RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
l4stat-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/l4stat-header */
54
55
#ifndef _GRLIB_L4STAT_REGS_H
56
#define _GRLIB_L4STAT_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/l4stat */
65
75
83
84
#define L4STAT_CVAL_CVAL_SHIFT 0
85
#define L4STAT_CVAL_CVAL_MASK 0xffffffffU
86
#define L4STAT_CVAL_CVAL_GET( _reg ) \
87
( ( ( _reg ) & L4STAT_CVAL_CVAL_MASK ) >> \
88
L4STAT_CVAL_CVAL_SHIFT )
89
#define L4STAT_CVAL_CVAL_SET( _reg, _val ) \
90
( ( ( _reg ) & ~L4STAT_CVAL_CVAL_MASK ) | \
91
( ( ( _val ) << L4STAT_CVAL_CVAL_SHIFT ) & \
92
L4STAT_CVAL_CVAL_MASK ) )
93
#define L4STAT_CVAL_CVAL( _val ) \
94
95
96
98
106
107
#define L4STAT_CCTRL_NCPU_SHIFT 28
108
#define L4STAT_CCTRL_NCPU_MASK 0xf0000000U
109
#define L4STAT_CCTRL_NCPU_GET( _reg ) \
110
( ( ( _reg ) & L4STAT_CCTRL_NCPU_MASK ) >> \
111
L4STAT_CCTRL_NCPU_SHIFT )
112
#define L4STAT_CCTRL_NCPU_SET( _reg, _val ) \
113
( ( ( _reg ) & ~L4STAT_CCTRL_NCPU_MASK ) | \
114
( ( ( _val ) << L4STAT_CCTRL_NCPU_SHIFT ) & \
115
L4STAT_CCTRL_NCPU_MASK ) )
116
#define L4STAT_CCTRL_NCPU( _val ) \
117
118
119
120
#define L4STAT_CCTRL_NCNT_SHIFT 23
121
#define L4STAT_CCTRL_NCNT_MASK 0xf800000U
122
#define L4STAT_CCTRL_NCNT_GET( _reg ) \
123
( ( ( _reg ) & L4STAT_CCTRL_NCNT_MASK ) >> \
124
L4STAT_CCTRL_NCNT_SHIFT )
125
#define L4STAT_CCTRL_NCNT_SET( _reg, _val ) \
126
( ( ( _reg ) & ~L4STAT_CCTRL_NCNT_MASK ) | \
127
( ( ( _val ) << L4STAT_CCTRL_NCNT_SHIFT ) & \
128
L4STAT_CCTRL_NCNT_MASK ) )
129
#define L4STAT_CCTRL_NCNT( _val ) \
130
131
132
133
#define L4STAT_CCTRL_MC 0x400000U
134
135
#define L4STAT_CCTRL_IA 0x200000U
136
137
#define L4STAT_CCTRL_DS 0x100000U
138
139
#define L4STAT_CCTRL_EE 0x80000U
140
141
#define L4STAT_CCTRL_AE 0x40000U
142
143
#define L4STAT_CCTRL_EL 0x20000U
144
145
#define L4STAT_CCTRL_CD 0x10000U
146
147
#define L4STAT_CCTRL_SU_SHIFT 14
148
#define L4STAT_CCTRL_SU_MASK 0xc000U
149
#define L4STAT_CCTRL_SU_GET( _reg ) \
150
( ( ( _reg ) & L4STAT_CCTRL_SU_MASK ) >> \
151
L4STAT_CCTRL_SU_SHIFT )
152
#define L4STAT_CCTRL_SU_SET( _reg, _val ) \
153
( ( ( _reg ) & ~L4STAT_CCTRL_SU_MASK ) | \
154
( ( ( _val ) << L4STAT_CCTRL_SU_SHIFT ) & \
155
L4STAT_CCTRL_SU_MASK ) )
156
#define L4STAT_CCTRL_SU( _val ) \
157
158
159
160
#define L4STAT_CCTRL_CL 0x2000U
161
162
#define L4STAT_CCTRL_EN 0x1000U
163
164
#define L4STAT_CCTRL_EVENT_ID_SHIFT 4
165
#define L4STAT_CCTRL_EVENT_ID_MASK 0xff0U
166
#define L4STAT_CCTRL_EVENT_ID_GET( _reg ) \
167
( ( ( _reg ) & L4STAT_CCTRL_EVENT_ID_MASK ) >> \
168
L4STAT_CCTRL_EVENT_ID_SHIFT )
169
#define L4STAT_CCTRL_EVENT_ID_SET( _reg, _val ) \
170
( ( ( _reg ) & ~L4STAT_CCTRL_EVENT_ID_MASK ) | \
171
( ( ( _val ) << L4STAT_CCTRL_EVENT_ID_SHIFT ) & \
172
L4STAT_CCTRL_EVENT_ID_MASK ) )
173
#define L4STAT_CCTRL_EVENT_ID( _val ) \
174
175
176
177
#define L4STAT_CCTRL_CPU_AHBM_SHIFT 0
178
#define L4STAT_CCTRL_CPU_AHBM_MASK 0xfU
179
#define L4STAT_CCTRL_CPU_AHBM_GET( _reg ) \
180
( ( ( _reg ) & L4STAT_CCTRL_CPU_AHBM_MASK ) >> \
181
L4STAT_CCTRL_CPU_AHBM_SHIFT )
182
#define L4STAT_CCTRL_CPU_AHBM_SET( _reg, _val ) \
183
( ( ( _reg ) & ~L4STAT_CCTRL_CPU_AHBM_MASK ) | \
184
( ( ( _val ) << L4STAT_CCTRL_CPU_AHBM_SHIFT ) & \
185
L4STAT_CCTRL_CPU_AHBM_MASK ) )
186
#define L4STAT_CCTRL_CPU_AHBM( _val ) \
187
188
189
191
200
201
#define L4STAT_CSVAL_CSVAL_SHIFT 0
202
#define L4STAT_CSVAL_CSVAL_MASK 0xffffffffU
203
#define L4STAT_CSVAL_CSVAL_GET( _reg ) \
204
( ( ( _reg ) & L4STAT_CSVAL_CSVAL_MASK ) >> \
205
L4STAT_CSVAL_CSVAL_SHIFT )
206
#define L4STAT_CSVAL_CSVAL_SET( _reg, _val ) \
207
( ( ( _reg ) & ~L4STAT_CSVAL_CSVAL_MASK ) | \
208
( ( ( _val ) << L4STAT_CSVAL_CSVAL_SHIFT ) & \
209
L4STAT_CSVAL_CSVAL_MASK ) )
210
#define L4STAT_CSVAL_CSVAL( _val ) \
211
212
213
215
223
224
#define L4STAT_TSTAMP_TSTAMP_SHIFT 0
225
#define L4STAT_TSTAMP_TSTAMP_MASK 0xffffffffU
226
#define L4STAT_TSTAMP_TSTAMP_GET( _reg ) \
227
( ( ( _reg ) & L4STAT_TSTAMP_TSTAMP_MASK ) >> \
228
L4STAT_TSTAMP_TSTAMP_SHIFT )
229
#define L4STAT_TSTAMP_TSTAMP_SET( _reg, _val ) \
230
( ( ( _reg ) & ~L4STAT_TSTAMP_TSTAMP_MASK ) | \
231
( ( ( _val ) << L4STAT_TSTAMP_TSTAMP_SHIFT ) & \
232
L4STAT_TSTAMP_TSTAMP_MASK ) )
233
#define L4STAT_TSTAMP_TSTAMP( _val ) \
234
235
236
238
242
typedef
struct
l4stat
246
uint32_t
cval_0
247
248
uint32_t reserved_4_3c[ 14 ];
249
253
uint32_t
cval_1
254
255
uint32_t reserved_40_80[ 16 ];
256
260
uint32_t
cctrl_0
261
262
uint32_t reserved_84_cc[ 18 ];
263
267
uint32_t
cctrl_1
268
269
uint32_t reserved_d0_100[ 12 ];
270
274
uint32_t
csval_0
275
276
uint32_t reserved_104_13c[ 14 ];
277
281
uint32_t
csval_1
282
283
uint32_t reserved_140_180[ 16 ];
284
288
uint32_t
tstamp
289
l4stat
290
292
293
#ifdef __cplusplus
294
295
#endif
296
297
#endif
/* _GRLIB_L4STAT_REGS_H */
l4stat
This structure defines the L4STAT register block memory map.
Definition
l4stat-regs.h:242
l4stat::csval_0
uint32_t csval_0
See Counter 0-15 max/latch register (CSVAL).
Definition
l4stat-regs.h:274
l4stat::cctrl_0
uint32_t cctrl_0
See Counter 0-15 control register (CCTRL).
Definition
l4stat-regs.h:260
l4stat::csval_1
uint32_t csval_1
Definition
l4stat-regs.h:281
l4stat::cctrl_1
uint32_t cctrl_1
Definition
l4stat-regs.h:267
l4stat::cval_1
uint32_t cval_1
See Counter 0-15 value register (CVAL).
Definition
l4stat-regs.h:253
l4stat::cval_0
uint32_t cval_0
Definition
l4stat-regs.h:246
l4stat::tstamp
uint32_t tstamp
See Timestamp register (TSTAMP).
Definition
l4stat-regs.h:288
