RTEMS 6.3
| struct | _csi2rx_config |
| CSI2RX configuration. More... | |
| uint8_t | _csi2rx_config::laneNum |
| uint8_t | _csi2rx_config::tHsSettle_EscClk |
Driver version | |
| enum | _csi2rx_data_lane { kCSI2RX_DataLane0 = (1U << 0U) , kCSI2RX_DataLane1 = (1U << 1U) , kCSI2RX_DataLane2 = (1U << 2U) , kCSI2RX_DataLane3 = (1U << 3U) } |
| CSI2RX data lanes. More... | |
| enum | _csi2rx_payload { kCSI2RX_PayloadGroup0Null = (1U << 0U) , kCSI2RX_PayloadGroup0Blank = (1U << 1U) , kCSI2RX_PayloadGroup0Embedded = (1U << 2U) , kCSI2RX_PayloadGroup0YUV420_8Bit = (1U << 10U) , kCSI2RX_PayloadGroup0YUV422_8Bit = (1U << 14U) , kCSI2RX_PayloadGroup0YUV422_10Bit = (1U << 15U) , kCSI2RX_PayloadGroup0RGB444 = (1U << 16U) , kCSI2RX_PayloadGroup0RGB555 = (1U << 17U) , kCSI2RX_PayloadGroup0RGB565 = (1U << 18U) , kCSI2RX_PayloadGroup0RGB666 = (1U << 19U) , kCSI2RX_PayloadGroup0RGB888 = (1U << 20U) , kCSI2RX_PayloadGroup0Raw6 = (1U << 24U) , kCSI2RX_PayloadGroup0Raw7 = (1U << 25U) , kCSI2RX_PayloadGroup0Raw8 = (1U << 26U) , kCSI2RX_PayloadGroup0Raw10 = (1U << 27U) , kCSI2RX_PayloadGroup0Raw12 = (1U << 28U) , kCSI2RX_PayloadGroup0Raw14 = (1U << 29U) , kCSI2RX_PayloadGroup1UserDefined1 = (1U << 0U) , kCSI2RX_PayloadGroup1UserDefined2 = (1U << 1U) , kCSI2RX_PayloadGroup1UserDefined3 = (1U << 2U) , kCSI2RX_PayloadGroup1UserDefined4 = (1U << 3U) , kCSI2RX_PayloadGroup1UserDefined5 = (1U << 4U) , kCSI2RX_PayloadGroup1UserDefined6 = (1U << 5U) , kCSI2RX_PayloadGroup1UserDefined7 = (1U << 6U) , kCSI2RX_PayloadGroup1UserDefined8 = (1U << 7U) } |
| CSI2RX payload type. More... | |
| enum | _csi2rx_bit_error { kCSI2RX_BitErrorEccTwoBit = (1U << 0U) , kCSI2RX_BitErrorEccOneBit = (1U << 1U) } |
| MIPI CSI2RX bit errors. More... | |
| enum | _csi2rx_ppi_error { kCSI2RX_PpiErrorSotHs , kCSI2RX_PpiErrorSotSyncHs , kCSI2RX_PpiErrorEsc , kCSI2RX_PpiErrorSyncEsc , kCSI2RX_PpiErrorControl } |
| MIPI CSI2RX PPI error types. More... | |
| enum | _csi2rx_interrupt { kCSI2RX_InterruptCrcError = (1U << 0U) , kCSI2RX_InterruptEccOneBitError = (1U << 1U) , kCSI2RX_InterruptEccTwoBitError = (1U << 2U) , kCSI2RX_InterruptUlpsStatusChange = (1U << 3U) , kCSI2RX_InterruptErrorSotHs = (1U << 4U) , kCSI2RX_InterruptErrorSotSyncHs = (1U << 5U) , kCSI2RX_InterruptErrorEsc = (1U << 6U) , kCSI2RX_InterruptErrorSyncEsc = (1U << 7U) , kCSI2RX_InterruptErrorControl = (1U << 8U) } |
| MIPI CSI2RX interrupt. | |
| enum | _csi2rx_ulps_status { kCSI2RX_ClockLaneUlps = (1U << 0U) , kCSI2RX_DataLane0Ulps = (1U << 1U) , kCSI2RX_DataLane1Ulps = (1U << 2U) , kCSI2RX_DataLane2Ulps = (1U << 3U) , kCSI2RX_DataLane3Ulps = (1U << 4U) , kCSI2RX_ClockLaneMark = (1U << 5U) , kCSI2RX_DataLane0Mark = (1U << 6U) , kCSI2RX_DataLane1Mark = (1U << 7U) , kCSI2RX_DataLane2Mark = (1U << 8U) , kCSI2RX_DataLane3Mark = (1U << 9U) } |
| MIPI CSI2RX D-PHY ULPS state. More... | |
| typedef struct _csi2rx_config | csi2rx_config_t |
| CSI2RX configuration. | |
| typedef enum _csi2rx_ppi_error | csi2rx_ppi_error_t |
| MIPI CSI2RX PPI error types. | |
| void | CSI2RX_Init (MIPI_CSI2RX_Type *base, const csi2rx_config_t *config) |
| Enables and configures the CSI2RX peripheral module. | |
| void | CSI2RX_Deinit (MIPI_CSI2RX_Type *base) |
| Disables the CSI2RX peripheral module. | |
| #define | FSL_CSI2RX_DRIVER_VERSION (MAKE_VERSION(2, 0, 4)) |
| CSI2RX driver version. | |
| #define | CSI2RX_REG_CFG_NUM_LANES(base) |
| #define | CSI2RX_REG_CFG_DISABLE_DATA_LANES(base) |
| #define | CSI2RX_REG_BIT_ERR(base) |
| #define | CSI2RX_REG_IRQ_STATUS(base) |
| #define | CSI2RX_REG_IRQ_MASK(base) |
| #define | CSI2RX_REG_ULPS_STATUS(base) |
| #define | CSI2RX_REG_PPI_ERRSOT_HS(base) |
| #define | CSI2RX_REG_PPI_ERRSOTSYNC_HS(base) |
| #define | CSI2RX_REG_PPI_ERRESC(base) |
| #define | CSI2RX_REG_PPI_ERRSYNCESC(base) |
| #define | CSI2RX_REG_PPI_ERRCONTROL(base) |
| #define | CSI2RX_REG_CFG_DISABLE_PAYLOAD_0(base) |
| #define | CSI2RX_REG_CFG_DISABLE_PAYLOAD_1(base) |
| #define | CSI2RX_REG_CFG_IGNORE_VC(base) |
| #define | CSI2RX_REG_CFG_VID_VC(base) |
| #define | CSI2RX_REG_CFG_VID_P_FIFO_SEND_LEVEL(base) |
| #define | CSI2RX_REG_CFG_VID_VSYNC(base) |
| #define | CSI2RX_REG_CFG_VID_HSYNC_FP(base) |
| #define | CSI2RX_REG_CFG_VID_HSYNC(base) |
| #define | CSI2RX_REG_CFG_VID_HSYNC_BP(base) |
| #define | MIPI_CSI2RX_CSI2RX_CFG_NUM_LANES_csi2rx_cfg_num_lanes_MASK MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK |
| #define | MIPI_CSI2RX_CSI2RX_IRQ_MASK_csi2rx_irq_mask_MASK MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK |
| #define CSI2RX_REG_BIT_ERR | ( | base | ) |
| #define CSI2RX_REG_CFG_DISABLE_DATA_LANES | ( | base | ) |
| #define CSI2RX_REG_CFG_DISABLE_PAYLOAD_0 | ( | base | ) |
| #define CSI2RX_REG_CFG_DISABLE_PAYLOAD_1 | ( | base | ) |
| #define CSI2RX_REG_CFG_IGNORE_VC | ( | base | ) |
| #define CSI2RX_REG_CFG_NUM_LANES | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_HSYNC | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_HSYNC_BP | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_HSYNC_FP | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_P_FIFO_SEND_LEVEL | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_VC | ( | base | ) |
| #define CSI2RX_REG_CFG_VID_VSYNC | ( | base | ) |
| #define CSI2RX_REG_IRQ_MASK | ( | base | ) |
| #define CSI2RX_REG_IRQ_STATUS | ( | base | ) |
| #define CSI2RX_REG_PPI_ERRCONTROL | ( | base | ) |
| #define CSI2RX_REG_PPI_ERRESC | ( | base | ) |
| #define CSI2RX_REG_PPI_ERRSOT_HS | ( | base | ) |
| #define CSI2RX_REG_PPI_ERRSOTSYNC_HS | ( | base | ) |
| #define CSI2RX_REG_PPI_ERRSYNCESC | ( | base | ) |
| #define CSI2RX_REG_ULPS_STATUS | ( | base | ) |
| enum _csi2rx_bit_error |
| enum _csi2rx_data_lane |
| enum _csi2rx_payload |
| enum _csi2rx_ulps_status |
| void CSI2RX_Deinit | ( | MIPI_CSI2RX_Type * | base | ) |
| base | CSI2RX peripheral address. |
brief Disables the CSI2RX peripheral module.
param base CSI2RX peripheral address.
| void CSI2RX_Init | ( | MIPI_CSI2RX_Type * | base, |
| const csi2rx_config_t * | config ) |
| config | CSI2RX module configuration structure. |
brief Enables and configures the CSI2RX peripheral module.
param base CSI2RX peripheral address. param config CSI2RX module configuration structure.
| uint8_t _csi2rx_config::laneNum |
Number of active lanes used for receiving data.
| uint8_t _csi2rx_config::tHsSettle_EscClk |
Number of rx_clk_esc clock periods for T_HS_SETTLE. The T_HS_SETTLE should be in the range of 85ns + 6UI to 145ns + 10UI.
