RTEMS 6.3
CTRL0 - Fractional PLL Control Register
#define VIDEO_PLL_CTRL0_DIV_SELECT_MASK   (0x7FU)
#define VIDEO_PLL_CTRL0_DIV_SELECT_SHIFT   (0U)
#define VIDEO_PLL_CTRL0_DIV_SELECT(x)
#define VIDEO_PLL_CTRL0_ENABLE_ALT_MASK   (0x100U)
#define VIDEO_PLL_CTRL0_ENABLE_ALT_SHIFT   (8U)
#define VIDEO_PLL_CTRL0_ENABLE_ALT(x)
#define VIDEO_PLL_CTRL0_HOLD_RING_OFF_MASK   (0x2000U)
#define VIDEO_PLL_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define VIDEO_PLL_CTRL0_HOLD_RING_OFF(x)
#define VIDEO_PLL_CTRL0_POWERUP_MASK   (0x4000U)
#define VIDEO_PLL_CTRL0_POWERUP_SHIFT   (14U)
#define VIDEO_PLL_CTRL0_POWERUP(x)
#define VIDEO_PLL_CTRL0_ENABLE_MASK   (0x8000U)
#define VIDEO_PLL_CTRL0_ENABLE_SHIFT   (15U)
#define VIDEO_PLL_CTRL0_ENABLE(x)
#define VIDEO_PLL_CTRL0_BYPASS_MASK   (0x10000U)
#define VIDEO_PLL_CTRL0_BYPASS_SHIFT   (16U)
#define VIDEO_PLL_CTRL0_BYPASS(x)
#define VIDEO_PLL_CTRL0_DITHER_EN_MASK   (0x20000U)
#define VIDEO_PLL_CTRL0_DITHER_EN_SHIFT   (17U)
#define VIDEO_PLL_CTRL0_DITHER_EN(x)
#define VIDEO_PLL_CTRL0_BIAS_TRIM_MASK   (0x380000U)
#define VIDEO_PLL_CTRL0_BIAS_TRIM_SHIFT   (19U)
#define VIDEO_PLL_CTRL0_BIAS_TRIM(x)
#define VIDEO_PLL_CTRL0_PLL_REG_EN_MASK   (0x400000U)
#define VIDEO_PLL_CTRL0_PLL_REG_EN_SHIFT   (22U)
#define VIDEO_PLL_CTRL0_PLL_REG_EN(x)
#define VIDEO_PLL_CTRL0_POST_DIV_SEL_MASK   (0xE000000U)
#define VIDEO_PLL_CTRL0_POST_DIV_SEL_SHIFT   (25U)
#define VIDEO_PLL_CTRL0_POST_DIV_SEL(x)
#define VIDEO_PLL_CTRL0_BIAS_SELECT_MASK   (0x20000000U)
#define VIDEO_PLL_CTRL0_BIAS_SELECT_SHIFT   (29U)
#define VIDEO_PLL_CTRL0_BIAS_SELECT(x)
SPREAD_SPECTRUM - Fractional PLL Spread Spectrum Control Register
#define VIDEO_PLL_SPREAD_SPECTRUM_STEP_MASK   (0x7FFFU)
#define VIDEO_PLL_SPREAD_SPECTRUM_STEP_SHIFT   (0U)
#define VIDEO_PLL_SPREAD_SPECTRUM_STEP(x)
#define VIDEO_PLL_SPREAD_SPECTRUM_ENABLE_MASK   (0x8000U)
#define VIDEO_PLL_SPREAD_SPECTRUM_ENABLE_SHIFT   (15U)
#define VIDEO_PLL_SPREAD_SPECTRUM_ENABLE(x)
#define VIDEO_PLL_SPREAD_SPECTRUM_STOP_MASK   (0xFFFF0000U)
#define VIDEO_PLL_SPREAD_SPECTRUM_STOP_SHIFT   (16U)
#define VIDEO_PLL_SPREAD_SPECTRUM_STOP(x)
NUMERATOR - Fractional PLL Numerator Control Register
#define VIDEO_PLL_NUMERATOR_NUM_MASK   (0x3FFFFFFFU)
#define VIDEO_PLL_NUMERATOR_NUM_SHIFT   (0U)
#define VIDEO_PLL_NUMERATOR_NUM(x)
DENOMINATOR - Fractional PLL Denominator Control Register
#define VIDEO_PLL_DENOMINATOR_DENOM_MASK   (0x3FFFFFFFU)
#define VIDEO_PLL_DENOMINATOR_DENOM_SHIFT   (0U)
#define VIDEO_PLL_DENOMINATOR_DENOM(x)
◆ VIDEO_PLL_CTRL0_BIAS_SELECT [1/2]
#define VIDEO_PLL_CTRL0_BIAS_SELECT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_BIAS_SELECT_SHIFT)) & VIDEO_PLL_CTRL0_BIAS_SELECT_MASK)
BIAS_SELECT - BIAS_SELECT 0b0..Used in SoCs with a bias current of 10uA 0b1..Used in SoCs with a bias current of 2uA
◆ VIDEO_PLL_CTRL0_BIAS_SELECT [2/2]
Value:
◆ VIDEO_PLL_CTRL0_BIAS_TRIM [1/2]
#define VIDEO_PLL_CTRL0_BIAS_TRIM ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_BIAS_TRIM_SHIFT)) & VIDEO_PLL_CTRL0_BIAS_TRIM_MASK)
BIAS_TRIM - BIAS_TRIM
◆ VIDEO_PLL_CTRL0_BIAS_TRIM [2/2]
Value:
◆ VIDEO_PLL_CTRL0_BYPASS [1/2]
#define VIDEO_PLL_CTRL0_BYPASS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_BYPASS_SHIFT)) & VIDEO_PLL_CTRL0_BYPASS_MASK)
BYPASS - BYPASS 0b1..Bypass the PLL 0b0..No Bypass
◆ VIDEO_PLL_CTRL0_BYPASS [2/2]
Value:
◆ VIDEO_PLL_CTRL0_DITHER_EN [1/2]
#define VIDEO_PLL_CTRL0_DITHER_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_DITHER_EN_SHIFT)) & VIDEO_PLL_CTRL0_DITHER_EN_MASK)
DITHER_EN - DITHER_EN 0b0..Disable Dither 0b1..Enable Dither
◆ VIDEO_PLL_CTRL0_DITHER_EN [2/2]
Value:
◆ VIDEO_PLL_CTRL0_DIV_SELECT [1/2]
#define VIDEO_PLL_CTRL0_DIV_SELECT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_DIV_SELECT_SHIFT)) & VIDEO_PLL_CTRL0_DIV_SELECT_MASK)
DIV_SELECT - DIV_SELECT
◆ VIDEO_PLL_CTRL0_DIV_SELECT [2/2]
Value:
◆ VIDEO_PLL_CTRL0_ENABLE [1/2]
#define VIDEO_PLL_CTRL0_ENABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_ENABLE_SHIFT)) & VIDEO_PLL_CTRL0_ENABLE_MASK)
ENABLE - ENABLE 0b1..Enable the clock output 0b0..Disable the clock output
◆ VIDEO_PLL_CTRL0_ENABLE [2/2]
Value:
◆ VIDEO_PLL_CTRL0_ENABLE_ALT [1/2]
#define VIDEO_PLL_CTRL0_ENABLE_ALT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_ENABLE_ALT_SHIFT)) & VIDEO_PLL_CTRL0_ENABLE_ALT_MASK)
ENABLE_ALT - ENABLE_ALT 0b0..Disable the alternate clock output 0b1..Enable the alternate clock output which is the output of the post_divider, and cannot be bypassed
◆ VIDEO_PLL_CTRL0_ENABLE_ALT [2/2]
Value:
◆ VIDEO_PLL_CTRL0_HOLD_RING_OFF [1/2]
#define VIDEO_PLL_CTRL0_HOLD_RING_OFF ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_HOLD_RING_OFF_SHIFT)) & VIDEO_PLL_CTRL0_HOLD_RING_OFF_MASK)
HOLD_RING_OFF - PLL Start up initialization 0b0..Normal operation 0b1..Initialize PLL start up
◆ VIDEO_PLL_CTRL0_HOLD_RING_OFF [2/2]
Value:
◆ VIDEO_PLL_CTRL0_PLL_REG_EN [1/2]
#define VIDEO_PLL_CTRL0_PLL_REG_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_PLL_REG_EN_SHIFT)) & VIDEO_PLL_CTRL0_PLL_REG_EN_MASK)
PLL_REG_EN - PLL_REG_EN
◆ VIDEO_PLL_CTRL0_PLL_REG_EN [2/2]
Value:
◆ VIDEO_PLL_CTRL0_POST_DIV_SEL [1/2]
#define VIDEO_PLL_CTRL0_POST_DIV_SEL ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_POST_DIV_SEL_SHIFT)) & VIDEO_PLL_CTRL0_POST_DIV_SEL_MASK)
POST_DIV_SEL - Post Divide Select 0b000..Divide by 1 0b001..Divide by 2 0b010..Divide by 4 0b011..Divide by 8 0b100..Divide by 16 0b101..Divide by 32
◆ VIDEO_PLL_CTRL0_POST_DIV_SEL [2/2]
Value:
◆ VIDEO_PLL_CTRL0_POWERUP [1/2]
#define VIDEO_PLL_CTRL0_POWERUP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_CTRL0_POWERUP_SHIFT)) & VIDEO_PLL_CTRL0_POWERUP_MASK)
POWERUP - POWERUP 0b1..Power Up the PLL 0b0..Power down the PLL
◆ VIDEO_PLL_CTRL0_POWERUP [2/2]
Value:
◆ VIDEO_PLL_DENOMINATOR_DENOM [1/2]
#define VIDEO_PLL_DENOMINATOR_DENOM ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_DENOMINATOR_DENOM_SHIFT)) & VIDEO_PLL_DENOMINATOR_DENOM_MASK)
DENOM - Denominator
◆ VIDEO_PLL_DENOMINATOR_DENOM [2/2]
Value:
DENOM - Denominator
◆ VIDEO_PLL_NUMERATOR_NUM [1/2]
#define VIDEO_PLL_NUMERATOR_NUM ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_NUMERATOR_NUM_SHIFT)) & VIDEO_PLL_NUMERATOR_NUM_MASK)
NUM - Numerator
◆ VIDEO_PLL_NUMERATOR_NUM [2/2]
Value:
NUM - Numerator
◆ VIDEO_PLL_SPREAD_SPECTRUM_ENABLE [1/2]
#define VIDEO_PLL_SPREAD_SPECTRUM_ENABLE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_SPREAD_SPECTRUM_ENABLE_SHIFT)) & VIDEO_PLL_SPREAD_SPECTRUM_ENABLE_MASK)
ENABLE - Enable
◆ VIDEO_PLL_SPREAD_SPECTRUM_ENABLE [2/2]
Value:
ENABLE - Enable
◆ VIDEO_PLL_SPREAD_SPECTRUM_STEP [1/2]
#define VIDEO_PLL_SPREAD_SPECTRUM_STEP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_SPREAD_SPECTRUM_STEP_SHIFT)) & VIDEO_PLL_SPREAD_SPECTRUM_STEP_MASK)
STEP - Step
◆ VIDEO_PLL_SPREAD_SPECTRUM_STEP [2/2]
Value:
STEP - Step
◆ VIDEO_PLL_SPREAD_SPECTRUM_STOP [1/2]
#define VIDEO_PLL_SPREAD_SPECTRUM_STOP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << VIDEO_PLL_SPREAD_SPECTRUM_STOP_SHIFT)) & VIDEO_PLL_SPREAD_SPECTRUM_STOP_MASK)
STOP - Stop
◆ VIDEO_PLL_SPREAD_SPECTRUM_STOP [2/2]
Value:
STOP - Stop
