RTEMS 6.3
Usage
  • ISI_Init: initialize ISI with default parameters
  • ISI_EnableInterrupt: enable one or more interrupts
  • ISI_DisableInterrupt: disable one or more interrupts
  • ISI_Enable: enable isi module
  • ISI_Disable: disable isi module
  • ISI_CodecPathFull: enable codec path
  • ISI_SetFrame: set frame rate
  • ISI_BytesForOnePixel: return number of byte for one pixel
  • ISI_StatusRegister: return ISI status register
  • ISI_Reset: make a software reset
