RTEMS 6.3
Aoi
struct  _aoi_event_config
 AOI event configuration structure. More...
#define AOI   AOI0
aoi_input_config_t _aoi_event_config::PT0AC
aoi_input_config_t _aoi_event_config::PT0BC
aoi_input_config_t _aoi_event_config::PT0CC
aoi_input_config_t _aoi_event_config::PT0DC
aoi_input_config_t _aoi_event_config::PT1AC
aoi_input_config_t _aoi_event_config::PT1BC
aoi_input_config_t _aoi_event_config::PT1CC
aoi_input_config_t _aoi_event_config::PT1DC
aoi_input_config_t _aoi_event_config::PT2AC
aoi_input_config_t _aoi_event_config::PT2BC
aoi_input_config_t _aoi_event_config::PT2CC
aoi_input_config_t _aoi_event_config::PT2DC
aoi_input_config_t _aoi_event_config::PT3AC
aoi_input_config_t _aoi_event_config::PT3BC
aoi_input_config_t _aoi_event_config::PT3CC
aoi_input_config_t _aoi_event_config::PT3DC
Driver version
enum  _aoi_input_config { kAOI_LogicZero = 0x0U , kAOI_InputSignal = 0x1U , kAOI_InvInputSignal = 0x2U , kAOI_LogicOne = 0x3U }
 AOI input configurations. More...
enum  _aoi_event { kAOI_Event0 = 0x0U , kAOI_Event1 = 0x1U , kAOI_Event2 = 0x2U , kAOI_Event3 = 0x3U }
 AOI event indexes, where an event is the collection of the four product terms (0, 1, 2, and 3) and the four signal inputs (A, B, C, and D). More...
typedef enum _aoi_input_config aoi_input_config_t
typedef enum _aoi_event aoi_event_t
typedef struct _aoi_event_config aoi_event_config_t
#define FSL_AOI_DRIVER_VERSION   (MAKE_VERSION(2, 0, 1))
AOI Initialization
void AOI_Init (AOI_Type *base)
 Initializes an AOI instance for operation.
void AOI_Deinit (AOI_Type *base)
 Deinitializes an AOI instance for operation.
AOI Get Set Operation
void AOI_GetEventLogicConfig (AOI_Type *base, aoi_event_t event, aoi_event_config_t *config)
 Gets the Boolean evaluation associated.
void AOI_SetEventLogicConfig (AOI_Type *base, aoi_event_t event, const aoi_event_config_t *eventConfig)
 Configures an AOI event.
◆ AOI
#define AOI   AOI0
AOI peripheral address
◆ FSL_AOI_DRIVER_VERSION
Version 2.0.1.
Typedef Documentation
◆ aoi_event_config_t
Defines structure _aoi_event_config and use the AOI_SetEventLogicConfig() function to make whole event configuration.
◆ aoi_input_config_t
The selection item represents the Boolean evaluations.
◆ _aoi_event
enum _aoi_event
kAOI_Event0
Event 0 index
kAOI_Event1
Event 1 index
kAOI_Event2
Event 2 index
kAOI_Event3
Event 3 index
◆ _aoi_input_config
kAOI_LogicZero
Forces the input to logical zero.
kAOI_InputSignal
Passes the input signal.
kAOI_InvInputSignal
Inverts the input signal.
kAOI_LogicOne
Forces the input to logical one.
◆ AOI_Deinit()
void AOI_Deinit ( AOI_Type * base)
This function shutdowns AOI module.
Parameters
baseAOI peripheral address.
brief Deinitializes an AOI instance for operation.
param base AOI peripheral address.
◆ AOI_GetEventLogicConfig()
void AOI_GetEventLogicConfig ( AOI_Type * base,
aoi_event_t event,
aoi_event_config_t * config )
This function returns the Boolean evaluation associated.
Example:
aoi_event_config_t demoEventLogicStruct;
AOI_GetEventLogicConfig(AOI, kAOI_Event0, &demoEventLogicStruct);
void AOI_GetEventLogicConfig(AOI_Type *base, aoi_event_t event, aoi_event_config_t *config)
Definition fsl_aoi.c:104
#define AOI
Definition fsl_aoi.h:22
@ kAOI_Event0
Definition fsl_aoi.h:49
Parameters
eventIndex of the event which will be set of type aoi_event_t.
configSelected input configuration .
brief Gets the Boolean evaluation associated.
Example: code aoi_event_config_t demoEventLogicStruct;
AOI_GetEventLogicConfig(AOI, kAOI_Event0, &demoEventLogicStruct); endcode
param base AOI peripheral address. param event Index of the event which will be set of type aoi_event_t. param config Selected input configuration .
◆ AOI_Init()
void AOI_Init ( AOI_Type * base)
This function un-gates the AOI clock.
Parameters
brief Initializes an AOI instance for operation.
◆ AOI_SetEventLogicConfig()
void AOI_SetEventLogicConfig ( AOI_Type * base,
aoi_event_t event,
const aoi_event_config_t * eventConfig )
This function configures an AOI event according to the aoiEventConfig structure. This function configures all inputs (A, B, C, and D) of all product terms (0, 1, 2, and 3) of a desired event.
Example:
demoEventLogicStruct.PT0AC = kAOI_InvInputSignal;
demoEventLogicStruct.PT0BC = kAOI_InputSignal;
demoEventLogicStruct.PT0CC = kAOI_LogicOne;
demoEventLogicStruct.PT0DC = kAOI_LogicOne;
demoEventLogicStruct.PT1AC = kAOI_LogicZero;
demoEventLogicStruct.PT1BC = kAOI_LogicOne;
demoEventLogicStruct.PT1CC = kAOI_LogicOne;
demoEventLogicStruct.PT1DC = kAOI_LogicOne;
demoEventLogicStruct.PT2AC = kAOI_LogicZero;
demoEventLogicStruct.PT2BC = kAOI_LogicOne;
demoEventLogicStruct.PT2CC = kAOI_LogicOne;
demoEventLogicStruct.PT2DC = kAOI_LogicOne;
demoEventLogicStruct.PT3AC = kAOI_LogicZero;
demoEventLogicStruct.PT3BC = kAOI_LogicOne;
demoEventLogicStruct.PT3CC = kAOI_LogicOne;
demoEventLogicStruct.PT3DC = kAOI_LogicOne;
AOI_SetEventLogicConfig(AOI, kAOI_Event0, demoEventLogicStruct);
void AOI_SetEventLogicConfig(AOI_Type *base, aoi_event_t event, const aoi_event_config_t *eventConfig)
Definition fsl_aoi.c:193
aoi_input_config_t PT2DC
Definition fsl_aoi.h:74
aoi_input_config_t PT0CC
Definition fsl_aoi.h:65
aoi_input_config_t PT2BC
Definition fsl_aoi.h:72
aoi_input_config_t PT3AC
Definition fsl_aoi.h:75
aoi_input_config_t PT1DC
Definition fsl_aoi.h:70
aoi_input_config_t PT1CC
Definition fsl_aoi.h:69
aoi_input_config_t PT0AC
Definition fsl_aoi.h:63
aoi_input_config_t PT1AC
Definition fsl_aoi.h:67
aoi_input_config_t PT2CC
Definition fsl_aoi.h:73
aoi_input_config_t PT2AC
Definition fsl_aoi.h:71
aoi_input_config_t PT3DC
Definition fsl_aoi.h:78
aoi_input_config_t PT0BC
Definition fsl_aoi.h:64
aoi_input_config_t PT1BC
Definition fsl_aoi.h:68
aoi_input_config_t PT3CC
Definition fsl_aoi.h:77
aoi_input_config_t PT0DC
Definition fsl_aoi.h:66
aoi_input_config_t PT3BC
Definition fsl_aoi.h:76
@ kAOI_InputSignal
Definition fsl_aoi.h:38
@ kAOI_LogicOne
Definition fsl_aoi.h:40
@ kAOI_LogicZero
Definition fsl_aoi.h:37
@ kAOI_InvInputSignal
Definition fsl_aoi.h:39
Parameters
eventEvent which will be configured of type aoi_event_t.
eventConfigPointer to type aoi_event_config_t structure. The user is responsible for filling out the members of this structure and passing the pointer to this function.
brief Configures an AOI event.
demoEventLogicStruct.PT0AC = kAOI_InvInputSignal; demoEventLogicStruct.PT0BC = kAOI_InputSignal; demoEventLogicStruct.PT0CC = kAOI_LogicOne; demoEventLogicStruct.PT0DC = kAOI_LogicOne;
demoEventLogicStruct.PT1AC = kAOI_LogicZero; demoEventLogicStruct.PT1BC = kAOI_LogicOne; demoEventLogicStruct.PT1CC = kAOI_LogicOne; demoEventLogicStruct.PT1DC = kAOI_LogicOne;
demoEventLogicStruct.PT2AC = kAOI_LogicZero; demoEventLogicStruct.PT2BC = kAOI_LogicOne; demoEventLogicStruct.PT2CC = kAOI_LogicOne; demoEventLogicStruct.PT2DC = kAOI_LogicOne;
demoEventLogicStruct.PT3AC = kAOI_LogicZero; demoEventLogicStruct.PT3BC = kAOI_LogicOne; demoEventLogicStruct.PT3CC = kAOI_LogicOne; demoEventLogicStruct.PT3DC = kAOI_LogicOne;
AOI_SetEventLogicConfig(AOI, kAOI_Event0, demoEventLogicStruct); endcode
param base AOI peripheral address. param event Event which will be configured of type aoi_event_t. param eventConfig Pointer to type aoi_event_config_t structure. The user is responsible for filling out the members of this structure and passing the pointer to this function.
Variable Documentation
◆ PT0AC
Product term 0 input A
◆ PT0BC
Product term 0 input B
◆ PT0CC
Product term 0 input C
◆ PT0DC
Product term 0 input D
◆ PT1AC
Product term 1 input A
◆ PT1BC
Product term 1 input B
◆ PT1CC
Product term 1 input C
◆ PT1DC
Product term 1 input D
◆ PT2AC
Product term 2 input A
◆ PT2BC
Product term 2 input B
◆ PT2CC
Product term 2 input C
◆ PT2DC
Product term 2 input D
◆ PT3AC
Product term 3 input A
◆ PT3BC
Product term 3 input B
◆ PT3CC
Product term 3 input C
◆ PT3DC
Product term 3 input D
