39#define SENDOR_SUPPORTED_OUTPUTS 7
42#define SENSOR_REG_TERM 0xFF
44#define SENSOR_VAL_TERM 0xFF
51typedef enum _sensorType {
57typedef enum _sensorStatus {
61 SENSOR_RESOLUTION_NOT_SUPPORTED
65typedef enum _sensorTwiMode {
66 SENSOR_TWI_REG_BYTE_DATA_BYTE = 0,
67 SENSOR_TWI_REG_2BYTE_DATA_BYTE,
68 SENSOR_TWI_REG_BYTE_DATA_2BYTE
72typedef enum _sensorResolution {
79} sensorOutputResolution_t;
82typedef enum _sensorOutputFormat {
88} sensorOutputFormat_t;
108 sensorType_t cmos_ccd;
123extern sendorStatus_t sensor_twi_write_regs(Twid *pTwid,
124 const sensorReg_t *pReglist);
126extern sendorStatus_t sensor_twi_read_regs(Twid *pTwid,
127 const sensorReg_t *pReglist);
129extern sendorStatus_t sensor_setup(Twid *pTwid,
130 const sensorProfile_t *sensor_profile,
131 sensorOutputResolution_t resolution);
133extern sendorStatus_t sensor_get_output(sensorOutputFormat_t *
format,
136 sensorOutputResolution_t resolution);
Definition image_sensor_inf.h:96
uint32_t output_height
Definition image_sensor_inf.h:102
sensorOutputResolution_t output_resolution
Definition image_sensor_inf.h:98
uint32_t output_width
Definition image_sensor_inf.h:101
const sensorReg_t * output_setting
Definition image_sensor_inf.h:103
uint8_t supported
Definition image_sensor_inf.h:100
sensorOutputFormat_t output_format
Definition image_sensor_inf.h:99
Definition image_sensor_inf.h:107
uint16_t pid_low_reg
Definition image_sensor_inf.h:112
sensorTwiMode_t twi_inf_mode
Definition image_sensor_inf.h:109
uint16_t version_mask
Definition image_sensor_inf.h:115
const sensorOutput_t * outputConf[SENDOR_SUPPORTED_OUTPUTS]
Definition image_sensor_inf.h:117
uint16_t pid_high_reg
Definition image_sensor_inf.h:111
uint16_t pid_high
Definition image_sensor_inf.h:113
uint32_t twi_slave_addr
Definition image_sensor_inf.h:110
uint16_t pid_low
Definition image_sensor_inf.h:114
Definition image_sensor_inf.h:91
