RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
grpwm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* GRPWM PWM Driver interface.
5
6
* COPYRIGHT (c) 2009.
7
* Cobham Gaisler AB.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
18
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28
* POSSIBILITY OF SUCH DAMAGE.
29
30
31
#ifndef __GRPWM_H__
32
#define __GRPWM_H__
33
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
37
38
extern
void
grpwm_register_drv (
void
39
40
#define GRPWM_IOCTL_GET_CAP 1
/* Get Capabilities */
41
#define GRPWM_IOCTL_SET_CONFIG 2
/* Configure one PWM Channel */
42
#define GRPWM_IOCTL_SET_SCALER 3
/* Set one scaler */
43
#define GRPWM_IOCTL_UPDATE 4
/* Set current period and compare value */
44
#define GRPWM_IOCTL_IRQ 5
/* Set up IRQ handling */
45
46
/*** Argument for GRPWM_IOCTL_GET_CAP ***/
47
48
/* The Capability of the PWM core */
49
struct
grpwm_ioctl_cap
50
int
channel_cnt;
/* Number of channels */
51
unsigned
int
pwm;
/* Capability1 register */
52
unsigned
int
wave;
/* Capability2 register, Wave form capabilities of last PWM channel, otherwise 0 */
53
54
55
/*** Argument for GRPWM_IOCTL_GET_CONFIG and GRPWM_IOCTL_SET_CONFIG ***/
56
57
/* Config One PWM */
58
struct
grpwm_ioctl_config
59
unsigned
int
channel;
/* Select channel to configure */
60
61
/* Specific for one PWM channel */
62
unsigned
int
options;
/* PWM options */
63
unsigned
char
dbscaler;
/* value greater than 15 disable Dead band */
64
unsigned
char
scaler_index;
/* Select scaler used by PWM channel */
65
66
/* IRQ Setup */
67
unsigned
char
irqscaler;
/* IRQ scaler */
68
void
*isr_arg;
/* Argument of IRQ handler */
69
void (*isr)(
int
channel,
void
*arg);
/* Interrupt service routine for this PWM Channel */
70
71
/* Waveform set up */
72
int
wave_activate;
/* Enables Waveform functionality */
73
unsigned
int
wave_synccfg;
/* Bits [29,30,31] is written into Wave-Config register */
74
unsigned
int
wave_sync;
/* Sets sync compare register */
75
unsigned
int
*wave_data;
/* If not NULL, the Wave RAM is filled with data */
76
unsigned
int
wave_data_length;
/* Length of Wave RAM Data, Also used for wstopaddr */
77
78
79
#define GRPWM_CONFIG_OPTION_FLIP 0x04000000
/* Set this to Flip PWM output pair */
80
#define GRPWM_CONFIG_OPTION_DEAD_BAND 0x00200000
/* Dead Band enable */
81
#define GRPWM_CONFIG_OPTION_SYMMETRIC 0x00000040
/* If not defined, asymmetric */
82
#define GRPWM_CONFIG_OPTION_ASYMMERTIC 0
83
#define GRPWM_CONFIG_OPTION_DUAL 0x00000020
/* Dual Compare Enable */
84
#define GRPWM_CONFIG_OPTION_PAIR 0x00000004
/* PWM Pair Enable */
85
#define GRPWM_CONFIG_OPTION_SINGLE 0x00000000
/* PWM Pair Disable */
86
#define GRPWM_CONFIG_OPTION_POLARITY_HIGH 0x00000002
/* PWM Polarity HIGH */
87
#define GRPWM_CONFIG_OPTION_POLARITY_LOW 0x00000000
/* PWM Polarity LOW */
88
89
#define GRPWM_CONFIG_OPTION_MASK ( \
90
GRPWM_CONFIG_OPTION_DEAD_BAND | GRPWM_CONFIG_OPTION_SYMMETRIC | \
91
GRPWM_CONFIG_OPTION_DUAL | GRPWM_CONFIG_OPTION_PAIR | \
92
GRPWM_CONFIG_OPTION_POLARITY_HIGH \
93
94
95
/*** Argument for GPPWM_IOCTL_SET_SCALER ***/
96
97
struct
grpwm_ioctl_scaler
98
unsigned
int
index_mask;
/* Scaler update index mask, bit 0 = Scaler 0, bit 1 = Scaler 1 */
99
unsigned
int
values[8];
/* Scaler update values, values[N] is stored into scaler N, if mask & 1<<N is set */
100
101
102
/*** Argument for GRPWM_IOCTL_UPDATE ***/
103
104
#define GRPWM_UPDATE_OPTION_ENABLE 0x01
/* Enable the PWM core */
105
#define GRPWM_UPDATE_OPTION_DISABLE 0x02
/* Disable the PWM core */
106
#define GRPWM_UPDATE_OPTION_PERIOD 0x04
/* Update period register */
107
#define GRPWM_UPDATE_OPTION_COMP 0x08
/* Update Compare register */
108
#define GRPWM_UPDATE_OPTION_DBCOMP 0x10
/* Update Dead band register */
109
#define GRPWM_UPDATE_OPTION_FIX 0x20
/* Update fix output pins (bypass PWM) */
110
111
/* FIX PIN bit-mask */
112
#define GRPWM_UPDATE_FIX_ENABLE 1
/* Enable force ouput */
113
#define GRPWM_UPDATE_FIX_DISABLE 0
/* Disable force ouput */
114
#define GRPWM_UPDATE_FIX_0_LOW 0
/* PIN 0 OUPUT: LOW */
115
#define GRPWM_UPDATE_FIX_0_HIGH 2
/* PIN 0 OUPUT: HIGH */
116
#define GRPWM_UPDATE_FIX_1_LOW 0
/* PIN 1 OUPUT: LOW */
117
#define GRPWM_UPDATE_FIX_1_HIGH 4
/* PIN 1 OUPUT: HIGH */
118
119
struct
grpwm_ioctl_update_chan
120
unsigned
int
options;
/* Select what is updated */
121
unsigned
int
period;
/* Period register content */
122
unsigned
int
compare;
/* Compare register content */
123
unsigned
int
dbcomp;
/* Dead band register content */
124
unsigned
char
fix;
/* Bit-mask that select output on one or two PWM
125
* output pins. Depends on PAIR config value.
126
127
128
struct
grpwm_ioctl_update
129
unsigned
char
chanmask;
/* Bit Mask select channels */
130
struct
channels[8];
131
132
133
/*** Argument for GPPWM_IOCTL_IRQ ***/
134
135
#define GRPWM_IRQ_DISABLE 0
/* Disable IRQ */
136
#define GRPWM_IRQ_PERIOD 1
/* Enable IRQ on period match */
137
#define GRPWM_IRQ_COMPARE 3
/* Enable IRQ on Compare Match */
138
#define GRPWM_IRQ_CLEAR 0x10
/* Clear any pending IRQ on GRPWM and IRQ controller */
139
140
#define GRPWM_IRQ_CHAN 0x100
/* Channel N is selected, by adding 0x100*N */
141
142
#ifdef __cplusplus
143
144
#endif
145
146
#endif
grpwm_ioctl_cap
Definition
grpwm.h:49
grpwm_ioctl_config
Definition
grpwm.h:58
grpwm_ioctl_scaler
Definition
grpwm.h:97
Definition
grpwm.h:119
grpwm_ioctl_update
Definition
grpwm.h:128
