RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
gen83xx
include
bsp
hwreg_vals.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS generic MPC83xx BSP
5
6
* This file contains board specific definitions.
7
8
9
10
* Copyright (c) 2007 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __GEN83xx_HWREG_VALS_h
35
#define __GEN83xx_HWREG_VALS_h
36
37
#include <mpc83xx/mpc83xx.h>
38
#include <bsp.h>
39
40
#ifdef MPC83XX_HAS_NAND_LP_FLASH_ON_CS0
41
#define MPC83XX_RCWHR_BOOT_DEVICE (RCWHR_ROMLOC_LB08 | RCWHR_RLEXT_NAND)
42
#else
43
#define MPC83XX_RCWHR_BOOT_DEVICE (RCWHR_ROMLOC_LB16 | RCWHR_RLEXT_LGCY)
44
#endif
45
46
47
* distinguish board characteristics
48
49
#if defined(MPC83XX_BOARD_MPC8349EAMDS)
50
51
* for Freescale MPC8349 EAMDS
52
53
54
* two DUART channels supported
55
56
#define GEN83xx_DUART_AVAIL_MASK 0x03
57
58
/* we need the low level initialization in start.S*/
59
#define NEED_LOW_LEVEL_INIT
60
61
* clocking infos
62
63
#define BSP_CLKIN_FRQ 66000000L
64
#define RCFG_SYSPLL_MF 4
65
#define RCFG_COREPLL_MF 4
66
67
68
* Reset configuration words
69
70
#define RESET_CONF_WRD_L (RCWLR_LBIUCM_1_1 | \
71
RCWLR_DDRCM_1_1 | \
72
RCWLR_SPMF(RCFG_SYSPLL_MF) | \
73
RCWLR_COREPLL(RCFG_COREPLL_MF))
74
75
#define RESET_CONF_WRD_H (RCWHR_PCI_HOST | \
76
RCWHR_PCI_32 | \
77
RCWHR_PCI1ARB_EN | \
78
RCWHR_PCI2ARB_EN | \
79
RCWHR_CORE_EN | \
80
RCWHR_BMS_LOW | \
81
RCWHR_BOOTSEQ_NONE | \
82
RCWHR_SW_DIS | \
83
MPC83XX_RCWHR_BOOT_DEVICE | \
84
RCWHR_TSEC1M_GMII | \
85
RCWHR_TSEC2M_GMII | \
86
RCWHR_ENDIAN_BIG | \
87
RCWHR_LALE_NORM | \
88
RCWHR_LDP_PAR)
89
#elif defined(MPC83XX_BOARD_HSC_CM01)
90
91
* for JPK HSC_CM01
92
93
94
* one DUART channel (UART1) supported
95
96
#define GEN83xx_DUART_AVAIL_MASK 0x01
97
98
99
100
101
* clocking infos
102
103
#define BSP_CLKIN_FRQ 30000000L
104
#define RCFG_SYSPLL_MF 11
105
106
107
108
109
110
RCWLR_DDRCM_1_1 | \
111
112
113
114
115
RCWHR_PCI_32 | \
116
RCWHR_PCI1ARB_DIS | \
117
RCWHR_PCI2ARB_DIS | \
118
RCWHR_CORE_EN | \
119
RCWHR_BMS_LOW | \
120
121
RCWHR_SW_DIS | \
122
123
RCWHR_TSEC1M_RGMII | \
124
125
126
RCWHR_LALE_EARLY | \
127
RCWHR_LDP_SPC)
128
129
#elif defined(MPC83XX_BOARD_BR_UID)
130
131
* for BR UID
132
133
134
135
136
137
138
139
140
141
* clocking infos
142
143
#define BSP_CLKIN_FRQ 25000000L
144
#define RCFG_SYSPLL_MF 5
145
#define RCFG_COREPLL_MF 5
146
147
148
149
#define RESET_CONF_WRD_L \
150
(RCWLR_LBIUCM_1_1 \
151
| RCWLR_DDRCM_2_1 \
152
| RCWLR_SPMF(RCFG_SYSPLL_MF) \
153
| RCWLR_COREPLL(RCFG_COREPLL_MF) \
154
| RCWLR_CEVCOD_1_2 \
155
| RCWLR_CEPMF(8) \
156
157
158
159
RCWHR_PCI_32 | \
160
161
RCWHR_CORE_EN | \
162
RCWHR_BMS_LOW | \
163
164
RCWHR_SW_DIS | \
165
166
RCWHR_ENDIAN_BIG)
167
168
#elif defined( HAS_UBOOT)
169
170
/* TODO */
171
172
#else
173
174
#error "board type not defined"
175
176
#endif
177
178
179
180
* for Freescale MPC83XX_BOARD_MPC8349EAMDS
181
182
183
184
* working values for various registers, used in start/start.S
185
186
187
188
* Local Access Windows
189
* FIXME: decode bit settings
190
191
#define LBLAWBAR0_VAL 0xFE000000
192
#define LBLAWAR0_VAL 0x80000016
193
#define LBLAWBAR1_VAL 0xF8000000
194
#define LBLAWAR1_VAL 0x8000000E
195
#define LBLAWBAR2_VAL 0xF0000000
196
#define LBLAWAR2_VAL 0x80000019
197
#define DDRLAWBAR0_VAL 0x00000000
198
#define DDRLAWAR0_VAL 0x8000001B
199
200
* Local Bus (Memory) Controller
201
202
203
#define BR0_VAL 0xFE001001
204
#define OR0_VAL 0xFF806FF7
205
#define BR1_VAL 0xF8000801
206
#define OR1_VAL 0xFFFFE8F0
207
#define BR2_VAL 0xF0001861
208
#define OR2_VAL 0xFC006901
209
210
* SDRAM registers
211
212
213
#define MRPTR_VAL 0x20000000
214
#define LSRT_VAL 0x32000000
215
#define LSDMR_VAL 0x4062D733
216
#define LCRR_VAL 0x80000004
217
218
219
* DDR-SDRAM registers
220
221
222
#define CS2_BNDS_VAL 0x00000007
223
#define CS3_BNDS_VAL 0x0008000F
224
#define CS2_CONFIG_VAL 0x80000101
225
#define CS3_CONFIG_VAL 0x80000101
226
#define TIMING_CFG_1_VAL 0x36333321
227
#define TIMING_CFG_2_VAL 0x00000800
228
#define DDR_SDRAM_CFG_VAL 0xC2000000
229
#define DDR_SDRAM_MODE_VAL 0x00000022
230
#define DDR_SDRAM_INTTVL_VAL 0x045B0100
231
#define DDR_SDRAM_CLK_CNTL_VAL 0x00000000
232
233
234
235
* for JPK HSC_CM01
236
237
238
239
240
241
242
/* fpga config 16 MB size */
243
#define FPGA_CONFIG_START 0xF8000000
244
#define FPGA_CONFIG_SIZE 0x01000000
245
/* fpga register 8 MB size */
246
#define FPGA_REGISTER_START 0xF9000000
247
#define FPGA_REGISTER_SIZE 0x00800000
248
/* fpga fifo 8 MB size */
249
#define FPGA_FIFO_START 0xF9800000
250
#define FPGA_FIFO_SIZE 0x00800000
251
252
#define FPGA_START (FPGA_CONFIG_START)
253
// fpga window size 32 MByte
254
#define FPGA_SIZE (0x02000000)
255
#define FPGA_END (FPGA_START+FPGA_SIZE-1)
256
257
258
259
260
261
262
#define LBLAWBAR0_VAL bsp_rom_start
263
#define LBLAWAR0_VAL 0x80000018
264
#define LBLAWBAR1_VAL (FPGA_CONFIG_START)
265
#define LBLAWAR1_VAL 0x80000018
266
#define DDRLAWBAR0_VAL bsp_ram_start
267
268
269
270
271
272
#define BR0_VAL (0xFE000000 | 0x01001)
273
#define OR0_VAL 0xFE000E54
274
// fpga config access range (UPM_A) (32 kByte)
275
#define BR2_VAL (FPGA_CONFIG_START | 0x01881)
276
#define OR2_VAL 0xFFFF9100
277
278
// fpga register access range (UPM_B) (8 MByte)
279
#define BR3_VAL (FPGA_REGISTER_START | 0x018A1)
280
#define OR3_VAL 0xFF801100
281
282
// fpga fifo access range (UPM_C) (8 MByte)
283
#define BR4_VAL (FPGA_FIFO_START | 0x018C1)
284
#define OR4_VAL 0xFF801100
285
286
287
* SDRAM registers
288
289
290
291
292
#define LCRR_VAL 0x80010004
293
294
295
296
297
298
#define DDRCDR_VAL 0x00000001
299
#define CS0_BNDS_VAL 0x0000000F
300
#define CS0_CONFIG_VAL 0x80810102
301
#define TIMING_CFG_0_VAL 0x00420802
302
#define TIMING_CFG_1_VAL 0x3735A322
303
#define TIMING_CFG_2_VAL 0x2F9044C7
304
#define DDR_SDRAM_CFG_2_VAL 0x00401000
305
#define DDR_SDRAM_MODE_VAL 0x44521632
306
#define DDR_SDRAM_CLK_CNTL_VAL 0x01800000
307
#define DDR_SDRAM_CFG_VAL 0x63000008
308
309
#define DDR_ERR_DISABLE_VAL 0x0000008D
310
#define DDR_ERR_DISABLE_VAL2 0x00000089
311
#define DDR_SDRAM_DATA_INIT_VAL 0xC01DCAFE
312
#define DDR_SDRAM_INIT_ADDR_VAL 0
313
#define DDR_SDRAM_INTERVAL_VAL 0x05080000
314
315
316
317
* for BR UID
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
* clocking for local bus:
337
* ALE active for 1 clock
338
* local bus clock = 1/2 csb clock
339
340
#define LCRR_VAL 0x80010002
341
342
343
344
345
346
347
348
#define CS0_CONFIG_VAL 0x80014202
349
#define TIMING_CFG_0_VAL 0x00220802
350
#define TIMING_CFG_1_VAL 0x26259222
351
#define TIMING_CFG_2_VAL 0x111048C7
352
353
#define DDR_SDRAM_MODE_VAL 0x200F1632
354
#define DDR_SDRAM_MODE_2_VAL 0x40006000
355
356
#define DDR_SDRAM_CFG_VAL 0x43100008
357
358
359
360
361
362
#define DDR_SDRAM_INTERVAL_VAL 0x01E8222E
363
364
365
366
/* TODO */
367
368
#else
369
370
371
372
#endif
373
374
375
* derived values for all boards
376
377
/* value of input clock divider (derived from pll mode reg) */
378
#if MPC83XX_CHIP_TYPE != 8309
379
#define BSP_SYSPLL_CKID (((mpc83xx.clk.spmr>>(31-8))&0x01)+1)
380
#else
381
/* On the MPC8309 this bit is reserved */
382
#define BSP_SYSPLL_CKID 1
383
#endif
384
/* value of system pll (derived from pll mode reg) */
385
#define BSP_SYSPLL_MF ((mpc83xx.clk.spmr>>(31-7))&0x0f)
386
387
#define BSP_COREPLL_MF ((mpc83xx.clk.spmr>>(31-15))&0x7f)
388
389
#endif
/* __GEN83xx_HWREG_VALS_h */
