RTEMS 6.3
led.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
53
54#ifndef _LED_
55#define _LED_
56
57#include <stdint.h>
58
59/*----------------------------------------------------------------------------
60 * Exported functions
61 *----------------------------------------------------------------------------*/
62
63extern uint32_t LED_Configure(uint32_t dwLed);
64
65extern uint32_t LED_Set(uint32_t dwLed);
66
67extern uint32_t LED_Clear(uint32_t dwLed);
68
69extern uint32_t LED_Toggle(uint32_t dwLed);
70
71#endif /* #ifndef LED_H */
72
