RTEMS
6.3
Toggle main menu visibility
bsps
arm
imxrt
include
imxrt
imxrt1050-pinfunc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
37
#define LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
/* __cplusplus */
42
43
/* GPIO_AD_B0_00 */
44
#define IMXRT_PAD_GPIO_AD_B0_00__PWM2_A3 0x00bc 0x02ac 0x0474 0 2
45
#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_OUT14 0x00bc 0x02ac 0x0644 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */
46
#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_IN14 0x00bc 0x02ac 0x0644 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */
47
#define IMXRT_PAD_GPIO_AD_B0_00__XTALOSC24M_REF_CLK_32K 0x00bc 0x02ac 0x0000 2 0
48
#define IMXRT_PAD_GPIO_AD_B0_00__USB2_usb_otg2_id 0x00bc 0x02ac 0x03f8 3 0
49
#define IMXRT_PAD_GPIO_AD_B0_00__LPI2C1_SCLS 0x00bc 0x02ac 0x0000 4 0
50
#define IMXRT_PAD_GPIO_AD_B0_00__GPIO1_gpio_io00 0x00bc 0x02ac 0x0000 5 0
51
#define IMXRT_PAD_GPIO_AD_B0_00__USDHC1_usdhc_reset_b 0x00bc 0x02ac 0x0000 6 0
52
#define IMXRT_PAD_GPIO_AD_B0_00__LPSPI3_SCK 0x00bc 0x02ac 0x0510 7 0
53
#define IMXRT_PAD_GPIO_AD_B0_00__CMP1_IN4 0x00bc 0x02ac 0x0000 5 0
54
55
/* GPIO_AD_B0_01 */
56
#define IMXRT_PAD_GPIO_AD_B0_01__PWM2_B3 0x00c0 0x02b0 0x0484 0 2
57
#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_OUT15 0x00c0 0x02b0 0x0648 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */
58
#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_IN15 0x00c0 0x02b0 0x0648 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */
59
#define IMXRT_PAD_GPIO_AD_B0_01__XTALOSC24M_REF_CLK_24M 0x00c0 0x02b0 0x0000 2 0
60
#define IMXRT_PAD_GPIO_AD_B0_01__USB1_usb_otg1_id 0x00c0 0x02b0 0x03f4 3 0
61
#define IMXRT_PAD_GPIO_AD_B0_01__LPI2C1_SDAS 0x00c0 0x02b0 0x0000 4 0
62
#define IMXRT_PAD_GPIO_AD_B0_01__GPIO1_gpio_io01 0x00c0 0x02b0 0x0000 5 0
63
#define IMXRT_PAD_GPIO_AD_B0_01__EWM_EWM_OUT_B 0x00c0 0x02b0 0x0000 6 0
64
#define IMXRT_PAD_GPIO_AD_B0_01__LPSPI3_SDO 0x00c0 0x02b0 0x0518 7 0
65
#define IMXRT_PAD_GPIO_AD_B0_01__CMP2_IN4 0x00c0 0x02b0 0x0000 5 0
66
67
/* GPIO_AD_B0_02 */
68
#define IMXRT_PAD_GPIO_AD_B0_02__CAN2_TX 0x00c4 0x02b4 0x0000 0 0
69
#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_OUT16 0x00c4 0x02b4 0x064c 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */
70
#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_IN16 0x00c4 0x02b4 0x064c 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */
71
#define IMXRT_PAD_GPIO_AD_B0_02__LPUART6_TX 0x00c4 0x02b4 0x0554 2 1
72
#define IMXRT_PAD_GPIO_AD_B0_02__USB1_usb_otg1_pwr 0x00c4 0x02b4 0x0000 3 0
73
#define IMXRT_PAD_GPIO_AD_B0_02__PWM1_X0 0x00c4 0x02b4 0x0000 4 0
74
#define IMXRT_PAD_GPIO_AD_B0_02__GPIO1_gpio_io02 0x00c4 0x02b4 0x0000 5 0
75
#define IMXRT_PAD_GPIO_AD_B0_02__LPI2C1_HREQ 0x00c4 0x02b4 0x0000 6 0
76
#define IMXRT_PAD_GPIO_AD_B0_02__LPSPI3_SDI 0x00c4 0x02b4 0x0514 7 0
77
#define IMXRT_PAD_GPIO_AD_B0_02__CMP3_IN4 0x00c4 0x02b4 0x0000 5 0
78
79
/* GPIO_AD_B0_03 */
80
#define IMXRT_PAD_GPIO_AD_B0_03__CAN2_RX 0x00c8 0x02b8 0x0450 0 1
81
#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_OUT17 0x00c8 0x02b8 0x062c 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
82
#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_IN17 0x00c8 0x02b8 0x062c 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
83
#define IMXRT_PAD_GPIO_AD_B0_03__LPUART6_RX 0x00c8 0x02b8 0x0550 2 1
84
#define IMXRT_PAD_GPIO_AD_B0_03__USB1_usb_otg1_oc 0x00c8 0x02b8 0x05d0 3 0
85
#define IMXRT_PAD_GPIO_AD_B0_03__PWM1_X1 0x00c8 0x02b8 0x0000 4 0
86
#define IMXRT_PAD_GPIO_AD_B0_03__GPIO1_gpio_io03 0x00c8 0x02b8 0x0000 5 0
87
#define IMXRT_PAD_GPIO_AD_B0_03__XTALOSC24M_REF_CLK_24M 0x00c8 0x02b8 0x0000 6 0
88
#define IMXRT_PAD_GPIO_AD_B0_03__LPSPI3_PCS0 0x00c8 0x02b8 0x050c 7 0
89
#define IMXRT_PAD_GPIO_AD_B0_03__CMP4_IN4 0x00c8 0x02b8 0x0000 5 0
90
91
/* GPIO_AD_B0_04 */
92
#define IMXRT_PAD_GPIO_AD_B0_04__SRC_BOOT_MODE0 0x00cc 0x02bc 0x0000 0 0
93
#define IMXRT_PAD_GPIO_AD_B0_04__MQS_RIGHT 0x00cc 0x02bc 0x0000 1 0
94
#define IMXRT_PAD_GPIO_AD_B0_04__ENET_enet_tx_data3 0x00cc 0x02bc 0x0000 2 0
95
#define IMXRT_PAD_GPIO_AD_B0_04__SAI2_sai_tx_sync 0x00cc 0x02bc 0x05c4 3 1
96
#define IMXRT_PAD_GPIO_AD_B0_04__CSI_csi_data09 0x00cc 0x02bc 0x041c 4 1
97
#define IMXRT_PAD_GPIO_AD_B0_04__GPIO1_gpio_io04 0x00cc 0x02bc 0x0000 5 0
98
#define IMXRT_PAD_GPIO_AD_B0_04__PIT_TRIGGER0 0x00cc 0x02bc 0x0000 6 0
99
#define IMXRT_PAD_GPIO_AD_B0_04__LPSPI3_PCS1 0x00cc 0x02bc 0x0000 7 0
100
101
/* GPIO_AD_B0_05 */
102
#define IMXRT_PAD_GPIO_AD_B0_05__SRC_BOOT_MODE1 0x00d0 0x02c0 0x0000 0 0
103
#define IMXRT_PAD_GPIO_AD_B0_05__MQS_LEFT 0x00d0 0x02c0 0x0000 1 0
104
#define IMXRT_PAD_GPIO_AD_B0_05__ENET_enet_tx_data2 0x00d0 0x02c0 0x0000 2 0
105
#define IMXRT_PAD_GPIO_AD_B0_05__SAI2_sai_tx_bclk 0x00d0 0x02c0 0x05c0 3 1
106
#define IMXRT_PAD_GPIO_AD_B0_05__CSI_csi_data08 0x00d0 0x02c0 0x0418 4 1
107
#define IMXRT_PAD_GPIO_AD_B0_05__GPIO1_gpio_io05 0x00d0 0x02c0 0x0000 5 0
108
#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_OUT17 0x00d0 0x02c0 0x062c 6 2
109
#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_IN17 0x00d0 0x02c0 0x062c 6 2
110
#define IMXRT_PAD_GPIO_AD_B0_05__LPSPI3_PCS2 0x00d0 0x02c0 0x0000 7 0
111
112
/* GPIO_AD_B0_06 */
113
#define IMXRT_PAD_GPIO_AD_B0_06__JTAG_TMS 0x00d4 0x02c4 0x0000 0 0
114
#define IMXRT_PAD_GPIO_AD_B0_06__GPT2_gpt_compare1 0x00d4 0x02c4 0x0000 1 0
115
#define IMXRT_PAD_GPIO_AD_B0_06__ENET_enet_rx_clk 0x00d4 0x02c4 0x0000 2 0
116
#define IMXRT_PAD_GPIO_AD_B0_06__SAI2_sai_rx_bclk 0x00d4 0x02c4 0x05b4 3 1
117
#define IMXRT_PAD_GPIO_AD_B0_06__CSI_csi_data07 0x00d4 0x02c4 0x0414 4 1
118
#define IMXRT_PAD_GPIO_AD_B0_06__GPIO1_gpio_io06 0x00d4 0x02c4 0x0000 5 0
119
#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_OUT18 0x00d4 0x02c4 0x0630 6 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */
120
#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_IN18 0x00d4 0x02c4 0x0630 6 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */
121
#define IMXRT_PAD_GPIO_AD_B0_06__LPSPI3_PCS3 0x00d4 0x02c4 0x0000 7 0
122
123
/* GPIO_AD_B0_07 */
124
#define IMXRT_PAD_GPIO_AD_B0_07__JTAG_TCK 0x00d8 0x02c8 0x0000 0 0
125
#define IMXRT_PAD_GPIO_AD_B0_07__GPT2_gpt_compare2 0x00d8 0x02c8 0x0000 1 0
126
#define IMXRT_PAD_GPIO_AD_B0_07__ENET_enet_tx_er 0x00d8 0x02c8 0x0000 2 0
127
#define IMXRT_PAD_GPIO_AD_B0_07__SAI2_sai_rx_sync 0x00d8 0x02c8 0x05bc 3 1
128
#define IMXRT_PAD_GPIO_AD_B0_07__CSI_csi_data06 0x00d8 0x02c8 0x0410 4 1
129
#define IMXRT_PAD_GPIO_AD_B0_07__GPIO1_gpio_io07 0x00d8 0x02c8 0x0000 5 0
130
#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_OUT19 0x00d8 0x02c8 0x0654 6 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */
131
#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_IN19 0x00d8 0x02c8 0x0654 6 1
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */
132
#define IMXRT_PAD_GPIO_AD_B0_07__ENET_1588_EVENT3_OUT 0x00d8 0x02c8 0x0000 7 0
133
134
/* GPIO_AD_B0_08 */
135
#define IMXRT_PAD_GPIO_AD_B0_08__JTAG_MOD 0x00dc 0x02cc 0x0000 0 0
136
#define IMXRT_PAD_GPIO_AD_B0_08__GPT2_gpt_compare3 0x00dc 0x02cc 0x0000 1 0
137
#define IMXRT_PAD_GPIO_AD_B0_08__ENET_enet_rx_data3 0x00dc 0x02cc 0x0000 2 0
138
#define IMXRT_PAD_GPIO_AD_B0_08__SAI2_sai_rx_data 0x00dc 0x02cc 0x05b8 3 1
139
#define IMXRT_PAD_GPIO_AD_B0_08__CSI_csi_data05 0x00dc 0x02cc 0x040c 4 1
140
#define IMXRT_PAD_GPIO_AD_B0_08__GPIO1_gpio_io08 0x00dc 0x02cc 0x0000 5 0
141
#define IMXRT_PAD_GPIO_AD_B0_08__XBARA1_IN20 0x00dc 0x02cc 0x0634 6 1
142
#define IMXRT_PAD_GPIO_AD_B0_08__ENET_1588_EVENT3_IN 0x00dc 0x02cc 0x0000 7 0
143
144
/* GPIO_AD_B0_09 */
145
#define IMXRT_PAD_GPIO_AD_B0_09__JTAG_TDI 0x00e0 0x02d0 0x0000 0 0
146
#define IMXRT_PAD_GPIO_AD_B0_09__PWM2_A3 0x00e0 0x02d0 0x0474 1 3
147
#define IMXRT_PAD_GPIO_AD_B0_09__ENET_enet_rx_data2 0x00e0 0x02d0 0x0000 2 0
148
#define IMXRT_PAD_GPIO_AD_B0_09__SAI2_sai_tx_data 0x00e0 0x02d0 0x0000 3 0
149
#define IMXRT_PAD_GPIO_AD_B0_09__CSI_csi_data04 0x00e0 0x02d0 0x0408 4 1
150
#define IMXRT_PAD_GPIO_AD_B0_09__GPIO1_gpio_io09 0x00e0 0x02d0 0x0000 5 0
151
#define IMXRT_PAD_GPIO_AD_B0_09__XBARA1_IN21 0x00e0 0x02d0 0x0658 6 1
152
#define IMXRT_PAD_GPIO_AD_B0_09__GPT2_gpt_clk 0x00e0 0x02d0 0x0000 7 0
153
154
/* GPIO_AD_B0_10 */
155
#define IMXRT_PAD_GPIO_AD_B0_10__JTAG_TDO 0x00e4 0x02d4 0x0000 0 0
156
#define IMXRT_PAD_GPIO_AD_B0_10__PWM1_A3 0x00e4 0x02d4 0x0454 1 3
157
#define IMXRT_PAD_GPIO_AD_B0_10__ENET_enet_crs 0x00e4 0x02d4 0x0000 2 0
158
#define IMXRT_PAD_GPIO_AD_B0_10__SAI2_sai_mclk 0x00e4 0x02d4 0x05b0 3 1
159
#define IMXRT_PAD_GPIO_AD_B0_10__CSI_csi_data03 0x00e4 0x02d4 0x0404 4 1
160
#define IMXRT_PAD_GPIO_AD_B0_10__GPIO1_gpio_io10 0x00e4 0x02d4 0x0000 5 0
161
#define IMXRT_PAD_GPIO_AD_B0_10__XBARA1_IN22 0x00e4 0x02d4 0x0638 6 1
162
#define IMXRT_PAD_GPIO_AD_B0_10__ENET_1588_EVENT0_OUT 0x00e4 0x02d4 0x0000 7 0
163
164
/* GPIO_AD_B0_11 */
165
#define IMXRT_PAD_GPIO_AD_B0_11__JTAG_TRSTB 0x00e8 0x02d8 0x0000 0 0
166
#define IMXRT_PAD_GPIO_AD_B0_11__PWM1_B3 0x00e8 0x02d8 0x0464 1 3
167
#define IMXRT_PAD_GPIO_AD_B0_11__ENET_enet_col 0x00e8 0x02d8 0x0000 2 0
168
#define IMXRT_PAD_GPIO_AD_B0_11__WDOG1_wdog_b 0x00e8 0x02d8 0x0000 3 0
169
#define IMXRT_PAD_GPIO_AD_B0_11__CSI_csi_data02 0x00e8 0x02d8 0x0400 4 1
170
#define IMXRT_PAD_GPIO_AD_B0_11__GPIO1_gpio_io11 0x00e8 0x02d8 0x0000 5 0
171
#define IMXRT_PAD_GPIO_AD_B0_11__XBARA1_IN23 0x00e8 0x02d8 0x063c 6 1
172
#define IMXRT_PAD_GPIO_AD_B0_11__ENET_1588_EVENT0_IN 0x00e8 0x02d8 0x0444 7 1
173
174
/* GPIO_AD_B0_12 */
175
#define IMXRT_PAD_GPIO_AD_B0_12__LPI2C4_SCL 0x00ec 0x02dc 0x04e4 0 1
176
#define IMXRT_PAD_GPIO_AD_B0_12__CCM_PMIC_RDY 0x00ec 0x02dc 0x03fc 1 1
177
#define IMXRT_PAD_GPIO_AD_B0_12__LPUART1_TX 0x00ec 0x02dc 0x0000 2 0
178
#define IMXRT_PAD_GPIO_AD_B0_12__WDOG2_wdog_b 0x00ec 0x02dc 0x0000 3 0
179
#define IMXRT_PAD_GPIO_AD_B0_12__PWM1_X2 0x00ec 0x02dc 0x0000 4 0
180
#define IMXRT_PAD_GPIO_AD_B0_12__GPIO1_gpio_io12 0x00ec 0x02dc 0x0000 5 0
181
#define IMXRT_PAD_GPIO_AD_B0_12__ENET_1588_EVENT1_OUT 0x00ec 0x02dc 0x0000 6 0
182
#define IMXRT_PAD_GPIO_AD_B0_12__ARM_arm_nmi 0x00ec 0x02dc 0x0568 7 0
183
#define IMXRT_PAD_GPIO_AD_B0_12__ADC1_IN1 0x00ec 0x02dc 0x0000 5 0
184
185
/* GPIO_AD_B0_13 */
186
#define IMXRT_PAD_GPIO_AD_B0_13__LPI2C4_SDA 0x00f0 0x02e0 0x04e8 0 1
187
#define IMXRT_PAD_GPIO_AD_B0_13__GPT1_gpt_clk 0x00f0 0x02e0 0x0000 1 0
188
#define IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX 0x00f0 0x02e0 0x0000 2 0
189
#define IMXRT_PAD_GPIO_AD_B0_13__EWM_EWM_OUT_B 0x00f0 0x02e0 0x0000 3 0
190
#define IMXRT_PAD_GPIO_AD_B0_13__PWM1_X3 0x00f0 0x02e0 0x0000 4 0
191
#define IMXRT_PAD_GPIO_AD_B0_13__GPIO1_gpio_io13 0x00f0 0x02e0 0x0000 5 0
192
#define IMXRT_PAD_GPIO_AD_B0_13__ENET_1588_EVENT1_IN 0x00f0 0x02e0 0x0000 6 0
193
#define IMXRT_PAD_GPIO_AD_B0_13__XTALOSC24M_REF_CLK_24M 0x00f0 0x02e0 0x0000 7 0
194
#define IMXRT_PAD_GPIO_AD_B0_13__ADC1_IN2 0x00f0 0x02e0 0x0000 5 0
195
#define IMXRT_PAD_GPIO_AD_B0_13__CMP1_IN2 0x00f0 0x02e0 0x0000 5 0
196
197
/* GPIO_AD_B0_14 */
198
#define IMXRT_PAD_GPIO_AD_B0_14__USB2_usb_otg2_oc 0x00f4 0x02e4 0x05cc 0 0
199
#define IMXRT_PAD_GPIO_AD_B0_14__XBARA1_IN24 0x00f4 0x02e4 0x0640 1 1
200
#define IMXRT_PAD_GPIO_AD_B0_14__LPUART1_CTS_B 0x00f4 0x02e4 0x0000 2 0
201
#define IMXRT_PAD_GPIO_AD_B0_14__ENET_1588_EVENT0_OUT 0x00f4 0x02e4 0x0000 3 0
202
#define IMXRT_PAD_GPIO_AD_B0_14__CSI_csi_vsync 0x00f4 0x02e4 0x0428 4 0
203
#define IMXRT_PAD_GPIO_AD_B0_14__GPIO1_gpio_io14 0x00f4 0x02e4 0x0000 5 0
204
#define IMXRT_PAD_GPIO_AD_B0_14__CAN2_TX 0x00f4 0x02e4 0x0000 6 0
205
#define IMXRT_PAD_GPIO_AD_B0_14__ADC1_IN3 0x00f4 0x02e4 0x0000 5 0
206
#define IMXRT_PAD_GPIO_AD_B0_14__CMP2_IN2 0x00f4 0x02e4 0x0000 5 0
207
208
/* GPIO_AD_B0_15 */
209
#define IMXRT_PAD_GPIO_AD_B0_15__USB2_usb_otg2_pwr 0x00f8 0x02e8 0x0000 0 0
210
#define IMXRT_PAD_GPIO_AD_B0_15__XBARA1_IN25 0x00f8 0x02e8 0x0650 1 0
211
#define IMXRT_PAD_GPIO_AD_B0_15__LPUART1_RTS_B 0x00f8 0x02e8 0x0000 2 0
212
#define IMXRT_PAD_GPIO_AD_B0_15__ENET_1588_EVENT0_IN 0x00f8 0x02e8 0x0444 3 0
213
#define IMXRT_PAD_GPIO_AD_B0_15__CSI_csi_hsync 0x00f8 0x02e8 0x0420 4 0
214
#define IMXRT_PAD_GPIO_AD_B0_15__GPIO1_gpio_io15 0x00f8 0x02e8 0x0000 5 0
215
#define IMXRT_PAD_GPIO_AD_B0_15__CAN2_RX 0x00f8 0x02e8 0x0450 6 2
216
#define IMXRT_PAD_GPIO_AD_B0_15__WDOG1_wdog_rst_b_deb 0x00f8 0x02e8 0x0000 7 0
217
#define IMXRT_PAD_GPIO_AD_B0_15__ADC1_IN4 0x00f8 0x02e8 0x0000 5 0
218
#define IMXRT_PAD_GPIO_AD_B0_15__CMP3_IN2 0x00f8 0x02e8 0x0000 5 0
219
220
/* GPIO_AD_B1_00 */
221
#define IMXRT_PAD_GPIO_AD_B1_00__USB2_usb_otg2_id 0x00fc 0x02ec 0x03f8 0 1
222
#define IMXRT_PAD_GPIO_AD_B1_00__TMR3_TIMER0 0x00fc 0x02ec 0x057c 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
223
#define IMXRT_PAD_GPIO_AD_B1_00__LPUART2_CTS_B 0x00fc 0x02ec 0x0000 2 0
224
#define IMXRT_PAD_GPIO_AD_B1_00__LPI2C1_SCL 0x00fc 0x02ec 0x04cc 3 1
225
#define IMXRT_PAD_GPIO_AD_B1_00__WDOG1_wdog_b 0x00fc 0x02ec 0x0000 4 0
226
#define IMXRT_PAD_GPIO_AD_B1_00__GPIO1_gpio_io16 0x00fc 0x02ec 0x0000 5 0
227
#define IMXRT_PAD_GPIO_AD_B1_00__USDHC1_usdhc_wp 0x00fc 0x02ec 0x05d8 6 2
228
#define IMXRT_PAD_GPIO_AD_B1_00__KPP_kpp_row7 0x00fc 0x02ec 0x0000 7 0
229
#define IMXRT_PAD_GPIO_AD_B1_00__ADC1_IN5 0x00fc 0x02ec 0x0000 5 0
230
#define IMXRT_PAD_GPIO_AD_B1_00__ADC2_IN5 0x00fc 0x02ec 0x0000 5 0
231
#define IMXRT_PAD_GPIO_AD_B1_00__CMP4_IN2 0x00fc 0x02ec 0x0000 5 0
232
233
/* GPIO_AD_B1_01 */
234
#define IMXRT_PAD_GPIO_AD_B1_01__USB1_usb_otg1_pwr 0x0100 0x02f0 0x0000 0 0
235
#define IMXRT_PAD_GPIO_AD_B1_01__TMR3_TIMER1 0x0100 0x02f0 0x0580 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
236
#define IMXRT_PAD_GPIO_AD_B1_01__LPUART2_RTS_B 0x0100 0x02f0 0x0000 2 0
237
#define IMXRT_PAD_GPIO_AD_B1_01__LPI2C1_SDA 0x0100 0x02f0 0x04d0 3 1
238
#define IMXRT_PAD_GPIO_AD_B1_01__CCM_PMIC_RDY 0x0100 0x02f0 0x03fc 4 2
239
#define IMXRT_PAD_GPIO_AD_B1_01__GPIO1_gpio_io17 0x0100 0x02f0 0x0000 5 0
240
#define IMXRT_PAD_GPIO_AD_B1_01__USDHC1_usdhc_vselect 0x0100 0x02f0 0x0000 6 0
241
#define IMXRT_PAD_GPIO_AD_B1_01__KPP_kpp_col7 0x0100 0x02f0 0x0000 7 0
242
#define IMXRT_PAD_GPIO_AD_B1_01__ADC1_IN6 0x0100 0x02f0 0x0000 5 0
243
#define IMXRT_PAD_GPIO_AD_B1_01__ADC2_IN6 0x0100 0x02f0 0x0000 5 0
244
#define IMXRT_PAD_GPIO_AD_B1_01__CMP1_IN0 0x0100 0x02f0 0x0000 5 0
245
#define IMXRT_PAD_GPIO_AD_B1_01__CMP2_IN0 0x0100 0x02f0 0x0000 5 0
246
#define IMXRT_PAD_GPIO_AD_B1_01__CMP3_IN0 0x0100 0x02f0 0x0000 5 0
247
#define IMXRT_PAD_GPIO_AD_B1_01__CMP4_IN0 0x0100 0x02f0 0x0000 5 0
248
249
/* GPIO_AD_B1_02 */
250
#define IMXRT_PAD_GPIO_AD_B1_02__USB1_usb_otg1_id 0x0104 0x02f4 0x03f4 0 1
251
#define IMXRT_PAD_GPIO_AD_B1_02__TMR3_TIMER2 0x0104 0x02f4 0x0584 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
252
#define IMXRT_PAD_GPIO_AD_B1_02__LPUART2_TX 0x0104 0x02f4 0x0530 2 1
253
#define IMXRT_PAD_GPIO_AD_B1_02__SPDIF_spdif_out 0x0104 0x02f4 0x0000 3 0
254
#define IMXRT_PAD_GPIO_AD_B1_02__ENET_1588_EVENT2_OUT 0x0104 0x02f4 0x0000 4 0
255
#define IMXRT_PAD_GPIO_AD_B1_02__GPIO1_gpio_io18 0x0104 0x02f4 0x0000 5 0
256
#define IMXRT_PAD_GPIO_AD_B1_02__USDHC1_usdhc_cd_b 0x0104 0x02f4 0x05d4 6 1
257
#define IMXRT_PAD_GPIO_AD_B1_02__KPP_kpp_row6 0x0104 0x02f4 0x0000 7 0
258
#define IMXRT_PAD_GPIO_AD_B1_02__ADC1_IN7 0x0104 0x02f4 0x0000 5 0
259
#define IMXRT_PAD_GPIO_AD_B1_02__ADC2_IN7 0x0104 0x02f4 0x0000 5 0
260
#define IMXRT_PAD_GPIO_AD_B1_02__CMP1_IN3 0x0104 0x02f4 0x0000 5 0
261
262
/* GPIO_AD_B1_03 */
263
#define IMXRT_PAD_GPIO_AD_B1_03__USB1_usb_otg1_oc 0x0108 0x02f8 0x05d0 0 1
264
#define IMXRT_PAD_GPIO_AD_B1_03__TMR3_TIMER3 0x0108 0x02f8 0x0588 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
265
#define IMXRT_PAD_GPIO_AD_B1_03__LPUART2_RX 0x0108 0x02f8 0x052c 2 1
266
#define IMXRT_PAD_GPIO_AD_B1_03__SPDIF_spdif_in 0x0108 0x02f8 0x05c8 3 0
267
#define IMXRT_PAD_GPIO_AD_B1_03__ENET_1588_EVENT2_IN 0x0108 0x02f8 0x0000 4 0
268
#define IMXRT_PAD_GPIO_AD_B1_03__GPIO1_gpio_io19 0x0108 0x02f8 0x0000 5 0
269
#define IMXRT_PAD_GPIO_AD_B1_03__USDHC2_usdhc_cd_b 0x0108 0x02f8 0x05e0 6 0
270
#define IMXRT_PAD_GPIO_AD_B1_03__KPP_kpp_col6 0x0108 0x02f8 0x0000 7 0
271
#define IMXRT_PAD_GPIO_AD_B1_03__ADC1_IN8 0x0108 0x02f8 0x0000 5 0
272
#define IMXRT_PAD_GPIO_AD_B1_03__ADC2_IN8 0x0108 0x02f8 0x0000 5 0
273
#define IMXRT_PAD_GPIO_AD_B1_03__CMP2_IN3 0x0108 0x02f8 0x0000 5 0
274
275
/* GPIO_AD_B1_04 */
276
#define IMXRT_PAD_GPIO_AD_B1_04__FLEXSPI_FLEXSPI_B_DATA3 0x010c 0x02fc 0x04c4 0 1
277
#define IMXRT_PAD_GPIO_AD_B1_04__ENET_enet_mdc 0x010c 0x02fc 0x0000 1 0
278
#define IMXRT_PAD_GPIO_AD_B1_04__LPUART3_CTS_B 0x010c 0x02fc 0x0534 2 1
279
#define IMXRT_PAD_GPIO_AD_B1_04__SPDIF_spdif_sr_clk 0x010c 0x02fc 0x0000 3 0
280
#define IMXRT_PAD_GPIO_AD_B1_04__CSI_csi_pixclk 0x010c 0x02fc 0x0424 4 0
281
#define IMXRT_PAD_GPIO_AD_B1_04__GPIO1_gpio_io20 0x010c 0x02fc 0x0000 5 0
282
#define IMXRT_PAD_GPIO_AD_B1_04__USDHC2_usdhc_data0 0x010c 0x02fc 0x05e8 6 1
283
#define IMXRT_PAD_GPIO_AD_B1_04__KPP_kpp_row5 0x010c 0x02fc 0x0000 7 0
284
#define IMXRT_PAD_GPIO_AD_B1_04__ADC1_IN9 0x010c 0x02fc 0x0000 5 0
285
#define IMXRT_PAD_GPIO_AD_B1_04__ADC2_IN9 0x010c 0x02fc 0x0000 5 0
286
#define IMXRT_PAD_GPIO_AD_B1_04__CMP3_IN3 0x010c 0x02fc 0x0000 5 0
287
288
/* GPIO_AD_B1_05 */
289
#define IMXRT_PAD_GPIO_AD_B1_05__FLEXSPI_FLEXSPI_B_DATA2 0x0110 0x0300 0x04c0 0 1
290
#define IMXRT_PAD_GPIO_AD_B1_05__ENET_enet_mdio 0x0110 0x0300 0x0430 1 0
291
#define IMXRT_PAD_GPIO_AD_B1_05__LPUART3_RTS_B 0x0110 0x0300 0x0000 2 0
292
#define IMXRT_PAD_GPIO_AD_B1_05__SPDIF_spdif_out 0x0110 0x0300 0x0000 3 0
293
#define IMXRT_PAD_GPIO_AD_B1_05__CSI_csi_mclk 0x0110 0x0300 0x0000 4 0
294
#define IMXRT_PAD_GPIO_AD_B1_05__GPIO1_gpio_io21 0x0110 0x0300 0x0000 5 0
295
#define IMXRT_PAD_GPIO_AD_B1_05__USDHC2_usdhc_data1 0x0110 0x0300 0x05ec 6 1
296
#define IMXRT_PAD_GPIO_AD_B1_05__KPP_kpp_col5 0x0110 0x0300 0x0000 7 0
297
#define IMXRT_PAD_GPIO_AD_B1_05__ADC1_IN10 0x0110 0x0300 0x0000 5 0
298
#define IMXRT_PAD_GPIO_AD_B1_05__ADC2_IN10 0x0110 0x0300 0x0000 5 0
299
#define IMXRT_PAD_GPIO_AD_B1_05__CMP4_IN3 0x0110 0x0300 0x0000 5 0
300
301
/* GPIO_AD_B1_06 */
302
#define IMXRT_PAD_GPIO_AD_B1_06__FLEXSPI_FLEXSPI_B_DATA1 0x0114 0x0304 0x04bc 0 1
303
#define IMXRT_PAD_GPIO_AD_B1_06__LPI2C3_SDA 0x0114 0x0304 0x04e0 1 2
304
#define IMXRT_PAD_GPIO_AD_B1_06__LPUART3_TX 0x0114 0x0304 0x053c 2 0
305
#define IMXRT_PAD_GPIO_AD_B1_06__SPDIF_spdif_lock 0x0114 0x0304 0x0000 3 0
306
#define IMXRT_PAD_GPIO_AD_B1_06__CSI_csi_vsync 0x0114 0x0304 0x0428 4 1
307
#define IMXRT_PAD_GPIO_AD_B1_06__GPIO1_gpio_io22 0x0114 0x0304 0x0000 5 0
308
#define IMXRT_PAD_GPIO_AD_B1_06__USDHC2_usdhc_data2 0x0114 0x0304 0x05f0 6 1
309
#define IMXRT_PAD_GPIO_AD_B1_06__KPP_kpp_row4 0x0114 0x0304 0x0000 7 0
310
#define IMXRT_PAD_GPIO_AD_B1_06__ADC1_IN11 0x0114 0x0304 0x0000 5 0
311
#define IMXRT_PAD_GPIO_AD_B1_06__ADC2_IN11 0x0114 0x0304 0x0000 5 0
312
#define IMXRT_PAD_GPIO_AD_B1_06__CMP1_IN1 0x0114 0x0304 0x0000 5 0
313
#define IMXRT_PAD_GPIO_AD_B1_06__CMP2_IN1 0x0114 0x0304 0x0000 5 0
314
#define IMXRT_PAD_GPIO_AD_B1_06__CMP3_IN1 0x0114 0x0304 0x0000 5 0
315
#define IMXRT_PAD_GPIO_AD_B1_06__CMP4_IN1 0x0114 0x0304 0x0000 5 0
316
317
/* GPIO_AD_B1_07 */
318
#define IMXRT_PAD_GPIO_AD_B1_07__FLEXSPI_FLEXSPI_B_DATA0 0x0118 0x0308 0x04b8 0 1
319
#define IMXRT_PAD_GPIO_AD_B1_07__LPI2C3_SCL 0x0118 0x0308 0x04dc 1 2
320
#define IMXRT_PAD_GPIO_AD_B1_07__LPUART3_RX 0x0118 0x0308 0x0538 2 0
321
#define IMXRT_PAD_GPIO_AD_B1_07__SPDIF_spdif_ext_clk 0x0118 0x0308 0x0000 3 0
322
#define IMXRT_PAD_GPIO_AD_B1_07__CSI_csi_hsync 0x0118 0x0308 0x0420 4 1
323
#define IMXRT_PAD_GPIO_AD_B1_07__GPIO1_gpio_io23 0x0118 0x0308 0x0000 5 0
324
#define IMXRT_PAD_GPIO_AD_B1_07__USDHC2_usdhc_data3 0x0118 0x0308 0x05f4 6 1
325
#define IMXRT_PAD_GPIO_AD_B1_07__KPP_kpp_col4 0x0118 0x0308 0x0000 7 0
326
#define IMXRT_PAD_GPIO_AD_B1_07__ADC1_IN12 0x0118 0x0308 0x0000 5 0
327
#define IMXRT_PAD_GPIO_AD_B1_07__ADC2_IN12 0x0118 0x0308 0x0000 5 0
328
#define IMXRT_PAD_GPIO_AD_B1_07__CMP1_IN5 0x0118 0x0308 0x0000 5 0
329
330
/* GPIO_AD_B1_08 */
331
#define IMXRT_PAD_GPIO_AD_B1_08__FLEXSPI_FLEXSPI_A_SS1_B 0x011c 0x030c 0x0000 0 0
332
#define IMXRT_PAD_GPIO_AD_B1_08__PWM4_A0 0x011c 0x030c 0x0494 1 1
333
#define IMXRT_PAD_GPIO_AD_B1_08__CAN1_TX 0x011c 0x030c 0x0000 2 0
334
#define IMXRT_PAD_GPIO_AD_B1_08__CCM_PMIC_RDY 0x011c 0x030c 0x03fc 3 3
335
#define IMXRT_PAD_GPIO_AD_B1_08__CSI_csi_data09 0x011c 0x030c 0x041c 4 0
336
#define IMXRT_PAD_GPIO_AD_B1_08__GPIO1_gpio_io24 0x011c 0x030c 0x0000 5 0
337
#define IMXRT_PAD_GPIO_AD_B1_08__USDHC2_usdhc_cmd 0x011c 0x030c 0x05e4 6 1
338
#define IMXRT_PAD_GPIO_AD_B1_08__KPP_kpp_row3 0x011c 0x030c 0x0000 7 0
339
#define IMXRT_PAD_GPIO_AD_B1_08__ADC1_IN13 0x011c 0x030c 0x0000 5 0
340
#define IMXRT_PAD_GPIO_AD_B1_08__ADC2_IN13 0x011c 0x030c 0x0000 5 0
341
#define IMXRT_PAD_GPIO_AD_B1_08__CMP2_IN5 0x011c 0x030c 0x0000 5 0
342
343
/* GPIO_AD_B1_09 */
344
#define IMXRT_PAD_GPIO_AD_B1_09__FLEXSPI_FLEXSPI_A_DQS 0x0120 0x0310 0x04a4 0 1
345
#define IMXRT_PAD_GPIO_AD_B1_09__PWM4_A1 0x0120 0x0310 0x0498 1 1
346
#define IMXRT_PAD_GPIO_AD_B1_09__CAN1_RX 0x0120 0x0310 0x044c 2 2
347
#define IMXRT_PAD_GPIO_AD_B1_09__SAI1_sai_mclk 0x0120 0x0310 0x058c 3 1
348
#define IMXRT_PAD_GPIO_AD_B1_09__CSI_csi_data08 0x0120 0x0310 0x0418 4 0
349
#define IMXRT_PAD_GPIO_AD_B1_09__GPIO1_gpio_io25 0x0120 0x0310 0x0000 5 0
350
#define IMXRT_PAD_GPIO_AD_B1_09__USDHC2_usdhc_clk 0x0120 0x0310 0x05dc 6 1
351
#define IMXRT_PAD_GPIO_AD_B1_09__KPP_kpp_col3 0x0120 0x0310 0x0000 7 0
352
#define IMXRT_PAD_GPIO_AD_B1_09__ADC1_IN14 0x0120 0x0310 0x0000 5 0
353
#define IMXRT_PAD_GPIO_AD_B1_09__ADC2_IN14 0x0120 0x0310 0x0000 5 0
354
#define IMXRT_PAD_GPIO_AD_B1_09__CMP3_IN5 0x0120 0x0310 0x0000 5 0
355
356
/* GPIO_AD_B1_10 */
357
#define IMXRT_PAD_GPIO_AD_B1_10__FLEXSPI_FLEXSPI_A_DATA3 0x0124 0x0314 0x04b4 0 1
358
#define IMXRT_PAD_GPIO_AD_B1_10__WDOG1_wdog_b 0x0124 0x0314 0x0000 1 0
359
#define IMXRT_PAD_GPIO_AD_B1_10__LPUART8_TX 0x0124 0x0314 0x0564 2 1
360
#define IMXRT_PAD_GPIO_AD_B1_10__SAI1_sai_rx_sync 0x0124 0x0314 0x05a4 3 1
361
#define IMXRT_PAD_GPIO_AD_B1_10__CSI_csi_data07 0x0124 0x0314 0x0414 4 0
362
#define IMXRT_PAD_GPIO_AD_B1_10__GPIO1_gpio_io26 0x0124 0x0314 0x0000 5 0
363
#define IMXRT_PAD_GPIO_AD_B1_10__USDHC2_usdhc_wp 0x0124 0x0314 0x0608 6 1
364
#define IMXRT_PAD_GPIO_AD_B1_10__KPP_kpp_row2 0x0124 0x0314 0x0000 7 0
365
#define IMXRT_PAD_GPIO_AD_B1_10__ADC1_IN15 0x0124 0x0314 0x0000 5 0
366
#define IMXRT_PAD_GPIO_AD_B1_10__ADC2_IN15 0x0124 0x0314 0x0000 5 0
367
#define IMXRT_PAD_GPIO_AD_B1_10__CMP4_IN5 0x0124 0x0314 0x0000 5 0
368
369
/* GPIO_AD_B1_11 */
370
#define IMXRT_PAD_GPIO_AD_B1_11__FLEXSPI_FLEXSPI_A_DATA2 0x0128 0x0318 0x04b0 0 1
371
#define IMXRT_PAD_GPIO_AD_B1_11__EWM_EWM_OUT_B 0x0128 0x0318 0x0000 1 0
372
#define IMXRT_PAD_GPIO_AD_B1_11__LPUART8_RX 0x0128 0x0318 0x0560 2 1
373
#define IMXRT_PAD_GPIO_AD_B1_11__SAI1_sai_rx_bclk 0x0128 0x0318 0x0590 3 1
374
#define IMXRT_PAD_GPIO_AD_B1_11__CSI_csi_data06 0x0128 0x0318 0x0410 4 0
375
#define IMXRT_PAD_GPIO_AD_B1_11__GPIO1_gpio_io27 0x0128 0x0318 0x0000 5 0
376
#define IMXRT_PAD_GPIO_AD_B1_11__USDHC2_usdhc_reset_b 0x0128 0x0318 0x0000 6 0
377
#define IMXRT_PAD_GPIO_AD_B1_11__KPP_kpp_col2 0x0128 0x0318 0x0000 7 0
378
#define IMXRT_PAD_GPIO_AD_B1_11__ADC1_IN0 0x0128 0x0318 0x0000 5 0
379
#define IMXRT_PAD_GPIO_AD_B1_11__ADC2_IN0 0x0128 0x0318 0x0000 5 0
380
#define IMXRT_PAD_GPIO_AD_B1_11__CMP1_IN6 0x0128 0x0318 0x0000 5 0
381
382
/* GPIO_AD_B1_12 */
383
#define IMXRT_PAD_GPIO_AD_B1_12__FLEXSPI_FLEXSPI_A_DATA1 0x012c 0x031c 0x04ac 0 1
384
#define IMXRT_PAD_GPIO_AD_B1_12__CMP1_OUT 0x012c 0x031c 0x0000 1 0
385
#define IMXRT_PAD_GPIO_AD_B1_12__LPSPI3_PCS0 0x012c 0x031c 0x050c 2 1
386
#define IMXRT_PAD_GPIO_AD_B1_12__SAI1_sai_rx_data0 0x012c 0x031c 0x0594 3 1
387
#define IMXRT_PAD_GPIO_AD_B1_12__CSI_csi_data05 0x012c 0x031c 0x040c 4 0
388
#define IMXRT_PAD_GPIO_AD_B1_12__GPIO1_gpio_io28 0x012c 0x031c 0x0000 5 0
389
#define IMXRT_PAD_GPIO_AD_B1_12__USDHC2_usdhc_data4 0x012c 0x031c 0x05f8 6 1
390
#define IMXRT_PAD_GPIO_AD_B1_12__KPP_kpp_row1 0x012c 0x031c 0x0000 7 0
391
#define IMXRT_PAD_GPIO_AD_B1_12__ADC2_IN1 0x012c 0x031c 0x0000 5 0
392
#define IMXRT_PAD_GPIO_AD_B1_12__CMP2_IN6 0x012c 0x031c 0x0000 5 0
393
394
/* GPIO_AD_B1_13 */
395
#define IMXRT_PAD_GPIO_AD_B1_13__FLEXSPI_FLEXSPI_A_DATA0 0x0130 0x0320 0x04a8 0 1
396
#define IMXRT_PAD_GPIO_AD_B1_13__CMP2_OUT 0x0130 0x0320 0x0000 1 0
397
#define IMXRT_PAD_GPIO_AD_B1_13__LPSPI3_SDI 0x0130 0x0320 0x0514 2 1
398
#define IMXRT_PAD_GPIO_AD_B1_13__SAI1_sai_tx_data0 0x0130 0x0320 0x0000 3 0
399
#define IMXRT_PAD_GPIO_AD_B1_13__CSI_csi_data04 0x0130 0x0320 0x0408 4 0
400
#define IMXRT_PAD_GPIO_AD_B1_13__GPIO1_gpio_io29 0x0130 0x0320 0x0000 5 0
401
#define IMXRT_PAD_GPIO_AD_B1_13__USDHC2_usdhc_data5 0x0130 0x0320 0x05fc 6 1
402
#define IMXRT_PAD_GPIO_AD_B1_13__KPP_kpp_col1 0x0130 0x0320 0x0000 7 0
403
#define IMXRT_PAD_GPIO_AD_B1_13__ADC2_IN2 0x0130 0x0320 0x0000 5 0
404
#define IMXRT_PAD_GPIO_AD_B1_13__CMP3_IN6 0x0130 0x0320 0x0000 5 0
405
406
/* GPIO_AD_B1_14 */
407
#define IMXRT_PAD_GPIO_AD_B1_14__FLEXSPI_FLEXSPI_A_SCLK 0x0134 0x0324 0x04c8 0 1
408
#define IMXRT_PAD_GPIO_AD_B1_14__CMP3_OUT 0x0134 0x0324 0x0000 1 0
409
#define IMXRT_PAD_GPIO_AD_B1_14__LPSPI3_SDO 0x0134 0x0324 0x0518 2 1
410
#define IMXRT_PAD_GPIO_AD_B1_14__SAI1_sai_tx_bclk 0x0134 0x0324 0x05a8 3 1
411
#define IMXRT_PAD_GPIO_AD_B1_14__CSI_csi_data03 0x0134 0x0324 0x0404 4 0
412
#define IMXRT_PAD_GPIO_AD_B1_14__GPIO1_gpio_io30 0x0134 0x0324 0x0000 5 0
413
#define IMXRT_PAD_GPIO_AD_B1_14__USDHC2_usdhc_data6 0x0134 0x0324 0x0600 6 1
414
#define IMXRT_PAD_GPIO_AD_B1_14__KPP_kpp_row0 0x0134 0x0324 0x0000 7 0
415
#define IMXRT_PAD_GPIO_AD_B1_14__ADC2_IN3 0x0134 0x0324 0x0000 5 0
416
#define IMXRT_PAD_GPIO_AD_B1_14__CMP4_IN6 0x0134 0x0324 0x0000 5 0
417
418
/* GPIO_AD_B1_15 */
419
#define IMXRT_PAD_GPIO_AD_B1_15__FLEXSPI_FLEXSPI_A_SS0_B 0x0138 0x0328 0x0000 0 0
420
#define IMXRT_PAD_GPIO_AD_B1_15__CMP4_OUT 0x0138 0x0328 0x0000 1 0
421
#define IMXRT_PAD_GPIO_AD_B1_15__LPSPI3_SCK 0x0138 0x0328 0x0000 2 0
422
#define IMXRT_PAD_GPIO_AD_B1_15__SAI1_sai_tx_sync 0x0138 0x0328 0x05ac 3 1
423
#define IMXRT_PAD_GPIO_AD_B1_15__CSI_csi_data02 0x0138 0x0328 0x0400 4 0
424
#define IMXRT_PAD_GPIO_AD_B1_15__GPIO1_gpio_io31 0x0138 0x0328 0x0000 5 0
425
#define IMXRT_PAD_GPIO_AD_B1_15__USDHC2_usdhc_data7 0x0138 0x0328 0x0604 6 1
426
#define IMXRT_PAD_GPIO_AD_B1_15__KPP_kpp_col0 0x0138 0x0328 0x0000 7 0
427
#define IMXRT_PAD_GPIO_AD_B1_15__ADC2_IN4 0x0138 0x0328 0x0000 5 0
428
429
/* GPIO_B0_00 */
430
#define IMXRT_PAD_GPIO_B0_00__LCDIF_lcdif_clk 0x013c 0x032c 0x0000 0 0
431
#define IMXRT_PAD_GPIO_B0_00__TMR1_TIMER0 0x013c 0x032c 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM0_INPUT_SEL to 0 */
432
#define IMXRT_PAD_GPIO_B0_00__MQS_RIGHT 0x013c 0x032c 0x0000 2 0
433
#define IMXRT_PAD_GPIO_B0_00__LPSPI4_PCS0 0x013c 0x032c 0x051c 3 0
434
#define IMXRT_PAD_GPIO_B0_00__FLEXIO2_IO00 0x013c 0x032c 0x0000 4 0
435
#define IMXRT_PAD_GPIO_B0_00__GPIO2_gpio_io00 0x013c 0x032c 0x0000 5 0
436
#define IMXRT_PAD_GPIO_B0_00__SEMC_CSX1 0x013c 0x032c 0x0000 6 0
437
438
/* GPIO_B0_01 */
439
#define IMXRT_PAD_GPIO_B0_01__LCDIF_lcdif_enable 0x0140 0x0330 0x0000 0 0
440
#define IMXRT_PAD_GPIO_B0_01__TMR1_TIMER1 0x0140 0x0330 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM1_INPUT_SEL to 0 */
441
#define IMXRT_PAD_GPIO_B0_01__MQS_LEFT 0x0140 0x0330 0x0000 2 0
442
#define IMXRT_PAD_GPIO_B0_01__LPSPI4_SDI 0x0140 0x0330 0x0524 3 0
443
#define IMXRT_PAD_GPIO_B0_01__FLEXIO2_IO01 0x0140 0x0330 0x0000 4 0
444
#define IMXRT_PAD_GPIO_B0_01__GPIO2_gpio_io01 0x0140 0x0330 0x0000 5 0
445
#define IMXRT_PAD_GPIO_B0_01__SEMC_CSX2 0x0140 0x0330 0x0000 6 0
446
447
/* GPIO_B0_02 */
448
#define IMXRT_PAD_GPIO_B0_02__LCDIF_lcdif_hsync 0x0144 0x0334 0x0000 0 0
449
#define IMXRT_PAD_GPIO_B0_02__TMR1_TIMER2 0x0144 0x0334 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM2_INPUT_SEL to 0 */
450
#define IMXRT_PAD_GPIO_B0_02__CAN1_TX 0x0144 0x0334 0x0000 2 0
451
#define IMXRT_PAD_GPIO_B0_02__LPSPI4_SDO 0x0144 0x0334 0x0528 3 0
452
#define IMXRT_PAD_GPIO_B0_02__FLEXIO2_IO02 0x0144 0x0334 0x0000 4 0
453
#define IMXRT_PAD_GPIO_B0_02__GPIO2_gpio_io02 0x0144 0x0334 0x0000 5 0
454
#define IMXRT_PAD_GPIO_B0_02__SEMC_CSX3 0x0144 0x0334 0x0000 6 0
455
456
/* GPIO_B0_03 */
457
#define IMXRT_PAD_GPIO_B0_03__LCDIF_lcdif_vsync 0x0148 0x0338 0x0000 0 0
458
#define IMXRT_PAD_GPIO_B0_03__TMR2_TIMER0 0x0148 0x0338 0x056c 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */
459
#define IMXRT_PAD_GPIO_B0_03__CAN1_RX 0x0148 0x0338 0x044c 2 3
460
#define IMXRT_PAD_GPIO_B0_03__LPSPI4_SCK 0x0148 0x0338 0x0520 3 0
461
#define IMXRT_PAD_GPIO_B0_03__FLEXIO2_IO03 0x0148 0x0338 0x0000 4 0
462
#define IMXRT_PAD_GPIO_B0_03__GPIO2_gpio_io03 0x0148 0x0338 0x0000 5 0
463
#define IMXRT_PAD_GPIO_B0_03__WDOG2_wdog_rst_b_deb 0x0148 0x0338 0x0000 6 0
464
465
/* GPIO_B0_04 */
466
#define IMXRT_PAD_GPIO_B0_04__LCDIF_lcdif_data00 0x014c 0x033c 0x0000 0 0
467
#define IMXRT_PAD_GPIO_B0_04__TMR2_TIMER1 0x014c 0x033c 0x0570 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */
468
#define IMXRT_PAD_GPIO_B0_04__LPI2C2_SCL 0x014c 0x033c 0x04d4 2 1
469
#define IMXRT_PAD_GPIO_B0_04__ARM_TRACE0 0x014c 0x033c 0x0000 3 0
470
#define IMXRT_PAD_GPIO_B0_04__FLEXIO2_IO04 0x014c 0x033c 0x0000 4 0
471
#define IMXRT_PAD_GPIO_B0_04__GPIO2_gpio_io04 0x014c 0x033c 0x0000 5 0
472
#define IMXRT_PAD_GPIO_B0_04__SRC_BOOT_CFG0 0x014c 0x033c 0x0000 6 0
473
474
/* GPIO_B0_05 */
475
#define IMXRT_PAD_GPIO_B0_05__LCDIF_lcdif_data01 0x0150 0x0340 0x0000 0 0
476
#define IMXRT_PAD_GPIO_B0_05__TMR2_TIMER2 0x0150 0x0340 0x0574 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */
477
#define IMXRT_PAD_GPIO_B0_05__LPI2C2_SDA 0x0150 0x0340 0x04d8 2 1
478
#define IMXRT_PAD_GPIO_B0_05__ARM_TRACE1 0x0150 0x0340 0x0000 3 0
479
#define IMXRT_PAD_GPIO_B0_05__FLEXIO2_IO05 0x0150 0x0340 0x0000 4 0
480
#define IMXRT_PAD_GPIO_B0_05__GPIO2_gpio_io05 0x0150 0x0340 0x0000 5 0
481
#define IMXRT_PAD_GPIO_B0_05__SRC_BOOT_CFG1 0x0150 0x0340 0x0000 6 0
482
483
/* GPIO_B0_06 */
484
#define IMXRT_PAD_GPIO_B0_06__LCDIF_lcdif_data02 0x0154 0x0344 0x0000 0 0
485
#define IMXRT_PAD_GPIO_B0_06__TMR3_TIMER0 0x0154 0x0344 0x057c 1 2
486
#define IMXRT_PAD_GPIO_B0_06__PWM2_A0 0x0154 0x0344 0x0478 2 1
487
#define IMXRT_PAD_GPIO_B0_06__ARM_TRACE2 0x0154 0x0344 0x0000 3 0
488
#define IMXRT_PAD_GPIO_B0_06__FLEXIO2_IO06 0x0154 0x0344 0x0000 4 0
489
#define IMXRT_PAD_GPIO_B0_06__GPIO2_gpio_io06 0x0154 0x0344 0x0000 5 0
490
#define IMXRT_PAD_GPIO_B0_06__SRC_BOOT_CFG2 0x0154 0x0344 0x0000 6 0
491
492
/* GPIO_B0_07 */
493
#define IMXRT_PAD_GPIO_B0_07__LCDIF_lcdif_data03 0x0158 0x0348 0x0000 0 0
494
#define IMXRT_PAD_GPIO_B0_07__TMR3_TIMER1 0x0158 0x0348 0x0580 1 2
495
#define IMXRT_PAD_GPIO_B0_07__PWM2_B0 0x0158 0x0348 0x0488 2 1
496
#define IMXRT_PAD_GPIO_B0_07__ARM_TRACE3 0x0158 0x0348 0x0000 3 0
497
#define IMXRT_PAD_GPIO_B0_07__FLEXIO2_IO07 0x0158 0x0348 0x0000 4 0
498
#define IMXRT_PAD_GPIO_B0_07__GPIO2_gpio_io07 0x0158 0x0348 0x0000 5 0
499
#define IMXRT_PAD_GPIO_B0_07__SRC_BOOT_CFG3 0x0158 0x0348 0x0000 6 0
500
501
/* GPIO_B0_08 */
502
#define IMXRT_PAD_GPIO_B0_08__LCDIF_lcdif_data04 0x015c 0x034c 0x0000 0 0
503
#define IMXRT_PAD_GPIO_B0_08__TMR3_TIMER2 0x015c 0x034c 0x0584 1 2
504
#define IMXRT_PAD_GPIO_B0_08__PWM2_A1 0x015c 0x034c 0x047c 2 1
505
#define IMXRT_PAD_GPIO_B0_08__LPUART3_TX 0x015c 0x034c 0x053c 3 2
506
#define IMXRT_PAD_GPIO_B0_08__FLEXIO2_IO08 0x015c 0x034c 0x0000 4 0
507
#define IMXRT_PAD_GPIO_B0_08__GPIO2_gpio_io08 0x015c 0x034c 0x0000 5 0
508
#define IMXRT_PAD_GPIO_B0_08__SRC_BOOT_CFG4 0x015c 0x034c 0x0000 6 0
509
510
/* GPIO_B0_09 */
511
#define IMXRT_PAD_GPIO_B0_09__LCDIF_lcdif_data05 0x0160 0x0350 0x0000 0 0
512
#define IMXRT_PAD_GPIO_B0_09__TMR4_TIMER0 0x0160 0x0350 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM0_INPUT_SEL to 0 */
513
#define IMXRT_PAD_GPIO_B0_09__PWM2_B1 0x0160 0x0350 0x048c 2 1
514
#define IMXRT_PAD_GPIO_B0_09__LPUART3_RX 0x0160 0x0350 0x0538 3 2
515
#define IMXRT_PAD_GPIO_B0_09__FLEXIO2_IO09 0x0160 0x0350 0x0000 4 0
516
#define IMXRT_PAD_GPIO_B0_09__GPIO2_gpio_io09 0x0160 0x0350 0x0000 5 0
517
#define IMXRT_PAD_GPIO_B0_09__SRC_BOOT_CFG5 0x0160 0x0350 0x0000 6 0
518
519
/* GPIO_B0_10 */
520
#define IMXRT_PAD_GPIO_B0_10__LCDIF_lcdif_data06 0x0164 0x0354 0x0000 0 0
521
#define IMXRT_PAD_GPIO_B0_10__TMR4_TIMER1 0x0164 0x0354 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM1_INPUT_SEL to 0 */
522
#define IMXRT_PAD_GPIO_B0_10__PWM2_A2 0x0164 0x0354 0x0480 2 1
523
#define IMXRT_PAD_GPIO_B0_10__SAI1_sai_tx_data3 0x0164 0x0354 0x0598 3 1
524
#define IMXRT_PAD_GPIO_B0_10__FLEXIO2_IO10 0x0164 0x0354 0x0000 4 0
525
#define IMXRT_PAD_GPIO_B0_10__GPIO2_gpio_io10 0x0164 0x0354 0x0000 5 0
526
#define IMXRT_PAD_GPIO_B0_10__SRC_BOOT_CFG6 0x0164 0x0354 0x0000 6 0
527
528
/* GPIO_B0_11 */
529
#define IMXRT_PAD_GPIO_B0_11__LCDIF_lcdif_data07 0x0168 0x0358 0x0000 0 0
530
#define IMXRT_PAD_GPIO_B0_11__TMR4_TIMER2 0x0168 0x0358 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM2_INPUT_SEL to 0 */
531
#define IMXRT_PAD_GPIO_B0_11__PWM2_B2 0x0168 0x0358 0x0490 2 1
532
#define IMXRT_PAD_GPIO_B0_11__SAI1_sai_tx_data2 0x0168 0x0358 0x059c 3 1
533
#define IMXRT_PAD_GPIO_B0_11__FLEXIO2_IO11 0x0168 0x0358 0x0000 4 0
534
#define IMXRT_PAD_GPIO_B0_11__GPIO2_gpio_io11 0x0168 0x0358 0x0000 5 0
535
#define IMXRT_PAD_GPIO_B0_11__SRC_BOOT_CFG7 0x0168 0x0358 0x0000 6 0
536
537
/* GPIO_B0_12 */
538
#define IMXRT_PAD_GPIO_B0_12__LCDIF_lcdif_data08 0x016c 0x035c 0x0000 0 0
539
#define IMXRT_PAD_GPIO_B0_12__XBARA1_OUT10 0x016c 0x035c 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0x1 */
540
#define IMXRT_PAD_GPIO_B0_12__XBARA1_IN10 0x016c 0x035c 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0 */
541
#define IMXRT_PAD_GPIO_B0_12__ARM_arm_trace_clk 0x016c 0x035c 0x0000 2 0
542
#define IMXRT_PAD_GPIO_B0_12__SAI1_sai_tx_data1 0x016c 0x035c 0x05a0 3 1
543
#define IMXRT_PAD_GPIO_B0_12__FLEXIO2_IO12 0x016c 0x035c 0x0000 4 0
544
#define IMXRT_PAD_GPIO_B0_12__GPIO2_gpio_io12 0x016c 0x035c 0x0000 5 0
545
#define IMXRT_PAD_GPIO_B0_12__SRC_BOOT_CFG8 0x016c 0x035c 0x0000 6 0
546
547
/* GPIO_B0_13 */
548
#define IMXRT_PAD_GPIO_B0_13__LCDIF_lcdif_data09 0x0170 0x0360 0x0000 0 0
549
#define IMXRT_PAD_GPIO_B0_13__XBARA1_OUT11 0x0170 0x0360 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0x1 */
550
#define IMXRT_PAD_GPIO_B0_13__XBARA1_IN11 0x0170 0x0360 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0 */
551
#define IMXRT_PAD_GPIO_B0_13__ARM_arm_trace_swo 0x0170 0x0360 0x0000 2 0
552
#define IMXRT_PAD_GPIO_B0_13__SAI1_sai_mclk 0x0170 0x0360 0x058c 3 2
553
#define IMXRT_PAD_GPIO_B0_13__FLEXIO2_IO13 0x0170 0x0360 0x0000 4 0
554
#define IMXRT_PAD_GPIO_B0_13__GPIO2_gpio_io13 0x0170 0x0360 0x0000 5 0
555
#define IMXRT_PAD_GPIO_B0_13__SRC_BOOT_CFG9 0x0170 0x0360 0x0000 6 0
556
557
/* GPIO_B0_14 */
558
#define IMXRT_PAD_GPIO_B0_14__LCDIF_lcdif_data10 0x0174 0x0364 0x0000 0 0
559
#define IMXRT_PAD_GPIO_B0_14__XBARA1_OUT12 0x0174 0x0364 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0x1 */
560
#define IMXRT_PAD_GPIO_B0_14__XBARA1_IN12 0x0174 0x0364 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0 */
561
#define IMXRT_PAD_GPIO_B0_14__ARM_arm_cm7_txev 0x0174 0x0364 0x0000 2 0
562
#define IMXRT_PAD_GPIO_B0_14__SAI1_sai_rx_sync 0x0174 0x0364 0x05a4 3 2
563
#define IMXRT_PAD_GPIO_B0_14__FLEXIO2_IO14 0x0174 0x0364 0x0000 4 0
564
#define IMXRT_PAD_GPIO_B0_14__GPIO2_gpio_io14 0x0174 0x0364 0x0000 5 0
565
#define IMXRT_PAD_GPIO_B0_14__SRC_BOOT_CFG10 0x0174 0x0364 0x0000 6 0
566
567
/* GPIO_B0_15 */
568
#define IMXRT_PAD_GPIO_B0_15__LCDIF_lcdif_data11 0x0178 0x0368 0x0000 0 0
569
#define IMXRT_PAD_GPIO_B0_15__XBARA1_OUT13 0x0178 0x0368 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0x1 */
570
#define IMXRT_PAD_GPIO_B0_15__XBARA1_IN13 0x0178 0x0368 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0 */
571
#define IMXRT_PAD_GPIO_B0_15__ARM_arm_cm7_rxev 0x0178 0x0368 0x0000 2 0
572
#define IMXRT_PAD_GPIO_B0_15__SAI1_sai_rx_bclk 0x0178 0x0368 0x0590 3 2
573
#define IMXRT_PAD_GPIO_B0_15__FLEXIO2_IO15 0x0178 0x0368 0x0000 4 0
574
#define IMXRT_PAD_GPIO_B0_15__GPIO2_gpio_io15 0x0178 0x0368 0x0000 5 0
575
#define IMXRT_PAD_GPIO_B0_15__SRC_BOOT_CFG11 0x0178 0x0368 0x0000 6 0
576
577
/* GPIO_B1_00 */
578
#define IMXRT_PAD_GPIO_B1_00__LCDIF_lcdif_data12 0x017c 0x036c 0x0000 0 0
579
#define IMXRT_PAD_GPIO_B1_00__XBARA1_OUT14 0x017c 0x036c 0x0644 1 1
580
#define IMXRT_PAD_GPIO_B1_00__XBARA1_IN14 0x017c 0x036c 0x0644 1 1
581
#define IMXRT_PAD_GPIO_B1_00__LPUART4_TX 0x017c 0x036c 0x0544 2 2
582
#define IMXRT_PAD_GPIO_B1_00__SAI1_sai_rx_data0 0x017c 0x036c 0x0594 3 2
583
#define IMXRT_PAD_GPIO_B1_00__FLEXIO2_IO16 0x017c 0x036c 0x0000 4 0
584
#define IMXRT_PAD_GPIO_B1_00__GPIO2_gpio_io16 0x017c 0x036c 0x0000 5 0
585
#define IMXRT_PAD_GPIO_B1_00__PWM1_A3 0x017c 0x036c 0x0454 6 4
586
587
/* GPIO_B1_01 */
588
#define IMXRT_PAD_GPIO_B1_01__LCDIF_lcdif_data13 0x0180 0x0370 0x0000 0 0
589
#define IMXRT_PAD_GPIO_B1_01__XBARA1_OUT15 0x0180 0x0370 0x0648 1 1
590
#define IMXRT_PAD_GPIO_B1_01__XBARA1_IN15 0x0180 0x0370 0x0648 1 1
591
#define IMXRT_PAD_GPIO_B1_01__LPUART4_RX 0x0180 0x0370 0x0540 2 2
592
#define IMXRT_PAD_GPIO_B1_01__SAI1_sai_tx_data0 0x0180 0x0370 0x0000 3 0
593
#define IMXRT_PAD_GPIO_B1_01__FLEXIO2_IO17 0x0180 0x0370 0x0000 4 0
594
#define IMXRT_PAD_GPIO_B1_01__GPIO2_gpio_io17 0x0180 0x0370 0x0000 5 0
595
#define IMXRT_PAD_GPIO_B1_01__PWM1_B3 0x0180 0x0370 0x0464 6 4
596
597
/* GPIO_B1_02 */
598
#define IMXRT_PAD_GPIO_B1_02__LCDIF_lcdif_data14 0x0184 0x0374 0x0000 0 0
599
#define IMXRT_PAD_GPIO_B1_02__XBARA1_OUT16 0x0184 0x0374 0x064c 1 1
600
#define IMXRT_PAD_GPIO_B1_02__XBARA1_IN16 0x0184 0x0374 0x064c 1 1
601
#define IMXRT_PAD_GPIO_B1_02__LPSPI4_PCS2 0x0184 0x0374 0x0000 2 0
602
#define IMXRT_PAD_GPIO_B1_02__SAI1_sai_tx_bclk 0x0184 0x0374 0x05a8 3 2
603
#define IMXRT_PAD_GPIO_B1_02__FLEXIO2_IO18 0x0184 0x0374 0x0000 4 0
604
#define IMXRT_PAD_GPIO_B1_02__GPIO2_gpio_io18 0x0184 0x0374 0x0000 5 0
605
#define IMXRT_PAD_GPIO_B1_02__PWM2_A3 0x0184 0x0374 0x0474 6 4
606
607
/* GPIO_B1_03 */
608
#define IMXRT_PAD_GPIO_B1_03__LCDIF_lcdif_data15 0x0188 0x0378 0x0000 0 0
609
#define IMXRT_PAD_GPIO_B1_03__XBARA1_OUT17 0x0188 0x0378 0x062c 1 3
610
#define IMXRT_PAD_GPIO_B1_03__XBARA1_IN17 0x0188 0x0378 0x062c 1 3
611
#define IMXRT_PAD_GPIO_B1_03__LPSPI4_PCS1 0x0188 0x0378 0x0000 2 0
612
#define IMXRT_PAD_GPIO_B1_03__SAI1_sai_tx_sync 0x0188 0x0378 0x05ac 3 2
613
#define IMXRT_PAD_GPIO_B1_03__FLEXIO2_IO19 0x0188 0x0378 0x0000 4 0
614
#define IMXRT_PAD_GPIO_B1_03__GPIO2_gpio_io19 0x0188 0x0378 0x0000 5 0
615
#define IMXRT_PAD_GPIO_B1_03__PWM2_B3 0x0188 0x0378 0x0484 6 3
616
617
/* GPIO_B1_04 */
618
#define IMXRT_PAD_GPIO_B1_04__LCDIF_lcdif_data16 0x018c 0x037c 0x0000 0 0
619
#define IMXRT_PAD_GPIO_B1_04__LPSPI4_PCS0 0x018c 0x037c 0x051c 1 1
620
#define IMXRT_PAD_GPIO_B1_04__CSI_csi_data15 0x018c 0x037c 0x0000 2 0
621
#define IMXRT_PAD_GPIO_B1_04__ENET_enet_rx_data0 0x018c 0x037c 0x0434 3 1
622
#define IMXRT_PAD_GPIO_B1_04__FLEXIO2_IO20 0x018c 0x037c 0x0000 4 0
623
#define IMXRT_PAD_GPIO_B1_04__GPIO2_gpio_io20 0x018c 0x037c 0x0000 5 0
624
625
/* GPIO_B1_05 */
626
#define IMXRT_PAD_GPIO_B1_05__LCDIF_lcdif_data17 0x0190 0x0380 0x0000 0 0
627
#define IMXRT_PAD_GPIO_B1_05__LPSPI4_SDI 0x0190 0x0380 0x0524 1 1
628
#define IMXRT_PAD_GPIO_B1_05__CSI_csi_data14 0x0190 0x0380 0x0000 2 0
629
#define IMXRT_PAD_GPIO_B1_05__ENET_enet_rx_data1 0x0190 0x0380 0x0438 3 1
630
#define IMXRT_PAD_GPIO_B1_05__FLEXIO2_IO21 0x0190 0x0380 0x0000 4 0
631
#define IMXRT_PAD_GPIO_B1_05__GPIO2_gpio_io21 0x0190 0x0380 0x0000 5 0
632
633
/* GPIO_B1_06 */
634
#define IMXRT_PAD_GPIO_B1_06__LCDIF_lcdif_data18 0x0194 0x0384 0x0000 0 0
635
#define IMXRT_PAD_GPIO_B1_06__LPSPI4_SDO 0x0194 0x0384 0x0528 1 1
636
#define IMXRT_PAD_GPIO_B1_06__CSI_csi_data13 0x0194 0x0384 0x0000 2 0
637
#define IMXRT_PAD_GPIO_B1_06__ENET_enet_rx_en 0x0194 0x0384 0x043c 3 1
638
#define IMXRT_PAD_GPIO_B1_06__FLEXIO2_IO22 0x0194 0x0384 0x0000 4 0
639
#define IMXRT_PAD_GPIO_B1_06__GPIO2_gpio_io22 0x0194 0x0384 0x0000 5 0
640
641
/* GPIO_B1_07 */
642
#define IMXRT_PAD_GPIO_B1_07__LCDIF_lcdif_data19 0x0198 0x0388 0x0000 0 0
643
#define IMXRT_PAD_GPIO_B1_07__LPSPI4_SCK 0x0198 0x0388 0x0520 1 1
644
#define IMXRT_PAD_GPIO_B1_07__CSI_csi_data12 0x0198 0x0388 0x0000 2 0
645
#define IMXRT_PAD_GPIO_B1_07__ENET_enet_tx_data0 0x0198 0x0388 0x0000 3 0
646
#define IMXRT_PAD_GPIO_B1_07__FLEXIO2_IO23 0x0198 0x0388 0x0000 4 0
647
#define IMXRT_PAD_GPIO_B1_07__GPIO2_gpio_io23 0x0198 0x0388 0x0000 5 0
648
649
/* GPIO_B1_08 */
650
#define IMXRT_PAD_GPIO_B1_08__LCDIF_lcdif_data20 0x019c 0x038c 0x0000 0 0
651
#define IMXRT_PAD_GPIO_B1_08__TMR1_TIMER3 0x019c 0x038c 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM3_INPUT_SEL to 0 */
652
#define IMXRT_PAD_GPIO_B1_08__CSI_csi_data11 0x019c 0x038c 0x0000 2 0
653
#define IMXRT_PAD_GPIO_B1_08__ENET_enet_tx_data1 0x019c 0x038c 0x0000 3 0
654
#define IMXRT_PAD_GPIO_B1_08__FLEXIO2_IO24 0x019c 0x038c 0x0000 4 0
655
#define IMXRT_PAD_GPIO_B1_08__GPIO2_gpio_io24 0x019c 0x038c 0x0000 5 0
656
#define IMXRT_PAD_GPIO_B1_08__CAN2_TX 0x019c 0x038c 0x0000 6 0
657
658
/* GPIO_B1_09 */
659
#define IMXRT_PAD_GPIO_B1_09__LCDIF_lcdif_data21 0x01a0 0x0390 0x0000 0 0
660
#define IMXRT_PAD_GPIO_B1_09__TMR2_TIMER3 0x01a0 0x0390 0x0578 1 1
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */
661
#define IMXRT_PAD_GPIO_B1_09__CSI_csi_data10 0x01a0 0x0390 0x0000 2 0
662
#define IMXRT_PAD_GPIO_B1_09__ENET_enet_tx_en 0x01a0 0x0390 0x0000 3 0
663
#define IMXRT_PAD_GPIO_B1_09__FLEXIO2_IO25 0x01a0 0x0390 0x0000 4 0
664
#define IMXRT_PAD_GPIO_B1_09__GPIO2_gpio_io25 0x01a0 0x0390 0x0000 5 0
665
#define IMXRT_PAD_GPIO_B1_09__CAN2_RX 0x01a0 0x0390 0x0450 6 3
666
667
/* GPIO_B1_10 */
668
#define IMXRT_PAD_GPIO_B1_10__LCDIF_lcdif_data22 0x01a4 0x0394 0x0000 0 0
669
#define IMXRT_PAD_GPIO_B1_10__TMR3_TIMER3 0x01a4 0x0394 0x0588 1 2
670
#define IMXRT_PAD_GPIO_B1_10__CSI_csi_data00 0x01a4 0x0394 0x0000 2 0
671
#define IMXRT_PAD_GPIO_B1_10__ENET_enet_tx_clk 0x01a4 0x0394 0x0448 3 1
672
#define IMXRT_PAD_GPIO_B1_10__FLEXIO2_IO26 0x01a4 0x0394 0x0000 4 0
673
#define IMXRT_PAD_GPIO_B1_10__GPIO2_gpio_io26 0x01a4 0x0394 0x0000 5 0
674
#define IMXRT_PAD_GPIO_B1_10__ENET_enet_ref_clk 0x01a4 0x0394 0x042c 6 1
675
676
/* GPIO_B1_11 */
677
#define IMXRT_PAD_GPIO_B1_11__LCDIF_lcdif_data23 0x01a8 0x0398 0x0000 0 0
678
#define IMXRT_PAD_GPIO_B1_11__TMR4_TIMER3 0x01a8 0x0398 0x0000 1 0
/* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM3_INPUT_SEL to 0 */
679
#define IMXRT_PAD_GPIO_B1_11__CSI_csi_data01 0x01a8 0x0398 0x0000 2 0
680
#define IMXRT_PAD_GPIO_B1_11__ENET_enet_rx_er 0x01a8 0x0398 0x0440 3 1
681
#define IMXRT_PAD_GPIO_B1_11__FLEXIO2_IO27 0x01a8 0x0398 0x0000 4 0
682
#define IMXRT_PAD_GPIO_B1_11__GPIO2_gpio_io27 0x01a8 0x0398 0x0000 5 0
683
#define IMXRT_PAD_GPIO_B1_11__LPSPI4_PCS3 0x01a8 0x0398 0x0000 6 0
684
685
/* GPIO_B1_12 */
686
#define IMXRT_PAD_GPIO_B1_12__LPUART5_TX 0x01ac 0x039c 0x054c 1 1
687
#define IMXRT_PAD_GPIO_B1_12__CSI_csi_pixclk 0x01ac 0x039c 0x0424 2 1
688
#define IMXRT_PAD_GPIO_B1_12__ENET_1588_EVENT0_IN 0x01ac 0x039c 0x0444 3 2
689
#define IMXRT_PAD_GPIO_B1_12__FLEXIO2_IO28 0x01ac 0x039c 0x0000 4 0
690
#define IMXRT_PAD_GPIO_B1_12__GPIO2_gpio_io28 0x01ac 0x039c 0x0000 5 0
691
#define IMXRT_PAD_GPIO_B1_12__USDHC1_usdhc_cd_b 0x01ac 0x039c 0x05d4 6 2
692
693
/* GPIO_B1_13 */
694
#define IMXRT_PAD_GPIO_B1_13__WDOG1_wdog_b 0x01b0 0x03a0 0x0000 0 0
695
#define IMXRT_PAD_GPIO_B1_13__LPUART5_RX 0x01b0 0x03a0 0x0548 1 1
696
#define IMXRT_PAD_GPIO_B1_13__CSI_csi_vsync 0x01b0 0x03a0 0x0428 2 2
697
#define IMXRT_PAD_GPIO_B1_13__ENET_1588_EVENT0_OUT 0x01b0 0x03a0 0x0000 3 0
698
#define IMXRT_PAD_GPIO_B1_13__FLEXIO2_IO29 0x01b0 0x03a0 0x0000 4 0
699
#define IMXRT_PAD_GPIO_B1_13__GPIO2_gpio_io29 0x01b0 0x03a0 0x0000 5 0
700
#define IMXRT_PAD_GPIO_B1_13__USDHC1_usdhc_wp 0x01b0 0x03a0 0x05d8 6 3
701
702
/* GPIO_B1_14 */
703
#define IMXRT_PAD_GPIO_B1_14__ENET_enet_mdc 0x01b4 0x03a4 0x0000 0 0
704
#define IMXRT_PAD_GPIO_B1_14__PWM4_A2 0x01b4 0x03a4 0x049c 1 1
705
#define IMXRT_PAD_GPIO_B1_14__CSI_csi_hsync 0x01b4 0x03a4 0x0420 2 2
706
#define IMXRT_PAD_GPIO_B1_14__XBARA1_IN02 0x01b4 0x03a4 0x060c 3 1
707
#define IMXRT_PAD_GPIO_B1_14__FLEXIO2_IO30 0x01b4 0x03a4 0x0000 4 0
708
#define IMXRT_PAD_GPIO_B1_14__GPIO2_gpio_io30 0x01b4 0x03a4 0x0000 5 0
709
#define IMXRT_PAD_GPIO_B1_14__USDHC1_usdhc_vselect 0x01b4 0x03a4 0x0000 6 0
710
711
/* GPIO_B1_15 */
712
#define IMXRT_PAD_GPIO_B1_15__ENET_enet_mdio 0x01b8 0x03a8 0x0430 0 2
713
#define IMXRT_PAD_GPIO_B1_15__PWM4_A3 0x01b8 0x03a8 0x04a0 1 1
714
#define IMXRT_PAD_GPIO_B1_15__CSI_csi_mclk 0x01b8 0x03a8 0x0000 2 0
715
#define IMXRT_PAD_GPIO_B1_15__XBARA1_IN03 0x01b8 0x03a8 0x0610 3 1
716
#define IMXRT_PAD_GPIO_B1_15__FLEXIO2_IO31 0x01b8 0x03a8 0x0000 4 0
717
#define IMXRT_PAD_GPIO_B1_15__GPIO2_gpio_io31 0x01b8 0x03a8 0x0000 5 0
718
#define IMXRT_PAD_GPIO_B1_15__USDHC1_usdhc_reset_b 0x01b8 0x03a8 0x0000 6 0
719
720
/* GPIO_EMC_00 */
721
#define IMXRT_PAD_GPIO_EMC_00__SEMC_DATA00 0x0014 0x0204 0x0000 0 0
722
#define IMXRT_PAD_GPIO_EMC_00__PWM4_A0 0x0014 0x0204 0x0494 1 0
723
#define IMXRT_PAD_GPIO_EMC_00__LPSPI2_SCK 0x0014 0x0204 0x0500 2 1
724
#define IMXRT_PAD_GPIO_EMC_00__XBARA1_IN02 0x0014 0x0204 0x060c 3 0
725
#define IMXRT_PAD_GPIO_EMC_00__FLEXIO1_IO00 0x0014 0x0204 0x0000 4 0
726
#define IMXRT_PAD_GPIO_EMC_00__GPIO4_gpio_io00 0x0014 0x0204 0x0000 5 0
727
728
/* GPIO_EMC_01 */
729
#define IMXRT_PAD_GPIO_EMC_01__SEMC_DATA01 0x0018 0x0208 0x0000 0 0
730
#define IMXRT_PAD_GPIO_EMC_01__PWM4_B0 0x0018 0x0208 0x0000 1 0
731
#define IMXRT_PAD_GPIO_EMC_01__LPSPI2_PCS0 0x0018 0x0208 0x04fc 2 1
732
#define IMXRT_PAD_GPIO_EMC_01__XBARA1_IN03 0x0018 0x0208 0x0610 3 0
733
#define IMXRT_PAD_GPIO_EMC_01__FLEXIO1_IO01 0x0018 0x0208 0x0000 4 0
734
#define IMXRT_PAD_GPIO_EMC_01__GPIO4_gpio_io01 0x0018 0x0208 0x0000 5 0
735
736
/* GPIO_EMC_02 */
737
#define IMXRT_PAD_GPIO_EMC_02__SEMC_DATA02 0x001c 0x020c 0x0000 0 0
738
#define IMXRT_PAD_GPIO_EMC_02__PWM4_A1 0x001c 0x020c 0x0498 1 0
739
#define IMXRT_PAD_GPIO_EMC_02__LPSPI2_SDO 0x001c 0x020c 0x0508 2 1
740
#define IMXRT_PAD_GPIO_EMC_02__XBARA1_OUT04 0x001c 0x020c 0x0614 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */
741
#define IMXRT_PAD_GPIO_EMC_02__XBARA1_IN04 0x001c 0x020c 0x0614 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */
742
#define IMXRT_PAD_GPIO_EMC_02__FLEXIO1_IO02 0x001c 0x020c 0x0000 4 0
743
#define IMXRT_PAD_GPIO_EMC_02__GPIO4_gpio_io02 0x001c 0x020c 0x0000 5 0
744
745
/* GPIO_EMC_03 */
746
#define IMXRT_PAD_GPIO_EMC_03__SEMC_DATA03 0x0020 0x0210 0x0000 0 0
747
#define IMXRT_PAD_GPIO_EMC_03__PWM4_B1 0x0020 0x0210 0x0000 1 0
748
#define IMXRT_PAD_GPIO_EMC_03__LPSPI2_SDI 0x0020 0x0210 0x0504 2 1
749
#define IMXRT_PAD_GPIO_EMC_03__XBARA1_OUT05 0x0020 0x0210 0x0618 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */
750
#define IMXRT_PAD_GPIO_EMC_03__XBARA1_IN05 0x0020 0x0210 0x0618 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */
751
#define IMXRT_PAD_GPIO_EMC_03__FLEXIO1_IO03 0x0020 0x0210 0x0000 4 0
752
#define IMXRT_PAD_GPIO_EMC_03__GPIO4_gpio_io03 0x0020 0x0210 0x0000 5 0
753
754
/* GPIO_EMC_04 */
755
#define IMXRT_PAD_GPIO_EMC_04__SEMC_DATA04 0x0024 0x0214 0x0000 0 0
756
#define IMXRT_PAD_GPIO_EMC_04__PWM4_A2 0x0024 0x0214 0x049c 1 0
757
#define IMXRT_PAD_GPIO_EMC_04__SAI2_sai_tx_data 0x0024 0x0214 0x0000 2 0
758
#define IMXRT_PAD_GPIO_EMC_04__XBARA1_OUT06 0x0024 0x0214 0x061c 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */
759
#define IMXRT_PAD_GPIO_EMC_04__XBARA1_IN06 0x0024 0x0214 0x061c 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */
760
#define IMXRT_PAD_GPIO_EMC_04__FLEXIO1_IO04 0x0024 0x0214 0x0000 4 0
761
#define IMXRT_PAD_GPIO_EMC_04__GPIO4_gpio_io04 0x0024 0x0214 0x0000 5 0
762
763
/* GPIO_EMC_05 */
764
#define IMXRT_PAD_GPIO_EMC_05__SEMC_DATA05 0x0028 0x0218 0x0000 0 0
765
#define IMXRT_PAD_GPIO_EMC_05__PWM4_B2 0x0028 0x0218 0x0000 1 0
766
#define IMXRT_PAD_GPIO_EMC_05__SAI2_sai_tx_sync 0x0028 0x0218 0x05c4 2 0
767
#define IMXRT_PAD_GPIO_EMC_05__XBARA1_OUT07 0x0028 0x0218 0x0620 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */
768
#define IMXRT_PAD_GPIO_EMC_05__XBARA1_IN07 0x0028 0x0218 0x0620 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */
769
#define IMXRT_PAD_GPIO_EMC_05__FLEXIO1_IO05 0x0028 0x0218 0x0000 4 0
770
#define IMXRT_PAD_GPIO_EMC_05__GPIO4_gpio_io05 0x0028 0x0218 0x0000 5 0
771
772
/* GPIO_EMC_06 */
773
#define IMXRT_PAD_GPIO_EMC_06__SEMC_DATA06 0x002c 0x021c 0x0000 0 0
774
#define IMXRT_PAD_GPIO_EMC_06__PWM2_A0 0x002c 0x021c 0x0478 1 0
775
#define IMXRT_PAD_GPIO_EMC_06__SAI2_sai_tx_bclk 0x002c 0x021c 0x05c0 2 0
776
#define IMXRT_PAD_GPIO_EMC_06__XBARA1_OUT08 0x002c 0x021c 0x0624 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */
777
#define IMXRT_PAD_GPIO_EMC_06__XBARA1_IN08 0x002c 0x021c 0x0624 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */
778
#define IMXRT_PAD_GPIO_EMC_06__FLEXIO1_IO06 0x002c 0x021c 0x0000 4 0
779
#define IMXRT_PAD_GPIO_EMC_06__GPIO4_gpio_io06 0x002c 0x021c 0x0000 5 0
780
781
/* GPIO_EMC_07 */
782
#define IMXRT_PAD_GPIO_EMC_07__SEMC_DATA07 0x0030 0x0220 0x0000 0 0
783
#define IMXRT_PAD_GPIO_EMC_07__PWM2_B0 0x0030 0x0220 0x0488 1 0
784
#define IMXRT_PAD_GPIO_EMC_07__SAI2_sai_mclk 0x0030 0x0220 0x05b0 2 0
785
#define IMXRT_PAD_GPIO_EMC_07__XBARA1_OUT09 0x0030 0x0220 0x0628 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */
786
#define IMXRT_PAD_GPIO_EMC_07__XBARA1_IN09 0x0030 0x0220 0x0628 3 0
/* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */
787
#define IMXRT_PAD_GPIO_EMC_07__FLEXIO1_IO07 0x0030 0x0220 0x0000 4 0
788
#define IMXRT_PAD_GPIO_EMC_07__GPIO4_gpio_io07 0x0030 0x0220 0x0000 5 0
789
790
/* GPIO_EMC_08 */
791
#define IMXRT_PAD_GPIO_EMC_08__SEMC_DM0 0x0034 0x0224 0x0000 0 0
792
#define IMXRT_PAD_GPIO_EMC_08__PWM2_A1 0x0034 0x0224 0x047c 1 0
793
#define IMXRT_PAD_GPIO_EMC_08__SAI2_sai_rx_data 0x0034 0x0224 0x05b8 2 0
794
#define IMXRT_PAD_GPIO_EMC_08__XBARA1_OUT17 0x0034 0x0224 0x062c 3 0
795
#define IMXRT_PAD_GPIO_EMC_08__XBARA1_IN17 0x0034 0x0224 0x062c 3 0
796
#define IMXRT_PAD_GPIO_EMC_08__FLEXIO1_IO08 0x0034 0x0224 0x0000 4 0
797
#define IMXRT_PAD_GPIO_EMC_08__GPIO4_gpio_io08 0x0034 0x0224 0x0000 5 0
798
799
/* GPIO_EMC_09 */
800
#define IMXRT_PAD_GPIO_EMC_09__SEMC_ADDR00 0x0038 0x0228 0x0000 0 0
801
#define IMXRT_PAD_GPIO_EMC_09__PWM2_B1 0x0038 0x0228 0x048c 1 0
802
#define IMXRT_PAD_GPIO_EMC_09__SAI2_sai_rx_sync 0x0038 0x0228 0x05bc 2 0
803
#define IMXRT_PAD_GPIO_EMC_09__CAN2_TX 0x0038 0x0228 0x0000 3 0
804
#define IMXRT_PAD_GPIO_EMC_09__FLEXIO1_IO09 0x0038 0x0228 0x0000 4 0
805
#define IMXRT_PAD_GPIO_EMC_09__GPIO4_gpio_io09 0x0038 0x0228 0x0000 5 0
806
807
/* GPIO_EMC_10 */
808
#define IMXRT_PAD_GPIO_EMC_10__SEMC_ADDR01 0x003c 0x022c 0x0000 0 0
809
#define IMXRT_PAD_GPIO_EMC_10__PWM2_A2 0x003c 0x022c 0x0480 1 0
810
#define IMXRT_PAD_GPIO_EMC_10__SAI2_sai_rx_bclk 0x003c 0x022c 0x05b4 2 0
811
#define IMXRT_PAD_GPIO_EMC_10__CAN2_RX 0x003c 0x022c 0x0450 3 0
812
#define IMXRT_PAD_GPIO_EMC_10__FLEXIO1_IO10 0x003c 0x022c 0x0000 4 0
813
#define IMXRT_PAD_GPIO_EMC_10__GPIO4_gpio_io10 0x003c 0x022c 0x0000 5 0
814
815
/* GPIO_EMC_11 */
816
#define IMXRT_PAD_GPIO_EMC_11__SEMC_ADDR02 0x0040 0x0230 0x0000 0 0
817
#define IMXRT_PAD_GPIO_EMC_11__PWM2_B2 0x0040 0x0230 0x0490 1 0
818
#define IMXRT_PAD_GPIO_EMC_11__LPI2C4_SDA 0x0040 0x0230 0x04e8 2 0
819
#define IMXRT_PAD_GPIO_EMC_11__USDHC2_usdhc_reset_b 0x0040 0x0230 0x0000 3 0
820
#define IMXRT_PAD_GPIO_EMC_11__FLEXIO1_IO11 0x0040 0x0230 0x0000 4 0
821
#define IMXRT_PAD_GPIO_EMC_11__GPIO4_gpio_io11 0x0040 0x0230 0x0000 5 0
822
823
/* GPIO_EMC_12 */
824
#define IMXRT_PAD_GPIO_EMC_12__SEMC_ADDR03 0x0044 0x0234 0x0000 0 0
825
#define IMXRT_PAD_GPIO_EMC_12__XBARA1_IN24 0x0044 0x0234 0x0640 1 0
826
#define IMXRT_PAD_GPIO_EMC_12__LPI2C4_SCL 0x0044 0x0234 0x04e4 2 0
827
#define IMXRT_PAD_GPIO_EMC_12__USDHC1_usdhc_wp 0x0044 0x0234 0x05d8 3 0
828
#define IMXRT_PAD_GPIO_EMC_12__PWM1_A3 0x0044 0x0234 0x0454 4 1
829
#define IMXRT_PAD_GPIO_EMC_12__GPIO4_gpio_io12 0x0044 0x0234 0x0000 5 0
830
831
/* GPIO_EMC_13 */
832
#define IMXRT_PAD_GPIO_EMC_13__SEMC_ADDR04 0x0048 0x0238 0x0000 0 0
833
#define IMXRT_PAD_GPIO_EMC_13__XBARA1_IN25 0x0048 0x0238 0x0650 1 1
834
#define IMXRT_PAD_GPIO_EMC_13__LPUART3_TX 0x0048 0x0238 0x053c 2 1
835
#define IMXRT_PAD_GPIO_EMC_13__MQS_RIGHT 0x0048 0x0238 0x0000 3 0
836
#define IMXRT_PAD_GPIO_EMC_13__PWM1_B3 0x0048 0x0238 0x0464 4 1
837
#define IMXRT_PAD_GPIO_EMC_13__GPIO4_gpio_io13 0x0048 0x0238 0x0000 5 0
838
839
/* GPIO_EMC_14 */
840
#define IMXRT_PAD_GPIO_EMC_14__SEMC_ADDR05 0x004c 0x023c 0x0000 0 0
841
#define IMXRT_PAD_GPIO_EMC_14__XBARA1_OUT19 0x004c 0x023c 0x0654 1 0
842
#define IMXRT_PAD_GPIO_EMC_14__XBARA1_IN19 0x004c 0x023c 0x0654 1 0
843
#define IMXRT_PAD_GPIO_EMC_14__LPUART3_RX 0x004c 0x023c 0x0538 2 1
844
#define IMXRT_PAD_GPIO_EMC_14__MQS_LEFT 0x004c 0x023c 0x0000 3 0
845
#define IMXRT_PAD_GPIO_EMC_14__LPSPI2_PCS1 0x004c 0x023c 0x0000 4 0
846
#define IMXRT_PAD_GPIO_EMC_14__GPIO4_gpio_io14 0x004c 0x023c 0x0000 5 0
847
848
/* GPIO_EMC_15 */
849
#define IMXRT_PAD_GPIO_EMC_15__SEMC_ADDR06 0x0050 0x0240 0x0000 0 0
850
#define IMXRT_PAD_GPIO_EMC_15__XBARA1_IN20 0x0050 0x0240 0x0634 1 0
851
#define IMXRT_PAD_GPIO_EMC_15__LPUART3_CTS_B 0x0050 0x0240 0x0534 2 0
852
#define IMXRT_PAD_GPIO_EMC_15__SPDIF_spdif_out 0x0050 0x0240 0x0000 3 0
853
#define IMXRT_PAD_GPIO_EMC_15__TMR3_TIMER0 0x0050 0x0240 0x057c 4 0
854
#define IMXRT_PAD_GPIO_EMC_15__GPIO4_gpio_io15 0x0050 0x0240 0x0000 5 0
855
856
/* GPIO_EMC_16 */
857
#define IMXRT_PAD_GPIO_EMC_16__SEMC_ADDR07 0x0054 0x0244 0x0000 0 0
858
#define IMXRT_PAD_GPIO_EMC_16__XBARA1_IN21 0x0054 0x0244 0x0658 1 0
859
#define IMXRT_PAD_GPIO_EMC_16__LPUART3_RTS_B 0x0054 0x0244 0x0000 2 0
860
#define IMXRT_PAD_GPIO_EMC_16__SPDIF_spdif_in 0x0054 0x0244 0x05c8 3 1
861
#define IMXRT_PAD_GPIO_EMC_16__TMR3_TIMER1 0x0054 0x0244 0x0580 4 1
862
#define IMXRT_PAD_GPIO_EMC_16__GPIO4_gpio_io16 0x0054 0x0244 0x0000 5 0
863
864
/* GPIO_EMC_17 */
865
#define IMXRT_PAD_GPIO_EMC_17__SEMC_ADDR08 0x0058 0x0248 0x0000 0 0
866
#define IMXRT_PAD_GPIO_EMC_17__PWM4_A3 0x0058 0x0248 0x04a0 1 0
867
#define IMXRT_PAD_GPIO_EMC_17__LPUART4_CTS_B 0x0058 0x0248 0x0000 2 0
868
#define IMXRT_PAD_GPIO_EMC_17__CAN1_TX 0x0058 0x0248 0x0000 3 0
869
#define IMXRT_PAD_GPIO_EMC_17__TMR3_TIMER2 0x0058 0x0248 0x0584 4 0
870
#define IMXRT_PAD_GPIO_EMC_17__GPIO4_gpio_io17 0x0058 0x0248 0x0000 5 0
871
872
/* GPIO_EMC_18 */
873
#define IMXRT_PAD_GPIO_EMC_18__SEMC_ADDR09 0x005c 0x024c 0x0000 0 0
874
#define IMXRT_PAD_GPIO_EMC_18__PWM4_B3 0x005c 0x024c 0x0000 1 0
875
#define IMXRT_PAD_GPIO_EMC_18__LPUART4_RTS_B 0x005c 0x024c 0x0000 2 0
876
#define IMXRT_PAD_GPIO_EMC_18__CAN1_RX 0x005c 0x024c 0x044c 3 1
877
#define IMXRT_PAD_GPIO_EMC_18__TMR3_TIMER3 0x005c 0x024c 0x0588 4 0
878
#define IMXRT_PAD_GPIO_EMC_18__GPIO4_gpio_io18 0x005c 0x024c 0x0000 5 0
879
#define IMXRT_PAD_GPIO_EMC_18__SNVS_snvs_vio_5_ctl 0x005c 0x024c 0x0000 6 0
880
881
/* GPIO_EMC_19 */
882
#define IMXRT_PAD_GPIO_EMC_19__SEMC_ADDR11 0x0060 0x0250 0x0000 0 0
883
#define IMXRT_PAD_GPIO_EMC_19__PWM2_A3 0x0060 0x0250 0x0474 1 1
884
#define IMXRT_PAD_GPIO_EMC_19__LPUART4_TX 0x0060 0x0250 0x0544 2 1
885
#define IMXRT_PAD_GPIO_EMC_19__ENET_enet_rx_data1 0x0060 0x0250 0x0438 3 0
886
#define IMXRT_PAD_GPIO_EMC_19__TMR2_TIMER0 0x0060 0x0250 0x056c 4 0
887
#define IMXRT_PAD_GPIO_EMC_19__GPIO4_gpio_io19 0x0060 0x0250 0x0000 5 0
888
#define IMXRT_PAD_GPIO_EMC_19__SNVS_snvs_vio_5_b 0x0060 0x0250 0x0000 6 0
889
890
/* GPIO_EMC_20 */
891
#define IMXRT_PAD_GPIO_EMC_20__SEMC_ADDR12 0x0064 0x0254 0x0000 0 0
892
#define IMXRT_PAD_GPIO_EMC_20__PWM2_B3 0x0064 0x0254 0x0484 1 1
893
#define IMXRT_PAD_GPIO_EMC_20__LPUART4_RX 0x0064 0x0254 0x0540 2 1
894
#define IMXRT_PAD_GPIO_EMC_20__ENET_enet_rx_data0 0x0064 0x0254 0x0434 3 0
895
#define IMXRT_PAD_GPIO_EMC_20__TMR2_TIMER1 0x0064 0x0254 0x0570 4 0
896
#define IMXRT_PAD_GPIO_EMC_20__GPIO4_gpio_io20 0x0064 0x0254 0x0000 5 0
897
898
/* GPIO_EMC_21 */
899
#define IMXRT_PAD_GPIO_EMC_21__SEMC_BA0 0x0068 0x0258 0x0000 0 0
900
#define IMXRT_PAD_GPIO_EMC_21__PWM3_A3 0x0068 0x0258 0x0000 1 0
901
#define IMXRT_PAD_GPIO_EMC_21__LPI2C3_SDA 0x0068 0x0258 0x04e0 2 0
902
#define IMXRT_PAD_GPIO_EMC_21__ENET_enet_tx_data1 0x0068 0x0258 0x0000 3 0
903
#define IMXRT_PAD_GPIO_EMC_21__TMR2_TIMER2 0x0068 0x0258 0x0574 4 0
904
#define IMXRT_PAD_GPIO_EMC_21__GPIO4_gpio_io21 0x0068 0x0258 0x0000 5 0
905
906
/* GPIO_EMC_22 */
907
#define IMXRT_PAD_GPIO_EMC_22__SEMC_BA1 0x006c 0x025c 0x0000 0 0
908
#define IMXRT_PAD_GPIO_EMC_22__PWM3_B3 0x006c 0x025c 0x0000 1 0
909
#define IMXRT_PAD_GPIO_EMC_22__LPI2C3_SCL 0x006c 0x025c 0x04dc 2 0
910
#define IMXRT_PAD_GPIO_EMC_22__ENET_enet_tx_data0 0x006c 0x025c 0x0000 3 0
911
#define IMXRT_PAD_GPIO_EMC_22__TMR2_TIMER3 0x006c 0x025c 0x0578 4 0
912
#define IMXRT_PAD_GPIO_EMC_22__GPIO4_gpio_io22 0x006c 0x025c 0x0000 5 0
913
914
/* GPIO_EMC_23 */
915
#define IMXRT_PAD_GPIO_EMC_23__SEMC_ADDR10 0x0070 0x0260 0x0000 0 0
916
#define IMXRT_PAD_GPIO_EMC_23__PWM1_A0 0x0070 0x0260 0x0458 1 0
917
#define IMXRT_PAD_GPIO_EMC_23__LPUART5_TX 0x0070 0x0260 0x054c 2 0
918
#define IMXRT_PAD_GPIO_EMC_23__ENET_enet_rx_en 0x0070 0x0260 0x043c 3 0
919
#define IMXRT_PAD_GPIO_EMC_23__GPT1_gpt_capture2 0x0070 0x0260 0x0000 4 0
920
#define IMXRT_PAD_GPIO_EMC_23__GPIO4_gpio_io23 0x0070 0x0260 0x0000 5 0
921
922
/* GPIO_EMC_24 */
923
#define IMXRT_PAD_GPIO_EMC_24__SEMC_semc_cas 0x0074 0x0264 0x0000 0 0
924
#define IMXRT_PAD_GPIO_EMC_24__PWM1_B0 0x0074 0x0264 0x0468 1 0
925
#define IMXRT_PAD_GPIO_EMC_24__LPUART5_RX 0x0074 0x0264 0x0548 2 0
926
#define IMXRT_PAD_GPIO_EMC_24__ENET_enet_tx_en 0x0074 0x0264 0x0000 3 0
927
#define IMXRT_PAD_GPIO_EMC_24__GPT1_gpt_capture1 0x0074 0x0264 0x0000 4 0
928
#define IMXRT_PAD_GPIO_EMC_24__GPIO4_gpio_io24 0x0074 0x0264 0x0000 5 0
929
930
/* GPIO_EMC_25 */
931
#define IMXRT_PAD_GPIO_EMC_25__SEMC_semc_ras 0x0078 0x0268 0x0000 0 0
932
#define IMXRT_PAD_GPIO_EMC_25__PWM1_A1 0x0078 0x0268 0x045c 1 0
933
#define IMXRT_PAD_GPIO_EMC_25__LPUART6_TX 0x0078 0x0268 0x0554 2 0
934
#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_tx_clk 0x0078 0x0268 0x0448 3 0
935
#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_ref_clk 0x0078 0x0268 0x042c 4 0
936
#define IMXRT_PAD_GPIO_EMC_25__GPIO4_gpio_io25 0x0078 0x0268 0x0000 5 0
937
938
/* GPIO_EMC_26 */
939
#define IMXRT_PAD_GPIO_EMC_26__SEMC_semc_clk 0x007c 0x026c 0x0000 0 0
940
#define IMXRT_PAD_GPIO_EMC_26__PWM1_B1 0x007c 0x026c 0x046c 1 0
941
#define IMXRT_PAD_GPIO_EMC_26__LPUART6_RX 0x007c 0x026c 0x0550 2 0
942
#define IMXRT_PAD_GPIO_EMC_26__ENET_enet_rx_er 0x007c 0x026c 0x0440 3 0
943
#define IMXRT_PAD_GPIO_EMC_26__FLEXIO1_IO12 0x007c 0x026c 0x0000 4 0
944
#define IMXRT_PAD_GPIO_EMC_26__GPIO4_gpio_io26 0x007c 0x026c 0x0000 5 0
945
946
/* GPIO_EMC_27 */
947
#define IMXRT_PAD_GPIO_EMC_27__SEMC_semc_cke 0x0080 0x0270 0x0000 0 0
948
#define IMXRT_PAD_GPIO_EMC_27__PWM1_A2 0x0080 0x0270 0x0460 1 0
949
#define IMXRT_PAD_GPIO_EMC_27__LPUART5_RTS_B 0x0080 0x0270 0x0000 2 0
950
#define IMXRT_PAD_GPIO_EMC_27__LPSPI1_SCK 0x0080 0x0270 0x04f0 3 0
951
#define IMXRT_PAD_GPIO_EMC_27__FLEXIO1_IO13 0x0080 0x0270 0x0000 4 0
952
#define IMXRT_PAD_GPIO_EMC_27__GPIO4_gpio_io27 0x0080 0x0270 0x0000 5 0
953
954
/* GPIO_EMC_28 */
955
#define IMXRT_PAD_GPIO_EMC_28__SEMC_semc_we 0x0084 0x0274 0x0000 0 0
956
#define IMXRT_PAD_GPIO_EMC_28__PWM1_B2 0x0084 0x0274 0x0470 1 0
957
#define IMXRT_PAD_GPIO_EMC_28__LPUART5_CTS_B 0x0084 0x0274 0x0000 2 0
958
#define IMXRT_PAD_GPIO_EMC_28__LPSPI1_SDO 0x0084 0x0274 0x04f8 3 0
959
#define IMXRT_PAD_GPIO_EMC_28__FLEXIO1_IO14 0x0084 0x0274 0x0000 4 0
960
#define IMXRT_PAD_GPIO_EMC_28__GPIO4_gpio_io28 0x0084 0x0274 0x0000 5 0
961
962
/* GPIO_EMC_29 */
963
#define IMXRT_PAD_GPIO_EMC_29__SEMC_CS0 0x0088 0x0278 0x0000 0 0
964
#define IMXRT_PAD_GPIO_EMC_29__PWM3_A0 0x0088 0x0278 0x0000 1 0
965
#define IMXRT_PAD_GPIO_EMC_29__LPUART6_RTS_B 0x0088 0x0278 0x0000 2 0
966
#define IMXRT_PAD_GPIO_EMC_29__LPSPI1_SDI 0x0088 0x0278 0x04f4 3 0
967
#define IMXRT_PAD_GPIO_EMC_29__FLEXIO1_IO15 0x0088 0x0278 0x0000 4 0
968
#define IMXRT_PAD_GPIO_EMC_29__GPIO4_gpio_io29 0x0088 0x0278 0x0000 5 0
969
970
/* GPIO_EMC_30 */
971
#define IMXRT_PAD_GPIO_EMC_30__SEMC_DATA08 0x008c 0x027c 0x0000 0 0
972
#define IMXRT_PAD_GPIO_EMC_30__PWM3_B0 0x008c 0x027c 0x0000 1 0
973
#define IMXRT_PAD_GPIO_EMC_30__LPUART6_CTS_B 0x008c 0x027c 0x0000 2 0
974
#define IMXRT_PAD_GPIO_EMC_30__LPSPI1_PCS0 0x008c 0x027c 0x04ec 3 1
975
#define IMXRT_PAD_GPIO_EMC_30__CSI_csi_data23 0x008c 0x027c 0x0000 4 0
976
#define IMXRT_PAD_GPIO_EMC_30__GPIO4_gpio_io30 0x008c 0x027c 0x0000 5 0
977
978
/* GPIO_EMC_31 */
979
#define IMXRT_PAD_GPIO_EMC_31__SEMC_DATA09 0x0090 0x0280 0x0000 0 0
980
#define IMXRT_PAD_GPIO_EMC_31__PWM3_A1 0x0090 0x0280 0x0000 1 0
981
#define IMXRT_PAD_GPIO_EMC_31__LPUART7_TX 0x0090 0x0280 0x055c 2 1
982
#define IMXRT_PAD_GPIO_EMC_31__LPSPI1_PCS1 0x0090 0x0280 0x0000 3 0
983
#define IMXRT_PAD_GPIO_EMC_31__CSI_csi_data22 0x0090 0x0280 0x0000 4 0
984
#define IMXRT_PAD_GPIO_EMC_31__GPIO4_gpio_io31 0x0090 0x0280 0x0000 5 0
985
986
/* GPIO_EMC_32 */
987
#define IMXRT_PAD_GPIO_EMC_32__SEMC_DATA10 0x0094 0x0284 0x0000 0 0
988
#define IMXRT_PAD_GPIO_EMC_32__PWM3_B1 0x0094 0x0284 0x0000 1 0
989
#define IMXRT_PAD_GPIO_EMC_32__LPUART7_RX 0x0094 0x0284 0x0558 2 1
990
#define IMXRT_PAD_GPIO_EMC_32__CCM_PMIC_RDY 0x0094 0x0284 0x03fc 3 4
991
#define IMXRT_PAD_GPIO_EMC_32__CSI_csi_data21 0x0094 0x0284 0x0000 4 0
992
#define IMXRT_PAD_GPIO_EMC_32__GPIO3_gpio_io18 0x0094 0x0284 0x0000 5 0
993
994
/* GPIO_EMC_33 */
995
#define IMXRT_PAD_GPIO_EMC_33__SEMC_DATA11 0x0098 0x0288 0x0000 0 0
996
#define IMXRT_PAD_GPIO_EMC_33__PWM3_A2 0x0098 0x0288 0x0000 1 0
997
#define IMXRT_PAD_GPIO_EMC_33__USDHC1_usdhc_reset_b 0x0098 0x0288 0x0000 2 0
998
#define IMXRT_PAD_GPIO_EMC_33__SAI3_sai_rx_data 0x0098 0x0288 0x0000 3 0
999
#define IMXRT_PAD_GPIO_EMC_33__CSI_csi_data20 0x0098 0x0288 0x0000 4 0
1000
#define IMXRT_PAD_GPIO_EMC_33__GPIO3_gpio_io19 0x0098 0x0288 0x0000 5 0
1001
1002
/* GPIO_EMC_34 */
1003
#define IMXRT_PAD_GPIO_EMC_34__SEMC_DATA12 0x009c 0x028c 0x0000 0 0
1004
#define IMXRT_PAD_GPIO_EMC_34__PWM3_B2 0x009c 0x028c 0x0000 1 0
1005
#define IMXRT_PAD_GPIO_EMC_34__USDHC1_usdhc_vselect 0x009c 0x028c 0x0000 2 0
1006
#define IMXRT_PAD_GPIO_EMC_34__SAI3_sai_rx_sync 0x009c 0x028c 0x0000 3 0
1007
#define IMXRT_PAD_GPIO_EMC_34__CSI_csi_data19 0x009c 0x028c 0x0000 4 0
1008
#define IMXRT_PAD_GPIO_EMC_34__GPIO3_gpio_io20 0x009c 0x028c 0x0000 5 0
1009
1010
/* GPIO_EMC_35 */
1011
#define IMXRT_PAD_GPIO_EMC_35__SEMC_DATA13 0x00a0 0x0290 0x0000 0 0
1012
#define IMXRT_PAD_GPIO_EMC_35__XBARA1_OUT18 0x00a0 0x0290 0x0630 1 0
1013
#define IMXRT_PAD_GPIO_EMC_35__XBARA1_IN18 0x00a0 0x0290 0x0630 1 0
1014
#define IMXRT_PAD_GPIO_EMC_35__GPT1_gpt_compare1 0x00a0 0x0290 0x0000 2 0
1015
#define IMXRT_PAD_GPIO_EMC_35__SAI3_sai_rx_bclk 0x00a0 0x0290 0x0000 3 0
1016
#define IMXRT_PAD_GPIO_EMC_35__CSI_csi_data18 0x00a0 0x0290 0x0000 4 0
1017
#define IMXRT_PAD_GPIO_EMC_35__GPIO3_gpio_io21 0x00a0 0x0290 0x0000 5 0
1018
#define IMXRT_PAD_GPIO_EMC_35__USDHC1_usdhc_cd_b 0x00a0 0x0290 0x05d4 6 0
1019
1020
/* GPIO_EMC_36 */
1021
#define IMXRT_PAD_GPIO_EMC_36__SEMC_DATA14 0x00a4 0x0294 0x0000 0 0
1022
#define IMXRT_PAD_GPIO_EMC_36__XBARA1_IN22 0x00a4 0x0294 0x0638 1 0
1023
#define IMXRT_PAD_GPIO_EMC_36__GPT1_gpt_compare2 0x00a4 0x0294 0x0000 2 0
1024
#define IMXRT_PAD_GPIO_EMC_36__SAI3_sai_tx_data 0x00a4 0x0294 0x0000 3 0
1025
#define IMXRT_PAD_GPIO_EMC_36__CSI_csi_data17 0x00a4 0x0294 0x0000 4 0
1026
#define IMXRT_PAD_GPIO_EMC_36__GPIO3_gpio_io22 0x00a4 0x0294 0x0000 5 0
1027
#define IMXRT_PAD_GPIO_EMC_36__USDHC1_usdhc_wp 0x00a4 0x0294 0x05d8 6 1
1028
1029
/* GPIO_EMC_37 */
1030
#define IMXRT_PAD_GPIO_EMC_37__SEMC_DATA15 0x00a8 0x0298 0x0000 0 0
1031
#define IMXRT_PAD_GPIO_EMC_37__XBARA1_IN23 0x00a8 0x0298 0x063c 1 0
1032
#define IMXRT_PAD_GPIO_EMC_37__GPT1_gpt_compare3 0x00a8 0x0298 0x0000 2 0
1033
#define IMXRT_PAD_GPIO_EMC_37__SAI3_sai_mclk 0x00a8 0x0298 0x0000 3 0
1034
#define IMXRT_PAD_GPIO_EMC_37__CSI_csi_data16 0x00a8 0x0298 0x0000 4 0
1035
#define IMXRT_PAD_GPIO_EMC_37__GPIO3_gpio_io23 0x00a8 0x0298 0x0000 5 0
1036
#define IMXRT_PAD_GPIO_EMC_37__USDHC2_usdhc_wp 0x00a8 0x0298 0x0608 6 0
1037
1038
/* GPIO_EMC_38 */
1039
#define IMXRT_PAD_GPIO_EMC_38__SEMC_DM1 0x00ac 0x029c 0x0000 0 0
1040
#define IMXRT_PAD_GPIO_EMC_38__PWM1_A3 0x00ac 0x029c 0x0454 1 2
1041
#define IMXRT_PAD_GPIO_EMC_38__LPUART8_TX 0x00ac 0x029c 0x0564 2 2
1042
#define IMXRT_PAD_GPIO_EMC_38__SAI3_sai_tx_bclk 0x00ac 0x029c 0x0000 3 0
1043
#define IMXRT_PAD_GPIO_EMC_38__CSI_csi_field 0x00ac 0x029c 0x0000 4 0
1044
#define IMXRT_PAD_GPIO_EMC_38__GPIO3_gpio_io24 0x00ac 0x029c 0x0000 5 0
1045
#define IMXRT_PAD_GPIO_EMC_38__USDHC2_usdhc_vselect 0x00ac 0x029c 0x0000 6 0
1046
1047
/* GPIO_EMC_39 */
1048
#define IMXRT_PAD_GPIO_EMC_39__SEMC_semc_dqs 0x00b0 0x02a0 0x0000 0 0
1049
#define IMXRT_PAD_GPIO_EMC_39__PWM1_B3 0x00b0 0x02a0 0x0464 1 2
1050
#define IMXRT_PAD_GPIO_EMC_39__LPUART8_RX 0x00b0 0x02a0 0x0560 2 2
1051
#define IMXRT_PAD_GPIO_EMC_39__SAI3_sai_tx_sync 0x00b0 0x02a0 0x0000 3 0
1052
#define IMXRT_PAD_GPIO_EMC_39__WDOG1_wdog_b 0x00b0 0x02a0 0x0000 4 0
1053
#define IMXRT_PAD_GPIO_EMC_39__GPIO3_gpio_io25 0x00b0 0x02a0 0x0000 5 0
1054
#define IMXRT_PAD_GPIO_EMC_39__USDHC2_usdhc_cd_b 0x00b0 0x02a0 0x05e0 6 1
1055
1056
/* GPIO_EMC_40 */
1057
#define IMXRT_PAD_GPIO_EMC_40__SEMC_semc_rdy 0x00b4 0x02a4 0x0000 0 0
1058
#define IMXRT_PAD_GPIO_EMC_40__GPT2_gpt_capture2 0x00b4 0x02a4 0x0000 1 0
1059
#define IMXRT_PAD_GPIO_EMC_40__LPSPI1_PCS2 0x00b4 0x02a4 0x0000 2 0
1060
#define IMXRT_PAD_GPIO_EMC_40__USB2_usb_otg2_oc 0x00b4 0x02a4 0x05cc 3 1
1061
#define IMXRT_PAD_GPIO_EMC_40__ENET_enet_mdc 0x00b4 0x02a4 0x0000 4 0
1062
#define IMXRT_PAD_GPIO_EMC_40__GPIO3_gpio_io26 0x00b4 0x02a4 0x0000 5 0
1063
#define IMXRT_PAD_GPIO_EMC_40__USDHC2_usdhc_reset_b 0x00b4 0x02a4 0x0000 6 0
1064
1065
/* GPIO_EMC_41 */
1066
#define IMXRT_PAD_GPIO_EMC_41__SEMC_CSX0 0x00b8 0x02a8 0x0000 0 0
1067
#define IMXRT_PAD_GPIO_EMC_41__GPT2_gpt_capture1 0x00b8 0x02a8 0x0000 1 0
1068
#define IMXRT_PAD_GPIO_EMC_41__LPSPI1_PCS3 0x00b8 0x02a8 0x0000 2 0
1069
#define IMXRT_PAD_GPIO_EMC_41__USB2_usb_otg2_pwr 0x00b8 0x02a8 0x0000 3 0
1070
#define IMXRT_PAD_GPIO_EMC_41__ENET_enet_mdio 0x00b8 0x02a8 0x0430 4 1
1071
#define IMXRT_PAD_GPIO_EMC_41__GPIO3_gpio_io27 0x00b8 0x02a8 0x0000 5 0
1072
#define IMXRT_PAD_GPIO_EMC_41__USDHC1_usdhc_vselect 0x00b8 0x02a8 0x0000 6 0
1073
1074
/* GPIO_SD_B0_00 */
1075
#define IMXRT_PAD_GPIO_SD_B0_00__USDHC1_usdhc_cmd 0x01bc 0x03ac 0x0000 0 0
1076
#define IMXRT_PAD_GPIO_SD_B0_00__PWM1_A0 0x01bc 0x03ac 0x0458 1 1
1077
#define IMXRT_PAD_GPIO_SD_B0_00__LPI2C3_SCL 0x01bc 0x03ac 0x04dc 2 1
1078
#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_OUT04 0x01bc 0x03ac 0x0614 3 1
1079
#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_IN04 0x01bc 0x03ac 0x0614 3 1
1080
#define IMXRT_PAD_GPIO_SD_B0_00__LPSPI1_SCK 0x01bc 0x03ac 0x04f0 4 1
1081
#define IMXRT_PAD_GPIO_SD_B0_00__GPIO3_gpio_io12 0x01bc 0x03ac 0x0000 5 0
1082
#define IMXRT_PAD_GPIO_SD_B0_00__FLEXSPI_FLEXSPI_A_SS1_B 0x01bc 0x03ac 0x0000 6 0
1083
1084
/* GPIO_SD_B0_01 */
1085
#define IMXRT_PAD_GPIO_SD_B0_01__USDHC1_usdhc_clk 0x01c0 0x03b0 0x0000 0 0
1086
#define IMXRT_PAD_GPIO_SD_B0_01__PWM1_B0 0x01c0 0x03b0 0x0468 1 1
1087
#define IMXRT_PAD_GPIO_SD_B0_01__LPI2C3_SDA 0x01c0 0x03b0 0x04e0 2 1
1088
#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_OUT05 0x01c0 0x03b0 0x0618 3 1
1089
#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_IN05 0x01c0 0x03b0 0x0618 3 1
1090
#define IMXRT_PAD_GPIO_SD_B0_01__LPSPI1_PCS0 0x01c0 0x03b0 0x04ec 4 0
1091
#define IMXRT_PAD_GPIO_SD_B0_01__GPIO3_gpio_io13 0x01c0 0x03b0 0x0000 5 0
1092
#define IMXRT_PAD_GPIO_SD_B0_01__FLEXSPI_FLEXSPI_B_SS1_B 0x01c0 0x03b0 0x0000 6 0
1093
1094
/* GPIO_SD_B0_02 */
1095
#define IMXRT_PAD_GPIO_SD_B0_02__USDHC1_usdhc_data0 0x01c4 0x03b4 0x0000 0 0
1096
#define IMXRT_PAD_GPIO_SD_B0_02__PWM1_A1 0x01c4 0x03b4 0x045c 1 1
1097
#define IMXRT_PAD_GPIO_SD_B0_02__LPUART8_CTS_B 0x01c4 0x03b4 0x0000 2 0
1098
#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_OUT06 0x01c4 0x03b4 0x061c 3 1
1099
#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_IN06 0x01c4 0x03b4 0x061c 3 1
1100
#define IMXRT_PAD_GPIO_SD_B0_02__LPSPI1_SDO 0x01c4 0x03b4 0x04f8 4 1
1101
#define IMXRT_PAD_GPIO_SD_B0_02__GPIO3_gpio_io14 0x01c4 0x03b4 0x0000 5 0
1102
1103
/* GPIO_SD_B0_03 */
1104
#define IMXRT_PAD_GPIO_SD_B0_03__USDHC1_usdhc_data1 0x01c8 0x03b8 0x0000 0 0
1105
#define IMXRT_PAD_GPIO_SD_B0_03__PWM1_B1 0x01c8 0x03b8 0x046c 1 1
1106
#define IMXRT_PAD_GPIO_SD_B0_03__LPUART8_RTS_B 0x01c8 0x03b8 0x0000 2 0
1107
#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_OUT07 0x01c8 0x03b8 0x0620 3 1
1108
#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_IN07 0x01c8 0x03b8 0x0620 3 1
1109
#define IMXRT_PAD_GPIO_SD_B0_03__LPSPI1_SDI 0x01c8 0x03b8 0x04f4 4 1
1110
#define IMXRT_PAD_GPIO_SD_B0_03__GPIO3_gpio_io15 0x01c8 0x03b8 0x0000 5 0
1111
1112
/* GPIO_SD_B0_04 */
1113
#define IMXRT_PAD_GPIO_SD_B0_04__USDHC1_usdhc_data2 0x01cc 0x03bc 0x0000 0 0
1114
#define IMXRT_PAD_GPIO_SD_B0_04__PWM1_A2 0x01cc 0x03bc 0x0460 1 1
1115
#define IMXRT_PAD_GPIO_SD_B0_04__LPUART8_TX 0x01cc 0x03bc 0x0564 2 0
1116
#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_OUT08 0x01cc 0x03bc 0x0624 3 1
1117
#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_IN08 0x01cc 0x03bc 0x0624 3 1
1118
#define IMXRT_PAD_GPIO_SD_B0_04__FLEXSPI_FLEXSPI_B_SS0_B 0x01cc 0x03bc 0x0000 4 0
1119
#define IMXRT_PAD_GPIO_SD_B0_04__GPIO3_gpio_io16 0x01cc 0x03bc 0x0000 5 0
1120
#define IMXRT_PAD_GPIO_SD_B0_04__CCM_CLKO1 0x01cc 0x03bc 0x0000 6 0
1121
1122
/* GPIO_SD_B0_05 */
1123
#define IMXRT_PAD_GPIO_SD_B0_05__USDHC1_usdhc_data3 0x01d0 0x03c0 0x0000 0 0
1124
#define IMXRT_PAD_GPIO_SD_B0_05__PWM1_B2 0x01d0 0x03c0 0x0470 1 1
1125
#define IMXRT_PAD_GPIO_SD_B0_05__LPUART8_RX 0x01d0 0x03c0 0x0560 2 0
1126
#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_OUT09 0x01d0 0x03c0 0x0628 3 1
1127
#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_IN09 0x01d0 0x03c0 0x0628 3 1
1128
#define IMXRT_PAD_GPIO_SD_B0_05__FLEXSPI_FLEXSPI_B_DQS 0x01d0 0x03c0 0x0000 4 0
1129
#define IMXRT_PAD_GPIO_SD_B0_05__GPIO3_gpio_io17 0x01d0 0x03c0 0x0000 5 0
1130
#define IMXRT_PAD_GPIO_SD_B0_05__CCM_CLKO2 0x01d0 0x03c0 0x0000 6 0
1131
1132
/* GPIO_SD_B1_00 */
1133
#define IMXRT_PAD_GPIO_SD_B1_00__USDHC2_usdhc_data3 0x01d4 0x03c4 0x05f4 0 0
1134
#define IMXRT_PAD_GPIO_SD_B1_00__FLEXSPI_FLEXSPI_B_DATA3 0x01d4 0x03c4 0x04c4 1 0
1135
#define IMXRT_PAD_GPIO_SD_B1_00__PWM1_A3 0x01d4 0x03c4 0x0454 2 0
1136
#define IMXRT_PAD_GPIO_SD_B1_00__SAI1_sai_tx_data3 0x01d4 0x03c4 0x0598 3 0
1137
#define IMXRT_PAD_GPIO_SD_B1_00__LPUART4_TX 0x01d4 0x03c4 0x0544 4 0
1138
#define IMXRT_PAD_GPIO_SD_B1_00__GPIO3_gpio_io00 0x01d4 0x03c4 0x0000 5 0
1139
1140
/* GPIO_SD_B1_01 */
1141
#define IMXRT_PAD_GPIO_SD_B1_01__USDHC2_usdhc_data2 0x01d8 0x03c8 0x05f0 0 0
1142
#define IMXRT_PAD_GPIO_SD_B1_01__FLEXSPI_FLEXSPI_B_DATA2 0x01d8 0x03c8 0x04c0 1 0
1143
#define IMXRT_PAD_GPIO_SD_B1_01__PWM1_B3 0x01d8 0x03c8 0x0464 2 0
1144
#define IMXRT_PAD_GPIO_SD_B1_01__SAI1_sai_tx_data2 0x01d8 0x03c8 0x059c 3 0
1145
#define IMXRT_PAD_GPIO_SD_B1_01__LPUART4_RX 0x01d8 0x03c8 0x0540 4 0
1146
#define IMXRT_PAD_GPIO_SD_B1_01__GPIO3_gpio_io01 0x01d8 0x03c8 0x0000 5 0
1147
1148
/* GPIO_SD_B1_02 */
1149
#define IMXRT_PAD_GPIO_SD_B1_02__USDHC2_usdhc_data1 0x01dc 0x03cc 0x05ec 0 0
1150
#define IMXRT_PAD_GPIO_SD_B1_02__FLEXSPI_FLEXSPI_B_DATA1 0x01dc 0x03cc 0x04bc 1 0
1151
#define IMXRT_PAD_GPIO_SD_B1_02__PWM2_A3 0x01dc 0x03cc 0x0474 2 0
1152
#define IMXRT_PAD_GPIO_SD_B1_02__SAI1_sai_tx_data1 0x01dc 0x03cc 0x05a0 3 0
1153
#define IMXRT_PAD_GPIO_SD_B1_02__CAN1_TX 0x01dc 0x03cc 0x0000 4 0
1154
#define IMXRT_PAD_GPIO_SD_B1_02__GPIO3_gpio_io02 0x01dc 0x03cc 0x0000 5 0
1155
#define IMXRT_PAD_GPIO_SD_B1_02__CCM_WAIT 0x01dc 0x03cc 0x0000 6 0
1156
1157
/* GPIO_SD_B1_03 */
1158
#define IMXRT_PAD_GPIO_SD_B1_03__USDHC2_usdhc_data0 0x01e0 0x03d0 0x05e8 0 0
1159
#define IMXRT_PAD_GPIO_SD_B1_03__FLEXSPI_FLEXSPI_B_DATA0 0x01e0 0x03d0 0x04b8 1 0
1160
#define IMXRT_PAD_GPIO_SD_B1_03__PWM2_B3 0x01e0 0x03d0 0x0484 2 0
1161
#define IMXRT_PAD_GPIO_SD_B1_03__SAI1_sai_mclk 0x01e0 0x03d0 0x058c 3 0
1162
#define IMXRT_PAD_GPIO_SD_B1_03__CAN1_RX 0x01e0 0x03d0 0x044c 4 0
1163
#define IMXRT_PAD_GPIO_SD_B1_03__GPIO3_gpio_io03 0x01e0 0x03d0 0x0000 5 0
1164
#define IMXRT_PAD_GPIO_SD_B1_03__CCM_PMIC_RDY 0x01e0 0x03d0 0x03fc 6 0
1165
1166
/* GPIO_SD_B1_04 */
1167
#define IMXRT_PAD_GPIO_SD_B1_04__USDHC2_usdhc_clk 0x01e4 0x03d4 0x05dc 0 0
1168
#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_B_SCLK 0x01e4 0x03d4 0x0000 1 0
1169
#define IMXRT_PAD_GPIO_SD_B1_04__LPI2C1_SCL 0x01e4 0x03d4 0x04cc 2 0
1170
#define IMXRT_PAD_GPIO_SD_B1_04__SAI1_sai_rx_sync 0x01e4 0x03d4 0x05a4 3 0
1171
#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_A_SS1_B 0x01e4 0x03d4 0x0000 4 0
1172
#define IMXRT_PAD_GPIO_SD_B1_04__GPIO3_gpio_io04 0x01e4 0x03d4 0x0000 5 0
1173
#define IMXRT_PAD_GPIO_SD_B1_04__CCM_STOP 0x01e4 0x03d4 0x0000 6 0
1174
1175
/* GPIO_SD_B1_05 */
1176
#define IMXRT_PAD_GPIO_SD_B1_05__USDHC2_usdhc_cmd 0x01e8 0x03d8 0x05e4 0 0
1177
#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_A_DQS 0x01e8 0x03d8 0x04a4 1 0
1178
#define IMXRT_PAD_GPIO_SD_B1_05__LPI2C1_SDA 0x01e8 0x03d8 0x04d0 2 0
1179
#define IMXRT_PAD_GPIO_SD_B1_05__SAI1_sai_rx_bclk 0x01e8 0x03d8 0x0590 3 0
1180
#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_B_SS0_B 0x01e8 0x03d8 0x0000 4 0
1181
#define IMXRT_PAD_GPIO_SD_B1_05__GPIO3_gpio_io05 0x01e8 0x03d8 0x0000 5 0
1182
1183
/* GPIO_SD_B1_06 */
1184
#define IMXRT_PAD_GPIO_SD_B1_06__USDHC2_usdhc_reset_b 0x01ec 0x03dc 0x0000 0 0
1185
#define IMXRT_PAD_GPIO_SD_B1_06__FLEXSPI_FLEXSPI_A_SS0_B 0x01ec 0x03dc 0x0000 1 0
1186
#define IMXRT_PAD_GPIO_SD_B1_06__LPUART7_CTS_B 0x01ec 0x03dc 0x0000 2 0
1187
#define IMXRT_PAD_GPIO_SD_B1_06__SAI1_sai_rx_data0 0x01ec 0x03dc 0x0594 3 0
1188
#define IMXRT_PAD_GPIO_SD_B1_06__LPSPI2_PCS0 0x01ec 0x03dc 0x04fc 4 0
1189
#define IMXRT_PAD_GPIO_SD_B1_06__GPIO3_gpio_io06 0x01ec 0x03dc 0x0000 5 0
1190
1191
/* GPIO_SD_B1_07 */
1192
#define IMXRT_PAD_GPIO_SD_B1_07__SEMC_CSX1 0x01f0 0x03e0 0x0000 0 0
1193
#define IMXRT_PAD_GPIO_SD_B1_07__FLEXSPI_FLEXSPI_A_SCLK 0x01f0 0x03e0 0x04c8 1 0
1194
#define IMXRT_PAD_GPIO_SD_B1_07__LPUART7_RTS_B 0x01f0 0x03e0 0x0000 2 0
1195
#define IMXRT_PAD_GPIO_SD_B1_07__SAI1_sai_tx_data0 0x01f0 0x03e0 0x0000 3 0
1196
#define IMXRT_PAD_GPIO_SD_B1_07__LPSPI2_SCK 0x01f0 0x03e0 0x0500 4 0
1197
#define IMXRT_PAD_GPIO_SD_B1_07__GPIO3_gpio_io07 0x01f0 0x03e0 0x0000 5 0
1198
1199
/* GPIO_SD_B1_08 */
1200
#define IMXRT_PAD_GPIO_SD_B1_08__USDHC2_usdhc_data4 0x01f4 0x03e4 0x05f8 0 0
1201
#define IMXRT_PAD_GPIO_SD_B1_08__FLEXSPI_FLEXSPI_A_DATA0 0x01f4 0x03e4 0x04a8 1 0
1202
#define IMXRT_PAD_GPIO_SD_B1_08__LPUART7_TX 0x01f4 0x03e4 0x055c 2 0
1203
#define IMXRT_PAD_GPIO_SD_B1_08__SAI1_sai_tx_bclk 0x01f4 0x03e4 0x05a8 3 0
1204
#define IMXRT_PAD_GPIO_SD_B1_08__LPSPI2_SDO 0x01f4 0x03e4 0x0508 4 0
1205
#define IMXRT_PAD_GPIO_SD_B1_08__GPIO3_gpio_io08 0x01f4 0x03e4 0x0000 5 0
1206
#define IMXRT_PAD_GPIO_SD_B1_08__SEMC_CSX2 0x01f4 0x03e4 0x0000 6 0
1207
1208
/* GPIO_SD_B1_09 */
1209
#define IMXRT_PAD_GPIO_SD_B1_09__USDHC2_usdhc_data5 0x01f8 0x03e8 0x05fc 0 0
1210
#define IMXRT_PAD_GPIO_SD_B1_09__FLEXSPI_FLEXSPI_A_DATA1 0x01f8 0x03e8 0x04ac 1 0
1211
#define IMXRT_PAD_GPIO_SD_B1_09__LPUART7_RX 0x01f8 0x03e8 0x0558 2 0
1212
#define IMXRT_PAD_GPIO_SD_B1_09__SAI1_sai_tx_sync 0x01f8 0x03e8 0x05ac 3 0
1213
#define IMXRT_PAD_GPIO_SD_B1_09__LPSPI2_SDI 0x01f8 0x03e8 0x0504 4 0
1214
#define IMXRT_PAD_GPIO_SD_B1_09__GPIO3_gpio_io09 0x01f8 0x03e8 0x0000 5 0
1215
1216
/* GPIO_SD_B1_10 */
1217
#define IMXRT_PAD_GPIO_SD_B1_10__USDHC2_usdhc_data6 0x01fc 0x03ec 0x0600 0 0
1218
#define IMXRT_PAD_GPIO_SD_B1_10__FLEXSPI_FLEXSPI_A_DATA2 0x01fc 0x03ec 0x04b0 1 0
1219
#define IMXRT_PAD_GPIO_SD_B1_10__LPUART2_RX 0x01fc 0x03ec 0x052c 2 0
1220
#define IMXRT_PAD_GPIO_SD_B1_10__LPI2C2_SDA 0x01fc 0x03ec 0x04d8 3 0
1221
#define IMXRT_PAD_GPIO_SD_B1_10__LPSPI2_PCS2 0x01fc 0x03ec 0x0000 4 0
1222
#define IMXRT_PAD_GPIO_SD_B1_10__GPIO3_gpio_io10 0x01fc 0x03ec 0x0000 5 0
1223
1224
/* GPIO_SD_B1_11 */
1225
#define IMXRT_PAD_GPIO_SD_B1_11__USDHC2_usdhc_data7 0x0200 0x03f0 0x0604 0 0
1226
#define IMXRT_PAD_GPIO_SD_B1_11__FLEXSPI_FLEXSPI_A_DATA3 0x0200 0x03f0 0x04b4 1 0
1227
#define IMXRT_PAD_GPIO_SD_B1_11__LPUART2_TX 0x0200 0x03f0 0x0530 2 0
1228
#define IMXRT_PAD_GPIO_SD_B1_11__LPI2C2_SCL 0x0200 0x03f0 0x04d4 3 0
1229
#define IMXRT_PAD_GPIO_SD_B1_11__LPSPI2_PCS3 0x0200 0x03f0 0x0000 4 0
1230
#define IMXRT_PAD_GPIO_SD_B1_11__GPIO3_gpio_io11 0x0200 0x03f0 0x0000 5 0
1231
1232
#ifdef __cplusplus
1233
1234
#endif
/* __cplusplus */
1235
1236
#endif
/* LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H */
