RTEMS
6.3
Toggle main menu visibility
bsps
mips
include
bsp
i8259.h
1
6
7
/* irq.h
8
9
* This include file describe the data structure and the functions implemented
10
* by RTEMS to control the i8259 chip.
11
12
* Copyright (C) 1999 valette@crf.canon.fr
13
14
* This code is heavilly inspired by the public specification of STREAM V2
15
* that can be found at :
16
17
* <http://www.chorus.com/Documentation/index.html> by following
18
* the STREAM API Specification Document link.
19
20
* The license and distribution terms for this file may be
21
* found in the file LICENSE in this distribution or at
22
* http://www.rtems.org/license/LICENSE.
23
24
25
#ifndef I8259_H
26
#define I8259_H
27
34
39
40
#if 1
41
#define ISA8259_M_ELCR 0x4d0
42
#define ISA8259_S_ELCR 0x4d1
43
#endif
44
45
#define ELCRS_INT15_LVL 0x80
46
#define ELCRS_INT14_LVL 0x40
47
#define ELCRS_INT13_LVL 0x20
48
#define ELCRS_INT12_LVL 0x10
49
#define ELCRS_INT11_LVL 0x08
50
#define ELCRS_INT10_LVL 0x04
51
#define ELCRS_INT9_LVL 0x02
52
#define ELCRS_INT8_LVL 0x01
53
#define ELCRM_INT7_LVL 0x80
54
#define ELCRM_INT6_LVL 0x40
55
#define ELCRM_INT5_LVL 0x20
56
#define ELCRM_INT4_LVL 0x10
57
#define ELCRM_INT3_LVL 0x8
58
#define ELCRM_INT2_LVL 0x4
59
#define ELCRM_INT1_LVL 0x2
60
#define ELCRM_INT0_LVL 0x1
61
63
68
69
#define PIC_MASTER_COMMAND_IO_PORT 0x20
70
#define PIC_SLAVE_COMMAND_IO_PORT 0xa0
71
#define PIC_MASTER_IMR_IO_PORT 0x21
72
#define PIC_SLAVE_IMR_IO_PORT 0xa1
73
75
80
81
#define PIC_EOSI 0x60
82
#define SLAVE_PIC_EOSI 0x62
83
#define PIC_EOI 0x20
84
86
87
#ifndef ASM
88
89
#ifdef __cplusplus
90
extern
"C"
91
#endif
92
93
94
* rtems_irq_number Definitions
95
96
#if 0
97
102
103
#define BSP_ISA_IRQ_NUMBER (16)
104
#define BSP_ISA_IRQ_LOWEST_OFFSET (0)
105
#define BSP_ISA_IRQ_MAX_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET + BSP_ISA_IRQ_NUMBER - 1)
106
108
109
#ifndef qemu
110
#define BSP_PCI_IRQ_NUMBER (16)
111
#else
112
#define BSP_PCI_IRQ_NUMBER (0)
113
#endif
114
#define BSP_PCI_IRQ_LOWEST_OFFSET (BSP_ISA_IRQ_NUMBER)
115
#define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
116
117
118
* PowerPC exceptions handled as interrupt where an RTEMS managed interrupt
119
* handler might be connected
120
121
#define BSP_PROCESSOR_IRQ_NUMBER (1)
122
#define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_MAX_OFFSET + 1)
123
#define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
124
/* Misc vectors for OPENPIC irqs (IPI, timers)
125
126
#ifndef qemu
127
#define BSP_MISC_IRQ_NUMBER (8)
128
#else
129
#define BSP_MISC_IRQ_NUMBER (0)
130
#endif
131
132
#define BSP_MISC_IRQ_LOWEST_OFFSET (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
133
#define BSP_MISC_IRQ_MAX_OFFSET (BSP_MISC_IRQ_LOWEST_OFFSET + BSP_MISC_IRQ_NUMBER - 1)
134
139
140
#define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
141
#define BSP_LOWEST_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET)
142
#define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
143
145
150
151
#define BSP_ISA_PERIODIC_TIMER (0)
152
#define BSP_ISA_KEYBOARD (1)
153
#define BSP_ISA_UART_COM2_IRQ (3)
154
#define BSP_ISA_UART_COM1_IRQ (4)
155
#define BSP_ISA_RT_TIMER1 (8)
156
#define BSP_ISA_RT_TIMER3 (10)
157
159
164
165
#define BSP_PCI_IRQ0 (BSP_PCI_IRQ_LOWEST_OFFSET)
166
#if BSP_PCI_IRQ_NUMBER > 0
167
#define BSP_PCI_ISA_BRIDGE_IRQ (BSP_PCI_IRQ0)
168
#endif
169
171
172
#if defined(mot_ppc_mvme2100)
173
#define BSP_DEC21143_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
174
#define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
175
#define BSP_PCMIP_TYPE1_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
176
#define BSP_PCMIP_TYPE2_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 4)
177
#define BSP_PCMIP_TYPE2_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 5)
178
#define BSP_PCI_INTA_UNIVERSE_LINT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 7)
179
#define BSP_PCI_INTB_UNIVERSE_LINT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 8)
180
#define BSP_PCI_INTC_UNIVERSE_LINT2_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 9)
181
#define BSP_PCI_INTD_UNIVERSE_LINT3_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 10)
182
#define BSP_UART_COM1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 13)
183
#define BSP_FRONT_PANEL_ABORT_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 14)
184
#define BSP_RTC_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 15)
185
#else
186
#define BSP_UART_COM1_IRQ BSP_ISA_UART_COM1_IRQ
187
#define BSP_UART_COM2_IRQ BSP_ISA_UART_COM2_IRQ
188
#endif
189
193
#define BSP_DECREMENTER (BSP_PROCESSOR_IRQ_LOWEST_OFFSET)
194
#endif
195
200
201
typedef
unsigned
short
rtems_i8259_masks
202
extern
volatile
rtems_i8259_masks
i8259s_cache;
203
205
206
207
| Function Prototypes.
208
209
210
* ------------------------ Intel 8259 (or emulation) Mngt Routines -------
211
212
217
218
void
BSP_i8259s_init(
void
219
230
int
BSP_irq_disable_at_i8259s
const
rtems_irq_number irqLine);
231
238
int
BSP_irq_enable_at_i8259s
const
239
248
int
BSP_irq_ack_at_i8259s
const
249
253
int
BSP_irq_enabled_at_i8259s
const
254
255
int
BSP_i8259s_int_process(
void
256
257
extern
void
BSP_rtems_irq_mng_init(
unsigned
cpuId);
258
extern
void
BSP_i8259s_init(
void
259
261
263
264
#ifdef __cplusplus
265
266
#endif
267
268
#endif
269
#endif
rtems_i8259_masks
unsigned short rtems_i8259_masks
Type definition for RTEMS managed interrupts.
Definition
irq.h:89
int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
function to enable a particular irq at 8259 level.
Definition
i8259.c:91
int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
function to disable a particular irq at 8259 level.
Definition
i8259.c:49
int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
function to acknowledge a particular irq at 8259 level.
Definition
i8259.c:143
int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
function to check if a particular irq is enabled at 8259 level.
Definition
i8259.c:125
