RTEMS
6.3
Toggle main menu visibility
bsps
include
bsp
irq-info.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_SHARED_IRQ_INFO_H
38
#define LIBBSP_SHARED_IRQ_INFO_H
39
40
rtems/shell.h
41
rtems/print.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
51
void
bsp_interrupt_report_with_plugin
52
const
rtems_printer
*printer
53
54
58
void
void
59
63
extern
struct
rtems_shell_cmd_tt
bsp_interrupt_shell_command
64
66
67
#ifdef __cplusplus
68
69
#endif
/* __cplusplus */
70
71
#endif
/* LIBBSP_SHARED_IRQ_INFO_H */
void bsp_interrupt_report_with_plugin(const rtems_printer *printer)
Prints interrupt information via the printk plugin print with the context context.
Definition
irq-info.c:71
struct rtems_shell_cmd_tt bsp_interrupt_shell_command
Shell command entry for interrupt information.
Definition
irq-shell.c:53
void bsp_interrupt_report(void)
Prints interrupt information via the default printk plugin.
Definition
irq-info.c:105
print.h
User print interface to the bspIO print plug in.
shell.h
Instantatiate a New Terminal Shell.
rtems_printer
Definition
printer.h:76
rtems_shell_cmd_tt
Definition
shell.h:79
