RTEMS 6.3
Flexio_edma_camera
struct  _flexio_camera_edma_handle
 Camera eDMA handle. More...
flexio_camera_edma_transfer_callback_t _flexio_camera_edma_handle::callback
void * _flexio_camera_edma_handle::userData
size_t _flexio_camera_edma_handle::rxSize
edma_handle_t * _flexio_camera_edma_handle::rxEdmaHandle
uint8_t _flexio_camera_edma_handle::nbytes
volatile uint8_t _flexio_camera_edma_handle::rxState
Driver version
typedef struct _flexio_camera_edma_handle flexio_camera_edma_handle_t
 Forward declaration of the handle typedef.
typedef void(*) flexio_camera_edma_transfer_callback_t(FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, status_t status, void *userData)
 Camera transfer callback function.
#define FSL_FLEXIO_CAMERA_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 1, 3))
 FlexIO Camera EDMA driver version 2.1.3.
eDMA transactional
status_t FLEXIO_CAMERA_TransferCreateHandleEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, flexio_camera_edma_transfer_callback_t callback, void *userData, edma_handle_t *rxEdmaHandle)
 Initializes the Camera handle, which is used in transactional functions.
status_t FLEXIO_CAMERA_TransferReceiveEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, flexio_camera_transfer_t *xfer)
 Receives data using eDMA.
void FLEXIO_CAMERA_TransferAbortReceiveEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle)
 Aborts the receive data which used the eDMA.
status_t FLEXIO_CAMERA_TransferGetReceiveCountEDMA (FLEXIO_CAMERA_Type *base, flexio_camera_edma_handle_t *handle, size_t *count)
 Gets the remaining bytes to be received.
◆ FLEXIO_CAMERA_TransferAbortReceiveEDMA()
void FLEXIO_CAMERA_TransferAbortReceiveEDMA ( FLEXIO_CAMERA_Type * base,
flexio_camera_edma_handle_t * handle )
This function aborts the receive data which used the eDMA.
Parameters
basePointer to the FLEXIO_CAMERA_Type.
handlePointer to the flexio_camera_edma_handle_t structure.
◆ FLEXIO_CAMERA_TransferCreateHandleEDMA()
status_t FLEXIO_CAMERA_TransferCreateHandleEDMA ( FLEXIO_CAMERA_Type * base,
flexio_camera_edma_handle_t * handle,
void * userData,
edma_handle_t * rxEdmaHandle )
Parameters
handlePointer to flexio_camera_edma_handle_t structure.
callbackThe callback function.
userDataThe parameter of the callback function.
rxEdmaHandleUser requested DMA handle for RX DMA transfer.
Return values
kStatus_SuccessSuccessfully create the handle.
kStatus_OutOfRangeThe FlexIO Camera eDMA type/handle table out of range.
◆ FLEXIO_CAMERA_TransferGetReceiveCountEDMA()
status_t FLEXIO_CAMERA_TransferGetReceiveCountEDMA ( FLEXIO_CAMERA_Type * base,
size_t * count )
This function gets the number of bytes still not received.
Parameters
countNumber of bytes sent so far by the non-blocking transaction.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_InvalidArgumentThe count parameter is invalid.
◆ FLEXIO_CAMERA_TransferReceiveEDMA()
status_t FLEXIO_CAMERA_TransferReceiveEDMA ( FLEXIO_CAMERA_Type * base,
flexio_camera_transfer_t * xfer )
This function receives data using eDMA. This is a non-blocking function, which returns right away. When all data is received, the receive callback function is called.
Parameters
xferCamera eDMA transfer structure, see flexio_camera_transfer_t.
Return values
kStatus_Successif succeeded, others failed.
kStatus_CAMERA_RxBusyPrevious transfer on going.
Variable Documentation
◆ callback
Callback function.
◆ nbytes
eDMA minor byte transfer count initially configured.
◆ rxEdmaHandle
edma_handle_t* _flexio_camera_edma_handle::rxEdmaHandle
The eDMA RX channel used.
◆ rxSize
Total bytes to be received.
◆ rxState
RX transfer state
◆ userData
void* _flexio_camera_edma_handle::userData
Camera callback function parameter.
