RTEMS 6.3
Mu
#define MU_CR_NMI_MASK   0U
Driver version
enum  _mu_status_flags {
  kMU_Tx0EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 3U)) , kMU_Tx1EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 2U)) , kMU_Tx2EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 1U)) , kMU_Tx3EmptyFlag = (1U << (MU_SR_TEn_SHIFT + 0U)) ,
  kMU_Rx0FullFlag = (1U << (MU_SR_RFn_SHIFT + 3U)) , kMU_Rx1FullFlag = (1U << (MU_SR_RFn_SHIFT + 2U)) , kMU_Rx2FullFlag = (1U << (MU_SR_RFn_SHIFT + 1U)) , kMU_Rx3FullFlag = (1U << (MU_SR_RFn_SHIFT + 0U)) ,
  kMU_GenInt0Flag = (1U << (MU_SR_GIPn_SHIFT + 3U)) , kMU_GenInt1Flag = (1U << (MU_SR_GIPn_SHIFT + 2U)) , kMU_GenInt2Flag = (1U << (MU_SR_GIPn_SHIFT + 1U)) , kMU_GenInt3Flag = (1U << (MU_SR_GIPn_SHIFT + 0U)) ,
  kMU_EventPendingFlag = MU_SR_EP_MASK , kMU_FlagsUpdatingFlag = MU_SR_FUP_MASK
 MU status flags. More...
enum  _mu_interrupt_enable {
  kMU_Tx0EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 3U)) , kMU_Tx1EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 2U)) , kMU_Tx2EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 1U)) , kMU_Tx3EmptyInterruptEnable = (1U << (MU_CR_TIEn_SHIFT + 0U)) ,
  kMU_Rx0FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 3U)) , kMU_Rx1FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 2U)) , kMU_Rx2FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 1U)) , kMU_Rx3FullInterruptEnable = (1U << (MU_CR_RIEn_SHIFT + 0U)) ,
  kMU_GenInt0InterruptEnable = (int)(1U << (MU_CR_GIEn_SHIFT + 3U)) , kMU_GenInt1InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 2U)) , kMU_GenInt2InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 1U)) , kMU_GenInt3InterruptEnable = (1U << (MU_CR_GIEn_SHIFT + 0U))
 MU interrupt source to enable. More...
enum  _mu_interrupt_trigger {
  kMU_NmiInterruptTrigger = MU_CR_NMI_MASK , kMU_GenInt0InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 3U)) , kMU_GenInt1InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 2U)) , kMU_GenInt2InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 1U)) ,
  kMU_GenInt3InterruptTrigger = (1U << (MU_CR_GIRn_SHIFT + 0U))
 MU interrupt that could be triggered to the other core. More...
enum  _mu_msg_reg_index { kMU_MsgReg0 = 0 , kMU_MsgReg1 , kMU_MsgReg2 , kMU_MsgReg3 }
 MU message register.
typedef enum _mu_msg_reg_index mu_msg_reg_index_t
#define FSL_MU_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 MU driver version.
MU initialization.
void MU_Init (MU_Type *base)
 Initializes the MU module.
void MU_Deinit (MU_Type *base)
 De-initializes the MU module.
MU Message
void MU_SendMsg (MU_Type *base, uint32_t regIndex, uint32_t msg)
 Blocks to send a message.
uint32_t MU_ReceiveMsg (MU_Type *base, uint32_t regIndex)
 Blocks to receive a message.
MU Flags
void MU_SetFlags (MU_Type *base, uint32_t flags)
 Blocks setting the 3-bit MU flags reflect on the other MU side.
Status and Interrupt.
status_t MU_TriggerInterrupts (MU_Type *base, uint32_t mask)
 Triggers interrupts to the other core.
MU misc functions
void MU_BootCoreB (MU_Type *base, mu_core_boot_mode_t mode)
 Boots the core at B side.
void MU_BootOtherCore (MU_Type *base, mu_core_boot_mode_t mode)
 Boots the other core.
void MU_HardwareResetOtherCore (MU_Type *base, bool waitReset, bool holdReset, mu_core_boot_mode_t bootMode)
 Hardware reset the other core.
◆ _mu_interrupt_enable
TX0 empty.
TX1 empty.
TX2 empty.
TX3 empty.
RX0 full.
RX1 full.
RX2 full.
RX3 full.
General purpose interrupt 0.
General purpose interrupt 1.
General purpose interrupt 2.
General purpose interrupt 3.
◆ _mu_interrupt_trigger
NMI interrupt.
◆ _mu_status_flags
MU status flags.
kMU_Tx0EmptyFlag
TX0 empty.
kMU_Tx1EmptyFlag
TX1 empty.
kMU_Tx2EmptyFlag
TX2 empty.
kMU_Tx3EmptyFlag
TX3 empty.
kMU_Rx0FullFlag
RX0 full.
kMU_Rx1FullFlag
RX1 full.
kMU_Rx2FullFlag
RX2 full.
kMU_Rx3FullFlag
RX3 full.
kMU_GenInt0Flag
General purpose interrupt 0 pending.
kMU_GenInt1Flag
General purpose interrupt 1 pending.
kMU_GenInt2Flag
General purpose interrupt 2 pending.
kMU_GenInt3Flag
General purpose interrupt 3 pending.
MU event pending.
MU flags update is on-going.
◆ MU_BootCoreB()
void MU_BootCoreB ( MU_Type * base,
mu_core_boot_mode_t mode )
This function sets the B side core's boot configuration and releases the core from reset.
Parameters
baseMU peripheral base address.
modeCore B boot mode.
Note
Only MU side A can use this function.
brief Boots the core at B side.
param base MU peripheral base address. param mode Core B boot mode. note Only MU side A can use this function.
◆ MU_BootOtherCore()
void MU_BootOtherCore ( MU_Type * base,
This function boots the other core with a boot configuration.
Parameters
modeThe other core boot mode.
brief Boots the other core.
param base MU peripheral base address. param mode The other core boot mode.
◆ MU_Deinit()
void MU_Deinit ( MU_Type * base)
This function disables the MU clock only.
Parameters
brief De-initializes the MU module.
◆ MU_HardwareResetOtherCore()
void MU_HardwareResetOtherCore ( MU_Type * base,
bool waitReset,
bool holdReset,
mu_core_boot_mode_t bootMode )
This function resets the other core, the other core could mask the hardware reset by calling MU_MaskHardwareReset. The hardware reset mask feature is only available for some platforms. This function could be used together with MU_BootOtherCore to control the other core reset workflow.
Example 1: Reset the other core, and no hold reset
MU_HardwareResetOtherCore(MU_A, true, false, bootMode);
void MU_HardwareResetOtherCore(MU_Type *base, bool waitReset, bool holdReset, mu_core_boot_mode_t bootMode)
Definition fsl_mu.c:358
In this example, the core at MU side B will reset with the specified boot mode.
Example 2: Reset the other core and hold it, then boot the other core later.
Here the other core enters reset, and the reset is hold
MU_HardwareResetOtherCore(MU_A, true, true, modeDontCare);
Current core boot the other core when necessary.
MU_BootOtherCore(MU_A, bootMode);
Parameters
waitResetWait the other core enters reset.
  • true: Wait until the other core enters reset, if the other core has masked the hardware reset, then this function will be blocked.
  • false: Don't wait the reset.
holdResetHold the other core reset or not.
  • true: Hold the other core in reset, this function returns directly when the other core enters reset.
  • false: Don't hold the other core in reset, this function waits until the other core out of reset.
bootModeBoot mode of the other core, if holdReset is true, this parameter is useless.
brief Hardware reset the other core.
This function resets the other core, the other core could mask the hardware reset by calling ref MU_MaskHardwareReset. The hardware reset mask feature is only available for some platforms. This function could be used together with MU_BootOtherCore to control the other core reset workflow.
Example 1: Reset the other core, and no hold reset code MU_HardwareResetOtherCore(MU_A, true, false, bootMode); endcode In this example, the core at MU side B will reset with the specified boot mode.
Example 2: Reset the other core and hold it, then boot the other core later. code Here the other core enters reset, and the reset is hold MU_HardwareResetOtherCore(MU_A, true, true, modeDontCare); Current core boot the other core when necessary. MU_BootOtherCore(MU_A, bootMode); endcode
param base MU peripheral base address. param waitReset Wait the other core enters reset.
  • false: Don't wait the reset. param holdReset Hold the other core reset or not.
  • false: Don't hold the other core in reset, this function waits until the other core out of reset. param bootMode Boot mode of the other core, if p holdReset is true, this parameter is useless.
◆ MU_Init()
void MU_Init ( MU_Type * base)
This function enables the MU clock only.
Parameters
brief Initializes the MU module.
◆ MU_ReceiveMsg()
uint32_t MU_ReceiveMsg ( MU_Type * base,
uint32_t regIndex )
This function waits until the RX register is full and receives the message.
Parameters
regIndexMU message register, see mu_msg_reg_index_t
Returns
The received message.
brief Blocks to receive a message.
param base MU peripheral base address. param regIndex RX register index. return The received message.
◆ MU_SendMsg()
void MU_SendMsg ( MU_Type * base,
uint32_t regIndex,
uint32_t msg )
This function waits until the TX register is empty and sends the message.
Parameters
msgMessage to send.
brief Blocks to send a message.
param base MU peripheral base address. param regIndex TX register index. param msg Message to send.
◆ MU_SetFlags()
void MU_SetFlags ( MU_Type * base,
uint32_t flags )
This function blocks setting the 3-bit MU flags. Every time the 3-bit MU flags are changed, the status flag kMU_FlagsUpdatingFlag asserts indicating the 3-bit MU flags are updating to the other side. After the 3-bit MU flags are updated, the status flag kMU_FlagsUpdatingFlag is cleared by hardware. During the flags updating period, the flags cannot be changed. This function waits for the MU status flag kMU_FlagsUpdatingFlag cleared and sets the 3-bit MU flags.
Parameters
flagsThe 3-bit MU flags to set.
brief Blocks setting the 3-bit MU flags reflect on the other MU side.
param base MU peripheral base address. param flags The 3-bit MU flags to set.
◆ MU_TriggerInterrupts()
status_t MU_TriggerInterrupts ( MU_Type * base,
uint32_t mask )
This function triggers the specific interrupts to the other core. The interrupts to trigger are passed in as bit mask. See _mu_interrupt_trigger. The MU should not trigger an interrupt to the other core when the previous interrupt has not been processed by the other core. This function checks whether the previous interrupts have been processed. If not, it returns an error.
Previous general purpose interrupt 0 or general purpose interrupt 2
@ kStatus_Success
Definition fsl_common.h:211
status_t MU_TriggerInterrupts(MU_Type *base, uint32_t mask)
Definition fsl_mu.c:165
@ kMU_GenInt2InterruptTrigger
Definition fsl_mu.h:134
@ kMU_GenInt0InterruptTrigger
Definition fsl_mu.h:132
Parameters
maskBit mask of the interrupts to trigger. See _mu_interrupt_trigger.
Return values
kStatus_SuccessInterrupts have been triggered successfully.
kStatus_FailPrevious interrupts have not been accepted.
brief Triggers interrupts to the other core.
code if (kStatus_Success != MU_TriggerInterrupts(base, kMU_GenInt0InterruptTrigger | kMU_GenInt2InterruptTrigger)) { Previous general purpose interrupt 0 or general purpose interrupt 2 has not been processed by the other core. } endcode
param base MU peripheral base address. param mask Bit mask of the interrupts to trigger. See _mu_interrupt_trigger. retval kStatus_Success Interrupts have been triggered successfully. retval kStatus_Fail Previous interrupts have not been accepted.
