RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
contrib
libraries
libboard
include
ili9488.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
36
37
#ifndef _ILI9488_H_
38
#define _ILI9488_H_
39
40
41
* Headers
42
43
44
#include "
board.h
45
46
#include <stdint.h>
47
48
49
50
* Definitions
51
52
53
#define ILI9488_SPIMODE 0
54
#define ILI9488_EBIMODE 1
55
56
/* ILI9325 ID code */
57
#define ILI9488_DEVICE_CODE 0x9488
58
59
#define ILI9488_LCD_WIDTH 320
60
#define ILI9488_LCD_HEIGHT 480
61
#define ILI9488_SELF_TEST_OK 0xC0
62
63
/* EBI chip select for LCD */
64
#define SMC_EBI_LCD_CS 3
65
66
67
* Types
68
69
typedef
enum
70
AccessInst = 0,
71
AccessRead,
72
AccessWrite
73
} AccessIli_t;
74
75
typedef
union
_union_type
76
uint32_t value;
77
struct
78
uint8_t byte_8;
79
uint8_t byte_l6;
80
uint8_t byte_24;
81
uint8_t byte_32;
82
} byte;
83
struct
84
uint16_t half_word_l;
85
uint16_t half_word_h;
86
} half_word;
87
} union_type;
88
typedef
volatile
uint8_t REG8;
89
90
typedef
uint32_t LcdColor_t;
91
92
93
* Marcos
94
95
/* Pixel cache used to speed up communication */
96
#define LCD_DATA_CACHE_SIZE BOARD_LCD_WIDTH
97
98
99
* Function Marcos
100
101
#define get_0b_to_8b(x) (((union_type*)&(x))->byte.byte_8)
102
#define get_8b_to_16b(x) (((union_type*)&(x))->byte.byte_l6)
103
#define get_16b_to_24b(x) (((union_type*)&(x))->byte.byte_24)
104
#define get_24b_to_32b(x) (((union_type*)&(x))->byte.byte_32)
105
106
#endif
/* #ifndef ILI9488 */
board.h
_union_type
Definition
ili9488.h:75
