#define AD0DR0 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )
699
#define AD0DR1 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x14 ) )
700
#define AD0DR2 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x18 ) )
701
#define AD0DR3 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x1C ) )
702
#define AD0DR4 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x20 ) )
703
#define AD0DR5 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x24 ) )
704
#define AD0DR6 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x28 ) )
705
#define AD0DR7 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x2C ) )
706
#define AD0STAT ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x30 ) )
707
708
/* D/A Converter */
709
#define DAC_BASE_ADDR 0x4008C000
710
711
#define DACR ( *(volatile uint32_t *) ( DAC_BASE_ADDR + 0x00 ) )
712
713
/* CAN CONTROLLERS AND ACCEPTANCE FILTER */
714
#define CAN_ACCEPT_BASE_ADDR 0x4003C000
715
716
#define CAN_AFMR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x00 ) )
717
#define CAN_SFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x04 ) )
718
#define CAN_SFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
719
0x08 ) )
720
#define CAN_EFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x0C ) )
721
#define CAN_EFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
722
0x10 ) )
723
#define CAN_EOT ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x14 ) )
724
#define CAN_LUT_ERR_ADR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
725
0x18 ) )
726
#define CAN_LUT_ERR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x1C ) )
727
728
#define CAN_CENTRAL_BASE_ADDR 0x40040000
729
730
#define CAN_TX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x00 ) )
731
#define CAN_RX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x04 ) )
732
#define CAN_MSR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x08 ) )
733
734
#define CAN1_BASE_ADDR 0x40044000
735
736
#define CAN1MOD ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x00 ) )
737
#define CAN1CMR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x04 ) )
738
#define CAN1GSR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x08 ) )
739
#define CAN1ICR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x0C ) )
740
#define CAN1IER ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x10 ) )
741
#define CAN1BTR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x14 ) )
742
#define CAN1EWL ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x18 ) )
743
#define CAN1SR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x1C ) )
744
#define CAN1RFS ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x20 ) )
745
#define CAN1RID ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x24 ) )
746
#define CAN1RDA ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x28 ) )
747
#define CAN1RDB ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x2C ) )
748
749
#define CAN1TFI1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x30 ) )
750
#define CAN1TID1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x34 ) )
751
#define CAN1TDA1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x38 ) )
752
#define CAN1TDB1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x3C ) )
753
#define CAN1TFI2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x40 ) )
754
#define CAN1TID2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x44 ) )
755
#define CAN1TDA2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x48 ) )
756
#define CAN1TDB2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x4C ) )
757
#define CAN1TFI3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x50 ) )
758
#define CAN1TID3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x54 ) )
759
#define CAN1TDA3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x58 ) )
760
#define CAN1TDB3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x5C ) )
761
762
#define CAN2_BASE_ADDR 0x40048000
763
764
#define CAN2MOD ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x00 ) )
765
#define CAN2CMR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x04 ) )
766
#define CAN2GSR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x08 ) )
767
#define CAN2ICR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x0C ) )
768
#define CAN2IER ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x10 ) )
769
#define CAN2BTR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x14 ) )
770
#define CAN2EWL ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x18 ) )
771
#define CAN2SR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x1C ) )
772
#define CAN2RFS ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x20 ) )
773
#define CAN2RID ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x24 ) )
774
#define CAN2RDA ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x28 ) )
775
#define CAN2RDB ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x2C ) )
776
777
#define CAN2TFI1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x30 ) )
778
#define CAN2TID1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x34 ) )
779
#define CAN2TDA1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x38 ) )
780
#define CAN2TDB1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x3C ) )
781
#define CAN2TFI2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x40 ) )
782
#define CAN2TID2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x44 ) )
783
#define CAN2TDA2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x48 ) )
784
#define CAN2TDB2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x4C ) )
785
#define CAN2TFI3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x50 ) )
786
#define CAN2TID3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x54 ) )
787
#define CAN2TDA3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x58 ) )
788
#define CAN2TDB3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x5C ) )
789
790
/* MultiMedia Card Interface(MCI) Controller */
791
#define MCI_BASE_ADDR 0x400c0000
792
793
#define MCI_POWER ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x00 ) )
794
#define MCI_CLOCK ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x04 ) )
795
#define MCI_ARGUMENT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x08 ) )
796
#define MCI_COMMAND ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x0C ) )
797
#define MCI_RESP_CMD ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x10 ) )
798
#define MCI_RESP0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x14 ) )
799
#define MCI_RESP1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x18 ) )
800
#define MCI_RESP2 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x1C ) )
801
#define MCI_RESP3 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x20 ) )
802
#define MCI_DATA_TMR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x24 ) )
803
#define MCI_DATA_LEN ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x28 ) )
804
#define MCI_DATA_CTRL ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x2C ) )
805
#define MCI_DATA_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x30 ) )
806
#define MCI_STATUS ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x34 ) )
807
#define MCI_CLEAR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x38 ) )
808
#define MCI_MASK0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x3C ) )
809
#define MCI_MASK1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x40 ) )
810
#define MCI_FIFO_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x48 ) )
811
#define MCI_FIFO ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x80 ) )
812
813
/* I2S Interface Controller (I2S) */
814
#define I2S_BASE_ADDR 0x400a8000
815
816
#define I2S_DAO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x00 ) )
817
#define I2S_DAI ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x04 ) )
818
#define I2S_TX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x08 ) )
819
#define I2S_RX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x0C ) )
820
#define I2S_STATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x10 ) )
821
#define I2S_DMA1 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x14 ) )
822
#define I2S_DMA2 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x18 ) )
823
#define I2S_IRQ ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x1C ) )
824
#define I2S_TXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x20 ) )
825
#define I2S_RXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x24 ) )
826
827
/* General-purpose DMA Controller */
828
#define DMA_BASE_ADDR 0x50004000
829
830
#define GPDMA_INT_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x000 ) )
831
#define GPDMA_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x004 ) )
832
#define GPDMA_INT_TCCLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x008 ) )
833
#define GPDMA_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x00C ) )
834
#define GPDMA_INT_ERR_CLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x010 ) )
835
#define GPDMA_RAW_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \
836
0x014 ) )
837
#define GPDMA_RAW_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \
838
0x018 ) )
839
#define GPDMA_ENABLED_CHNS ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x01C ) )
840
#define GPDMA_SOFT_BREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x020 ) )
841
#define GPDMA_SOFT_SREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x024 ) )
842
#define GPDMA_SOFT_LBREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x028 ) )
843
#define GPDMA_SOFT_LSREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x02C ) )
844
#define GPDMA_CONFIG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x030 ) )
845
#define GPDMA_SYNC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x034 ) )
846
847
/* DMA channel 0 registers */
848
#define GPDMA_CH0_BASE_ADDR ( DMA_BASE_ADDR + 0x100 )
849
#define GPDMA_CH0_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x100 ) )
850
#define GPDMA_CH0_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x104 ) )
851
#define GPDMA_CH0_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x108 ) )
852
#define GPDMA_CH0_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x10C ) )
853
#define GPDMA_CH0_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x110 ) )
854
855
/* DMA channel 1 registers */
856
#define GPDMA_CH1_BASE_ADDR ( DMA_BASE_ADDR + 0x120 )
857
#define GPDMA_CH1_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x120 ) )
858
#define GPDMA_CH1_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x124 ) )
859
#define GPDMA_CH1_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x128 ) )
860
#define GPDMA_CH1_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x12C ) )
861
#define GPDMA_CH1_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x130 ) )
862
863
/* USB Controller */
864
#define USB_INT_BASE_ADDR 0x400fc1c0
865
#define USB_BASE_ADDR 0x2008c200
866
867
#define USB_INT_STAT ( *(volatile uint32_t *) ( USB_INT_BASE_ADDR + 0x00 ) )
868
869
/* USB Device Interrupt Registers */
870
#define DEV_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x00 ) )
871
#define DEV_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x04 ) )
872
#define DEV_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x08 ) )
873
#define DEV_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x0C ) )
874
#define DEV_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x2C ) )
875
876
/* USB Device Endpoint Interrupt Registers */
877
#define EP_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x30 ) )
878
#define EP_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x34 ) )
879
#define EP_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x38 ) )
880
#define EP_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x3C ) )
881
#define EP_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x40 ) )
882
883
/* USB Device Endpoint Realization Registers */
884
#define REALIZE_EP ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x44 ) )
885
#define EP_INDEX ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x48 ) )
886
#define MAXPACKET_SIZE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x4C ) )
887
888
/* USB Device Command Reagisters */
889
#define CMD_CODE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x10 ) )
890
#define CMD_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x14 ) )
891
892
/* USB Device Data Transfer Registers */
893
#define RX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x18 ) )
894
#define TX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x1C ) )
895
#define RX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x20 ) )
896
#define TX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x24 ) )
897
#define USB_CTRL ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x28 ) )
898
899
/* USB Device DMA Registers */
900
#define DMA_REQ_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x50 ) )
901
#define DMA_REQ_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x54 ) )
902
#define DMA_REQ_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x58 ) )
903
#define UDCA_HEAD ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x80 ) )
904
#define EP_DMA_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x84 ) )
905
#define EP_DMA_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x88 ) )
906
#define EP_DMA_DIS ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x8C ) )
907
#define DMA_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x90 ) )
908
#define DMA_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x94 ) )
909
#define EOT_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA0 ) )
910
#define EOT_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA4 ) )
911
#define EOT_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA8 ) )
912
#define NDD_REQ_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xAC ) )
913
#define NDD_REQ_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB0 ) )
914
#define NDD_REQ_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB4 ) )
915
#define SYS_ERR_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB8 ) )
916
#define SYS_ERR_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xBC ) )
917
#define SYS_ERR_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xC0 ) )
918
919
/* USB Host Controller */
920
#define USBHC_BASE_ADDR 0x2008c000
921
922
#define HC_REVISION ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x00 ) )
923
#define HC_CONTROL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x04 ) )
924
#define HC_CMD_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x08 ) )
925
#define HC_INT_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x0C ) )
926
#define HC_INT_EN ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x10 ) )
927
#define HC_INT_DIS ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x14 ) )
928
#define HC_HCCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x18 ) )
929
#define HC_PERIOD_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x1C ) )
930
#define HC_CTRL_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x20 ) )
931
#define HC_CTRL_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x24 ) )
932
#define HC_BULK_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x28 ) )
933
#define HC_BULK_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x2C ) )
934
#define HC_DONE_HEAD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x30 ) )
935
#define HC_FM_INTERVAL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x34 ) )
936
#define HC_FM_REMAINING ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x38 ) )
937
#define HC_FM_NUMBER ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x3C ) )
938
#define HC_PERIOD_START ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x40 ) )
939
#define HC_LS_THRHLD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x44 ) )
940
#define HC_RH_DESCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x48 ) )
941
#define HC_RH_DESCB ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x4C ) )
942
#define HC_RH_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x50 ) )
943
#define HC_RH_PORT_STAT1 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x54 ) )
944
#define HC_RH_PORT_STAT2 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x58 ) )
945
946
/* USB OTG Controller */
947
#define USBOTG_BASE_ADDR 0x2008c100
948
949
#define OTG_INT_STAT ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x00 ) )
950
#define OTG_INT_EN ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x04 ) )
951
#define OTG_INT_SET ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x08 ) )
952
#define OTG_INT_CLR ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x0C ) )
953
#define OTG_STAT_CTRL ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x10 ) )
954
#define OTG_TIMER ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x14 ) )
955
956
#define USBOTG_I2C_BASE_ADDR 0x2008c300
957
958
#define OTG_I2C_RX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )
959
#define OTG_I2C_TX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )
960
#define OTG_I2C_STS ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x04 ) )
961
#define OTG_I2C_CTL ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x08 ) )
962
#define OTG_I2C_CLKHI ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \
963
0x0C ) )
964
#define OTG_I2C_CLKLO ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \
965
0x10 ) )
966
967
#define USBOTG_CLK_BASE_ADDR 0x2008CFF0U
968
969
#define OTG_CLK_CTRL ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \
970
0x04U ) )
971
#define OTG_CLK_STAT ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \
972
0x08U ) )
973
974
/* Register Fields */
975
#define GET_FIELD( val, mask, shift ) \
976
( ( ( val ) & ( mask ) ) >> ( shift ) )
977
978
#define SET_FIELD( val, field, mask, shift ) \
979
( ( ( val ) & ~( mask ) ) | ( ( ( field ) << ( shift ) ) & ( mask ) ) )
980
981
/* CLKSRCSEL */
982
#define CLKSRCSEL_CLKSRC_MASK 0x00000003U
983
984
#define GET_CLKSRCSEL_CLKSRC( reg ) \
985
GET_FIELD( reg, CLKSRCSEL_CLKSRC_MASK, 0 )
986
987
#define SET_CLKSRCSEL_CLKSRC( reg, val ) \
988
SET_FIELD( reg, val, CLKSRCSEL_CLKSRC_MASK, 0 )
989
990
/* PLLCON */
991
#define PLLCON_PLLE 0x00000001U
992
993
#define PLLCON_PLLC 0x00000002U
994
995
/* PLLCFG */
996
#define PLLCFG_MSEL_MASK 0x00007fffU
997
998
#define GET_PLLCFG_MSEL( reg ) \
999
GET_FIELD( reg, PLLCFG_MSEL_MASK, 0 )
1000
1001
#define SET_PLLCFG_MSEL( reg, val ) \
1002
SET_FIELD( reg, val, PLLCFG_MSEL_MASK, 0 )
1003
1004
#define PLLCFG_NSEL_MASK 0x00ff0000U
1005
1006
#define GET_PLLCFG_NSEL( reg ) \
1007
GET_FIELD( reg, PLLCFG_NSEL_MASK, 16 )
1008
1009
#define SET_PLLCFG_NSEL( reg, val ) \
1010
SET_FIELD( reg, val, PLLCFG_NSEL_MASK, 16 )
1011
1012
/* PLLSTAT */
1013
#define PLLSTAT_MSEL_MASK 0x00007fffU
1014
1015
#define GET_PLLSTAT_MSEL( reg ) \
1016
GET_FIELD( reg, PLLSTAT_MSEL_MASK, 0 )
1017
1018
#define SET_PLLSTAT_MSEL( reg, val ) \
1019
SET_FIELD( reg, val, PLLSTAT_MSEL_MASK, 0 )
1020
1021
#define PLLSTAT_NSEL_MASK 0x00ff0000U
1022
1023
#define GET_PLLSTAT_NSEL( reg ) \
1024
GET_FIELD( reg, PLLSTAT_NSEL_MASK, 16 )
1025
1026
#define SET_PLLSTAT_NSEL( reg, val ) \
1027
SET_FIELD( reg, val, PLLSTAT_NSEL_MASK, 16 )
1028
1029
#define PLLSTAT_PLLE 0x01000000U
1030
1031
#define PLLSTAT_PLLC 0x02000000U
1032
1033
#define PLLSTAT_PLOCK 0x04000000U
1034
1035
/* CCLKCFG */
1036
#define CCLKCFG_CCLKSEL_MASK 0x000000ffU
1037
1038
#define GET_CCLKCFG_CCLKSEL( reg ) \
1039
GET_FIELD( reg, CCLKCFG_CCLKSEL_MASK, 0 )
1040
1041
#define SET_CCLKCFG_CCLKSEL( reg, val ) \
1042
SET_FIELD( reg, val, CCLKCFG_CCLKSEL_MASK, 0 )
1043
1044
/* MEMMAP */
1045
#define MEMMAP_MAP_MASK 0x00000003U
1046
1047
#define GET_MEMMAP_MAP( reg ) \
1048
GET_FIELD( reg, MEMMAP_MAP_MASK, 0 )
1049
1050
#define SET_MEMMAP_MAP( reg, val ) \
1051
SET_FIELD( reg, val, MEMMAP_MAP_MASK, 0 )
1052
1053
/* TIR */
1054
#define TIR_MR0 0x00000001U
1055
#define TIR_MR1 0x00000002U
1056
#define TIR_MR2 0x00000004U
1057
#define TIR_MR3 0x00000008U
1058
#define TIR_CR0 0x00000010U
1059
#define TIR_CR1 0x00000020U
1060
#define TIR_CR2 0x00000040U
1061
#define TIR_CR3 0x00000080U
1062
1063
/* TCR */
1064
#define TCR_EN 0x00000001U
1065
#define TCR_RST 0x00000002U
1066
1067
/* TMCR */
1068
#define TMCR_MR0I 0x00000001U
1069
#define TMCR_MR0R 0x00000002U
1070
#define TMCR_MR0S 0x00000004U
1071
#define TMCR_MR1I 0x00000008U
1072
#define TMCR_MR1R 0x00000010U
1073
#define TMCR_MR1S 0x00000020U
1074
#define TMCR_MR2I 0x00000040U
1075
#define TMCR_MR2R 0x00000080U
1076
#define TMCR_MR2S 0x00000100U
1077
#define TMCR_MR3I 0x00000200U
1078
#define TMCR_MR3R 0x00000400U
1079
#define TMCR_MR3S 0x00000800U
1080
1081
/* PCLKSEL0 */
1082
#define PCLKSEL0_PCLK_WDT_MASK 0x00000003U
1083
1084
#define GET_PCLKSEL0_PCLK_WDT( reg ) \
1085
GET_FIELD( reg, PCLKSEL0_PCLK_WDT_MASK, 0 )
1086
1087
#define SET_PCLKSEL0_PCLK_WDT( reg, val ) \
1088
SET_FIELD( reg, val, PCLKSEL0_PCLK_WDT_MASK, 0 )
1089
1090
#define PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU
1091
1092
#define GET_PCLKSEL0_PCLK_TIMER0( reg ) \
1093
GET_FIELD( reg, PCLKSEL0_PCLK_TIMER0_MASK, 2 )
1094
1095
#define SET_PCLKSEL0_PCLK_TIMER0( reg, val ) \
1096
SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2 )
1097
1098
#define PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U
1099
1100
#define GET_PCLKSEL0_PCLK_TIMER1( reg ) \
1101
GET_FIELD( reg, PCLKSEL0_PCLK_TIMER1_MASK, 4 )
1102
1103
#define SET_PCLKSEL0_PCLK_TIMER1( reg, val ) \
1104
SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4 )
1105
1106
#define PCLKSEL0_PCLK_UART0_MASK 0x000000c0U
1107
1108
#define GET_PCLKSEL0_PCLK_UART0( reg ) \
1109
GET_FIELD( reg, PCLKSEL0_PCLK_UART0_MASK, 6 )
1110
1111
#define SET_PCLKSEL0_PCLK_UART0( reg, val ) \
1112
SET_FIELD( reg, val, PCLKSEL0_PCLK_UART0_MASK, 6 )
1113
1114
#define PCLKSEL0_PCLK_UART1_MASK 0x00000300U
1115
1116
#define GET_PCLKSEL0_PCLK_UART1( reg ) \
1117
GET_FIELD( reg, PCLKSEL0_PCLK_UART1_MASK, 8 )
1118
1119
#define SET_PCLKSEL0_PCLK_UART1( reg, val ) \
1120
SET_FIELD( reg, val, PCLKSEL0_PCLK_UART1_MASK, 8 )
1121
1122
#define PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U
1123
1124
#define GET_PCLKSEL0_PCLK_PWM0( reg ) \
1125
GET_FIELD( reg, PCLKSEL0_PCLK_PWM0_MASK, 10 )
1126
1127
#define SET_PCLKSEL0_PCLK_PWM0( reg, val ) \
1128
SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10 )
1129
1130
#define PCLKSEL0_PCLK_PWM1_MASK 0x00003000U
1131
1132
#define GET_PCLKSEL0_PCLK_PWM1( reg ) \
1133
GET_FIELD( reg, PCLKSEL0_PCLK_PWM1_MASK, 12 )
1134
1135
#define SET_PCLKSEL0_PCLK_PWM1( reg, val ) \
1136
SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12 )
1137
1138
#define PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U
1139
1140
#define GET_PCLKSEL0_PCLK_I2C0( reg ) \
1141
GET_FIELD( reg, PCLKSEL0_PCLK_I2C0_MASK, 14 )
1142
1143
#define SET_PCLKSEL0_PCLK_I2C0( reg, val ) \
1144
SET_FIELD( reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14 )
1145
1146
#define PCLKSEL0_PCLK_SPI_MASK 0x00030000U
1147
1148
#define GET_PCLKSEL0_PCLK_SPI( reg ) \
1149
GET_FIELD( reg, PCLKSEL0_PCLK_SPI_MASK, 16 )
1150
1151
#define SET_PCLKSEL0_PCLK_SPI( reg, val ) \
1152
SET_FIELD( reg, val, PCLKSEL0_PCLK_SPI_MASK, 16 )
1153
1154
#define PCLKSEL0_PCLK_RTC_MASK 0x000c0000U
1155
1156
#define GET_PCLKSEL0_PCLK_RTC( reg ) \
1157
GET_FIELD( reg, PCLKSEL0_PCLK_RTC_MASK, 18 )
1158
1159
#define SET_PCLKSEL0_PCLK_RTC( reg, val ) \
1160
SET_FIELD( reg, val, PCLKSEL0_PCLK_RTC_MASK, 18 )
1161
1162
#define PCLKSEL0_PCLK_SSP1_MASK 0x00300000U
1163
1164
#define GET_PCLKSEL0_PCLK_SSP1( reg ) \
1165
GET_FIELD( reg, PCLKSEL0_PCLK_SSP1_MASK, 20 )
1166
1167
#define SET_PCLKSEL0_PCLK_SSP1( reg, val ) \
1168
SET_FIELD( reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20 )
1169
1170
#define PCLKSEL0_PCLK_DAC_MASK 0x00c00000U
1171
1172
#define GET_PCLKSEL0_PCLK_DAC( reg ) \
1173
GET_FIELD( reg, PCLKSEL0_PCLK_DAC_MASK, 22 )
1174
1175
#define SET_PCLKSEL0_PCLK_DAC( reg, val ) \
1176
SET_FIELD( reg, val, PCLKSEL0_PCLK_DAC_MASK, 22 )
1177
1178
#define PCLKSEL0_PCLK_ADC_MASK 0x03000000U
1179
1180
#define GET_PCLKSEL0_PCLK_ADC( reg ) \
1181
GET_FIELD( reg, PCLKSEL0_PCLK_ADC_MASK, 24 )
1182
1183
#define SET_PCLKSEL0_PCLK_ADC( reg, val ) \
1184
SET_FIELD( reg, val, PCLKSEL0_PCLK_ADC_MASK, 24 )
1185
1186
#define PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U
1187
1188
#define GET_PCLKSEL0_PCLK_CAN1( reg ) \
1189
GET_FIELD( reg, PCLKSEL0_PCLK_CAN1_MASK, 26 )
1190
1191
#define SET_PCLKSEL0_PCLK_CAN1( reg, val ) \
1192
SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26 )
1193
1194
#define PCLKSEL0_PCLK_CAN2_MASK 0x30000000U
1195
1196
#define GET_PCLKSEL0_PCLK_CAN2( reg ) \
1197
GET_FIELD( reg, PCLKSEL0_PCLK_CAN2_MASK, 28 )
1198
1199
#define SET_PCLKSEL0_PCLK_CAN2( reg, val ) \
1200
SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28 )
1201
1202
/* PCLKSEL1 */
1203
#define PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U
1204
1205
#define GET_PCLKSEL1_PCLK_BAT_RAM( reg ) \
1206
GET_FIELD( reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )
1207
1208
#define SET_PCLKSEL1_PCLK_BAT_RAM( reg, val ) \
1209
SET_FIELD( reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )
1210
1211
#define PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU
1212
1213
#define GET_PCLKSEL1_PCLK_GPIO( reg ) \
1214
GET_FIELD( reg, PCLKSEL1_PCLK_GPIO_MASK, 2 )
1215
1216
#define SET_PCLKSEL1_PCLK_GPIO( reg, val ) \
1217
SET_FIELD( reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2 )
1218
1219
#define PCLKSEL1_PCLK_PCB_MASK 0x00000030U
1220
1221
#define GET_PCLKSEL1_PCLK_PCB( reg ) \
1222
GET_FIELD( reg, PCLKSEL1_PCLK_PCB_MASK, 4 )
1223
1224
#define SET_PCLKSEL1_PCLK_PCB( reg, val ) \
1225
SET_FIELD( reg, val, PCLKSEL1_PCLK_PCB_MASK, 4 )
1226
1227
#define PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U
1228
1229
#define GET_PCLKSEL1_PCLK_I2C1( reg ) \
1230
GET_FIELD( reg, PCLKSEL1_PCLK_I2C1_MASK, 6 )
1231
1232
#define SET_PCLKSEL1_PCLK_I2C1( reg, val ) \
1233
SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6 )
1234
1235
#define PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U
1236
1237
#define GET_PCLKSEL1_PCLK_SSP0( reg ) \
1238
GET_FIELD( reg, PCLKSEL1_PCLK_SSP0_MASK, 10 )
1239
1240
#define SET_PCLKSEL1_PCLK_SSP0( reg, val ) \
1241
SET_FIELD( reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10 )
1242
1243
#define PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U
1244
1245
#define GET_PCLKSEL1_PCLK_TIMER2( reg ) \
1246
GET_FIELD( reg, PCLKSEL1_PCLK_TIMER2_MASK, 12 )
1247
1248
#define SET_PCLKSEL1_PCLK_TIMER2( reg, val ) \
1249
SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12 )
1250
1251
#define PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U
1252
1253
#define GET_PCLKSEL1_PCLK_TIMER3( reg ) \
1254
GET_FIELD( reg, PCLKSEL1_PCLK_TIMER3_MASK, 14 )
1255
1256
#define SET_PCLKSEL1_PCLK_TIMER3( reg, val ) \
1257
SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14 )
1258
1259
#define PCLKSEL1_PCLK_UART2_MASK 0x00030000U
1260
1261
#define GET_PCLKSEL1_PCLK_UART2( reg ) \
1262
GET_FIELD( reg, PCLKSEL1_PCLK_UART2_MASK, 16 )
1263
1264
#define SET_PCLKSEL1_PCLK_UART2( reg, val ) \
1265
SET_FIELD( reg, val, PCLKSEL1_PCLK_UART2_MASK, 16 )
1266
1267
#define PCLKSEL1_PCLK_UART3_MASK 0x000c0000U
1268
1269
#define GET_PCLKSEL1_PCLK_UART3( reg ) \
1270
GET_FIELD( reg, PCLKSEL1_PCLK_UART3_MASK, 18 )
1271
1272
#define SET_PCLKSEL1_PCLK_UART3( reg, val ) \
1273
SET_FIELD( reg, val, PCLKSEL1_PCLK_UART3_MASK, 18 )
1274
1275
#define PCLKSEL1_PCLK_I2C2_MASK 0x00300000U
1276
1277
#define GET_PCLKSEL1_PCLK_I2C2( reg ) \
1278
GET_FIELD( reg, PCLKSEL1_PCLK_I2C2_MASK, 20 )
1279
1280
#define SET_PCLKSEL1_PCLK_I2C2( reg, val ) \
1281
SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20 )
1282
1283
#define PCLKSEL1_PCLK_I2S_MASK 0x00c00000U
1284
1285
#define GET_PCLKSEL1_PCLK_I2S( reg ) \
1286
GET_FIELD( reg, PCLKSEL1_PCLK_I2S_MASK, 22 )
1287
1288
#define SET_PCLKSEL1_PCLK_I2S( reg, val ) \
1289
SET_FIELD( reg, val, PCLKSEL1_PCLK_I2S_MASK, 22 )
1290
1291
#define PCLKSEL1_PCLK_MCI_MASK 0x03000000U
1292
1293
#define GET_PCLKSEL1_PCLK_MCI( reg ) \
1294
GET_FIELD( reg, PCLKSEL1_PCLK_MCI_MASK, 24 )
1295
1296
#define SET_PCLKSEL1_PCLK_MCI( reg, val ) \
1297
SET_FIELD( reg, val, PCLKSEL1_PCLK_MCI_MASK, 24 )
1298
1299
#define PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U
1300
1301
#define GET_PCLKSEL1_PCLK_SYSCON( reg ) \
1302
GET_FIELD( reg, PCLKSEL1_PCLK_SYSCON_MASK, 28 )
1303
1304
#define SET_PCLKSEL1_PCLK_SYSCON( reg, val ) \
1305
SET_FIELD( reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28 )
1306
1307
/* RTC_ILR */
1308
#define RTC_ILR_RTCCIF 0x00000001U
1309
#define RTC_ILR_RTCALF 0x00000002U
1310
#define RTC_ILR_RTSSF 0x00000004U
1311
1312
/* RTC_CCR */
1313
#define RTC_CCR_CLKEN 0x00000001U
1314
#define RTC_CCR_CTCRST 0x00000002U
1315
#define RTC_CCR_CLKSRC 0x00000010U
1316
1317
/* GPDMA */
1318
typedef
struct
1319
uint32_t src;
1320
uint32_t dest;
1321
uint32_t lli;
1322
uint32_t ctrl;
1323
lpc176x_dma_descriptor
1324
1325
typedef
struct
1326
desc;
1327
uint32_t cfg;
1328
lpc176x_dma_channel
1329
1330
#define GPDMA_CH_NUMBER 2
1331
#define GPDMA_STATUS_CH_0 0x00000001U
1332
#define GPDMA_STATUS_CH_1 0x00000002U
1333
#define GPDMA_CH_BASE_ADDR( i ) \
1334
( (volatile lpc176x_dma_channel *) \
1335
( ( i ) ? GPDMA_CH1_BASE_ADDR : GPDMA_CH0_BASE_ADDR ) )
1336
1337
/* GPDMA_CONFIG */
1338
#define GPDMA_CONFIG_EN 0x00000001U
1339
#define GPDMA_CONFIG_MODE 0x00000002U
1340
1341
/* GPDMA_ENABLED_CHNS */
1342
#define GPDMA_ENABLED_CHNS_CH0 0x00000001U
1343
#define GPDMA_ENABLED_CHNS_CH1 0x00000002U
1344
1345
/* GPDMA_CH_CTRL */
1346
#define GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU
1347
1348
#define GET_GPDMA_CH_CTRL_TSZ( reg ) \
1349
GET_FIELD( reg, GPDMA_CH_CTRL_TSZ_MASK, 0 )
1350
1351
#define SET_GPDMA_CH_CTRL_TSZ( reg, val ) \
1352
SET_FIELD( reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0 )
1353
1354
#define GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU
1355
1356
#define GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U
1357
1358
#define GET_GPDMA_CH_CTRL_SBSZ( reg ) \
1359
GET_FIELD( reg, GPDMA_CH_CTRL_SBSZ_MASK, 12 )
1360
1361
#define SET_GPDMA_CH_CTRL_SBSZ( reg, val ) \
1362
SET_FIELD( reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12 )
1363
1364
#define GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U
1365
1366
#define GET_GPDMA_CH_CTRL_DBSZ( reg ) \
1367
GET_FIELD( reg, GPDMA_CH_CTRL_DBSZ_MASK, 15 )
1368
1369
#define SET_GPDMA_CH_CTRL_DBSZ( reg, val ) \
1370
SET_FIELD( reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15 )
1371
1372
#define GPDMA_CH_CTRL_BSZ_1 0x00000000U
1373
1374
#define GPDMA_CH_CTRL_BSZ_4 0x00000001U
1375
1376
#define GPDMA_CH_CTRL_BSZ_8 0x00000002U
1377
1378
#define GPDMA_CH_CTRL_BSZ_16 0x00000003U
1379
1380
#define GPDMA_CH_CTRL_BSZ_32 0x00000004U
1381
1382
#define GPDMA_CH_CTRL_BSZ_64 0x00000005U
1383
1384
#define GPDMA_CH_CTRL_BSZ_128 0x00000006U
1385
1386
#define GPDMA_CH_CTRL_BSZ_256 0x00000007U
1387
1388
#define GPDMA_CH_CTRL_SW_MASK 0x001c0000U
1389
1390
#define GET_GPDMA_CH_CTRL_SW( reg ) \
1391
GET_FIELD( reg, GPDMA_CH_CTRL_SW_MASK, 18 )
1392
1393
#define SET_GPDMA_CH_CTRL_SW( reg, val ) \
1394
SET_FIELD( reg, val, GPDMA_CH_CTRL_SW_MASK, 18 )
1395
1396
#define GPDMA_CH_CTRL_DW_MASK 0x00e00000U
1397
1398
#define GET_GPDMA_CH_CTRL_DW( reg ) \
1399
GET_FIELD( reg, GPDMA_CH_CTRL_DW_MASK, 21 )
1400
1401
#define SET_GPDMA_CH_CTRL_DW( reg, val ) \
1402
SET_FIELD( reg, val, GPDMA_CH_CTRL_DW_MASK, 21 )
1403
1404
#define GPDMA_CH_CTRL_W_8 0x00000000U
1405
1406
#define GPDMA_CH_CTRL_W_16 0x00000001U
1407
1408
#define GPDMA_CH_CTRL_W_32 0x00000002U
1409
1410
#define GPDMA_CH_CTRL_SI 0x04000000U
1411
1412
#define GPDMA_CH_CTRL_DI 0x08000000U
1413
1414
#define GPDMA_CH_CTRL_PROT_MASK 0x70000000U
1415
1416
#define GET_GPDMA_CH_CTRL_PROT( reg ) \
1417
GET_FIELD( reg, GPDMA_CH_CTRL_PROT_MASK, 28 )
1418
1419
#define SET_GPDMA_CH_CTRL_PROT( reg, val ) \
1420
SET_FIELD( reg, val, GPDMA_CH_CTRL_PROT_MASK, 28 )
1421
1422
#define GPDMA_CH_CTRL_ITC 0x80000000U
1423
1424
/* GPDMA_CH_CFG */
1425
#define GPDMA_CH_CFG_EN 0x00000001U
1426
1427
#define GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU
1428
1429
#define GET_GPDMA_CH_CFG_SRCPER( reg ) \
1430
GET_FIELD( reg, GPDMA_CH_CFG_SRCPER_MASK, 1 )
1431
1432
#define SET_GPDMA_CH_CFG_SRCPER( reg, val ) \
1433
SET_FIELD( reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1 )
1434
1435
#define GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U
1436
1437
#define GET_GPDMA_CH_CFG_DESTPER( reg ) \
1438
GET_FIELD( reg, GPDMA_CH_CFG_DESTPER_MASK, 6 )
1439
1440
#define SET_GPDMA_CH_CFG_DESTPER( reg, val ) \
1441
SET_FIELD( reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6 )
1442
1443
#define GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U
1444
1445
#define GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U
1446
1447
#define GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U
1448
1449
#define GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U
1450
1451
#define GPDMA_CH_CFG_PER_SD_MMC 0x00000004U
1452
1453
#define GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U
1454
1455
#define GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U
1456
1457
#define GPDMA_CH_CFG_FLOW_MASK 0x00003800U
1458
1459
#define GET_GPDMA_CH_CFG_FLOW( reg ) \
1460
GET_FIELD( reg, GPDMA_CH_CFG_FLOW_MASK, 11 )
1461
1462
#define SET_GPDMA_CH_CFG_FLOW( reg, val ) \
1463
SET_FIELD( reg, val, GPDMA_CH_CFG_FLOW_MASK, 11 )
1464
1465
#define GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U
1466
1467
#define GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U
1468
1469
#define GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U
1470
1471
#define GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U
1472
1473
#define GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U
1474
1475
#define GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U
1476
1477
#define GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U
1478
1479
#define GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U
1480
1481
#define GPDMA_CH_CFG_IE 0x00004000U
1482
1483
#define GPDMA_CH_CFG_ITC 0x00008000U
1484
1485
#define GPDMA_CH_CFG_LOCK 0x00010000U
1486
1487
#define GPDMA_CH_CFG_ACTIVE 0x00020000U
1488
1489
#define GPDMA_CH_CFG_HALT 0x00040000U
1490
1491
/* AHBCFG */
1492
#define AHBCFG_SCHEDULER_UNIFORM 0x00000001U
1493
1494
#define AHBCFG_BREAK_BURST_MASK 0x00000006U
1495
1496
#define GET_AHBCFG_BREAK_BURST( reg ) \
1497
GET_FIELD( reg, AHBCFG_BREAK_BURST_MASK, 1 )
1498
1499
#define SET_AHBCFG_BREAK_BURST( reg, val ) \
1500
SET_FIELD( reg, val, AHBCFG_BREAK_BURST_MASK, 1 )
1501
1502
#define AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U
1503
1504
#define AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U
1505
1506
#define GET_AHBCFG_QUANTUM_SIZE( reg ) \
1507
GET_FIELD( reg, AHBCFG_QUANTUM_SIZE_MASK, 4 )
1508
1509
#define SET_AHBCFG_QUANTUM_SIZE( reg, val ) \
1510
SET_FIELD( reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4 )
1511
1512
#define AHBCFG_DEFAULT_MASTER_MASK 0x00000700U
1513
1514
#define GET_AHBCFG_DEFAULT_MASTER( reg ) \
1515
GET_FIELD( reg, AHBCFG_DEFAULT_MASTER_MASK, 8 )
1516
1517
#define SET_AHBCFG_DEFAULT_MASTER( reg, val ) \
1518
SET_FIELD( reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8 )
1519
1520
#define AHBCFG_EP1_MASK 0x00007000U
1521
1522
#define GET_AHBCFG_EP1( reg ) \
1523
GET_FIELD( reg, AHBCFG_EP1_MASK, 12 )
1524
1525
#define SET_AHBCFG_EP1( reg, val ) \
1526
SET_FIELD( reg, val, AHBCFG_EP1_MASK, 12 )
1527
1528
#define AHBCFG_EP2_MASK 0x00070000U
1529
1530
#define GET_AHBCFG_EP2( reg ) \
1531
GET_FIELD( reg, AHBCFG_EP2_MASK, 16 )
1532
1533
#define SET_AHBCFG_EP2( reg, val ) \
1534
SET_FIELD( reg, val, AHBCFG_EP2_MASK, 16 )
1535
1536
#define AHBCFG_EP3_MASK 0x00700000U
1537
1538
#define GET_AHBCFG_EP3( reg ) \
1539
GET_FIELD( reg, AHBCFG_EP3_MASK, 20 )
1540
1541
#define SET_AHBCFG_EP3( reg, val ) \
1542
SET_FIELD( reg, val, AHBCFG_EP3_MASK, 20 )
1543
1544
#define AHBCFG_EP4_MASK 0x07000000U
1545
1546
#define GET_AHBCFG_EP4( reg ) \
1547
GET_FIELD( reg, AHBCFG_EP4_MASK, 24 )
1548
1549
#define SET_AHBCFG_EP4( reg, val ) \
1550
SET_FIELD( reg, val, AHBCFG_EP4_MASK, 24 )
1551
1552
#define AHBCFG_EP5_MASK 0x70000000U
1553
1554
#define GET_AHBCFG_EP5( reg ) \
1555
GET_FIELD( reg, AHBCFG_EP5_MASK, 28 )
1556
1557
#define SET_AHBCFG_EP5( reg, val ) \
1558
SET_FIELD( reg, val, AHBCFG_EP5_MASK, 28 )
1559
1560
/* I2S */
1561
static
volatile
lpc_i2s
const
lpc176x_i2s = (
lpc_i2s
*) I2S_BASE_ADDR;
1562
1563
/* ADC */
1564
#define ADC_CR_SEL( val ) BSP_FLD32( val, 0, 7 )
1565
#define ADC_CR_SEL_GET( val ) BSP_FLD32GET( val, 0, 7 )
1566
#define ADC_CR_SEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 7 )
1567
#define ADC_CR_CLKDIV( val ) BSP_FLD32( val, 8, 15 )
1568
#define ADC_CR_CLKDIV_GET( reg ) BSP_FLD32GET( reg, 8, 15 )
1569
#define ADC_CR_CLKDIV_SET( reg, val ) BSP_FLD32SET( reg, val, 8, 15 )
1570
#define ADC_CR_BURST BSP_BIT32( 16 )
1571
#define ADC_CR_CLKS( val ) BSP_FLD32( val, 17, 19 )
1572
#define ADC_CR_PDN BSP_BIT32( 21 )
1573
#define ADC_CR_START( val ) BSP_FLD32( val, 24, 26 )
1574
#define ADC_CR_EDGE BSP_BIT32( 27 )
1575
1576
#define ADC_DR_VALUE( reg ) BSP_FLD32GET( reg, 6, 15 )
1577
#define ADC_DR_OVERRUN BSP_BIT32( 30 )
1578
#define ADC_DR_DONE BSP_BIT32( 31 )
1579
1580
/* DAC */
1581
#define DAC_STEPS 1024
1582
#define DAC_VALUE( val ) BSP_FLD32( val, 6, 15 )
1583
#define DAC_BIAS BSP_BIT32( 16 )
1584
1585
#endif
/* LIBBSP_ARM_LPC176X_H */
lpc-i2s.h
I2S API.
lpc176x_dma_channel
Definition
lpc176x.h:1325
Definition
lpc176x.h:1318
lpc176x_pll
Phase-Locked Loop representation.
Definition
lpc176x.h:42
lpc176x_pll::stat
uint32_t stat
PLL Status Register.
Definition
lpc176x.h:54
lpc176x_pll::feed
uint32_t feed
PLL Feed Register.
Definition
lpc176x.h:58
lpc176x_pll::cfg
uint32_t cfg
PLL Configuration Register.
Definition
lpc176x.h:50
lpc176x_pll::con
uint32_t con
PLL Control Register.
Definition
lpc176x.h:46
lpc176x_scb
System Control Block representation.
Definition
lpc176x.h:191
lpc176x_scb::flashcfg
uint32_t flashcfg
Flash Accelerator Configuration Register.
Definition
lpc176x.h:195
lpc176x_scb::extint
uint32_t extint
External Interrupt flag register.
Definition
lpc176x.h:239
lpc176x_scb::pll_0
lpc176x_pll pll_0
Phase-Locked Loop 0.
Definition
lpc176x.h:205
lpc176x_scb::clksrcsel
uint32_t clksrcsel
Clock Source Select register.
Definition
lpc176x.h:234
lpc176x_scb::pll_1
lpc176x_pll pll_1
Phase-Locked Loop 1.
Definition
lpc176x.h:210
lpc176x_scb::usbclksel
uint32_t usbclksel
Selects the divide value for creating the USB clock from the PPL0 output.
Definition
lpc176x.h:230
lpc176x_scb::pboost
uint32_t pboost
Peripheral boost.
Definition
lpc176x.h:267
lpc176x_scb::extmode
uint32_t extmode
External Interrupt Mode register.
Definition
lpc176x.h:244
lpc176x_scb::pconp
uint32_t pconp
Power Control for Peripherals register.
Definition
lpc176x.h:219
lpc176x_scb::clkoutcfg
uint32_t clkoutcfg
Clock Output Configuration Register.
Definition
lpc176x.h:272
lpc176x_scb::rsid
uint32_t rsid
Reset Source Identification Register.
Definition
lpc176x.h:253
lpc176x_scb::memmap
uint32_t memmap
Memopry Map Control.
Definition
lpc176x.h:200
lpc176x_scb::cclksel
uint32_t cclksel
Selects the divide valuefor creating the CPU clock from the PPL0 output.
Definition
lpc176x.h:225
lpc176x_scb::pcon
uint32_t pcon
Power Mode Control register.
Definition
lpc176x.h:215
lpc176x_scb::scs
uint32_t scs
System Controls and Status Register.
Definition
lpc176x.h:258
lpc176x_scb::rstcon
uint32_t rstcon[2]
Reset Control bit 0 and 1.
Definition
lpc176x.h:276
lpc176x_scb::pclksel
uint32_t pclksel[2]
Peripheral Clock Selection registers 0 and 1.
Definition
lpc176x.h:263
lpc176x_scb::extpolar
uint32_t extpolar
External Interrupt Polarity register.
Definition
lpc176x.h:248
lpc_i2s
I2S control block.
Definition
lpc-i2s.h:59
