RTEMS
6.3
Toggle main menu visibility
score
cpu
i386
include
score
idtr.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
23
24
25
* COPYRIGHT (C) 1998 Eric Valette (valette@crf.canon.fr)
26
* Canon Centre Recherche France.
27
28
29
* modification, are permitted provided that the following conditions
30
* are met:
31
* 1. Redistributions of source code must retain the above copyright
32
* notice, this list of conditions and the following disclaimer.
33
* 2. Redistributions in binary form must reproduce the above copyright
34
* notice, this list of conditions and the following disclaimer in the
35
* documentation and/or other materials provided with the distribution.
36
37
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
38
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
39
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
40
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
41
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
42
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
43
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
44
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
45
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
46
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
47
* POSSIBILITY OF SUCH DAMAGE.
48
49
50
#ifndef _RTEMS_SCORE_IDTR_H
51
#define _RTEMS_SCORE_IDTR_H
52
53
54
* See page 14.9 Figure 14-2.
55
56
57
typedef
struct
58
59
unsigned
int
low_offsets_bits:16;
60
unsigned
int
segment_selector:16;
61
unsigned
int
fixed_value_bits:8;
62
unsigned
int
gate_type:5;
63
unsigned
int
privilege:2;
64
unsigned
int
present:1;
65
unsigned
int
high_offsets_bits:16;
66
interrupt_gate_descriptor
67
68
69
* C callable function enabling to create a interrupt_gate_descriptor
70
71
extern
void
create_interrupt_gate_descriptor (
*, rtems_raw_irq_hdl);
72
73
74
* C callable function enabling to get easily usable info from
75
* the actual value of IDT register.
76
77
extern
void
i386_get_info_from_IDTR (
** table,
78
unsigned
* limit);
79
80
81
* C callable function enabling to change the value of IDT register. Must be called
82
* with interrupts masked at processor level!!!.
83
84
extern
void
i386_set_IDTR (
* table,
85
unsigned
limit);
86
87
#endif
Definition
idtr.h:58
