RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
isi.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
31
47
48
#ifndef ISI_H
49
#define ISI_H
50
51
52
53
54
* Definition
55
56
#define YUV_INPUT 0
57
#define RGB_INPUT 1
58
#define GRAYSCALE_INPUT 2
59
60
61
* Types
62
63
65
typedef
struct
67
uint32_t
CurrentLcdIndex
69
volatile
uint32_t
DisplayCodec
71
uint32_t
nb_codec_ovf
73
uint32_t
nb_prev_ovf
74
ISI_Descriptors
75
77
typedef
struct
79
uint32_t
Current
81
uint32_t
Control
83
uint32_t
Next
84
ISI_FrameBufferDescriptors
85
86
88
typedef
struct
90
uint8_t
C0
92
uint8_t
C1
94
uint8_t
C2
96
uint8_t
C3
98
uint8_t
Croff
100
uint8_t
Cboff
102
uint8_t
Yoff
104
uint16_t
C4
105
ISI_Y2R
106
108
typedef
struct
110
uint8_t
C0
112
uint8_t
C1
114
uint8_t
C2
116
uint8_t
Roff
118
uint8_t
C3
120
uint8_t
C4
122
uint8_t
C5
124
uint8_t
Goff
126
uint8_t
C6
128
uint8_t
C7
130
uint8_t
C8
132
uint8_t
Boff
133
ISI_R2Y
134
135
136
* Exported functions
137
138
extern
void
ISI_Enable(
void
139
140
extern
void
ISI_Disable(
void
141
142
void
ISI_DmaChannelEnable(uint32_t channel);
143
144
void
ISI_DmaChannelDisable(uint32_t channel);
145
146
extern
void
ISI_EnableInterrupt(uint32_t flag);
147
148
extern
void
ISI_DisableInterrupt(uint32_t flag);
149
150
extern
void
ISI_CodecPathFull(
void
151
152
extern
void
ISI_SetFrameRate(uint32_t frame);
153
154
extern
uint8_t ISI_BytesForOnePixel(uint8_t bmpRgb);
155
156
extern
void
ISI_Reset(
void
157
158
extern
void
ISI_Init(pIsi_Video pVideo);
159
160
extern
uint32_t ISI_StatusRegister(
void
161
162
extern
void
ISI_SetBlank(
163
uint8_t hBlank,
164
uint8_t vBlank);
165
166
extern
void
ISI_SetSensorSize(
167
uint32_t hSize,
168
uint32_t vSize);
169
170
extern
void
ISI_RgbPixelMapping(uint32_t wRgbPixelMapping);
171
172
extern
void
ISI_RgbSwapMode(uint32_t swapMode);
173
174
extern
void
ISI_YCrCbFormat(uint32_t wYuvSwapMode);
175
176
extern
void
ISI_setGrayScaleMode(uint32_t wPixelFormat);
177
178
extern
void
ISI_setInputStream(uint32_t wStreamMode);
179
180
extern
void
ISI_setPreviewSize(
181
uint32_t hSize,
182
uint32_t vSize);
183
184
extern
void
ISI_calcScalerFactor(
void
185
186
extern
void
ISI_setDmaInPreviewPath(
187
uint32_t baseFrameBufDesc,
188
uint32_t dmaCtrl,
189
uint32_t frameBufferStartAddr);
190
191
extern
void
ISI_setDmaInCodecPath(
192
193
uint32_t dmaCtrl,
194
195
196
extern
void
ISI_SetMatrix4Yuv2Rgb (
ISI_Y2R
*yuv2rgb);
197
extern
void
ISI_SetMatrix4Rgb2Yuv (
ISI_R2Y
*rgb2yuv);
198
199
#endif
//#ifndef ISI_H
200
ISI_Descriptors
Definition
isi.h:65
ISI_Descriptors::CurrentLcdIndex
uint32_t CurrentLcdIndex
Definition
isi.h:67
ISI_Descriptors::nb_codec_ovf
uint32_t nb_codec_ovf
Definition
isi.h:71
ISI_Descriptors::nb_prev_ovf
uint32_t nb_prev_ovf
Definition
isi.h:73
ISI_Descriptors::DisplayCodec
volatile uint32_t DisplayCodec
Definition
isi.h:69
Definition
isi.h:77
ISI_FrameBufferDescriptors::Next
uint32_t Next
Definition
isi.h:83
ISI_FrameBufferDescriptors::Control
uint32_t Control
Definition
isi.h:81
ISI_FrameBufferDescriptors::Current
uint32_t Current
Definition
isi.h:79
ISI_R2Y
Definition
isi.h:108
ISI_R2Y::Goff
uint8_t Goff
Definition
isi.h:124
ISI_R2Y::C8
uint8_t C8
Definition
isi.h:130
ISI_R2Y::C5
uint8_t C5
Definition
isi.h:122
ISI_R2Y::C6
uint8_t C6
Definition
isi.h:126
ISI_R2Y::C0
uint8_t C0
Definition
isi.h:110
ISI_R2Y::C2
uint8_t C2
Definition
isi.h:114
ISI_R2Y::Boff
uint8_t Boff
Definition
isi.h:132
ISI_R2Y::C1
uint8_t C1
Definition
isi.h:112
ISI_R2Y::Roff
uint8_t Roff
Definition
isi.h:116
ISI_R2Y::C4
uint8_t C4
Definition
isi.h:120
ISI_R2Y::C7
uint8_t C7
Definition
isi.h:128
ISI_R2Y::C3
uint8_t C3
Definition
isi.h:118
ISI_Y2R
Definition
isi.h:88
ISI_Y2R::C2
uint8_t C2
Definition
isi.h:94
ISI_Y2R::C4
uint16_t C4
Definition
isi.h:104
ISI_Y2R::C1
uint8_t C1
Definition
isi.h:92
ISI_Y2R::C0
uint8_t C0
Definition
isi.h:90
ISI_Y2R::Yoff
uint8_t Yoff
Definition
isi.h:102
ISI_Y2R::C3
uint8_t C3
Definition
isi.h:96
ISI_Y2R::Cboff
uint8_t Cboff
Definition
isi.h:100
ISI_Y2R::Croff
uint8_t Croff
Definition
isi.h:98
