RTEMS
6.3
Toggle main menu visibility
bsps
include
fsl
regs-edma.h
1
6
7
8
* Copyright (C) 2011, 2020 embedded brains GmbH & Co. KG
9
10
11
* modification, are permitted provided that the following conditions
12
* are met:
13
* 1. Redistributions of source code must retain the above copyright
14
* notice, this list of conditions and the following disclaimer.
15
* 2. Redistributions in binary form must reproduce the above copyright
16
* notice, this list of conditions and the following disclaimer in the
17
* documentation and/or other materials provided with the distribution.
18
19
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
20
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
23
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
24
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
25
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
27
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
28
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
29
* POSSIBILITY OF SUCH DAMAGE.
30
31
32
33
34
* Copyright:
35
* Freescale Semiconductor, INC. All Rights Reserved.
36
* You are hereby granted a copyright license to use, modify, and
37
* distribute the SOFTWARE so long as this entire notice is
38
* retained without alteration in any modified and/or redistributed
39
* versions, and that such modified versions are clearly identified
40
* as such. No licenses are granted by implication, estoppel or
41
* otherwise under any patents or trademarks of Freescale
42
* Semiconductor, Inc. This software is provided on an "AS IS"
43
* basis and without warranty.
44
45
* To the maximum extent permitted by applicable law, Freescale
46
* Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
47
* INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
48
* PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
49
* REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
50
* AND ANY ACCOMPANYING WRITTEN MATERIALS.
51
52
* To the maximum extent permitted by applicable law, IN NO EVENT
53
* SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
54
* (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
55
* BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
56
* PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
57
58
* Freescale Semiconductor assumes no responsibility for the
59
* maintenance and support of this software
60
61
62
63
#ifndef LIBBSP_SHARED_FSL_REGS_EDMA_H
64
#define LIBBSP_SHARED_FSL_REGS_EDMA_H
65
66
#include <stdint.h>
67
#include <bsp.h>
68
#include <bspopts.h>
69
70
#ifdef __cplusplus
71
extern
"C"
72
#endif
73
74
#if (defined(MPC55XX_CHIP_FAMILY) && \
75
(MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567))
76
#define EDMA_HAS_CR_EBW 1
77
#define EDMA_HAS_CR_CX_ECX 1
78
#define EDMA_HAS_CR_EMLM_CLM_HALT_HOE 1
79
#define EDMA_HAS_ESR_ECX 1
80
#define EDMA_HAS_HRS 1
81
#define EDMA_HAS_CPR_DPA 1
82
#endif
83
84
#if defined(LIBBSP_ARM_IMXRT_BSP_H)
85
86
87
#define EDMA_HAS_CR_ACTIVE 1
88
#define EDMA_HAS_CR_VERSION 1
89
90
91
#define EDMA_HAS_EARS 1
92
93
#endif
94
95
struct
fsl_edma
96
uint32_t CR;
97
#ifdef EDMA_HAS_CR_EBW
98
#define EDMA_CR_EBW (1 << 0)
99
#endif
100
#define EDMA_CR_EDBG (1 << 1)
101
#define EDMA_CR_ERCA (1 << 2)
102
#define EDMA_CR_ERGA (1 << 3)
103
#ifdef EDMA_HAS_CR_EMLM_CLM_HALT_HOE
104
#define EDMA_CR_HOE (1 << 4)
105
#define EDMA_CR_HALT (1 << 5)
106
#define EDMA_CR_CLM (1 << 6)
107
#define EDMA_CR_EMLM (1 << 7)
108
#endif
109
#define EDMA_CR_GRPxPRI_SHIFT(x) (8 + (x) * 2)
110
#define EDMA_CR_GRPxPRI_MASK(x) (0x3 << EDMA_CR_GRPxPRI_SHIFT(x))
111
#define EDMA_CR_GRPxPRI(x,val) (((val) << EDMA_CR_GRPxPRI_SHIFT(x)) & EDMA_CR_GRPxPRI_MASK(x))
112
#define EDMA_CR_GRPxPRI_GET(x,reg) (((reg) & EDMA_CR_GRPxPRI_MASK(x)) >> EDMA_CR_GRPxPRI_SHIFT(x))
113
#ifdef EDMA_HAS_CR_CX_ECX
114
#define EDMA_CR_ECX (1 << 16)
115
#define EDMA_CR_CX (1 << 17)
116
#endif
117
#ifdef EDMA_HAS_CR_VERSION
118
#define EDMA_CR_VERSION_SHIFT (24)
119
#define EDMA_CR_VERSION_MASK (0x7F << EDMA_CR_VERSION_SHIFT)
120
#define EDMA_CR_VERSION(val) (((val) << EDMA_CR_VERSION_SHIFT) & EDMA_CR_VERSION_MASK)
121
#define EDMA_CR_VERSION_GET(reg) (((reg) & EDMA_CR_VERSION_MASK) >> EDMA_CR_VERSION_SHIFT)
122
#endif
123
#ifdef EDMA_HAS_CR_ACTIVE
124
#define EDMA_CR_ACTIVE (1 << 31)
125
#endif
126
127
uint32_t ESR;
128
#define EDMA_ESR_DBE (1 << 0)
129
#define EDMA_ESR_SBE (1 << 1)
130
#define EDMA_ESR_SGE (1 << 2)
131
#define EDMA_ESR_NCE (1 << 3)
132
#define EDMA_ESR_DOE (1 << 4)
133
#define EDMA_ESR_DAE (1 << 5)
134
#define EDMA_ESR_SOE (1 << 6)
135
#define EDMA_ESR_SAE (1 << 7)
136
#define EDMA_ESR_ERRCHN_SHIFT (8)
137
#define EDMA_ESR_ERRCHN_MASK (0x3F << EDMA_ESR_ERRCHN_SHIFT)
138
#define EDMA_ESR_ERRCHN(val) (((val) << EDMA_ESR_ERRCHN_SHIFT) & EDMA_ESR_ERRCHN_MASK)
139
#define EDMA_ESR_ERRCHN_GET(reg) (((reg) & EDMA_ESR_ERRCHN_MASK) >> EDMA_ESR_ERRCHN_SHIFT)
140
#define EDMA_ESR_CPE (1 << 14)
141
#define EDMA_ESR_GPE (1 << 15)
142
#ifdef EDMA_HAS_ESR_ECX
143
#define EDMA_ESR_ECX (1 << 16)
144
#endif
145
#define EDMA_ESR_VLD (1 << 31)
146
147
uint32_t ERRQH;
148
#define EDMA_ERRQH_ERRQ(x) (1 << ((x) - 32))
149
150
uint32_t ERRQL;
151
#define EDMA_ERRQL_ERRQ(x) (1 << (x))
152
153
uint32_t EEIH;
154
#define EDMA_EEIH_EEI(x) (1 << ((x) - 32))
155
156
uint32_t EEIL;
157
#define EDMA_EEIL_EEI(x) (1 << (x))
158
159
#if __BYTE_ORDER__ == __ORDER_BIG_ENDIAN__
160
uint8_t SERQR;
161
uint8_t CERQR;
162
uint8_t SEEIR;
163
uint8_t CEEIR;
164
#elif __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
165
uint8_t CEEIR;
166
uint8_t SEEIR;
167
uint8_t CERQR;
168
uint8_t SERQR;
169
#endif
170
#define EDMA_SERQR_NOP (1 << 7)
171
#define EDMA_SERQR_SAER (1 << 6)
172
#define EDMA_SERQR_SERQ_SHIFT (0)
173
#define EDMA_SERQR_SERQ_MASK (0x1F << EDMA_CIRQR_SERQ_SHIFT)
174
#define EDMA_SERQR_SERQ(val) (((val) << EDMA_CIRQR_SERQ_SHIFT) & EDMA_CIRQR_SERQ_MASK)
175
#define EDMA_SERQR_SERQ_GET(reg) (((reg) & EDMA_CIRQR_SERQ_MASK) >> EDMA_CIRQR_SERQ_SHIFT)
176
#define EDMA_CERQR_NOP (1 << 7)
177
#define EDMA_CERQR_CAER (1 << 6)
178
#define EDMA_CERQR_CERQ_SHIFT (0)
179
#define EDMA_CERQR_CERQ_MASK (0x1F << EDMA_CIRQR_CERQ_SHIFT)
180
#define EDMA_CERQR_CERQ(val) (((val) << EDMA_CIRQR_CERQ_SHIFT) & EDMA_CIRQR_CERQ_MASK)
181
#define EDMA_CERQR_CERQ_GET(reg) (((reg) & EDMA_CIRQR_CERQ_MASK) >> EDMA_CIRQR_CERQ_SHIFT)
182
#define EDMA_SEEIR_NOP (1 << 7)
183
#define EDMA_SEEIR_SAEE (1 << 6)
184
#define EDMA_SEEIR_SEEI_SHIFT (0)
185
#define EDMA_SEEIR_SEEI_MASK (0x1F << EDMA_CIRQR_SEEI_SHIFT)
186
#define EDMA_SEEIR_SEEI(val) (((val) << EDMA_CIRQR_SEEI_SHIFT) & EDMA_CIRQR_SEEI_MASK)
187
#define EDMA_SEEIR_SEEI_GET(reg) (((reg) & EDMA_CIRQR_SEEI_MASK) >> EDMA_CIRQR_SEEI_SHIFT)
188
#define EDMA_CEEIR_NOP (1 << 7)
189
#define EDMA_CEEIR_CAEE (1 << 6)
190
#define EDMA_CEEIR_CEEI_SHIFT (0)
191
#define EDMA_CEEIR_CEEI_MASK (0x1F << EDMA_CIRQR_CEEI_SHIFT)
192
#define EDMA_CEEIR_CEEI(val) (((val) << EDMA_CIRQR_CEEI_SHIFT) & EDMA_CIRQR_CEEI_MASK)
193
#define EDMA_CEEIR_CEEI_GET(reg) (((reg) & EDMA_CIRQR_CEEI_MASK) >> EDMA_CIRQR_CEEI_SHIFT)
194
195
196
uint8_t CIRQR;
197
uint8_t CER;
198
uint8_t SSBR;
199
uint8_t CDSBR;
200
201
uint8_t CDSBR;
202
uint8_t SSBR;
203
uint8_t CER;
204
uint8_t CIRQR;
205
#endif
206
#define EDMA_CIRQR_NOP (1 << 7)
207
#define EDMA_CIRQR_CAIR (1 << 6)
208
#define EDMA_CIRQR_CINT_SHIFT (0)
209
#define EDMA_CIRQR_CINT_MASK (0x1F << EDMA_CIRQR_CINT_SHIFT)
210
#define EDMA_CIRQR_CINT(val) (((val) << EDMA_CIRQR_CINT_SHIFT) & EDMA_CIRQR_CINT_MASK)
211
#define EDMA_CIRQR_CINT_GET(reg) (((reg) & EDMA_CIRQR_CINT_MASK) >> EDMA_CIRQR_CINT_SHIFT)
212
#define EDMA_CER_NOP (1 << 7)
213
#define EDMA_CER_CAEI (1 << 6)
214
#define EDMA_CER_CERR_SHIFT (0)
215
#define EDMA_CER_CERR_MASK (0x1F << EDMA_CIRQR_CERR_SHIFT)
216
#define EDMA_CER_CERR(val) (((val) << EDMA_CIRQR_CERR_SHIFT) & EDMA_CIRQR_CERR_MASK)
217
#define EDMA_CER_CERR_GET(reg) (((reg) & EDMA_CIRQR_CERR_MASK) >> EDMA_CIRQR_CERR_SHIFT)
218
#define EDMA_SSBR_NOP (1 << 7)
219
#define EDMA_SSBR_SAST (1 << 6)
220
#define EDMA_SSBR_SSB_SHIFT (0)
221
#define EDMA_SSBR_SSB_MASK (0x1F << EDMA_CIRQR_SSB_SHIFT)
222
#define EDMA_SSBR_SSB(val) (((val) << EDMA_CIRQR_SSB_SHIFT) & EDMA_CIRQR_SSB_MASK)
223
#define EDMA_SSBR_SSB_GET(reg) (((reg) & EDMA_CIRQR_SSB_MASK) >> EDMA_CIRQR_SSB_SHIFT)
224
#define EDMA_CDSBR_NOP (1 << 7)
225
#define EDMA_CDSBR_CADN (1 << 6)
226
#define EDMA_CDSBR_CDSB_SHIFT (0)
227
#define EDMA_CDSBR_CDSB_MASK (0x1F << EDMA_CIRQR_CDSB_SHIFT)
228
#define EDMA_CDSBR_CDSB(val) (((val) << EDMA_CIRQR_CDSB_SHIFT) & EDMA_CIRQR_CDSB_MASK)
229
#define EDMA_CDSBR_CDSB_GET(reg) (((reg) & EDMA_CIRQR_CDSB_MASK) >> EDMA_CIRQR_CDSB_SHIFT)
230
231
uint32_t IRQH;
232
#define EDMA_IRQH_INT(x) (1 << ((x) - 32))
233
234
uint32_t IRQL;
235
#define EDMA_IRQL_INT(x) (1 << ((x)))
236
237
uint32_t ERH;
238
#define EDMA_ERH_ERR(x) (1 << ((x) - 32))
239
240
uint32_t ERL;
241
#define EDMA_ERL_ERR(x) (1 << ((x)))
242
243
#ifdef EDMA_HAS_HRS
244
uint32_t HRS;
245
#define EDMA_HRSH_HRS(x) (1 << ((x) - 32))
246
247
uint32_t HRSL;
248
#define EDMA_HRSL_HRS(x) (1 << ((x)))
249
#else
250
uint32_t reserved0030[2];
251
#endif
252
253
uint32_t reserved0038[(0x44-0x38)/4];
254
255
#ifdef EDMA_HAS_EARS
256
uint32_t EARSL;
257
#define EDMA_EARSL_EDREQ(x) (1 << ((x)))
/* iMXRT only */
258
#else
259
uint32_t reserved0044;
260
#endif
261
262
uint32_t reserved0048[(0x100-0x48)/4];
263
264
uint8_t CPR[64];
265
#define EDMA_CPR_CHPRI_SHIFT (0)
266
#define EDMA_CPR_CHPRI_MASK (0xF << EDMA_CPR_CHPRI_SHIFT)
267
#define EDMA_CPR_CHPRI(val) (((val) << EDMA_CPR_CHPRI_SHIFT) & EDMA_CPR_CHPRI_MASK)
268
#define EDMA_CPR_CHPRI_GET(reg) (((reg) & EDMA_CPR_CHPRI_MASK) >> EDMA_CPR_CHPRI_SHIFT)
269
#define EDMA_CPR_GRPPRI_SHIFT (0)
270
#define EDMA_CPR_GRPPRI_MASK (0xF << EDMA_CPR_GRPPRI_SHIFT)
271
#define EDMA_CPR_GRPPRI(val) (((val) << EDMA_CPR_GRPPRI_SHIFT) & EDMA_CPR_GRPPRI_MASK)
272
#define EDMA_CPR_GRPPRI_GET(reg) (((reg) & EDMA_CPR_GRPPRI_MASK) >> EDMA_CPR_GRPPRI_SHIFT)
273
#ifdef EDMA_HAS_CPR_DPA
274
#define EDMA_CPR_DPA (1 << 6)
275
#endif
276
#define EDMA_CPR_ECP (1 << 7)
277
278
uint32_t reserved0140[(0x1000-0x140)/4];
279
280
struct
fsl_edma_tcd
281
uint32_t SADDR;
282
uint32_t SDF;
283
#define EDMA_TCD_SDF_SMOD_SHIFT (27)
284
#define EDMA_TCD_SDF_SMOD_MASK (0x1F << EDMA_TCD_SDF_SMOD_SHIFT)
285
#define EDMA_TCD_SDF_SMOD(val) (((val) << EDMA_TCD_SDF_SMOD_SHIFT) & EDMA_TCD_SDF_SMOD_MASK)
286
#define EDMA_TCD_SDF_SMOD_GET(reg) (((reg) & EDMA_TCD_SDF_SMOD_MASK) >> EDMA_TCD_SDF_SMOD_SHIFT)
287
#define EDMA_TCD_SDF_SSIZE_SHIFT (24)
288
#define EDMA_TCD_SDF_SSIZE_MASK (0x7 << EDMA_TCD_SDF_SSIZE_SHIFT)
289
#define EDMA_TCD_SDF_SSIZE(val) (((val) << EDMA_TCD_SDF_SSIZE_SHIFT) & EDMA_TCD_SDF_SSIZE_MASK)
290
#define EDMA_TCD_SDF_SSIZE_GET(reg) (((reg) & EDMA_TCD_SDF_SSIZE_MASK) >> EDMA_TCD_SDF_SSIZE_SHIFT)
291
#define EDMA_TCD_SDF_SSIZE_8BIT EDMA_TCD_SDF_SSIZE(0)
292
#define EDMA_TCD_SDF_SSIZE_16BIT EDMA_TCD_SDF_SSIZE(1)
293
#define EDMA_TCD_SDF_SSIZE_32BIT EDMA_TCD_SDF_SSIZE(2)
294
#define EDMA_TCD_SDF_SSIZE_64BIT EDMA_TCD_SDF_SSIZE(3)
295
#define EDMA_TCD_SDF_SSIZE_32BYTE EDMA_TCD_SDF_SSIZE(5)
296
#define EDMA_TCD_SDF_DMOD_SHIFT (19)
297
#define EDMA_TCD_SDF_DMOD_MASK (0x1F << EDMA_TCD_SDF_DMOD_SHIFT)
298
#define EDMA_TCD_SDF_DMOD(val) (((val) << EDMA_TCD_SDF_DMOD_SHIFT) & EDMA_TCD_SDF_DMOD_MASK)
299
#define EDMA_TCD_SDF_DMOD_GET(reg) (((reg) & EDMA_TCD_SDF_DMOD_MASK) >> EDMA_TCD_SDF_DMOD_SHIFT)
300
#define EDMA_TCD_SDF_DSIZE_SHIFT (16)
301
#define EDMA_TCD_SDF_DSIZE_MASK (0x7 << EDMA_TCD_SDF_DSIZE_SHIFT)
302
#define EDMA_TCD_SDF_DSIZE(val) (((val) << EDMA_TCD_SDF_DSIZE_SHIFT) & EDMA_TCD_SDF_DSIZE_MASK)
303
#define EDMA_TCD_SDF_DSIZE_GET(reg) (((reg) & EDMA_TCD_SDF_DSIZE_MASK) >> EDMA_TCD_SDF_DSIZE_SHIFT)
304
#define EDMA_TCD_SDF_DSIZE_8BIT EDMA_TCD_SDF_DSIZE(0)
305
#define EDMA_TCD_SDF_DSIZE_16BIT EDMA_TCD_SDF_DSIZE(1)
306
#define EDMA_TCD_SDF_DSIZE_32BIT EDMA_TCD_SDF_DSIZE(2)
307
#define EDMA_TCD_SDF_DSIZE_64BIT EDMA_TCD_SDF_DSIZE(3)
308
#define EDMA_TCD_SDF_DSIZE_32BYTE EDMA_TCD_SDF_DSIZE(5)
309
#define EDMA_TCD_SDF_SOFF_SHIFT (0)
310
#define EDMA_TCD_SDF_SOFF_MASK (0xFFFF << EDMA_TCD_SDF_SOFF_SHIFT)
311
#define EDMA_TCD_SDF_SOFF(val) (((val) << EDMA_TCD_SDF_SOFF_SHIFT) & EDMA_TCD_SDF_SOFF_MASK)
312
#define EDMA_TCD_SDF_SOFF_GET(reg) (((reg) & EDMA_TCD_SDF_SOFF_MASK) >> EDMA_TCD_SDF_SOFF_SHIFT)
313
314
uint32_t NBYTES;
315
#define EDMA_TCD_NBYTES_ALT_NBYTES_SHIFT (0)
316
#define EDMA_TCD_NBYTES_ALT_NBYTES_MASK (0x3FF << EDMA_TCD_NBYTES_ALT_NBYTES_SHIFT)
317
#define EDMA_TCD_NBYTES_ALT_NBYTES(val) (((val) << EDMA_TCD_NBYTES_ALT_NBYTES_SHIFT) & EDMA_TCD_NBYTES_ALT_NBYTES_MASK)
318
#define EDMA_TCD_NBYTES_ALT_MLOFF_SHIFT (10)
319
#define EDMA_TCD_NBYTES_ALT_MLOFF_MASK (0xFFFFF << EDMA_TCD_NBYTES_ALT_MLOFF_SHIFT)
320
#define EDMA_TCD_NBYTES_ALT_MLOFF(val) (((val) << EDMA_TCD_NBYTES_ALT_MLOFF_SHIFT) & EDMA_TCD_NBYTES_ALT_MLOFF_MASK)
321
#define EDMA_TCD_NBYTES_ALT_DMLOE (1 << 30)
322
#define EDMA_TCD_NBYTES_ALT_SMLOE (1 << 31)
323
int32_t SLAST;
324
uint32_t DADDR;
325
uint32_t CDF;
326
#define EDMA_TCD_CDF_CITERE_LINK (1 << 31)
327
#define EDMA_TCD_CDF_CITER_SHIFT (16)
328
#define EDMA_TCD_CDF_CITER_MASK (0x7FFF << EDMA_TCD_CDF_CITER_SHIFT)
329
#define EDMA_TCD_CDF_CITER(val) (((val) << EDMA_TCD_CDF_CITER_SHIFT) & EDMA_TCD_CDF_CITER_MASK)
330
#define EDMA_TCD_CDF_CITER_GET(reg) (((reg) & EDMA_TCD_CDF_CITER_MASK) >> EDMA_TCD_CDF_CITER_SHIFT)
331
#define EDMA_TCD_CDF_DOFF_SHIFT (0)
332
#define EDMA_TCD_CDF_DOFF_MASK (0xFFFF << EDMA_TCD_CDF_DOFF_SHIFT)
333
#define EDMA_TCD_CDF_DOFF(val) (((val) << EDMA_TCD_CDF_DOFF_SHIFT) & EDMA_TCD_CDF_DOFF_MASK)
334
#define EDMA_TCD_CDF_DOFF_GET(reg) (((reg) & EDMA_TCD_CDF_DOFF_MASK) >> EDMA_TCD_CDF_DOFF_SHIFT)
335
336
#define EDMA_TCD_CDF_ALT_CITERLINKCH_SHIFT (25)
337
#define EDMA_TCD_CDF_ALT_CITERLINKCH_MASK (0x3F << EDMA_TCD_CDF_ALT_CITERLINKCH_SHIFT)
338
#define EDMA_TCD_CDF_ALT_CITERLINKCH(val) (((val) << EDMA_TCD_CDF_ALT_CITERLINKCH_SHIFT) & EDMA_TCD_CDF_ALT_CITERLINKCH_MASK)
339
#define EDMA_TCD_CDF_ALT_CITERLINKCH_GET(reg) (((reg) & EDMA_TCD_CDF_ALT_CITERLINKCH_MASK) >> EDMA_TCD_CDF_ALT_CITERLINKCH_SHIFT)
340
#define EDMA_TCD_CDF_ALT_CITER_SHIFT (16)
341
#define EDMA_TCD_CDF_ALT_CITER_MASK (0x1FF << EDMA_TCD_CDF_ALT_CITER_SHIFT)
342
#define EDMA_TCD_CDF_ALT_CITER(val) (((val) << EDMA_TCD_CDF_ALT_CITER_SHIFT) & EDMA_TCD_CDF_ALT_CITER_MASK)
343
#define EDMA_TCD_CDF_ALT_CITER_GET(reg) (((reg) & EDMA_TCD_CDF_ALT_CITER_MASK) >> EDMA_TCD_CDF_ALT_CITER_SHIFT)
344
345
#define EDMA_TCD_CDF_NOLINK_CITER_SHIFT (16)
346
#define EDMA_TCD_CDF_NOLINK_CITER_MASK (0xFFFF << EDMA_TCD_CDF_NOLINK_CITER_SHIFT)
347
#define EDMA_TCD_CDF_NOLINK_CITER(val) (((val) << EDMA_TCD_CDF_NOLINK_CITER_SHIFT) & EDMA_TCD_CDF_NOLINK_CITER_MASK)
348
#define EDMA_TCD_CDF_NOLINK_CITER_GET(reg) (((reg) & EDMA_TCD_CDF_NOLINK_CITER_MASK) >> EDMA_TCD_CDF_NOLINK_CITER_SHIFT)
349
350
int32_t DLAST_SGA;
351
uint32_t BMF;
352
#define EDMA_TCD_BMF_BITERE_LINK (1 << 31)
353
#define EDMA_TCD_BMF_BITER_SHIFT (16)
354
#define EDMA_TCD_BMF_BITER_MASK (0x7FFF << EDMA_TCD_BMF_BITER_SHIFT)
355
#define EDMA_TCD_BMF_BITER(val) (((val) << EDMA_TCD_BMF_BITER_SHIFT) & EDMA_TCD_BMF_BITER_MASK)
356
#define EDMA_TCD_BMF_BITER_GET(reg) (((reg) & EDMA_TCD_BMF_BITER_MASK) >> EDMA_TCD_BMF_BITER_SHIFT)
357
#define EDMA_TCD_BMF_BWC_SHIFT (14)
358
#define EDMA_TCD_BMF_BWC_MASK (0x3 << EDMA_TCD_BMF_BWC_SHIFT)
359
#define EDMA_TCD_BMF_BWC(val) (((val) << EDMA_TCD_BMF_BWC_SHIFT) & EDMA_TCD_BMF_BWC_MASK)
360
#define EDMA_TCD_BMF_BWC_GET(reg) (((reg) & EDMA_TCD_BMF_BWC_MASK) >> EDMA_TCD_BMF_BWC_SHIFT)
361
#define EDMA_TCD_BMF_MAJORLINKCH_SHIFT (8)
362
#define EDMA_TCD_BMF_MAJORLINKCH_MASK (0x3F << EDMA_TCD_BMF_MAJORLINKCH_SHIFT)
363
#define EDMA_TCD_BMF_MAJORLINKCH(val) (((val) << EDMA_TCD_BMF_MAJORLINKCH_SHIFT) & EDMA_TCD_BMF_MAJORLINKCH_MASK)
364
#define EDMA_TCD_BMF_MAJORLINKCH_GET(reg) (((reg) & EDMA_TCD_BMF_MAJORLINKCH_MASK) >> EDMA_TCD_BMF_MAJORLINKCH_SHIFT)
365
#define EDMA_TCD_BMF_DONE (1 << 7)
366
#define EDMA_TCD_BMF_ACTIVE (1 << 6)
367
#define EDMA_TCD_BMF_MAJORE_LINK (1 << 5)
368
#define EDMA_TCD_BMF_E_SG (1 << 4)
369
#define EDMA_TCD_BMF_D_REQ (1 << 3)
370
#define EDMA_TCD_BMF_INT_HALF (1 << 2)
371
#define EDMA_TCD_BMF_INT_MAJ (1 << 1)
372
#define EDMA_TCD_BMF_START (1 << 0)
373
374
#define EDMA_TCD_BMF_ALT_BITERLINKCH_SHIFT (25)
375
#define EDMA_TCD_BMF_ALT_BITERLINKCH_MASK (0x3F << EDMA_TCD_BMF_ALT_BITERLINKCH_SHIFT)
376
#define EDMA_TCD_BMF_ALT_BITERLINKCH(val) (((val) << EDMA_TCD_BMF_ALT_BITERLINKCH_SHIFT) & EDMA_TCD_BMF_ALT_BITERLINKCH_MASK)
377
#define EDMA_TCD_BMF_ALT_BITERLINKCH_GET(reg) (((reg) & EDMA_TCD_BMF_ALT_BITERLINKCH_MASK) >> EDMA_TCD_BMF_ALT_BITERLINKCH_SHIFT)
378
#define EDMA_TCD_BMF_ALT_BITER_SHIFT (16)
379
#define EDMA_TCD_BMF_ALT_BITER_MASK (0x1FF << EDMA_TCD_BMF_ALT_BITER_SHIFT)
380
#define EDMA_TCD_BMF_ALT_BITER(val) (((val) << EDMA_TCD_BMF_ALT_BITER_SHIFT) & EDMA_TCD_BMF_ALT_BITER_MASK)
381
#define EDMA_TCD_BMF_ALT_BITER_GET(reg) (((reg) & EDMA_TCD_BMF_ALT_BITER_MASK) >> EDMA_TCD_BMF_ALT_BITER_SHIFT)
382
383
#define EDMA_TCD_BMF_NOLINK_BITER_SHIFT (16)
384
#define EDMA_TCD_BMF_NOLINK_BITER_MASK (0xFFFF << EDMA_TCD_BMF_NOLINK_BITER_SHIFT)
385
#define EDMA_TCD_BMF_NOLINK_BITER(val) (((val) << EDMA_TCD_BMF_NOLINK_BITER_SHIFT) & EDMA_TCD_BMF_NOLINK_BITER_MASK)
386
#define EDMA_TCD_BMF_NOLINK_BITER_GET(reg) (((reg) & EDMA_TCD_BMF_NOLINK_BITER_MASK) >> EDMA_TCD_BMF_NOLINK_BITER_SHIFT)
387
388
} TCD[64];
389
390
391
#ifndef __cplusplus
392
static
const
struct
fsl_edma_tcd EDMA_TCD_DEFAULT = {
393
.SADDR = 0,
394
.SDF = 0,
395
.NBYTES = 0,
396
.SLAST = 0,
397
.DADDR = 0,
398
.CDF = 0,
399
.DLAST_SGA = 0,
400
.BMF = 0,
401
402
#endif
/* __cplusplus */
403
404
#define EDMA_TCD_BITER_MASK 0x7fff
405
406
#define EDMA_TCD_BITER_SIZE (EDMA_TCD_BITER_MASK + 1)
407
408
#define EDMA_TCD_BITER_LINKED_MASK 0x1ff
409
410
#define EDMA_TCD_BITER_LINKED_SIZE (EDMA_TCD_BITER_LINKED_MASK + 1)
411
412
#define EDMA_TCD_LINK_AND_BITER(link, biter) \
413
(((link) << 9) + ((biter) & EDMA_TCD_BITER_LINKED_MASK))
414
415
#ifdef __cplusplus
416
417
#endif
/* __cplusplus */
418
419
#endif
/* LIBBSP_SHARED_FSL_REGS_EDMA_H */
fsl_edma::fsl_edma_tcd
Definition
regs-edma.h:280
fsl_edma
Definition
regs-edma.h:95
