RTEMS 6.3
Nic301
#define FSL_COMPONENT_ID   "platform.drivers.nic301"
Driver version
enum  _nic_reg {
  kNIC_REG_READ_QOS_LCD = NIC_LCD_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_CSI = NIC_CSI_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_PXP = NIC_PXP_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_DCP = NIC_DCP_BASE + NIC_READ_QOS_OFFSET ,
  kNIC_REG_READ_QOS_ENET = NIC_ENET_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_USBO2 = NIC_USBO2_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_USDHC1 = NIC_USDHC1_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_USDHC2 = NIC_USDHC2_BASE + NIC_READ_QOS_OFFSET ,
  kNIC_REG_READ_QOS_TestPort = NIC_TestPort_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_CM7 = NIC_CM7_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_DMA = NIC_DMA_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_WRITE_QOS_LCD = NIC_LCD_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_CSI = NIC_CSI_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_PXP = NIC_PXP_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_DCP = NIC_DCP_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_ENET = NIC_ENET_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_USBO2 = NIC_USBO2_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_USDHC1 = NIC_USDHC1_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_USDHC2 = NIC_USDHC2_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_TestPort = NIC_TestPort_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_CM7 = NIC_CM7_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_DMA = NIC_DMA_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_FN_MOD_LCD = NIC_LCD_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_CSI = NIC_CSI_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_PXP = NIC_PXP_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_DCP = NIC_DCP_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_ENET = NIC_ENET_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_USBO2 = NIC_USBO2_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_USDHC1 = NIC_USDHC1_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_USDHC2 = NIC_USDHC2_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_TestPort = NIC_TestPort_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_CM7 = NIC_CM7_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_DMA = NIC_DMA_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD2_DCP = NIC_ENET_BASE + NIC_FN_MOD2_OFFSET , kNIC_REG_FN_MOD_AHB_ENET = NIC_ENET_BASE + NIC_FN_MOD_AHB_OFFSET , kNIC_REG_FN_MOD_AHB_TestPort = NIC_TestPort_BASE + NIC_FN_MOD_AHB_OFFSET ,
  kNIC_REG_FN_MOD_AHB_DMA = NIC_DMA_BASE + NIC_FN_MOD_AHB_OFFSET , kNIC_REG_WR_TIDEMARK_CM7 = NIC_CM7_BASE + NIC_WR_TIDEMARK_OFFSET
enum  _nic_fn_mod2 { kNIC_FN_MOD2_ENABLE = 0 , kNIC_FN_MOD2_BYPASS }
enum  _nic_fn_mod_ahb { kNIC_FN_MOD_AHB_RD_INCR_OVERRIDE = 0 , kNIC_FN_MOD_AHB_WR_INCR_OVERRIDE , kNIC_FN_MOD_AHB_LOCK_OVERRIDE }
enum  _nic_fn_mod { kNIC_FN_MOD_ReadIssue = 0 , kNIC_FN_MOD_WriteIssue }
enum  _nic_qos {
  kNIC_QOS_0 = 0 , kNIC_QOS_1 , kNIC_QOS_2 , kNIC_QOS_3 ,
  kNIC_QOS_4 , kNIC_QOS_5 , kNIC_QOS_6 , kNIC_QOS_7 ,
  kNIC_QOS_8 , kNIC_QOS_9 , kNIC_QOS_10 , kNIC_QOS_11 ,
  kNIC_QOS_12 , kNIC_QOS_13 , kNIC_QOS_14 , kNIC_QOS_15
typedef enum _nic_reg nic_reg_t
typedef enum _nic_fn_mod2 nic_fn_mod2_t
typedef enum _nic_fn_mod_ahb nic_fn_mod_ahb_t
typedef enum _nic_fn_mod nic_fn_mod_t
typedef enum _nic_qos nic_qos_t
#define NIC_FN_MOD2_OFFSET   (0x024UL)
#define NIC_LCD_BASE   (GPV0_BASE + 0x44000)
#define NIC_DCP_BASE   (GPV1_BASE + 0x42000)
#define NIC_TestPort_BASE   (GPV1_BASE + 0x47000)
#define NIC_FN_MOD2_MASK   (0x1)
Driver version
enum  _nic_reg {
  kNIC_REG_READ_QOS_GC355 = NIC_GC355_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_PXP = NIC_PXP_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_LCDIF = NIC_LCDIF_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_LCDIFV2 = NIC_LCDIFV2_BASE + NIC_READ_QOS_OFFSET ,
  kNIC_REG_READ_QOS_CSI = NIC_CSI_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_CAAM = NIC_CAAM_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_ENET1G_RX = NIC_ENET1G_RX_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_ENET1G_TX = NIC_ENET1G_TX_BASE + NIC_READ_QOS_OFFSET ,
  kNIC_REG_READ_QOS_ENET_QOS = NIC_ENET_QOS_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_CM7 = NIC_CM7_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_DMA = NIC_DMA_BASE + NIC_READ_QOS_OFFSET , kNIC_REG_READ_QOS_IEE = NIC_IEE_BASE + NIC_READ_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_GC355 = NIC_GC355_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_PXP = NIC_PXP_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_LCDIF = NIC_LCDIF_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_LCDIFV2 = NIC_LCDIFV2_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_CSI = NIC_CSI_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_CAAM = NIC_CAAM_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_ENET1G_RX = NIC_ENET1G_RX_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_ENET1G_TX = NIC_ENET1G_TX_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_ENET = NIC_ENET_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_USBO2 = NIC_USBO2_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_USDHC1 = NIC_USDHC1_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_USDHC2 = NIC_USDHC2_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_WRITE_QOS_ENET_QOS = NIC_ENET_QOS_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_CM7 = NIC_CM7_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_DMA = NIC_DMA_BASE + NIC_WRITE_QOS_OFFSET , kNIC_REG_WRITE_QOS_IEE = NIC_IEE_BASE + NIC_WRITE_QOS_OFFSET ,
  kNIC_REG_FN_MOD_GC355 = NIC_GC355_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_PXP = NIC_PXP_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_LCDIF = NIC_LCDIF_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_LCDIFV2 = NIC_LCDIFV2_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_CSI = NIC_CSI_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_CAAM = NIC_CAAM_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_ENET1G_RX = NIC_ENET1G_RX_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_ENET1G_TX = NIC_ENET1G_TX_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_ENET = NIC_ENET_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_USBO2 = NIC_USBO2_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_USDHC1 = NIC_USDHC1_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_USDHC2 = NIC_USDHC2_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_ENET_QOS = NIC_ENET_QOS_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_CM7 = NIC_CM7_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_DMA = NIC_DMA_BASE + NIC_FN_MOD_OFFSET , kNIC_REG_FN_MOD_IEE = NIC_IEE_BASE + NIC_FN_MOD_OFFSET ,
  kNIC_REG_FN_MOD_AHB_ENET = NIC_ENET_BASE + NIC_FN_MOD_AHB_OFFSET , kNIC_REG_FN_MOD_AHB_DMA = NIC_DMA_BASE + NIC_FN_MOD_AHB_OFFSET , kNIC_REG_WR_TIDEMARK_LPSRMIX_M = NIC_LPSRMIX_M_BASE + NIC_WR_TIDEMARK_OFFSET
enum  _nic_qos {
#define FSL_NIC301_DRIVER_VERSION   (MAKE_VERSION(2U, 0U, 1U))
 NIC301 driver version 2.0.1.
#define GPV0_BASE   (0x41000000UL)
#define GPV1_BASE   (0x41100000UL)
#define GPV4_BASE   (0x41400000UL)
#define NIC_FN_MOD_AHB_OFFSET   (0x028UL)
#define NIC_WR_TIDEMARK_OFFSET   (0x040UL)
#define NIC_READ_QOS_OFFSET   (0x100UL)
#define NIC_WRITE_QOS_OFFSET   (0x104UL)
#define NIC_FN_MOD_OFFSET   (0x108UL)
#define NIC_CSI_BASE   (GPV0_BASE + 0x45000)
#define NIC_PXP_BASE   (GPV0_BASE + 0x46000)
#define NIC_ENET_BASE   (GPV1_BASE + 0x43000)
#define NIC_USBO2_BASE   (GPV1_BASE + 0x44000)
#define NIC_USDHC1_BASE   (GPV1_BASE + 0x45000)
#define NIC_USDHC2_BASE   (GPV1_BASE + 0x46000)
#define NIC_CM7_BASE   (GPV4_BASE + 0x42000)
#define NIC_DMA_BASE   (GPV4_BASE + 0x43000)
#define NIC_QOS_MASK   (0xF)
#define NIC_WR_TIDEMARK_MASK   (0x7)
#define NIC_FN_MOD_AHB_MASK   (0x7)
#define NIC_FN_MOD_MASK   (0x1)
#define NIC_GC355_BASE   (GPV0_BASE + 0x42000)
#define NIC_PXP_BASE   (GPV0_BASE + 0x43000)
#define NIC_LCDIF_BASE   (GPV0_BASE + 0x44000)
#define NIC_LCDIFV2_BASE   (GPV0_BASE + 0x45000)
#define NIC_CSI_BASE   (GPV0_BASE + 0x46000)
#define NIC_CAAM_BASE   (GPV1_BASE + 0x42000)
#define NIC_ENET1G_RX_BASE   (GPV1_BASE + 0x43000)
#define NIC_ENET1G_TX_BASE   (GPV1_BASE + 0x44000)
#define NIC_ENET_BASE   (GPV1_BASE + 0x45000)
#define NIC_USBO2_BASE   (GPV1_BASE + 0x46000)
#define NIC_USDHC1_BASE   (GPV1_BASE + 0x47000)
#define NIC_USDHC2_BASE   (GPV1_BASE + 0x48000)
#define NIC_ENET_QOS_BASE   (GPV1_BASE + 0x4A000)
#define NIC_LPSRMIX_M_BASE   (GPV4_BASE + 0x46000)
#define NIC_DMA_BASE   (GPV4_BASE + 0x47000)
#define NIC_IEE_BASE   (GPV4_BASE + 0x48000)
#define NIC_WR_TIDEMARK_MASK   (0xF)
