RTEMS 6.3
grpci2.h
2
3/* GRLIB GRPCI2 PCI HOST driver.
4 *
5 * COPYRIGHT (c) 2011
6 * Cobham Gaisler AB.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27 * POSSIBILITY OF SUCH DAMAGE.
28 */
29
30#ifndef __GRPCI2_H__
31#define __GRPCI2_H__
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
37extern void grpci2_register_drv(void);
38
39/* Driver Resources:
40 *
41 * PCI Interrupts
42 * ==============
43 * The interrupt settings are normally autodetected from Plyg&Play, however
44 * if IRQs are routed using custom GPIO pins in order to reduce the PIN count
45 * reserved for PCI, the options below can be used to tell GRPCI2 driver which
46 * System IRQ a PCI interrupt is connected to.
47 * Name="INTA#", Type=INT, System Interrupt number that PCI INTA is connected to
48 * Name="INTB#", Type=INT, System Interrupt number that PCI INTB is connected to
49 * Name="INTC#", Type=INT, System Interrupt number that PCI INTC is connected to
50 * Name="INTD#", Type=INT, System Interrupt number that PCI INTD is connected to
51 *
52 * Name="IRQmask", Type=INT,
53 *
54 * PCI Bytetwisting (endianess)
55 * ============================
56 * Name="byteTwisting", Type=INT, Enable/Disable Bytetwisting by hardware
57 *
58 * PCI Latency timer
59 * ============================
60 * Name="latencyTimer", Type=INT, Set the latency timer
61 *
62 * PCI Host's Target BARs setup
63 * ============================
64 * The Host's BARs are not configured by the configuration routines, by default
65 * the BARs are configured disabled (BAR=0) except for BAR0 which is mapped to
66 * the Main Memory for the Host.
67 * Name="tgtBarCfg", Type=PTR (*grpci2_pcibar_cfg), Target PCI BARs of Host
68 */
69
70/* When the Host acts as a target on the PCI bus, the PCI BARs of the host's
71 * configuration space determine at which PCI address the Host will be accessed
72 * at and when accessing a BAR which AMBA address it will be translated to.
73 */
75 unsigned int pciadr; /* PCI address of BAR (BAR content) */
76 unsigned int ahbadr; /* 'pciadr' translated to this AHB Address */
77 unsigned int barsize; /* PCI BAR Size, must be a power of 2 */
78};
79
80#ifdef __cplusplus
81}
82#endif
83
84#endif
Definition grpci2.h:74
