RTEMS 6.3
access.h File Reference
PCI Access Methods. More...
#include <stdint.h>
#include <libcpu/byteorder.h>
#include <pci.h>
struct  pci_cfg_ops
struct  pci_io_ops
struct  pci_memreg_ops
struct  pci_access_drv
#define PCI_DEV(bus, slot, func)
#define PCI_DEV_BUS(dev)
#define PCI_DEV_SLOT(dev)
#define PCI_DEV_FUNC(dev)
#define PCI_DEV_DEVFUNC(dev)
#define PCI_DEV_EXPAND(dev)
typedef uint16_t pci_dev_t
typedef uint8_t(*) pci_ld8_t(uint8_t *adr)
typedef void(*) pci_st8_t(uint8_t *adr, uint8_t data)
typedef uint16_t pci_ld16_t(uint16_t *adr)
typedef void(*) pci_st16_t(uint16_t *adr, uint16_t data)
typedef uint32_t(*) pci_ld32_t(uint32_t *adr)
typedef void(*) pci_st32_t(uint32_t *adr, uint32_t data)
int pci_access_drv_register (struct pci_access_drv *drv)
void pci_modify_cmdsts (pci_dev_t dev, uint32_t mask, uint32_t val)
int pci_cfg_r8 (pci_dev_t dev, int ofs, uint8_t *data)
int pci_cfg_r16 (pci_dev_t dev, int ofs, uint16_t *data)
int pci_cfg_r32 (pci_dev_t dev, int ofs, uint32_t *data)
int pci_cfg_w8 (pci_dev_t dev, int ofs, uint8_t data)
int pci_cfg_w16 (pci_dev_t dev, int ofs, uint16_t data)
int pci_cfg_w32 (pci_dev_t dev, int ofs, uint32_t data)
uint8_t pci_io_r8 (uint32_t adr)
uint16_t pci_io_r16 (uint32_t adr)
uint32_t pci_io_r32 (uint32_t adr)
void pci_io_w8 (uint32_t adr, uint8_t data)
void pci_io_w16 (uint32_t adr, uint16_t data)
void pci_io_w32 (uint32_t adr, uint32_t data)
uint8_t pci_mem_ld8 (uint8_t *adr)
void pci_mem_st8 (uint8_t *adr, uint8_t data)
uint16_t pci_mem_be_ld_le16 (uint16_t *adr)
uint16_t pci_mem_be_ld_be16 (uint16_t *adr)
uint32_t pci_mem_be_ld_le32 (uint32_t *adr)
uint32_t pci_mem_be_ld_be32 (uint32_t *adr)
void pci_mem_be_st_le16 (uint16_t *adr, uint16_t data)
void pci_mem_be_st_be16 (uint16_t *adr, uint16_t data)
void pci_mem_be_st_le32 (uint32_t *adr, uint32_t data)
void pci_mem_be_st_be32 (uint32_t *adr, uint32_t data)
uint16_t pci_mem_le_ld_le16 (uint16_t *adr)
uint16_t pci_mem_le_ld_be16 (uint16_t *adr)
uint32_t pci_mem_le_ld_le32 (uint32_t *adr)
uint32_t pci_mem_le_ld_be32 (uint32_t *adr)
void pci_mem_le_st_le16 (uint16_t *adr, uint16_t data)
void pci_mem_le_st_be16 (uint16_t *adr, uint16_t data)
void pci_mem_le_st_le32 (uint32_t *adr, uint32_t data)
void pci_mem_le_st_be32 (uint32_t *adr, uint32_t data)
int pci_access_func (int wr, int size, void **func, int endian, int type)
struct pci_access_drv pci_access_ops
struct pci_memreg_ops pci_mem_le_ops
struct pci_memreg_ops pci_mem_be_ops
PCI Access Methods.
Routines to access PCI memory/configuration space and other PCI related functions the PCI Library provides.
◆ PCI_DEV
#define PCI_DEV ( bus,
slot,
func )
Value:
(((bus)<<8) | ((slot)<<3) | (func))
◆ PCI_DEV_BUS
#define PCI_DEV_BUS ( dev)
Value:
(((dev) >> 8) & 0xff)
◆ PCI_DEV_DEVFUNC
#define PCI_DEV_DEVFUNC ( dev)
Value:
((dev) & 0xff)
◆ PCI_DEV_EXPAND
#define PCI_DEV_EXPAND ( dev)
Value:
PCI_DEV_BUS((dev)), PCI_DEV_SLOT((dev)), PCI_DEV_FUNC((dev))
◆ PCI_DEV_FUNC
#define PCI_DEV_FUNC ( dev)
Value:
((dev) & 0x7)
◆ PCI_DEV_SLOT
#define PCI_DEV_SLOT ( dev)
Value:
(((dev) >> 3) & 0x1f)
