RTEMS 6.3
Semc
struct  _semc_sdram_config
 SEMC SDRAM configuration structure. More...
struct  _semc_nand_timing_config
 SEMC NAND device timing configuration structure. More...
struct  _semc_nand_config
 SEMC NAND configuration structure. More...
struct  _semc_nor_config
 SEMC NOR configuration structure. More...
struct  _semc_sram_config
 SEMC SRAM configuration structure. More...
struct  _semc_dbi_config
 SEMC DBI configuration structure. More...
struct  _semc_queuea_weight_struct
 SEMC AXI queue a weight setting structure. More...
union  _semc_queuea_weight
 SEMC AXI queue a weight setting union. More...
struct  _semc_queueb_weight_struct
 SEMC AXI queue b weight setting structure. More...
union  _semc_queueb_weight
 SEMC AXI queue b weight setting union. More...
struct  _semc_axi_queueweight
 SEMC AXI queue weight setting. More...
struct  _semc_config_t
 SEMC configuration structure. More...
semc_iomux_pin _semc_sdram_config::csxPinMux
uint32_t _semc_sdram_config::address
uint32_t _semc_sdram_config::memsize_kbytes
smec_port_size_t _semc_sdram_config::portSize
sem_sdram_burst_len_t _semc_sdram_config::burstLen
semc_sdram_column_bit_num_t _semc_sdram_config::columnAddrBitNum
semc_caslatency_t _semc_sdram_config::casLatency
uint8_t _semc_sdram_config::tPrecharge2Act_Ns
uint8_t _semc_sdram_config::tAct2ReadWrite_Ns
uint8_t _semc_sdram_config::tRefreshRecovery_Ns
uint8_t _semc_sdram_config::tWriteRecovery_Ns
uint8_t _semc_sdram_config::tCkeOff_Ns
uint8_t _semc_sdram_config::tAct2Prechage_Ns
uint8_t _semc_sdram_config::tSelfRefRecovery_Ns
uint8_t _semc_sdram_config::tRefresh2Refresh_Ns
uint8_t _semc_sdram_config::tAct2Act_Ns
uint32_t _semc_sdram_config::tPrescalePeriod_Ns
uint32_t _semc_sdram_config::tIdleTimeout_Ns
uint32_t _semc_sdram_config::refreshPeriod_nsPerRow
uint32_t _semc_sdram_config::refreshUrgThreshold
uint8_t _semc_sdram_config::refreshBurstLen
uint8_t _semc_nand_timing_config::tCeSetup_Ns
uint8_t _semc_nand_timing_config::tCeHold_Ns
uint8_t _semc_nand_timing_config::tCeInterval_Ns
uint8_t _semc_nand_timing_config::tWeLow_Ns
uint8_t _semc_nand_timing_config::tWeHigh_Ns
uint8_t _semc_nand_timing_config::tReLow_Ns
uint8_t _semc_nand_timing_config::tReHigh_Ns
uint8_t _semc_nand_timing_config::tTurnAround_Ns
uint8_t _semc_nand_timing_config::tWehigh2Relow_Ns
uint8_t _semc_nand_timing_config::tRehigh2Welow_Ns
uint8_t _semc_nand_timing_config::tAle2WriteStart_Ns
uint8_t _semc_nand_timing_config::tReady2Relow_Ns
uint8_t _semc_nand_timing_config::tWehigh2Busy_Ns
semc_iomux_pin _semc_nand_config::cePinMux
uint32_t _semc_nand_config::axiAddress
uint32_t _semc_nand_config::axiMemsize_kbytes
uint32_t _semc_nand_config::ipgAddress
uint32_t _semc_nand_config::ipgMemsize_kbytes
semc_rdy_polarity_t _semc_nand_config::rdyactivePolarity
bool _semc_nand_config::edoModeEnabled
semc_nand_column_bit_num_t _semc_nand_config::columnAddrBitNum
semc_nand_address_option_t _semc_nand_config::arrayAddrOption
sem_nand_burst_len_t _semc_nand_config::burstLen
smec_port_size_t _semc_nand_config::portSize
semc_nand_timing_config_t * _semc_nand_config::timingConfig
semc_iomux_pin _semc_nor_config::cePinMux
semc_iomux_nora27_pin _semc_nor_config::addr27
uint32_t _semc_nor_config::address
uint32_t _semc_nor_config::memsize_kbytes
uint8_t _semc_nor_config::addrPortWidth
semc_rdy_polarity_t _semc_nor_config::rdyactivePolarity
semc_adv_polarity_t _semc_nor_config::advActivePolarity
semc_norsram_column_bit_num_t _semc_nor_config::columnAddrBitNum
semc_addr_mode_t _semc_nor_config::addrMode
sem_norsram_burst_len_t _semc_nor_config::burstLen
smec_port_size_t _semc_nor_config::portSize
uint8_t _semc_nor_config::tCeSetup_Ns
uint8_t _semc_nor_config::tCeHold_Ns
uint8_t _semc_nor_config::tCeInterval_Ns
uint8_t _semc_nor_config::tAddrSetup_Ns
uint8_t _semc_nor_config::tAddrHold_Ns
uint8_t _semc_nor_config::tWeLow_Ns
uint8_t _semc_nor_config::tWeHigh_Ns
uint8_t _semc_nor_config::tReLow_Ns
uint8_t _semc_nor_config::tReHigh_Ns
uint8_t _semc_nor_config::tTurnAround_Ns
uint8_t _semc_nor_config::tAddr2WriteHold_Ns
semc_iomux_pin _semc_sram_config::cePinMux
semc_iomux_nora27_pin _semc_sram_config::addr27
uint32_t _semc_sram_config::address
uint32_t _semc_sram_config::memsize_kbytes
uint8_t _semc_sram_config::addrPortWidth
semc_adv_polarity_t _semc_sram_config::advActivePolarity
semc_addr_mode_t _semc_sram_config::addrMode
sem_norsram_burst_len_t _semc_sram_config::burstLen
smec_port_size_t _semc_sram_config::portSize
uint8_t _semc_sram_config::tCeSetup_Ns
uint8_t _semc_sram_config::tCeHold_Ns
uint8_t _semc_sram_config::tCeInterval_Ns
uint8_t _semc_sram_config::tAddrSetup_Ns
uint8_t _semc_sram_config::tAddrHold_Ns
uint8_t _semc_sram_config::tWeLow_Ns
uint8_t _semc_sram_config::tWeHigh_Ns
uint8_t _semc_sram_config::tReLow_Ns
uint8_t _semc_sram_config::tReHigh_Ns
uint8_t _semc_sram_config::tTurnAround_Ns
uint8_t _semc_sram_config::tAddr2WriteHold_Ns
semc_iomux_pin _semc_dbi_config::csxPinMux
uint32_t _semc_dbi_config::address
uint32_t _semc_dbi_config::memsize_kbytes
semc_dbi_column_bit_num_t _semc_dbi_config::columnAddrBitNum
sem_dbi_burst_len_t _semc_dbi_config::burstLen
smec_port_size_t _semc_dbi_config::portSize
uint8_t _semc_dbi_config::tCsxSetup_Ns
uint8_t _semc_dbi_config::tCsxHold_Ns
uint8_t _semc_dbi_config::tWexLow_Ns
uint8_t _semc_dbi_config::tWexHigh_Ns
uint8_t _semc_dbi_config::tRdxLow_Ns
uint8_t _semc_dbi_config::tRdxHigh_Ns
uint8_t _semc_dbi_config::tCsxInterval_Ns
uint32_t _semc_queuea_weight_struct::qos: 4
uint32_t _semc_queuea_weight_struct::aging: 4
uint32_t _semc_queuea_weight_struct::slaveHitSwith: 8
uint32_t _semc_queuea_weight_struct::slaveHitNoswitch: 8
semc_queuea_weight_struct_t _semc_queuea_weight::queueaConfig
uint32_t _semc_queuea_weight::queueaValue
uint32_t _semc_queueb_weight_struct::qos: 4
uint32_t _semc_queueb_weight_struct::aging: 4
uint32_t _semc_queueb_weight_struct::slaveHitSwith: 8
uint32_t _semc_queueb_weight_struct::weightPagehit: 8
uint32_t _semc_queueb_weight_struct::bankRotation: 8
semc_queueb_weight_struct_t _semc_queueb_weight::queuebConfig
uint32_t _semc_queueb_weight::queuebValue
bool _semc_axi_queueweight::queueaEnable
semc_queuea_weight_t _semc_axi_queueweight::queueaWeight
bool _semc_axi_queueweight::queuebEnable
semc_queueb_weight_t _semc_axi_queueweight::queuebWeight
semc_dqs_mode_t _semc_config_t::dqsMode
uint8_t _semc_config_t::cmdTimeoutCycles
uint8_t _semc_config_t::busTimeoutCycles
semc_axi_queueweight_t _semc_config_t::queueWeight
Driver version
enum  {
  kStatus_SEMC_InvalidDeviceType = MAKE_STATUS(kStatusGroup_SEMC, 0) , kStatus_SEMC_IpCommandExecutionError = MAKE_STATUS(kStatusGroup_SEMC, 1) , kStatus_SEMC_AxiCommandExecutionError = MAKE_STATUS(kStatusGroup_SEMC, 2) , kStatus_SEMC_InvalidMemorySize = MAKE_STATUS(kStatusGroup_SEMC, 3) ,
  kStatus_SEMC_InvalidIpcmdDataSize = MAKE_STATUS(kStatusGroup_SEMC, 4) , kStatus_SEMC_InvalidAddressPortWidth = MAKE_STATUS(kStatusGroup_SEMC, 5) , kStatus_SEMC_InvalidDataPortWidth = MAKE_STATUS(kStatusGroup_SEMC, 6) , kStatus_SEMC_InvalidSwPinmuxSelection = MAKE_STATUS(kStatusGroup_SEMC, 7) ,
  kStatus_SEMC_InvalidBurstLength = MAKE_STATUS(kStatusGroup_SEMC, 8) , kStatus_SEMC_InvalidColumnAddressBitWidth = MAKE_STATUS(kStatusGroup_SEMC, 9) , kStatus_SEMC_InvalidBaseAddress = MAKE_STATUS(kStatusGroup_SEMC, 10) , kStatus_SEMC_InvalidTimerSetting = MAKE_STATUS(kStatusGroup_SEMC, 11)
 SEMC status, _semc_status. More...
enum  _semc_mem_type {
  kSEMC_MemType_SDRAM = 0 , kSEMC_MemType_SRAM , kSEMC_MemType_NOR , kSEMC_MemType_NAND ,
  kSEMC_MemType_8080
 SEMC memory device type. More...
enum  _semc_waitready_polarity { kSEMC_LowActive = 0 , kSEMC_HighActive }
 SEMC WAIT/RDY polarity. More...
enum  _semc_sdram_cs { kSEMC_SDRAM_CS0 = 0 , kSEMC_SDRAM_CS1 , kSEMC_SDRAM_CS2 , kSEMC_SDRAM_CS3 }
 SEMC SDRAM Chip selection . More...
enum  _semc_sram_cs { kSEMC_SRAM_CS0 = 0 }
 SEMC SRAM Chip selection . More...
enum  _semc_nand_access_type { kSEMC_NAND_ACCESS_BY_AXI = 0 , kSEMC_NAND_ACCESS_BY_IPCMD }
 SEMC NAND device type. More...
enum  _semc_interrupt_enable { kSEMC_IPCmdDoneInterrupt = SEMC_INTEN_IPCMDDONEEN_MASK , kSEMC_IPCmdErrInterrupt = SEMC_INTEN_IPCMDERREN_MASK , kSEMC_AXICmdErrInterrupt = SEMC_INTEN_AXICMDERREN_MASK , kSEMC_AXIBusErrInterrupt = SEMC_INTEN_AXIBUSERREN_MASK }
 SEMC interrupts . More...
enum  _semc_ipcmd_datasize { kSEMC_IPcmdDataSize_1bytes = 1 , kSEMC_IPcmdDataSize_2bytes , kSEMC_IPcmdDataSize_3bytes , kSEMC_IPcmdDataSize_4bytes }
 SEMC IP command data size in bytes. More...
enum  _semc_refresh_time { kSEMC_RefreshThreeClocks = 0x0U , kSEMC_RefreshSixClocks , kSEMC_RefreshNineClocks }
 SEMC auto-refresh timing. More...
enum  _semc_caslatency { kSEMC_LatencyOne = 1 , kSEMC_LatencyTwo , kSEMC_LatencyThree }
 CAS latency. More...
enum  _semc_sdram_column_bit_num { kSEMC_SdramColunm_12bit = 0x0U , kSEMC_SdramColunm_11bit , kSEMC_SdramColunm_10bit , kSEMC_SdramColunm_9bit }
 SEMC sdram column address bit number. More...
enum  _semc_sdram_burst_len { kSEMC_Sdram_BurstLen1 = 0 , kSEMC_Sdram_BurstLen2 , kSEMC_Sdram_BurstLen4 , kSEMC_Sdram_BurstLen8 }
 SEMC sdram burst length. More...
enum  _semc_nand_column_bit_num {
  kSEMC_NandColum_16bit = 0x0U , kSEMC_NandColum_15bit , kSEMC_NandColum_14bit , kSEMC_NandColum_13bit ,
  kSEMC_NandColum_12bit , kSEMC_NandColum_11bit , kSEMC_NandColum_10bit , kSEMC_NandColum_9bit
 SEMC nand column address bit number. More...
enum  _semc_nand_burst_len {
  kSEMC_Nand_BurstLen1 = 0 , kSEMC_Nand_BurstLen2 , kSEMC_Nand_BurstLen4 , kSEMC_Nand_BurstLen8 ,
  kSEMC_Nand_BurstLen16 , kSEMC_Nand_BurstLen32 , kSEMC_Nand_BurstLen64
 SEMC nand burst length. More...
enum  _semc_norsram_column_bit_num {
  kSEMC_NorColum_12bit = 0x0U , kSEMC_NorColum_11bit , kSEMC_NorColum_10bit , kSEMC_NorColum_9bit ,
  kSEMC_NorColum_8bit , kSEMC_NorColum_7bit , kSEMC_NorColum_6bit , kSEMC_NorColum_5bit ,
  kSEMC_NorColum_4bit , kSEMC_NorColum_3bit , kSEMC_NorColum_2bit
 SEMC nor/sram column address bit number. More...
enum  _semc_norsram_burst_len {
  kSEMC_Nor_BurstLen1 = 0 , kSEMC_Nor_BurstLen2 , kSEMC_Nor_BurstLen4 , kSEMC_Nor_BurstLen8 ,
  kSEMC_Nor_BurstLen16 , kSEMC_Nor_BurstLen32 , kSEMC_Nor_BurstLen64
 SEMC nor/sram burst length. More...
enum  _semc_dbi_column_bit_num {
  kSEMC_Dbi_Colum_12bit = 0x0U , kSEMC_Dbi_Colum_11bit , kSEMC_Dbi_Colum_10bit , kSEMC_Dbi_Colum_9bit ,
  kSEMC_Dbi_Colum_8bit , kSEMC_Dbi_Colum_7bit , kSEMC_Dbi_Colum_6bit , kSEMC_Dbi_Colum_5bit ,
  kSEMC_Dbi_Colum_4bit , kSEMC_Dbi_Colum_3bit , kSEMC_Dbi_Colum_2bit
 SEMC dbi column address bit number. More...
enum  _semc_dbi_burst_len {
  kSEMC_Dbi_BurstLen1 = 0 , kSEMC_Dbi_BurstLen2 , kSEMC_Dbi_Dbi_BurstLen4 , kSEMC_Dbi_BurstLen8 ,
  kSEMC_Dbi_BurstLen16 , kSEMC_Dbi_BurstLen32 , kSEMC_Dbi_BurstLen64
 SEMC dbi burst length. More...
enum  _semc_iomux_pin {
  kSEMC_MUXA8 = SEMC_IOCR_MUX_A8_SHIFT , kSEMC_MUXCSX0 = SEMC_IOCR_MUX_CSX0_SHIFT , kSEMC_MUXCSX1 = SEMC_IOCR_MUX_CSX1_SHIFT , kSEMC_MUXCSX2 = SEMC_IOCR_MUX_CSX2_SHIFT ,
  kSEMC_MUXCSX3 = SEMC_IOCR_MUX_CSX3_SHIFT , kSEMC_MUXRDY = SEMC_IOCR_MUX_RDY_SHIFT
 SEMC IOMUXC. More...
enum  _semc_iomux_nora27_pin { kSEMC_MORA27_NONE = 0 , kSEMC_NORA27_MUXCSX3 = SEMC_IOCR_MUX_CSX3_SHIFT , kSEMC_NORA27_MUXRDY = SEMC_IOCR_MUX_RDY_SHIFT }
 SEMC NOR/PSRAM Address bit 27 A27. More...
enum  _semc_port_size { kSEMC_PortSize8Bit = 0 , kSEMC_PortSize16Bit }
 SEMC port size. More...
enum  _semc_addr_mode { kSEMC_AddrDataMux = 0 , kSEMC_AdvAddrdataMux , kSEMC_AddrDataNonMux }
 SEMC address mode. More...
enum  _semc_dqs_mode { kSEMC_Loopbackinternal = 0 , kSEMC_Loopbackdqspad }
 SEMC DQS read strobe mode. More...
enum  _semc_adv_polarity { kSEMC_AdvActiveLow = 0 , kSEMC_AdvActiveHigh }
 SEMC ADV signal active polarity. More...
enum  _semc_sync_mode { kSEMC_AsyncMode = 0 , kSEMC_SyncMode }
 SEMC sync mode. More...
enum  _semc_adv_level_control { kSEMC_AdvHigh = 0 , kSEMC_AdvLow }
 SEMC ADV signal level control. More...
enum  _semc_rdy_polarity { kSEMC_RdyActiveLow = 0 , kSEMC_RdyActivehigh }
 SEMC RDY signal active polarity. More...
enum  _semc_ipcmd_nand_addrmode {
  kSEMC_NANDAM_ColumnRow = 0x0U , kSEMC_NANDAM_ColumnCA0 , kSEMC_NANDAM_ColumnCA0CA1 , kSEMC_NANDAM_RawRA0 ,
  kSEMC_NANDAM_RawRA0RA1 , kSEMC_NANDAM_RawRA0RA1RA2
 SEMC IP command for NAND: address mode. More...
enum  _semc_ipcmd_nand_cmdmode {
  kSEMC_NANDCM_Command = 0x2U , kSEMC_NANDCM_CommandHold , kSEMC_NANDCM_CommandAddress , kSEMC_NANDCM_CommandAddressHold ,
  kSEMC_NANDCM_CommandAddressRead , kSEMC_NANDCM_CommandAddressWrite , kSEMC_NANDCM_CommandRead , kSEMC_NANDCM_CommandWrite ,
  kSEMC_NANDCM_Read , kSEMC_NANDCM_Write
 SEMC IP command for NAND: command mode. More...
enum  _semc_nand_address_option {
  kSEMC_NandAddrOption_5byte_CA2RA3 = 0U , kSEMC_NandAddrOption_4byte_CA2RA2 = 2U , kSEMC_NandAddrOption_3byte_CA2RA1 = 4U , kSEMC_NandAddrOption_4byte_CA1RA3 = 1U ,
  kSEMC_NandAddrOption_3byte_CA1RA2 = 3U , kSEMC_NandAddrOption_2byte_CA1RA1 = 7U
 SEMC NAND address option. More...
enum  _semc_ipcmd_nor_dbi { kSEMC_NORDBICM_Read = 0x2U , kSEMC_NORDBICM_Write }
 SEMC IP command for NOR. More...
enum  _semc_ipcmd_sram { kSEMC_SRAMCM_ArrayRead = 0x2U , kSEMC_SRAMCM_ArrayWrite , kSEMC_SRAMCM_RegRead , kSEMC_SRAMCM_RegWrite }
 SEMC IP command for SRAM. More...
enum  _semc_ipcmd_sdram {
  kSEMC_SDRAMCM_Read = 0x8U , kSEMC_SDRAMCM_Write , kSEMC_SDRAMCM_Modeset , kSEMC_SDRAMCM_Active ,
  kSEMC_SDRAMCM_AutoRefresh , kSEMC_SDRAMCM_SelfRefresh , kSEMC_SDRAMCM_Precharge , kSEMC_SDRAMCM_Prechargeall
 SEMC IP command for SDARM. More...
typedef enum _semc_mem_type semc_mem_type_t
typedef enum _semc_waitready_polarity semc_waitready_polarity_t
typedef enum _semc_sdram_cs semc_sdram_cs_t
typedef enum _semc_sram_cs semc_sram_cs_t
typedef enum _semc_nand_access_type semc_nand_access_type_t
typedef enum _semc_interrupt_enable semc_interrupt_enable_t
 SEMC interrupts .
typedef enum _semc_ipcmd_datasize semc_ipcmd_datasize_t
typedef enum _semc_refresh_time semc_refresh_time_t
typedef enum _semc_caslatency semc_caslatency_t
 CAS latency.
typedef enum _semc_sdram_column_bit_num semc_sdram_column_bit_num_t
typedef enum _semc_sdram_burst_len sem_sdram_burst_len_t
typedef enum _semc_nand_column_bit_num semc_nand_column_bit_num_t
typedef enum _semc_nand_burst_len sem_nand_burst_len_t
typedef enum _semc_norsram_column_bit_num semc_norsram_column_bit_num_t
typedef enum _semc_norsram_burst_len sem_norsram_burst_len_t
typedef enum _semc_dbi_column_bit_num semc_dbi_column_bit_num_t
typedef enum _semc_dbi_burst_len sem_dbi_burst_len_t
typedef enum _semc_iomux_pin semc_iomux_pin
 SEMC IOMUXC.
typedef enum _semc_iomux_nora27_pin semc_iomux_nora27_pin
typedef enum _semc_port_size smec_port_size_t
 SEMC port size.
typedef enum _semc_addr_mode semc_addr_mode_t
 SEMC address mode.
typedef enum _semc_dqs_mode semc_dqs_mode_t
typedef enum _semc_adv_polarity semc_adv_polarity_t
typedef enum _semc_sync_mode semc_sync_mode_t
 SEMC sync mode.
typedef enum _semc_adv_level_control semc_adv_level_control_t
typedef enum _semc_rdy_polarity semc_rdy_polarity_t
typedef enum _semc_ipcmd_nand_addrmode semc_ipcmd_nand_addrmode_t
typedef enum _semc_ipcmd_nand_cmdmode semc_ipcmd_nand_cmdmode_t
typedef enum _semc_nand_address_option semc_nand_address_option_t
typedef enum _semc_ipcmd_nor_dbi semc_ipcmd_nor_dbi_t
typedef enum _semc_ipcmd_sram semc_ipcmd_sram_t
typedef enum _semc_ipcmd_sdram semc_ipcmd_sdram_t
typedef struct _semc_sdram_config semc_sdram_config_t
typedef struct _semc_nand_timing_config semc_nand_timing_config_t
typedef struct _semc_nand_config semc_nand_config_t
typedef struct _semc_nor_config semc_nor_config_t
typedef struct _semc_sram_config semc_sram_config_t
typedef struct _semc_dbi_config semc_dbi_config_t
typedef struct _semc_queuea_weight_struct semc_queuea_weight_struct_t
typedef union _semc_queuea_weight semc_queuea_weight_t
typedef struct _semc_queueb_weight_struct semc_queueb_weight_struct_t
typedef union _semc_queueb_weight semc_queueb_weight_t
typedef struct _semc_axi_queueweight semc_axi_queueweight_t
typedef struct _semc_config_t semc_config_t
#define FSL_SEMC_DRIVER_VERSION   (MAKE_VERSION(2, 4, 3))
 SEMC driver version.
SEMC Initialization and De-initialization
void SEMC_GetDefaultConfig (semc_config_t *config)
 Gets the SEMC default basic configuration structure.
void SEMC_Init (SEMC_Type *base, semc_config_t *configure)
 Initializes SEMC. This function ungates the SEMC clock and initializes SEMC. This function must be called before calling any other SEMC driver functions.
void SEMC_Deinit (SEMC_Type *base)
 Deinitializes the SEMC module and gates the clock.
SEMC Configuration Operation For Each Memory Type
status_t SEMC_ConfigureSDRAM (SEMC_Type *base, semc_sdram_cs_t cs, semc_sdram_config_t *config, uint32_t clkSrc_Hz)
 Configures SDRAM controller in SEMC.
status_t SEMC_ConfigureNAND (SEMC_Type *base, semc_nand_config_t *config, uint32_t clkSrc_Hz)
 Configures NAND controller in SEMC.
status_t SEMC_ConfigureNOR (SEMC_Type *base, semc_nor_config_t *config, uint32_t clkSrc_Hz)
 Configures NOR controller in SEMC.
status_t SEMC_ConfigureSRAMWithChipSelection (SEMC_Type *base, semc_sram_cs_t cs, semc_sram_config_t *config, uint32_t clkSrc_Hz)
 Configures SRAM controller in SEMC.
status_t SEMC_ConfigureSRAM (SEMC_Type *base, semc_sram_config_t *config, uint32_t clkSrc_Hz)
status_t SEMC_ConfigureDBI (SEMC_Type *base, semc_dbi_config_t *config, uint32_t clkSrc_Hz)
 Configures DBI controller in SEMC.
SEMC Memory Access Operation
status_t SEMC_SendIPCommand (SEMC_Type *base, semc_mem_type_t memType, uint32_t address, uint32_t command, uint32_t write, uint32_t *read)
 SEMC IP command access.
status_t SEMC_IPCommandNandWrite (SEMC_Type *base, uint32_t address, uint8_t *data, uint32_t size_bytes)
 SEMC NAND device memory write through IP command.
status_t SEMC_IPCommandNandRead (SEMC_Type *base, uint32_t address, uint8_t *data, uint32_t size_bytes)
 SEMC NAND device memory read through IP command.
status_t SEMC_IPCommandNorWrite (SEMC_Type *base, uint32_t address, uint8_t *data, uint32_t size_bytes)
 SEMC NOR device memory write through IP command.
status_t SEMC_IPCommandNorRead (SEMC_Type *base, uint32_t address, uint8_t *data, uint32_t size_bytes)
 SEMC NOR device memory read through IP command.
Typedef Documentation
◆ semc_config_t
busTimeoutCycles: when busTimeoutCycles is zero, the bus timeout cycle is 255*1024. otherwise the bus timeout cycles is busTimeoutCycles*1024. cmdTimeoutCycles: is used for command execution timeout cycles. it's similar to the busTimeoutCycles.
◆ semc_sdram_config_t
  1. The memory size in the configuration is in the unit of KB. So memsize_kbytes should be set as 2^2, 2^3, 2^4 .etc which is base 2KB exponential function. Take refer to BR0~BR3 register in RM for details.
  2. The prescalePeriod_N16Cycle is in unit of 16 clock cycle. It is a exception for prescaleTimer_n16cycle = 0, it means the prescaler timer period is 256 * 16 clock cycles. For precalerIf precalerTimer_n16cycle not equal to 0, The prescaler timer period is prescalePeriod_N16Cycle * 16 clock cycles. idleTimeout_NprescalePeriod, refreshUrgThreshold_NprescalePeriod, refreshPeriod_NprescalePeriod are similar to prescalePeriod_N16Cycle.
◆ anonymous enum
anonymous enum
Invalid device type.
IP command execution error.
AXI command execution error.
Invalid memory sie.
Invalid IP command data size.
Invalid address port width.
Invalid data port width.
Invalid SW pinmux selection.
Invalid burst length
Invalid column address bit width.
Invalid base address.
Invalid timer setting.
◆ _semc_addr_mode
SEMC address mode.
kSEMC_AddrDataMux
SEMC address/data mux mode.
Advanced address/data mux mode.
Address/data non-mux mode.
◆ _semc_adv_level_control
kSEMC_AdvHigh
Adv is high during address hold state.
kSEMC_AdvLow
Adv is low during address hold state.
◆ _semc_adv_polarity
kSEMC_AdvActiveLow
Adv active low.
kSEMC_AdvActiveHigh
Adv active high.
◆ _semc_caslatency
CAS latency.
kSEMC_LatencyOne
Latency 1.
kSEMC_LatencyTwo
Latency 2.
kSEMC_LatencyThree
Latency 3.
◆ _semc_dbi_burst_len
kSEMC_Dbi_BurstLen1
Burst length 1
kSEMC_Dbi_BurstLen2
Burst length 2
Burst length 4
kSEMC_Dbi_BurstLen8
Burst length 8
Burst length 16
Burst length 32
Burst length 64
◆ _semc_dbi_column_bit_num
12 bit.
11 bit.
10 bit.
9 bit.
8 bit.
7 bit.
6 bit.
5 bit.
4 bit.
3 bit.
2 bit.
◆ _semc_dqs_mode
Dummy read strobe loopbacked internally.
Dummy read strobe loopbacked from DQS pad.
◆ _semc_interrupt_enable
SEMC interrupts .
Ip command done interrupt.
Ip command error interrupt.
AXI command error interrupt.
AXI bus error interrupt.
◆ _semc_iomux_nora27_pin
kSEMC_MORA27_NONE
No NOR/SRAM A27 pin.
MUX CSX3 Pin.
kSEMC_NORA27_MUXRDY
MUX RDY pin.
◆ _semc_iomux_pin
SEMC IOMUXC.
kSEMC_MUXA8
MUX A8 pin.
kSEMC_MUXCSX0
MUX CSX0 pin
kSEMC_MUXCSX1
MUX CSX1 Pin.
kSEMC_MUXCSX2
MUX CSX2 Pin.
kSEMC_MUXCSX3
MUX CSX3 Pin.
kSEMC_MUXRDY
MUX RDY pin.
◆ _semc_ipcmd_datasize
The IP command data size 1 byte.
The IP command data size 2 byte.
The IP command data size 3 byte.
The IP command data size 4 byte.
◆ _semc_ipcmd_nand_addrmode
Address mode: column and row address(5Byte-CA0/CA1/RA0/RA1/RA2).
Address mode: column address only(1 Byte-CA0).
Address mode: column address only(2 Byte-CA0/CA1).
kSEMC_NANDAM_RawRA0
Address mode: row address only(1 Byte-RA0).
Address mode: row address only(2 Byte-RA0/RA1).
Address mode: row address only(3 Byte-RA0).
◆ _semc_ipcmd_nand_cmdmode
command.
Command hold.
Command address.
Command address hold.
Command address read.
Command address write.
Command read.
Command write.
kSEMC_NANDCM_Read
Read.
kSEMC_NANDCM_Write
Write.
◆ _semc_ipcmd_nor_dbi
kSEMC_NORDBICM_Read
NOR read.
NOR write.
◆ _semc_ipcmd_sdram
kSEMC_SDRAMCM_Read
SDRAM memory read.
kSEMC_SDRAMCM_Write
SDRAM memory write.
SDRAM MODE SET.
SDRAM active.
SDRAM auto-refresh.
SDRAM self-refresh.
SDRAM precharge.
SDRAM precharge all.
◆ _semc_ipcmd_sram
SRAM memory array read.
SRAM memory array write.
SRAM memory register read.
SRAM memory register write.
◆ _semc_mem_type
kSEMC_MemType_SDRAM
SDRAM
kSEMC_MemType_SRAM
SRAM
kSEMC_MemType_NOR
NOR
kSEMC_MemType_NAND
NAND
kSEMC_MemType_8080
◆ _semc_nand_access_type
Access to NAND flash by AXI bus.
Access to NAND flash by IP bus.
◆ _semc_nand_address_option
CA0+CA1+RA0+RA1+RA2
CA0+CA1+RA0+RA1
CA0+CA1+RA0
CA0+RA0+RA1+RA2
CA0+RA0+RA1
CA0+RA0
◆ _semc_nand_burst_len
Burst length 1
Burst length 2
Burst length 4
Burst length 8
Burst length 16
Burst length 32
Burst length 64
◆ _semc_nand_column_bit_num
16 bit.
15 bit.
14 bit.
13 bit.
12 bit.
11 bit.
10 bit.
9 bit.
◆ _semc_norsram_burst_len
kSEMC_Nor_BurstLen1
Burst length 1
kSEMC_Nor_BurstLen2
Burst length 2
kSEMC_Nor_BurstLen4
Burst length 4
kSEMC_Nor_BurstLen8
Burst length 8
Burst length 16
Burst length 32
Burst length 64
◆ _semc_norsram_column_bit_num
12 bit.
11 bit.
10 bit.
kSEMC_NorColum_9bit
9 bit.
kSEMC_NorColum_8bit
8 bit.
kSEMC_NorColum_7bit
7 bit.
kSEMC_NorColum_6bit
6 bit.
kSEMC_NorColum_5bit
5 bit.
kSEMC_NorColum_4bit
4 bit.
kSEMC_NorColum_3bit
3 bit.
kSEMC_NorColum_2bit
2 bit.
◆ _semc_port_size
SEMC port size.
kSEMC_PortSize8Bit
8-Bit port size.
kSEMC_PortSize16Bit
16-Bit port size.
◆ _semc_rdy_polarity
kSEMC_RdyActiveLow
Adv active low.
kSEMC_RdyActivehigh
Adv active low.
◆ _semc_refresh_time
The refresh timing with three bus clocks.
The refresh timing with six bus clocks.
The refresh timing with nine bus clocks.
◆ _semc_sdram_burst_len
According to ERR050577, Auto-refresh command may possibly fail to be triggered during long time back-to-back write (or read) when SDRAM controller's burst length is greater than 1. Burst length 1
Burst length 2
Burst length 4
Burst length 8
◆ _semc_sdram_column_bit_num
12 bit.
11 bit.
10 bit.
9 bit.
◆ _semc_sdram_cs
kSEMC_SDRAM_CS0
SEMC SDRAM CS0.
kSEMC_SDRAM_CS1
SEMC SDRAM CS1.
kSEMC_SDRAM_CS2
SEMC SDRAM CS2.
kSEMC_SDRAM_CS3
SEMC SDRAM CS3.
◆ _semc_sram_cs
kSEMC_SRAM_CS0
SEMC SRAM CS0.
◆ _semc_sync_mode
SEMC sync mode.
kSEMC_AsyncMode
Async mode.
kSEMC_SyncMode
Sync mode.
◆ _semc_waitready_polarity
kSEMC_LowActive
Low active.
kSEMC_HighActive
High active.
◆ SEMC_ConfigureDBI()
status_t SEMC_ConfigureDBI ( SEMC_Type * base,
semc_dbi_config_t * config,
uint32_t clkSrc_Hz )
Parameters
baseSEMC peripheral base address.
configThe dbi configuration.
clkSrc_HzThe SEMC clock frequency.
brief Configures DBI controller in SEMC.
param base SEMC peripheral base address. param config The dbi configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_ConfigureNAND()
status_t SEMC_ConfigureNAND ( SEMC_Type * base,
semc_nand_config_t * config,
Parameters
configThe nand configuration.
brief Configures NAND controller in SEMC.
param base SEMC peripheral base address. param config The nand configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_ConfigureNOR()
status_t SEMC_ConfigureNOR ( SEMC_Type * base,
semc_nor_config_t * config,
Parameters
configThe nor configuration.
brief Configures NOR controller in SEMC.
param base SEMC peripheral base address. param config The nor configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_ConfigureSDRAM()
status_t SEMC_ConfigureSDRAM ( SEMC_Type * base,
semc_sdram_cs_t cs,
semc_sdram_config_t * config,
Parameters
csThe chip selection.
configThe sdram configuration.
brief Configures SDRAM controller in SEMC.
param base SEMC peripheral base address. param cs The chip selection. param config The sdram configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_ConfigureSRAM()
status_t SEMC_ConfigureSRAM ( SEMC_Type * base,
semc_sram_config_t * config,
Deprecated
Do not use this function. It has been superceded by SEMC_ConfigureSRAMWithChipSelection.
Parameters
configThe sram configuration.
brief Configures SRAM controller in SEMC, which can be used only for specific chip selection CS0.
param base SEMC peripheral base address. param config The sram configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_ConfigureSRAMWithChipSelection()
status_t SEMC_ConfigureSRAMWithChipSelection ( SEMC_Type * base,
semc_sram_cs_t cs,
Parameters
brief Configures SRAM controller in SEMC, which can be used up to four chip selections CS0/CS1/CS2/CS3..
param base SEMC peripheral base address. param cs The chip selection. param config The sram configuration. param clkSrc_Hz The SEMC clock frequency.
◆ SEMC_Deinit()
void SEMC_Deinit ( SEMC_Type * base)
This function gates the SEMC clock. As a result, the SEMC module doesn't work after calling this function, for some IDE, calling this API may cause the next downloading operation failed. so, please call this API cautiously. Additional, users can using "#define FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL (1)" to disable the clock control operation in drivers.
Parameters
brief Deinitializes the SEMC module and gates the clock. This function gates the SEMC clock. As a result, the SEMC module doesn't work after calling this function.
◆ SEMC_GetDefaultConfig()
void SEMC_GetDefaultConfig ( semc_config_t * config)
The purpose of this API is to get the default SEMC configure structure for SEMC_Init(). User may use the initialized structure unchanged in SEMC_Init(), or modify some fields of the structure before calling SEMC_Init(). Example:
void SEMC_GetDefaultConfig(semc_config_t *config)
Definition fsl_semc.c:253
Parameters
configThe SEMC configuration structure pointer.
brief Gets the SEMC default basic configuration structure.
The purpose of this API is to get the default SEMC configure structure for SEMC_Init(). User may use the initialized structure unchanged in SEMC_Init(), or modify some fields of the structure before calling SEMC_Init(). Example: code semc_config_t config; SEMC_GetDefaultConfig(&config); endcode param config The SEMC configuration structure pointer.
◆ SEMC_Init()
void SEMC_Init ( SEMC_Type * base,
semc_config_t * configure )
Parameters
configureThe SEMC configuration structure pointer.
brief Initializes SEMC. This function ungates the SEMC clock and initializes SEMC. This function must be called before calling any other SEMC driver functions.
param base SEMC peripheral base address. param configure The SEMC configuration structure pointer.
◆ SEMC_IPCommandNandRead()
status_t SEMC_IPCommandNandRead ( SEMC_Type * base,
uint32_t address,
uint8_t * data,
uint32_t size_bytes )
Parameters
addressSEMC NAND device address.
dataData pointer for data read out.
size_bytesData length.
brief SEMC NAND device memory read through IP command.
param base SEMC peripheral base address. param address SEMC NAND device address. param data Data pointer for data read out. param size_bytes Data length.
◆ SEMC_IPCommandNandWrite()
status_t SEMC_IPCommandNandWrite ( SEMC_Type * base,
uint32_t address,
uint8_t * data,
Parameters
dataData for write access.
brief SEMC NAND device memory write through IP command.
param base SEMC peripheral base address. param address SEMC NAND device address. param data Data for write access. param size_bytes Data length.
◆ SEMC_IPCommandNorRead()
status_t SEMC_IPCommandNorRead ( SEMC_Type * base,
uint32_t address,
uint8_t * data,
Parameters
addressSEMC NOR device address.
brief SEMC NOR device memory read through IP command.
param base SEMC peripheral base address. param address SEMC NOR device address. param data Data pointer for data read out. param size_bytes Data length.
◆ SEMC_IPCommandNorWrite()
status_t SEMC_IPCommandNorWrite ( SEMC_Type * base,
uint32_t address,
uint8_t * data,
Parameters
brief SEMC NOR device memory write through IP command.
param base SEMC peripheral base address. param address SEMC NOR device address. param data Data for write access. param size_bytes Data length.
◆ SEMC_SendIPCommand()
status_t SEMC_SendIPCommand ( SEMC_Type * base,
uint32_t address,
uint32_t command,
uint32_t write,
uint32_t * read )
Parameters
memTypeSEMC memory type. refer to "semc_mem_type_t"
addressSEMC device address.
commandSEMC IP command. For NAND device, we should use the SEMC_BuildNandIPCommand to get the right nand command. For NOR/DBI device, take refer to "semc_ipcmd_nor_dbi_t". For SRAM device, take refer to "semc_ipcmd_sram_t". For SDRAM device, take refer to "semc_ipcmd_sdram_t".
writeData for write access.
readData pointer for read data out.
brief SEMC IP command access.
param base SEMC peripheral base address. param memType SEMC memory type. refer to "semc_mem_type_t" param address SEMC device address. param command SEMC IP command. For NAND device, we should use the SEMC_BuildNandIPCommand to get the right nand command. For NOR/DBI device, take refer to "semc_ipcmd_nor_dbi_t". For SRAM device, take refer to "semc_ipcmd_sram_t". For SDRAM device, take refer to "semc_ipcmd_sdram_t". param write Data for write access. param read Data pointer for read data out.
Variable Documentation
◆ addr27 [1/2]
The Addr bit 27 pin mux setting.
◆ addr27 [2/2]
◆ address [1/4]
The base address.
◆ address [2/4]
The base address.
◆ address [3/4]
The base address.
◆ address [4/4]
The base address.
◆ addrMode [1/2]
Address mode.
◆ addrMode [2/2]
Address mode.
◆ addrPortWidth [1/2]
The address port width.
◆ addrPortWidth [2/2]
◆ advActivePolarity [1/2]
ADV# polarity.
◆ advActivePolarity [2/2]
ADV# polarity 1: active high, 0: active low.
◆ aging [1/2]
weight of aging for queue 0.
◆ aging [2/2]
weight of aging for queue 1.
◆ arrayAddrOption
Address option.
◆ axiAddress
The base address for AXI nand.
◆ axiMemsize_kbytes
The memory size in unit of kbytes for AXI nand.
◆ bankRotation
weight of bank rotation for queue 1 only .
◆ burstLen [1/5]
Burst length.
◆ burstLen [2/5]
Burst length.
◆ burstLen [3/5]
Burst length.
◆ burstLen [4/5]
Burst length.
◆ burstLen [5/5]
Burst length.
◆ busTimeoutCycles
Bus timeout cycles.
◆ casLatency
CAS latency.
◆ cePinMux [1/3]
The CE pin mux setting. The kSEMC_MUXRDY is not valid for CE pin setting.
◆ cePinMux [2/3]
The CE# pin mux setting.
◆ cePinMux [3/3]
◆ cmdTimeoutCycles
Command execution timeout cycles.
◆ columnAddrBitNum [1/4]
Column address bit number.
◆ columnAddrBitNum [2/4]
◆ columnAddrBitNum [3/4]
◆ columnAddrBitNum [4/4]
◆ csxPinMux [1/2]
The CE# pin mux.
◆ csxPinMux [2/2]
CS pin mux. The kSEMC_MUXA8 is not valid in sdram pin mux setting.
◆ dqsMode
Dummy read strobe mode: use enum in "semc_dqs_mode_t".
◆ edoModeEnabled
EDO mode enabled.
◆ ipgAddress
The base address for IPG nand .
◆ ipgMemsize_kbytes
The memory size in unit of kbytes for IPG nand.
◆ memsize_kbytes [1/4]
The memory size in unit of 4kbytes.
◆ memsize_kbytes [2/4]
The memory size in unit of kbytes.
◆ memsize_kbytes [3/4]
◆ memsize_kbytes [4/4]
◆ portSize [1/5]
Port size.
◆ portSize [2/5]
Port size.
◆ portSize [3/5]
Port size.
◆ portSize [4/5]
Port size.
◆ portSize [5/5]
Port size.
◆ qos [1/2]
weight of qos for queue 0 .
◆ qos [2/2]
weight of qos for queue 1.
◆ queueaConfig
Structure configuration for queueA.
◆ queueaEnable
Enable queue a.
◆ queueaValue
Configuration value for queueA which could directly write to the reg.
◆ queueaWeight
Weight settings for queue a.
◆ queuebConfig
Structure configuration for queueB.
◆ queuebEnable
Enable queue b.
◆ queuebValue
Configuration value for queueB which could directly write to the reg.
◆ queuebWeight
Weight settings for queue b.
◆ queueWeight
AXI queue weight.
◆ rdyactivePolarity [1/2]
Wait ready polarity.
◆ rdyactivePolarity [2/2]
◆ refreshBurstLen
Refresh burst length.
◆ refreshPeriod_nsPerRow
Refresh timer period like 64ms * 1000000/8192 .
◆ refreshUrgThreshold
Refresh urgent threshold.
◆ slaveHitNoswitch
weight of read/write no switch for queue 0 .
◆ slaveHitSwith [1/2]
weight of read/write switch for queue 0.
◆ slaveHitSwith [2/2]
weight of read/write switch for queue 1.
◆ tAct2Act_Ns
Active to active wait time in unit of nanosecond.
◆ tAct2Prechage_Ns
Active to precharge in unit of nanosecond.
◆ tAct2ReadWrite_Ns
Act to read/write wait time in unit of nanosecond.
◆ tAddr2WriteHold_Ns [1/2]
Address to write data hold time for async mode.
◆ tAddr2WriteHold_Ns [2/2]
◆ tAddrHold_Ns [1/2]
The address hold time.
◆ tAddrHold_Ns [2/2]
◆ tAddrSetup_Ns [1/2]
The address setup time.
◆ tAddrSetup_Ns [2/2]
◆ tAle2WriteStart_Ns
ALE to write start wait time: tADL.
◆ tCeHold_Ns [1/3]
CE hold time: tCH.
◆ tCeHold_Ns [2/3]
The CE hold time.
◆ tCeHold_Ns [3/3]
The CE hold time.
◆ tCeInterval_Ns [1/3]
CE interval time:tCEITV.
◆ tCeInterval_Ns [2/3]
CE interval minimum time.
◆ tCeInterval_Ns [3/3]
◆ tCeSetup_Ns [1/3]
CE setup time: tCS.
◆ tCeSetup_Ns [2/3]
The CE setup time.
◆ tCeSetup_Ns [3/3]
The CE setup time.
◆ tCkeOff_Ns
CKE off minimum time in unit of nanosecond.
◆ tCsxHold_Ns
The CSX hold time.
◆ tCsxInterval_Ns
Write data setup time.
◆ tCsxSetup_Ns
The CSX setup time.
◆ tIdleTimeout_Ns
Idle timeout in unit of prescale time period.
◆ timingConfig
semc_nand_timing_config_t* _semc_nand_config::timingConfig
SEMC nand timing configuration.
◆ tPrecharge2Act_Ns
Precharge to active wait time in unit of nanosecond.
◆ tPrescalePeriod_Ns
Prescaler timer period should not be larger than 256 * 16 * clock cycle.
◆ tRdxHigh_Ns
RDX high time.
◆ tRdxLow_Ns
RDX low time.
◆ tReady2Relow_Ns
Ready to RE# low min wait time: tRR.
◆ tRefresh2Refresh_Ns
Refresh to refresh wait time in unit of nanosecond.
◆ tRefreshRecovery_Ns
Refresh recovery time in unit of nanosecond.
◆ tRehigh2Welow_Ns
RE# high to WE# low wait time: tRHW.
◆ tReHigh_Ns [1/3]
RE high time: tREH.
◆ tReHigh_Ns [2/3]
RE high time for async mode.
◆ tReHigh_Ns [3/3]
◆ tReLow_Ns [1/3]
RE low time: tRP.
◆ tReLow_Ns [2/3]
RE low time for async mode.
◆ tReLow_Ns [3/3]
◆ tSelfRefRecovery_Ns
Self refresh recovery time in unit of nanosecond.
◆ tTurnAround_Ns [1/3]
Turnaround time for async mode: tTA.
◆ tTurnAround_Ns [2/3]
Turnaround time for async mode.
◆ tTurnAround_Ns [3/3]
◆ tWehigh2Busy_Ns
WE# high to busy wait time: tWB.
◆ tWehigh2Relow_Ns
WE# high to RE# wait time: tWHR.
◆ tWeHigh_Ns [1/3]
WE high time: tWH.
◆ tWeHigh_Ns [2/3]
WE high time for async mode.
◆ tWeHigh_Ns [3/3]
◆ tWeLow_Ns [1/3]
WE low time: tWP.
◆ tWeLow_Ns [2/3]
WE low time for async mode.
◆ tWeLow_Ns [3/3]
◆ tWexHigh_Ns
WEX high time.
◆ tWexLow_Ns
WEX low time.
◆ tWriteRecovery_Ns
write recovery time in unit of nanosecond.
◆ weightPagehit
weight of page hit for queue 1 only .
