RTEMS
6.3
Toggle main menu visibility
bsps
arm
imxrt
include
imxrt
mpu-config.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H
37
#define LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H
38
39
#include <bsp/start.h>
40
rtems/score/armv7m.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
/* __cplusplus */
45
46
extern
BSP_START_DATA_SECTION
const
ARMV7M_MPU_Region_config
47
imxrt_config_mpu_region[];
48
extern
const
size_t
imxrt_config_mpu_region_count;
49
50
#ifdef __cplusplus
51
52
#endif
/* __cplusplus */
53
54
#endif
/* LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H */
armv7m.h
This header file provides interfaces of the ARMv7-M architecture support.
