RTEMS 6.3
| struct | _flexio_i2c_type |
| Define FlexIO I2C master access structure typedef. More... | |
| struct | _flexio_i2c_master_config |
| Define FlexIO I2C master user configuration structure. More... | |
| struct | _flexio_i2c_master_transfer |
| Define FlexIO I2C master transfer structure. More... | |
| struct | _flexio_i2c_master_handle |
| Define FlexIO I2C master handle structure. More... | |
Driver version | |
| enum | { kStatus_FLEXIO_I2C_Busy = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 0) , kStatus_FLEXIO_I2C_Idle = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 1) , kStatus_FLEXIO_I2C_Nak = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 2) , kStatus_FLEXIO_I2C_Timeout = MAKE_STATUS(kStatusGroup_FLEXIO_I2C, 3) } |
| FlexIO I2C transfer status. More... | |
| enum | _flexio_i2c_master_interrupt { kFLEXIO_I2C_TxEmptyInterruptEnable = 0x1U , kFLEXIO_I2C_RxFullInterruptEnable = 0x2U } |
| Define FlexIO I2C master interrupt mask. More... | |
| enum | _flexio_i2c_master_status_flags { kFLEXIO_I2C_TxEmptyFlag = 0x1U , kFLEXIO_I2C_RxFullFlag = 0x2U , kFLEXIO_I2C_ReceiveNakFlag = 0x4U } |
| Define FlexIO I2C master status mask. More... | |
| enum | _flexio_i2c_direction { kFLEXIO_I2C_Write = 0x0U , kFLEXIO_I2C_Read = 0x1U } |
| Direction of master transfer. More... | |
| typedef enum _flexio_i2c_direction | flexio_i2c_direction_t |
| Direction of master transfer. | |
| typedef struct _flexio_i2c_type | FLEXIO_I2C_Type |
| Define FlexIO I2C master access structure typedef. | |
| typedef struct _flexio_i2c_master_config | flexio_i2c_master_config_t |
| Define FlexIO I2C master user configuration structure. | |
| typedef struct _flexio_i2c_master_transfer | flexio_i2c_master_transfer_t |
| Define FlexIO I2C master transfer structure. | |
| typedef struct _flexio_i2c_master_handle | flexio_i2c_master_handle_t |
| FlexIO I2C master handle typedef. | |
| typedef void(*) | flexio_i2c_master_transfer_callback_t(FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, status_t status, void *userData) |
| FlexIO I2C master transfer callback typedef. | |
| #define | FSL_FLEXIO_I2C_MASTER_DRIVER_VERSION (MAKE_VERSION(2, 5, 0)) |
| #define | I2C_RETRY_TIMES 0U |
| Retry times for waiting flag. | |
Initialization and deinitialization | |
| status_t | FLEXIO_I2C_MasterInit (FLEXIO_I2C_Type *base, flexio_i2c_master_config_t *masterConfig, uint32_t srcClock_Hz) |
| Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO I2C hardware configuration. | |
| void | FLEXIO_I2C_MasterDeinit (FLEXIO_I2C_Type *base) |
| De-initializes the FlexIO I2C master peripheral. Calling this API Resets the FlexIO I2C master shifer and timer config, module can't work unless the FLEXIO_I2C_MasterInit is called. | |
| void | FLEXIO_I2C_MasterGetDefaultConfig (flexio_i2c_master_config_t *masterConfig) |
| Gets the default configuration to configure the FlexIO module. The configuration can be used directly for calling the FLEXIO_I2C_MasterInit(). | |
Status | |
| uint32_t | FLEXIO_I2C_MasterGetStatusFlags (FLEXIO_I2C_Type *base) |
| Gets the FlexIO I2C master status flags. | |
| void | FLEXIO_I2C_MasterClearStatusFlags (FLEXIO_I2C_Type *base, uint32_t mask) |
| Clears the FlexIO I2C master status flags. | |
Interrupts | |
| void | FLEXIO_I2C_MasterEnableInterrupts (FLEXIO_I2C_Type *base, uint32_t mask) |
| Enables the FlexIO i2c master interrupt requests. | |
| void | FLEXIO_I2C_MasterDisableInterrupts (FLEXIO_I2C_Type *base, uint32_t mask) |
| Disables the FlexIO I2C master interrupt requests. | |
Bus Operations | |
| void | FLEXIO_I2C_MasterSetBaudRate (FLEXIO_I2C_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz) |
| Sets the FlexIO I2C master transfer baudrate. | |
| void | FLEXIO_I2C_MasterStart (FLEXIO_I2C_Type *base, uint8_t address, flexio_i2c_direction_t direction) |
| Sends START + 7-bit address to the bus. | |
| void | FLEXIO_I2C_MasterStop (FLEXIO_I2C_Type *base) |
| Sends the stop signal on the bus. | |
| void | FLEXIO_I2C_MasterRepeatedStart (FLEXIO_I2C_Type *base) |
| Sends the repeated start signal on the bus. | |
| void | FLEXIO_I2C_MasterAbortStop (FLEXIO_I2C_Type *base) |
| Sends the stop signal when transfer is still on-going. | |
| void | FLEXIO_I2C_MasterEnableAck (FLEXIO_I2C_Type *base, bool enable) |
| Configures the sent ACK/NAK for the following byte. | |
| status_t | FLEXIO_I2C_MasterSetTransferCount (FLEXIO_I2C_Type *base, uint16_t count) |
| Sets the number of bytes to be transferred from a start signal to a stop signal. | |
| status_t | FLEXIO_I2C_MasterWriteBlocking (FLEXIO_I2C_Type *base, const uint8_t *txBuff, uint8_t txSize) |
| Sends a buffer of data in bytes. | |
| status_t | FLEXIO_I2C_MasterReadBlocking (FLEXIO_I2C_Type *base, uint8_t *rxBuff, uint8_t rxSize) |
| Receives a buffer of bytes. | |
| status_t | FLEXIO_I2C_MasterTransferBlocking (FLEXIO_I2C_Type *base, flexio_i2c_master_transfer_t *xfer) |
| Performs a master polling transfer on the I2C bus. | |
Transactional | |
| status_t | FLEXIO_I2C_MasterTransferCreateHandle (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, flexio_i2c_master_transfer_callback_t callback, void *userData) |
| Initializes the I2C handle which is used in transactional functions. | |
| status_t | FLEXIO_I2C_MasterTransferNonBlocking (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, flexio_i2c_master_transfer_t *xfer) |
| Performs a master interrupt non-blocking transfer on the I2C bus. | |
| status_t | FLEXIO_I2C_MasterTransferGetCount (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle, size_t *count) |
| Gets the master transfer status during a interrupt non-blocking transfer. | |
| void | FLEXIO_I2C_MasterTransferAbort (FLEXIO_I2C_Type *base, flexio_i2c_master_handle_t *handle) |
| Aborts an interrupt non-blocking transfer early. | |
| void | FLEXIO_I2C_MasterTransferHandleIRQ (void *i2cType, void *i2cHandle) |
| Master interrupt handler. | |
| anonymous enum |
| void FLEXIO_I2C_MasterAbortStop | ( | FLEXIO_I2C_Type * | base | ) |
| base | Pointer to FLEXIO_I2C_Type structure. |
brief Sends the stop signal when transfer is still on-going.
param base Pointer to FLEXIO_I2C_Type structure.
| void FLEXIO_I2C_MasterClearStatusFlags | ( | FLEXIO_I2C_Type * | base, |
| uint32_t | mask ) |
| mask | Status flag. The parameter can be any combination of the following values:
param base Pointer to FLEXIO_I2C_Type structure. param mask Status flag. The parameter can be any combination of the following values: arg kFLEXIO_I2C_RxFullFlag arg kFLEXIO_I2C_ReceiveNakFlag
| void FLEXIO_I2C_MasterDeinit | ( | FLEXIO_I2C_Type * | base | ) |
| base | pointer to FLEXIO_I2C_Type structure. |
brief De-initializes the FlexIO I2C master peripheral. Calling this API Resets the FlexIO I2C master shifer and timer config, module can't work unless the FLEXIO_I2C_MasterInit is called.
param base pointer to FLEXIO_I2C_Type structure.
| void FLEXIO_I2C_MasterDisableInterrupts | ( | FLEXIO_I2C_Type * | base, |
| uint32_t | mask ) |
| mask | Interrupt source. |
brief Disables the FlexIO I2C master interrupt requests.
param base Pointer to FLEXIO_I2C_Type structure. param mask Interrupt source.
| void FLEXIO_I2C_MasterEnableAck | ( | FLEXIO_I2C_Type * | base, |
| bool | enable ) |
| enable | True to configure send ACK, false configure to send NAK. |
brief Configures the sent ACK/NAK for the following byte.
param base Pointer to FLEXIO_I2C_Type structure. param enable True to configure send ACK, false configure to send NAK.
| void FLEXIO_I2C_MasterEnableInterrupts | ( | FLEXIO_I2C_Type * | base, |
| uint32_t | mask ) |
| mask | Interrupt source. Currently only one interrupt request source:
param base Pointer to FLEXIO_I2C_Type structure. param mask Interrupt source. Currently only one interrupt request source: arg kFLEXIO_I2C_TransferCompleteInterruptEnable
| void FLEXIO_I2C_MasterGetDefaultConfig | ( | flexio_i2c_master_config_t * | masterConfig | ) |
Example:
| masterConfig | Pointer to flexio_i2c_master_config_t structure. |
brief Gets the default configuration to configure the FlexIO module. The configuration can be used directly for calling the FLEXIO_I2C_MasterInit().
Example: code flexio_i2c_master_config_t config; FLEXIO_I2C_MasterGetDefaultConfig(&config); endcode param masterConfig Pointer to flexio_i2c_master_config_t structure.
| uint32_t FLEXIO_I2C_MasterGetStatusFlags | ( | FLEXIO_I2C_Type * | base | ) |
| base | Pointer to FLEXIO_I2C_Type structure |
brief Gets the FlexIO I2C master status flags.
param base Pointer to FLEXIO_I2C_Type structure return Status flag, use status flag to AND _flexio_i2c_master_status_flags can get the related status.
| status_t FLEXIO_I2C_MasterInit | ( | FLEXIO_I2C_Type * | base, |
| flexio_i2c_master_config_t * | masterConfig, | ||
| uint32_t | srcClock_Hz ) |
Example
| srcClock_Hz | FlexIO source clock in Hz. |
| kStatus_Success | Initialization successful |
| kStatus_InvalidArgument | The source clock exceed upper range limitation |
brief Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO I2C hardware configuration.
Example code FLEXIO_I2C_Type base = { .flexioBase = FLEXIO, .SDAPinIndex = 0, .SCLPinIndex = 1, .shifterIndex = {0,1}, .timerIndex = {0,1} }; flexio_i2c_master_config_t config = { .enableInDoze = false, .enableInDebug = true, .enableFastAccess = false, .baudRate_Bps = 100000 }; FLEXIO_I2C_MasterInit(base, &config, srcClock_Hz); endcode
param base Pointer to FLEXIO_I2C_Type structure. param masterConfig Pointer to flexio_i2c_master_config_t structure. param srcClock_Hz FlexIO source clock in Hz. retval kStatus_Success Initialization successful retval kStatus_InvalidArgument The source clock exceed upper range limitation
| status_t FLEXIO_I2C_MasterReadBlocking | ( | FLEXIO_I2C_Type * | base, |
| uint8_t * | rxBuff, | ||
| uint8_t | rxSize ) |
| rxBuff | The buffer to store the received bytes. |
| rxSize | The number of data bytes to be received. |
| kStatus_Success | Successfully read data. |
| kStatus_FLEXIO_I2C_Timeout | Timeout polling status flags. |
brief Receives a buffer of bytes.
note This function blocks via polling until all bytes have been received.
param base Pointer to FLEXIO_I2C_Type structure. param rxBuff The buffer to store the received bytes. param rxSize The number of data bytes to be received. retval kStatus_Success Successfully read data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
| void FLEXIO_I2C_MasterRepeatedStart | ( | FLEXIO_I2C_Type * | base | ) |
brief Sends the repeated start signal on the bus.
| void FLEXIO_I2C_MasterSetBaudRate | ( | FLEXIO_I2C_Type * | base, |
| uint32_t | baudRate_Bps, | ||
| baudRate_Bps | the baud rate value in HZ |
| srcClock_Hz | source clock in HZ |
brief Sets the FlexIO I2C master transfer baudrate.
param base Pointer to FLEXIO_I2C_Type structure param baudRate_Bps the baud rate value in HZ param srcClock_Hz source clock in HZ
| status_t FLEXIO_I2C_MasterSetTransferCount | ( | FLEXIO_I2C_Type * | base, |
| uint16_t | count ) |
| count | Number of bytes need to be transferred from a start signal to a re-start/stop signal |
| kStatus_Success | Successfully configured the count. |
| kStatus_InvalidArgument | Input argument is invalid. |
brief Sets the number of bytes to be transferred from a start signal to a stop signal.
note Call this API before a transfer begins because the timer generates a number of clocks according to the number of bytes that need to be transferred.
param base Pointer to FLEXIO_I2C_Type structure. param count Number of bytes need to be transferred from a start signal to a re-start/stop signal retval kStatus_Success Successfully configured the count. retval kStatus_InvalidArgument Input argument is invalid.
| void FLEXIO_I2C_MasterStart | ( | FLEXIO_I2C_Type * | base, |
| uint8_t | address, | ||
| flexio_i2c_direction_t | direction ) |
| address | 7-bit address. |
| direction | transfer direction. This parameter is one of the values in flexio_i2c_direction_t:
note This API should be called when the transfer configuration is ready to send a START signal and 7-bit address to the bus. This is a non-blocking API, which returns directly after the address is put into the data register but the address transfer is not finished on the bus. Ensure that the kFLEXIO_I2C_RxFullFlag status is asserted before calling this API. param base Pointer to FLEXIO_I2C_Type structure. param address 7-bit address. param direction transfer direction. This parameter is one of the values in flexio_i2c_direction_t: arg kFLEXIO_I2C_Write: Transmit arg kFLEXIO_I2C_Read: Receive
| void FLEXIO_I2C_MasterStop | ( | FLEXIO_I2C_Type * | base | ) |
brief Sends the stop signal on the bus.
| void FLEXIO_I2C_MasterTransferAbort | ( | FLEXIO_I2C_Type * | base, |
| flexio_i2c_master_handle_t * | handle ) |
| handle | Pointer to flexio_i2c_master_handle_t structure which stores the transfer state |
brief Aborts an interrupt non-blocking transfer early.
note This API can be called at any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base Pointer to FLEXIO_I2C_Type structure param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state
| status_t FLEXIO_I2C_MasterTransferBlocking | ( | FLEXIO_I2C_Type * | base, |
| flexio_i2c_master_transfer_t * | xfer ) |
| xfer | pointer to flexio_i2c_master_transfer_t structure. |
brief Performs a master polling transfer on the I2C bus.
note The API does not return until the transfer succeeds or fails due to receiving NAK.
param base pointer to FLEXIO_I2C_Type structure. param xfer pointer to flexio_i2c_master_transfer_t structure. return status of status_t.
| status_t FLEXIO_I2C_MasterTransferCreateHandle | ( | FLEXIO_I2C_Type * | base, |
| flexio_i2c_master_handle_t * | handle, | ||
| flexio_i2c_master_transfer_callback_t | callback, | ||
| void * | userData ) |
| handle | Pointer to flexio_i2c_master_handle_t structure to store the transfer state. |
| callback | Pointer to user callback function. |
| userData | User param passed to the callback function. |
| kStatus_Success | Successfully create the handle. |
| kStatus_OutOfRange | The FlexIO type/handle/isr table out of range. |
brief Initializes the I2C handle which is used in transactional functions.
param base Pointer to FLEXIO_I2C_Type structure. param handle Pointer to flexio_i2c_master_handle_t structure to store the transfer state. param callback Pointer to user callback function. param userData User param passed to the callback function. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO type/handle/isr table out of range.
| status_t FLEXIO_I2C_MasterTransferGetCount | ( | FLEXIO_I2C_Type * | base, |
| size_t * | count ) |
| handle | Pointer to flexio_i2c_master_handle_t structure which stores the transfer state. |
| count | Number of bytes transferred so far by the non-blocking transaction. |
| kStatus_InvalidArgument | count is Invalid. |
| kStatus_NoTransferInProgress | There is not a non-blocking transaction currently in progress. |
| kStatus_Success | Successfully return the count. |
brief Gets the master transfer status during a interrupt non-blocking transfer.
param base Pointer to FLEXIO_I2C_Type structure. param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the non-blocking transaction. retval kStatus_InvalidArgument count is Invalid. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress. retval kStatus_Success Successfully return the count.
| void FLEXIO_I2C_MasterTransferHandleIRQ | ( | void * | i2cType, |
| void * | i2cHandle ) |
| i2cType | Pointer to FLEXIO_I2C_Type structure |
| i2cHandle | Pointer to flexio_i2c_master_transfer_t structure |
brief Master interrupt handler.
param i2cType Pointer to FLEXIO_I2C_Type structure param i2cHandle Pointer to flexio_i2c_master_transfer_t structure
| status_t FLEXIO_I2C_MasterTransferNonBlocking | ( | FLEXIO_I2C_Type * | base, |
| xfer | pointer to flexio_i2c_master_transfer_t structure |
| kStatus_Success | Successfully start a transfer. |
| kStatus_FLEXIO_I2C_Busy | FlexIO I2C is not idle, is running another transfer. |
brief Performs a master interrupt non-blocking transfer on the I2C bus.
note The API returns immediately after the transfer initiates. Call FLEXIO_I2C_MasterTransferGetCount to poll the transfer status to check whether the transfer is finished. If the return status is not kStatus_FLEXIO_I2C_Busy, the transfer is finished.
param base Pointer to FLEXIO_I2C_Type structure param handle Pointer to flexio_i2c_master_handle_t structure which stores the transfer state param xfer pointer to flexio_i2c_master_transfer_t structure retval kStatus_Success Successfully start a transfer. retval kStatus_FLEXIO_I2C_Busy FlexIO I2C is not idle, is running another transfer.
| status_t FLEXIO_I2C_MasterWriteBlocking | ( | FLEXIO_I2C_Type * | base, |
| const uint8_t * | txBuff, | ||
| uint8_t | txSize ) |
| txBuff | The data bytes to send. |
| txSize | The number of data bytes to send. |
| kStatus_Success | Successfully write data. |
| kStatus_FLEXIO_I2C_Nak | Receive NAK during writing data. |
brief Sends a buffer of data in bytes.
note This function blocks via polling until all bytes have been sent.
param base Pointer to FLEXIO_I2C_Type structure. param txBuff The data bytes to send. param txSize The number of data bytes to send. retval kStatus_Success Successfully write data. retval kStatus_FLEXIO_I2C_Nak Receive NAK during writing data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
| uint32_t _flexio_i2c_type::baudrate |
Master transfer baudrate, used to calculate delay time.
| uint32_t _flexio_i2c_master_config::baudRate_Bps |
Baud rate in Bps.
| flexio_i2c_master_transfer_callback_t _flexio_i2c_master_handle::completionCallback |
Callback function called at transfer event. Callback function called at transfer event.
| uint8_t volatile* _flexio_i2c_master_transfer::data |
Transfer buffer.
| volatile size_t _flexio_i2c_master_transfer::dataSize |
Transfer size.
| flexio_i2c_direction_t _flexio_i2c_master_transfer::direction |
Transfer direction, read or write.
| bool _flexio_i2c_master_config::enableFastAccess |
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
| bool _flexio_i2c_master_config::enableInDebug |
Enable/disable FlexIO operation in debug mode.
| bool _flexio_i2c_master_config::enableInDoze |
Enable/disable FlexIO operation in doze mode.
| bool _flexio_i2c_master_config::enableMaster |
Enables the FlexIO I2C peripheral at initialization time.
| uint32_t _flexio_i2c_master_transfer::flags |
Transfer flag which controls the transfer, reserved for FlexIO I2C.
| FLEXIO_Type* _flexio_i2c_type::flexioBase |
FlexIO base pointer.
| bool _flexio_i2c_master_handle::needRestart |
Whether master needs to send re-start signal.
| uint8_t _flexio_i2c_type::SCLPinIndex |
Pin select for I2C SCL.
| uint8_t _flexio_i2c_type::SDAPinIndex |
Pin select for I2C SDA.
| uint8_t _flexio_i2c_type::shifterIndex[2] |
Shifter index used in FlexIO I2C.
| uint8_t _flexio_i2c_master_transfer::slaveAddress |
7-bit slave address.
| uint8_t _flexio_i2c_master_handle::state |
Transfer state maintained during transfer.
| uint32_t _flexio_i2c_master_transfer::subaddress |
Sub address. Transferred MSB first.
| uint8_t _flexio_i2c_master_transfer::subaddressSize |
Size of command buffer.
| uint8_t _flexio_i2c_type::timerIndex[3] |
Timer index used in FlexIO I2C.
| flexio_i2c_master_transfer_t _flexio_i2c_master_handle::transfer |
FlexIO I2C master transfer copy.
| size_t _flexio_i2c_master_handle::transferSize |
Total bytes to be transferred.
| void* _flexio_i2c_master_handle::userData |
Callback parameter passed to callback function.
