RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
mvme5500
include
bsp
if_wmreg.h
1
/* $NetBSD: if_wmreg.h,v 1.22 2007/04/29 20:35:21 bouyer Exp $ */
2
3
4
* Copyright (c) 2001 Wasabi Systems, Inc.
5
* All rights reserved.
6
7
* Written by Jason R. Thorpe for Wasabi Systems, Inc.
8
* Some are added by Shuchen Kate Feng <feng1@bnl.gov>,
9
* NSLS, Brookhaven National Laboratory. All rights reserved.
10
* under the Deaprtment of Energy contract DE-AC02-98CH10886
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
* 3. All advertising materials mentioning features or use of this software
21
* must display the following acknowledgement:
22
* This product includes software developed for the NetBSD Project by
23
* Wasabi Systems, Inc.
24
* 4. The name of Wasabi Systems, Inc. may not be used to endorse
25
* or promote products derived from this software without specific prior
26
* written permission.
27
28
* THIS SOFTWARE IS PROVIDED BY WASABI SYSTEMS, INC. ``AS IS'' AND
29
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
30
* TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
31
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL WASABI SYSTEMS, INC
32
* BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
42
* Register description for the Intel i82542 (``Wiseman''),
43
* i82543 (``Livengood''), and i82544 (``Cordova'') Gigabit
44
* Ethernet chips.
45
46
47
48
* The wiseman supports 64-bit PCI addressing. This structure
49
* describes the address in descriptors.
50
51
typedef
struct
wiseman_addr
52
uint32_t wa_low;
/* low-order 32 bits */
53
uint32_t wa_high;
/* high-order 32 bits */
54
__attribute__
((__packed__)) wiseman_addr_t;
55
56
57
* The Wiseman receive descriptor.
58
59
* The receive descriptor ring must be aligned to a 4K boundary,
60
* and there must be an even multiple of 8 descriptors in the ring.
61
62
typedef
volatile
struct
wiseman_rxdesc
63
wiseman_addr_t wrx_addr;
/* buffer address */
64
65
uint16_t wrx_len;
/* buffer length */
66
uint16_t wrx_cksum;
/* checksum (starting at PCSS) */
67
68
uint8_t wrx_status;
/* Rx status */
69
uint8_t wrx_errors;
/* Rx errors */
70
uint16_t wrx_special;
/* special field (VLAN, etc.) */
71
__attribute__
((__packed__)) wiseman_rxdesc_t;
72
73
/* wrx_status bits */
74
#define WRX_ST_DD (1U << 0)
/* descriptor done */
75
#define WRX_ST_EOP (1U << 1)
/* end of packet */
76
#define WRX_ST_IXSM (1U << 2)
/* ignore checksum indication */
77
#define WRX_ST_VP (1U << 3)
/* VLAN packet */
78
#define WRX_ST_BPDU (1U << 4)
79
#define WRX_ST_TCPCS (1U << 5)
/* TCP checksum performed */
80
#define WRX_ST_IPCS (1U << 6)
/* IP checksum performed */
81
#define WRX_ST_PIF (1U << 7)
/* passed in-exact filter */
82
83
/* wrx_error bits */
84
#define WRX_ER_CE (1U << 0)
/* CRC error */
85
#define WRX_ER_SE (1U << 1)
/* symbol error */
86
#define WRX_ER_SEQ (1U << 2)
/* sequence error */
87
#define WRX_ER_ICE (1U << 3)
88
#define WRX_ER_CXE (1U << 4)
/* carrier extension error */
89
#define WRX_ER_TCPE (1U << 5)
/* TCP checksum error */
90
#define WRX_ER_IPE (1U << 6)
/* IP checksum error */
91
#define WRX_ER_RXE (1U << 7)
/* Rx data error */
92
93
/* wrx_special field for VLAN packets */
94
#define WRX_VLAN_ID(x) ((x) & 0x0fff)
/* VLAN identifier */
95
#define WRX_VLAN_CFI (1U << 12)
/* Canonical Form Indicator */
96
#define WRX_VLAN_PRI(x) (((x) >> 13) & 7)
/* VLAN priority field */
97
98
99
* The Wiseman transmit descriptor.
100
101
* The transmit descriptor ring must be aligned to a 4K boundary,
102
103
104
typedef
struct
wiseman_tx_fields
105
uint8_t wtxu_status;
/* Tx status */
106
uint8_t wtxu_options;
/* options */
107
uint16_t wtxu_vlan;
/* VLAN info */
108
__attribute__
((__packed__)) wiseman_txfields_t;
109
typedef
volatile
struct
wiseman_txdesc
110
wiseman_addr_t wtx_addr;
111
uint32_t wtx_cmdlen;
/* command and length */
112
wiseman_txfields_t wtx_fields;
/* fields; see below */
113
__attribute__
((__packed__)) wiseman_txdesc_t;
114
115
/* Commands for wtx_cmdlen */
116
#define WTX_CMD_EOP (1U << 24)
/* end of packet */
117
#define WTX_CMD_IFCS (1U << 25)
/* insert FCS */
118
#define WTX_CMD_RS (1U << 27)
/* report status */
119
#define WTX_CMD_RPS (1U << 28)
/* report packet sent */
120
#define WTX_CMD_DEXT (1U << 29)
/* descriptor extension */
121
#define WTX_CMD_VLE (1U << 30)
/* VLAN enable */
122
#define WTX_CMD_IDE (1U << 31)
/* interrupt delay enable */
123
124
/* Descriptor types (if DEXT is set) */
125
#define WTX_DTYP_C (0U << 20)
/* context */
126
#define WTX_DTYP_D (1U << 20)
/* data */
127
128
/* wtx_fields status bits */
129
#define WTX_ST_DD (1U << 0)
130
#define WTX_ST_EC (1U << 1)
/* excessive collisions */
131
#define WTX_ST_LC (1U << 2)
/* late collision */
132
#define WTX_ST_TU (1U << 3)
/* transmit underrun */
133
134
/* wtx_fields option bits for IP/TCP/UDP checksum offload */
135
#define WTX_IXSM (1U << 0)
/* IP checksum offload */
136
#define WTX_TXSM (1U << 1)
/* TCP/UDP checksum offload */
137
138
/* Maximum payload per Tx descriptor */
139
#define WTX_MAX_LEN 4096
140
141
142
* The Livengood TCP/IP context descriptor.
143
144
struct
livengood_tcpip_ctxdesc
145
uint32_t tcpip_ipcs;
/* IP checksum context */
146
uint32_t tcpip_tucs;
/* TCP/UDP checksum context */
147
uint32_t tcpip_cmdlen;
148
uint32_t tcpip_seg;
/* TCP segmentation context */
149
150
151
/* commands for context descriptors */
152
#define WTX_TCPIP_CMD_TCP (1U << 24)
/* 1 = TCP, 0 = UDP */
153
#define WTX_TCPIP_CMD_IP (1U << 25)
/* 1 = IPv4, 0 = IPv6 */
154
#define WTX_TCPIP_CMD_TSE (1U << 26)
/* segmentation context valid */
155
156
#define WTX_TCPIP_IPCSS(x) ((x) << 0)
/* checksum start */
157
#define WTX_TCPIP_IPCSO(x) ((x) << 8)
/* checksum value offset */
158
#define WTX_TCPIP_IPCSE(x) ((x) << 16)
/* checksum end */
159
160
#define WTX_TCPIP_TUCSS(x) ((x) << 0)
161
#define WTX_TCPIP_TUCSO(x) ((x) << 8)
162
#define WTX_TCPIP_TUCSE(x) ((x) << 16)
/* checksum end */
163
164
#define WTX_TCPIP_SEG_STATUS(x) ((x) << 0)
165
#define WTX_TCPIP_SEG_HDRLEN(x) ((x) << 8)
166
#define WTX_TCPIP_SEG_MSS(x) ((x) << 16)
167
168
169
* PCI config registers used by the Wiseman.
170
171
#define WM_PCI_MMBA PCI_MAPREG_START
172
/* registers for FLASH access on ICH8 */
173
#define WM_ICH8_FLASH 0x0014
174
175
176
* Wiseman Control/Status Registers.
177
178
#define WMREG_CTRL 0x0000
/* Device Control Register */
179
#define CTRL_FD (1U << 0)
/* full duplex */
180
#define CTRL_BEM (1U << 1)
/* big-endian mode */
181
#define CTRL_PRIOR (1U << 2)
/* 0 = receive, 1 = fair */
182
#define CTRL_LRST (1U << 3)
/* link reset */
183
#define CTRL_ASDE (1U << 5)
/* auto speed detect enable */
184
#define CTRL_SLU (1U << 6)
/* set link up */
185
#define CTRL_ILOS (1U << 7)
/* invert loss of signal */
186
#define CTRL_SPEED(x) ((x) << 8)
/* speed (Livengood) */
187
#define CTRL_SPEED_10 CTRL_SPEED(0)
188
#define CTRL_SPEED_100 CTRL_SPEED(1)
189
#define CTRL_SPEED_1000 CTRL_SPEED(2)
190
#define CTRL_SPEED_MASK CTRL_SPEED(3)
191
#define CTRL_FRCSPD (1U << 11)
/* force speed (Livengood) */
192
#define CTRL_FRCFDX (1U << 12)
/* force full-duplex (Livengood) */
193
#define CTRL_D_UD_EN (1U << 13)
/* Dock/Undock enable */
194
#define CTRL_D_UD_POL (1U << 14)
/* Defined polarity of Dock/Undock indication in SDP[0] */
195
#define CTRL_F_PHY_R (1U << 15)
/* Reset both PHY ports, through PHYRST_N pin */
196
#define CTRL_EXT_LINK_EN (1U << 16)
/* enable link status from external LINK_0 and LINK_1 pins */
197
#define CTRL_SWDPINS_SHIFT 18
198
#define CTRL_SWDPINS_MASK 0x0f
199
#define CTRL_SWDPIN(x) (1U << (CTRL_SWDPINS_SHIFT + (x)))
200
#define CTRL_SWDPIO_SHIFT 22
201
#define CTRL_SWDPIO_MASK 0x0f
202
#define CTRL_SWDPIO(x) (1U << (CTRL_SWDPIO_SHIFT + (x)))
203
#define CTRL_RST (1U << 26)
/* device reset */
204
#define CTRL_RFCE (1U << 27)
/* Rx flow control enable */
205
#define CTRL_TFCE (1U << 28)
/* Tx flow control enable */
206
#define CTRL_VME (1U << 30)
/* VLAN Mode Enable */
207
#define CTRL_PHY_RESET (1U << 31)
/* PHY reset (Cordova) */
208
209
#define WMREG_CTRL_SHADOW 0x0004
/* Device Control Register (shadow) */
210
211
#define WMREG_STATUS 0x0008
/* Device Status Register */
212
#define STATUS_FD (1U << 0)
/* full duplex */
213
#define STATUS_LU (1U << 1)
/* link up */
214
#define STATUS_TCKOK (1U << 2)
/* Tx clock running */
215
#define STATUS_RBCOK (1U << 3)
/* Rx clock running */
216
#define STATUS_FUNCID_SHIFT 2
/* 82546 function ID */
217
#define STATUS_FUNCID_MASK 3
218
#define STATUS_TXOFF (1U << 4)
/* Tx paused */
219
#define STATUS_TBIMODE (1U << 5)
/* fiber mode (Livengood) */
220
#define STATUS_SPEED(x) ((x) << 6)
/* speed indication */
221
#define STATUS_SPEED_10 STATUS_SPEED(0)
222
#define STATUS_SPEED_100 STATUS_SPEED(1)
223
#define STATUS_SPEED_1000 STATUS_SPEED(2)
224
#define STATUS_ASDV(x) ((x) << 8)
/* auto speed det. val. (Livengood) */
225
#define STATUS_MTXCKOK (1U << 10)
/* MTXD clock running */
226
#define STATUS_PCI66 (1U << 11)
/* 66MHz bus (Livengood) */
227
#define STATUS_BUS64 (1U << 12)
/* 64-bit bus (Livengood) */
228
#define STATUS_PCIX_MODE (1U << 13)
/* PCIX mode (Cordova) */
229
#define STATUS_PCIXSPD(x) ((x) << 14)
/* PCIX speed indication (Cordova) */
230
#define STATUS_PCIXSPD_50_66 STATUS_PCIXSPD(0)
231
#define STATUS_PCIXSPD_66_100 STATUS_PCIXSPD(1)
232
#define STATUS_PCIXSPD_100_133 STATUS_PCIXSPD(2)
233
#define STATUS_PCIXSPD_MASK STATUS_PCIXSPD(3)
234
235
#define WMREG_EECD 0x0010
/* EEPROM Control Register */
236
#define EECD_SK (1U << 0)
/* clock */
237
#define EECD_CS (1U << 1)
/* chip select */
238
#define EECD_DI (1U << 2)
/* data in */
239
#define EECD_DO (1U << 3)
/* data out */
240
#define EECD_FWE(x) ((x) << 4)
/* flash write enable control */
241
#define EECD_FWE_DISABLED EECD_FWE(1)
242
#define EECD_FWE_ENABLED EECD_FWE(2)
243
#define EECD_EE_REQ (1U << 6)
/* (shared) EEPROM request */
244
#define EECD_EE_GNT (1U << 7)
/* (shared) EEPROM grant */
245
#define EECD_EE_PRES (1U << 8)
/* EEPROM present */
246
#define EECD_EE_SIZE (1U << 9)
/* EEPROM size
247
(0 = 64 word, 1 = 256 word) */
248
#define EECD_EE_AUTORD (1U << 9)
/* auto read done */
249
#define EECD_EE_ABITS (1U << 10)
/* EEPROM address bits
250
(based on type) */
251
#define EECD_EE_TYPE (1U << 13)
/* EEPROM type
252
(0 = Microwire, 1 = SPI) */
253
#define EECD_SEC1VAL (1U << 22)
/* Sector One Valid */
254
255
#define UWIRE_OPC_ERASE 0x04
/* MicroWire "erase" opcode */
256
#define UWIRE_OPC_WRITE 0x05
/* MicroWire "write" opcode */
257
#define UWIRE_OPC_READ 0x06
/* MicroWire "read" opcode */
258
259
#define SPI_OPC_WRITE 0x02
/* SPI "write" opcode */
260
#define SPI_OPC_READ 0x03
/* SPI "read" opcode */
261
#define SPI_OPC_A8 0x08
/* opcode bit 3 == address bit 8 */
262
#define SPI_OPC_WREN 0x06
/* SPI "set write enable" opcode */
263
#define SPI_OPC_WRDI 0x04
/* SPI "clear write enable" opcode */
264
#define SPI_OPC_RDSR 0x05
/* SPI "read status" opcode */
265
#define SPI_OPC_WRSR 0x01
/* SPI "write status" opcode */
266
#define SPI_MAX_RETRIES 5000
/* max wait of 5ms for RDY signal */
267
268
#define SPI_SR_RDY 0x01
269
#define SPI_SR_WEN 0x02
270
#define SPI_SR_BP0 0x04
271
#define SPI_SR_BP1 0x08
272
#define SPI_SR_WPEN 0x80
273
274
#define EEPROM_OFF_MACADDR 0x00
/* MAC address offset */
275
#define EEPROM_OFF_CFG1 0x0a
/* config word 1 */
276
#define EEPROM_OFF_CFG2 0x0f
/* config word 2 */
277
#define EEPROM_OFF_SWDPIN 0x20
/* SWD Pins (Cordova) */
278
279
#define EEPROM_CFG1_LVDID (1U << 0)
280
#define EEPROM_CFG1_LSSID (1U << 1)
281
#define EEPROM_CFG1_PME_CLOCK (1U << 2)
282
#define EEPROM_CFG1_PM (1U << 3)
283
#define EEPROM_CFG1_ILOS (1U << 4)
284
#define EEPROM_CFG1_SWDPIO_SHIFT 5
285
#define EEPROM_CFG1_SWDPIO_MASK (0xf << EEPROM_CFG1_SWDPIO_SHIFT)
286
#define EEPROM_CFG1_IPS1 (1U << 8)
287
#define EEPROM_CFG1_LRST (1U << 9)
288
#define EEPROM_CFG1_FD (1U << 10)
289
#define EEPROM_CFG1_FRCSPD (1U << 11)
290
#define EEPROM_CFG1_IPS0 (1U << 12)
291
#define EEPROM_CFG1_64_32_BAR (1U << 13)
292
293
#define EEPROM_CFG2_CSR_RD_SPLIT (1U << 1)
294
#define EEPROM_CFG2_APM_EN (1U << 2)
295
#define EEPROM_CFG2_64_BIT (1U << 3)
296
#define EEPROM_CFG2_MAX_READ (1U << 4)
297
#define EEPROM_CFG2_DMCR_MAP (1U << 5)
298
#define EEPROM_CFG2_133_CAP (1U << 6)
299
#define EEPROM_CFG2_MSI_DIS (1U << 7)
300
#define EEPROM_CFG2_FLASH_DIS (1U << 8)
301
#define EEPROM_CFG2_FLASH_SIZE(x) (((x) & 3) >> 9)
302
#define EEPROM_CFG2_ANE (1U << 11)
303
#define EEPROM_CFG2_PAUSE(x) (((x) & 3) >> 12)
304
#define EEPROM_CFG2_ASDE (1U << 14)
305
#define EEPROM_CFG2_APM_PME (1U << 15)
306
#define EEPROM_CFG2_SWDPIO_SHIFT 4
307
#define EEPROM_CFG2_SWDPIO_MASK (0xf << EEPROM_CFG2_SWDPIO_SHIFT)
308
309
#define EEPROM_SWDPIN_MASK 0xdf
310
#define EEPROM_SWDPIN_SWDPIN_SHIFT 0
311
#define EEPROM_SWDPIN_SWDPIO_SHIFT 8
312
313
#define WMREG_EERD 0x0014
/* EEPROM read */
314
#define EERD_DONE 0x02
/* done bit */
315
#define EERD_START 0x01
/* First bit for telling part to start operation */
316
#define EERD_ADDR_SHIFT 2
/* Shift to the address bits */
317
#define EERD_DATA_SHIFT 16
/* Offset to data in EEPROM read/write registers */
318
319
#define WMREG_CTRL_EXT 0x0018
/* Extended Device Control Register */
320
#define CTRL_EXT_GPI_EN(x) (1U << (x))
/* gpin interrupt enable */
321
#define CTRL_EXT_SWDPINS_SHIFT 4
322
#define CTRL_EXT_SWDPINS_MASK 0x0d
323
#define CTRL_EXT_SWDPIN(x) (1U << (CTRL_EXT_SWDPINS_SHIFT + (x) - 4))
324
#define CTRL_EXT_SWDPIO_SHIFT 8
325
#define CTRL_EXT_SWDPIO_MASK 0x0d
326
#define CTRL_EXT_SWDPIO(x) (1U << (CTRL_EXT_SWDPIO_SHIFT + (x) - 4))
327
#define CTRL_EXT_ASDCHK (1U << 12)
/* ASD check */
328
#define CTRL_EXT_EE_RST (1U << 13)
/* EEPROM reset */
329
#define CTRL_EXT_IPS (1U << 14)
/* invert power state bit 0 */
330
#define CTRL_EXT_SPD_BYPS (1U << 15)
/* speed select bypass */
331
#define CTRL_EXT_IPS1 (1U << 16)
/* invert power state bit 1 */
332
#define CTRL_EXT_RO_DIS (1U << 17)
/* relaxed ordering disabled */
333
#define CTRL_EXT_LINK_MODE_MASK 0x00C00000
334
#define CTRL_EXT_LINK_MODE_GMII 0x00000000
335
#define CTRL_EXT_LINK_MODE_TBI 0x00C00000
336
#define CTRL_EXT_LINK_MODE_KMRN 0x00000000
337
#define CTRL_EXT_LINK_MODE_SERDES 0x00C00000
338
339
340
#define WMREG_MDIC 0x0020
/* MDI Control Register */
341
#define MDIC_DATA(x) ((x) & 0xffff)
342
#define MDIC_REGADD(x) ((x) << 16)
343
#define MDIC_PHYADD(x) ((x) << 21)
344
#define MDIC_OP_WRITE (1U << 26)
345
#define MDIC_OP_READ (2U << 26)
346
#define MDIC_READY (1U << 28)
347
#define MDIC_I (1U << 29)
/* interrupt on MDI complete */
348
#define MDIC_E (1U << 30)
/* MDI error */
349
350
#define WMREG_FCAL 0x0028
/* Flow Control Address Low */
351
#define FCAL_CONST 0x00c28001
/* Flow Control MAC addr low */
352
353
#define WMREG_FCAH 0x002c
/* Flow Control Address High */
354
#define FCAH_CONST 0x00000100
/* Flow Control MAC addr high */
355
356
#define WMREG_FCT 0x0030
/* Flow Control Type */
357
358
#define WMREG_VET 0x0038
/* VLAN Ethertype */
359
360
#define WMREG_RAL_BASE 0x0040
/* Receive Address List */
361
#define WMREG_CORDOVA_RAL_BASE 0x5400
362
#define WMREG_RAL_LO(b, x) ((b) + ((x) << 3))
363
#define WMREG_RAL_HI(b, x) (WMREG_RAL_LO(b, x) + 4)
364
365
* Receive Address List: The LO part is the low-order 32-bits
366
* of the MAC address. The HI part is the high-order 16-bits
367
* along with a few control bits.
368
369
#define RAL_AS(x) ((x) << 16)
/* address select */
370
#define RAL_AS_DEST RAL_AS(0)
/* (cordova?) */
371
#define RAL_AS_SOURCE RAL_AS(1)
/* (cordova?) */
372
#define RAL_RDR1 (1U << 30)
/* put packet in alt. rx ring */
373
#define RAL_AV (1U << 31)
/* entry is valid */
374
375
#define WM_RAL_TABSIZE 16
376
#define WM_ICH8_RAL_TABSIZE 7
377
378
#define WMREG_ICR 0x00c0
/* Interrupt Cause Register */
379
#define ICR_TXDW (1U << 0)
/* Tx desc written back */
380
#define ICR_TXQE (1U << 1)
/* Tx queue empty */
381
#define ICR_LSC (1U << 2)
/* link status change */
382
#define ICR_RXSEQ (1U << 3)
/* receive sequence error */
383
#define ICR_RXDMT0 (1U << 4)
/* Rx ring 0 nearly empty */
384
#define ICR_RXO (1U << 6)
/* Rx overrun */
385
#define ICR_RXT0 (1U << 7)
/* Rx ring 0 timer */
386
#define ICR_MDAC (1U << 9)
/* MDIO access complete */
387
#define ICR_RXCFG (1U << 10)
/* Receiving /C/ */
388
#define ICR_GPI(x) (1U << (x))
/* general purpose interrupts */
389
#define ICR_INT (1U << 31)
/* device generated an interrupt */
390
391
#define WMREG_ITR 0x00c4
/* Interrupt Throttling Register */
392
#define ITR_IVAL_MASK 0xffff
/* Interval mask */
393
#define ITR_IVAL_SHIFT 0
/* Interval shift */
394
395
#define WMREG_ICS 0x00c8
/* Interrupt Cause Set Register */
396
/* See ICR bits. */
397
398
#define WMREG_IMS 0x00d0
/* Interrupt Mask Set Register */
399
/* See ICR bits. */
400
401
#define WMREG_IMC 0x00d8
/* Interrupt Mask Clear Register */
402
/* See ICR bits. */
403
404
#define WMREG_RCTL 0x0100
/* Receive Control */
405
#define RCTL_EN (1U << 1)
/* receiver enable */
406
#define RCTL_SBP (1U << 2)
/* store bad packets */
407
#define RCTL_UPE (1U << 3)
/* unicast promisc. enable */
408
#define RCTL_MPE (1U << 4)
/* multicast promisc. enable */
409
#define RCTL_LPE (1U << 5)
/* large packet enable */
410
#define RCTL_LBM(x) ((x) << 6)
/* loopback mode */
411
#define RCTL_LBM_NONE RCTL_LBM(0)
412
#define RCTL_LBM_PHY RCTL_LBM(3)
413
#define RCTL_RDMTS(x) ((x) << 8)
/* receive desc. min thresh size */
414
#define RCTL_RDMTS_1_2 RCTL_RDMTS(0)
415
#define RCTL_RDMTS_1_4 RCTL_RDMTS(1)
416
#define RCTL_RDMTS_1_8 RCTL_RDMTS(2)
417
#define RCTL_RDMTS_MASK RCTL_RDMTS(3)
418
#define RCTL_MO(x) ((x) << 12)
/* multicast offset */
419
#define RCTL_BAM (1U << 15)
/* broadcast accept mode */
420
#define RCTL_2k (0 << 16)
/* 2k Rx buffers */
421
#define RCTL_1k (1 << 16)
/* 1k Rx buffers */
422
#define RCTL_512 (2 << 16)
/* 512 byte Rx buffers */
423
#define RCTL_256 (3 << 16)
/* 256 byte Rx buffers */
424
#define RCTL_BSEX_16k (1 << 16)
/* 16k Rx buffers (BSEX) */
425
#define RCTL_BSEX_8k (2 << 16)
/* 8k Rx buffers (BSEX) */
426
#define RCTL_BSEX_4k (3 << 16)
/* 4k Rx buffers (BSEX) */
427
#define RCTL_DPF (1U << 22)
/* discard pause frames */
428
#define RCTL_PMCF (1U << 23)
/* pass MAC control frames */
429
#define RCTL_BSEX (1U << 25)
/* buffer size extension (Livengood) */
430
#define RCTL_SECRC (1U << 26)
/* strip Ethernet CRC */
431
432
#define WMREG_OLD_RDTR0 0x0108
/* Receive Delay Timer (ring 0) */
433
#define WMREG_RDTR 0x2820
434
#define RDTR_FPD (1U << 31)
/* flush partial descriptor */
435
436
#define WMREG_RADV 0x282c
/* Receive Interrupt Absolute Delay Timer */
437
438
#define WMREG_OLD_RDBAL0 0x0110
/* Receive Descriptor Base Low (ring 0) */
439
#define WMREG_RDBAL 0x2800
440
441
#define WMREG_OLD_RDBAH0 0x0114
/* Receive Descriptor Base High (ring 0) */
442
#define WMREG_RDBAH 0x2804
443
444
#define WMREG_OLD_RDLEN0 0x0118
/* Receive Descriptor Length (ring 0) */
445
#define WMREG_RDLEN 0x2808
446
447
#define WMREG_OLD_RDH0 0x0120
/* Receive Descriptor Head (ring 0) */
448
#define WMREG_RDH 0x2810
449
450
#define WMREG_OLD_RDT0 0x0128
/* Receive Descriptor Tail (ring 0) */
451
#define WMREG_RDT 0x2818
452
453
#define WMREG_RXDCTL 0x2828
/* Receive Descriptor Control */
454
#define RXDCTL_PTHRESH(x) ((x) << 0)
/* prefetch threshold */
455
#define RXDCTL_HTHRESH(x) ((x) << 8)
/* host threshold */
456
#define RXDCTL_WTHRESH(x) ((x) << 16)
/* write back threshold */
457
#define RXDCTL_GRAN (1U << 24)
/* 0 = cacheline, 1 = descriptor */
458
459
#define WMREG_OLD_RDTR1 0x0130
/* Receive Delay Timer (ring 1) */
460
461
#define WMREG_OLD_RDBA1_LO 0x0138
/* Receive Descriptor Base Low (ring 1) */
462
463
#define WMREG_OLD_RDBA1_HI 0x013c
/* Receive Descriptor Base High (ring 1) */
464
465
#define WMREG_OLD_RDLEN1 0x0140
/* Receive Drscriptor Length (ring 1) */
466
467
#define WMREG_OLD_RDH1 0x0148
468
469
#define WMREG_OLD_RDT1 0x0150
470
471
#define WMREG_OLD_FCRTH 0x0160
/* Flow Control Rx Threshold Hi (OLD) */
472
#define WMREG_FCRTL 0x2160
/* Flow Control Rx Threshold Lo */
473
#define FCRTH_DFLT 0x00008000
474
475
#define WMREG_OLD_FCRTL 0x0168
/* Flow Control Rx Threshold Lo (OLD) */
476
#define WMREG_FCRTH 0x2168
/* Flow Control Rx Threhsold Hi */
477
#define FCRTL_DFLT 0x00004000
478
#define FCRTL_XONE 0x80000000
/* Enable XON frame transmission */
479
480
#define WMREG_FCTTV 0x0170
/* Flow Control Transmit Timer Value */
481
#define FCTTV_DFLT 0x00000600
482
483
#define WMREG_TXCW 0x0178
/* Transmit Configuration Word (TBI mode) */
484
/* See MII ANAR_X bits. */
485
#define TXCW_TxConfig (1U << 30)
/* Tx Config */
486
#define TXCW_ANE (1U << 31)
/* Autonegotiate */
487
488
#define WMREG_RXCW 0x0180
/* Receive Configuration Word (TBI mode) */
489
/* See MII ANLPAR_X bits. */
490
#define RXCW_NC (1U << 26)
/* no carrier */
491
#define RXCW_IV (1U << 27)
/* config invalid */
492
#define RXCW_CC (1U << 28)
/* config change */
493
#define RXCW_C (1U << 29)
/* /C/ reception */
494
#define RXCW_SYNCH (1U << 30)
/* synchronized */
495
#define RXCW_ANC (1U << 31)
/* autonegotiation complete */
496
497
#define WMREG_MTA 0x0200
/* Multicast Table Array */
498
#define WMREG_CORDOVA_MTA 0x5200
499
500
#define WMREG_TCTL 0x0400
/* Transmit Control Register */
501
#define TCTL_EN (1U << 1)
/* transmitter enable */
502
#define TCTL_PSP (1U << 3)
/* pad short packets */
503
#define TCTL_CT(x) (((x) & 0xff) << 4)
/* 4:11 - collision threshold */
504
#define TCTL_COLD(x) (((x) & 0x3ff) << 12)
/* 12:21 - collision distance */
505
#define TCTL_SWXOFF (1U << 22)
/* software XOFF */
506
#define TCTL_RTLC (1U << 24)
/* retransmit on late collision */
507
#define TCTL_NRTU (1U << 25)
/* no retransmit on underrun */
508
#define TCTL_MULR (1U << 28)
/* multiple request */
509
510
#define TX_COLLISION_THRESHOLD 15
511
#define TX_COLLISION_DISTANCE_HDX 512
512
#define TX_COLLISION_DISTANCE_FDX 64
513
514
#define WMREG_TCTL_EXT 0x0404
515
#define TCTL_EXT_BST_MASK 0x000003FF
/* Backoff Slot Time */
516
#define TCTL_EXT_GCEX_MASK 0x000FFC00
/* Gigabit Carry Extend Padding */
517
518
#define DEFAULT_80003ES2LAN_TCTL_EXT_GCEX 0x00010000
519
520
#define WMREG_TQSA_LO 0x0408
521
522
#define WMREG_TQSA_HI 0x040c
523
524
#define WMREG_TIPG 0x0410
/* Transmit IPG Register */
525
#define TIPG_IPGT(x) (x)
/* IPG transmit time */
526
#define TIPG_IPGR1(x) ((x) << 10)
/* IPG receive time 1 */
527
#define TIPG_IPGR2(x) ((x) << 20)
/* IPG receive time 2 */
528
529
#define TIPG_WM_DFLT (TIPG_IPGT(0x0a) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x0a))
530
#define TIPG_LG_DFLT (TIPG_IPGT(0x06) | TIPG_IPGR1(0x08) | TIPG_IPGR2(0x06))
531
#define TIPG_1000T_DFLT (TIPG_IPGT(0x08) | TIPG_IPGR1(0x08) | TIPG_IPGR2(0x06))
532
#define TIPG_1000T_80003_DFLT \
533
(TIPG_IPGT(0x08) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x07))
534
#define TIPG_10_100_80003_DFLT \
535
(TIPG_IPGT(0x09) | TIPG_IPGR1(0x02) | TIPG_IPGR2(0x07))
536
537
#define WMREG_TQC 0x0418
538
539
#define WMREG_EEWR 0x102c
/* EEPROM write */
540
541
#define WMREG_RDFH 0x2410
/* Receive Data FIFO Head */
542
543
#define WMREG_RDFT 0x2418
/* Receive Data FIFO Tail */
544
545
#define WMREG_RDFHS 0x2420
/* Receive Data FIFO Head Saved */
546
547
#define WMREG_RDFTS 0x2428
/* Receive Data FIFO Tail Saved */
548
549
#define WMREG_TDFH 0x3410
/* Transmit Data FIFO Head */
550
551
#define WMREG_TDFT 0x3418
/* Transmit Data FIFO Tail */
552
553
#define WMREG_TDFHS 0x3420
/* Transmit Data FIFO Head Saved */
554
555
#define WMREG_TDFTS 0x3428
/* Transmit Data FIFO Tail Saved */
556
557
#define WMREG_TDFPC 0x3430
/* Transmit Data FIFO Packet Count */
558
559
#define WMREG_OLD_TBDAL 0x0420
/* Transmit Descriptor Base Lo */
560
#define WMREG_TBDAL 0x3800
561
562
#define WMREG_OLD_TBDAH 0x0424
/* Transmit Descriptor Base Hi */
563
#define WMREG_TBDAH 0x3804
564
565
#define WMREG_OLD_TDLEN 0x0428
/* Transmit Descriptor Length */
566
#define WMREG_TDLEN 0x3808
567
568
#define WMREG_OLD_TDH 0x0430
/* Transmit Descriptor Head */
569
#define WMREG_TDH 0x3810
570
571
#define WMREG_OLD_TDT 0x0438
/* Transmit Descriptor Tail */
572
#define WMREG_TDT 0x3818
573
574
#define WMREG_OLD_TIDV 0x0440
/* Transmit Delay Interrupt Value */
575
#define WMREG_TIDV 0x3820
576
577
#define WMREG_TXDCTL 0x3828
/* Trandmit Descriptor Control */
578
#define TXDCTL_PTHRESH(x) ((x) << 0)
579
#define TXDCTL_HTHRESH(x) ((x) << 8)
580
#define TXDCTL_WTHRESH(x) ((x) << 16)
581
582
#define WMREG_TADV 0x382c
/* Transmit Absolute Interrupt Delay Timer */
583
584
#define WMREG_AIT 0x0458
/* Adaptive IFS Throttle */
585
586
#define WMREG_VFTA 0x0600
587
588
#define WM_MC_TABSIZE 128
589
#define WM_ICH8_MC_TABSIZE 32
590
#define WM_VLAN_TABSIZE 128
591
592
#define WMREG_PBA 0x1000
/* Packet Buffer Allocation */
593
#define PBA_BYTE_SHIFT 10
/* KB -> bytes */
594
#define PBA_ADDR_SHIFT 7
/* KB -> quadwords */
595
#define PBA_8K 0x0008
596
#define PBA_12K 0x000c
597
#define PBA_16K 0x0010
/* 16K, default Tx allocation */
598
#define PBA_22K 0x0016
599
#define PBA_24K 0x0018
600
#define PBA_30K 0x001e
601
#define PBA_32K 0x0020
602
#define PBA_40K 0x0028
603
#define PBA_48K 0x0030
/* 48K, default Rx allocation */
604
605
#define WMREG_PBS 0x1000
/* Packet Buffer Size (ICH8 only ?) */
606
607
#define WMREG_TXDMAC 0x3000
/* Transfer DMA Control */
608
#define TXDMAC_DPP (1U << 0)
/* disable packet prefetch */
609
610
#define WMREG_TSPMT 0x3830
/* TCP Segmentation Pad and Minimum
611
Threshold (Cordova) */
612
#define TSPMT_TSMT(x) (x)
/* TCP seg min transfer */
613
#define TSPMT_TSPBP(x) ((x) << 16)
/* TCP seg pkt buf padding */
614
615
#define WMREG_RXCSUM 0x5000
/* Receive Checksum register */
616
#define RXCSUM_PCSS 0x000000ff
/* Packet Checksum Start */
617
#define RXCSUM_IPOFL (1U << 8)
618
#define RXCSUM_TUOFL (1U << 9)
619
#define RXCSUM_IPV6OFL (1U << 10)
/* IPv6 checksum offload */
620
621
#define WMREG_RXERRC 0x400C
/* receive error Count - R/clr */
622
#define WMREG_COLC 0x4028
/* collision Count - R/clr */
623
#define WMREG_XONRXC 0x4048
/* XON Rx Count - R/clr */
624
#define WMREG_XONTXC 0x404c
/* XON Tx Count - R/clr */
625
#define WMREG_XOFFRXC 0x4050
/* XOFF Rx Count - R/clr */
626
#define WMREG_XOFFTXC 0x4054
/* XOFF Tx Count - R/clr */
627
#define WMREG_FCRUC 0x4058
/* Flow Control Rx Unsupported Count - R/clr */
628
629
#define WMREG_KUMCTRLSTA 0x0034
/* MAC-PHY interface - RW */
630
#define KUMCTRLSTA_MASK 0x0000FFFF
631
#define KUMCTRLSTA_OFFSET 0x001F0000
632
#define KUMCTRLSTA_OFFSET_SHIFT 16
633
#define KUMCTRLSTA_REN 0x00200000
634
635
#define KUMCTRLSTA_OFFSET_FIFO_CTRL 0x00000000
636
#define KUMCTRLSTA_OFFSET_CTRL 0x00000001
637
#define KUMCTRLSTA_OFFSET_INB_CTRL 0x00000002
638
#define KUMCTRLSTA_OFFSET_DIAG 0x00000003
639
#define KUMCTRLSTA_OFFSET_TIMEOUTS 0x00000004
640
#define KUMCTRLSTA_OFFSET_INB_PARAM 0x00000009
641
#define KUMCTRLSTA_OFFSET_HD_CTRL 0x00000010
642
#define KUMCTRLSTA_OFFSET_M2P_SERDES 0x0000001E
643
#define KUMCTRLSTA_OFFSET_M2P_MODES 0x0000001F
644
645
/* FIFO Control */
646
#define KUMCTRLSTA_FIFO_CTRL_RX_BYPASS 0x00000008
647
#define KUMCTRLSTA_FIFO_CTRL_TX_BYPASS 0x00000800
648
649
/* In-Band Control */
650
#define KUMCTRLSTA_INB_CTRL_LINK_TMOUT_DFLT 0x00000500
651
#define KUMCTRLSTA_INB_CTRL_DIS_PADDING 0x00000010
652
653
/* Half-Duplex Control */
654
#define KUMCTRLSTA_HD_CTRL_10_100_DEFAULT 0x00000004
655
#define KUMCTRLSTA_HD_CTRL_1000_DEFAULT 0x00000000
656
657
#define WMREG_MDPHYA 0x003C
/* PHY address - RW */
658
659
#define WMREG_MANC2H 0x5860
/* Managment Control To Host - RW */
660
661
#define WMREG_SWSM 0x5b50
/* SW Semaphore */
662
#define SWSM_SMBI 0x00000001
/* Driver Semaphore bit */
663
#define SWSM_SWESMBI 0x00000002
/* FW Semaphore bit */
664
#define SWSM_WMNG 0x00000004
/* Wake MNG Clock */
665
#define SWSM_DRV_LOAD 0x00000008
/* Driver Loaded Bit */
666
667
#define WMREG_SW_FW_SYNC 0x5b5c
/* software-firmware semaphore */
668
#define SWFW_EEP_SM 0x0001
/* eeprom access */
669
#define SWFW_PHY0_SM 0x0002
/* first ctrl phy access */
670
#define SWFW_PHY1_SM 0x0004
/* second ctrl phy access */
671
#define SWFW_MAC_CSR_SM 0x0008
672
#define SWFW_SOFT_SHIFT 0
/* software semaphores */
673
#define SWFW_FIRM_SHIFT 16
/* firmware semaphores */
674
675
#define WMREG_EXTCNFCTR 0x0f00
/* Extended Configuration Control */
676
#define EXTCNFCTR_PCIE_WRITE_ENABLE 0x00000001
677
#define EXTCNFCTR_PHY_WRITE_ENABLE 0x00000002
678
#define EXTCNFCTR_D_UD_ENABLE 0x00000004
679
#define EXTCNFCTR_D_UD_LATENCY 0x00000008
680
#define EXTCNFCTR_D_UD_OWNER 0x00000010
681
#define EXTCNFCTR_MDIO_SW_OWNERSHIP 0x00000020
682
#define EXTCNFCTR_MDIO_HW_OWNERSHIP 0x00000040
683
#define EXTCNFCTR_EXT_CNF_POINTER 0x0FFF0000
684
#define E1000_EXTCNF_CTRL_SWFLAG EXTCNFCTR_MDIO_SW_OWNERSHIP
685
686
/* ich8 flash control */
687
#define ICH_FLASH_COMMAND_TIMEOUT 5000
/* 5000 uSecs - adjusted */
688
#define ICH_FLASH_ERASE_TIMEOUT 3000000
/* Up to 3 seconds - worst case */
689
#define ICH_FLASH_CYCLE_REPEAT_COUNT 10
/* 10 cycles */
690
#define ICH_FLASH_SEG_SIZE_256 256
691
#define ICH_FLASH_SEG_SIZE_4K 4096
692
#define ICH_FLASH_SEG_SIZE_64K 65536
693
694
#define ICH_CYCLE_READ 0x0
695
#define ICH_CYCLE_RESERVED 0x1
696
#define ICH_CYCLE_WRITE 0x2
697
#define ICH_CYCLE_ERASE 0x3
698
699
#define ICH_FLASH_GFPREG 0x0000
700
#define ICH_FLASH_HSFSTS 0x0004
/* Flash Status Register */
701
#define HSFSTS_DONE 0x0001
/* Flash Cycle Done */
702
#define HSFSTS_ERR 0x0002
/* Flash Cycle Error */
703
#define HSFSTS_DAEL 0x0004
/* Direct Access error Log */
704
#define HSFSTS_ERSZ_MASK 0x0018
/* Block/Sector Erase Size */
705
#define HSFSTS_ERSZ_SHIFT 3
706
#define HSFSTS_FLINPRO 0x0020
/* flash SPI cycle in Progress */
707
#define HSFSTS_FLDVAL 0x4000
/* Flash Descriptor Valid */
708
#define HSFSTS_FLLK 0x8000
/* Flash Configuration Lock-Down */
709
#define ICH_FLASH_HSFCTL 0x0006
/* Flash control Register */
710
#define HSFCTL_GO 0x0001
/* Flash Cycle Go */
711
#define HSFCTL_CYCLE_MASK 0x0006
/* Flash Cycle */
712
#define HSFCTL_CYCLE_SHIFT 1
713
#define HSFCTL_BCOUNT_MASK 0x0300
/* Data Byte Count */
714
#define HSFCTL_BCOUNT_SHIFT 8
715
#define ICH_FLASH_FADDR 0x0008
716
#define ICH_FLASH_FDATA0 0x0010
717
#define ICH_FLASH_FRACC 0x0050
718
#define ICH_FLASH_FREG0 0x0054
719
#define ICH_FLASH_FREG1 0x0058
720
#define ICH_FLASH_FREG2 0x005C
721
#define ICH_FLASH_FREG3 0x0060
722
#define ICH_FLASH_FPR0 0x0074
723
#define ICH_FLASH_FPR1 0x0078
724
#define ICH_FLASH_SSFSTS 0x0090
725
#define ICH_FLASH_SSFCTL 0x0092
726
#define ICH_FLASH_PREOP 0x0094
727
#define ICH_FLASH_OPTYPE 0x0096
728
#define ICH_FLASH_OPMENU 0x0098
729
730
#define ICH_FLASH_REG_MAPSIZE 0x00A0
731
#define ICH_FLASH_SECTOR_SIZE 4096
732
#define ICH_GFPREG_BASE_MASK 0x1FFF
733
#define ICH_FLASH_LINEAR_ADDR_MASK 0x00FFFFFF
734
735
/* start of Kate Feng added */
736
#define WMREG_GPTC 0x4080
/* Good packets transmitted count */
737
#define WMREG_GPRC 0x4074
/* Good packets received count */
738
#define WMREG_CRCERRS 0x4000
/* CRC Error Count */
739
#define WMREG_RLEC 0x4040
/* Receive Length Error Count */
740
/* end of Kate Feng added */
__attribute__
Definition
xnandpsu_onfi.h:185
Definition
if_wmreg.h:144
wiseman_addr
Definition
if_wmreg.h:51
wiseman_rxdesc
Definition
if_wmreg.h:62
wiseman_tx_fields
Definition
if_wmreg.h:104
wiseman_txdesc
Definition
if_wmreg.h:109
