RTEMS 6.3
Topics
 Ssarc_mapping
typedef enum _iomuxc_lpsr_sw_mux_ctl_pad iomuxc_lpsr_sw_mux_ctl_pad_t
 Enumeration for the IOMUXC_LPSR SW_MUX_CTL_PAD.
typedef enum _iomuxc_lpsr_sw_pad_ctl_pad iomuxc_lpsr_sw_pad_ctl_pad_t
 Enumeration for the IOMUXC_LPSR SW_PAD_CTL_PAD.
typedef enum _iomuxc_lpsr_select_input iomuxc_lpsr_select_input_t
 Enumeration for the IOMUXC_LPSR select input.
enum  _iomuxc_lpsr_sw_mux_ctl_pad {
  kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_00 = 0U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_01 = 1U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_02 = 2U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_03 = 3U ,
  kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_04 = 4U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_05 = 5U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_06 = 6U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_07 = 7U ,
  kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_08 = 8U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_09 = 9U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_10 = 10U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_11 = 11U ,
  kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_12 = 12U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_13 = 13U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_14 = 14U , kIOMUXC_LPSR_SW_MUX_CTL_PAD_GPIO_LPSR_15 = 15U
 Enumeration for the IOMUXC_LPSR SW_MUX_CTL_PAD. More...
enum  _iomuxc_lpsr_sw_pad_ctl_pad {
  kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_00 = 0U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_01 = 1U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_02 = 2U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_03 = 3U ,
  kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_04 = 4U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_05 = 5U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_06 = 6U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_07 = 7U ,
  kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_08 = 8U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_09 = 9U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_10 = 10U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_11 = 11U ,
  kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_12 = 12U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_13 = 13U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_14 = 14U , kIOMUXC_LPSR_SW_PAD_CTL_PAD_GPIO_LPSR_15 = 15U
 Enumeration for the IOMUXC_LPSR SW_PAD_CTL_PAD. More...
enum  _iomuxc_lpsr_select_input {
  kIOMUXC_LPSR_CAN3_IPP_IND_CANRX_SELECT_INPUT = 0U , kIOMUXC_LPSR_LPI2C5_IPP_IND_LPI2C_SCL_SELECT_INPUT = 1U , kIOMUXC_LPSR_LPI2C5_IPP_IND_LPI2C_SDA_SELECT_INPUT = 2U , kIOMUXC_LPSR_LPI2C6_IPP_IND_LPI2C_SCL_SELECT_INPUT = 3U ,
  kIOMUXC_LPSR_LPI2C6_IPP_IND_LPI2C_SDA_SELECT_INPUT = 4U , kIOMUXC_LPSR_LPSPI5_IPP_IND_LPSPI_PCS_SELECT_INPUT_0 = 5U , kIOMUXC_LPSR_LPSPI5_IPP_IND_LPSPI_SCK_SELECT_INPUT = 6U , kIOMUXC_LPSR_LPSPI5_IPP_IND_LPSPI_SDI_SELECT_INPUT = 7U ,
  kIOMUXC_LPSR_LPSPI5_IPP_IND_LPSPI_SDO_SELECT_INPUT = 8U , kIOMUXC_LPSR_LPUART11_IPP_IND_LPUART_RXD_SELECT_INPUT = 9U , kIOMUXC_LPSR_LPUART11_IPP_IND_LPUART_TXD_SELECT_INPUT = 10U , kIOMUXC_LPSR_LPUART12_IPP_IND_LPUART_RXD_SELECT_INPUT = 11U ,
  kIOMUXC_LPSR_LPUART12_IPP_IND_LPUART_TXD_SELECT_INPUT = 12U , kIOMUXC_LPSR_MIC_IPP_IND_MIC_PDM_BITSTREAM_SELECT_INPUT_0 = 13U , kIOMUXC_LPSR_MIC_IPP_IND_MIC_PDM_BITSTREAM_SELECT_INPUT_1 = 14U , kIOMUXC_LPSR_MIC_IPP_IND_MIC_PDM_BITSTREAM_SELECT_INPUT_2 = 15U ,
  kIOMUXC_LPSR_MIC_IPP_IND_MIC_PDM_BITSTREAM_SELECT_INPUT_3 = 16U , kIOMUXC_LPSR_NMI_GLUE_IPP_IND_NMI_SELECT_INPUT = 17U , kIOMUXC_LPSR_SAI4_IPG_CLK_SAI_MCLK_SELECT_INPUT = 18U , kIOMUXC_LPSR_SAI4_IPP_IND_SAI_RXBCLK_SELECT_INPUT = 19U ,
  kIOMUXC_LPSR_SAI4_IPP_IND_SAI_RXDATA_SELECT_INPUT_0 = 20U , kIOMUXC_LPSR_SAI4_IPP_IND_SAI_RXSYNC_SELECT_INPUT = 21U , kIOMUXC_LPSR_SAI4_IPP_IND_SAI_TXBCLK_SELECT_INPUT = 22U , kIOMUXC_LPSR_SAI4_IPP_IND_SAI_TXSYNC_SELECT_INPUT = 23U
 Enumeration for the IOMUXC_LPSR select input. More...
Typedef Documentation
◆ iomuxc_lpsr_select_input_t [1/2]
Defines the enumeration for the IOMUXC_LPSR select input collections.
◆ iomuxc_lpsr_select_input_t [2/2]
◆ iomuxc_lpsr_sw_mux_ctl_pad_t [1/2]
Defines the enumeration for the IOMUXC_LPSR SW_MUX_CTL_PAD collections.
◆ iomuxc_lpsr_sw_mux_ctl_pad_t [2/2]
◆ iomuxc_lpsr_sw_pad_ctl_pad_t [1/2]
Defines the enumeration for the IOMUXC_LPSR SW_PAD_CTL_PAD collections.
◆ iomuxc_lpsr_sw_pad_ctl_pad_t [2/2]
◆ _iomuxc_lpsr_select_input [1/2]
IOMUXC select input index
◆ _iomuxc_lpsr_select_input [2/2]
◆ _iomuxc_lpsr_sw_mux_ctl_pad [1/2]
IOMUXC SW_MUX_CTL_PAD index
◆ _iomuxc_lpsr_sw_mux_ctl_pad [2/2]
◆ _iomuxc_lpsr_sw_pad_ctl_pad [1/2]
IOMUXC SW_PAD_CTL_PAD index
◆ _iomuxc_lpsr_sw_pad_ctl_pad [2/2]
