RTEMS 6.3
Register Definitions
Register Definitions. More...
file  bsps/arm/raspberrypi/include/bsp/raspberrypi.h
 Register definitions.
Register Macros
#define BCM2711_REG(x)
#define BCM2711_BIT(n)
Register Macros
#define BCM2835_REG(addr)
#define BCM2835_REG(x)
#define BCM2835_BIT(n)
Peripheral Base Register Address
#define RPI_PERIPHERAL_BASE   0xFE000000
#define BASE_OFFSET   0xFE000000
#define RPI_PERIPHERAL_SIZE   0x01800000
#define RPI_PERIPHERAL_BASE   0x20000000
#define BASE_OFFSET   0X5E000000
#define RPI_PERIPHERAL_SIZE   0x01000000
Bus to Physical address translation
Macro.
#define BUS_TO_PHY(x)
Internal ARM Timer Registers
#define BCM2711_CLOCK_FREQ   250000000
#define BCM2711_TIMER_BASE   (RPI_PERIPHERAL_BASE + 0xB400)
#define BCM2711_TIMER_LOD   (BCM2711_TIMER_BASE + 0x00)
#define BCM2711_TIMER_VAL   (BCM2711_TIMER_BASE + 0x04)
#define BCM2711_TIMER_CTL   (BCM2711_TIMER_BASE + 0x08)
#define BCM2711_TIMER_CLI   (BCM2711_TIMER_BASE + 0x0C)
#define BCM2711_TIMER_RIS   (BCM2711_TIMER_BASE + 0x10)
#define BCM2711_TIMER_MIS   (BCM2711_TIMER_BASE + 0x14)
#define BCM2711_TIMER_RLD   (BCM2711_TIMER_BASE + 0x18)
#define BCM2711_TIMER_DIV   (BCM2711_TIMER_BASE + 0x1C)
#define BCM2711_TIMER_CNT   (BCM2711_TIMER_BASE + 0x20)
#define BCM2711_TIMER_PRESCALE   0xF9
Power Management and Watchdog Registers
#define BCM2711_PM_PASSWD_MAGIC   0x5a000000
#define BCM2711_PM_BASE   (RPI_PERIPHERAL_BASE + 0x100000)
#define BCM2711_PM_GNRIC   (BCM2711_PM_BASE + 0x00)
#define BCM2711_PM_GNRIC_POWUP   0x00000001
#define BCM2711_PM_GNRIC_POWOK   0x00000002
#define BCM2711_PM_GNRIC_ISPOW   0x00000004
#define BCM2711_PM_GNRIC_MEMREP   0x00000008
#define BCM2711_PM_GNRIC_MRDONE   0x00000010
#define BCM2711_PM_GNRIC_ISFUNC   0x00000020
#define BCM2711_PM_GNRIC_RSTN   0x00000fc0
#define BCM2711_PM_GNRIC_ENAB   0x00001000
#define BCM2711_PM_GNRIC_CFG   0x007f0000
#define BCM2711_PM_AUDIO   (BCM2711_PM_BASE + 0x04)
#define BCM2711_PM_AUDIO_APSM   0x000fffff
#define BCM2711_PM_AUDIO_CTRLEN   0x00100000
#define BCM2711_PM_AUDIO_RSTN   0x00200000
#define BCM2711_PM_STATUS   (BCM2711_PM_BASE + 0x18)
#define BCM2711_PM_RSTC   (BCM2711_PM_BASE + 0x1c)
#define BCM2711_PM_RSTC_DRCFG   0x00000003
#define BCM2711_PM_RSTC_WRCFG   0x00000030
#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
#define BCM2711_PM_RSTC_WRCFG_CLR   0xffffffcf
#define BCM2711_PM_RSTC_SRCFG   0x00000300
#define BCM2711_PM_RSTC_QRCFG   0x00003000
#define BCM2711_PM_RSTC_FRCFG   0x00030000
#define BCM2711_PM_RSTC_HRCFG   0x00300000
#define BCM2711_PM_RSTC_RESET   0x00000102
#define BCM2711_PM_RSTS   (BCM2711_PM_BASE + 0x20)
#define BCM2711_PM_RSTS_HADDRQ   0x00000001
#define BCM2711_PM_RSTS_HADDRF   0x00000002
#define BCM2711_PM_RSTS_HADDRH   0x00000004
#define BCM2711_PM_RSTS_HADWRQ   0x00000010
#define BCM2711_PM_RSTS_HADWRF   0x0000002
#define BCM2711_PM_RSTS_HADWRH   0x00000040
#define BCM2711_PM_RSTS_HADSRQ   0x00000100
#define BCM2711_PM_RSTS_HADSRF   0x00000200
#define BCM2711_PM_RSTS_HADSRH   0x00000400
#define BCM2711_PM_RSTS_HADPOR   0x00001000
#define BCM2711_PM_WDOG   (BCM2711_PM_BASE + 0x24)
#define BCM2711_PM_WDOG_MASK   0x000fffff
#define BCM2835_CLOCK_FREQ   250000000
#define BCM2835_TIMER_BASE   (RPI_PERIPHERAL_BASE + 0xB400)
#define BCM2835_TIMER_LOD   (BCM2835_TIMER_BASE + 0x00)
#define BCM2835_TIMER_VAL   (BCM2835_TIMER_BASE + 0x04)
#define BCM2835_TIMER_CTL   (BCM2835_TIMER_BASE + 0x08)
#define BCM2835_TIMER_CLI   (BCM2835_TIMER_BASE + 0x0C)
#define BCM2835_TIMER_RIS   (BCM2835_TIMER_BASE + 0x10)
#define BCM2835_TIMER_MIS   (BCM2835_TIMER_BASE + 0x14)
#define BCM2835_TIMER_RLD   (BCM2835_TIMER_BASE + 0x18)
#define BCM2835_TIMER_DIV   (BCM2835_TIMER_BASE + 0x1C)
#define BCM2835_TIMER_CNT   (BCM2835_TIMER_BASE + 0x20)
#define BCM2835_TIMER_PRESCALE   0xF9
#define BCM2835_PM_PASSWD_MAGIC   0x5a000000
#define BCM2835_PM_BASE   (RPI_PERIPHERAL_BASE + 0x100000)
#define BCM2835_PM_GNRIC   (BCM2835_PM_BASE + 0x00)
#define BCM2835_PM_GNRIC_POWUP   0x00000001
#define BCM2835_PM_GNRIC_POWOK   0x00000002
#define BCM2835_PM_GNRIC_ISPOW   0x00000004
#define BCM2835_PM_GNRIC_MEMREP   0x00000008
#define BCM2835_PM_GNRIC_MRDONE   0x00000010
#define BCM2835_PM_GNRIC_ISFUNC   0x00000020
#define BCM2835_PM_GNRIC_RSTN   0x00000fc0
#define BCM2835_PM_GNRIC_ENAB   0x00001000
#define BCM2835_PM_GNRIC_CFG   0x007f0000
#define BCM2835_PM_AUDIO   (BCM2835_PM_BASE + 0x04)
#define BCM2835_PM_AUDIO_APSM   0x000fffff
#define BCM2835_PM_AUDIO_CTRLEN   0x00100000
#define BCM2835_PM_AUDIO_RSTN   0x00200000
#define BCM2835_PM_STATUS   (BCM2835_PM_BASE + 0x18)
#define BCM2835_PM_RSTC   (BCM2835_PM_BASE + 0x1c)
#define BCM2835_PM_RSTC_DRCFG   0x00000003
#define BCM2835_PM_RSTC_WRCFG   0x00000030
#define BCM2835_PM_RSTC_WRCFG_FULL   0x00000020
#define BCM2835_PM_RSTC_SRCFG   0x00000300
#define BCM2835_PM_RSTC_QRCFG   0x00003000
#define BCM2835_PM_RSTC_FRCFG   0x00030000
#define BCM2835_PM_RSTC_HRCFG   0x00300000
#define BCM2835_PM_RSTS   (BCM2835_PM_BASE + 0x20)
#define BCM2835_PM_RSTS_HADDRQ   0x00000001
#define BCM2835_PM_RSTS_HADDRF   0x00000002
#define BCM2835_PM_RSTS_HADDRH   0x00000004
#define BCM2835_PM_RSTS_HADWRQ   0x00000010
#define BCM2835_PM_RSTS_HADWRF   0x00000020
#define BCM2835_PM_RSTS_HADWRH   0x00000040
#define BCM2835_PM_RSTS_HADSRQ   0x00000100
#define BCM2835_PM_RSTS_HADSRF   0x00000200
#define BCM2835_PM_RSTS_HADSRH   0x00000400
#define BCM2835_PM_RSTS_HADPOR   0x00001000
#define BCM2835_PM_WDOG   (BCM2835_PM_BASE + 0x24)
GPIO Registers
#define BCM2835_GPIO_REGS_BASE   (RPI_PERIPHERAL_BASE + 0x200000)
#define BCM2835_GPIO_GPFSEL1   (BCM2835_GPIO_REGS_BASE + 0x04)
#define BCM2835_GPIO_GPSET0   (BCM2835_GPIO_REGS_BASE + 0x1C)
#define BCM2835_GPIO_GPCLR0   (BCM2835_GPIO_REGS_BASE + 0x28)
#define BCM2835_GPIO_GPLEV0   (BCM2835_GPIO_REGS_BASE + 0x34)
#define BCM2835_GPIO_GPEDS0   (BCM2835_GPIO_REGS_BASE + 0x40)
#define BCM2835_GPIO_GPREN0   (BCM2835_GPIO_REGS_BASE + 0x4C)
#define BCM2835_GPIO_GPFEN0   (BCM2835_GPIO_REGS_BASE + 0x58)
#define BCM2835_GPIO_GPHEN0   (BCM2835_GPIO_REGS_BASE + 0x64)
#define BCM2835_GPIO_GPLEN0   (BCM2835_GPIO_REGS_BASE + 0x70)
#define BCM2835_GPIO_GPAREN0   (BCM2835_GPIO_REGS_BASE + 0x7C)
#define BCM2835_GPIO_GPAFEN0   (BCM2835_GPIO_REGS_BASE + 0x88)
#define BCM2835_GPIO_GPPUD   (BCM2835_GPIO_REGS_BASE + 0x94)
#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE + 0x98)
AUX Registers
#define BCM2835_AUX_BASE   (RPI_PERIPHERAL_BASE + 0x215000)
#define AUX_ENABLES   (BCM2835_AUX_BASE + 0x04)
#define AUX_MU_IO_REG   (BCM2835_AUX_BASE + 0x40)
#define AUX_MU_IER_REG   (BCM2835_AUX_BASE + 0x44)
#define AUX_MU_IIR_REG   (BCM2835_AUX_BASE + 0x48)
#define AUX_MU_LCR_REG   (BCM2835_AUX_BASE + 0x4C)
#define AUX_MU_MCR_REG   (BCM2835_AUX_BASE + 0x50)
#define AUX_MU_LSR_REG   (BCM2835_AUX_BASE + 0x54)
#define AUX_MU_MSR_REG   (BCM2835_AUX_BASE + 0x58)
#define AUX_MU_SCRATCH   (BCM2835_AUX_BASE + 0x5C)
#define AUX_MU_CNTL_REG   (BCM2835_AUX_BASE + 0x60)
#define AUX_MU_STAT_REG   (BCM2835_AUX_BASE + 0x64)
#define AUX_MU_BAUD_REG   (BCM2835_AUX_BASE + 0x68)
◆ BCM2711_BIT
#define BCM2711_BIT ( n)
Value:
(1 << (n))
◆ BCM2711_REG
#define BCM2711_REG ( x)
Value:
(*(volatile uint64_t *)(x))
◆ BCM2835_BIT
#define BCM2835_BIT ( n)
Value:
(1 << (n))
◆ BCM2835_REG [1/2]
#define BCM2835_REG ( addr)
Value:
(*(volatile uint32_t*)(addr))
◆ BCM2835_REG [2/2]
#define BCM2835_REG ( x)
Value:
(*(volatile uint32_t *)(x))
◆ BUS_TO_PHY [1/2]
#define BUS_TO_PHY ( x)
Value:
((x) - BASE_OFFSET)
◆ BUS_TO_PHY [2/2]
Value:
((x) - BASE_OFFSET)
