RTEMS
6.3
Toggle main menu visibility
compression
zlib
gzguts.h
1
/* gzguts.h -- zlib internal header definitions for gz* operations
2
* Copyright (C) 2004-2019 Mark Adler
3
* For conditions of distribution and use, see copyright notice in zlib.h
4
5
6
#ifdef _LARGEFILE64_SOURCE
7
# ifndef _LARGEFILE_SOURCE
8
# define _LARGEFILE_SOURCE 1
9
# endif
10
# ifdef _FILE_OFFSET_BITS
11
# undef _FILE_OFFSET_BITS
12
# endif
13
#endif
14
15
#ifdef HAVE_HIDDEN
16
# define ZLIB_INTERNAL __attribute__((visibility ("hidden")))
17
#else
18
19
#endif
20
21
#include "zlib.h"
23
#ifdef STDC
24
# include <string.h>
25
# include <stdlib.h>
26
# include <limits.h>
27
#endif
28
29
#ifndef _POSIX_SOURCE
30
# define _POSIX_SOURCE
31
#endif
32
#include <fcntl.h>
33
34
#ifdef _WIN32
35
# include <stddef.h>
36
#endif
37
38
#if defined(__TURBOC__) || defined(_MSC_VER) || defined(_WIN32)
39
# include <io.h>
40
#endif
41
42
#if defined(_WIN32)
43
# define WIDECHAR
44
#endif
45
46
#ifdef WINAPI_FAMILY
47
# define open _open
48
# define read _read
49
# define write _write
50
# define close _close
51
#endif
52
53
#ifdef NO_DEFLATE
/* for compatibility with old definition */
54
# define NO_GZCOMPRESS
55
#endif
56
57
#if defined(STDC99) || (defined(__TURBOC__) && __TURBOC__ >= 0x550)
58
# ifndef HAVE_VSNPRINTF
59
# define HAVE_VSNPRINTF
60
# endif
61
#endif
62
63
#if defined(__CYGWIN__)
64
65
66
# endif
67
#endif
68
69
#if defined(MSDOS) && defined(__BORLANDC__) && (BORLANDC > 0x410)
70
71
72
# endif
73
#endif
74
75
#ifndef HAVE_VSNPRINTF
76
# ifdef MSDOS
77
/* vsnprintf may exist on some MS-DOS compilers (DJGPP?),
78
but for now we just assume it doesn't. */
79
# define NO_vsnprintf
80
# endif
81
# ifdef __TURBOC__
82
83
# endif
84
# ifdef WIN32
85
/* In Win32, vsnprintf is available as the "non-ANSI" _vsnprintf. */
86
# if !defined(vsnprintf) && !defined(NO_vsnprintf)
87
# if !defined(_MSC_VER) || ( defined(_MSC_VER) && _MSC_VER < 1500 )
88
# define vsnprintf _vsnprintf
89
# endif
90
# endif
91
# endif
92
# ifdef __SASC
93
94
# endif
95
# ifdef VMS
96
97
# endif
98
# ifdef __OS400__
99
100
# endif
101
# ifdef __MVS__
102
103
# endif
104
#endif
105
106
/* unlike snprintf (which is required in C99), _snprintf does not guarantee
107
null termination of the result -- however this is only used in gzlib.c where
108
the result is assured to fit in the space provided */
109
#if defined(_MSC_VER) && _MSC_VER < 1900
110
# define snprintf _snprintf
111
#endif
112
113
#ifndef local
114
# define local static
115
#endif
116
/* since "static" is used to mean two completely different things in C, we
117
define "local" for the non-static meaning of "static", for readability
118
(compile with -Dlocal if your debugger can't find static symbols) */
119
120
/* gz* functions always use library allocation functions */
121
#ifndef STDC
122
extern
voidp malloc OF((uInt size));
123
extern
void
free OF((voidpf ptr));
124
#endif
125
126
/* get errno and strerror definition */
127
#if defined UNDER_CE
128
# include <windows.h>
129
# define zstrerror() gz_strwinerror((DWORD)GetLastError())
130
#else
131
# ifndef NO_STRERROR
132
# include <errno.h>
133
# define zstrerror() strerror(errno)
134
# else
135
# define zstrerror() "stdio error (consult errno)"
136
# endif
137
#endif
138
139
/* provide prototypes for these when building zlib without LFS */
140
#if !defined(_LARGEFILE64_SOURCE) || _LFS64_LARGEFILE-0 == 0
141
ZEXTERN gzFile ZEXPORT gzopen64 OF((
const
char
const
char
142
ZEXTERN z_off64_t ZEXPORT gzseek64 OF((gzFile, z_off64_t,
int
143
ZEXTERN z_off64_t ZEXPORT gztell64 OF((gzFile));
144
ZEXTERN z_off64_t ZEXPORT gzoffset64 OF((gzFile));
145
#endif
146
147
/* default memLevel */
148
#if MAX_MEM_LEVEL >= 8
149
# define DEF_MEM_LEVEL 8
150
#else
151
# define DEF_MEM_LEVEL MAX_MEM_LEVEL
152
#endif
153
154
/* default i/o buffer size -- double this for output when reading (this and
155
twice this must be able to fit in an unsigned type) */
156
#define GZBUFSIZE 8192
157
158
/* gzip modes, also provide a little integrity check on the passed structure */
159
#define GZ_NONE 0
160
#define GZ_READ 7247
161
#define GZ_WRITE 31153
162
#define GZ_APPEND 1
/* mode set to GZ_WRITE after the file is opened */
163
164
/* values for gz_state how */
165
#define LOOK 0
/* look for a gzip header */
166
#define COPY 1
/* copy input directly */
167
#define GZIP 2
/* decompress a gzip stream */
168
169
/* internal gzip file state data structure */
170
typedef
struct
171
/* exposed contents for gzgetc() macro */
172
struct
gzFile_s
x;
/* "x" for exposed */
173
/* x.have: number of bytes available at x.next */
174
/* x.next: next output data to deliver or write */
175
/* x.pos: current position in uncompressed data */
176
/* used for both reading and writing */
177
int
mode;
/* see gzip modes above */
178
int
fd;
/* file descriptor */
179
char
*path;
/* path or fd for error messages */
180
unsigned
size;
/* buffer size, zero if not allocated yet */
181
unsigned
want;
/* requested buffer size, default is GZBUFSIZE */
182
unsigned
char
*in;
/* input buffer (double-sized when writing) */
183
unsigned
char
*out;
/* output buffer (double-sized when reading) */
184
int
direct;
/* 0 if processing gzip, 1 if transparent */
185
/* just for reading */
186
int
how;
/* 0: get header, 1: copy, 2: decompress */
187
z_off64_t start;
/* where the gzip data started, for rewinding */
188
int
eof;
/* true if end of input file reached */
189
int
past;
/* true if read requested past end */
190
/* just for writing */
191
int
level;
/* compression level */
192
int
strategy;
/* compression strategy */
193
int
reset;
/* true if a reset is pending after a Z_FINISH */
194
/* seek request */
195
z_off64_t skip;
/* amount to skip (already rewound if backwards) */
196
int
seek;
/* true if seek request pending */
197
/* error information */
198
int
err;
/* error code */
199
char
*msg;
/* error message */
200
/* zlib inflate or deflate stream */
201
z_stream strm;
/* stream structure in-place (not a pointer) */
202
gz_state
203
typedef
gz_state
FAR *gz_statep;
204
205
/* shared functions */
206
void
ZLIB_INTERNAL gz_error OF((gz_statep,
int
const
char
207
208
char
ZLIB_INTERNAL *gz_strwinerror OF((DWORD error));
209
#endif
210
211
/* GT_OFF(x), where x is an unsigned value, is true if x > maximum z_off64_t
212
value -- needed when comparing unsigned to z_off64_t, which is signed
213
(possible z_off64_t types off_t, off64_t, and long are all signed) */
214
#ifdef INT_MAX
215
# define GT_OFF(x) (sizeof(int) == sizeof(z_off64_t) && (x) > INT_MAX)
216
#else
217
unsigned
ZLIB_INTERNAL gz_intmax OF((
void
218
# define GT_OFF(x) (sizeof(int) == sizeof(z_off64_t) && (x) > gz_intmax())
219
#endif
gzFile_s
Definition
zlib.h:1834
gz_state
Definition
gzguts.h:170
