RTEMS 6.3
| #define | ctz(u) |
| Counts the trailing zero bits of the given value considered as a 32-bit integer. | |
Interrupt Service Routine definition | |
| #define | Enable_global_interrupt() |
| #define | Disable_global_interrupt() |
| #define | Is_global_interrupt_enabled() |
Usual Constants | |
| #define | DISABLE 0 |
| #define | ENABLE 1 |
| #define | DISABLED 0 |
| #define | ENABLED 1 |
| #define | OFF 0 |
| #define | ON 1 |
| #define | FALSE 0 |
| #define | TRUE 1 |
| #define | false FALSE |
| #define | true TRUE |
| #define | KO 0 |
| #define | OK 1 |
| #define | PASS 0 |
| #define | FAIL 1 |
| #define | LOW 0 |
| #define | HIGH 1 |
| #define | CLR 0 |
| #define | SET 1 |
| #define ctz | ( | u | ) |
| u | Value of which to count the trailing zero bits. |
| #define Disable_global_interrupt | ( | ) |
| #define Enable_global_interrupt | ( | ) |
| #define Is_global_interrupt_enabled | ( | ) |
