RTEMS
6.3
Toggle main menu visibility
Topics
Gmacd_module
Board Support Packages
ARM
Atmel/Microchip SAM E70, S70, V70 and V71
Contributed Code
Topics
GMAC Driver Defines
GMAC Driver Functions
GMAC Driver Types
Implement GMAC data transfer and PHY management functions.
Usage
Implement GMAC interrupt handler, which must invoke
GMACD_Handler()
to handle GMAC interrupt events.
Implement
sGmacd
instance in application.
Initialize the instance with
GMACD_Init()
and
GMACD_InitTransfer()
, so that GMAC data can be transmitted/received.
Some management callbacks can be set by
GMACD_SetRxCallback()
and
GMACD_SetTxWakeupCallback()
Send ethernet packets using
GMACD_Send()
GMACD_TxLoad()
is used to check the free space in TX queue.
Check and obtain received ethernet packets via
GMACD_Poll()
See also
Ethernet GMACB Driver
Gmac_module
Related files:
gmacd.c
gmacd.h.
