RTEMS
6.3
Toggle main menu visibility
score
cpu
mips
include
mips
idtcpu.h
1
10
11
12
* Based upon IDT provided code with the following release:
13
14
* This source code has been made available to you by IDT on an AS-IS
15
* basis. Anyone receiving this source is licensed under IDT copyrights
16
* to use it in any way he or she deems fit, including copying it,
17
* modifying it, compiling it, and redistributing it either with or
18
* without modifications. No license under IDT patents or patent
19
* applications is to be implied by the copyright license.
20
21
* Any user of this software should understand that IDT cannot provide
22
* technical support for this software and will not be responsible for
23
* any consequences resulting from the use of this software.
24
25
* Any person who transfers this source code or any derivative work must
26
* include the IDT copyright notice, this paragraph, and the preceeding
27
* two paragraphs in the transferred software.
28
29
* COPYRIGHT IDT CORPORATION 1996
30
* LICENSED MATERIAL - PROGRAM PROPERTY OF IDT
31
32
33
#ifndef _RTEMS_MIPS_IDTCPU_H
34
#define _RTEMS_MIPS_IDTCPU_H
35
43
44
45
* 950313: Ketan added Register definition for XContext reg.
46
* added define for WAIT instruction.
47
* 950421: Ketan added Register definition for Config reg (R3081)
48
49
50
51
** memory configuration and mapping
52
53
#define K0BASE 0x80000000
54
#define K0SIZE 0x20000000
55
#define K1BASE 0xa0000000
56
#define K1SIZE 0x20000000
57
#define K2BASE 0xc0000000
58
#define K2SIZE 0x20000000
59
#if __mips == 3
60
#define KSBASE 0xe0000000
61
#define KSSIZE 0x20000000
62
#endif
63
64
#define KUBASE 0
65
#define KUSIZE 0x80000000
66
67
68
** Exception Vectors
69
70
#if __mips == 1
71
#define UT_VEC K0BASE
/* utlbmiss vector */
72
#define DB_VEC (K0BASE+0x40)
/* debug vector */
73
#define E_VEC (K0BASE+0x80)
/* exception vector */
74
#elif __mips == 32
75
#define T_VEC (K0BASE+0x000)
/* tlbmiss vector */
76
#define X_VEC (K0BASE+0x080)
/* xtlbmiss vector */
77
#define C_VEC (K0BASE+0x100)
/* cache error vector */
78
#define E_VEC (K0BASE+0x180)
79
#elif __mips == 3
80
81
82
83
84
#else
85
#error "EXCEPTION VECTORS: unknown ISA level"
86
#endif
87
#define R_VEC (K1BASE+0x1fc00000)
/* reset vector */
88
89
90
** Address conversion macros
91
92
#ifdef CLANGUAGE
93
#define CAST(as) (as)
94
#else
95
#define CAST(as)
96
#endif
97
#define K0_TO_K1(x) (CAST(unsigned)(x)|0xA0000000)
/* kseg0 to kseg1 */
98
#define K1_TO_K0(x) (CAST(unsigned)(x)&0x9FFFFFFF)
/* kseg1 to kseg0 */
99
#define K0_TO_PHYS(x) (CAST(unsigned)(x)&0x1FFFFFFF)
/* kseg0 to physical */
100
#define K1_TO_PHYS(x) (CAST(unsigned)(x)&0x1FFFFFFF)
/* kseg1 to physical */
101
#define PHYS_TO_K0(x) (CAST(unsigned)(x)|0x80000000)
/* physical to kseg0 */
102
#define PHYS_TO_K1(x) (CAST(unsigned)(x)|0xA0000000)
/* physical to kseg1 */
103
104
105
** Cache size constants
106
107
#define MINCACHE 0x200
/* 512 For 3041. */
108
#define MAXCACHE 0x40000
/* 256*1024 256k */
109
110
#if __mips == 32
111
/* R4000 configuration register definitions */
112
#define CFG_CM 0x80000000
/* Master-Checker mode */
113
#define CFG_ECMASK 0x70000000
/* System Clock Ratio */
114
#define CFG_ECBY2 0x00000000
/* divide by 2 */
115
#define CFG_ECBY3 0x10000000
/* divide by 3 */
116
#define CFG_ECBY4 0x20000000
/* divide by 4 */
117
#define CFG_EPMASK 0x0f000000
/* Transmit data pattern */
118
#define CFG_EPD 0x00000000
/* D */
119
#define CFG_EPDDX 0x01000000
/* DDX */
120
#define CFG_EPDDXX 0x02000000
/* DDXX */
121
#define CFG_EPDXDX 0x03000000
/* DXDX */
122
#define CFG_EPDDXXX 0x04000000
/* DDXXX */
123
#define CFG_EPDDXXXX 0x05000000
/* DDXXXX */
124
#define CFG_EPDXXDXX 0x06000000
/* DXXDXX */
125
#define CFG_EPDDXXXXX 0x07000000
/* DDXXXXX */
126
#define CFG_EPDXXXDXXX 0x08000000
/* DXXXDXXX */
127
#define CFG_SBMASK 0x00c00000
/* Secondary cache block size */
128
#define CFG_SBSHIFT 22
129
#define CFG_SB4 0x00000000
/* 4 words */
130
#define CFG_SB8 0x00400000
/* 8 words */
131
#define CFG_SB16 0x00800000
/* 16 words */
132
#define CFG_SB32 0x00c00000
/* 32 words */
133
#define CFG_SS 0x00200000
/* Split secondary cache */
134
#define CFG_SW 0x00100000
/* Secondary cache port width */
135
#define CFG_EWMASK 0x000c0000
/* System port width */
136
#define CFG_EWSHIFT 18
137
#define CFG_EW64 0x00000000
/* 64 bit */
138
#define CFG_EW32 0x00010000
/* 32 bit */
139
#define CFG_SC 0x00020000
/* Secondary cache absent */
140
#define CFG_SM 0x00010000
/* Dirty Shared mode disabled */
141
#define CFG_BE 0x00008000
/* Big Endian */
142
#define CFG_EM 0x00004000
/* ECC mode enable */
143
#define CFG_EB 0x00002000
/* Block ordering */
144
#define CFG_ICMASK 0x00000e00
/* Instruction cache size */
145
#define CFG_ICSHIFT 9
146
#define CFG_DCMASK 0x000001c0
/* Data cache size */
147
#define CFG_DCSHIFT 6
148
#define CFG_IB 0x00000020
/* Instruction cache block size */
149
#define CFG_DB 0x00000010
/* Data cache block size */
150
#define CFG_CU 0x00000008
/* Update on Store Conditional */
151
#define CFG_K0MASK 0x00000007
/* KSEG0 coherency algorithm */
152
153
154
* R4000 primary cache mode
155
156
#define CFG_C_UNCACHED 2
157
#define CFG_C_NONCOHERENT 3
158
#define CFG_C_COHERENTXCL 4
159
#define CFG_C_COHERENTXCLW 5
160
#define CFG_C_COHERENTUPD 6
161
162
163
* R4000 cache operations (should be in assembler...?)
164
165
#define Index_Invalidate_I 0x0
/* 0 0 */
166
#define Index_Writeback_Inv_D 0x1
/* 0 1 */
167
#define Index_Invalidate_SI 0x2
/* 0 2 */
168
#define Index_Writeback_Inv_SD 0x3
/* 0 3 */
169
#define Index_Load_Tag_I 0x4
/* 1 0 */
170
#define Index_Load_Tag_D 0x5
/* 1 1 */
171
#define Index_Load_Tag_SI 0x6
/* 1 2 */
172
#define Index_Load_Tag_SD 0x7
/* 1 3 */
173
#define Index_Store_Tag_I 0x8
/* 2 0 */
174
#define Index_Store_Tag_D 0x9
/* 2 1 */
175
#define Index_Store_Tag_SI 0xA
/* 2 2 */
176
#define Index_Store_Tag_SD 0xB
/* 2 3 */
177
#define Create_Dirty_Exc_D 0xD
/* 3 1 */
178
#define Create_Dirty_Exc_SD 0xF
/* 3 3 */
179
#define Hit_Invalidate_I 0x10
/* 4 0 */
180
#define Hit_Invalidate_D 0x11
/* 4 1 */
181
#define Hit_Invalidate_SI 0x12
/* 4 2 */
182
#define Hit_Invalidate_SD 0x13
/* 4 3 */
183
#define Hit_Writeback_Inv_D 0x15
/* 5 1 */
184
#define Hit_Writeback_Inv_SD 0x17
/* 5 3 */
185
#define Fill_I 0x14
/* 5 0 */
186
#define Hit_Writeback_D 0x19
/* 6 1 */
187
#define Hit_Writeback_SD 0x1B
/* 6 3 */
188
#define Hit_Writeback_I 0x18
/* 6 0 */
189
#define Hit_Set_Virtual_SI 0x1E
/* 7 2 */
190
#define Hit_Set_Virtual_SD 0x1F
/* 7 3 */
191
192
/* Disabled by chris -- horrible overload of common word.
193
#ifndef WAIT
194
#define WAIT .word 0x42000020
195
#endif
196
197
/* Disabled by joel -- horrible overload of common word.
198
#ifndef wait
199
#define wait .word 0x42000020
200
#endif wait
201
202
203
#endif
204
205
#if __mips == 3
206
207
208
209
/* divide by 2 */
210
/* divide by 3 */
211
/* divide by 4 */
212
213
/* D */
214
/* DDX */
215
/* DDXX */
216
/* DXDX */
217
/* DDXXX */
218
/* DDXXXX */
219
/* DXXDXX */
220
/* DDXXXXX */
221
/* DXXXDXXX */
222
223
224
/* 4 words */
225
/* 8 words */
226
/* 16 words */
227
/* 32 words */
228
229
230
231
232
/* 64 bit */
233
/* 32 bit */
234
235
236
/* Big Endian */
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
/* 0 0 */
261
/* 0 1 */
262
/* 0 2 */
263
/* 0 3 */
264
/* 1 0 */
265
/* 1 1 */
266
/* 1 2 */
267
/* 1 3 */
268
/* 2 0 */
269
/* 2 1 */
270
/* 2 2 */
271
/* 2 3 */
272
/* 3 1 */
273
/* 3 3 */
274
/* 4 0 */
275
/* 4 1 */
276
/* 4 2 */
277
/* 4 3 */
278
/* 5 1 */
279
/* 5 3 */
280
#define Fill_I 0x14
/* 5 0 */
281
/* 6 1 */
282
/* 6 3 */
283
/* 6 0 */
284
/* 7 2 */
285
/* 7 3 */
286
287
288
#ifndef WAIT
289
290
#endif
291
292
293
#ifndef wait
294
295
#endif wait
296
297
298
#endif
299
300
301
** TLB resource defines
302
303
#if __mips == 1
304
#define N_TLB_ENTRIES 64
305
#define TLB_PGSIZE 0x1000
306
#define RANDBASE 8
307
#define TLBLO_PFNMASK 0xfffff000
308
#define TLBLO_PFNSHIFT 12
309
#define TLBLO_N 0x800
/* non-cacheable */
310
#define TLBLO_D 0x400
/* writeable */
311
#define TLBLO_V 0x200
/* valid bit */
312
#define TLBLO_G 0x100
/* global access bit */
313
314
#define TLBHI_VPNMASK 0xfffff000
315
#define TLBHI_VPNSHIFT 12
316
#define TLBHI_PIDMASK 0xfc0
317
#define TLBHI_PIDSHIFT 6
318
#define TLBHI_NPID 64
319
320
#define TLBINX_PROBE 0x80000000
321
#define TLBINX_INXMASK 0x00003f00
322
#define TLBINX_INXSHIFT 8
323
324
#define TLBRAND_RANDMASK 0x00003f00
325
#define TLBRAND_RANDSHIFT 8
326
327
#define TLBCTXT_BASEMASK 0xffe00000
328
#define TLBCTXT_BASESHIFT 21
329
330
#define TLBCTXT_VPNMASK 0x001ffffc
331
#define TLBCTXT_VPNSHIFT 2
332
#endif
333
#if __mips == 3
334
#define N_TLB_ENTRIES 48
335
336
#define TLBHI_VPN2MASK 0xffffe000
337
#define TLBHI_PIDMASK 0x000000ff
338
#define TLBHI_NPID 256
339
340
#define TLBLO_PFNMASK 0x3fffffc0
341
#define TLBLO_PFNSHIFT 6
342
#define TLBLO_D 0x00000004
/* writeable */
343
#define TLBLO_V 0x00000002
/* valid bit */
344
#define TLBLO_G 0x00000001
345
#define TLBLO_CMASK 0x00000038
/* cache algorithm mask */
346
#define TLBLO_CSHIFT 3
347
348
#define TLBLO_UNCACHED (CFG_C_UNCACHED<<TLBLO_CSHIFT)
349
#define TLBLO_NONCOHERENT (CFG_C_NONCOHERENT<<TLBLO_CSHIFT)
350
#define TLBLO_COHERENTXCL (CFG_C_COHERENTXCL<<TLBLO_CSHIFT)
351
#define TLBLO_COHERENTXCLW (CFG_C_COHERENTXCLW<<TLBLO_CSHIFT)
352
#define TLBLO_COHERENTUPD (CFG_C_COHERENTUPD<<TLBLO_CSHIFT)
353
354
355
#define TLBINX_INXMASK 0x0000003f
356
357
#define TLBRAND_RANDMASK 0x0000003f
358
359
#define TLBCTXT_BASEMASK 0xff800000
360
#define TLBCTXT_BASESHIFT 23
361
362
#define TLBCTXT_VPN2MASK 0x007ffff0
363
#define TLBCTXT_VPN2SHIFT 4
364
365
#define TLBPGMASK_MASK 0x01ffe000
366
#endif
367
368
#if __mips == 32
369
#define N_TLB_ENTRIES 16
370
371
372
373
374
375
376
377
/* writeable */
378
/* valid bit */
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
#endif
402
403
#if __mips == 1
404
405
406
/* definitions for Debug and Cache Invalidate control (DCIC) register bits */
407
#define DCIC_TR 0x80000000
/* Trap enable */
408
#define DCIC_UD 0x40000000
/* User debug enable */
409
#define DCIC_KD 0x20000000
/* Kernel debug enable */
410
#define DCIC_TE 0x10000000
/* Trace enable */
411
#define DCIC_DW 0x08000000
/* Enable data breakpoints on write */
412
#define DCIC_DR 0x04000000
/* Enable data breakpoints on read */
413
#define DCIC_DAE 0x02000000
/* Enable data addresss breakpoints */
414
#define DCIC_PCE 0x01000000
/* Enable instruction breakpoints */
415
#define DCIC_DE 0x00800000
/* Debug enable */
416
#define DCIC_DL 0x00008000
/* Data cache line invalidate */
417
#define DCIC_IL 0x00004000
/* Instruction cache line invalidate */
418
#define DCIC_D 0x00002000
/* Data cache invalidate enable */
419
#define DCIC_I 0x00001000
/* Instr. cache invalidate enable */
420
#define DCIC_T 0x00000020
/* Trace, set by CPU */
421
#define DCIC_W 0x00000010
/* Write reference, set by CPU */
422
#define DCIC_R 0x00000008
/* Read reference, set by CPU */
423
#define DCIC_DA 0x00000004
/* Data address, set by CPU */
424
#define DCIC_PC 0x00000002
/* Program counter, set by CPU */
425
#define DCIC_DB 0x00000001
/* Debug, set by CPU */
426
427
428
429
430
#define SR_CUMASK 0xf0000000
/* coproc usable bits */
431
#define SR_CU3 0x80000000
/* Coprocessor 3 usable */
432
#define SR_CU2 0x40000000
/* Coprocessor 2 usable */
433
#define SR_CU1 0x20000000
/* Coprocessor 1 usable */
434
#define SR_CU0 0x10000000
/* Coprocessor 0 usable */
435
436
#define SR_BEV 0x00400000
/* use boot exception vectors */
437
438
/* Cache control bits */
439
#define SR_TS 0x00200000
/* TLB shutdown */
440
#define SR_PE 0x00100000
/* cache parity error */
441
#define SR_CM 0x00080000
/* cache miss */
442
#define SR_PZ 0x00040000
/* cache parity zero */
443
#define SR_SWC 0x00020000
/* swap cache */
444
#define SR_ISC 0x00010000
/* Isolate data cache */
445
446
447
** status register interrupt masks and bits
448
449
450
#define SR_IMASK 0x0000ff00
/* Interrupt mask */
451
#define SR_IMASK8 0x00000000
/* mask level 8 */
452
#define SR_IMASK7 0x00008000
/* mask level 7 */
453
#define SR_IMASK6 0x0000c000
/* mask level 6 */
454
#define SR_IMASK5 0x0000e000
/* mask level 5 */
455
#define SR_IMASK4 0x0000f000
/* mask level 4 */
456
#define SR_IMASK3 0x0000f800
/* mask level 3 */
457
#define SR_IMASK2 0x0000fc00
/* mask level 2 */
458
#define SR_IMASK1 0x0000fe00
/* mask level 1 */
459
#define SR_IMASK0 0x0000ff00
/* mask level 0 */
460
461
#define SR_IMASKSHIFT 8
462
463
#define SR_IBIT8 0x00008000
/* bit level 8 */
464
#define SR_IBIT7 0x00004000
/* bit level 7 */
465
#define SR_IBIT6 0x00002000
/* bit level 6 */
466
#define SR_IBIT5 0x00001000
/* bit level 5 */
467
#define SR_IBIT4 0x00000800
/* bit level 4 */
468
#define SR_IBIT3 0x00000400
/* bit level 3 */
469
#define SR_IBIT2 0x00000200
/* bit level 2 */
470
#define SR_IBIT1 0x00000100
/* bit level 1 */
471
472
#define SR_KUO 0x00000020
/* old kernel/user, 0 => k, 1 => u */
473
#define SR_IEO 0x00000010
/* old interrupt enable, 1 => enable */
474
#define SR_KUP 0x00000008
/* prev kernel/user, 0 => k, 1 => u */
475
#define SR_IEP 0x00000004
/* prev interrupt enable, 1 => enable */
476
#define SR_KUC 0x00000002
/* cur kernel/user, 0 => k, 1 => u */
477
#define SR_IEC 0x00000001
/* cur interrupt enable, 1 => enable */
478
#endif
479
480
#if __mips == 3
481
482
483
484
485
486
487
#define SR_RP 0x08000000
/* Reduced power operation */
488
#define SR_FR 0x04000000
/* Additional floating point registers */
489
#define SR_RE 0x02000000
/* Reverse endian in user mode */
490
491
/* Use boot exception vectors */
492
/* TLB shutdown */
493
#define SR_SR 0x00100000
/* Soft reset */
494
#define SR_CH 0x00040000
/* Cache hit */
495
#define SR_CE 0x00020000
/* Use cache ECC */
496
#define SR_DE 0x00010000
/* Disable cache exceptions */
497
498
499
500
501
502
503
/* mask level 8 */
504
/* mask level 7 */
505
/* mask level 6 */
506
/* mask level 5 */
507
/* mask level 4 */
508
/* mask level 3 */
509
/* mask level 2 */
510
/* mask level 1 */
511
/* mask level 0 */
512
513
514
515
/* bit level 8 */
516
/* bit level 7 */
517
/* bit level 6 */
518
/* bit level 5 */
519
/* bit level 4 */
520
/* bit level 3 */
521
/* bit level 2 */
522
/* bit level 1 */
523
524
#define SR_KSMASK 0x00000018
/* Kernel mode mask */
525
#define SR_KSUSER 0x00000010
/* User mode */
526
#define SR_KSSUPER 0x00000008
/* Supervisor mode */
527
#define SR_KSKERNEL 0x00000000
/* Kernel mode */
528
#define SR_ERL 0x00000004
/* Error level */
529
#define SR_EXL 0x00000002
/* Exception level */
530
#define SR_IE 0x00000001
/* Interrupts enabled */
531
#endif
532
533
#if __mips == 32
534
535
536
537
538
539
540
541
542
543
544
545
/* TLB shutdown */
546
/* Soft reset */
547
/* Cache hit */
548
/* Use cache ECC */
549
550
551
552
553
554
555
556
/* mask level 8 */
557
/* mask level 7 */
558
/* mask level 6 */
559
/* mask level 5 */
560
/* mask level 4 */
561
/* mask level 3 */
562
/* mask level 2 */
563
/* mask level 1 */
564
/* mask level 0 */
565
566
567
568
/* bit level 8 */
569
/* bit level 7 */
570
/* bit level 6 */
571
/* bit level 5 */
572
/* bit level 4 */
573
/* bit level 3 */
574
/* bit level 2 */
575
/* bit level 1 */
576
577
578
/* User mode */
579
580
/* Kernel mode */
581
/* Error level */
582
583
584
#endif
585
586
587
* Cause Register
588
589
#define CAUSE_BD 0x80000000
/* Branch delay slot */
590
#define CAUSE_BT 0x40000000
/* Branch Taken */
591
#define CAUSE_CEMASK 0x30000000
/* coprocessor error */
592
#define CAUSE_CESHIFT 28
593
594
595
#define CAUSE_IPMASK 0x0000FF00
/* Pending interrupt mask */
596
#define CAUSE_IPSHIFT 8
597
598
#define CAUSE_EXCMASK 0x0000003C
/* Cause code bits */
599
#define CAUSE_EXCSHIFT 2
600
601
#ifndef XDS
602
603
** Coprocessor 0 registers
604
605
#define C0_INX $0
/* tlb index */
606
#define C0_RAND $1
/* tlb random */
607
#if __mips == 1
608
#define C0_TLBLO $2
/* tlb entry low */
609
#endif
610
#if __mips == 3
611
#define C0_TLBLO0 $2
/* tlb entry low 0 */
612
#define C0_TLBLO1 $3
/* tlb entry low 1 */
613
#endif
614
615
#if __mips == 32
616
617
618
#endif
619
620
621
#define C0_CTXT $4
/* tlb context */
622
623
#if __mips == 3
624
#define C0_PAGEMASK $5
/* tlb page mask */
625
#define C0_WIRED $6
/* number of wired tlb entries */
626
#endif
627
628
#if __mips == 32
629
/* tlb page mask */
630
#define C0_WIRED $6
631
#endif
632
633
#if __mips == 1
634
#define C0_TAR $6
635
#endif
636
637
#define C0_BADVADDR $8
/* bad virtual address */
638
639
#if __mips == 3
640
#define C0_COUNT $9
/* cycle count */
641
#endif
642
#if __mips == 32
643
#define C0_COUNT $9
/* cycle count */
644
#endif
645
646
#define C0_TLBHI $10
/* tlb entry hi */
647
648
#if __mips == 3
649
#define C0_COMPARE $11
/* cyccle count comparator */
650
#endif
651
652
#if __mips == 32
653
654
#endif
655
656
#define C0_SR $12
/* status register */
657
#define C0_CAUSE $13
/* exception cause */
658
#define C0_EPC $14
/* exception pc */
659
#define C0_PRID $15
/* revision identifier */
660
661
#if __mips == 1
662
#define C0_CONFIG $3
/* configuration register R3081*/
663
#endif
664
665
#if __mips == 3
666
#define C0_CONFIG $16
/* configuration register */
667
#define C0_LLADDR $17
/* linked load address */
668
#define C0_WATCHLO $18
/* watchpoint trap register */
669
#define C0_WATCHHI $19
670
#define C0_XCTXT $20
/* extended tlb context */
671
#define C0_ECC $26
/* secondary cache ECC control */
672
#define C0_CACHEERR $27
/* cache error status */
673
#define C0_TAGLO $28
/* cache tag lo */
674
#define C0_TAGHI $29
/* cache tag hi */
675
#define C0_ERRPC $30
/* cache error pc */
676
#endif
677
678
#if __mips == 32
679
680
681
682
683
684
#define C0_ECC $26
685
686
/* cache tag lo */
687
/* cache tag hi */
688
689
#endif
690
691
692
#define C1_REVISION $0
693
#define C1_STATUS $31
694
695
#endif
/* XDS */
696
697
#ifdef R4650
698
#define IWATCH $18
699
#define DWATCH $19
700
#define IBASE $0
701
#define IBOUND $1
702
#define DBASE $2
703
#define DBOUND $3
704
#define CALG $17
705
#endif
706
708
#endif
/* _RTEMS_MIPS_IDTCPU_H */
