RTEMS 6.3
Virtex 5 - MMU Support
MMU support. More...
struct  bsp_tlb_entry_t
struct  bsp_tlb_entry_t::[struct].id
struct  bsp_tlb_entry_t::[struct].hi
struct  bsp_tlb_entry_t::[struct].lo
struct  bsp_tlb_entry_t::[struct].w0
struct  bsp_tlb_entry_t::[struct].w1
struct  bsp_tlb_entry_t::[struct].w2
#define NTLBS   64
#define MMU_M_SIZE_1K   (0x00000000U)
#define MMU_M_SIZE_4K   (0x08000000U)
#define MMU_M_SIZE_16K   (0x10000000U)
#define MMU_M_SIZE_64K   (0x18000000U)
#define MMU_M_SIZE_256K   (0x20000000U)
#define MMU_M_SIZE_1M   (0x28000000U)
#define MMU_M_SIZE_16M   (0x38000000U)
#define MMU_M_SIZE_256M   (0x48000000U)
#define MMU_M_SIZE_MIN   (MMU_M_SIZE_1K)
#define MMU_M_SIZE_MAX   (MMU_M_SIZE_256M)
#define MMU_M_SIZE   (0x78000000U)
#define MMU_V_SIZE   (27)
#define MMU_M_ATTR_USER0   (0x00010000U)
#define MMU_M_ATTR_USER1   (0x00008000U)
#define MMU_M_ATTR_USER2   (0x00004000U)
#define MMU_M_ATTR_USER3   (0x00002000U)
#define MMU_M_ATTR   (0x0001e000U)
#define MMU_V_ATTR   (13)
#define MMU_M_PROP_WRITE_THROUGH   (0x00001000U)
#define MMU_M_PROP_UNCACHED   (0x00000800U)
#define MMU_M_PROP_MEM_COHERENT   (0x00000400U)
#define MMU_M_PROP_GUARDED   (0x00000200U)
#define MMU_M_PROP_LITTLE_ENDIAN   (0x00000100U)
#define MMU_M_PROP   (0x00000f00U)
#define MMU_V_PROP   (8)
#define MMU_M_PERM_USER_EXEC   (0x00000020U)
#define MMU_M_PERM_USER_WRITE   (0x00000010U)
#define MMU_M_PERM_USER_READ   (0x00000008U)
#define MMU_M_PERM_SUPER_EXEC   (0x00000004U)
#define MMU_M_PERM_SUPER_WRITE   (0x00000002U)
#define MMU_M_PERM_SUPER_READ   (0x00000001U)
#define MMU_M_PERM   (0x0000003fU)
#define MMU_V_PERM   (0)
typedef int bsp_tlb_idx_t
void bsp_mmu_dump_cache (FILE *f)
int bsp_mmu_update (bsp_tlb_idx_t key, bool quiet, FILE *f)
int bsp_mmu_initialize (void)
bsp_tlb_idx_t bsp_mmu_find_first_free (void)
bsp_tlb_idx_t bsp_mmu_write (bsp_tlb_idx_t idx, uint32_t ea, uint32_t pa, int sz, uint32_t flgs, uint32_t tid, uint32_t ts, uint32_t erpn)
bsp_tlb_idx_t bsp_mmu_match (uint32_t ea, int sz, uint32_t tid, uint32_t ts)
bsp_tlb_idx_t bsp_mmu_find (uint32_t ea, uint32_t tid, uint32_t ts)
int bsp_mmu_invalidate (bsp_tlb_idx_t key)
bsp_tlb_entry_t * bsp_mmu_cache
MMU support.
