RTEMS 6.3
Anatop_ai
file  bsps/arm/imxrt/mcux-sdk/devices/MIMXRT1166/drivers/fsl_anatop_ai.h
Driver version
enum  _anatop_ai_itf {
  kAI_Itf_Ldo = 0 , kAI_Itf_1g = 1 , kAI_Itf_Audio = 2 , kAI_Itf_Video = 3 ,
  kAI_Itf_400m = 4 , kAI_Itf_Temp = 5 , kAI_Itf_Bandgap = 6
 Anatop AI ITF enumeration. More...
enum  _anatop_ai_reg {
  kAI_PHY_LDO_CTRL0 = 0x0 , kAI_PHY_LDO_CTRL0_SET = 0x4 , kAI_PHY_LDO_CTRL0_CLR = 0x8 , kAI_PHY_LDO_CTRL0_TOG = 0xC ,
  kAI_PHY_LDO_STAT0 = 0x50 , kAI_PHY_LDO_STAT0_SET = 0x54 , kAI_PHY_LDO_STAT0_CLR = 0x58 , kAI_PHY_LDO_STAT0_TOG = 0x5C ,
  kAI_BANDGAP_CTRL0 = 0x0 , kAI_BANDGAP_STAT0 = 0x50 , kAI_RCOSC400M_CTRL0 = 0x0 , kAI_RCOSC400M_CTRL0_SET = 0x4 ,
  kAI_RCOSC400M_CTRL0_CLR = 0x8 , kAI_RCOSC400M_CTRL0_TOG = 0xC , kAI_RCOSC400M_CTRL1 = 0x10 , kAI_RCOSC400M_CTRL1_SET = 0x14 ,
  kAI_RCOSC400M_CTRL1_CLR = 0x18 , kAI_RCOSC400M_CTRL1_TOG = 0x1C , kAI_RCOSC400M_CTRL2 = 0x20 , kAI_RCOSC400M_CTRL2_SET = 0x24 ,
  kAI_RCOSC400M_CTRL2_CLR = 0x28 , kAI_RCOSC400M_CTRL2_TOG = 0x2C , kAI_RCOSC400M_CTRL3 = 0x30 , kAI_RCOSC400M_CTRL3_SET = 0x34 ,
  kAI_RCOSC400M_CTRL3_CLR = 0x38 , kAI_RCOSC400M_CTRL3_TOG = 0x3C , kAI_RCOSC400M_STAT0 = 0x50 , kAI_RCOSC400M_STAT0_SET = 0x54 ,
  kAI_RCOSC400M_STAT0_CLR = 0x58 , kAI_RCOSC400M_STAT0_TOG = 0x5C , kAI_RCOSC400M_STAT1 = 0x60 , kAI_RCOSC400M_STAT1_SET = 0x64 ,
  kAI_RCOSC400M_STAT1_CLR = 0x68 , kAI_RCOSC400M_STAT1_TOG = 0x6C , kAI_RCOSC400M_STAT2 = 0x70 , kAI_RCOSC400M_STAT2_SET = 0x74 ,
  kAI_RCOSC400M_STAT2_CLR = 0x78 , kAI_RCOSC400M_STAT2_TOG = 0x7C , kAI_PLL1G_CTRL0 = 0x0 , kAI_PLL1G_CTRL0_SET = 0x4 ,
  kAI_PLL1G_CTRL0_CLR = 0x8 , kAI_PLL1G_CTRL1 = 0x10 , kAI_PLL1G_CTRL1_SET = 0x14 , kAI_PLL1G_CTRL1_CLR = 0x18 ,
  kAI_PLL1G_CTRL2 = 0x20 , kAI_PLL1G_CTRL2_SET = 0x24 , kAI_PLL1G_CTRL2_CLR = 0x28 , kAI_PLL1G_CTRL3 = 0x30 ,
  kAI_PLL1G_CTRL3_SET = 0x34 , kAI_PLL1G_CTRL3_CLR = 0x38 , kAI_PLLAUDIO_CTRL0 = 0x0 , kAI_PLLAUDIO_CTRL0_SET = 0x4 ,
  kAI_PLLAUDIO_CTRL0_CLR = 0x8 , kAI_PLLAUDIO_CTRL1 = 0x10 , kAI_PLLAUDIO_CTRL1_SET = 0x14 , kAI_PLLAUDIO_CTRL1_CLR = 0x18 ,
  kAI_PLLAUDIO_CTRL2 = 0x20 , kAI_PLLAUDIO_CTRL2_SET = 0x24 , kAI_PLLAUDIO_CTRL2_CLR = 0x28 , kAI_PLLAUDIO_CTRL3 = 0x30 ,
  kAI_PLLAUDIO_CTRL3_SET = 0x34 , kAI_PLLAUDIO_CTRL3_CLR = 0x38 , kAI_PLLVIDEO_CTRL0 = 0x0 , kAI_PLLVIDEO_CTRL0_SET = 0x4 ,
  kAI_PLLVIDEO_CTRL0_CLR = 0x8 , kAI_PLLVIDEO_CTRL1 = 0x10 , kAI_PLLVIDEO_CTRL1_SET = 0x14 , kAI_PLLVIDEO_CTRL1_CLR = 0x18 ,
  kAI_PLLVIDEO_CTRL2 = 0x20 , kAI_PLLVIDEO_CTRL2_SET = 0x24 , kAI_PLLVIDEO_CTRL2_CLR = 0x28 , kAI_PLLVIDEO_CTRL3 = 0x30 ,
  kAI_PLLVIDEO_CTRL3_SET = 0x34 , kAI_PLLVIDEO_CTRL3_CLR = 0x38
 The enumeration of ANATOP AI Register. More...
typedef enum _anatop_ai_itf anatop_ai_itf_t
typedef enum _anatop_ai_reg anatop_ai_reg_t
#define FSL_ANATOP_AI_DRIVER_VERSION   (MAKE_VERSION(1, 0, 0))
 Anatop AI driver version 1.0.0.
CTRL0 - CTRL0 Register
#define AI_PHY_LDO_CTRL0_LINREG_EN(x)
#define AI_PHY_LDO_CTRL0_LINREG_EN_MASK   (0x1U)
#define AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT   (0U)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS(x)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK   (0x2U)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT   (1U)
#define AI_PHY_LDO_CTRL0_LIMIT_EN(x)
#define AI_PHY_LDO_CTRL0_LIMIT_EN_MASK   (0x4U)
#define AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT   (2U)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG(x)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK   (0x1F0U)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT   (4U)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B(x)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK   (0x8000U)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT   (15U)
#define AI_BANDGAP_CTRL0_REFTOP_PWD(x)
#define AI_BANDGAP_CTRL0_REFTOP_PWD_MASK   (0x1U)
#define AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT   (0U)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD(x)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK   (0x2U)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT   (1U)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP(x)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK   (0x4U)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT   (2U)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER(x)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK   (0x8U)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT   (3U)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF(x)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK   (0x10U)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT   (4U)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ(x)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK   (0xE0U)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT   (5U)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ(x)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK   (0x1C00U)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT   (10U)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV(x)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK   (0x3F000000U)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT   (24U)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF(x)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLL1G_CTRL0_POWER_UP(x)
#define AI_PLL1G_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLL1G_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLL1G_CTRL0_ENABLE(x)
#define AI_PLL1G_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLL1G_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLL1G_CTRL0_BYPASS(x)
#define AI_PLL1G_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLL1G_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLL1G_CTRL0_PLL_REG_EN(x)
#define AI_PLL1G_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT   (22U)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF(x)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLLAUDIO_CTRL0_POWER_UP(x)
#define AI_PLLAUDIO_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLLAUDIO_CTRL0_ENABLE(x)
#define AI_PLLAUDIO_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLLAUDIO_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLLAUDIO_CTRL0_BYPASS(x)
#define AI_PLLAUDIO_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLLAUDIO_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN(x)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT   (22U)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF(x)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLLVIDEO_CTRL0_POWER_UP(x)
#define AI_PLLVIDEO_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLLVIDEO_CTRL0_ENABLE(x)
#define AI_PLLVIDEO_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLLVIDEO_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLLVIDEO_CTRL0_BYPASS(x)
#define AI_PLLVIDEO_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLLVIDEO_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN(x)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT   (22U)
STAT0 - STAT0 Register
#define AI_PHY_LDO_STAT0_LINREG_STAT(x)
#define AI_PHY_LDO_STAT0_LINREG_STAT_MASK   (0xFU)
#define AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT   (0U)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP(x)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK   (0x1U)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT   (0U)
#define AI_RCOSC400M_STAT0_CLK1M_ERR(x)
#define AI_RCOSC400M_STAT0_CLK1M_ERR_MASK   (0x1U)
#define AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT   (0U)
CTRL1 - CTRL1 Register
#define AI_RCOSC400M_CTRL1_HYST_MINUS(x)
#define AI_RCOSC400M_CTRL1_HYST_MINUS_MASK   (0xFU)
#define AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT   (0U)
#define AI_RCOSC400M_CTRL1_HYST_PLUS(x)
#define AI_RCOSC400M_CTRL1_HYST_PLUS_MASK   (0xF00U)
#define AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT   (8U)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT(x)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT   (16U)
CTRL2 - CTRL2 Register
#define AI_RCOSC400M_CTRL2_TUNE_BYP(x)
#define AI_RCOSC400M_CTRL2_TUNE_BYP_MASK   (0x400U)
#define AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT   (10U)
#define AI_RCOSC400M_CTRL2_TUNE_EN(x)
#define AI_RCOSC400M_CTRL2_TUNE_EN_MASK   (0x1000U)
#define AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT   (12U)
#define AI_RCOSC400M_CTRL2_TUNE_START(x)
#define AI_RCOSC400M_CTRL2_TUNE_START_MASK   (0x4000U)
#define AI_RCOSC400M_CTRL2_TUNE_START_SHIFT   (14U)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL(x)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK   (0xFF000000U)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT   (24U)
CTRL3 - CTRL3 Register
#define AI_RCOSC400M_CTRL3_CLR_ERR(x)
#define AI_RCOSC400M_CTRL3_CLR_ERR_MASK   (0x1U)
#define AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT   (0U)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK(x)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK   (0x100U)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT   (8U)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK(x)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK   (0x400U)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT   (10U)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK(x)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT   (16U)
STAT1 - STAT1 Register
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL(x)
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT   (16U)
STAT2 - STAT2 Register
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL(x)
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_MASK   (0xFF000000U)
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT   (24U)
◆ AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK)
REFTOP_VBGADJ - These bits allow the output VBG voltage of the bandgap to be trimmed 000 : nominal 001 : +10mV 010 : +20mV 011 : +30mV 100 : -10mV 101 : -20mV 110 : -30mV 111 : -40mV
◆ AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT)) & \
AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK)
REFTOP_PWD - This bit fully powers down the bandgap module. Setting this bit high will disable reference output currents and voltages from the bandgap and will affect functionality and validity of the voltage detectors.
◆ AI_BANDGAP_CTRL0_REFTOP_LOWPOWER
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK)
REFTOP_PWDVBGUP - This bit powers down the VBGUP detector of the bandgap without affecting any additional functionality.
◆ AI_BANDGAP_CTRL0_REFTOP_PWD
#define AI_BANDGAP_CTRL0_REFTOP_PWD ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWD_MASK)
◆ AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK)
REFOP_LINREGREF_PWD - This bit powers down only the voltage reference output section of the bandgap. Setting this bit high will affect functionality and validity of the voltage detectors.
◆ AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT)) & \
AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK)
REFTOP_LOWPOWER - This bit enables the low-power operation of the bandgap by cutting the bias currents in half to the main amplifiers. This will save power but could affect the accuracy of the output voltages and currents.
◆ AI_BANDGAP_CTRL0_REFTOP_VBGADJ
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK)
REFTOP_SELFBIASOFF - Control bit to disable the self-bias circuit in the bandgap. The self-bias circuit is used by the bandgap during startup. This bit should be set high after the bandgap has stabilized and is necessary for best noise performance of modules using the outputs of the bandgap. It is expected that this control bit be set low any time that either the bandgap is fully powered-down or the 1.8V supply is removed.
◆ AI_BANDGAP_STAT0_REFTOP_VBGUP
#define AI_BANDGAP_STAT0_REFTOP_VBGUP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT)) & AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK)
◆ AI_PHY_LDO_CTRL0_LIMIT_EN
#define AI_PHY_LDO_CTRL0_LIMIT_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LIMIT_EN_MASK)
LINREG_PWRUPLOAD_DIS - LinReg power-up load disable 0b0..Internal pull-down enabled 0b1..Internal pull-down disabled
◆ AI_PHY_LDO_CTRL0_LINREG_EN
#define AI_PHY_LDO_CTRL0_LINREG_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LINREG_EN_MASK)
◆ AI_PHY_LDO_CTRL0_OUTPUT_TRG
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT)) & AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK)
LINREG_LIMIT_EN - LinReg current limit enable LinReg current-limit enable. Setting this bit will enable the current-limiter in the regulator
◆ AI_PHY_LDO_CTRL0_PHY_ISO_B
#define AI_PHY_LDO_CTRL0_PHY_ISO_B ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT)) & AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK)
LINREG_OUTPUT_TRG - LinReg output voltage target setting 0b00000..Set output voltage to x.xV 0b10000..Set output voltage to 1.0V 0b11111..Set output voltage to x.xV
◆ AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT)) & AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK)
LINREG_EN - LinReg master enable LinReg master enable. Setting this bit will enable the regular
◆ AI_PHY_LDO_STAT0_LINREG_STAT
#define AI_PHY_LDO_STAT0_LINREG_STAT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT)) & AI_PHY_LDO_STAT0_LINREG_STAT_MASK)
◆ AI_PLL1G_CTRL0_BYPASS
#define AI_PLL1G_CTRL0_BYPASS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_BYPASS_SHIFT)) & AI_PLL1G_CTRL0_BYPASS_MASK)
◆ AI_PLL1G_CTRL0_ENABLE
#define AI_PLL1G_CTRL0_ENABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_ENABLE_SHIFT)) & AI_PLL1G_CTRL0_ENABLE_MASK)
◆ AI_PLL1G_CTRL0_HOLD_RING_OFF
#define AI_PLL1G_CTRL0_HOLD_RING_OFF ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK)
◆ AI_PLL1G_CTRL0_PLL_REG_EN
#define AI_PLL1G_CTRL0_PLL_REG_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLL1G_CTRL0_PLL_REG_EN_MASK)
◆ AI_PLL1G_CTRL0_POWER_UP
#define AI_PLL1G_CTRL0_POWER_UP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_POWER_UP_SHIFT)) & AI_PLL1G_CTRL0_POWER_UP_MASK)
◆ AI_PLLAUDIO_CTRL0_BYPASS
#define AI_PLLAUDIO_CTRL0_BYPASS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_BYPASS_SHIFT)) & AI_PLLAUDIO_CTRL0_BYPASS_MASK)
◆ AI_PLLAUDIO_CTRL0_ENABLE
#define AI_PLLAUDIO_CTRL0_ENABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_ENABLE_SHIFT)) & AI_PLLAUDIO_CTRL0_ENABLE_MASK)
◆ AI_PLLAUDIO_CTRL0_HOLD_RING_OFF
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK)
◆ AI_PLLAUDIO_CTRL0_PLL_REG_EN
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK)
◆ AI_PLLAUDIO_CTRL0_POWER_UP
#define AI_PLLAUDIO_CTRL0_POWER_UP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT)) & AI_PLLAUDIO_CTRL0_POWER_UP_MASK)
◆ AI_PLLVIDEO_CTRL0_BYPASS
#define AI_PLLVIDEO_CTRL0_BYPASS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_BYPASS_SHIFT)) & AI_PLLVIDEO_CTRL0_BYPASS_MASK)
◆ AI_PLLVIDEO_CTRL0_ENABLE
#define AI_PLLVIDEO_CTRL0_ENABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_ENABLE_SHIFT)) & AI_PLLVIDEO_CTRL0_ENABLE_MASK)
◆ AI_PLLVIDEO_CTRL0_HOLD_RING_OFF
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK)
◆ AI_PLLVIDEO_CTRL0_PLL_REG_EN
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK)
◆ AI_PLLVIDEO_CTRL0_POWER_UP
#define AI_PLLVIDEO_CTRL0_POWER_UP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT)) & AI_PLLVIDEO_CTRL0_POWER_UP_MASK)
◆ AI_RCOSC400M_CTRL0_REF_CLK_DIV
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT)) & AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK)
◆ AI_RCOSC400M_CTRL1_HYST_MINUS
#define AI_RCOSC400M_CTRL1_HYST_MINUS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_MINUS_MASK)
◆ AI_RCOSC400M_CTRL1_HYST_PLUS
#define AI_RCOSC400M_CTRL1_HYST_PLUS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_PLUS_MASK)
◆ AI_RCOSC400M_CTRL1_TARGET_COUNT
#define AI_RCOSC400M_CTRL1_TARGET_COUNT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT)) & AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK)
◆ AI_RCOSC400M_CTRL2_OSC_TUNE_VAL
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK)
◆ AI_RCOSC400M_CTRL2_TUNE_BYP
#define AI_RCOSC400M_CTRL2_TUNE_BYP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_BYP_MASK)
◆ AI_RCOSC400M_CTRL2_TUNE_EN
#define AI_RCOSC400M_CTRL2_TUNE_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_EN_MASK)
◆ AI_RCOSC400M_CTRL2_TUNE_START
#define AI_RCOSC400M_CTRL2_TUNE_START ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_START_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_START_MASK)
◆ AI_RCOSC400M_CTRL3_CLR_ERR
#define AI_RCOSC400M_CTRL3_CLR_ERR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT)) & AI_RCOSC400M_CTRL3_CLR_ERR_MASK)
◆ AI_RCOSC400M_CTRL3_COUNT_1M_CLK
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK)
◆ AI_RCOSC400M_CTRL3_EN_1M_CLK
#define AI_RCOSC400M_CTRL3_EN_1M_CLK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK)
◆ AI_RCOSC400M_CTRL3_MUX_1M_CLK
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK)
◆ AI_RCOSC400M_STAT0_CLK1M_ERR
#define AI_RCOSC400M_STAT0_CLK1M_ERR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT)) & AI_RCOSC400M_STAT0_CLK1M_ERR_MASK)
◆ AI_RCOSC400M_STAT1_CURR_COUNT_VAL
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT)) & AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK)
◆ AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT)) & \
AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_MASK)
◆ _anatop_ai_itf
kAI_Itf_Ldo
LDO ITF.
kAI_Itf_1g
1G PLL ITF.
kAI_Itf_Audio
Audio PLL ITF.
kAI_Itf_Video
Video PLL ITF.
kAI_Itf_400m
400M OSC ITF.
kAI_Itf_Temp
Temperature Sensor ITF.
kAI_Itf_Bandgap
Bandgap ITF.
◆ _anatop_ai_reg
kAI_PHY_LDO_CTRL0
PHY LDO CTRL0 Register.
PHY LDO CTRL0 Set Register.
PHY LDO CTRL0 Clr Register.
PHY LDO CTRL0 TOG Register.
kAI_PHY_LDO_STAT0
PHY LDO STAT0 Register.
PHY LDO STAT0 Set Register.
PHY LDO STAT0 Clr Register.
PHY LDO STAT0 Tog Register.
kAI_BANDGAP_CTRL0
BANDGAP CTRL0 Register.
kAI_BANDGAP_STAT0
BANDGAP STAT0 Register.
kAI_RCOSC400M_CTRL0
RC OSC 400M CTRL0 Register.
RC OSC 400M CTRL0 SET Register.
RC OSC 400M CTRL0 CLR Register.
RC OSC 400M CTRL0 TOG Register.
kAI_RCOSC400M_CTRL1
RC OSC 400M CTRL1 Register.
RC OSC 400M CTRL1 SET Register.
RC OSC 400M CTRL1 CLR Register.
RC OSC 400M CTRL1 TOG Register.
kAI_RCOSC400M_CTRL2
RC OSC 400M CTRL2 Register.
RC OSC 400M CTRL2 SET Register.
RC OSC 400M CTRL2 CLR Register.
RC OSC 400M CTRL2 TOG Register.
kAI_RCOSC400M_CTRL3
RC OSC 400M CTRL3 Register.
RC OSC 400M CTRL3 SET Register.
RC OSC 400M CTRL3 CLR Register.
RC OSC 400M CTRL3 TOG Register.
kAI_RCOSC400M_STAT0
RC OSC 400M STAT0 Register.
RC OSC 400M STAT0 SET Register.
RC OSC 400M STAT0 CLR Register.
RC OSC 400M STAT0 TOG Register.
kAI_RCOSC400M_STAT1
RC OSC 400M STAT1 Register.
RC OSC 400M STAT1 SET Register.
RC OSC 400M STAT1 CLR Register.
RC OSC 400M STAT1 TOG Register.
kAI_RCOSC400M_STAT2
RC OSC 400M STAT2 Register.
RC OSC 400M STAT2 SET Register.
RC OSC 400M STAT2 CLR Register.
RC OSC 400M STAT2 TOG Register.
kAI_PLL1G_CTRL0
1G PLL CTRL0 Register.
kAI_PLL1G_CTRL0_SET
1G PLL CTRL0 SET Register.
kAI_PLL1G_CTRL0_CLR
1G PLL CTRL0 CLR Register.
kAI_PLL1G_CTRL1
1G PLL CTRL1 Register.
kAI_PLL1G_CTRL1_SET
1G PLL CTRL1 SET Register.
kAI_PLL1G_CTRL1_CLR
1G PLL CTRL1 CLR Register.
kAI_PLL1G_CTRL2
1G PLL CTRL2 Register.
kAI_PLL1G_CTRL2_SET
1G PLL CTRL2 SET Register.
kAI_PLL1G_CTRL2_CLR
1G PLL CTRL2 CLR Register.
kAI_PLL1G_CTRL3
1G PLL CTRL3 Register.
kAI_PLL1G_CTRL3_SET
1G PLL CTRL3 SET Register.
kAI_PLL1G_CTRL3_CLR
1G PLL CTRL3 CLR Register.
kAI_PLLAUDIO_CTRL0
AUDIO PLL CTRL0 Register.
AUDIO PLL CTRL0 SET Register.
AUDIO PLL CTRL0 CLR Register.
kAI_PLLAUDIO_CTRL1
AUDIO PLL CTRL1 Register.
AUDIO PLL CTRL1 SET Register.
AUDIO PLL CTRL1 CLR Register.
kAI_PLLAUDIO_CTRL2
AUDIO PLL CTRL2 Register.
AUDIO PLL CTRL2 SET Register.
AUDIO PLL CTRL2 CLR Register.
kAI_PLLAUDIO_CTRL3
AUDIO PLL CTRL3 Register.
AUDIO PLL CTRL3 SET Register.
AUDIO PLL CTRL3 CLR Register.
kAI_PLLVIDEO_CTRL0
VIDEO PLL CTRL0 Register.
VIDEO PLL CTRL0 SET Register.
VIDEO PLL CTRL0 CLR Register.
kAI_PLLVIDEO_CTRL1
VIDEO PLL CTRL1 Register.
VIDEO PLL CTRL1 SET Register.
VIDEO PLL CTRL1 CLR Register.
kAI_PLLVIDEO_CTRL2
VIDEO PLL CTRL2 Register.
VIDEO PLL CTRL2 SET Register.
VIDEO PLL CTRL2 CLR Register.
kAI_PLLVIDEO_CTRL3
VIDEO PLL CTRL3 Register.
VIDEO PLL CTRL3 SET Register.
VIDEO PLL CTRL3 CLR Register.
